root/radiance/ray/src/util/ranimove.h
Revision: 3.10
Committed: Fri Oct 5 01:03:22 2012 UTC (11 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Backed out unintentional commit
# User Rev Content
1 greg 3.9 /* RCSid $Id: ranimove.h,v 3.8 2012/09/28 22:20:49 greg Exp $ */
2 greg 3.1 /*
3     * ranimove.h
4     *
5     * Radiance object animation program
6     *
7     * The main difference between this program and ranimate is that
8     * ranimove is optimized for object motion, and includes a complete
9     * blur simulation. We also have a number of clever schemes
10     * for optimizing the computation, allowing rendering time
11     * per frame and noticeable difference threshold to be specified.
12     * Parallel rendering uses multiple processors on the local host,
13     * and network rendering is not directly supported. (However, no
14     * one says you can't run ranimove on other machines at the
15     * same time; just be careful not to overlap frames.)
16     *
17     * See the ranimove(1) man page for further details.
18     */
19 schorsch 3.4 #ifndef _RAD_RANIMOVE_H_
20     #define _RAD_RANIMOVE_H_
21 schorsch 3.5
22     #include "ray.h"
23     #include "view.h"
24     #include "vars.h"
25
26 schorsch 3.4 #ifdef __cplusplus
27     extern "C" {
28     #endif
29
30 greg 3.1 /* input variables (alphabetical by name) */
31     #define BASENAME 0 /* output image base name */
32     #define END 1 /* number of animation frames */
33     #define EXPOSURE 2 /* how to compute exposure */
34     #define HIGHQ 3 /* high quality setting */
35     #define LOWQ 4 /* low quality setting */
36     #define MBLUR 5 /* motion blur parameter */
37 greg 3.8 #define MNAME 6 /* motion vector file */
38     #define MOVE 7 /* object movement */
39     #define OCONV 8 /* oconv options */
40     #define OCTREEF 9 /* octree file name */
41     #define RATE 10 /* frame rate (fps) */
42     #define RESOLUTION 11 /* desired final resolution */
43     #define RIF 12 /* rad input file */
44     #define VIEWFILE 13 /* animation frame views */
45     #define ZNAME 14 /* depth file */
46 greg 3.1
47 greg 3.8 #define NV_INIT 15 /* number of variables */
48 greg 3.1
49     #define VV_INIT { \
50     {"BASENAME", 3, 0, NULL, onevalue}, \
51     {"END", 3, 0, NULL, intvalue}, \
52     {"EXPOSURE", 3, 0, NULL, onevalue}, \
53     {"highq", 2, 0, NULL, catvalues}, \
54     {"lowq", 2, 0, NULL, catvalues}, \
55     {"MBLUR", 2, 0, NULL, fltvalue}, \
56 greg 3.8 {"MNAME", 2, 0, NULL, onevalue}, \
57 greg 3.1 {"move", 2, 0, NULL, NULL}, \
58     {"oconv", 2, 0, NULL, catvalues}, \
59     {"OCTREE", 3, 0, NULL, onevalue}, \
60     {"RATE", 2, 0, NULL, fltvalue}, \
61     {"RESOLUTION", 3, 0, NULL, onevalue}, \
62     {"RIF", 3, 0, NULL, onevalue}, \
63 greg 3.8 {"VIEWFILE", 2, 0, NULL, onevalue}, \
64     {"ZNAME", 2, 0, NULL, onevalue} \
65 greg 3.1 }
66
67     struct ObjMove {
68     int parent; /* parent object index */
69     char name[64]; /* object name */
70     char xf_file[128]; /* transform file name */
71     char spec[512]; /* object file or command */
72     char prio_file[128]; /* priority file name */
73     int cfm; /* current frame number */
74     char xfs[512]; /* part transform arguments */
75     MAT4 xfm; /* part transform matrix */
76     MAT4 cxfm; /* combined transform matrix */
77     MAT4 bxfm; /* transform to previous frame */
78     double prio; /* part priority */
79     double cprio; /* combined priority */
80     };
81
82     extern int silent; /* run silently? */
83
84     extern int quickstart; /* time initial frame as well? */
85
86     extern int nprocs; /* number of rendering processes */
87
88     extern int rtperfrm; /* seconds to spend per frame */
89
90     extern double ndthresh; /* noticeable difference threshold */
91     extern int ndtset; /* did user set ndthresh? */
92
93     extern int fbeg; /* starting frame */
94     extern int fend; /* ending frame */
95     extern int fcur; /* current frame being rendered */
96
97     extern char lorendoptf[]; /* LQ options file */
98     extern RAYPARAMS lorendparams; /* LQ rendering parameters */
99     extern char hirendoptf[]; /* HQ options file */
100     extern RAYPARAMS hirendparams; /* HQ rendering parameters */
101     extern RAYPARAMS *curparams; /* current parameter settings */
102     extern int twolevels; /* low and high quality differ */
103
104     extern double mblur; /* vflt(MBLUR) */
