root/radiance/ray/src/util/ranimove.h
Revision: 3.2
Committed: Tue Feb 25 02:47:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.1: +2 -57 lines
1 /* RCSid $Id$ */
2 /*
3 * ranimove.h
4 *
5 * Radiance object animation program
6 *
7 * The main difference between this program and ranimate is that
8 * ranimove is optimized for object motion, and includes a complete
9 * blur simulation. We also have a number of clever schemes
10 * for optimizing the computation, allowing rendering time
11 * per frame and noticeable difference threshold to be specified.
12 * Parallel rendering uses multiple processors on the local host,
13 * and network rendering is not directly supported. (However, no
14 * one says you can't run ranimove on other machines at the
15 * same time; just be careful not to overlap frames.)
16 *
17 * See the ranimove(1) man page for further details.
18 */
19
20 #include "copyright.h"
21
22 #include "ray.h"
23 #include "view.h"
24 #include "vars.h"
25 /* input variables (alphabetical by name) */
26 #define BASENAME 0 /* output image base name */
27 #define END 1 /* number of animation frames */
28 #define EXPOSURE 2 /* how to compute exposure */
29 #define HIGHQ 3 /* high quality setting */
30 #define LOWQ 4 /* low quality setting */
31 #define MBLUR 5 /* motion blur parameter */
32 #define MOVE 6 /* object movement */
33 #define OCONV 7 /* oconv options */
34 #define OCTREEF 8 /* octree file name */
35 #define RATE 9 /* frame rate (fps) */
36 #define RESOLUTION 10 /* desired final resolution */
37 #define RIF 11 /* rad input file */
38 #define VIEWFILE 12 /* animation frame views */
39
40 #define NV_INIT 13 /* number of variables */
41
42 #define VV_INIT { \
43 {"BASENAME", 3, 0, NULL, onevalue}, \
44 {"END", 3, 0, NULL, intvalue}, \
45 {"EXPOSURE", 3, 0, NULL, onevalue}, \
46 {"highq", 2, 0, NULL, catvalues}, \
47 {"lowq", 2, 0, NULL, catvalues}, \
48 {"MBLUR", 2, 0, NULL, fltvalue}, \
49 {"move", 2, 0, NULL, NULL}, \
50 {"oconv", 2, 0, NULL, catvalues}, \
51 {"OCTREE", 3, 0, NULL, onevalue}, \
52 {"RATE", 2, 0, NULL, fltvalue}, \
53 {"RESOLUTION", 3, 0, NULL, onevalue}, \
54 {"RIF", 3, 0, NULL, onevalue}, \
55 {"VIEWFILE", 2, 0, NULL, onevalue} \
56 }
57
58 struct ObjMove {
59 int parent; /* parent object index */
60 char name[64]; /* object name */
61 char xf_file[128]; /* transform file name */
62 char spec[512]; /* object file or command */
63 char prio_file[128]; /* priority file name */
64 int cfm; /* current frame number */
65 char xfs[512]; /* part transform arguments */
66 MAT4 xfm; /* part transform matrix */
67 MAT4 cxfm; /* combined transform matrix */
68 MAT4 bxfm; /* transform to previous frame */
69 double prio; /* part priority */
70 double cprio; /* combined priority */
71 };
72
73 extern int silent; /* run silently? */
74
75 extern int quickstart; /* time initial frame as well? */
76
77 extern int nprocs; /* number of rendering processes */
78
79 extern int rtperfrm; /* seconds to spend per frame */
80
81 extern double ndthresh; /* noticeable difference threshold */
82 extern int ndtset; /* did user set ndthresh? */
83
84 extern int fbeg; /* starting frame */
85 extern int fend; /* ending frame */
86 extern int fcur; /* current frame being rendered */
87
88 extern char lorendoptf[]; /* LQ options file */
89 extern RAYPARAMS lorendparams; /* LQ rendering parameters */
90 extern char hirendoptf[]; /* HQ options file */
