root/radiance/ray/src/util/ranimove.h
Revision: 3.2
Committed: Tue Feb 25 02:47:24 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.1: +2 -57 lines
# User Rev Content
1 greg 3.2 /* RCSid $Id$ */
2 greg 3.1 /*
3     * ranimove.h
4     *
5     * Radiance object animation program
6     *
7     * The main difference between this program and ranimate is that
8     * ranimove is optimized for object motion, and includes a complete
9     * blur simulation. We also have a number of clever schemes
10     * for optimizing the computation, allowing rendering time
11     * per frame and noticeable difference threshold to be specified.
12     * Parallel rendering uses multiple processors on the local host,
13     * and network rendering is not directly supported. (However, no
14     * one says you can't run ranimove on other machines at the
15     * same time; just be careful not to overlap frames.)
16     *
17     * See the ranimove(1) man page for further details.
18     */
19
20 greg 3.2 #include "copyright.h"
21 greg 3.1
22     #include "ray.h"
23     #include "view.h"
24     #include "vars.h"
25     /* input variables (alphabetical by name) */
26     #define BASENAME 0 /* output image base name */
27     #define END 1 /* number of animation frames */
28     #define EXPOSURE 2 /* how to compute exposure */
29     #define HIGHQ 3 /* high quality setting */
30     #define LOWQ 4 /* low quality setting */
31     #define MBLUR 5 /* motion blur parameter */
32     #define MOVE 6 /* object movement */
33     #define OCONV 7 /* oconv options */
34     #define OCTREEF 8 /* octree file name */
35     #define RATE 9 /* frame rate (fps) */
36     #define RESOLUTION 10 /* desired final resolution */
37     #define RIF 11 /* rad input file */
38     #define VIEWFILE 12 /* animation frame views */
39
40     #define NV_INIT 13 /* number of variables */
41
42     #define VV_INIT { \
43     {"BASENAME", 3, 0, NULL, onevalue}, \
44     {"END", 3, 0, NULL, intvalue}, \
45     {"EXPOSURE", 3, 0, NULL, onevalue}, \
46     {"highq", 2, 0, NULL, catvalues}, \
47     {"lowq", 2, 0, NULL, catvalues}, \
48     {"MBLUR", 2, 0, NULL, fltvalue}, \
49     {"move", 2, 0, NULL, NULL}, \
50     {"oconv", 2, 0, NULL, catvalues}, \
51     {"OCTREE", 3, 0, NULL, onevalue}, \
52     {"RATE", 2, 0, NULL, fltvalue}, \
53     {"RESOLUTION", 3, 0, NULL, onevalue}, \
54     {"RIF", 3, 0, NULL, onevalue}, \
55     {"VIEWFILE", 2, 0, NULL, onevalue} \
56     }
57
58     struct ObjMove {
59     int parent; /* parent object index */
60     char name[64]; /* object name */
61     char xf_file[128]; /* transform file name */
62     char spec[512]; /* object file or command */
63     char prio_file[128]; /* priority file name */
64     int cfm; /* current frame number */
65     char xfs[512]; /* part transform arguments */
66     MAT4 xfm; /* part transform matrix */
67     MAT4 cxfm; /* combined transform matrix */
68     MAT4 bxfm; /* transform to previous frame */
69     double prio; /* part priority */
70     double cprio; /* combined priority */
71     };
72
73     extern int silent; /* run silently? */
74
75     extern int quickstart; /* time initial frame as well? */
76
77     extern int nprocs; /* number of rendering processes */
78
79     extern int rtperfrm; /* seconds to spend per frame */
80
81     extern double ndthresh; /* noticeable difference threshold */
82     extern int ndtset; /* did user set ndthresh? */
83
84     extern int fbeg; /* starting frame */
85     extern int fend; /* ending frame */
86     extern int fcur; /* current frame being rendered */
87
88     extern char lorendoptf[]; /* LQ options file */
89     extern RAYPARAMS lorendparams; /* LQ rendering parameters */
