| 1 |
greg |
3.1 |
#ifndef lint
| 2 |
greg |
3.18 |
static const char RCSid[] = "$Id: ranimove.c,v 3.17 2016/03/21 19:06:08 greg Exp $";
| 3 |
greg |
3.1 |
#endif
| 4 |
| 5 |
* Radiance object animation program
| 6 |
| 7 |
* Main program and control file handling.
| 8 |
| 9 |
* See ranimove.h and the ranimove(1) man page for details.
| 10 |
| 11 |
| 12 |
greg |
3.2 |
#include "copyright.h"
| 13 |
greg |
3.1 |
| 14 |
greg |
3.3 |
#include <time.h>
| 15 |
schorsch |
3.16 |
#if defined(_WIN32) || defined(_WIN64)
| 16 |
schorsch |
3.9 |
#include <winsock.h> /* struct timeval. XXX find a replacement? */
| 17 |
#else
| 18 |
schorsch |
3.4 |
#include <sys/time.h>
| 19 |
#endif
| 20 |
greg |
3.1 |
#include <ctype.h>
| 21 |
schorsch |
3.5 |
#include <string.h>
| 22 |
| 23 |
schorsch |
3.16 |
#include "platform.h"
| 24 |
schorsch |
3.5 |
#include "paths.h"
| 25 |
#include "ranimove.h"
| 26 |
greg |
3.1 |
| 27 |
int NVARS = NV_INIT; /* total number of variables */
| 28 |
| 29 |
VARIABLE vv[] = VV_INIT; /* variable-value pairs */
| 30 |
| 31 |
extern int nowarn; /* don't report warnings? */
| 32 |
int silent = 0; /* run silently? */
| 33 |
| 34 |
int quickstart = 0; /* time initial frame as well? */
| 35 |
| 36 |
int nprocs = 1; /* number of rendering processes */
| 37 |
| 38 |
int rtperfrm = 60; /* seconds to spend per frame */
| 39 |
| 40 |
double ndthresh = 2.; /* noticeable difference threshold */
| 41 |
int ndtset = 0; /* user threshold -- stop when reached? */
| 42 |
| 43 |
int fbeg = 1; /* starting frame */
| 44 |
int fend = 0; /* ending frame */
| 45 |
int fcur; /* current frame being rendered */
| 46 |
| 47 |
char lorendoptf[32]; /* low quality options file */
| 48 |
RAYPARAMS lorendparams; /* low quality rendering parameters */
| 49 |
char hirendoptf[32]; /* high quality options file */
| 50 |
RAYPARAMS hirendparams; /* high quality rendering parameters */
| 51 |
RAYPARAMS *curparams; /* current parameter settings */
| 52 |
int twolevels; /* low and high quality differ */
| 53 |
| 54 |
double mblur; /* vflt(MBLUR) */
| 55 |
double rate; /* vflt(RATE) */
| 56 |
| 57 |
char objtmpf[32]; /* object temporary file */
| 58 |
| 59 |
struct ObjMove *obj_move; /* object movements */
| 60 |
| 61 |
int haveprio = 0; /* high-level saliency specified */
| 62 |
| 63 |
int gargc; /* global argc for printargs */
| 64 |
char **gargv; /* global argv for printargs */
| 65 |
| 66 |
schorsch |
3.10 |
static void setdefaults(void);
| 67 |
static void setmove(struct ObjMove *om, char *ms);
| 68 |
static void setrendparams(char *optf, char *qval);
| 69 |
static void getradfile(char *rfargs);
| 70 |
static void animate(void);
| 71 |
static int countviews(void); /* XXX duplicated function */
| 72 |
static char * getobjname(struct ObjMove *om);
| 73 |
static char * getxf(struct ObjMove *om, int n);
| 74 |
| 75 |
greg |
3.1 |
| 76 |
int
| 77 |
schorsch |
3.10 |
main(
| 78 |
int argc,
| 79 |
char *argv[]
| 80 |
| 81 |
greg |
3.1 |
| 82 |
int explicate = 0;
| 83 |
char *cfname;
| 84 |
int i;
| 85 |
| 86 |
progname = argv[0]; /* get arguments */
| 87 |
gargc = argc;
| 88 |
gargv = argv;
| 89 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 90 |
switch (argv[i][1]) {
| 91 |
case 't': /* seconds per frame */
| 92 |
rtperfrm = atoi(argv[++i]);
| 93 |
break;
| 94 |
case 'd': /* noticeable difference */
| 95 |
ndthresh = atof(argv[++i]);
| 96 |
ndtset = 1;
| 97 |
break;
| 98 |
case 'e': /* print variables */
| 99 |
explicate++;
| 100 |
break;
| 101 |
case 's': /* silent running */
| 102 |
silent++;
| 103 |
break;
| 104 |
case 'q': /* start quickly */
| 105 |
quickstart++;
| 106 |
break;
| 107 |
case 'w': /* turn off warnings */
| 108 |
nowarn++;
| 109 |
break;
| 110 |
case 'f': /* frame range */
| 111 |
