1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: ranimove.c,v 3.14 2010/11/03 05:05:21 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Radiance object animation program |
6 |
7 |
* Main program and control file handling. |
8 |
9 |
* See ranimove.h and the ranimove(1) man page for details. |
10 |
11 |
12 |
#include "copyright.h" |
13 |
14 |
#include <time.h> |
15 |
#ifdef _WIN32 |
16 |
#include <winsock.h> /* struct timeval. XXX find a replacement? */ |
17 |
#else |
18 |
#include <sys/time.h> |
19 |
#endif |
20 |
#include <ctype.h> |
21 |
#include <string.h> |
22 |
23 |
#include "paths.h" |
24 |
#include "ranimove.h" |
25 |
26 |
int NVARS = NV_INIT; /* total number of variables */ |
27 |
28 |
VARIABLE vv[] = VV_INIT; /* variable-value pairs */ |
29 |
30 |
extern int nowarn; /* don't report warnings? */ |
31 |
int silent = 0; /* run silently? */ |
32 |
33 |
int quickstart = 0; /* time initial frame as well? */ |
34 |
35 |
int nprocs = 1; /* number of rendering processes */ |
36 |
37 |
int rtperfrm = 60; /* seconds to spend per frame */ |
38 |
39 |
double ndthresh = 2.; /* noticeable difference threshold */ |
40 |
int ndtset = 0; /* user threshold -- stop when reached? */ |
41 |
42 |
int fbeg = 1; /* starting frame */ |
43 |
int fend = 0; /* ending frame */ |
44 |
int fcur; /* current frame being rendered */ |
45 |
46 |
char lorendoptf[32]; /* low quality options file */ |
47 |
RAYPARAMS lorendparams; /* low quality rendering parameters */ |
48 |
char hirendoptf[32]; /* high quality options file */ |
49 |
RAYPARAMS hirendparams; /* high quality rendering parameters */ |
50 |
RAYPARAMS *curparams; /* current parameter settings */ |
51 |
int twolevels; /* low and high quality differ */ |
52 |
53 |
double mblur; /* vflt(MBLUR) */ |
54 |
double rate; /* vflt(RATE) */ |
55 |
56 |
char objtmpf[32]; /* object temporary file */ |
57 |
58 |
struct ObjMove *obj_move; /* object movements */ |
59 |
60 |
int haveprio = 0; /* high-level saliency specified */ |
61 |
62 |
int gargc; /* global argc for printargs */ |
63 |
char **gargv; /* global argv for printargs */ |
64 |
65 |
static void setdefaults(void); |
66 |
static void setmove(struct ObjMove *om, char *ms); |
67 |
static void setrendparams(char *optf, char *qval); |
68 |
static void getradfile(char *rfargs); |
69 |
static void animate(void); |
70 |
static int countviews(void); /* XXX duplicated function */ |
71 |
static char * getobjname(struct ObjMove *om); |
72 |
static char * getxf(struct ObjMove *om, int n); |
73 |
74 |
75 |
int |
76 |
main( |
77 |
int argc, |
78 |
char *argv[] |
79 |
80 |
81 |
int explicate = 0; |
82 |
char *cfname; |
83 |
int i; |
84 |
85 |
progname = argv[0]; /* get arguments */ |
86 |
gargc = argc; |
87 |
gargv = argv; |
88 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
89 |
switch (argv[i][1]) { |
90 |
case 't': /* seconds per frame */ |
91 |
rtperfrm = atoi(argv[++i]); |
92 |
break; |
93 |
case 'd': /* noticeable difference */ |
94 |
ndthresh = atof(argv[++i]); |