90     extern char hirendoptf[]; /* HQ options file */
91     extern RAYPARAMS hirendparams; /* HQ rendering parameters */
92     extern RAYPARAMS *curparams; /* current parameter settings */
93     extern int twolevels; /* low and high quality differ */
94
95     extern double mblur; /* vflt(MBLUR) */
96     extern double rate; /* vflt(RATE) */
97
98     extern char objtmpf[]; /* object temporary file */
99
100     extern struct ObjMove *obj_move; /* object movements */
101
102     extern int haveprio; /* high-level saliency specified */
103
104     extern int gargc; /* global argc for printargs */
105     extern char **gargv; /* global argv for printargs */
106
107     VIEW *getview();
108     int countviews();
109     int getmove();
110     char *getexp(), *getoctspec(), *getobjname(), *getxf();
111     double expspec_val(), obj_prio();
112     void setdefaults(), setmove(), animate(), getradfile(), setrendparams();
113     void init_frame(), filter_frame(), send_frame(), free_frame();
114     int refine_frame();
115     double getTime();
116
117     /*************************************************************************
118     * Frame rendering stuff (defined in ranimove1.c and ranimove2.c)
119     */
120     /* enumerated accuracy map values */
121     #define ANOVAL 0 /* unevaluated pixel */
122     #define ALOWQ 1 /* single low-quality sample */
123     #define AHIGHQ 2 /* single high-quality sample */
124     #define AMIN 3 /* start of error lookup table */
125     #define ADISTANT 255 /* ray went off to infinity */
126
127     extern double acctab[256]; /* accuracy value table */
128
129     extern int hres, vres; /* frame resolution (fcur) */
130     extern double pixaspect; /* pixel aspect ratio */
131
132     extern VIEW vw; /* view for this frame */
133     extern COLOR *cbuffer; /* color at each pixel */
134     extern float *zbuffer; /* depth at each pixel */
135     extern OBJECT *obuffer; /* object id at each pixel */
136     extern short *xmbuffer; /* x motion at each pixel */
137     extern short *ymbuffer; /* y motion at each pixel */
138     extern BYTE *abuffer; /* accuracy at each pixel */
139     extern BYTE *sbuffer; /* sample count per pixel */
140
141     extern VIEW vwprev; /* last frame's view */
142     extern COLOR *cprev; /* last frame colors */
143     extern float *zprev; /* last frame depth */
144     extern OBJECT *oprev; /* last frame objects */
145     extern BYTE *aprev; /* last frame accuracy */
146
147     extern float *cerrmap; /* conspicuous error map */
148     extern int cerrzero; /* is all of cerrmap zero? */
149     extern COLOR *val2map; /* value-squared map for variance */
150
151     extern double frm_stop; /* when to stop rendering this frame */
152
153     extern double hlsmax; /* maximum high-level saliency */
154
155     #define CSF_SMN (1./0.82) /* 1/avg_tracking_efficacy */
156
157     #define outbuffer cprev /* used to hold final output */
158     #define wbuffer zprev /* used for final filtering */
159
160     #define fndx(x,y) ((y)*hres + (x))
161
162     #define MO_UNK -32768 /* unknown motion value */
163
164     #define FOV_DEG 1.0 /* foveal radius (degrees) */
165
166     #define LOG_E1 (-0.0233) /* ln(0.977) */
167     #define errorf(i) exp(LOG_E1*((i)-AMIN))
168     #define errori(e) (int)(log(e)*(1./LOG_E1) + (AMIN+.5))
169
170     #define NSAMPOK 5 /* samples enough for error estimation */
171
172     #define NPINTERP 4 /* number of pixels to interpolate */
173
174     #define ATIDIFF 7 /* error difference for time extrapolation */
175
176     void write_map(), sample_pos(), comp_frame_error(), conspicuity();
177     int getclosest(), getambcolor(), refine_first();
178     double sample_wt(), estimaterr(), comperr();
