root/Development/ray/src/util/ranimate.c
Revision: 2.9
Committed: Wed Feb 7 16:42:41 1996 UTC (29 years, 10 months ago) by greg
moved host name stuff to lib routine
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Radiance animation control program
9 */
10
11 #include "standard.h"
12 #include <ctype.h>
13 #include <sys/types.h>
14 #include <sys/stat.h>
15 #include "view.h"
16 #include "vars.h"
17 #include "netproc.h"
18 /* input variables */
19 #define HOST 0 /* rendering host machine */
20 #define RENDER 1 /* rendering options */
21 #define PFILT 2 /* pfilt options */
22 #define PINTERP 3 /* pinterp options */
23 #define OCTREE 4 /* octree file name */
24 #define DIRECTORY 5 /* working (sub)directory */
25 #define BASENAME 6 /* output image base name */
26 #define VIEWFILE 7 /* animation frame views */
27 #define START 8 /* starting frame number */
28 #define END 9 /* ending frame number */
29 #define RIF 10 /* rad input file */
30 #define NEXTANIM 11 /* next animation file */
31 #define ANIMATE 12 /* animation command */
32 #define TRANSFER 13 /* frame transfer command */
33 #define ARCHIVE 14 /* archiving command */
34 #define INTERP 15 /* # frames to interpolate */
35 #define OVERSAMP 16 /* # times to oversample image */
36 #define MBLUR 17 /* samples for motion blur */
37 #define RTRACE 18 /* use rtrace with pinterp? */
38 #define DISKSPACE 19 /* how much disk space to use */
39 #define RESOLUTION 20 /* desired final resolution */
40 #define EXPOSURE 21 /* how to compute exposure */
41
42 int NVARS = 22; /* total number of variables */
43
44 VARIABLE vv[] = { /* variable-value pairs */
45 {"host", 4, 0, NULL, NULL},
46 {"render", 3, 0, NULL, catvalues},
47 {"pfilt", 2, 0, NULL, catvalues},
48 {"pinterp", 2, 0, NULL, catvalues},
49 {"OCTREE", 3, 0, NULL, onevalue},
50 {"DIRECTORY", 3, 0, NULL, onevalue},
51 {"BASENAME", 3, 0, NULL, onevalue},
52 {"VIEWFILE", 2, 0, NULL, onevalue},
53 {"START", 2, 0, NULL, intvalue},
54 {"END", 2, 0, NULL, intvalue},
55 {"RIF", 3, 0, NULL, onevalue},
56 {"NEXTANIM", 3, 0, NULL, onevalue},
57 {"ANIMATE", 2, 0, NULL, onevalue},
58 {"TRANSFER", 2, 0, NULL, onevalue},
59 {"ARCHIVE", 2, 0, NULL, onevalue},
60 {"INTERPOLATE", 3, 0, NULL, intvalue},
61 {"OVERSAMPLE", 2, 0, NULL, fltvalue},
62 {"MBLUR", 2, 0, NULL, onevalue},
63 {"RTRACE", 2, 0, NULL, boolvalue},
64 {"DISKSPACE", 3, 0, NULL, fltvalue},
65 {"RESOLUTION", 3, 0, NULL, onevalue},
66 {"EXPOSURE", 3, 0, NULL, onevalue},
67 };
68
69 #define SFNAME "STATUS" /* status file name */
70
71 struct {
72 char host[64]; /* control host name */
73 int pid; /* control process id */
74 char cfname[128]; /* control file name */
75 int rnext; /* next frame to render */
76 int fnext; /* next frame to filter */
77 int tnext; /* next frame to transfer */
78 } astat; /* animation status */
79
80 char *progname; /* our program name */
81 char *cfname; /* our control file name */
82
83 int nowarn = 0; /* turn warnings off? */
84 int silent = 0; /* silent mode? */
85 int noaction = 0; /* take no action? */
86
87 char rendopt[2048] = ""; /* rendering options */
88 char rresopt[32]; /* rendering resolution options */
89 char fresopt[32]; /* filter resolution options */
90 int pfiltalways; /* always use pfilt? */
91
92 char arcargs[10240]; /* files to archive */
93 char *arcfirst, *arcnext; /* pointers to first and next argument */
94
95 struct pslot {
96 int pid; /* process ID (0 if empty) */
97 int fout; /* output frame number */
98 int (*rcvf)(); /* recover function */
99 } *pslot; /* process slots */
100 int npslots; /* number of process slots */
101
102 int lastpid; /* ID of last completed background process */
103 PSERVER *lastpserver; /* last process server used */
104
105 #define phostname(ps) ((ps)->hostname[0] ? (ps)->hostname : astat.host)
106
107 struct pslot *findpslot();
108
109 VIEW *getview();
110 char *getexp();
111
112
113 main(argc, argv)
114 int argc;
115 char *argv[];
116 {
117 int explicate = 0;
118 int i;
119
120 progname = argv[0]; /* get arguments */
121 for (i = 1; i < argc && argv[i][0] == '-'; i++)
122 switch (argv[i][1]) {
123 case 'e': /* print variables */
124 explicate++;
125 break;
126 case 'w': /* turn off warnings */
127 nowarn++;
128 break;
129 case 's': /* silent mode */
130 silent++;