95 |
ndtset = 1; |
96 |
break; |
97 |
case 'e': /* print variables */ |
98 |
explicate++; |
99 |
break; |
100 |
case 's': /* silent running */ |
101 |
silent++; |
102 |
break; |
103 |
case 'q': /* start quickly */ |
104 |
quickstart++; |
105 |
break; |
106 |
case 'w': /* turn off warnings */ |
107 |
nowarn++; |
108 |
break; |
109 |
case 'f': /* frame range */ |
110 |
switch (sscanf(argv[++i], "%d,%d", &fbeg, &fend)) { |
111 |
case 2: |
112 |
if ((fbeg <= 0) | (fend < fbeg)) |
113 |
goto userr; |
114 |
break; |
115 |
case 1: |
116 |
if (fbeg <= 0) |
117 |
goto userr; |
118 |
fend = 0; |
119 |
break; |
120 |
default: |
121 |
goto userr; |
122 |
123 |
break; |
124 |
case 'n': /* number of processes */ |
125 |
nprocs = atoi(argv[++i]); |
126 |
break; |
127 |
default: |
128 |
goto userr; |
129 |
130 |
if (rtperfrm <= 0) { |
131 |
if (!ndtset) |
132 |
error(USER, "specify -d jnd with -t 0"); |
133 |
rtperfrm = 7*24*3600; |
134 |
135 |
if (i != argc-1) |
136 |
goto userr; |
137 |
cfname = argv[i]; |
138 |
/* load variables */ |
139 |
loadvars(cfname); |
140 |
/* check variables */ |
141 |
checkvalues(); |
142 |
/* load RIF if any */ |
143 |
if (vdef(RIF)) |
144 |
getradfile(vval(RIF)); |
145 |
/* set defaults */ |
146 |
setdefaults(); |
147 |
148 |
if (explicate) |
149 |
printvars(stdout); |
150 |
/* run animation */ |
151 |
if (nprocs > 0) |
152 |
animate(); |
153 |
/* all done */ |
154 |
if (lorendoptf[0]) |
155 |
unlink(lorendoptf); |
156 |
if (hirendoptf[0] && strcmp(hirendoptf, lorendoptf)) |
157 |
unlink(hirendoptf); |
158 |
if (objtmpf[0]) |
159 |
unlink(objtmpf); |
160 |
return(0); |
161 |
userr: |
162 |
fprintf(stderr, |
163 |
"Usage: %s [-n nprocs][-f beg,end][-t sec][-d jnd][-s][-w][-e] anim_file\n", |
164 |
progname); |
165 |
quit(1); |
166 |
return 1; /* pro forma return */ |
167 |
168 |
169 |
170 |
void |
171 |
eputs( /* put string to stderr */ |
172 |
register char *s |
173 |
174 |
175 |
static int midline = 0; |
176 |
177 |
if (!*s) |
178 |
return; |
179 |
if (!midline++) { |
180 |
fputs(progname, stderr); |
181 |
fputs(": ", stderr); |
182 |
183 |
fputs(s, stderr); |
184 |
if (s[strlen(s)-1] == '\n') { |
185 |
fflush(stderr); |
186 |
midline = 0; |
187 |
188 |
189 |
190 |
191 |
void |
192 |
quit(ec) /* make sure exit is called */ |
193 |
int ec; |
194 |
195 |
if (ray_pnprocs > 0) /* close children if any */ |
196 |
ray_pclose(0); |
197 |
exit(ec); |
198 |
199 |
200 |
201 |
static void |
202 |
setdefaults(void) /* set default values */ |
203 |
204 |
int nviews; |
205 |
int decades; |
206 |
char buf[256]; |
207 |
int i; |
208 |
209 |
if (!vdef(OCTREEF)) { |
210 |
sprintf(errmsg, "%s or %s must be defined", |
211 |
vnam(OCTREEF), vnam(RIF)); |
212 |
error(USER, errmsg); |
213 |
214 |
if (!vdef(VIEWFILE)) { |
215 |
sprintf(errmsg, "%s must be defined", vnam(VIEWFILE)); |
216 |
217 |
218 |
nviews = countviews(); |
219 |
if (!nviews) |
220 |
error(USER, "no views in view file"); |
221 |
if (!vdef(END)) { |
222 |
if (nviews == 1) { |
