--- ray/src/util/ranimove.c 2003/07/21 22:30:19 3.6 +++ ray/src/util/ranimove.c 2025/04/23 02:35:26 3.22 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id"; +static const char RCSid[] = "$Id: ranimove.c,v 3.22 2025/04/23 02:35:26 greg Exp $"; #endif /* * Radiance object animation program @@ -12,14 +12,18 @@ static const char RCSid[] = "$Id"; #include "copyright.h" #include -#ifndef _WIN32 +#if defined(_WIN32) || defined(_WIN64) + #include /* struct timeval. XXX find a replacement? */ +#else #include #endif #include #include +#include "platform.h" #include "paths.h" #include "ranimove.h" +#include "func.h" int NVARS = NV_INIT; /* total number of variables */ @@ -60,17 +64,29 @@ int haveprio = 0; /* high-level saliency specified */ int gargc; /* global argc for printargs */ char **gargv; /* global argv for printargs */ +static void setdefaults(void); +static void setmove(struct ObjMove *om, char *ms); +static void setrendparams(char *optf, char *qval); +static void getradfile(char *rfargs); +static void animate(void); +static int countviews(void); /* XXX duplicated function */ +static char * getobjname(struct ObjMove *om); +static char * getxf(struct ObjMove *om, int n); + int -main(argc, argv) -int argc; -char *argv[]; +main( + int argc, + char *argv[] +) { int explicate = 0; char *cfname; int i; progname = argv[0]; /* get arguments */ + /* initialize calcomp */ + initfunc(); gargc = argc; gargv = argv; for (i = 1; i < argc && argv[i][0] == '-'; i++) @@ -97,7 +113,7 @@ char *argv[]; case 'f': /* frame range */ switch (sscanf(argv[++i], "%d,%d", &fbeg, &fend)) { case 2: - if ((fbeg <= 0 | fend < fbeg)) + if ((fbeg <= 0) | (fend < fbeg)) goto userr; break; case 1: @@ -141,7 +157,7 @@ char *argv[]; /* all done */ if (lorendoptf[0]) unlink(lorendoptf); - if (hirendoptf[0]) + if (hirendoptf[0] && strcmp(hirendoptf, lorendoptf)) unlink(hirendoptf); if (objtmpf[0]) unlink(objtmpf); @@ -151,12 +167,14 @@ userr: "Usage: %s [-n nprocs][-f beg,end][-t sec][-d jnd][-s][-w][-e] anim_file\n", progname); quit(1); + return 1; /* pro forma return */ } void -eputs(s) /* put string to stderr */ -register char *s; +eputs( /* put string to stderr */ + const char *s +) { static int midline = 0; @@ -175,8 +193,19 @@ register char *s; void -setdefaults() /* set default values */ +quit(int ec) /* make sure exit is called */ { + if (ray_pnprocs > 0) /* close children if any */ + ray_pclose(0); + else if (ray_pnprocs < 0) + _exit(ec); /* avoid flush in child */ + exit(ec); +} + + +static void +setdefaults(void) /* set default values */ +{ int nviews; int decades; char buf[256]; @@ -251,10 +280,11 @@ setdefaults() /* set default values */ } -void -setmove(om, ms) /* assign a move object from spec. */ -struct ObjMove *om; -char *ms; +static void +setmove( /* assign a move object from spec. */ + struct ObjMove *om, + char *ms +) { char parname[128]; char *cp; @@ -299,7 +329,7 @@ char *ms; if (isflt(om->prio_file)) { om->prio = atof(om->prio_file); om->prio_file[0] = '\0'; - haveprio |= (om->prio < 0.95 | om->prio > 1.05); + haveprio |= ((om->prio < 0.95) | (om->prio > 1.05)); } else haveprio = 1; } else @@ -311,10 +341,11 @@ badspec: } -void -setrendparams(optf, qval) /* set global rendering parameters */ -char *optf; -char *qval; +static void +setrendparams( /* set global rendering parameters */ + char *optf, + char *qval +) { char *argv[1024]; char **av = argv; @@ -323,7 +354,7 @@ char *qval; av[ac=0] = NULL; /* load options from file, first */ if (optf != NULL && *optf) { - ac = wordfile(av, optf); + ac = wordfile(av, 1024, optf); if (ac < 0) { sprintf(errmsg, "cannot load options file \"%s\"", optf); @@ -332,10 +363,10 @@ char *qval; } /* then from options string */ if (qval != NULL && qval[0] == '-') - ac += wordstring(av+ac, qval); + ac += wordstring(av+ac, 1024-ac, qval); - /* start with default parameters */ - ray_defaults(NULL); + /* restore default parameters */ + ray_restore(NULL); /* set what we have */ for (i = 0; i < ac; i++) { while ((rval = expandarg(&ac, &av, i)) > 0) @@ -349,25 +380,25 @@ char *qval; continue; } rval = getrenderopt(ac-i, av+i); - if (rval >= 0) { - i += rval; - continue; + if (rval < 0) { + sprintf(errmsg, "bad render option at '%s'", av[i]); + error(USER, errmsg); } - sprintf(errmsg, "bad render option at '%s'", av[i]); - error(USER, errmsg); + i += rval; } } -void -getradfile(rfargs) /* run rad and get needed variables */ -char *rfargs; +static void +getradfile( /* run rad and get needed variables */ + char *rfargs +) { static short mvar[] = {OCONV,OCTREEF,RESOLUTION,EXPOSURE,-1}; char combuf[256]; - register int i; - register char *cp; - char *pippt; + int i; + char *cp; + char *pippt = NULL; /* create rad command */ strcpy(lorendoptf, "ranim0.opt"); sprintf(combuf, @@ -410,8 +441,8 @@ char *rfargs; } -void -animate() /* run through animation */ +static void +animate(void) /* run through animation */ { int rpass; @@ -443,8 +474,9 @@ animate() /* run through animation */ VIEW * -getview(n) /* get view number n */ -int n; +getview( /* get view number n */ + int n +) { static FILE *viewfp = NULL; /* view file pointer */ static int viewnum = 0; /* current view number */ @@ -476,7 +508,7 @@ int n; viewnum = 0; } if (n < 0) { /* get next view */ - register int c = getc(viewfp); + int c = getc(viewfp); if (c == EOF) return(NULL); /* that's it */ ungetc(c, viewfp); @@ -492,8 +524,8 @@ int n; } -int -countviews() /* count views in view file */ +static int +countviews(void) /* count views in view file */ { int n; @@ -506,14 +538,14 @@ countviews() /* count views in view file */ char * -getexp(n) /* get exposure for nth frame */ -int n; +getexp( /* get exposure for nth frame */ + int n +) { - extern char *fskip(); static char expval[32]; static FILE *expfp = NULL; static int curfrm = 0; - register char *cp; + char *cp; if (n == 0) { /* signal to close file */ if (expfp != NULL) { @@ -559,12 +591,14 @@ formerr: sprintf(errmsg, "%s: exposure format error on line %d", vval(EXPOSURE), curfrm); error(USER, errmsg); + return NULL; /* pro forma return */ } double -expspec_val(s) /* get exposure value from spec. */ -char *s; +expspec_val( /* get exposure value from spec. */ + char *s +) { double expval; @@ -572,30 +606,30 @@ char *s; return(1.0); expval = atof(s); - if ((s[0] == '+' | s[0] == '-')) + if ((s[0] == '+') | (s[0] == '-')) return(pow(2.0, expval)); return(expval); } char * -getoctspec(n) /* get octree for the given frame */ -int n; +getoctspec( /* get octree for the given frame */ + int n +) { static