--- ray/src/util/ranimate.c 1996/02/07 16:42:41 2.9 +++ ray/src/util/ranimate.c 1996/05/30 17:00:10 2.14 @@ -1,4 +1,4 @@ -/* Copyright (c) 1995 Regents of the University of California */ +/* Copyright (c) 1996 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,6 +15,12 @@ static char SCCSid[] = "$SunId$ LBL"; #include "view.h" #include "vars.h" #include "netproc.h" + /* default remote shell */ +#ifdef _AUX_SOURCE +#define REMSH "remsh" +#else +#define REMSH "rsh" +#endif /* input variables */ #define HOST 0 /* rendering host machine */ #define RENDER 1 /* rendering options */ @@ -38,8 +44,9 @@ static char SCCSid[] = "$SunId$ LBL"; #define DISKSPACE 19 /* how much disk space to use */ #define RESOLUTION 20 /* desired final resolution */ #define EXPOSURE 21 /* how to compute exposure */ +#define RSH 22 /* remote shell script or program */ -int NVARS = 22; /* total number of variables */ +int NVARS = 23; /* total number of variables */ VARIABLE vv[] = { /* variable-value pairs */ {"host", 4, 0, NULL, NULL}, @@ -64,6 +71,7 @@ VARIABLE vv[] = { /* variable-value pairs */ {"DISKSPACE", 3, 0, NULL, fltvalue}, {"RESOLUTION", 3, 0, NULL, onevalue}, {"EXPOSURE", 3, 0, NULL, onevalue}, + {"RSH", 3, 0, NULL, onevalue}, }; #define SFNAME "STATUS" /* status file name */ @@ -84,6 +92,7 @@ int nowarn = 0; /* turn warnings off? */ int silent = 0; /* silent mode? */ int noaction = 0; /* take no action? */ +char *remsh; /* remote shell program/script */ char rendopt[2048] = ""; /* rendering options */ char rresopt[32]; /* rendering resolution options */ char fresopt[32]; /* filter resolution options */ @@ -109,7 +118,9 @@ struct pslot *findpslot(); VIEW *getview(); char *getexp(); +extern time_t fdate(), time(); + main(argc, argv) int argc; char *argv[]; @@ -166,8 +177,11 @@ char *argv[]; argv[i] = vval(NEXTANIM); /* just change input file */ if (!silent) printargs(argc, argv, stdout); - execvp(progname, argv); /* pass to next */ - quit(1); /* shouldn't return */ + if ((argv[0] = getpath(progname,getenv("PATH"),X_OK)) == NULL) + fprintf(stderr, "%s: command not found\n", progname); + else + execv(progname, argv); + quit(1); } quit(0); userr: @@ -178,13 +192,13 @@ userr: getastat() /* check/set animation status */ { - char buf[256]; + char sfname[256]; FILE *fp; - sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME); - if ((fp = fopen(buf, "r")) == NULL) { + sprintf(sfname, "%s/%s", vval(DIRECTORY), SFNAME); + if ((fp = fopen(sfname, "r")) == NULL) { if (errno != ENOENT) { - perror(buf); + perror(sfname); return(-1); } astat.rnext = astat.fnext = astat.tnext = 0; @@ -222,6 +236,11 @@ getastat() /* check/set animation status */ progname, astat.cfname); return(-1); } + /* check control file mods. */ + if (!nowarn && fdate(cfname) > fdate(sfname)) + fprintf(stderr, + "%s: warning - control file modified since last run\n", + progname); setours: /* set our values */ strcpy(astat.host, myhostname()); astat.pid = getpid(); @@ -229,7 +248,7 @@ setours: /* set our values */ return(0); fmterr: fprintf(stderr, "%s: format error in status file \"%s\"\n", - progname, buf); + progname, sfname); fclose(fp); return(-1); } @@ -281,6 +300,7 @@ checkdir() /* make sure we have our directory */ setdefaults() /* set default values */ { + extern char *atos(); char buf[256]; if (vdef(ANIMATE)) { @@ -346,6 +366,17 @@ setdefaults() /* set default values */ vval(DISKSPACE) = "100"; vdef(DISKSPACE)++; } + if (!vdef(RSH)) { + vval(RSH) = REMSH; + vdef(RSH)++; + } + /* locate remote shell program */ + atos(buf, sizeof(buf), vval(RSH)); + if ((remsh = getpath(buf, getenv("PATH"), X_OK)) != NULL) + remsh = savqstr(remsh); + else + remsh = vval(RSH); /* will generate error if used */ + /* append rendering options */ if (vdef(RENDER)) sprintf(rendopt+strlen(rendopt), " %s", vval(RENDER)); @@ -481,7 +512,7 @@ animate() /* run animation */ /* figure # frames per batch */ d1 = mult*xres*mult*yres*4; /* space for orig. picture */ if ((i=vint(INTERP)) || atoi(vval(MBLUR))) - d1 += mult*xres*mult*yres*4; /* space for z-buffer */ + d1 += mult*xres*mult*yres*sizeof(float); /* Z-buffer */ d2 = xres*yres*4; /* space for final picture */ frames_batch = (i+1)*(vflt(DISKSPACE)*1048576.-d1)/(d1+i*d2); if (frames_batch < i+2) { @@ -810,7 +841,7 @@ int rvr; while (*arcnext) arcnext++; strcpy(arcnext, ".unf"); arcnext += 4; - if (usepinterp || vint(INTERP)) { /* and z-buf */ + if (usepinterp || vint(INTERP)) { /* and Z-buf */ *arcnext++ = ' '; sprintf(arcnext, vval(BASENAME), frame-vint(INTERP)-1); @@ -989,10 +1020,12 @@ int n; if (n == 0) { /* signal to close file */ if (expfp != NULL) { fclose(expfp); + free((char *)exppos); expfp = NULL; } return(NULL); - } + } else if (n > vint(END)) /* request past end (error?) */ + return(NULL); if (!vdef(EXPOSURE)) /* no setting (auto) */ return(NULL); if (isflt(vval(EXPOSURE))) /* always the same */ @@ -1030,13 +1063,15 @@ int n; } curfrm++; cp = fskip(expval); /* check format */ - if (cp == NULL || *cp != '\n') { + if (cp != NULL) + while (isspace(*cp)) + *cp++ = '\0'; + if (cp == NULL || *cp) { fprintf(stderr, "%s: exposure format error on line %d\n", vval(EXPOSURE), curfrm); quit(1); } - *cp = '\0'; } return(expval); /* return value */ }