223 |
sprintf(errmsg, "%s must be defined for single view", |
224 |
vnam(END)); |
225 |
226 |
227 |
sprintf(buf, "%d", nviews); |
228 |
vval(END) = savqstr(buf); |
229 |
vdef(END)++; |
230 |
231 |
if (!fend) |
232 |
fend = vint(END); |
233 |
if (fbeg > fend) |
234 |
error(USER, "begin after end"); |
235 |
if (!vdef(BASENAME)) { |
236 |
decades = (int)log10((double)vint(END)) + 1; |
237 |
if (decades < 3) decades = 3; |
238 |
sprintf(buf, "frame%%0%dd", decades); |
239 |
vval(BASENAME) = savqstr(buf); |
240 |
vdef(BASENAME)++; |
241 |
242 |
if (!vdef(RATE)) { |
243 |
vval(RATE) = "8"; |
244 |
vdef(RATE)++; |
245 |
246 |
rate = vflt(RATE); |
247 |
if (!vdef(RESOLUTION)) { |
248 |
vval(RESOLUTION) = "640"; |
249 |
vdef(RESOLUTION)++; |
250 |
251 |
if (!vdef(MBLUR)) { |
252 |
vval(MBLUR) = "0"; |
253 |
vdef(MBLUR)++; |
254 |
255 |
mblur = vflt(MBLUR); |
256 |
if (mblur > 1.) |
257 |
mblur = 1.; |
258 |
/* set up objects */ |
259 |
if (vdef(MOVE)) { |
260 |
obj_move = (struct ObjMove *)malloc( |
261 |
sizeof(struct ObjMove)*vdef(MOVE) ); |
262 |
if (obj_move == NULL) |
263 |
error(SYSTEM, "out of memory in setdefaults"); |
264 |
for (i = 0; i < vdef(MOVE); i++) |
265 |
setmove(&obj_move[i], nvalue(MOVE, i)); |
266 |
267 |
/* set up high quality options */ |
268 |
setrendparams(hirendoptf, vval(HIGHQ)); |
269 |
ray_save(&hirendparams); |
270 |
/* set up low quality options */ |
271 |
setrendparams(lorendoptf, vval(LOWQ)); |
272 |
ray_save(&lorendparams); |
273 |
curparams = &lorendparams; |
274 |
twolevels = memcmp(&lorendparams, &hirendparams, sizeof(RAYPARAMS)); |
275 |
276 |
277 |
278 |
static void |
279 |
setmove( /* assign a move object from spec. */ |
280 |
struct ObjMove *om, |
281 |
char *ms |
282 |
283 |
284 |
char parname[128]; |
285 |
char *cp; |
286 |
287 |
ms = nextword(parname, sizeof(parname), ms); |
288 |
if (!parname[0]) |
289 |
goto badspec; |
290 |
for (cp = parname; *cp; cp++) |
291 |
if (isspace(*cp)) |
292 |
*cp = '_'; |
293 |
for (om->parent = (om - obj_move); om->parent--; ) |
294 |
if (!strcmp(parname, obj_move[om->parent].name)) |
295 |
break; |
296 |
if (om->parent < 0 && |
297 |
strcmp(parname, ".") && strcmp(parname, VOIDID)) { |
298 |
sprintf(errmsg, "undefined parent object '%s'", parname); |
299 |
300 |
301 |
ms = nextword(om->name, sizeof(om->name), ms); |
302 |
if (!om->name[0]) |
303 |
goto badspec; |
304 |
for (cp = om->name; *cp; cp++) |
305 |
if (isspace(*cp)) |
306 |
*cp = '_'; |
307 |
ms = nextword(om->xf_file, sizeof(om->xf_file), ms); |
308 |
if (!strcmp(om->xf_file, ".")) |
309 |
om->xf_file[0] = '\0'; |
310 |
if (!om->xf_file[0]) { |
311 |
om->xfs[0] = '\0'; |
312 |
} else if (om->xf_file[0] == '-') { |
313 |
strcpy(om->xfs, om->xf_file); |
314 |
315 |
316 |
ms = nextword(om->spec, sizeof(om->spec), ms); |
317 |
if (om->spec[0]) { |
318 |
if (!strcmp(om->spec, ".") || !strcmp(om->spec, VOIDID)) |
319 |
om->spec[0] = '\0'; |
320 |
ms = nextword(om->prio_file, sizeof(om->prio_file), ms); |
321 |
} else |