char combuf[1024]; - int cfm = 0; + static int cfm = 0; int uses_inline; FILE *fp; int i; /* is octree static? */ if (!vdef(MOVE)) return(vval(OCTREEF)); - /* done already */ + /* done already? */ if (n == cfm) return(combuf); /* else create object file */ - strcpy(objtmpf, "movinobj.rad"); - fp = fopen(objtmpf, "w"); + fp = fopen(mktemp(strcpy(objtmpf, TEMPLATE)), "w"); if (fp == NULL) { sprintf(errmsg, "cannot write to moving objects file '%s'", objtmpf); @@ -626,18 +660,20 @@ int n; vdef(OCONV) ? vval(OCONV) : "", vval(OCTREEF), objtmpf); else - sprintf(combuf, "!xform -f %s | oconv -f -i '%s' -", - objtmpf, vval(OCTREEF)); + sprintf(combuf, "!xform -f %s | oconv %s -f -i '%s' -", + objtmpf, vdef(OCONV) ? vval(OCONV) : "", + vval(OCTREEF)); return(combuf); } -char * -getobjname(om) /* get fully qualified object name */ -register struct ObjMove *om; +static char * +getobjname( /* get fully qualified object name */ + struct ObjMove *om +) { static char objName[512]; - register char *cp = objName; + char *cp = objName; strcpy(cp, om->name); while (om->parent >= 0) { @@ -650,10 +686,11 @@ register struct ObjMove *om; } -char * -getxf(om, n) /* get total transform for object */ -register struct ObjMove *om; -int n; +static char * +getxf( /* get total transform for object */ + struct ObjMove *om, + int n +) { static char xfsbuf[4096]; char *xfp; @@ -664,7 +701,7 @@ int n; char *av[64]; int ac; int i; - register char *cp; + char *cp; /* get parent transform, first */ if (om->parent >= 0) xfp = getxf(&obj_move[om->parent], n); @@ -773,14 +810,15 @@ int n; int -getmove(obj) /* find matching move object */ -OBJECT obj; +getmove( /* find matching move object */ + OBJECT obj +) { static int lasti; static OBJECT lasto = OVOID; char *onm, *objnm; int len, len2; - register int i; + int i; if (obj == OVOID) return(-1); @@ -792,7 +830,7 @@ OBJECT obj; objnm = obj_move[i].name; len = strlen(objnm); if (!strncmp(onm, objnm, len)) { - if ((obj_move[i].parent < 0 & onm[len] == '.')) + if ((obj_move[i].parent < 0) & (onm[len] == '.')) break; objnm = getobjname(&obj_move[i]) + len; len2 = strlen(objnm); @@ -806,8 +844,9 @@ OBJECT obj; double -obj_prio(obj) /* return priority for object */ -OBJECT obj; +obj_prio( /* return priority for object */ + OBJECT obj +) { int moi; @@ -817,8 +856,46 @@ OBJECT obj; } +#if defined(_WIN32) || defined(_WIN64) + /* replacement function for Windoze */ +static int +gettimeofday(struct timeval *tp, void *dummy) +{ + FILETIME ft; + LARGE_INTEGER li; + __int64 t; + + SYSTEMTIME st; + FILETIME ft2; + LARGE_INTEGER li2; + __int64 t2; + + st.wYear = 1970; + st.wHour = 0; + st.wMinute = 0; + st.wSecond = 0; + st.wMilliseconds = 1; + + SystemTimeToFileTime(&st, &ft2); + li2.LowPart = ft2.dwLowDateTime; + li2.HighPart = ft2.dwHighDateTime; + t2 = li2.QuadPart; + + GetSystemTimeAsFileTime(&ft); + li.LowPart = ft.dwLowDateTime; + li.HighPart = ft.dwHighDateTime; + t = li.QuadPart; + t -= t2; // From 1970 + t /= 10; // In microseconds + tp->tv_sec = (long)(t / 1000000); + tp->tv_usec = (long)(t % 1000000); + return 0; +} + +#endif + double -getTime() /* get current time (CPU or real) */ +getTime(void) /* get current time (CPU or real) */ { struct timeval time_now; /* return CPU time if one process */