switch (sscanf(argv[++i], "%d,%d", &fbeg, &fend)) {
| 112 |
case 2:
| 113 |
schorsch |
3.7 |
if ((fbeg <= 0) | (fend < fbeg))
| 114 |
greg |
3.1 |
goto userr;
| 115 |
break;
| 116 |
case 1:
| 117 |
if (fbeg <= 0)
| 118 |
goto userr;
| 119 |
fend = 0;
| 120 |
break;
| 121 |
default:
| 122 |
goto userr;
| 123 |
| 124 |
break;
| 125 |
case 'n': /* number of processes */
| 126 |
nprocs = atoi(argv[++i]);
| 127 |
break;
| 128 |
default:
| 129 |
goto userr;
| 130 |
| 131 |
if (rtperfrm <= 0) {
| 132 |
if (!ndtset)
| 133 |
error(USER, "specify -d jnd with -t 0");
| 134 |
rtperfrm = 7*24*3600;
| 135 |
| 136 |
if (i != argc-1)
| 137 |
goto userr;
| 138 |
cfname = argv[i];
| 139 |
/* load variables */
| 140 |
loadvars(cfname);
| 141 |
/* check variables */
| 142 |
checkvalues();
| 143 |
/* load RIF if any */
| 144 |
if (vdef(RIF))
| 145 |
getradfile(vval(RIF));
| 146 |
/* set defaults */
| 147 |
setdefaults();
| 148 |
| 149 |
if (explicate)
| 150 |
printvars(stdout);
| 151 |
/* run animation */
| 152 |
if (nprocs > 0)
| 153 |
animate();
| 154 |
/* all done */
| 155 |
if (lorendoptf[0])
| 156 |
unlink(lorendoptf);
| 157 |
greg |
3.8 |
if (hirendoptf[0] && strcmp(hirendoptf, lorendoptf))
| 158 |
greg |
3.1 |
unlink(hirendoptf);
| 159 |
if (objtmpf[0])
| 160 |
unlink(objtmpf);
| 161 |
return(0);
| 162 |
userr:
| 163 |
fprintf(stderr,
| 164 |
"Usage: %s [-n nprocs][-f beg,end][-t sec][-d jnd][-s][-w][-e] anim_file\n",
| 165 |
progname);
| 166 |
quit(1);
| 167 |
schorsch |
3.10 |
return 1; /* pro forma return */
| 168 |
greg |
3.1 |
| 169 |
| 170 |
| 171 |
void
| 172 |
schorsch |
3.11 |
eputs( /* put string to stderr */
| 173 |
greg |
3.18 |
char *s
| 174 |
schorsch |
3.11 |
| 175 |
greg |
3.1 |
| 176 |
static int midline = 0;
| 177 |
| 178 |
if (!*s)
| 179 |
return;
| 180 |
if (!midline++) {
| 181 |
fputs(progname, stderr);
| 182 |
fputs(": ", stderr);
| 183 |
| 184 |
fputs(s, stderr);
| 185 |
if (s[strlen(s)-1] == '\n') {
| 186 |
fflush(stderr);
| 187 |
midline = 0;
| 188 |
| 189 |
| 190 |
| 191 |
| 192 |
greg |
3.13 |
void
| 193 |
greg |
3.18 |
quit(int ec) /* make sure exit is called */
| 194 |
greg |
3.13 |
| 195 |
if (ray_pnprocs > 0) /* close children if any */
| 196 |
ray_pclose(0);
| 197 |
exit(ec);
| 198 |
| 199 |
| 200 |
| 201 |
schorsch |
3.10 |
static void
| 202 |
setdefaults(void) /* set default values */
| 203 |
greg |
3.1 |
| 204 |
int nviews;
| 205 |
int decades;
| 206 |
char buf[256];
| 207 |
int i;
| 208 |
| 209 |
if (!vdef(OCTREEF)) {
| 210 |
sprintf(errmsg, "%s or %s must be defined",
| 211 |
vnam(OCTREEF), vnam(RIF));
| 212 |
error(USER, errmsg);
| 213 |
| 214 |
if (!vdef(VIEWFILE)) {
| 215 |
sprintf(errmsg, "%s must be defined", vnam(VIEWFILE));
| 216 |
| 217 |
| 218 |
nviews = countviews();
| 219 |
if (!nviews)
| 220 |
error(USER, "no views in view file");
| 221 |
if (!vdef(END)) {
| 222 |
if (nviews == 1) {
| 223 |
sprintf(errmsg, "%s must be defined for single view",
| 224 |
vnam(END));
| 225 |
| 226 |
| 227 |
sprintf(buf, "%d", nviews);
| 228 |
vval(END) = savqstr(buf);
| 229 |
vdef(END)++;
| 230 |
| 231 |
if (!fend)
| 232 |
fend = vint(END);
| 233 |
if (fbeg > fend)
| 234 |
error(USER, "begin after end");
| 235 |
if (!vdef(BASENAME)) {
| 236 |
decades = (int)log10((double)vint(END)) + 1;
| 237 |
if (decades < 3) decades = 3;
| 238 |
sprintf(buf, "frame%%0%dd", decades);
| 239 |
vval(BASENAME) = savqstr(buf);
| 240 |
vdef(BASENAME)++;
| 241 |
| 242 |
if (!vdef(RATE)) {
| 243 |
vval(RATE) = "8";
| 244 |
vdef(RATE)++;
| 245 |
| 246 |
rate = vflt(RATE);
| 247 |
if (!vdef(RESOLUTION)) {
| 248 |
vval(RESOLUTION) = "640";
| 249 |
vdef(RESOLUTION)++;
| 250 |
| 251 |
if (!vdef(MBLUR)) {
| 252 |
vval(MBLUR) = "0";
| 253 |
vdef(MBLUR)++;
| 254 |
| 255 |
mblur = vflt(MBLUR);
| 256 |
if (mblur > 1.)
