root/radiance/ray/src/util/ranimove.c
Revision: 3.8
Committed: Tue Sep 23 03:54:57 2003 UTC (20 years, 9 months ago) by greg
Changes since 3.7: +7 -8 lines
2 static const char RCSid[] = "$Id";
5 * Radiance object animation program
6 *
7 * Main program and control file handling.
8 *
9 * See ranimove.h and the ranimove(1) man page for details.
10 */
11
12 #include "copyright.h"
13
14 #include <time.h>
15 #ifndef _WIN32
16 #include <sys/time.h>
17 #endif
18 #include <ctype.h>
19 #include <string.h>
20
21 #include "paths.h"
22 #include "ranimove.h"
23
24 int NVARS = NV_INIT; /* total number of variables */
25
26 VARIABLE vv[] = VV_INIT; /* variable-value pairs */
27
28 extern int nowarn; /* don't report warnings? */
29 int silent = 0; /* run silently? */
30
31 int quickstart = 0; /* time initial frame as well? */
32
33 int nprocs = 1; /* number of rendering processes */
34
35 int rtperfrm = 60; /* seconds to spend per frame */
36
37 double ndthresh = 2.; /* noticeable difference threshold */
38 int ndtset = 0; /* user threshold -- stop when reached? */
39
40 int fbeg = 1; /* starting frame */
41 int fend = 0; /* ending frame */
42 int fcur; /* current frame being rendered */
43
44 char lorendoptf[32]; /* low quality options file */
45 RAYPARAMS lorendparams; /* low quality rendering parameters */
46 char hirendoptf[32]; /* high quality options file */
47 RAYPARAMS hirendparams; /* high quality rendering parameters */
48 RAYPARAMS *curparams; /* current parameter settings */
49 int twolevels; /* low and high quality differ */
50
51 double mblur; /* vflt(MBLUR) */
52 double rate; /* vflt(RATE) */
53
54 char objtmpf[32]; /* object temporary file */
55
56 struct ObjMove *obj_move; /* object movements */
57
58 int haveprio = 0; /* high-level saliency specified */
59
60 int gargc; /* global argc for printargs */
61 char **gargv; /* global argv for printargs */
62
63
64 int
65 main(argc, argv)
66 int argc;
67 char *argv[];
68 {
69 int explicate = 0;
70 char *cfname;
71 int i;
72
73 progname = argv[0]; /* get arguments */
74 gargc = argc;
75 gargv = argv;
76 for (i = 1; i < argc && argv[i][0] == '-'; i++)
77 switch (argv[i][1]) {
78 case 't': /* seconds per frame */
79 rtperfrm = atoi(argv[++i]);
80 break;
81 case 'd': /* noticeable difference */
82 ndthresh = atof(argv[++i]);
83 ndtset = 1;
84 break;
85 case 'e': /* print variables */
86 explicate++;
87 break;
88 case 's': /* silent running */
89 silent++;
90 break;
91 case 'q': /* start quickly */
92 quickstart++;
93 break;
94 case 'w': /* turn off warnings */
95 nowarn++;
96 break;
97 case 'f': /* frame range */
98 switch (sscanf(argv[++i], "%d,%d", &fbeg, &fend)) {
99 case 2:
100 if ((fbeg <= 0) | (fend < fbeg))
101 goto userr;
102 break;
103 case 1:
104 if (fbeg <= 0)
105 goto userr;
106 fend = 0;
107 break;
108 default:
109 goto userr;
110 }
111 break;
112 case 'n': /* number of processes */
113 nprocs = atoi(argv[++i]);
114 break;
115 default:
116 goto userr;
117 }
118 if (rtperfrm <= 0) {
119 if (!ndtset)
120 error(USER, "specify -d jnd with -t 0");
121 rtperfrm = 7*24*3600;
122 }
123 if (i != argc-1)
124 goto userr;
125 cfname = argv[i];
126 /* load variables */
127 loadvars(cfname);
128 /* check variables */
129 checkvalues();
130 /* load RIF if any */
131 if (vdef(RIF))
132 getradfile(vval(RIF));
133 /* set defaults */
134 setdefaults();
135 /* print variables */
136 if (explicate)
137 printvars(stdout);
138 /* run animation */
139 if (nprocs > 0)
140 animate();
141 /* all done */