131 break;
132 case 'n': /* take no action */
133 noaction++;
134 break;
135 default:
136 goto userr;
137 }
138 if (i != argc-1)
139 goto userr;
140 cfname = argv[i];
141 /* load variables */
142 loadvars(cfname);
143 /* did we get DIRECTORY? */
144 checkdir();
145 /* check status */
146 if (getastat() < 0) {
147 fprintf(stderr, "%s: exiting\n", progname);
148 quit(1);
149 }
150 /* pfilt always if options given */
151 pfiltalways = vdef(PFILT);
152 /* load RIF if any */
153 if (vdef(RIF))
154 getradfile(vval(RIF));
155 /* set defaults */
156 setdefaults();
157 /* print variables */
158 if (explicate)
159 printvars(stdout);
160 /* set up process servers */
161 sethosts();
162 /* run animation */
163 animate();
164 /* all done */
165 if (vdef(NEXTANIM)) {
166 argv[i] = vval(NEXTANIM); /* just change input file */
167 if (!silent)
168 printargs(argc, argv, stdout);
169 execvp(progname, argv); /* pass to next */
170 quit(1); /* shouldn't return */
171 }
172 quit(0);
173 userr:
174 fprintf(stderr, "Usage: %s [-s][-n][-w][-e] anim_file\n", progname);
175 quit(1);
176 }
177
178
179 getastat() /* check/set animation status */
180 {
181 char buf[256];
182 FILE *fp;
183
184 sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME);
185 if ((fp = fopen(buf, "r")) == NULL) {
186 if (errno != ENOENT) {
187 perror(buf);
188 return(-1);
189 }
190 astat.rnext = astat.fnext = astat.tnext = 0;
191 goto setours;
192 }
193 if (fscanf(fp, "Control host: %s\n", astat.host) != 1)
194 goto fmterr;
195 if (fscanf(fp, "Control PID: %d\n", &astat.pid) != 1)
196 goto fmterr;
197 if (fscanf(fp, "Control file: %s\n", astat.cfname) != 1)
198 goto fmterr;
199 if (fscanf(fp, "Next render: %d\n", &astat.rnext) != 1)
200 goto fmterr;
201 if (fscanf(fp, "Next filter: %d\n", &astat.fnext) != 1)
202 goto fmterr;
203 if (fscanf(fp, "Next transfer: %d\n", &astat.tnext) != 1)
204 goto fmterr;
205 fclose(fp);
206 if (astat.pid != 0) { /* thinks it's still running */
207 if (strcmp(myhostname(), astat.host)) {
208 fprintf(stderr,
209 "%s: process %d may still be running on host %s\n",
210 progname, astat.pid, astat.host);
211 return(-1);
212 }
213 if (kill(astat.pid, 0) != -1 || errno != ESRCH) {
214 fprintf(stderr, "%s: process %d is still running\n",
215 progname, astat.pid);
216 return(-1);
217 }
218 /* assume it is dead */
219 }
220 if (strcmp(cfname, astat.cfname) && astat.tnext != 0) { /* other's */
221 fprintf(stderr, "%s: unfinished job \"%s\"\n",
222 progname, astat.cfname);
223 return(-1);
224 }
225 setours: /* set our values */
226 strcpy(astat.host, myhostname());
227 astat.pid = getpid();
228 strcpy(astat.cfname, cfname);
229 return(0);
230 fmterr:
231 fprintf(stderr, "%s: format error in status file \"%s\"\n",
232 progname, buf);
233 fclose(fp);
234 return(-1);
235 }
236
237
238 putastat() /* put out current status */
239 {
240 char buf[256];
241 FILE *fp;
242
243 if (noaction)
244 return;
245 sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME);
246 if ((fp = fopen(buf, "w")) == NULL) {
247 perror(buf);
248 quit(1);
249 }
250 fprintf(fp, "Control host: %s\n", astat.host);
251 fprintf(fp, "Control PID: %d\n", astat.pid);
252 fprintf(fp, "Control file: %s\n", astat.cfname);
253 fprintf(fp, "Next render: %d\n", astat.rnext);
254 fprintf(fp, "Next filter: %d\n", astat.fnext);
255 fprintf(fp, "Next transfer: %d\n", astat.tnext);
256 fclose(fp);
257 }
258
259
260 checkdir() /* make sure we have our directory */
261 {
262 struct stat stb;
263
264 if (!vdef(DIRECTORY)) {
265 fprintf(stderr, "%s: %s undefined\n",
266 progname, vnam(DIRECTORY));
267 quit(1);
268 }
269 if (stat(vval(DIRECTORY), &stb) == -1) {
270 if (errno == ENOENT && mkdir(vval(DIRECTORY), 0777) == 0)
271 return;
272 perror(vval(DIRECTORY));
273 quit(1);
274 }
275 if (!(stb.st_mode & S_IFDIR)) {
276 fprintf(stderr, "%s: not a directory\n", vval(DIRECTORY));
277 quit(1);
278 }
279 }
280
281
282 setdefaults() /* set default values */
283 {
284 char buf[256];
285
286 if (vdef(ANIMATE)) {
287 vval(OCTREE) = NULL;
288 vdef(OCTREE) = 0;
289 } else if (!vdef(OCTREE)) {
290 fprintf(stderr, "%s: either %s or %s must be defined\n",
291 progname, vnam(OCTREE), vnam(ANIMATE));
292 quit(1);
293 }
294 if (!vdef(VIEWFILE)) {
295 fprintf(stderr, "%s: %s undefined\n", progname, vnam(VIEWFILE));
