root/radiance/ray/src/util/ranimate.c
Sat Jun 10 15:49:55 2023 UTC (22 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.57: +7 -7 lines
Diff to previous 2.57 , to selected 2.13
feat(rad,ranimate): Improved handling of quoted strings for file names
Wed Jun 1 17:08:24 2022 UTC (2 years, 11 months ago) by greg
Diff to previous 2.56 , to selected 2.13
fix(ranimate): Explicitly ignore MBLUR setting when ANIMATE variable set
Sun Mar 6 01:13:18 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 2.55: +2 -2 lines
Diff to previous 2.55 , to selected 2.13
Sat Jun 8 02:49:19 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.54: +3 -3 lines
Diff to previous 2.54 , to selected 2.13
Increased default diskspace to 1000 MBytes
Mon Nov 10 19:08:20 2008 UTC (16 years, 5 months ago) by greg
CVS Tags: rad4R0, rad4R1
Diff to previous 2.53 , to selected 2.13
Thu Feb 21 01:22:06 2008 UTC (17 years, 2 months ago) by greg
Changes since 2.52: +1 -2 lines
Diff to previous 2.52 , to selected 2.13
Tue Apr 18 04:30:35 2006 UTC (19 years ago) by greg
Changes since 2.51: +8 -1 lines
Diff to previous 2.51 , to selected 2.13
Added check for overflowing arguments in archive/remove command
Tue Feb 28 03:44:54 2006 UTC (19 years, 2 months ago) by greg
Changes since 2.50: +7 -5 lines
Diff to previous 2.50 , to selected 2.13
Mon Sep 12 14:40:14 2005 UTC (19 years, 7 months ago) by schorsch
Changes since 2.49: +10 -9 lines
Diff to previous 2.49 , to selected 2.13
Using RT_PID instead of int.
Mon Feb 7 17:08:17 2005 UTC (20 years, 2 months ago) by greg
Diff to previous 2.48 , to selected 2.13
Tue Jan 18 03:59:41 2005 UTC (20 years, 3 months ago) by greg
Changes since 2.47: +69 -57 lines
Diff to previous 2.47 , to selected 2.13
Tue Jun 8 19:48:31 2004 UTC (20 years, 10 months ago) by greg
Changes since 2.46: +2 -4 lines
Diff to previous 2.46 , to selected 2.13
Fri Mar 26 21:36:20 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.45: +15 -11 lines
Diff to previous 2.45 , to selected 2.13
Continued ANSIfication.
Sun Feb 15 06:21:01 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.44: +1 -7 lines
Diff to previous 2.44 , to selected 2.13
Removed inappropriate error triggered by unset EXPOSURE variable
Tue Dec 9 22:46:41 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.43: +2 -4 lines
Diff to previous 2.43 , to selected 2.13
Some versions of gcc don't like static f(); followed by exter f();
Mon Oct 27 10:32:06 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 2.42: +123 -81 lines
Diff to previous 2.42 , to selected 2.13
Tue Oct 21 19:19:29 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 2.41: +1 -5 lines
Diff to previous 2.41 , to selected 2.13
Sun Jul 27 22:12:03 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.40 , to selected 2.13
Mon Jul 21 22:30:19 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.39: +5 -4 lines
Diff to previous 2.39 , to selected 2.13
Mon Jun 30 14:59:13 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.38: +5 -3 lines
Diff to previous 2.38 , to selected 2.13
Fri Jun 6 20:04:06 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.37: +20 -19 lines
Diff to previous 2.37 , to selected 2.13
Fixed bug in blur computation for recovered frames
Thu Jun 5 19:29:35 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.36 , to selected 2.13
Sun Jun 1 15:21:57 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.35: +1 -0 lines
Diff to previous 2.35 , to selected 2.13
Fixed bug in unremoved persist file for rpict
Thu May 29 14:53:36 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.34: +2 -1 lines
Diff to previous 2.34 , to selected 2.13
Undid last mistaken change -- rpict -S needs view for motion blur
Tue May 27 15:30:04 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.33: +1 -2 lines
Diff to previous 2.33 , to selected 2.13
Removed unnecessary view parameters to rpict with -S option
Sun May 25 20:51:10 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.32: +1 -1 lines
Diff to previous 2.32 , to selected 2.13
Bug fix in ranimate call to pinterp
Wed Apr 23 00:52:34 2003 UTC (22 years ago) by greg
Diff to previous 2.31 , to selected 2.13
Tue Feb 25 02:47:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.30: +1 -56 lines
Diff to previous 2.30 , to selected 2.13