142 if (lorendoptf[0])
143 unlink(lorendoptf);
144 if (hirendoptf[0] && strcmp(hirendoptf, lorendoptf))
145 unlink(hirendoptf);
146 if (objtmpf[0])
147 unlink(objtmpf);
148 return(0);
149 userr:
150 fprintf(stderr,
151 "Usage: %s [-n nprocs][-f beg,end][-t sec][-d jnd][-s][-w][-e] anim_file\n",
152 progname);
153 quit(1);
154 }
155
156
157 void
158 eputs(s) /* put string to stderr */
159 register char *s;
160 {
161 static int midline = 0;
162
163 if (!*s)
164 return;
165 if (!midline++) {
166 fputs(progname, stderr);
167 fputs(": ", stderr);
168 }
169 fputs(s, stderr);
170 if (s[strlen(s)-1] == '\n') {
171 fflush(stderr);
172 midline = 0;
173 }
174 }
175
176
177 void
178 setdefaults() /* set default values */
179 {
180 int nviews;
181 int decades;
182 char buf[256];
183 int i;
184
185 if (!vdef(OCTREEF)) {
186 sprintf(errmsg, "%s or %s must be defined",
187 vnam(OCTREEF), vnam(RIF));
188 error(USER, errmsg);
189 }
190 if (!vdef(VIEWFILE)) {
191 sprintf(errmsg, "%s must be defined", vnam(VIEWFILE));
192 error(USER, errmsg);
193 }
194 nviews = countviews();
195 if (!nviews)
196 error(USER, "no views in view file");
197 if (!vdef(END)) {
198 if (nviews == 1) {
199 sprintf(errmsg, "%s must be defined for single view",
200 vnam(END));
201 error(USER, errmsg);
202 }
203 sprintf(buf, "%d", nviews);
204 vval(END) = savqstr(buf);
205 vdef(END)++;
206 }
207 if (!fend)
208 fend = vint(END);
209 if (fbeg > fend)
210 error(USER, "begin after end");
211 if (!vdef(BASENAME)) {
212 decades = (int)log10((double)vint(END)) + 1;
213 if (decades < 3) decades = 3;
214 sprintf(buf, "frame%%0%dd", decades);
215 vval(BASENAME) = savqstr(buf);
216 vdef(BASENAME)++;
217 }
218 if (!vdef(RATE)) {
219 vval(RATE) = "8";
220 vdef(RATE)++;
221 }
222 rate = vflt(RATE);
223 if (!vdef(RESOLUTION)) {
224 vval(RESOLUTION) = "640";
225 vdef(RESOLUTION)++;
226 }
227 if (!vdef(MBLUR)) {
228 vval(MBLUR) = "0";
229 vdef(MBLUR)++;
230 }
231 mblur = vflt(MBLUR);
232 if (mblur > 1.)
233 mblur = 1.;
234 /* set up objects */
235 if (vdef(MOVE)) {
236 obj_move = (struct ObjMove *)malloc(
237 sizeof(struct ObjMove)*vdef(MOVE) );
238 if (obj_move == NULL)
239 error(SYSTEM, "out of memory in setdefaults");
240 for (i = 0; i < vdef(MOVE); i++)
241 setmove(&obj_move[i], nvalue(MOVE, i));
242 }
243 /* set up high quality options */
244 setrendparams(hirendoptf, vval(HIGHQ));
245 ray_save(&hirendparams);
246 /* set up low quality options */
247 setrendparams(lorendoptf, vval(LOWQ));
248 ray_save(&lorendparams);
249 curparams = &lorendparams;
250 twolevels = memcmp(&lorendparams, &hirendparams, sizeof(RAYPARAMS));
251 }
252
253
254 void
255 setmove(om, ms) /* assign a move object from spec. */
256 struct ObjMove *om;
257 char *ms;
258 {
259 char parname[128];
260 char *cp;
261
262 ms = nextword(parname, sizeof(parname), ms);
263 if (!parname[0])
264 goto badspec;
265 for (cp = parname; *cp; cp++)
266 if (isspace(*cp))
267 *cp = '_';
268 for (om->parent = (om - obj_move); om->parent--; )
269 if (!strcmp(parname, obj_move[om->parent].name))
270 break;
271 if (om->parent < 0 &&
272 strcmp(parname, ".") && strcmp(parname, VOIDID)) {
273 sprintf(errmsg, "undefined parent object '%s'", parname);
274 error(USER, errmsg);
275 }
276 ms = nextword(om->name, sizeof(om->name), ms);
277 if (!om->name[0])
278 goto badspec;
279 for (cp = om->name; *cp; cp++)
280 if (isspace(*cp))
281 *cp = '_';
282 ms = nextword(om->xf_file, sizeof(om->xf_file), ms);
283 if (!strcmp(om->xf_file, "."))