296 quit(1);
297 }
298 if (!vdef(HOST)) {
299 vval(HOST) = LHOSTNAME;
300 vdef(HOST)++;
301 }
302 if (!vdef(START)) {
303 vval(START) = "1";
304 vdef(START)++;
305 }
306 if (!vdef(END)) {
307 sprintf(buf, "%d", countviews()+vint(START)-1);
308 vval(END) = savqstr(buf);
309 vdef(END)++;
310 }
311 if (vint(END) < vint(START)) {
312 fprintf(stderr, "%s: ending frame less than starting frame\n",
313 progname);
314 quit(1);
315 }
316 if (!vdef(BASENAME)) {
317 sprintf(buf, "%s/frame%%03d", vval(DIRECTORY));
318 vval(BASENAME) = savqstr(buf);
319 vdef(BASENAME)++;
320 }
321 if (!vdef(RESOLUTION)) {
322 vval(RESOLUTION) = "640";
323 vdef(RESOLUTION)++;
324 }
325 if (!vdef(OVERSAMP)) {
326 vval(OVERSAMP) = "2";
327 vdef(OVERSAMP)++;
328 }
329 if (!vdef(INTERP)) {
330 vval(INTERP) = "0";
331 vdef(INTERP)++;
332 }
333 if (!vdef(MBLUR)) {
334 vval(MBLUR) = "0";
335 vdef(MBLUR)++;
336 }
337 if (!vdef(RTRACE)) {
338 vval(RTRACE) = "F";
339 vdef(RTRACE)++;
340 }
341 if (!vdef(DISKSPACE)) {
342 if (!nowarn)
343 fprintf(stderr,
344 "%s: warning - no %s setting, assuming 100 Mbytes available\n",
345 progname, vnam(DISKSPACE));
346 vval(DISKSPACE) = "100";
347 vdef(DISKSPACE)++;
348 }
349 /* append rendering options */
350 if (vdef(RENDER))
351 sprintf(rendopt+strlen(rendopt), " %s", vval(RENDER));
352 }
353
354
355 sethosts() /* set up process servers */
356 {
357 extern char *iskip();
358 char buf[256], *dir, *uname;
359 int np;
360 register char *cp;
361 int i;
362
363 npslots = 0;
364 if (noaction)
365 return;
366 for (i = 0; i < vdef(HOST); i++) { /* add each host */
367 dir = uname = NULL;
368 np = 1;
369 strcpy(cp=buf, nvalue(HOST, i)); /* copy to buffer */
370 cp = sskip(cp); /* skip host name */
371 while (isspace(*cp))
372 *cp++ = '\0';
373 if (*cp) { /* has # processes? */
374 np = atoi(cp);
375 if ((cp = iskip(cp)) == NULL || (*cp && !isspace(*cp)))
376 badvalue(HOST);
377 while (isspace(*cp))
378 cp++;
379 if (*cp) { /* has directory? */
380 dir = cp;
381 cp = sskip(cp); /* skip dir. */
382 while (isspace(*cp))
383 *cp++ = '\0';
384 if (*cp) { /* has user? */
385 uname = cp;
386 if (*sskip(cp))
387 badvalue(HOST);
388 }
389 }
390 }
391 if (addpserver(buf, dir, uname, np) == NULL) {
392 if (!nowarn)
393 fprintf(stderr,
394 "%s: cannot execute on host \"%s\"\n",
395 progname, buf);
396 } else
397 npslots += np;
398 }
399 if (npslots == 0) {
400 fprintf(stderr, "%s: no working process servers\n", progname);
401 quit(1);
402 }
403 pslot = (struct pslot *)calloc(npslots, sizeof(struct pslot));
404 if (pslot == NULL) {
405 perror("malloc");
406 quit(1);
407 }
408 }
409
410
411 getradfile(rfargs) /* run rad and get needed variables */
412 char *rfargs;
413 {
414 static short mvar[] = {OCTREE,PFILT,RESOLUTION,EXPOSURE,-1};
415 char combuf[256];
416 register int i;
417 register char *cp;
418 /* create rad command */
419 sprintf(rendopt, " @%s/render.opt", vval(DIRECTORY));
420 sprintf(combuf,
421 "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
422 rfargs, rendopt+2);
423 cp = combuf;
424 while (*cp) cp++; /* match unset variables */
425 for (i = 0; mvar[i] >= 0; i++)
426 if (!vdef(mvar[i])) {
427 *cp++ = '|';
428 strcpy(cp, vnam(mvar[i]));
429 while (*cp) cp++;
430 }
431 sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY));
432 cp += 11; /* point to file name */
433 if (system(combuf)) {
434 fprintf(stderr, "%s: error executing rad command:\n\t%s\n",
435 progname, combuf);
436 quit(1);
437 }
438 loadvars(cp); /* load variables and remove file */
439 unlink(cp);
440 }
441
442
443 animate() /* run animation */
444 {
445 int xres, yres;
446 float pa, mult;
447 int frames_batch;
448 register int i;
449 double d1, d2;
450 /* compute rpict resolution */
451 i = sscanf(vval(RESOLUTION), "%d %d %f", &xres, &yres, &pa);
452 mult = vflt(OVERSAMP);
453 if (i == 3) {
454 sprintf(rresopt, "-x %d -y %d -pa %f", (int)(mult*xres),
455 (int)(mult*yres), pa);
456 sprintf(fresopt, "-x %d -y %d -pa %f", xres, yres, pa);
457 } else if (i) {
458 if (i == 1) yres = xres;
459 sprintf(rresopt, "-x %d -y %d", (int)(mult*xres),
460 (int)(mult*yres));
461 sprintf(fresopt, "-x %d -y %d -pa 1", xres, yres);
462 } else
463 badvalue(RESOLUTION);
464 /* consistency checks */