| 257 |
mblur = 1.;
| 258 |
/* set up objects */
| 259 |
if (vdef(MOVE)) {
| 260 |
obj_move = (struct ObjMove *)malloc(
| 261 |
sizeof(struct ObjMove)*vdef(MOVE) );
| 262 |
if (obj_move == NULL)
| 263 |
error(SYSTEM, "out of memory in setdefaults");
| 264 |
for (i = 0; i < vdef(MOVE); i++)
| 265 |
setmove(&obj_move[i], nvalue(MOVE, i));
| 266 |
| 267 |
/* set up high quality options */
| 268 |
setrendparams(hirendoptf, vval(HIGHQ));
| 269 |
ray_save(&hirendparams);
| 270 |
/* set up low quality options */
| 271 |
setrendparams(lorendoptf, vval(LOWQ));
| 272 |
ray_save(&lorendparams);
| 273 |
curparams = &lorendparams;
| 274 |
schorsch |
3.5 |
twolevels = memcmp(&lorendparams, &hirendparams, sizeof(RAYPARAMS));
| 275 |
greg |
3.1 |
| 276 |
| 277 |
| 278 |
schorsch |
3.10 |
static void
| 279 |
setmove( /* assign a move object from spec. */
| 280 |
struct ObjMove *om,
| 281 |
char *ms
| 282 |
| 283 |
greg |
3.1 |
| 284 |
char parname[128];
| 285 |
char *cp;
| 286 |
| 287 |
ms = nextword(parname, sizeof(parname), ms);
| 288 |
if (!parname[0])
| 289 |
goto badspec;
| 290 |
for (cp = parname; *cp; cp++)
| 291 |
if (isspace(*cp))
| 292 |
*cp = '_';
| 293 |
for (om->parent = (om - obj_move); om->parent--; )
| 294 |
if (!strcmp(parname, obj_move[om->parent].name))
| 295 |
break;
| 296 |
if (om->parent < 0 &&
| 297 |
strcmp(parname, ".") && strcmp(parname, VOIDID)) {
| 298 |
sprintf(errmsg, "undefined parent object '%s'", parname);
| 299 |
| 300 |
| 301 |
ms = nextword(om->name, sizeof(om->name), ms);
| 302 |
if (!om->name[0])
| 303 |
goto badspec;
| 304 |
for (cp = om->name; *cp; cp++)
| 305 |
if (isspace(*cp))
| 306 |
*cp = '_';
| 307 |
ms = nextword(om->xf_file, sizeof(om->xf_file), ms);
| 308 |
if (!strcmp(om->xf_file, "."))
