root/radiance/ray/src/util/ranimove.c
Sat Jun 7 05:09:46 2025 UTC (2 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.23: +1 -2 lines
Diff to previous 3.23 , to selected 3.4
Tue Jun 3 21:31:51 2025 UTC (2 months, 1 week ago) by greg
Changes since 3.22: +3 -3 lines
Diff to previous 3.22 , to selected 3.4
Wed Apr 23 02:35:26 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 3.21: +4 -1 lines
Diff to previous 3.21 , to selected 3.4
fix: Added missing calls to initfunc()
Wed Aug 21 16:18:54 2024 UTC (11 months, 3 weeks ago) by greg
Changes since 3.20: +1 -2 lines
Diff to previous 3.20 , to selected 3.4
chore: Minor compiler warning fixes
Mon Feb 6 22:40:21 2023 UTC (2 years, 6 months ago) by greg
Diff to previous 3.19 , to selected 3.4
Mon Jul 20 15:54:29 2020 UTC (5 years ago) by greg
Changes since 3.18: +4 -2 lines
Diff to previous 3.18 , to selected 3.4
fix(mkillum, rcontrib, rtrace, ranimove, rsensor): stall under macOS 10.15
due to broken flockfile() implementation -- workaround is better, anyway
Mon Apr 18 22:39:13 2016 UTC (9 years, 3 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 3.17: +19 -20 lines
Diff to previous 3.17 , to selected 3.4
Minor ansifixations
Mon Mar 21 19:06:08 2016 UTC (9 years, 4 months ago) by greg
Changes since 3.16: +3 -3 lines
Diff to previous 3.16 , to selected 3.4
Sun Mar 6 01:13:18 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 3.15: +4 -3 lines
Diff to previous 3.15 , to selected 3.4
Wed Oct 5 17:20:55 2011 UTC (13 years, 10 months ago) by greg
Changes since 3.14: +39 -1 lines
Diff to previous 3.14 , to selected 3.4
Windows compatibility changes from Bill Hoffman
Wed Nov 3 05:05:21 2010 UTC (14 years, 9 months ago) by greg
Changes since 3.13: +7 -7 lines
Diff to previous 3.13 , to selected 3.4
Fixed efficiency and name collision issues with octree creation
Sat Dec 12 19:01:00 2009 UTC (15 years, 8 months ago) by greg
Changes since 3.12: +11 -1 lines
Diff to previous 3.12 , to selected 3.4
Tue Sep 28 17:54:19 2004 UTC (20 years, 10 months ago) by greg
Changes since 3.11: +1 -1 lines
Diff to previous 3.11 , to selected 3.4
Fri Mar 26 23:34:23 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.10: +3 -2 lines
Diff to previous 3.10 , to selected 3.4
Continued ANSIfication.
Fri Mar 26 21:36:20 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.9: +71 -48 lines
Diff to previous 3.9 , to selected 3.4
Tue Oct 21 19:19:29 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.8: +3 -1 lines
Diff to previous 3.8 , to selected 3.4
Tue Sep 23 03:54:57 2003 UTC (21 years, 10 months ago) by greg
Changes since 3.7: +7 -8 lines
Diff to previous 3.7 , to selected 3.4
Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
Diff to previous 3.6 , to selected 3.4
Mon Jul 21 22:30:19 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.5: +4 -3 lines
Diff to previous 3.5 , to selected 3.4
Mon Jun 30 14:59:13 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.4: +6 -3 lines
Diff to previous 3.4
Revision 3.4 - (view) (download) (annotate) - [selected]
Thu Jun 26 00:58:11 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.3: +3 -1 lines
Diff to previous 3.3
Mon Mar 10 17:26:26 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.2: +2 -1 lines
Diff to previous 3.2 , to selected 3.4
Compile fixes for Linux
Tue Feb 25 02:47:24 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.1: +1 -56 lines
Diff to previous 3.1 , to selected 3.4
Sat Feb 22 02:07:30 2003 UTC (22 years, 5 months ago) by greg
Diff to selected 3.4