284 om->xf_file[0] = '\0';
285 if (!om->xf_file[0]) {
286 om->xfs[0] = '\0';
287 } else if (om->xf_file[0] == '-') {
288 strcpy(om->xfs, om->xf_file);
289 om->xf_file[0] = '\0';
290 }
291 ms = nextword(om->spec, sizeof(om->spec), ms);
292 if (om->spec[0]) {
293 if (!strcmp(om->spec, ".") || !strcmp(om->spec, VOIDID))
294 om->spec[0] = '\0';
295 ms = nextword(om->prio_file, sizeof(om->prio_file), ms);
296 } else
297 om->prio_file[0] = '\0';
298 if (om->prio_file[0]) {
299 if (isflt(om->prio_file)) {
300 om->prio = atof(om->prio_file);
301 om->prio_file[0] = '\0';
302 haveprio |= ((om->prio < 0.95) | (om->prio > 1.05));
303 } else
304 haveprio = 1;
305 } else
306 om->prio = 1.;
307 om->cfm = -1;
308 return;
309 badspec:
310 error(USER, "bad object specification");
311 }
312
313
314 void
315 setrendparams(optf, qval) /* set global rendering parameters */
316 char *optf;
317 char *qval;
318 {
319 char *argv[1024];
320 char **av = argv;
321 int ac, i, rval;
322
323 av[ac=0] = NULL;
324 /* load options from file, first */
325 if (optf != NULL && *optf) {
326 ac = wordfile(av, optf);
327 if (ac < 0) {
328 sprintf(errmsg, "cannot load options file \"%s\"",
329 optf);
330 error(SYSTEM, errmsg);
331 }
332 }
333 /* then from options string */
334 if (qval != NULL && qval[0] == '-')
335 ac += wordstring(av+ac, qval);
336
337 /* restore default parameters */
338 ray_restore(NULL);
339 /* set what we have */
340 for (i = 0; i < ac; i++) {
341 while ((rval = expandarg(&ac, &av, i)) > 0)
342 ;
343 if (rval < 0) {
344 sprintf(errmsg, "cannot expand '%s'", av[i]);
345 error(SYSTEM, errmsg);
346 }
347 if (!strcmp(av[i], "-w")) {
348 nowarn++;
349 continue;
350 }
351 rval = getrenderopt(ac-i, av+i);
352 if (rval < 0) {
353 sprintf(errmsg, "bad render option at '%s'", av[i]);
354 error(USER, errmsg);
355 }
356 i += rval;
357 }
358 }
359
360
361 void
362 getradfile(rfargs) /* run rad and get needed variables */
363 char *rfargs;
364 {
365 static short mvar[] = {OCONV,OCTREEF,RESOLUTION,EXPOSURE,-1};
366 char combuf[256];
367 register int i;
368 register char *cp;
369 char *pippt;
370 /* create rad command */
371 strcpy(lorendoptf, "ranim0.opt");
372 sprintf(combuf,
373 "rad -v 0 -s -e -w %s %s oconv=-f OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
374 rfargs,
375 (vdef(LOWQ) && vval(LOWQ)[0]!='-') ? vval(LOWQ) : "",
376 lorendoptf);
377 cp = combuf;
378 while (*cp) {
379 if (*cp == '|') pippt = cp;
380 cp++;
381 } /* match unset variables */
382 for (i = 0; mvar[i] >= 0; i++)
383 if (!vdef(mvar[i])) {
384 *cp++ = '|';
385 strcpy(cp, vnam(mvar[i]));
386 while (*cp) cp++;
387 pippt = NULL;
388 }
389 if (pippt != NULL)
390 strcpy(pippt, "> " NULL_DEVICE); /* nothing to match */
391 else {
392 strcpy(cp, ")[ \t]*=' > ranimove.var");
393 cp += 11; /* point to file name */
394 }
395 system(combuf); /* ignore exit code */
396 if (pippt == NULL) { /* load variables and remove file */
397 loadvars(cp);
398 unlink(cp);
399 }
400 if (!vdef(HIGHQ) || vval(HIGHQ)[0]=='-') {
401 strcpy(hirendoptf, lorendoptf);
402 return;
403 }
404 /* get high quality options */
405 strcpy(hirendoptf, "ranim1.opt");
406 sprintf(combuf, "rad -v 0 -s -w %s %s OPTFILE=%s",
407 rfargs, vval(HIGHQ), hirendoptf);
408 system(combuf);
409 }
410
411