| 309 |
om->xf_file[0] = '\0';
| 310 |
if (!om->xf_file[0]) {
| 311 |
om->xfs[0] = '\0';
| 312 |
} else if (om->xf_file[0] == '-') {
| 313 |
strcpy(om->xfs, om->xf_file);
| 314 |
| 315 |
| 316 |
ms = nextword(om->spec, sizeof(om->spec), ms);
| 317 |
if (om->spec[0]) {
| 318 |
if (!strcmp(om->spec, ".") || !strcmp(om->spec, VOIDID))
| 319 |
om->spec[0] = '\0';
| 320 |
ms = nextword(om->prio_file, sizeof(om->prio_file), ms);
| 321 |
} else
| 322 |
om->prio_file[0] = '\0';
| 323 |
if (om->prio_file[0]) {
| 324 |
if (isflt(om->prio_file)) {
| 325 |
om->prio = atof(om->prio_file);
| 326 |
| 327 |
schorsch |
3.7 |
haveprio |= ((om->prio < 0.95) | (om->prio > 1.05));
| 328 |
greg |
3.1 |
} else
| 329 |
haveprio = 1;
| 330 |
} else
| 331 |
om->prio = 1.;
| 332 |
om->cfm = -1;
| 333 |
return;
| 334 |
badspec:
| 335 |
error(USER, "bad object specification");
| 336 |
| 337 |
| 338 |
| 339 |
schorsch |
3.10 |
static void
| 340 |
setrendparams( /* set global rendering parameters */
| 341 |
char *optf,
| 342 |
char *qval
| 343 |
| 344 |
greg |
3.1 |
| 345 |
char *argv[1024];
| 346 |
char **av = argv;
| 347 |
int ac, i, rval;
| 348 |
| 349 |
av[ac=0] = NULL;
| 350 |
/* load options from file, first */
| 351 |
if (optf != NULL && *optf) {
| 352 |
greg |
3.17 |
ac = wordfile(av, 1024, optf);
| 353 |
greg |
3.1 |
if (ac < 0) {
| 354 |
sprintf(errmsg, "cannot load options file \"%s\"",
| 355 |
optf);
| 356 |
error(SYSTEM, errmsg);
| 357 |
| 358 |
| 359 |
/* then from options string */
| 360 |
if (qval != NULL && qval[0] == '-')
| 361 |
greg |
3.17 |
ac += wordstring(av+ac, 1024-ac, qval);
| 362 |
greg |
3.1 |
| 363 |
greg |
3.8 |
/* restore default parameters */
| 364 |
ray_restore(NULL);
| 365 |
greg |
3.1 |
/* set what we have */
| 366 |
for (i = 0; i < ac; i++) {
| 367 |
while ((rval = expandarg(&ac, &av, i)) > 0)
| 368 |
| 369 |
if (rval < 0) {
| 370 |
sprintf(errmsg, "cannot expand '%s'", av[i]);
| 371 |
| 372 |
| 373 |
if (!strcmp(av[i], "-w")) {
| 374 |
nowarn++;
| 375 |
continue;
| 376 |
| 377 |
rval = getrenderopt(ac-i, av+i);
| 378 |
greg |
3.8 |
if (rval < 0) {
| 379 |
sprintf(errmsg, "bad render option at '%s'", av[i]);
| 380 |
| 381 |
greg |
3.1 |
| 382 |
greg |
3.8 |
i += rval;
| 383 |
greg |
3.1 |
| 384 |
| 385 |
| 386 |
| 387 |
schorsch |
3.10 |
static void
| 388 |
getradfile( /* run rad and get needed variables */
| 389 |
char *rfargs
| 390 |
| 391 |
greg |
3.1 |
| 392 |
static short mvar[] = {OCONV,OCTREEF,RESOLUTION,EXPOSURE,-1};
| 393 |
char combuf[256];
| 394 |
greg |
3.18 |
int i;
| 395 |
char *cp;
| 396 |
schorsch |
3.10 |
char *pippt = NULL;
| 397 |
greg |
3.1 |
/* create rad command */
| 398 |
strcpy(lorendoptf, "ranim0.opt");
| 399 |
sprintf(combuf,
| 400 |
"rad -v 0 -s -e -w %s %s oconv=-f OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
| 401 |
rfargs,
| 402 |
(vdef(LOWQ) && vval(LOWQ)[0]!='-') ? vval(LOWQ) : "",
| 403 |
lorendoptf);
| 404 |
cp = combuf;
| 405 |
while (*cp) {
| 406 |
if (*cp == '|') pippt = cp;
| 407 |
cp++;
| 408 |
} /* match unset variables */
| 409 |
for (i = 0; mvar[i] >= 0; i++)
| 410 |
if (!vdef(mvar[i])) {
| 411 |
*cp++ = '|';
| 412 |
strcpy(cp, vnam(mvar[i]));
| 413 |
while (*cp) cp++;
| 414 |
pippt = NULL;
| 415 |
| 416 |
if (pippt != NULL)
| 417 |
schorsch |
3.5 |
strcpy(pippt, "> " NULL_DEVICE); /* nothing to match */
| 418 |
greg |
3.1 |
else {
| 419 |
strcpy(cp, ")[ \t]*=' > ranimove.var");