322 |
om->prio_file[0] = '\0'; |
323 |
if (om->prio_file[0]) { |
324 |
if (isflt(om->prio_file)) { |
325 |
om->prio = atof(om->prio_file); |
326 |
327 |
haveprio |= ((om->prio < 0.95) | (om->prio > 1.05)); |
328 |
} else |
329 |
haveprio = 1; |
330 |
} else |
331 |
om->prio = 1.; |
332 |
om->cfm = -1; |
333 |
return; |
334 |
badspec: |
335 |
error(USER, "bad object specification"); |
336 |
337 |
338 |
339 |
static void |
340 |
setrendparams( /* set global rendering parameters */ |
341 |
char *optf, |
342 |
char *qval |
343 |
344 |
345 |
char *argv[1024]; |
346 |
char **av = argv; |
347 |
int ac, i, rval; |
348 |
349 |
av[ac=0] = NULL; |
350 |
/* load options from file, first */ |
351 |
if (optf != NULL && *optf) { |
352 |
ac = wordfile(av, optf); |
353 |
if (ac < 0) { |
354 |
sprintf(errmsg, "cannot load options file \"%s\"", |
355 |
optf); |
356 |
error(SYSTEM, errmsg); |
357 |
358 |
359 |
/* then from options string */ |
360 |
if (qval != NULL && qval[0] == '-') |
361 |
ac += wordstring(av+ac, qval); |
362 |
363 |
/* restore default parameters */ |
364 |
ray_restore(NULL); |
365 |
/* set what we have */ |
366 |
for (i = 0; i < ac; i++) { |
367 |
while ((rval = expandarg(&ac, &av, i)) > 0) |
368 |
369 |
if (rval < 0) { |
370 |
sprintf(errmsg, "cannot expand '%s'", av[i]); |
371 |
372 |
373 |
if (!strcmp(av[i], "-w")) { |
374 |
nowarn++; |
375 |
continue; |
376 |
377 |
rval = getrenderopt(ac-i, av+i); |
378 |
if (rval < 0) { |
379 |
sprintf(errmsg, "bad render option at '%s'", av[i]); |
380 |
381 |
382 |
i += rval; |
383 |
384 |
385 |
386 |
387 |
static void |
388 |
getradfile( /* run rad and get needed variables */ |
389 |
char *rfargs |
390 |
391 |
392 |
static short mvar[] = {OCONV,OCTREEF,RESOLUTION,EXPOSURE,-1}; |
393 |
char combuf[256]; |
394 |
register int i; |
395 |
register char *cp; |
396 |
char *pippt = NULL; |
397 |
/* create rad command */ |
398 |
strcpy(lorendoptf, "ranim0.opt"); |
399 |
sprintf(combuf, |
400 |
"rad -v 0 -s -e -w %s %s oconv=-f OPTFILE=%s | egrep '^[ \t]*(NOMATCH", |
401 |
rfargs, |
402 |
(vdef(LOWQ) && vval(LOWQ)[0]!='-') ? vval(LOWQ) : "", |
403 |
lorendoptf); |
404 |
cp = combuf; |
405 |
while (*cp) { |
406 |
if (*cp == '|') pippt = cp; |
407 |
cp++; |
408 |
} /* match unset variables */ |
409 |
for (i = 0; mvar[i] >= 0; i++) |
410 |
if (!vdef(mvar[i])) { |
411 |
*cp++ = '|'; |
412 |
strcpy(cp, vnam(mvar[i])); |
413 |
while (*cp) cp++; |
414 |
pippt = NULL; |
415 |
416 |
if (pippt != NULL) |
417 |
strcpy(pippt, "> " NULL_DEVICE); /* nothing to match */ |
418 |
else { |
419 |
strcpy(cp, ")[ \t]*=' > ranimove.var"); |
420 |
cp += 11; /* point to file name */ |
421 |
422 |
system(combuf); /* ignore exit code */ |
423 |
if (pippt == NULL) { /* load variables and remove file */ |
424 |
loadvars(cp); |
425 |
unlink(cp); |
426 |
427 |
if (!vdef(HIGHQ) || vval(HIGHQ)[0]=='-') { |
428 |
strcpy(hirendoptf, lorendoptf); |
429 |
return; |
430 |
431 |
/* get high quality options */ |
432 |
strcpy(hirendoptf, "ranim1.opt"); |
