feat(rad,ranimate): Improved handling of quoted strings for file names
fix(ranimate): Explicitly ignore MBLUR setting when ANIMATE variable set
Increased default diskspace to 1000 MBytes
Added check for overflowing arguments in archive/remove command
Using RT_PID instead of int.
Continued ANSIfication.
Removed inappropriate error triggered by unset EXPOSURE variable
Some versions of gcc don't like static f(); followed by exter f();
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Fixed bug in blur computation for recovered frames
Fixed bug in unremoved persist file for rpict
Undid last mistaken change -- rpict -S needs view for motion blur
Removed unnecessary view parameters to rpict with -S option
Bug fix in ranimate call to pinterp
Added missing -a option to pinterp calls
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed bug by eliminated exit code check on rad (sigh)
added last view to rpict command line for -pm option
change directories before running transfer or archive commands
fixed infinite loop in countviews()
fixed minor bug in getradfile() for matchless rad runs
added call to check variable assignments
fixed bug in passing of -fr option to pinterp
bug fix in status check on finished job
made default BASENAME respond to number of END frame
fixed problem in multiple recovery by putting important code in donecom()
fixed bug in -PP option of rpict
changed formatting on -pa option
fixed NULL pointer for AIX
bug paranoia in getexp()
changed "4" to sizeof(float) in space computation
added warning about updates to control file
changed call to execvp() to getpath() + execv()
added RSH variable to rename or replace remote shell execution
moved host name stuff to lib routine
added exception for VIEWFILE with just one view
more bug fixes
fixed pmblur view file naming problem
minor improvements
hopefully added -PP option to parallel machine runs
improved process recording