| 420 |
cp += 11; /* point to file name */
| 421 |
| 422 |
system(combuf); /* ignore exit code */
| 423 |
if (pippt == NULL) { /* load variables and remove file */
| 424 |
loadvars(cp);
| 425 |
unlink(cp);
| 426 |
| 427 |
if (!vdef(HIGHQ) || vval(HIGHQ)[0]=='-') {
| 428 |
strcpy(hirendoptf, lorendoptf);
| 429 |
return;
| 430 |
| 431 |
/* get high quality options */
| 432 |
strcpy(hirendoptf, "ranim1.opt");
| 433 |
sprintf(combuf, "rad -v 0 -s -w %s %s OPTFILE=%s",
| 434 |
rfargs, vval(HIGHQ), hirendoptf);
| 435 |
system(combuf);
| 436 |
| 437 |
| 438 |
| 439 |
schorsch |
3.10 |
static void
| 440 |
animate(void) /* run through animation */
| 441 |
greg |
3.1 |
| 442 |
int rpass;
| 443 |
| 444 |
if (fbeg > 1) /* synchronize transforms */
| 445 |
getoctspec(fbeg-1);
| 446 |
| 447 |
for (fcur = fbeg; fcur <= fend; fcur++) {
| 448 |
if (!silent)
| 449 |
printf("Frame %d:\n", fcur);
| 450 |
/* base rendering */
| 451 |
init_frame();
| 452 |
/* refinement */
| 453 |
for (rpass = 0; refine_frame(rpass); rpass++)
| 454 |
| 455 |
/* final filter pass */
| 456 |
filter_frame();
| 457 |
/* output frame */
| 458 |
send_frame();
| 459 |
| 460 |
/* free resources */
| 461 |
free_frame();
| 462 |
if (nprocs > 1)
| 463 |
ray_pdone(1);
| 464 |
else
| 465 |
ray_done(1);
| 466 |
getview(0);
| 467 |
getexp(0);
| 468 |
| 469 |
| 470 |
| 471 |
greg |
3.18 |
VIEW *
| 472 |
schorsch |
3.10 |
getview( /* get view number n */
| 473 |
int n
| 474 |
| 475 |
greg |
3.1 |
| 476 |
static FILE *viewfp = NULL; /* view file pointer */
| 477 |
static int viewnum = 0; /* current view number */
| 478 |
static VIEW curview = STDVIEW; /* current view */
| 479 |
char linebuf[256];
| 480 |
| 481 |
if (n == 0) { /* signal to close file and clean up */
| 482 |
if (viewfp != NULL) {
| 483 |
fclose(viewfp);
| 484 |
viewfp = NULL;
| 485 |
viewnum = 0;
| 486 |
schorsch |
3.6 |
curview = stdview;
| 487 |
greg |
3.1 |
| 488 |
return(NULL);
| 489 |
| 490 |
if (viewfp == NULL) { /* open file */
| 491 |
if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) {
| 492 |
perror(vval(VIEWFILE));
| 493 |
quit(1);
| 494 |
| 495 |
} else if (n > 0 && n < viewnum) { /* rewind file */
| 496 |
if (viewnum == 1 && feof(viewfp))
| 497 |
return(&curview); /* just one view */
| 498 |
if (fseek(viewfp, 0L, 0) == EOF) {
| 499 |
| 500 |
quit(1);
| 501 |
| 502 |
schorsch |
3.6 |
curview = stdview;
| 503 |
greg |
3.1 |
viewnum = 0;
| 504 |
| 505 |
if (n < 0) { /* get next view */
| 506 |
greg |
3.18 |
int c = getc(viewfp);
| 507 |
greg |
3.1 |
if (c == EOF)
| 508 |
return(NULL); /* that's it */
| 509 |
ungetc(c, viewfp);
| 510 |
n = viewnum + 1;
| 511 |
| 512 |
while (n > viewnum) { /* scan to desired view */
| 513 |
if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL)
| 514 |
return(viewnum==1 ? &curview : (VIEW *)NULL);
| 515 |
if (isview(linebuf) && sscanview(&curview, linebuf) > 0)
| 516 |
viewnum++;
| 517 |
| 518 |
return(&curview); /* return it */
| 519 |
| 520 |
| 521 |
| 522 |
schorsch |
3.10 |
static int
| 523 |
countviews(void) /* count views in view file */
| 524 |
greg |
3.1 |
| 525 |
int n;
| 526 |
| 527 |
if (getview(n=1) == NULL)
| 528 |
return(0);
| 529 |
while (getview(-1) != NULL)
| 530 |
n++;
| 531 |
return(n);
| 532 |
| 533 |
| 534 |
| 535 |
greg |
3.18 |
char *
| 536 |
schorsch |
3.10 |
getexp( /* get exposure for nth frame */
| 537 |
int n
| 538 |
| 539 |
greg |
3.1 |