433 |
sprintf(combuf, "rad -v 0 -s -w %s %s OPTFILE=%s", |
434 |
rfargs, vval(HIGHQ), hirendoptf); |
435 |
system(combuf); |
436 |
437 |
438 |
439 |
static void |
440 |
animate(void) /* run through animation */ |
441 |
442 |
int rpass; |
443 |
444 |
if (fbeg > 1) /* synchronize transforms */ |
445 |
getoctspec(fbeg-1); |
446 |
447 |
for (fcur = fbeg; fcur <= fend; fcur++) { |
448 |
if (!silent) |
449 |
printf("Frame %d:\n", fcur); |
450 |
/* base rendering */ |
451 |
init_frame(); |
452 |
/* refinement */ |
453 |
for (rpass = 0; refine_frame(rpass); rpass++) |
454 |
455 |
/* final filter pass */ |
456 |
filter_frame(); |
457 |
/* output frame */ |
458 |
send_frame(); |
459 |
460 |
/* free resources */ |
461 |
free_frame(); |
462 |
if (nprocs > 1) |
463 |
ray_pdone(1); |
464 |
else |
465 |
ray_done(1); |
466 |
getview(0); |
467 |
getexp(0); |
468 |
469 |
470 |
471 |
extern VIEW * |
472 |
getview( /* get view number n */ |
473 |
int n |
474 |
475 |
476 |
static FILE *viewfp = NULL; /* view file pointer */ |
477 |
static int viewnum = 0; /* current view number */ |
478 |
static VIEW curview = STDVIEW; /* current view */ |
479 |
char linebuf[256]; |
480 |
481 |
if (n == 0) { /* signal to close file and clean up */ |
482 |
if (viewfp != NULL) { |
483 |
fclose(viewfp); |
484 |
viewfp = NULL; |
485 |
viewnum = 0; |
486 |
curview = stdview; |
487 |
488 |
return(NULL); |
489 |
490 |
if (viewfp == NULL) { /* open file */ |
491 |
if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) { |
492 |
perror(vval(VIEWFILE)); |
493 |
quit(1); |
494 |
495 |
} else if (n > 0 && n < viewnum) { /* rewind file */ |
496 |
if (viewnum == 1 && feof(viewfp)) |
497 |
return(&curview); /* just one view */ |
498 |
if (fseek(viewfp, 0L, 0) == EOF) { |
499 |
500 |
quit(1); |
501 |
502 |
503 |
viewnum = 0; |
504 |
505 |
if (n < 0) { /* get next view */ |
506 |
register int c = getc(viewfp); |
507 |
if (c == EOF) |
508 |
return(NULL); /* that's it */ |
509 |
ungetc(c, viewfp); |
510 |
n = viewnum + 1; |
511 |
512 |
while (n > viewnum) { /* scan to desired view */ |
513 |
if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL) |
514 |
return(viewnum==1 ? &curview : (VIEW *)NULL); |
515 |
if (isview(linebuf) && sscanview(&curview, linebuf) > 0) |
516 |
viewnum++; |
517 |
518 |
return(&curview); /* return it */ |
519 |
520 |
521 |
522 |
static int |
523 |
countviews(void) /* count views in view file */ |
524 |
525 |
int n; |
526 |
527 |
if (getview(n=1) == NULL) |
528 |
return(0); |
529 |
while (getview(-1) != NULL) |
530 |
n++; |
531 |
return(n); |
532 |
533 |
534 |
535 |
extern char * |
536 |
getexp( /* get exposure for nth frame */ |
537 |
int n |
538 |
539 |
540 |
extern char *fskip(); |
541 |
static char expval[32]; |
542 |
static FILE *expfp = NULL; |
543 |
static int curfrm = 0; |
544 |
545 |
546 |
if (n == 0) { /* signal to close file */ |
547 |
if (expfp != NULL) { |
548 |
fclose(expfp); |
549 |
expfp = NULL; |
550 |
551 |
return(NULL); |
552 |
553 |