412 void
413 animate() /* run through animation */
414 {
415 int rpass;
416
417 if (fbeg > 1) /* synchronize transforms */
418 getoctspec(fbeg-1);
419
420 for (fcur = fbeg; fcur <= fend; fcur++) {
421 if (!silent)
422 printf("Frame %d:\n", fcur);
423 /* base rendering */
424 init_frame();
425 /* refinement */
426 for (rpass = 0; refine_frame(rpass); rpass++)
427 ;
428 /* final filter pass */
429 filter_frame();
430 /* output frame */
431 send_frame();
432 }
433 /* free resources */
434 free_frame();
435 if (nprocs > 1)
436 ray_pdone(1);
437 else
438 ray_done(1);
439 getview(0);
440 getexp(0);
441 }
442
443
444 VIEW *
445 getview(n) /* get view number n */
446 int n;
447 {
448 static FILE *viewfp = NULL; /* view file pointer */
449 static int viewnum = 0; /* current view number */
450 static VIEW curview = STDVIEW; /* current view */
451 char linebuf[256];
452
453 if (n == 0) { /* signal to close file and clean up */
454 if (viewfp != NULL) {
455 fclose(viewfp);
456 viewfp = NULL;
457 viewnum = 0;
458 curview = stdview;
459 }
460 return(NULL);
461 }
462 if (viewfp == NULL) { /* open file */
463 if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) {
464 perror(vval(VIEWFILE));
465 quit(1);
466 }
467 } else if (n > 0 && n < viewnum) { /* rewind file */
468 if (viewnum == 1 && feof(viewfp))
469 return(&curview); /* just one view */
470 if (fseek(viewfp, 0L, 0) == EOF) {
471 perror(vval(VIEWFILE));
472 quit(1);
473 }
474 curview = stdview;
475 viewnum = 0;
476 }
477 if (n < 0) { /* get next view */
478 register int c = getc(viewfp);
479 if (c == EOF)
480 return(NULL); /* that's it */
481 ungetc(c, viewfp);
482 n = viewnum + 1;
483 }
484 while (n > viewnum) { /* scan to desired view */
485 if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL)
486 return(viewnum==1 ? &curview : (VIEW *)NULL);
487 if (isview(linebuf) && sscanview(&curview, linebuf) > 0)
488 viewnum++;
489 }
490 return(&curview); /* return it */
491 }
492
493
494 int
495 countviews() /* count views in view file */
496 {
497 int n;
498
499 if (getview(n=1) == NULL)
500 return(0);
501 while (getview(-1) != NULL)
502 n++;
503 return(n);
504 }
505
506
507 char *
508 getexp(n) /* get exposure for nth frame */
509 int n;
510 {
511 extern char *fskip();
512 static char expval[32];
513 static FILE *expfp = NULL;
514 static int curfrm = 0;
515 register char *cp;
516
517 if (n == 0) { /* signal to close file */
518 if (expfp != NULL) {
519 fclose(expfp);
520 expfp = NULL;
521 }
522 return(NULL);
523 }
524 if (!vdef(EXPOSURE)) /* no setting (auto) */
525 return(NULL);
526 if (isflt(vval(EXPOSURE))) /* always the same */
527 return(vval(EXPOSURE));
528 if (expfp == NULL) { /* open exposure file */
529 if ((expfp = fopen(vval(EXPOSURE), "r")) == NULL) {
530 sprintf(errmsg, "cannot open exposure file \"%s\"",
531 vval(EXPOSURE));
532 error(SYSTEM, errmsg);
533 }
534 curfrm = 0;
535 }
536 if (curfrm > n) { /* rewind if necessary */
537 rewind(expfp);
538 curfrm = 0;
539 }
540 while (n > curfrm) { /* read to line */
541 if (fgets(expval, sizeof(expval), expfp) == NULL) {
542 sprintf(errmsg, "%s: too few exposures",
543 vval(EXPOSURE));
544 error(USER, errmsg);
545 }
546 if (strlen(expval) == sizeof(expval)-1)
547 goto formerr;
548 curfrm++;
549 }