465 if (vdef(ANIMATE)) {
466 if (vint(INTERP)) {
467 if (!nowarn)
468 fprintf(stderr,
469 "%s: resetting %s=0 for animation\n",
470 progname, vnam(INTERP));
471 vval(INTERP) = "0";
472 }
473 if (atoi(vval(MBLUR))) { /* can't handle this yet */
474 if (!nowarn)
475 fprintf(stderr,
476 "%s: resetting %s=0 for animation\n",
477 progname, vnam(MBLUR));
478 vval(MBLUR) = "0";
479 }
480 }
481 /* figure # frames per batch */
482 d1 = mult*xres*mult*yres*4; /* space for orig. picture */
483 if ((i=vint(INTERP)) || atoi(vval(MBLUR)))
484 d1 += mult*xres*mult*yres*4; /* space for z-buffer */
485 d2 = xres*yres*4; /* space for final picture */
486 frames_batch = (i+1)*(vflt(DISKSPACE)*1048576.-d1)/(d1+i*d2);
487 if (frames_batch < i+2) {
488 fprintf(stderr, "%s: insufficient disk space allocated\n",
489 progname);
490 quit(1);
491 }
492 /* initialize archive argument list */
493 i = 16;
494 if (vdef(ARCHIVE) && strlen(vval(ARCHIVE)) > i)
495 i = strlen(vval(ARCHIVE));
496 arcnext = arcfirst = arcargs + i;
497 /* initialize status file */
498 if (astat.rnext == 0)
499 astat.rnext = astat.fnext = astat.tnext = vint(START);
500 putastat();
501 /* render in batches */
502 while (astat.tnext <= vint(END)) {
503 renderframes(frames_batch);
504 filterframes();
505 transferframes();
506 }
507 /* mark status as finished */
508 astat.pid = 0;
509 putastat();
510 /* close open files */
511 getview(0);
512 getexp(0);
513 }
514
515
516 renderframes(nframes) /* render next nframes frames */
517 int nframes;
518 {
519 static char vendbuf[16];
520 VIEW *vp;
521 FILE *fp = NULL;
522 char vfname[128];
523 int lastframe;
524 register int i;
525
526 if (astat.tnext < astat.rnext) /* other work to do first */
527 return;
528 /* create batch view file */
529 if (!vdef(ANIMATE)) {
530 sprintf(vfname, "%s/anim.vf", vval(DIRECTORY));
531 if ((fp = fopen(vfname, "w")) == NULL) {
532 perror(vfname);
533 quit(1);
534 }
535 }
536 /* bound batch properly */
537 lastframe = astat.rnext + nframes - 1;
538 if ((lastframe-1) % (vint(INTERP)+1)) /* need even interval */
539 lastframe += vint(INTERP)+1 - ((lastframe-1)%(vint(INTERP)+1));
540 if (lastframe > vint(END)) /* check for end */
541 lastframe = vint(END);
542 /* render each view */
543 for (i = astat.rnext; i <= lastframe; i++) {
544 if ((vp = getview(i)) == NULL) {
545 if (!nowarn)
546 fprintf(stderr,
547 "%s: ran out of views before last frame\n",
548 progname);
549 sprintf(vval(END)=vendbuf, "%d", i-1);
550 lastframe = i - 1;
551 break;
552 }
553 if (vdef(ANIMATE)) /* animate frame */
554 animrend(i, vp);
555 else { /* else record it */
556 fputs(VIEWSTR, fp);
557 fprintview(vp, fp);
558 putc('\n', fp);
559 }
560 }
561 if (vdef(ANIMATE)) /* wait for renderings to finish */
562 bwait(0);
563 else { /* else if walk-through */
564 fclose(fp); /* close view file */
565 walkwait(astat.rnext, lastframe, vfname); /* walk it */
566 unlink(vfname); /* remove view file */
567 }
568 astat.rnext = i; /* update status */
569 putastat();
570 }
571
572
573 filterframes() /* catch up with filtering */
574 {
575 VIEW *vp;
576 register int i;
577
578 if (astat.tnext < astat.fnext) /* other work to do first */
579 return;
580 /* filter each view */
581 for (i = astat.fnext; i < astat.rnext; i++) {
582 if ((vp = getview(i)) == NULL) { /* get view i */
583 fprintf(stderr,
584 "%s: unexpected error reading view for frame %d\n",
585 progname, i);
586 quit(1);
587 }
588 dofilt(i, vp, getexp(i), 0); /* filter frame */
589 }
590 bwait(0); /* wait for filter processes */
591 archive(); /* archive originals */
592 astat.fnext = i; /* update status */
593 putastat();
594 }
595
596
597 transferframes() /* catch up with picture transfers */
598 {
599 char combuf[10240];
600 register char *cp;
601 register int i;
602
603 if (astat.tnext >= astat.fnext) /* nothing to do, yet */
604 return;
605 if (!vdef(TRANSFER)) { /* no transfer function -- leave 'em */
606 astat.tnext = astat.fnext;
607 putastat(); /* update status */
608 return;
609 }
610 strcpy(combuf, vval(TRANSFER)); /* start transfer command */
611 cp = combuf + strlen(combuf);
612 /* make argument list */
613 for (i = astat.tnext; i < astat.fnext; i++) {
614 *cp++ = ' ';
615 sprintf(cp, vval(BASENAME), i);
616 while (*cp) cp++;
617 strcpy(cp, ".pic");