if (!vdef(EXPOSURE)) /* no setting (auto) */ |
554 |
return(NULL); |
555 |
if (isflt(vval(EXPOSURE))) /* always the same */ |
556 |
return(vval(EXPOSURE)); |
557 |
if (expfp == NULL) { /* open exposure file */ |
558 |
if ((expfp = fopen(vval(EXPOSURE), "r")) == NULL) { |
559 |
sprintf(errmsg, "cannot open exposure file \"%s\"", |
560 |
vval(EXPOSURE)); |
561 |
562 |
563 |
curfrm = 0; |
564 |
565 |
if (curfrm > n) { /* rewind if necessary */ |
566 |
rewind(expfp); |
567 |
curfrm = 0; |
568 |
569 |
while (n > curfrm) { /* read to line */ |
570 |
if (fgets(expval, sizeof(expval), expfp) == NULL) { |
571 |
sprintf(errmsg, "%s: too few exposures", |
572 |
vval(EXPOSURE)); |
573 |
574 |
575 |
if (strlen(expval) == sizeof(expval)-1) |
576 |
goto formerr; |
577 |
curfrm++; |
578 |
579 |
cp = fskip(expval); /* check format */ |
580 |
if (cp != NULL) |
581 |
while (isspace(*cp)) |
582 |
*cp++ = '\0'; |
583 |
if (cp == NULL || *cp) |
584 |
goto formerr; |
585 |
return(expval); /* return value */ |
586 |
formerr: |
587 |
sprintf(errmsg, "%s: exposure format error on line %d", |
588 |
vval(EXPOSURE), curfrm); |
589 |
590 |
return NULL; /* pro forma return */ |
591 |
592 |
593 |
594 |
extern double |
595 |
expspec_val( /* get exposure value from spec. */ |
596 |
char *s |
597 |
598 |
599 |
double expval; |
600 |
601 |
if (s == NULL || !*s) |
602 |
return(1.0); |
603 |
604 |
expval = atof(s); |
605 |
if ((s[0] == '+') | (s[0] == '-')) |
606 |
return(pow(2.0, expval)); |
607 |
return(expval); |
608 |
609 |
610 |
611 |
extern char * |
612 |
getoctspec( /* get octree for the given frame */ |
613 |
int n |
614 |
615 |
616 |
static char combuf[1024]; |
617 |
static int cfm = 0; |
618 |
int uses_inline; |
619 |
FILE *fp; |
620 |
int i; |
621 |
/* is octree static? */ |
622 |
if (!vdef(MOVE)) |
623 |
return(vval(OCTREEF)); |
624 |
/* done already? */ |
625 |
if (n == cfm) |
626 |
return(combuf); |
627 |
/* else create object file */ |
628 |
fp = fopen(mktemp(strcpy(objtmpf, TEMPLATE)), "w"); |
629 |
if (fp == NULL) { |
630 |
sprintf(errmsg, "cannot write to moving objects file '%s'", |
631 |
objtmpf); |
632 |
633 |
634 |
uses_inline = 0; |
635 |
for (i = 0; i < vdef(MOVE); i++) { |
636 |
int inlc = (obj_move[i].spec[0] == '!'); |
637 |
if (!obj_move[i].spec[0]) |
638 |
continue; |
639 |
if (inlc) |
640 |
fprintf(fp, "%s %d \\\n\t| xform", |
641 |
obj_move[i].spec, n); |
642 |
else |
643 |
fputs("!xform", fp); |
644 |
fprintf(fp, " -n %s", getobjname(&obj_move[i])); |
645 |
fputs(getxf(&obj_move[i], n), fp); |
646 |
if (!inlc) |
647 |
fprintf(fp, " %s\n", obj_move[i].spec); |
648 |
else |
649 |
fputc('\n', fp); |
650 |
uses_inline |= inlc; |
651 |
652 |
if (fclose(fp) == EOF) |
653 |
error(SYSTEM, "error writing moving objects file"); |
654 |
if (uses_inline) |
655 |
sprintf(combuf, "!oconv %s -f -i '%s' %s", |
656 |
vdef(OCONV) ? vval(OCONV) : "", |
657 |
vval(OCTREEF), objtmpf); |
658 |
else |
659 |
sprintf(combuf, "!xform -f %s | oconv %s -f -i '%s' -", |
660 |