91 extern RAYPARAMS hirendparams; /* HQ rendering parameters */
92 extern RAYPARAMS *curparams; /* current parameter settings */
93 extern int twolevels; /* low and high quality differ */
94
95 extern double mblur; /* vflt(MBLUR) */
96 extern double rate; /* vflt(RATE) */
97
98 extern char objtmpf[]; /* object temporary file */
99
100 extern struct ObjMove *obj_move; /* object movements */
101
102 extern int haveprio; /* high-level saliency specified */
103
104 extern int gargc; /* global argc for printargs */
105 extern char **gargv; /* global argv for printargs */
106
107 VIEW *getview();
108 int countviews();
109 int getmove();
110 char *getexp(), *getoctspec(), *getobjname(), *getxf();
111 double expspec_val(), obj_prio();
112 void setdefaults(), setmove(), animate(), getradfile(), setrendparams();
113 void init_frame(), filter_frame(), send_frame(), free_frame();
114 int refine_frame();
115 double getTime();
116
117 /*************************************************************************
118 * Frame rendering stuff (defined in ranimove1.c and ranimove2.c)
119 */
120 /* enumerated accuracy map values */
121 #define ANOVAL 0 /* unevaluated pixel */
122 #define ALOWQ 1 /* single low-quality sample */
123 #define AHIGHQ 2 /* single high-quality sample */
124 #define AMIN 3 /* start of error lookup table */
125 #define ADISTANT 255 /* ray went off to infinity */
126
127 extern double acctab[256]; /* accuracy value table */
128
129 extern int hres, vres; /* frame resolution (fcur) */
130 extern double pixaspect; /* pixel aspect ratio */
131
132 extern VIEW vw; /* view for this frame */
133 extern COLOR *cbuffer; /* color at each pixel */
134 extern float *zbuffer; /* depth at each pixel */
135 extern OBJECT *obuffer; /* object id at each pixel */
136 extern short *xmbuffer; /* x motion at each pixel */
137 extern short *ymbuffer; /* y motion at each pixel */
138 extern BYTE *abuffer; /* accuracy at each pixel */
139 extern BYTE *sbuffer; /* sample count per pixel */
140
141 extern VIEW vwprev; /* last frame's view */
142 extern COLOR *cprev; /* last frame colors */
143 extern float *zprev; /* last frame depth */
144 extern OBJECT *oprev; /* last frame objects */
145 extern BYTE *aprev; /* last frame accuracy */
146
147 extern float *cerrmap; /* conspicuous error map */
148 extern int cerrzero; /* is all of cerrmap zero? */
149 extern COLOR *val2map; /* value-squared map for variance */
150
151 extern double frm_stop; /* when to stop rendering this frame */
152
153 extern double hlsmax; /* maximum high-level saliency */
154
155 #define CSF_SMN (1./0.82) /* 1/avg_tracking_efficacy */
156
157 #define outbuffer cprev /* used to hold final output */
158 #define wbuffer zprev /* used for final filtering */
159
160 #define fndx(x,y) ((y)*hres + (x))
161
162 #define MO_UNK -32768 /* unknown motion value */
163
164 #define FOV_DEG 1.0 /* foveal radius (degrees) */
165
166 #define LOG_E1 (-0.0233) /* ln(0.977) */
167 #define errorf(i) exp(LOG_E1*((i)-AMIN))
168 #define errori(e) (int)(log(e)*(1./LOG_E1) + (AMIN+.5))
169
170 #define NSAMPOK 5 /* samples enough for error estimation */
171
172 #define NPINTERP 4 /* number of pixels to interpolate */
173
174 #define ATIDIFF 7 /* error difference for time extrapolation */
175
176 void write_map(), sample_pos(), comp_frame_error(), conspicuity();
177 int getclosest(), getambcolor(), refine_first();
178 double sample_wt(), estimaterr(), comperr();