618 cp += 4;
619 }
620 if (runcom(combuf)) { /* transfer frames */
621 fprintf(stderr, "%s: error running transfer command\n",
622 progname);
623 quit(1);
624 }
625 astat.tnext = i; /* update status */
626 putastat();
627 }
628
629
630 animrend(frame, vp) /* start animation frame */
631 int frame;
632 VIEW *vp;
633 {
634 extern int recover();
635 char combuf[2048];
636 char fname[128];
637
638 sprintf(fname, vval(BASENAME), frame);
639 strcat(fname, ".unf");
640 if (access(fname, F_OK) == 0)
641 return;
642 sprintf(combuf, "%s %d | rpict%s%s -w0 %s > %s", vval(ANIMATE), frame,
643 rendopt, viewopt(vp), rresopt, fname);
644 bruncom(combuf, frame, recover); /* run in background */
645 }
646
647
648 walkwait(first, last, vfn) /* walk-through frames */
649 int first, last;
650 char *vfn;
651 {
652 char combuf[2048];
653 char *inspoint;
654 register int i;
655
656 if (!noaction && vint(INTERP)) /* create dummy frames */
657 for (i = first; i <= last; i++)
658 if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
659 sprintf(combuf, vval(BASENAME), i);
660 strcat(combuf, ".unf");
661 close(open(combuf, O_RDONLY|O_CREAT, 0666));
662 }
663 /* create command */
664 sprintf(combuf, "rpict%s -w0", rendopt);
665 if (vint(INTERP) || atoi(vval(MBLUR)))
666 sprintf(combuf+strlen(combuf), " -z %s.zbf", vval(BASENAME));
667 sprintf(combuf+strlen(combuf), " -o %s.unf %s -S %d",
668 vval(BASENAME), rresopt, first);
669 inspoint = combuf + strlen(combuf);
670 sprintf(inspoint, " %s < %s", vval(OCTREE), vfn);
671 /* run in parallel */
672 i = (last-first+1)/(vint(INTERP)+1);
673 if (i < 1) i = 1;
674 if (pruncom(combuf, inspoint, i)) {
675 fprintf(stderr, "%s: error rendering frames %d through %d\n",
676 progname, first, last);
677 quit(1);
678 }
679 if (!noaction && vint(INTERP)) /* remove dummy frames */
680 for (i = first; i <= last; i++)
681 if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
682 sprintf(combuf, vval(BASENAME), i);
683 strcat(combuf, ".unf");
684 unlink(combuf);
685 }
686 }
687
688
689 int
690 recover(frame) /* recover the specified frame */
691 int frame;
692 {
693 static int *rfrm; /* list of recovered frames */
694 static int nrfrms = 0;
695 char combuf[2048];
696 char fname[128];
697 register char *cp;
698 register int i;
699 /* check to see if recovered already */
700 for (i = nrfrms; i--; )
701 if (rfrm[i] == frame)
702 return(0);
703 /* build command */
704 sprintf(fname, vval(BASENAME), frame);
705 if (vdef(ANIMATE))
706 sprintf(combuf, "%s %d | rpict%s -w0",
707 vval(ANIMATE), frame, rendopt);
708 else
709 sprintf(combuf, "rpict%s -w0", rendopt);
710 cp = combuf + strlen(combuf);
711 if (vint(INTERP) || atoi(vval(MBLUR))) {
712 sprintf(cp, " -z %s.zbf", fname);
713 while (*cp) cp++;
714 }
715 sprintf(cp, " -ro %s.unf", fname);
716 while (*cp) cp++;
717 if (!vdef(ANIMATE)) {
718 *cp++ = ' ';
719 strcpy(cp, vval(OCTREE));
720 }
721 if (runcom(combuf)) /* run command */
722 return(1);
723 /* add frame to recovered list */
724 if (nrfrms)
725 rfrm = (int *)realloc((char *)rfrm, (nrfrms+1)*sizeof(int));
726 else
727 rfrm = (int *)malloc(sizeof(int));
728 if (rfrm == NULL) {
729 perror("malloc");
730 quit(1);
731 }
732 rfrm[nrfrms++] = frame;
733 return(0);
734 }
735
736
737 int
738 frecover(frame) /* recover filtered frame */
739 int frame;
740 {
741 VIEW *vp;
742 char *ex;
743
744 vp = getview(frame);
745 ex = getexp(frame);
746 if (dofilt(frame, vp, ex, 2) && dofilt(frame, vp, ex, 1))
747 return(1);
748 return(0);
749 }
750
751
752 archive() /* archive and remove renderings */
753 {
754 #define RMCOML (sizeof(rmcom)-1)
755 static char rmcom[] = "rm -f";
756 register int i;
757
758 if (arcnext == arcfirst)
759 return; /* nothing to do */
760 if (vdef(ARCHIVE)) { /* run archive command */
761 i = strlen(vval(ARCHIVE));
762 strncpy(arcfirst-i, vval(ARCHIVE), i);
763 if (runcom(arcfirst-i)) {
764 fprintf(stderr, "%s: error running archive command\n",
765 progname);
766 quit(1);
767 }
768 }
769 /* run remove command */
770 strncpy(arcfirst-RMCOML, rmcom, RMCOML);
771 runcom(arcfirst-RMCOML);
772 arcnext = arcfirst; /* reset argument list */
773 #undef RMCOML
774 }
775
776
777 int
778 dofilt(frame, vp, ep, rvr) /* filter frame */
779 int frame;
780 VIEW *vp;
781 char *ep;
782 int rvr;