550 cp = fskip(expval); /* check format */
551 if (cp != NULL)
552 while (isspace(*cp))
553 *cp++ = '\0';
554 if (cp == NULL || *cp)
555 goto formerr;
556 return(expval); /* return value */
557 formerr:
558 sprintf(errmsg, "%s: exposure format error on line %d",
559 vval(EXPOSURE), curfrm);
560 error(USER, errmsg);
561 }
562
563
564 double
565 expspec_val(s) /* get exposure value from spec. */
566 char *s;
567 {
568 double expval;
569
570 if (s == NULL || !*s)
571 return(1.0);
572
573 expval = atof(s);
574 if ((s[0] == '+') | (s[0] == '-'))
575 return(pow(2.0, expval));
576 return(expval);
577 }
578
579
580 char *
581 getoctspec(n) /* get octree for the given frame */
582 int n;
583 {
584 static char combuf[1024];
585 int cfm = 0;
586 int uses_inline;
587 FILE *fp;
588 int i;
589 /* is octree static? */
590 if (!vdef(MOVE))
591 return(vval(OCTREEF));
592 /* done already */
593 if (n == cfm)
594 return(combuf);
595 /* else create object file */
596 strcpy(objtmpf, "movinobj.rad");
597 fp = fopen(objtmpf, "w");
598 if (fp == NULL) {
599 sprintf(errmsg, "cannot write to moving objects file '%s'",
600 objtmpf);
601 error(SYSTEM, errmsg);
602 }
603 uses_inline = 0;
604 for (i = 0; i < vdef(MOVE); i++) {
605 int inlc = (obj_move[i].spec[0] == '!');
606 if (!obj_move[i].spec[0])
607 continue;
608 if (inlc)
609 fprintf(fp, "%s %d \\\n\t| xform",
610 obj_move[i].spec, n);
611 else
612 fputs("!xform", fp);
613 fprintf(fp, " -n %s", getobjname(&obj_move[i]));
614 fputs(getxf(&obj_move[i], n), fp);
615 if (!inlc)
616 fprintf(fp, " %s\n", obj_move[i].spec);
617 else
618 fputc('\n', fp);
619 uses_inline |= inlc;
620 }
621 if (fclose(fp) == EOF)
622 error(SYSTEM, "error writing moving objects file");
623 if (uses_inline)
624 sprintf(combuf, "!oconv %s -f -i '%s' %s",
625 vdef(OCONV) ? vval(OCONV) : "",
626 vval(OCTREEF), objtmpf);
627 else
628 sprintf(combuf, "!xform -f %s | oconv -f -i '%s' -",
629 objtmpf, vval(OCTREEF));
630 return(combuf);
631 }
632
633
634 char *
635 getobjname(om) /* get fully qualified object name */
636 register struct ObjMove *om;
637 {
638 static char objName[512];
639 register char *cp = objName;
640
641 strcpy(cp, om->name);
642 while (om->parent >= 0) {
643 while (*cp) cp++;
644 *cp++ = '@';
645 om = &obj_move[om->parent];
646 strcpy(cp, om->name);
647 }
648 return(objName);
649 }
650
651
652 char *
653 getxf(om, n) /* get total transform for object */
654 register struct ObjMove *om;
655 int n;
656 {
657 static char xfsbuf[4096];
658 char *xfp;
659 int framestep = 0;
660 XF oxf;
661 FILE *fp;
662 char abuf[512];
663 char *av[64];
664 int ac;
665 int i;
666 register char *cp;
667 /* get parent transform, first */
668 if (om->parent >= 0)
669 xfp = getxf(&obj_move[om->parent], n);
670 else
671 *(xfp = xfsbuf + sizeof(xfsbuf)-1) = '\0';
672 /* get transform spec. & priority */
673 if (om->cfm != n) {
674 if (om->xf_file[0]) {
675 fp = fopen(om->xf_file, "r");
676 if (fp == NULL) {
677 sprintf(errmsg,
678 "cannot open transform file '%s'",
679 om->xf_file);
680 error(SYSTEM, errmsg);
681 }
682 for (i = 0; i < n; i++)
683 if (fgetline(om->xfs, sizeof(om->xfs), fp)
684 == NULL) {
685 sprintf(errmsg,
686 "too few transforms in file '%s'",
687 om->xf_file);
688 error(USER, errmsg);
689 }