| 540 |
extern char *fskip();
| 541 |
static char expval[32];
| 542 |
static FILE *expfp = NULL;
| 543 |
static int curfrm = 0;
| 544 |
greg |
3.18 |
char *cp;
| 545 |
greg |
3.1 |
| 546 |
if (n == 0) { /* signal to close file */
| 547 |
if (expfp != NULL) {
| 548 |
fclose(expfp);
| 549 |
expfp = NULL;
| 550 |
| 551 |
return(NULL);
| 552 |
| 553 |
if (!vdef(EXPOSURE)) /* no setting (auto) */
| 554 |
return(NULL);
| 555 |
if (isflt(vval(EXPOSURE))) /* always the same */
| 556 |
return(vval(EXPOSURE));
| 557 |
if (expfp == NULL) { /* open exposure file */
| 558 |
if ((expfp = fopen(vval(EXPOSURE), "r")) == NULL) {
| 559 |
sprintf(errmsg, "cannot open exposure file \"%s\"",
| 560 |
vval(EXPOSURE));
| 561 |
| 562 |
| 563 |
curfrm = 0;
| 564 |
| 565 |
if (curfrm > n) { /* rewind if necessary */
| 566 |
rewind(expfp);
| 567 |
curfrm = 0;
| 568 |
| 569 |
while (n > curfrm) { /* read to line */
| 570 |
if (fgets(expval, sizeof(expval), expfp) == NULL) {
| 571 |
sprintf(errmsg, "%s: too few exposures",
| 572 |
vval(EXPOSURE));
| 573 |
| 574 |
| 575 |
if (strlen(expval) == sizeof(expval)-1)
| 576 |
goto formerr;
| 577 |
curfrm++;
| 578 |
| 579 |
cp = fskip(expval); /* check format */
| 580 |
if (cp != NULL)
| 581 |
while (isspace(*cp))
| 582 |
*cp++ = '\0';
| 583 |
if (cp == NULL || *cp)
| 584 |
goto formerr;
| 585 |
return(expval); /* return value */
| 586 |
formerr:
| 587 |
sprintf(errmsg, "%s: exposure format error on line %d",
| 588 |
vval(EXPOSURE), curfrm);
| 589 |
| 590 |
schorsch |
3.10 |
return NULL; /* pro forma return */
| 591 |
greg |
3.1 |
| 592 |
| 593 |
| 594 |
greg |
3.18 |
double
| 595 |
schorsch |
3.10 |
expspec_val( /* get exposure value from spec. */
| 596 |
char *s
| 597 |
| 598 |
greg |
3.1 |
| 599 |
double expval;
| 600 |
| 601 |
if (s == NULL || !*s)
| 602 |
return(1.0);
| 603 |
| 604 |
expval = atof(s);
| 605 |
schorsch |
3.7 |
if ((s[0] == '+') | (s[0] == '-'))
| 606 |
greg |
3.1 |
return(pow(2.0, expval));
| 607 |
return(expval);
| 608 |
| 609 |
| 610 |
| 611 |
greg |
3.18 |
char *
| 612 |
schorsch |
3.10 |
getoctspec( /* get octree for the given frame */
| 613 |
int n
| 614 |
| 615 |
greg |
3.1 |
| 616 |
static char combuf[1024];
| 617 |
greg |
3.14 |
static int cfm = 0;
| 618 |
greg |
3.1 |
int uses_inline;
| 619 |
FILE *fp;
| 620 |
int i;
| 621 |
/* is octree static? */
| 622 |
if (!vdef(MOVE))
| 623 |
return(vval(OCTREEF));
| 624 |
greg |
3.14 |
/* done already? */
| 625 |
greg |
3.1 |
if (n == cfm)
| 626 |
return(combuf);
| 627 |
/* else create object file */
| 628 |
greg |
3.14 |
fp = fopen(mktemp(strcpy(objtmpf, TEMPLATE)), "w");
| 629 |
greg |
3.1 |
if (fp == NULL) {
| 630 |
sprintf(errmsg, "cannot write to moving objects file '%s'",
| 631 |
objtmpf);
| 632 |
| 633 |
| 634 |
uses_inline = 0;
| 635 |
for (i = 0; i < vdef(MOVE); i++) {
| 636 |
int inlc = (obj_move[i].spec[0] == '!');
| 637 |
if (!obj_move[i].spec[0])
| 638 |
continue;
| 639 |
if (inlc)
| 640 |
fprintf(fp, "%s %d \\\n\t| xform",
| 641 |
obj_move[i].spec, n);
| 642 |
else
| 643 |
fputs("!xform", fp);
| 644 |
fprintf(fp, " -n %s", getobjname(&obj_move[i]));
| 645 |
fputs(getxf(&obj_move[i], n), fp);
| 646 |
if (!inlc)
| 647 |
fprintf(fp, " %s\n", obj_move[i].spec);
| 648 |
else
| 649 |
fputc('\n', fp);
| 650 |
uses_inline |= inlc;
| 651 |
| 652 |
if (fclose(fp) == EOF)
| 653 |
error(SYSTEM, "error writing moving objects file");
| 654 |