783 {
784 extern int frecover();
785 static int iter = 0;
786 char fnbefore[128], fnafter[128];
787 char combuf[1024], fname0[128], fname1[128];
788 int usepinterp, usepfilt, nora_rgbe;
789 int frseq[2];
790 /* check what is needed */
791 usepinterp = atoi(vval(MBLUR));
792 usepfilt = pfiltalways | ep==NULL;
793 if (ep != NULL && !strcmp(ep, "1"))
794 ep = "+0";
795 nora_rgbe = strcmp(vval(OVERSAMP),"1") || ep==NULL ||
796 *ep != '+' || *ep != '-' || !isint(ep);
797 /* compute rendered views */
798 frseq[0] = frame - ((frame-1) % (vint(INTERP)+1));
799 frseq[1] = frseq[0] + vint(INTERP) + 1;
800 if (frseq[1] > vint(END))
801 frseq[1] = vint(END);
802 if (frseq[1] == frame) { /* pfilt only */
803 frseq[0] = frseq[1];
804 usepinterp = 0; /* update what's needed */
805 usepfilt |= nora_rgbe;
806 } else if (frseq[0] == frame) { /* no interpolation needed */
807 if (!rvr && frame > 1+vint(INTERP)) { /* archive previous */
808 *arcnext++ = ' ';
809 sprintf(arcnext, vval(BASENAME), frame-vint(INTERP)-1);
810 while (*arcnext) arcnext++;
811 strcpy(arcnext, ".unf");
812 arcnext += 4;
813 if (usepinterp || vint(INTERP)) { /* and z-buf */
814 *arcnext++ = ' ';
815 sprintf(arcnext, vval(BASENAME),
816 frame-vint(INTERP)-1);
817 while (*arcnext) arcnext++;
818 strcpy(arcnext, ".zbf");
819 arcnext += 4;
820 }
821 }
822 if (!usepinterp) /* update what's needed */
823 usepfilt |= nora_rgbe;
824 } else /* interpolation needed */
825 usepinterp++;
826 if (frseq[1] >= astat.rnext) /* next batch unavailable */
827 frseq[1] = frseq[0];
828 sprintf(fnbefore, vval(BASENAME), frseq[0]);
829 sprintf(fnafter, vval(BASENAME), frseq[1]);
830 if (rvr == 1 && recover(frseq[0])) /* recover before frame? */
831 return(1);
832 /* generate command */
833 if (usepinterp) { /* using pinterp */
834 if (rvr == 2 && recover(frseq[1])) /* recover after? */
835 return(1);
836 if (atoi(vval(MBLUR))) {
837 FILE *fp; /* motion blurring */
838 sprintf(fname0, "%s/vw0%c", vval(DIRECTORY),
839 'a'+(iter%26));
840 if ((fp = fopen(fname0, "w")) == NULL) {
841 perror(fname0); quit(1);
842 }
843 fputs(VIEWSTR, fp);
844 fprintview(vp, fp);
845 putc('\n', fp); fclose(fp);
846 if ((vp = getview(frame+1)) == NULL) {
847 fprintf(stderr,
848 "%s: unexpected error reading view for frame %d\n",
849 progname, frame+1);
850 quit(1);
851 }
852 sprintf(fname1, "%s/vw1%c", vval(DIRECTORY),
853 'a'+(iter%26));
854 if ((fp = fopen(fname1, "w")) == NULL) {
855 perror(fname1); quit(1);
856 }
857 fputs(VIEWSTR, fp);
858 fprintview(vp, fp);
859 putc('\n', fp); fclose(fp);
860 sprintf(combuf,
861 "(pmblur %s %d %s %s; rm -f %s %s) | pinterp -B",
862 *sskip(vval(MBLUR)) ? sskip2(vval(MBLUR),1) : "1",
863 atoi(vval(MBLUR)),
864 fname0, fname1, fname0, fname1);
865 iter++;
866 } else /* no blurring */
867 strcpy(combuf, "pinterp");
868 strcat(combuf, viewopt(vp));
869 if (vbool(RTRACE))
870 sprintf(combuf+strlen(combuf), " -ff -fr '%s -w0 %s'",
871 rendopt, vval(OCTREE));
872 if (vdef(PINTERP))
873 sprintf(combuf+strlen(combuf), " %s", vval(PINTERP));
874 if (usepfilt)
875 sprintf(combuf+strlen(combuf), " %s", rresopt);
876 else
877 sprintf(combuf+strlen(combuf), " %s -e %s",
878 fresopt, ep);
879 sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
880 fnbefore, fnbefore);
881 if (frseq[1] != frseq[0])
882 sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
883 fnafter, fnafter);
884 if (usepfilt) { /* also pfilt */
885 if (vdef(PFILT))
886 sprintf(combuf+strlen(combuf), " | pfilt %s",
887 vval(PFILT));
888 else
889 strcat(combuf, " | pfilt");
890 if (ep != NULL)
891 sprintf(combuf+strlen(combuf), " -1 -e %s %s",
892 ep, fresopt);
893 else
894 sprintf(combuf+strlen(combuf), " %s", fresopt);
895 }
896 } else if (usepfilt) { /* pfilt only */
897 if (rvr == 2)
898 return(1);
899 if (vdef(PFILT))
900 sprintf(combuf, "pfilt %s", vval(PFILT));
901 else
902 strcpy(combuf, "pfilt");
903 if (ep != NULL)
904 sprintf(combuf+strlen(combuf), " -1 -e %s %s %s.unf",
905 ep, fresopt, fnbefore);
906 else
907 sprintf(combuf+strlen(combuf), " %s %s.unf",
908 fresopt, fnbefore);
909 } else { /* else just check it */
910 if (rvr == 2)
911 return(1);
912 sprintf(combuf, "ra_rgbe -e %s -r %s.unf", ep, fnbefore);
913 }
914 /* output file name */
915 sprintf(fname0, vval(BASENAME), frame);
