root/radiance/ray/src/util/ranimove.h
Revision: 3.4
Committed: Fri Jun 27 11:32:12 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 3.3: +14 -1 lines
Continued ANSIfication.
1 /* RCSid $Id: ranimove.h,v 3.3 2003/06/27 06:53:23 greg Exp $ */
2 /*
3 * ranimove.h
4 *
5 * Radiance object animation program
6 *
7 * The main difference between this program and ranimate is that
8 * ranimove is optimized for object motion, and includes a complete
9 * blur simulation. We also have a number of clever schemes
10 * for optimizing the computation, allowing rendering time
11 * per frame and noticeable difference threshold to be specified.
12 * Parallel rendering uses multiple processors on the local host,
13 * and network rendering is not directly supported. (However, no
14 * one says you can't run ranimove on other machines at the
15 * same time; just be careful not to overlap frames.)
16 *
17 * See the ranimove(1) man page for further details.
18 */
19 #ifndef _RAD_RANIMOVE_H_
20 #define _RAD_RANIMOVE_H_
21 #ifdef __cplusplus
22 extern "C" {
23 #endif
24
25
26 #include "ray.h"
27 #include "view.h"
28 #include "vars.h"
29 /* input variables (alphabetical by name) */
30 #define BASENAME 0 /* output image base name */
31 #define END 1 /* number of animation frames */
32 #define EXPOSURE 2 /* how to compute exposure */
33 #define HIGHQ 3 /* high quality setting */
34 #define LOWQ 4 /* low quality setting */
35 #define MBLUR 5 /* motion blur parameter */
36 #define MOVE 6 /* object movement */
37 #define OCONV 7 /* oconv options */
38 #define OCTREEF 8 /* octree file name */
39 #define RATE 9 /* frame rate (fps) */
40 #define RESOLUTION 10 /* desired final resolution */
41 #define RIF 11 /* rad input file */
42 #define VIEWFILE 12 /* animation frame views */
43
44 #define NV_INIT 13 /* number of variables */
45
46 #define VV_INIT { \
47 {"BASENAME", 3, 0, NULL, onevalue}, \
48 {"END", 3, 0, NULL, intvalue}, \
49 {"EXPOSURE", 3, 0, NULL, onevalue}, \
50 {"highq", 2, 0, NULL, catvalues}, \
51 {"lowq", 2, 0, NULL, catvalues}, \
52 {"MBLUR", 2, 0, NULL, fltvalue}, \
53 {"move", 2, 0, NULL, NULL}, \
54 {"oconv", 2, 0, NULL, catvalues}, \
55 {"OCTREE", 3, 0, NULL, onevalue}, \
56 {"RATE", 2, 0, NULL, fltvalue}, \
57 {"RESOLUTION", 3, 0, NULL, onevalue}, \
58 {"RIF", 3, 0, NULL, onevalue}, \
59 {"VIEWFILE", 2, 0, NULL, onevalue} \
60 }
61
62 struct ObjMove {
63 int parent; /* parent object index */
64 char name[64]; /* object name */
65 char xf_file[128]; /* transform file name */
66 char spec[512]; /* object file or command */
67 char prio_file[128]; /* priority file name */
68 int cfm; /* current frame number */
69 char xfs[512]; /* part transform arguments */
70 MAT4 xfm; /* part transform matrix */
71 MAT4 cxfm; /* combined transform matrix */
72 MAT4 bxfm; /* transform to previous frame */
73 double prio; /* part priority */
74 double cprio; /* combined priority */
75 };
76
77 extern int silent; /* run silently? */
78
79 extern int quickstart; /* time initial frame as well? */
80
81 extern int nprocs; /* number of rendering processes */
82
83 extern int rtperfrm; /* seconds to spend per frame */
84
85 extern double ndthresh; /* noticeable difference threshold */
86 extern int ndtset; /* did user set ndthresh? */
87
88 extern int fbeg; /* starting frame */
89 extern int fend; /* ending frame */
90 extern int fcur; /* current frame being rendered */
91
92 extern char lorendoptf[]; /* LQ options file */
93 extern RAYPARAMS lorendparams; /* LQ rendering parameters */
94 extern char hirendoptf[]; /* HQ options file */
