perf: Made +/-0.5% threshold for caring about pixel aspect ratio consistent
fix: Made PIXASPECT= output a little more stringent (+/-0.1% rather than 1%)
Added precautionary testing when checking for FHUGE
Fixed missing header from findmaterial() move
Backed out unintentional commit
Minor improvements -- motion blur still incorrect
Minor code clean-ups and efficiency improvements
Fixed bug in distant sources (sky, etc.)
Eliminated unnecessary bits of code
Changed octree reload so fonts and data files not lost.
Eliminated black pixels when no neighbor samples are acceptable
Fixed comments
Fixed infinite loop introduced during "beautification" of for loops
Continued ANSIfication.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