916 sprintf(combuf+strlen(combuf), " > %s.pic", fname0);
917 if (rvr) /* in recovery */
918 return(runcom(combuf));
919 bruncom(combuf, frame, frecover); /* else run in background */
920 return(0);
921 }
922
923
924 VIEW *
925 getview(n) /* get view number n */
926 int n;
927 {
928 static FILE *viewfp = NULL; /* view file pointer */
929 static int viewnum = 0; /* current view number */
930 static VIEW curview = STDVIEW; /* current view */
931 char linebuf[256];
932
933 if (n == 0) { /* signal to close file and clean up */
934 if (viewfp != NULL) {
935 fclose(viewfp);
936 viewfp = NULL;
937 viewnum = 0;
938 copystruct(&curview, &stdview);
939 }
940 return(NULL);
941 }
942 if (viewfp == NULL) { /* open file */
943 if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) {
944 perror(vval(VIEWFILE));
945 quit(1);
946 }
947 } else if (n < viewnum) { /* rewind file */
948 if (viewnum == 1 && feof(viewfp))
949 return(&curview); /* just one view */
950 if (fseek(viewfp, 0L, 0) == EOF) {
951 perror(vval(VIEWFILE));
952 quit(1);
953 }
954 copystruct(&curview, &stdview);
955 viewnum = 0;
956 }
957 while (n > viewnum) { /* scan to desired view */
958 if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL)
959 return(viewnum==1 ? &curview : NULL);
960 if (isview(linebuf) && sscanview(&curview, linebuf) > 0)
961 viewnum++;
962 }
963 return(&curview); /* return it */
964 }
965
966
967 int
968 countviews() /* count views in view file */
969 {
970 register int n = 0;
971
972 while (getview(n+1) != NULL)
973 n++;
974 return(n);
975 }
976
977
978 char *
979 getexp(n) /* get exposure for nth frame */
980 int n;
981 {
982 extern char *fskip();
983 static char expval[32];
984 static FILE *expfp = NULL;
985 static long *exppos;
986 static int curfrm;
987 register char *cp;
988
989 if (n == 0) { /* signal to close file */
990 if (expfp != NULL) {
991 fclose(expfp);
992 expfp = NULL;
993 }
994 return(NULL);
995 }
996 if (!vdef(EXPOSURE)) /* no setting (auto) */
997 return(NULL);
998 if (isflt(vval(EXPOSURE))) /* always the same */
999 return(vval(EXPOSURE));
1000 if (expfp == NULL) { /* open exposure file */
1001 if ((expfp = fopen(vval(EXPOSURE), "r")) == NULL) {
1002 fprintf(stderr,
1003 "%s: cannot open exposure file \"%s\"\n",
1004 progname, vval(EXPOSURE));
1005 quit(1);
1006 }
1007 curfrm = vint(END) + 1; /* init lookup tab. */
1008 exppos = (long *)malloc(curfrm*sizeof(long *));
1009 if (exppos == NULL) {
1010 perror(progname);
1011 quit(1);
1012 }
1013 while (curfrm--)
1014 exppos[curfrm] = -1L;
1015 curfrm = 0;
1016 }
1017 /* find position in file */
1018 if (n-1 != curfrm && n != curfrm && exppos[n-1] >= 0 &&
1019 fseek(expfp, exppos[curfrm=n-1], 0) == EOF) {
1020 fprintf(stderr, "%s: seek error on exposure file\n", progname);
1021 quit(1);
1022 }
1023 while (n > curfrm) { /* read exposure */
1024 if (exppos[curfrm] < 0)
1025 exppos[curfrm] = ftell(expfp);
1026 if (fgets(expval, sizeof(expval), expfp) == NULL) {
1027 fprintf(stderr, "%s: too few exposures\n",
1028 vval(EXPOSURE));
1029 quit(1);
1030 }
1031 curfrm++;
1032 cp = fskip(expval); /* check format */
1033 if (cp == NULL || *cp != '\n') {
1034 fprintf(stderr,
1035 "%s: exposure format error on line %d\n",
1036 vval(EXPOSURE), curfrm);
1037 quit(1);
1038 }
1039 *cp = '\0';
1040 }
1041 return(expval); /* return value */
1042 }
1043
1044
1045 struct pslot *
1046 findpslot(pid) /* find or allocate a process slot */
1047 int pid;
1048 {
1049 register struct pslot *psempty = NULL;
1050 register int i;
1051
1052 for (i = 0; i < npslots; i++) { /* look for match */
1053 if (pslot[i].pid == pid)
1054 return(pslot+i);
1055 if (psempty == NULL && pslot[i].pid == 0)
1056 psempty = pslot+i;
1057 }
1058 return(psempty); /* return emtpy slot (error if NULL) */
1059 }
1060
1061
1062 int
1063 donecom(ps, pn, status) /* clean up after finished process */
1064 PSERVER *ps;
1065 int pn;
1066 int status;
1067 {
1068 register PROC *pp;
1069
1070 pp = ps->proc + pn;
1071 if (pp->elen) { /* pass errors */
1072 if (ps->hostname[0])
1073 fprintf(stderr, "%s: ", ps->hostname);
1074 fprintf(stderr, "Error output from: %s\n", pp->com);
1075 fputs(pp->errs, stderr);
1076 fflush(stderr);
1077 if (ps->hostname[0])
1078 status = 1; /* because rsh doesn't return status */