Mon Feb 24 16:44:40 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.29 , to selected 2.13
Added missing -a option to pinterp calls
Sat Feb 22 02:07:30 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.28: +135 -22 lines
Diff to previous 2.28 , to selected 2.13
Mon Jul 6 18:17:39 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 2.27: +3 -7 lines
Diff to previous 2.27 , to selected 2.13
fixed bug by eliminated exit code check on rad (sigh)
Wed Jun 3 16:37:51 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 2.26: +41 -41 lines
Diff to previous 2.26 , to selected 2.13
Tue Mar 3 19:36:43 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.25: +2 -1 lines
Diff to previous 2.25 , to selected 2.13
added last view to rpict command line for -pm option
Tue Mar 3 11:44:46 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.24: +84 -35 lines
Diff to previous 2.24 , to selected 2.13
change directories before running transfer or archive commands
Thu Feb 26 10:27:45 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.23: +13 -4 lines
Diff to previous 2.23 , to selected 2.13
fixed infinite loop in countviews()
Fri Oct 31 15:02:43 1997 UTC (27 years, 6 months ago) by gregl
Changes since 2.22: +16 -5 lines
Diff to previous 2.22 , to selected 2.13
fixed minor bug in getradfile() for matchless rad runs
Thu Mar 20 14:53:17 1997 UTC (28 years, 1 month ago) by greg
Diff to previous 2.21 , to selected 2.13
added call to check variable assignments
Tue Jul 30 21:27:13 1996 UTC (28 years, 9 months ago) by greg
Diff to previous 2.20 , to selected 2.13
fixed bug in passing of -fr option to pinterp
Wed Jul 17 17:45:11 1996 UTC (28 years, 9 months ago) by greg
Diff to previous 2.19 , to selected 2.13
bug fix in status check on finished job
Wed Jul 10 15:14:59 1996 UTC (28 years, 9 months ago) by greg
Diff to previous 2.18 , to selected 2.13
made default BASENAME respond to number of END frame
Mon Jul 8 14:53:17 1996 UTC (28 years, 10 months ago) by greg
Changes since 2.17: +42 -36 lines
Diff to previous 2.17 , to selected 2.13
fixed problem in multiple recovery by putting important code in donecom()
Wed Jul 3 15:26:44 1996 UTC (28 years, 10 months ago) by greg
Changes since 2.16: +24 -11 lines
Diff to previous 2.16 , to selected 2.13
fixed bug in -PP option of rpict
Thu Jun 27 06:49:50 1996 UTC (28 years, 10 months ago) by greg
Diff to previous 2.15 , to selected 2.13
changed formatting on -pa option
Mon Jun 24 09:19:36 1996 UTC (28 years, 10 months ago) by greg
fixed NULL pointer for AIX
Thu May 30 17:00:10 1996 UTC (28 years, 11 months ago) by greg
Diff to previous 2.13
bug paranoia in getexp()
Revision 2.13 - (view) (download) (annotate) - [selected]
Tue May 21 14:27:19 1996 UTC (28 years, 11 months ago) by greg
Diff to previous 2.12
changed "4" to sizeof(float) in space computation
Mon May 20 11:50:19 1996 UTC (28 years, 11 months ago) by greg
Changes since 2.11: +12 -5 lines
added warning about updates to control file
Tue Apr 16 10:38:19 1996 UTC (29 years ago) by greg
Changes since 2.10: +6 -3 lines
changed call to execvp() to getpath() + execv()
Tue Feb 20 16:13:53 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.9: +22 -1 lines
added RSH variable to rename or replace remote shell execution
Wed Feb 7 16:42:41 1996 UTC (29 years, 3 months ago) by greg
moved host name stuff to lib routine
Wed Jan 24 14:31:36 1996 UTC (29 years, 3 months ago) by greg
added exception for VIEWFILE with just one view
Wed Jan 24 12:22:15 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.6: +52 -50 lines
more bug fixes
Tue Jan 23 17:01:33 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.5: +17 -16 lines
fixed pmblur view file naming problem
Tue Jan 23 16:14:28 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.4: +16 -8 lines
minor improvements
Mon Jan 22 17:19:37 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.3: +31 -13 lines
hopefully added -PP option to parallel machine runs
Fri Jan 19 17:24:19 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.2: +33 -15 lines
improved process recording
Thu Jan 18 11:25:11 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.1: +329 -100 lines
Fri Jan 12 12:16:17 1996 UTC (29 years, 3 months ago) by greg
Diff to selected 2.13
