--- ray/src/util/ranimate.c 1996/01/22 17:19:37 2.4 +++ ray/src/util/ranimate.c 1996/01/24 14:31:36 2.8 @@ -57,8 +57,8 @@ VARIABLE vv[] = { /* variable-value pairs */ {"ANIMATE", 2, 0, NULL, onevalue}, {"TRANSFER", 2, 0, NULL, onevalue}, {"ARCHIVE", 2, 0, NULL, onevalue}, - {"INTERP", 3, 0, NULL, intvalue}, - {"OVERSAMP", 2, 0, NULL, fltvalue}, + {"INTERPOLATE", 3, 0, NULL, intvalue}, + {"OVERSAMPLE", 2, 0, NULL, fltvalue}, {"MBLUR", 2, 0, NULL, onevalue}, {"RTRACE", 2, 0, NULL, boolvalue}, {"DISKSPACE", 3, 0, NULL, fltvalue}, @@ -89,6 +89,9 @@ char rresopt[32]; /* rendering resolution options */ char fresopt[32]; /* filter resolution options */ int pfiltalways; /* always use pfilt? */ +char arcargs[10240]; /* files to archive */ +char *arcfirst, *arcnext; /* pointers to first and next argument */ + struct pslot { int pid; /* process ID (0 if empty) */ int fout; /* output frame number */ @@ -302,10 +305,15 @@ setdefaults() /* set default values */ vdef(START)++; } if (!vdef(END)) { - sprintf(buf, "%d", countviews()); + sprintf(buf, "%d", countviews()+vint(START)-1); vval(END) = savqstr(buf); vdef(END)++; } + if (vint(END) < vint(START)) { + fprintf(stderr, "%s: ending frame less than starting frame\n", + progname); + quit(1); + } if (!vdef(BASENAME)) { sprintf(buf, "%s/frame%%03d", vval(DIRECTORY)); vval(BASENAME) = savqstr(buf); @@ -401,8 +409,8 @@ sethosts() /* set up process servers */ } -getradfile(rfname) /* run rad and get needed variables */ -char *rfname; +getradfile(rfargs) /* run rad and get needed variables */ +char *rfargs; { static short mvar[] = {OCTREE,PFILT,RESOLUTION,EXPOSURE,-1}; char combuf[256]; @@ -412,7 +420,7 @@ char *rfname; sprintf(rendopt, " @%s/render.opt", vval(DIRECTORY)); sprintf(combuf, "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH", - rfname, rendopt+2); + rfargs, rendopt+2); cp = combuf; while (*cp) cp++; /* match unset variables */ for (i = 0; mvar[i] >= 0; i++) @@ -424,8 +432,8 @@ char *rfname; sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY)); cp += 11; /* point to file name */ if (system(combuf)) { - fprintf(stderr, "%s: bad rad input file \"%s\"\n", - progname, rfname); + fprintf(stderr, "%s: error executing rad command:\n\t%s\n", + progname, combuf); quit(1); } loadvars(cp); /* load variables and remove file */ @@ -482,6 +490,11 @@ animate() /* run animation */ progname); quit(1); } + /* initialize archive argument list */ + i = 16; + if (vdef(ARCHIVE) && strlen(vval(ARCHIVE)) > i) + i = strlen(vval(ARCHIVE)); + arcnext = arcfirst = arcargs + i; /* initialize status file */ if (astat.rnext == 0) astat.rnext = astat.fnext = astat.tnext = vint(START); @@ -576,7 +589,7 @@ filterframes() /* catch up with filtering */ dofilt(i, vp, getexp(i), 0); /* filter frame */ } bwait(0); /* wait for filter processes */ - archive(astat.fnext, i-1); /* archive originals */ + archive(); /* archive originals */ astat.fnext = i; /* update status */ putastat(); } @@ -657,7 +670,9 @@ char *vfn; inspoint = combuf + strlen(combuf); sprintf(inspoint, " %s < %s", vval(OCTREE), vfn); /* run in parallel */ - if (pruncom(combuf, inspoint, (last-first+1)/(vint(INTERP)+1))) { + i = (last-first+1)/(vint(INTERP)+1); + if (i < 1) i = 1; + if (pruncom(combuf, inspoint, i)) { fprintf(stderr, "%s: error rendering frames %d through %d\n", progname, first, last); quit(1); @@ -735,53 +750,27 @@ int frame; } -archive(first, last) /* archive and remove renderings */ -int first, last; +archive() /* archive and remove renderings */ { #define RMCOML (sizeof(rmcom)-1) static char rmcom[] = "rm -f"; - int offset = RMCOML; - char combuf[10240]; - struct stat stb; - register char *cp; register int i; - if (noaction) - return; - if (vdef(ARCHIVE) && strlen(vval(ARCHIVE)) > offset) - offset = strlen(vval(ARCHIVE)); - cp = combuf + offset; - *cp++ = ' '; /* make argument list */ - for (i = first; i <= last; i++) { - sprintf(cp, vval(BASENAME), i); - strcat(cp, ".unf"); - if (stat(cp, &stb) == 0 && stb.st_size > 0) { /* non-zero? */ - while (*cp) cp++; - *cp++ = ' '; - sprintf(cp, vval(BASENAME), i); - strcat(cp, ".zbf"); - if (access(cp, F_OK) == 0) { /* exists? */ - while (*cp) cp++; - *cp++ = ' '; - } - } - } - *--cp = '\0'; - if (cp <= combuf + offset) /* no files? */ - return; + if (arcnext == arcfirst) + return; /* nothing to do */ if (vdef(ARCHIVE)) { /* run archive command */ i = strlen(vval(ARCHIVE)); - strncpy(combuf+offset-i, vval(ARCHIVE), i); - if (runcom(combuf+offset-i)) { - fprintf(stderr, - "%s: error running archive command on frames %d through %d\n", - progname, first, last); + strncpy(arcfirst-i, vval(ARCHIVE), i); + if (runcom(arcfirst-i)) { + fprintf(stderr, "%s: error running archive command\n", + progname); quit(1); } } /* run remove command */ - strncpy(combuf+offset-RMCOML, rmcom, RMCOML); - runcom(combuf+offset-RMCOML); + strncpy(arcfirst-RMCOML, rmcom, RMCOML); + runcom(arcfirst-RMCOML); + arcnext = arcfirst; /* reset argument list */ #undef RMCOML } @@ -794,13 +783,18 @@ char *ep; int rvr; { extern int frecover(); + static int iter = 0; char fnbefore[128], fnafter[128]; - char combuf[1024], fname[128]; - int usepinterp, usepfilt; + char combuf[1024], fname0[128], fname1[128]; + int usepinterp, usepfilt, nora_rgbe; int frseq[2]; /* check what is needed */ usepinterp = atoi(vval(MBLUR)); usepfilt = pfiltalways | ep==NULL; + if (ep != NULL && !strcmp(ep, "1")) + ep = "+0"; + nora_rgbe = strcmp(vval(OVERSAMP),"1") || ep==NULL || + *ep != '+' || *ep != '-' || !isint(ep); /* compute rendered views */ frseq[0] = frame - ((frame-1) % (vint(INTERP)+1)); frseq[1] = frseq[0] + vint(INTERP) + 1; @@ -809,11 +803,25 @@ int rvr; if (frseq[1] == frame) { /* pfilt only */ frseq[0] = frseq[1]; usepinterp = 0; /* update what's needed */ - usepfilt |= vflt(OVERSAMP)>1.01 || strcmp(ep,"1"); - } else if (frseq[0] == frame) { /* no interpolation */ - /* update what's needed */ - if (!usepinterp) - usepfilt |= vflt(OVERSAMP)>1.01 || strcmp(ep,"1"); + usepfilt |= nora_rgbe; + } else if (frseq[0] == frame) { /* no interpolation needed */ + if (!rvr && frame > 1+vint(INTERP)) { /* archive previous */ + *arcnext++ = ' '; + sprintf(arcnext, vval(BASENAME), frame-vint(INTERP)-1); + while (*arcnext) arcnext++; + strcpy(arcnext, ".unf"); + arcnext += 4; + if (usepinterp || vint(INTERP)) { /* and z-buf */ + *arcnext++ = ' '; + sprintf(arcnext, vval(BASENAME), + frame-vint(INTERP)-1); + while (*arcnext) arcnext++; + strcpy(arcnext, ".zbf"); + arcnext += 4; + } + } + if (!usepinterp) /* update what's needed */ + usepfilt |= nora_rgbe; } else /* interpolation needed */ usepinterp++; if (frseq[1] >= astat.rnext) /* next batch unavailable */ @@ -828,9 +836,10 @@ int rvr; return(1); if (atoi(vval(MBLUR))) { FILE *fp; /* motion blurring */ - sprintf(fname, "%s/vw0", vval(DIRECTORY)); - if ((fp = fopen(fname, "w")) == NULL) { - perror(fname); quit(1); + sprintf(fname0, "%s/vw0%c", vval(DIRECTORY), + 'a'+(iter%26)); + if ((fp = fopen(fname0, "w")) == NULL) { + perror(fname0); quit(1); } fputs(VIEWSTR, fp); fprintview(vp, fp); @@ -841,19 +850,20 @@ int rvr; progname, frame+1); quit(1); } - sprintf(fname, "%s/vw1", vval(DIRECTORY)); - if ((fp = fopen(fname, "w")) == NULL) { - perror(fname); quit(1); + sprintf(fname1, "%s/vw1%c", vval(DIRECTORY), + 'a'+(iter%26)); + if ((fp = fopen(fname1, "w")) == NULL) { + perror(fname1); quit(1); } fputs(VIEWSTR, fp); fprintview(vp, fp); putc('\n', fp); fclose(fp); sprintf(combuf, - "(pmblur %s %d %s/vw0 %s/vw1; rm -f %s/vw0 %s/vw1) | pinterp -B", + "(pmblur %s %d %s %s; rm -f %s %s) | pinterp -B", *sskip(vval(MBLUR)) ? sskip2(vval(MBLUR),1) : "1", - atoi(vval(MBLUR)), vval(DIRECTORY), - vval(DIRECTORY), vval(DIRECTORY), - vval(DIRECTORY), vval(DIRECTORY)); + atoi(vval(MBLUR)), + fname0, fname1, fname0, fname1); + iter++; } else /* no blurring */ strcpy(combuf, "pinterp"); strcat(combuf, viewopt(vp)); @@ -900,11 +910,11 @@ int rvr; } else { /* else just check it */ if (rvr == 2) return(1); - sprintf(combuf, "ra_rgbe -r %s.unf", fnbefore); + sprintf(combuf, "ra_rgbe -e %s -r %s.unf", ep, fnbefore); } /* output file name */ - sprintf(fname, vval(BASENAME), frame); - sprintf(combuf+strlen(combuf), " > %s.pic", fname); + sprintf(fname0, vval(BASENAME), frame); + sprintf(combuf+strlen(combuf), " > %s.pic", fname0); if (rvr) /* in recovery */ return(runcom(combuf)); bruncom(combuf, frame, frecover); /* else run in background */ @@ -936,6 +946,8 @@ int n; quit(1); } } else if (n < viewnum) { /* rewind file */ + if (viewnum == 1 && feof(viewfp)) + return(&curview); /* just one view */ if (fseek(viewfp, 0L, 0) == EOF) { perror(vval(VIEWFILE)); quit(1); @@ -945,7 +957,7 @@ int n; } while (n > viewnum) { /* scan to desired view */ if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL) - return(NULL); + return(viewnum==1 ? &curview : NULL); if (isview(linebuf) && sscanview(&curview, linebuf) > 0) viewnum++; } @@ -1097,18 +1109,19 @@ int (*rf)(); int pid; register struct pslot *psl; - if (!silent) - printf("\t%s &\n", com); /* echo command */ - if (noaction) + if (noaction) { + if (!silent) + printf("\t%s\n", com); /* echo command */ return(0); - fflush(stdout); + } /* else start it when we can */ while ((pid = startjob(NULL, savestr(com), donecom)) == -1) bwait(1); - if (!silent) { + if (!silent) { /* echo command */ PSERVER *ps; int psn = pid; ps = findjob(&psn); + printf("\t%s\n", com); printf("\tProcess started on %s\n", phostname(ps)); fflush(stdout); } @@ -1158,7 +1171,7 @@ int maxcopies; register PSERVER *ps; if (!silent) - printf("\t%s &\n", com); /* echo command */ + printf("\t%s\n", com); /* echo command */ if (noaction) return(0); fflush(stdout);