105     extern double rate; /* vflt(RATE) */
106
107     extern char objtmpf[]; /* object temporary file */
108
109     extern struct ObjMove *obj_move; /* object movements */
110
111     extern int haveprio; /* high-level saliency specified */
112
113     extern int gargc; /* global argc for printargs */
114     extern char **gargv; /* global argv for printargs */
115
116     /*************************************************************************
117     * Frame rendering stuff (defined in ranimove1.c and ranimove2.c)
118     */
119     /* enumerated accuracy map values */
120     #define ANOVAL 0 /* unevaluated pixel */
121     #define ALOWQ 1 /* single low-quality sample */
122     #define AHIGHQ 2 /* single high-quality sample */
123     #define AMIN 3 /* start of error lookup table */
124     #define ADISTANT 255 /* ray went off to infinity */
125
126     extern double acctab[256]; /* accuracy value table */
127
128     extern int hres, vres; /* frame resolution (fcur) */
129     extern double pixaspect; /* pixel aspect ratio */
130
131     extern VIEW vw; /* view for this frame */
132     extern COLOR *cbuffer; /* color at each pixel */
133     extern float *zbuffer; /* depth at each pixel */
134     extern OBJECT *obuffer; /* object id at each pixel */
135     extern short *xmbuffer; /* x motion at each pixel */
136     extern short *ymbuffer; /* y motion at each pixel */
137 greg 3.7 extern uby8 *abuffer; /* accuracy at each pixel */
138     extern uby8 *sbuffer; /* sample count per pixel */
139 greg 3.1
140     extern VIEW vwprev; /* last frame's view */
141     extern COLOR *cprev; /* last frame colors */
142     extern float *zprev; /* last frame depth */
143     extern OBJECT *oprev; /* last frame objects */
144 greg 3.7 extern uby8 *aprev; /* last frame accuracy */
145 greg 3.1
146     extern float *cerrmap; /* conspicuous error map */
147     extern int cerrzero; /* is all of cerrmap zero? */
148     extern COLOR *val2map; /* value-squared map for variance */
149
150     extern double frm_stop; /* when to stop rendering this frame */
151
152     extern double hlsmax; /* maximum high-level saliency */
153
154     #define CSF_SMN (1./0.82) /* 1/avg_tracking_efficacy */
155
156 greg 3.10 #define outbuffer cprev /* used to hold final output */
157 greg 3.1 #define wbuffer zprev /* used for final filtering */
158
159     #define fndx(x,y) ((y)*hres + (x))
160
161     #define MO_UNK -32768 /* unknown motion value */
162
163     #define FOV_DEG 1.0 /* foveal radius (degrees) */
164
165     #define LOG_E1 (-0.0233) /* ln(0.977) */
166     #define errorf(i) exp(LOG_E1*((i)-AMIN))
167     #define errori(e) (int)(log(e)*(1./LOG_E1) + (AMIN+.5))
168
169     #define NSAMPOK 5 /* samples enough for error estimation */
170
171     #define NPINTERP 4 /* number of pixels to interpolate */
172
173     #define ATIDIFF 7 /* error difference for time extrapolation */
174
175 schorsch 3.6 /* ranimove1.c */
176     extern void init_frame(void);
177     extern void filter_frame(void);
178     extern void send_frame(void);
179     extern void free_frame(void);
180 greg 3.8 extern void write_map(float *mp, char *fn);
181     extern void sample_pos(double hv[2], int x, int y, int sn);
182 schorsch 3.6 extern void comp_frame_error(void);
183 greg 3.8 extern int getclosest(int *iarr, int nc, int x, int y);
184     extern int getambcolor(COLOR clr, int obj);
185     extern double sample_wt(int xo, int yo);
186     extern double estimaterr(COLOR cs, COLOR cs2, int ns, int ns0);
187     extern double comperr(int *neigh, int nc, int ns0);
188 schorsch 3.6
189     /* ranimove2.c */
190     extern int refine_first();
191     extern void conspicuity(void);
192     extern int refine_frame(int pass);
193
194     /* ranimove.c */
195     extern double getTime(void);
196 greg 3.8 extern double obj_prio(OBJECT obj);
197     extern int getmove(OBJECT obj);
198 schorsch 3.6 extern char * getoctspec(int n);
199     extern double expspec_val(char *s);
200     extern char *getexp(int n); /* XXX partly duplicated function */
201     extern VIEW *getview(int n); /* XXX duplicated function */
202     double getTime();
203     /*
204     int countviews();
205     void setdefaults(),
206     void setmove(),
207     setrendparams();
208     getradfile(),
209     animate(),
210     */
211 schorsch 3.4
212     #ifdef __cplusplus
213     }
214     #endif
215     #endif /* _RAD_RANIMOVE_H_ */
216