if (uses_inline)
| 655 |
sprintf(combuf, "!oconv %s -f -i '%s' %s",
| 656 |
vdef(OCONV) ? vval(OCONV) : "",
| 657 |
vval(OCTREEF), objtmpf);
| 658 |
else
| 659 |
greg |
3.14 |
sprintf(combuf, "!xform -f %s | oconv %s -f -i '%s' -",
| 660 |
objtmpf, vdef(OCONV) ? vval(OCONV) : "",
| 661 |
vval(OCTREEF));
| 662 |
greg |
3.1 |
return(combuf);
| 663 |
| 664 |
| 665 |
| 666 |
schorsch |
3.10 |
static char *
| 667 |
getobjname( /* get fully qualified object name */
| 668 |
greg |
3.18 |
struct ObjMove *om
| 669 |
schorsch |
3.10 |
| 670 |
greg |
3.1 |
| 671 |
static char objName[512];
| 672 |
greg |
3.18 |
char *cp = objName;
| 673 |
greg |
3.1 |
| 674 |
strcpy(cp, om->name);
| 675 |
while (om->parent >= 0) {
| 676 |
while (*cp) cp++;
| 677 |
*cp++ = '@';
| 678 |
om = &obj_move[om->parent];
| 679 |
| 680 |
| 681 |
return(objName);
| 682 |
| 683 |
| 684 |
| 685 |
schorsch |
3.10 |
static char *
| 686 |
getxf( /* get total transform for object */
| 687 |
greg |
3.18 |
struct ObjMove *om,
| 688 |
schorsch |
3.10 |
int n
| 689 |
| 690 |
greg |
3.1 |
| 691 |
static char xfsbuf[4096];
| 692 |
char *xfp;
| 693 |
int framestep = 0;
| 694 |
XF oxf;
| 695 |
FILE *fp;
| 696 |
char abuf[512];
| 697 |
char *av[64];
| 698 |
int ac;
| 699 |
int i;
| 700 |
greg |
3.18 |
char *cp;
| 701 |
greg |
3.1 |
/* get parent transform, first */
| 702 |
if (om->parent >= 0)
| 703 |
xfp = getxf(&obj_move[om->parent], n);
| 704 |
else
| 705 |
*(xfp = xfsbuf + sizeof(xfsbuf)-1) = '\0';
| 706 |
/* get transform spec. & priority */
| 707 |
if (om->cfm != n) {
| 708 |
if (om->xf_file[0]) {
| 709 |
fp = fopen(om->xf_file, "r");
| 710 |
if (fp == NULL) {
| 711 |
sprintf(errmsg,
| 712 |
"cannot open transform file '%s'",
| 713 |
om->xf_file);
| 714 |
| 715 |
| 716 |
for (i = 0; i < n; i++)
| 717 |
if (fgetline(om->xfs, sizeof(om->xfs), fp)
| 718 |
== NULL) {
| 719 |
sprintf(errmsg,
| 720 |
"too few transforms in file '%s'",
| 721 |
om->xf_file);
| 722 |
| 723 |
| 724 |
fclose(fp);
| 725 |
| 726 |
strcpy(cp=abuf, om->xfs);
| 727 |
ac = 0;
| 728 |
for ( ; ; ) {
| 729 |
| 730 |
*cp++ = '\0';
| 731 |
if (!*cp)
| 732 |
break;
| 733 |
av[ac++] = cp;
| 734 |
while (*++cp && !isspace(*cp))
| 735 |
| 736 |
| 737 |
av[ac] = NULL;
| 738 |
if (xf(&oxf, ac, av) != ac ||
| 739 |
fabs(oxf.sca) <= FTINY) {
| 740 |
sprintf(errmsg, "bad transform args: %s",
| 741 |
om->xfs);
| 742 |
| 743 |
| 744 |
copymat4(om->xfm, oxf.xfm);
| 745 |
| 746 |
fp = fopen(om->prio_file, "r");
| 747 |
if (fp == NULL) {
| 748 |
sprintf(errmsg,
| 749 |
"cannot open priority file '%s'",
| 750 |
om->prio_file);
| 751 |
| 752 |
| 753 |
| 754 |
if (fgets(abuf, sizeof(abuf), fp)
| 755 |
== NULL) {
| 756 |
sprintf(errmsg,
| 757 |
"too few priorities in file '%s'",
| 758 |
om->prio_file);
| 759 |
| 760 |
| 761 |
fclose(fp);
| 762 |
cp = fskip(abuf);
| 763 |
if (cp != NULL)
| 764 |
| 765 |
*cp++ = '\0';
| 766 |
if (cp == NULL || *cp) {
| 767 |
sprintf(errmsg,
| 768 |
"priority '%s' in file '%s' not a number",
| 769 |
abuf, om->prio_file);
| 770 |
| 771 |
| 772 |
om->prio = atof(abuf);
| 773 |
| 774 |
framestep = (n == om->cfm + 1);
| 775 |
om->cfm = n;
| 776 |
| 777 |
/* prepend to parent transform */
| 778 |
if (om->xfs[0]) {
| 779 |
i = strlen(om->xfs);
| 780 |
if (xfp - i <= xfsbuf)
| 781 |
error(INTERNAL, "transform too long in getxf");
| 782 |
cp = om->xfs + i;
| 783 |
while (i--)
| 784 |
*--xfp = *--cp;
| 785 |
*--xfp = ' ';
