--- ray/src/util/ranimate.c 1998/03/03 19:36:43 2.26 +++ ray/src/util/ranimate.c 1998/07/06 18:17:39 2.28 @@ -1,7 +1,7 @@ -/* Copyright (c) 1996 Regents of the University of California */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static char SCCSid[] = "$SunId$ SGI"; #endif /* @@ -21,57 +21,57 @@ static char SCCSid[] = "$SunId$ LBL"; #else #define REMSH "rsh" #endif - /* input variables */ -#define HOST 0 /* rendering host machine */ -#define RENDER 1 /* rendering options */ -#define PFILT 2 /* pfilt options */ -#define PINTERP 3 /* pinterp options */ -#define OCTREE 4 /* octree file name */ -#define DIRECTORY 5 /* working (sub)directory */ -#define BASENAME 6 /* output image base name */ -#define VIEWFILE 7 /* animation frame views */ -#define START 8 /* starting frame number */ -#define END 9 /* ending frame number */ -#define RIF 10 /* rad input file */ -#define NEXTANIM 11 /* next animation file */ -#define ANIMATE 12 /* animation command */ -#define TRANSFER 13 /* frame transfer command */ -#define ARCHIVE 14 /* archiving command */ -#define INTERP 15 /* # frames to interpolate */ -#define OVERSAMP 16 /* # times to oversample image */ -#define MBLUR 17 /* samples for motion blur */ -#define RTRACE 18 /* use rtrace with pinterp? */ -#define DISKSPACE 19 /* how much disk space to use */ -#define RESOLUTION 20 /* desired final resolution */ -#define EXPOSURE 21 /* how to compute exposure */ -#define RSH 22 /* remote shell script or program */ + /* input variables (alphabetical by name) */ +#define ANIMATE 0 /* animation command */ +#define ARCHIVE 1 /* archiving command */ +#define BASENAME 2 /* output image base name */ +#define DIRECTORY 3 /* working (sub)directory */ +#define DISKSPACE 4 /* how much disk space to use */ +#define END 5 /* ending frame number */ +#define EXPOSURE 6 /* how to compute exposure */ +#define HOST 7 /* rendering host machine */ +#define INTERP 8 /* # frames to interpolate */ +#define MBLUR 9 /* samples for motion blur */ +#define NEXTANIM 10 /* next animation file */ +#define OCTREE 11 /* octree file name */ +#define OVERSAMP 12 /* # times to oversample image */ +#define PFILT 13 /* pfilt options */ +#define PINTERP 14 /* pinterp options */ +#define RENDER 15 /* rendering options */ +#define RESOLUTION 16 /* desired final resolution */ +#define RIF 17 /* rad input file */ +#define RSH 18 /* remote shell script or program */ +#define RTRACE 19 /* use rtrace with pinterp? */ +#define START 20 /* starting frame number */ +#define TRANSFER 21 /* frame transfer command */ +#define VIEWFILE 22 /* animation frame views */ int NVARS = 23; /* total number of variables */ VARIABLE vv[] = { /* variable-value pairs */ - {"host", 4, 0, NULL, NULL}, - {"render", 3, 0, NULL, catvalues}, - {"pfilt", 2, 0, NULL, catvalues}, - {"pinterp", 2, 0, NULL, catvalues}, - {"OCTREE", 3, 0, NULL, onevalue}, - {"DIRECTORY", 3, 0, NULL, onevalue}, - {"BASENAME", 3, 0, NULL, onevalue}, - {"VIEWFILE", 2, 0, NULL, onevalue}, - {"START", 2, 0, NULL, intvalue}, - {"END", 2, 0, NULL, intvalue}, - {"RIF", 3, 0, NULL, onevalue}, - {"NEXTANIM", 3, 0, NULL, onevalue}, {"ANIMATE", 2, 0, NULL, onevalue}, - {"TRANSFER", 2, 0, NULL, onevalue}, {"ARCHIVE", 2, 0, NULL, onevalue}, + {"BASENAME", 3, 0, NULL, onevalue}, + {"DIRECTORY", 3, 0, NULL, onevalue}, + {"DISKSPACE", 3, 0, NULL, fltvalue}, + {"END", 2, 0, NULL, intvalue}, + {"EXPOSURE", 3, 0, NULL, onevalue}, + {"host", 4, 0, NULL, NULL}, {"INTERPOLATE", 3, 0, NULL, intvalue}, - {"OVERSAMPLE", 2, 0, NULL, fltvalue}, {"MBLUR", 2, 0, NULL, onevalue}, - {"RTRACE", 2, 0, NULL, boolvalue}, - {"DISKSPACE", 3, 0, NULL, fltvalue}, + {"NEXTANIM", 3, 0, NULL, onevalue}, + {"OCTREE", 3, 0, NULL, onevalue}, + {"OVERSAMPLE", 2, 0, NULL, fltvalue}, + {"pfilt", 2, 0, NULL, catvalues}, + {"pinterp", 2, 0, NULL, catvalues}, + {"render", 3, 0, NULL, catvalues}, {"RESOLUTION", 3, 0, NULL, onevalue}, - {"EXPOSURE", 3, 0, NULL, onevalue}, + {"RIF", 3, 0, NULL, onevalue}, {"RSH", 3, 0, NULL, onevalue}, + {"RTRACE", 2, 0, NULL, boolvalue}, + {"START", 2, 0, NULL, intvalue}, + {"TRANSFER", 2, 0, NULL, onevalue}, + {"VIEWFILE", 2, 0, NULL, onevalue}, }; #define SFNAME "STATUS" /* status file name */ @@ -474,11 +474,7 @@ char *rfargs; sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY)); cp += 11; /* point to file name */ } - if (system(combuf)) { - fprintf(stderr, "%s: error executing rad command:\n\t%s\n", - progname, combuf); - quit(1); - } + system(combuf); /* ignore exit code */ if (pippt == NULL) { /* load variables and remove file */ loadvars(cp); unlink(cp);