95 extern RAYPARAMS hirendparams; /* HQ rendering parameters */
96 extern RAYPARAMS *curparams; /* current parameter settings */
97 extern int twolevels; /* low and high quality differ */
98
99 extern double mblur; /* vflt(MBLUR) */
100 extern double rate; /* vflt(RATE) */
101
102 extern char objtmpf[]; /* object temporary file */
103
104 extern struct ObjMove *obj_move; /* object movements */
105
106 extern int haveprio; /* high-level saliency specified */
107
108 extern int gargc; /* global argc for printargs */
109 extern char **gargv; /* global argv for printargs */
110
111 VIEW *getview();
112 int countviews();
113 int getmove();
114 char *getexp(), *getoctspec(), *getobjname(), *getxf();
115 double expspec_val(), obj_prio();
116 void setdefaults(), setmove(), animate(), getradfile(), setrendparams();
117 void init_frame(), filter_frame(), send_frame(), free_frame();
118 int refine_frame();
119 double getTime();
120
121 /*************************************************************************
122 * Frame rendering stuff (defined in ranimove1.c and ranimove2.c)
123 */
124 /* enumerated accuracy map values */
125 #define ANOVAL 0 /* unevaluated pixel */
126 #define ALOWQ 1 /* single low-quality sample */
127 #define AHIGHQ 2 /* single high-quality sample */
128 #define AMIN 3 /* start of error lookup table */
129 #define ADISTANT 255 /* ray went off to infinity */
130
131 extern double acctab[256]; /* accuracy value table */
132
133 extern int hres, vres; /* frame resolution (fcur) */
134 extern double pixaspect; /* pixel aspect ratio */
135
136 extern VIEW vw; /* view for this frame */
137 extern COLOR *cbuffer; /* color at each pixel */
138 extern float *zbuffer; /* depth at each pixel */
139 extern OBJECT *obuffer; /* object id at each pixel */
140 extern short *xmbuffer; /* x motion at each pixel */
141 extern short *ymbuffer; /* y motion at each pixel */
142 extern BYTE *abuffer; /* accuracy at each pixel */
143 extern BYTE *sbuffer; /* sample count per pixel */
144
145 extern VIEW vwprev; /* last frame's view */
146 extern COLOR *cprev; /* last frame colors */
147 extern float *zprev; /* last frame depth */
148 extern OBJECT *oprev; /* last frame objects */
149 extern BYTE *aprev; /* last frame accuracy */
150
151 extern float *cerrmap; /* conspicuous error map */
152 extern int cerrzero; /* is all of cerrmap zero? */
153 extern COLOR *val2map; /* value-squared map for variance */
154
155 extern double frm_stop; /* when to stop rendering this frame */
156
157 extern double hlsmax; /* maximum high-level saliency */
158
159 #define CSF_SMN (1./0.82) /* 1/avg_tracking_efficacy */
160
161 #define outbuffer cprev /* used to hold final output */
162 #define wbuffer zprev /* used for final filtering */
163
164 #define fndx(x,y) ((y)*hres + (x))
165
166 #define MO_UNK -32768 /* unknown motion value */
167
168 #define FOV_DEG 1.0 /* foveal radius (degrees) */
169
170 #define LOG_E1 (-0.0233) /* ln(0.977) */
171 #define errorf(i) exp(LOG_E1*((i)-AMIN))
172 #define errori(e) (int)(log(e)*(1./LOG_E1) + (AMIN+.5))
173
174 #define NSAMPOK 5 /* samples enough for error estimation */
175
176 #define NPINTERP 4 /* number of pixels to interpolate */
177
178 #define ATIDIFF 7 /* error difference for time extrapolation */
179
180 void write_map(), sample_pos(), comp_frame_error(), conspicuity();
181 int getclosest(), getambcolor(), refine_first();
182 double sample_wt(), estimaterr(), comperr();
183
184
185 #ifdef __cplusplus
186 }
187 #endif
188 #endif /* _RAD_RANIMOVE_H_ */
189