objtmpf, vdef(OCONV) ? vval(OCONV) : "", |
661 |
vval(OCTREEF)); |
662 |
return(combuf); |
663 |
664 |
665 |
666 |
static char * |
667 |
getobjname( /* get fully qualified object name */ |
668 |
register struct ObjMove *om |
669 |
670 |
671 |
static char objName[512]; |
672 |
register char *cp = objName; |
673 |
674 |
strcpy(cp, om->name); |
675 |
while (om->parent >= 0) { |
676 |
while (*cp) cp++; |
677 |
*cp++ = '@'; |
678 |
om = &obj_move[om->parent]; |
679 |
680 |
681 |
return(objName); |
682 |
683 |
684 |
685 |
static char * |
686 |
getxf( /* get total transform for object */ |
687 |
register struct ObjMove *om, |
688 |
int n |
689 |
690 |
691 |
static char xfsbuf[4096]; |
692 |
char *xfp; |
693 |
int framestep = 0; |
694 |
XF oxf; |
695 |
FILE *fp; |
696 |
char abuf[512]; |
697 |
char *av[64]; |
698 |
int ac; |
699 |
int i; |
700 |
701 |
/* get parent transform, first */ |
702 |
if (om->parent >= 0) |
703 |
xfp = getxf(&obj_move[om->parent], n); |
704 |
else |
705 |
*(xfp = xfsbuf + sizeof(xfsbuf)-1) = '\0'; |
706 |
/* get transform spec. & priority */ |
707 |
if (om->cfm != n) { |
708 |
if (om->xf_file[0]) { |
709 |
fp = fopen(om->xf_file, "r"); |
710 |
if (fp == NULL) { |
711 |
sprintf(errmsg, |
712 |
"cannot open transform file '%s'", |
713 |
om->xf_file); |
714 |
715 |
716 |
for (i = 0; i < n; i++) |
717 |
if (fgetline(om->xfs, sizeof(om->xfs), fp) |
718 |
== NULL) { |
719 |
sprintf(errmsg, |
720 |
"too few transforms in file '%s'", |
721 |
om->xf_file); |
722 |
723 |
724 |
fclose(fp); |
725 |
726 |
strcpy(cp=abuf, om->xfs); |
727 |
ac = 0; |
728 |
for ( ; ; ) { |
729 |
730 |
*cp++ = '\0'; |
731 |
if (!*cp) |
732 |
break; |
733 |
av[ac++] = cp; |
734 |
while (*++cp && !isspace(*cp)) |
735 |
736 |
737 |
av[ac] = NULL; |
738 |
if (xf(&oxf, ac, av) != ac || |
739 |
fabs(oxf.sca) <= FTINY) { |
740 |
sprintf(errmsg, "bad transform args: %s", |
741 |
om->xfs); |
742 |
743 |
744 |
copymat4(om->xfm, oxf.xfm); |
745 |
746 |
fp = fopen(om->prio_file, "r"); |
747 |
if (fp == NULL) { |
748 |
sprintf(errmsg, |
749 |
"cannot open priority file '%s'", |
750 |
om->prio_file); |
751 |
752 |
753 |
754 |
if (fgets(abuf, sizeof(abuf), fp) |
755 |
== NULL) { |
756 |
sprintf(errmsg, |
757 |
"too few priorities in file '%s'", |
758 |
om->prio_file); |
759 |
760 |
761 |
fclose(fp); |
762 |
cp = fskip(abuf); |
763 |
if (cp != NULL) |
764 |
765 |
*cp++ = '\0'; |
766 |
if (cp == NULL || *cp) { |
767 |
sprintf(errmsg, |
768 |
"priority '%s' in file '%s' not a number", |
769 |
abuf, om->prio_file); |
770 |
771 |
772 |
om->prio = atof(abuf); |
773 |
774 |
framestep = (n == om->cfm + 1); |
775 |
om->cfm = n; |
776 |
777 |
/* prepend to parent transform */ |
778 |
if (om->xfs[0]) { |
779 |
i = strlen(om->xfs); |
780 |
if (xfp - i <= xfsbuf) |
781 |
error(INTERNAL, "transform too long in getxf"); |
782 |
cp = om->xfs + i; |
783 |
while (i--) |
784 |
*--xfp = *--cp; |
785 |
*--xfp = ' '; |
786 |
787 |
if (framestep) |
788 |
copymat4(oxf.xfm, om->cxfm); |
789 |
if (om->parent >= 0) { |