| 786 |
| 787 |
if (framestep)
| 788 |
copymat4(oxf.xfm, om->cxfm);
| 789 |
if (om->parent >= 0) {
| 790 |
multmat4(om->cxfm, om->xfm, obj_move[om->parent].cxfm);
| 791 |
om->cprio = obj_move[om->parent].cprio * om->prio;
| 792 |
} else {
| 793 |
copymat4(om->cxfm, om->xfm);
| 794 |
om->cprio = om->prio;
| 795 |
| 796 |
/* XXX bxfm relies on call order */
| 797 |
schorsch |
3.6 |
if (framestep) {
| 798 |
greg |
3.1 |
if (invmat4(om->bxfm, om->cxfm))
| 799 |
multmat4(om->bxfm, om->bxfm, oxf.xfm);
| 800 |
else
| 801 |
setident4(om->bxfm);
| 802 |
schorsch |
3.6 |
| 803 |
greg |
3.1 |
/* all done */
| 804 |
return(xfp);
| 805 |
| 806 |
| 807 |
| 808 |
greg |
3.18 |
int
| 809 |
schorsch |
3.10 |
getmove( /* find matching move object */
| 810 |
OBJECT obj
| 811 |
| 812 |
greg |
3.1 |
| 813 |
static int lasti;
| 814 |
static OBJECT lasto = OVOID;
| 815 |
char *onm, *objnm;
| 816 |
int len, len2;
| 817 |
greg |
3.18 |
int i;
| 818 |
greg |
3.1 |
| 819 |
if (obj == OVOID)
| 820 |
return(-1);
| 821 |
if (obj == lasto)
| 822 |
return(lasti);
| 823 |
/* look for matching object */
| 824 |
onm = objptr(obj)->oname;
| 825 |
for (i = vdef(MOVE); i--; ) {
| 826 |
objnm = obj_move[i].name;
| 827 |
len = strlen(objnm);
| 828 |
if (!strncmp(onm, objnm, len)) {
| 829 |
schorsch |
3.7 |
if ((obj_move[i].parent < 0) & (onm[len] == '.'))
| 830 |
greg |
3.1 |
break;
| 831 |
objnm = getobjname(&obj_move[i]) + len;
| 832 |
len2 = strlen(objnm);
| 833 |
if (!strncmp(onm+len, objnm, len2) && onm[len+len2] == '.')
| 834 |
break;
| 835 |
| 836 |
| 837 |
lasto = obj; /* cache what we found */
| 838 |
return(lasti = i);
| 839 |
| 840 |
| 841 |
| 842 |
greg |
3.18 |
double
| 843 |
schorsch |
3.10 |
obj_prio( /* return priority for object */
| 844 |
OBJECT obj
| 845 |
| 846 |
greg |
3.1 |
| 847 |
int moi;
| 848 |
| 849 |
if (obj == OVOID || (moi = getmove(obj)) < 0)
| 850 |
return(1.0);
| 851 |
return(obj_move[moi].cprio);
| 852 |
| 853 |
| 854 |
| 855 |
schorsch |
3.16 |
| 856 |
greg |
3.15 |
/* replacement function for Windoze */
| 857 |
static int
| 858 |
gettimeofday(struct timeval *tp, void *dummy)
| 859 |
| 860 |
FILETIME ft;
| 861 |
LARGE_INTEGER li;
| 862 |
__int64 t;
| 863 |
| 864 |
SYSTEMTIME st;
| 865 |
FILETIME ft2;
| 866 |
LARGE_INTEGER li2;
| 867 |
__int64 t2;
| 868 |
| 869 |
st.wYear = 1970;
| 870 |
st.wHour = 0;
| 871 |
st.wMinute = 0;
| 872 |
st.wSecond = 0;
| 873 |
st.wMilliseconds = 1;
| 874 |
| 875 |
SystemTimeToFileTime(&st, &ft2);
| 876 |
li2.LowPart = ft2.dwLowDateTime;
| 877 |
li2.HighPart = ft2.dwHighDateTime;
| 878 |
t2 = li2.QuadPart;
| 879 |
| 880 |
GetSystemTimeAsFileTime(&ft);
| 881 |
li.LowPart = ft.dwLowDateTime;
| 882 |
li.HighPart = ft.dwHighDateTime;
| 883 |
t = li.QuadPart;
| 884 |
t -= t2; // From 1970
| 885 |
t /= 10; // In microseconds
| 886 |
tp->tv_sec = (long)(t / 1000000);
| 887 |
tp->tv_usec = (long)(t % 1000000);
| 888 |
return 0;
| 889 |
| 890 |
| 891 |
#endif
| 892 |
| 893 |
greg |
3.18 |
double
| 894 |
schorsch |
3.10 |
getTime(void) /* get current time (CPU or real) */
| 895 |
greg |
3.1 |
| 896 |
struct timeval time_now;
| 897 |
/* return CPU time if one process */
| 898 |
if (nprocs == 1)
| 899 |
return((double)clock()*(1.0/(double)CLOCKS_PER_SEC));
| 900 |
/* otherwise, return wall time */
| 901 |
gettimeofday(&time_now, NULL);
| 902 |
return((double)time_now.tv_sec + 1e-6*(double)time_now.tv_usec);
| 903 |