690 fclose(fp);
691 }
692 strcpy(cp=abuf, om->xfs);
693 ac = 0;
694 for ( ; ; ) {
695 while (isspace(*cp))
696 *cp++ = '\0';
697 if (!*cp)
698 break;
699 av[ac++] = cp;
700 while (*++cp && !isspace(*cp))
701 ;
702 }
703 av[ac] = NULL;
704 if (xf(&oxf, ac, av) != ac ||
705 fabs(oxf.sca) <= FTINY) {
706 sprintf(errmsg, "bad transform args: %s",
707 om->xfs);
708 error(USER, errmsg);
709 }
710 copymat4(om->xfm, oxf.xfm);
711 if (om->prio_file[0]) {
712 fp = fopen(om->prio_file, "r");
713 if (fp == NULL) {
714 sprintf(errmsg,
715 "cannot open priority file '%s'",
716 om->prio_file);
717 error(SYSTEM, errmsg);
718 }
719 for (i = 0; i < n; i++)
720 if (fgets(abuf, sizeof(abuf), fp)
721 == NULL) {
722 sprintf(errmsg,
723 "too few priorities in file '%s'",
724 om->prio_file);
725 error(USER, errmsg);
726 }
727 fclose(fp);
728 cp = fskip(abuf);
729 if (cp != NULL)
730 while (isspace(*cp))
731 *cp++ = '\0';
732 if (cp == NULL || *cp) {
733 sprintf(errmsg,
734 "priority '%s' in file '%s' not a number",
735 abuf, om->prio_file);
736 error(USER, errmsg);
737 }
738 om->prio = atof(abuf);
739 }
740 framestep = (n == om->cfm + 1);
741 om->cfm = n;
742 }
743 /* prepend to parent transform */
744 if (om->xfs[0]) {
745 i = strlen(om->xfs);
746 if (xfp - i <= xfsbuf)
747 error(INTERNAL, "transform too long in getxf");
748 cp = om->xfs + i;
749 while (i--)
750 *--xfp = *--cp;
751 *--xfp = ' ';
752 }
753 if (framestep)
754 copymat4(oxf.xfm, om->cxfm);
755 if (om->parent >= 0) {
756 multmat4(om->cxfm, om->xfm, obj_move[om->parent].cxfm);
757 om->cprio = obj_move[om->parent].cprio * om->prio;
758 } else {
759 copymat4(om->cxfm, om->xfm);
760 om->cprio = om->prio;
761 }
762 /* XXX bxfm relies on call order */
763 if (framestep) {
764 if (invmat4(om->bxfm, om->cxfm))
765 multmat4(om->bxfm, om->bxfm, oxf.xfm);
766 else
767 setident4(om->bxfm);
768 }
769 /* all done */
770 return(xfp);
771 }
772
773
774 int
775 getmove(obj) /* find matching move object */
776 OBJECT obj;
777 {
778 static int lasti;
779 static OBJECT lasto = OVOID;
780 char *onm, *objnm;
781 int len, len2;
782 register int i;
783
784 if (obj == OVOID)
785 return(-1);
786 if (obj == lasto)
787 return(lasti);
788 /* look for matching object */
789 onm = objptr(obj)->oname;
790 for (i = vdef(MOVE); i--; ) {
791 objnm = obj_move[i].name;
792 len = strlen(objnm);
793 if (!strncmp(onm, objnm, len)) {
794 if ((obj_move[i].parent < 0) & (onm[len] == '.'))
795 break;
796 objnm = getobjname(&obj_move[i]) + len;
797 len2 = strlen(objnm);
798 if (!strncmp(onm+len, objnm, len2) && onm[len+len2] == '.')
799 break;
800 }
801 }
802 lasto = obj; /* cache what we found */
803 return(lasti = i);
804 }
805
806
807 double
808 obj_prio(obj) /* return priority for object */
809 OBJECT obj;
810 {
811 int moi;
812
813 if (obj == OVOID || (moi = getmove(obj)) < 0)
814 return(1.0);
815 return(obj_move[moi].cprio);
816 }
817
818
819 double
820 getTime() /* get current time (CPU or real) */
821 {
822 struct timeval time_now;
823 /* return CPU time if one process */
824 if (nprocs == 1)
825 return((double)clock()*(1.0/(double)CLOCKS_PER_SEC));
826 /* otherwise, return wall time */
827 gettimeofday(&time_now, NULL);
828 return((double)time_now.tv_sec + 1e-6*(double)time_now.tv_usec);
829 }