790 |
multmat4(om->cxfm, om->xfm, obj_move[om->parent].cxfm); |
791 |
om->cprio = obj_move[om->parent].cprio * om->prio; |
792 |
} else { |
793 |
copymat4(om->cxfm, om->xfm); |
794 |
om->cprio = om->prio; |
795 |
796 |
/* XXX bxfm relies on call order */ |
797 |
if (framestep) { |
798 |
if (invmat4(om->bxfm, om->cxfm)) |
799 |
multmat4(om->bxfm, om->bxfm, oxf.xfm); |
800 |
else |
801 |
setident4(om->bxfm); |
802 |
803 |
/* all done */ |
804 |
return(xfp); |
805 |
806 |
807 |
808 |
extern int |
809 |
getmove( /* find matching move object */ |
810 |
OBJECT obj |
811 |
812 |
813 |
static int lasti; |
814 |
static OBJECT lasto = OVOID; |
815 |
char *onm, *objnm; |
816 |
int len, len2; |
817 |
register int i; |
818 |
819 |
if (obj == OVOID) |
820 |
return(-1); |
821 |
if (obj == lasto) |
822 |
return(lasti); |
823 |
/* look for matching object */ |
824 |
onm = objptr(obj)->oname; |
825 |
for (i = vdef(MOVE); i--; ) { |
826 |
objnm = obj_move[i].name; |
827 |
len = strlen(objnm); |
828 |
if (!strncmp(onm, objnm, len)) { |
829 |
if ((obj_move[i].parent < 0) & (onm[len] == '.')) |
830 |
break; |
831 |
objnm = getobjname(&obj_move[i]) + len; |
832 |
len2 = strlen(objnm); |
833 |
if (!strncmp(onm+len, objnm, len2) && onm[len+len2] == '.') |
834 |
break; |
835 |
836 |
837 |
lasto = obj; /* cache what we found */ |
838 |
return(lasti = i); |
839 |
840 |
841 |
842 |
extern double |
843 |
obj_prio( /* return priority for object */ |
844 |
OBJECT obj |
845 |
846 |
847 |
int moi; |
848 |
849 |
if (obj == OVOID || (moi = getmove(obj)) < 0) |
850 |
return(1.0); |
851 |
return(obj_move[moi].cprio); |
852 |
853 |
854 |
855 |
#ifdef _WIN32 |
856 |
/* replacement function for Windoze */ |
857 |
static int |
858 |
gettimeofday(struct timeval *tp, void *dummy) |
859 |
860 |
FILETIME ft; |
861 |
LARGE_INTEGER li; |
862 |
__int64 t; |
863 |
864 |
SYSTEMTIME st; |
865 |
FILETIME ft2; |
866 |
LARGE_INTEGER li2; |
867 |
__int64 t2; |
868 |
869 |
st.wYear = 1970; |
870 |
st.wHour = 0; |
871 |
st.wMinute = 0; |
872 |
st.wSecond = 0; |
873 |
st.wMilliseconds = 1; |
874 |
875 |
SystemTimeToFileTime(&st, &ft2); |
876 |
li2.LowPart = ft2.dwLowDateTime; |
877 |
li2.HighPart = ft2.dwHighDateTime; |
878 |
t2 = li2.QuadPart; |
879 |
880 |
GetSystemTimeAsFileTime(&ft); |
881 |
li.LowPart = ft.dwLowDateTime; |
882 |
li.HighPart = ft.dwHighDateTime; |
883 |
t = li.QuadPart; |
884 |
t -= t2; // From 1970 |
885 |
t /= 10; // In microseconds |
886 |
tp->tv_sec = (long)(t / 1000000); |
887 |
tp->tv_usec = (long)(t % 1000000); |
888 |
return 0; |
889 |
890 |
891 |
#endif |
892 |
893 |
extern double |
894 |
getTime(void) /* get current time (CPU or real) */ |
895 |
896 |
struct timeval time_now; |
897 |
/* return CPU time if one process */ |
898 |
if (nprocs == 1) |
899 |
return((double)clock()*(1.0/(double)CLOCKS_PER_SEC)); |
900 |
/* otherwise, return wall time */ |
901 |
gettimeofday(&time_now, NULL); |
902 |
return((double)time_now.tv_sec + 1e-6*(double)time_now.tv_usec); |
903 |