1079 }
1080 freestr(pp->com); /* free command string */
1081 lastpid = pp->pid; /* record PID for bwait() */
1082 lastpserver = ps; /* record server for serverdown() */
1083 return(status);
1084 }
1085
1086
1087 int
1088 serverdown() /* check status of last process server */
1089 {
1090 if (pserverOK(lastpserver)) /* server still up? */
1091 return(0);
1092 delpserver(lastpserver); /* else delete it */
1093 if (pslist == NULL) {
1094 fprintf(stderr, "%s: all process servers are down\n",
1095 progname);
1096 quit(1);
1097 }
1098 return(1);
1099 }
1100
1101
1102 int
1103 bruncom(com, fout, rf) /* run a command in the background */
1104 char *com;
1105 int fout;
1106 int (*rf)();
1107 {
1108 int pid;
1109 register struct pslot *psl;
1110
1111 if (noaction) {
1112 if (!silent)
1113 printf("\t%s\n", com); /* echo command */
1114 return(0);
1115 }
1116 /* else start it when we can */
1117 while ((pid = startjob(NULL, savestr(com), donecom)) == -1)
1118 bwait(1);
1119 if (!silent) { /* echo command */
1120 PSERVER *ps;
1121 int psn = pid;
1122 ps = findjob(&psn);
1123 printf("\t%s\n", com);
1124 printf("\tProcess started on %s\n", phostname(ps));
1125 fflush(stdout);
1126 }
1127 psl = findpslot(pid); /* record info. in appropriate slot */
1128 psl->pid = pid;
1129 psl->fout = fout;
1130 psl->rcvf = rf;
1131 return(pid);
1132 }
1133
1134
1135 bwait(ncoms) /* wait for batch job(s) to finish */
1136 int ncoms;
1137 {
1138 int status;
1139 register struct pslot *psl;
1140
1141 if (noaction)
1142 return;
1143 while ((status = wait4job(NULL, -1)) != -1) {
1144 psl = findpslot(lastpid);
1145 if (status) { /* attempt recovery */
1146 serverdown(); /* check server */
1147 if (psl->rcvf == NULL || (*psl->rcvf)(psl->fout)) {
1148 fprintf(stderr,
1149 "%s: error rendering frame %d\n",
1150 progname, psl->fout);
1151 quit(1);
1152 }
1153 }
1154 psl->pid = 0; /* free process slot */
1155 if (!--ncoms)
1156 return; /* done enough */
1157 }
1158 }
1159
1160
1161 int
1162 pruncom(com, ppins, maxcopies) /* run a command in parallel over network */
1163 char *com, *ppins;
1164 int maxcopies;
1165 {
1166 int retstatus = 0;
1167 int hostcopies;
1168 char com1buf[10240], *com1, *endcom1;
1169 int status;
1170 register PSERVER *ps;
1171
1172 if (!silent)
1173 printf("\t%s\n", com); /* echo command */
1174 if (noaction)
1175 return(0);
1176 fflush(stdout);
1177 /* start jobs on each server */
1178 for (ps = pslist; ps != NULL; ps = ps->next) {
1179 hostcopies = 0;
1180 if (maxcopies > 1 && ps->nprocs > 1 && ppins != NULL) {
1181 strcpy(com1=com1buf, com); /* build -PP command */
1182 sprintf(com1+(ppins-com), " -PP %s/%s.persist",
1183 vval(DIRECTORY), phostname(ps));
1184 strcat(com1, ppins);
1185 endcom1 = com1 + strlen(com1);
1186 sprintf(endcom1, "; kill `sed -n '1s/^[^ ]* //p' %s/%s.persist`",
1187 vval(DIRECTORY), phostname(ps));
1188 } else {
1189 com1 = com;
1190 endcom1 = NULL;
1191 }
1192 while (maxcopies > 0 &&
1193 startjob(ps, savestr(com1), donecom) != -1) {
1194 sleep(10);
1195 hostcopies++;
1196 maxcopies--;
1197 if (endcom1 != NULL)
1198 *endcom1 = '\0';
1199 }
1200 if (!silent && hostcopies) {
1201 if (hostcopies > 1)
1202 printf("\t%d duplicate processes", hostcopies);
1203 else
1204 printf("\tProcess");
1205 printf(" started on %s\n", phostname(ps));
1206 fflush(stdout);
1207 }
1208 }
1209 /* wait for jobs to finish */
1210 while ((status = wait4job(NULL, -1)) != -1)
1211 if (status)
1212 retstatus += !serverdown(); /* check server */
1213 return(retstatus);
1214 }
1215
1216
1217 runcom(cs) /* run a command locally and wait for it */
1218 char *cs;
1219 {
1220 if (!silent) /* echo it */
1221 printf("\t%s\n", cs);
1222 if (noaction)
1223 return(0);
1224 fflush(stdout); /* flush output and pass to shell */
1225 return(system(cs));
1226 }
1227
1228
1229 rmfile(fn) /* remove a file */
1230 char *fn;
1231 {
1232 if (!silent)
1233 #ifdef MSDOS
1234 printf("\tdel %s\n", fn);
1235 #else
1236 printf("\trm -f %s\n", fn);
1237 #endif
1238 if (noaction)
1239 return(0);
1240 return(unlink(fn));
1241 }
1242
1243
1244 badvalue(vc) /* report bad variable value and exit */
1245 int vc;
1246 {
1247 fprintf(stderr, "%s: bad value for variable '%s'\n",
1248 progname, vnam(vc));
1249 quit(1);
1250 }
