--- ray/src/util/ranimove.h 2004/03/26 21:36:20 3.6 +++ ray/src/util/ranimove.h 2012/10/05 00:59:38 3.9 @@ -1,4 +1,4 @@ -/* RCSid $Id: ranimove.h,v 3.6 2004/03/26 21:36:20 schorsch Exp $ */ +/* RCSid $Id: ranimove.h,v 3.9 2012/10/05 00:59:38 greg Exp $ */ /* * ranimove.h * @@ -34,15 +34,17 @@ extern "C" { #define HIGHQ 3 /* high quality setting */ #define LOWQ 4 /* low quality setting */ #define MBLUR 5 /* motion blur parameter */ -#define MOVE 6 /* object movement */ -#define OCONV 7 /* oconv options */ -#define OCTREEF 8 /* octree file name */ -#define RATE 9 /* frame rate (fps) */ -#define RESOLUTION 10 /* desired final resolution */ -#define RIF 11 /* rad input file */ -#define VIEWFILE 12 /* animation frame views */ +#define MNAME 6 /* motion vector file */ +#define MOVE 7 /* object movement */ +#define OCONV 8 /* oconv options */ +#define OCTREEF 9 /* octree file name */ +#define RATE 10 /* frame rate (fps) */ +#define RESOLUTION 11 /* desired final resolution */ +#define RIF 12 /* rad input file */ +#define VIEWFILE 13 /* animation frame views */ +#define ZNAME 14 /* depth file */ -#define NV_INIT 13 /* number of variables */ +#define NV_INIT 15 /* number of variables */ #define VV_INIT { \ {"BASENAME", 3, 0, NULL, onevalue}, \ @@ -51,13 +53,15 @@ extern "C" { {"highq", 2, 0, NULL, catvalues}, \ {"lowq", 2, 0, NULL, catvalues}, \ {"MBLUR", 2, 0, NULL, fltvalue}, \ + {"MNAME", 2, 0, NULL, onevalue}, \ {"move", 2, 0, NULL, NULL}, \ {"oconv", 2, 0, NULL, catvalues}, \ {"OCTREE", 3, 0, NULL, onevalue}, \ {"RATE", 2, 0, NULL, fltvalue}, \ {"RESOLUTION", 3, 0, NULL, onevalue}, \ {"RIF", 3, 0, NULL, onevalue}, \ - {"VIEWFILE", 2, 0, NULL, onevalue} \ + {"VIEWFILE", 2, 0, NULL, onevalue}, \ + {"ZNAME", 2, 0, NULL, onevalue} \ } struct ObjMove { @@ -130,14 +134,15 @@ extern float *zbuffer; /* depth at each pixel */ extern OBJECT *obuffer; /* object id at each pixel */ extern short *xmbuffer; /* x motion at each pixel */ extern short *ymbuffer; /* y motion at each pixel */ -extern BYTE *abuffer; /* accuracy at each pixel */ -extern BYTE *sbuffer; /* sample count per pixel */ +extern uby8 *abuffer; /* accuracy at each pixel */ +extern uby8 *sbuffer; /* sample count per pixel */ +extern COLOR *outbuffer; /* output buffer (may equal cbuffer) */ extern VIEW vwprev; /* last frame's view */ extern COLOR *cprev; /* last frame colors */ extern float *zprev; /* last frame depth */ extern OBJECT *oprev; /* last frame objects */ -extern BYTE *aprev; /* last frame accuracy */ +extern uby8 *aprev; /* last frame accuracy */ extern float *cerrmap; /* conspicuous error map */ extern int cerrzero; /* is all of cerrmap zero? */ @@ -149,7 +154,6 @@ extern double hlsmax; /* maximum high-level saliency #define CSF_SMN (1./0.82) /* 1/avg_tracking_efficacy */ -#define outbuffer cprev /* used to hold final output */ #define wbuffer zprev /* used for final filtering */ #define fndx(x,y) ((y)*hres + (x)) @@ -173,14 +177,14 @@ extern void init_frame(void); extern void filter_frame(void); extern void send_frame(void); extern void free_frame(void); -extern void write_map(float *mp, char *fn); -extern void sample_pos(double hv[2], int x, int y, int sn); +extern void write_map(float *mp, char *fn); +extern void sample_pos(double hv[2], int x, int y, int sn); extern void comp_frame_error(void); -extern int getclosest(int *iarr, int nc, int x, int y); -extern int getambcolor(COLOR clr, int obj); -extern double sample_wt(int xo, int yo); -extern double estimaterr(COLOR cs, COLOR cs2, int ns, int ns0); -extern double comperr(int *neigh, int nc, int ns0); +extern int getclosest(int *iarr, int nc, int x, int y); +extern int getambcolor(COLOR clr, int obj); +extern double sample_wt(int xo, int yo); +extern double estimaterr(COLOR cs, COLOR cs2, int ns, int ns0); +extern double comperr(int *neigh, int nc, int ns0); /* ranimove2.c */ extern int refine_first(); @@ -189,8 +193,8 @@ extern int refine_frame(int pass); /* ranimove.c */ extern double getTime(void); -extern double obj_prio(OBJECT obj); -extern int getmove(OBJECT obj); +extern double obj_prio(OBJECT obj); +extern int getmove(OBJECT obj); extern char * getoctspec(int n); extern double expspec_val(char *s); extern char *getexp(int n); /* XXX partly duplicated function */
