| 1 |
/* Copyright (c) 1995 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Radiance animation control program
| 9 |
| 10 |
| 11 |
#include "standard.h"
| 12 |
#include <ctype.h>
| 13 |
#include <sys/types.h>
| 14 |
#include <sys/stat.h>
| 15 |
#include "view.h"
| 16 |
#include "vars.h"
| 17 |
#include "netproc.h"
| 18 |
/* input variables */
| 19 |
#define HOST 0 /* rendering host machine */
| 20 |
#define RENDER 1 /* rendering options */
| 21 |
#define PFILT 2 /* pfilt options */
| 22 |
#define PINTERP 3 /* pinterp options */
| 23 |
#define OCTREE 4 /* octree file name */
| 24 |
#define DIRECTORY 5 /* working (sub)directory */
| 25 |
#define BASENAME 6 /* output image base name */
| 26 |
#define VIEWFILE 7 /* animation frame views */
| 27 |
#define START 8 /* starting frame number */
| 28 |
#define END 9 /* ending frame number */
| 29 |
#define RIF 10 /* rad input file */
| 30 |
#define NEXTANIM 11 /* next animation file */
| 31 |
#define ANIMATE 12 /* animation command */
| 32 |
#define TRANSFER 13 /* frame transfer command */
| 33 |
#define ARCHIVE 14 /* archiving command */
| 34 |
#define INTERP 15 /* # frames to interpolate */
| 35 |
#define OVERSAMP 16 /* # times to oversample image */
| 36 |
#define MBLUR 17 /* samples for motion blur */
| 37 |
#define RTRACE 18 /* use rtrace with pinterp? */
| 38 |
#define DISKSPACE 19 /* how much disk space to use */
| 39 |
#define RESOLUTION 20 /* desired final resolution */
| 40 |
#define EXPOSURE 21 /* how to compute exposure */
| 41 |
| 42 |
int NVARS = 22; /* total number of variables */
| 43 |
| 44 |
VARIABLE vv[] = { /* variable-value pairs */
| 45 |
{"host", 4, 0, NULL, NULL},
| 46 |
{"render", 3, 0, NULL, catvalues},
| 47 |
{"pfilt", 2, 0, NULL, catvalues},
| 48 |
{"pinterp", 2, 0, NULL, catvalues},
| 49 |
{"OCTREE", 3, 0, NULL, onevalue},
| 50 |
{"DIRECTORY", 3, 0, NULL, onevalue},
| 51 |
{"BASENAME", 3, 0, NULL, onevalue},
| 52 |
{"VIEWFILE", 2, 0, NULL, onevalue},
| 53 |
{"START", 2, 0, NULL, intvalue},
| 54 |
{"END", 2, 0, NULL, intvalue},
| 55 |
{"RIF", 3, 0, NULL, onevalue},
| 56 |
{"NEXTANIM", 3, 0, NULL, onevalue},
| 57 |
{"ANIMATE", 2, 0, NULL, onevalue},
| 58 |
{"TRANSFER", 2, 0, NULL, onevalue},
| 59 |
{"ARCHIVE", 2, 0, NULL, onevalue},
| 60 |
{"INTERPOLATE", 3, 0, NULL, intvalue},
| 61 |
{"OVERSAMPLE", 2, 0, NULL, fltvalue},
| 62 |
{"MBLUR", 2, 0, NULL, onevalue},
| 63 |
{"RTRACE", 2, 0, NULL, boolvalue},
| 64 |
{"DISKSPACE", 3, 0, NULL, fltvalue},
| 65 |
{"RESOLUTION", 3, 0, NULL, onevalue},
| 66 |
{"EXPOSURE", 3, 0, NULL, onevalue},
| 67 |
| 68 |
| 69 |
#define SFNAME "STATUS" /* status file name */
| 70 |
| 71 |
struct {
| 72 |
char host[64]; /* control host name */
| 73 |
int pid; /* control process id */
| 74 |
char cfname[128]; /* control file name */
| 75 |
int rnext; /* next frame to render */
| 76 |
int fnext; /* next frame to filter */
| 77 |
int tnext; /* next frame to transfer */
| 78 |
} astat; /* animation status */
| 79 |
| 80 |
char *progname; /* our program name */
| 81 |
char *cfname; /* our control file name */
| 82 |
| 83 |
int nowarn = 0; /* turn warnings off? */
| 84 |
int silent = 0; /* silent mode? */
| 85 |
int noaction = 0; /* take no action? */
| 86 |
| 87 |
char rendopt[2048] = ""; /* rendering options */
| 88 |
char rresopt[32]; /* rendering resolution options */
| 89 |
char fresopt[32]; /* filter resolution options */
| 90 |
int pfiltalways; /* always use pfilt? */
| 91 |
| 92 |
char arcargs[10240]; /* files to archive */
| 93 |
char *arcfirst, *arcnext; /* pointers to first and next argument */
| 94 |
| 95 |
struct pslot {
| 96 |
int pid; /* process ID (0 if empty) */
| 97 |
int fout; /* output frame number */
| 98 |
int (*rcvf)(); /* recover function */
| 99 |
} *pslot; /* process slots */
| 100 |
int npslots; /* number of process slots */
| 101 |
| 102 |
int lastpid; /* ID of last completed background process */
| 103 |
PSERVER *lastpserver; /* last process server used */
| 104 |
| 105 |
#define phostname(ps) ((ps)->hostname[0] ? (ps)->hostname : astat.host)
| 106 |
| 107 |
struct pslot *findpslot();
| 108 |
| 109 |
VIEW *getview();
| 110 |
char *getexp();
| 111 |
| 112 |
| 113 |
main(argc, argv)
| 114 |
int argc;
| 115 |
char *argv[];
| 116 |
| 117 |
int explicate = 0;
| 118 |
int i;
| 119 |
| 120 |
progname = argv[0]; /* get arguments */
| 121 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 122 |
switch (argv[i][1]) {
| 123 |
case 'e': /* print variables */
| 124 |
explicate++;
| 125 |
break;
| 126 |
case 'w': /* turn off warnings */
| 127 |
nowarn++;
| 128 |
break;
| 129 |
case 's': /* silent mode */
| 130 |
silent++;
| 131 |
break;
| 132 |
case 'n': /* take no action */
| 133 |
noaction++;
| 134 |
break;
| 135 |
default:
| 136 |
goto userr;
| 137 |
| 138 |
if (i != argc-1)
| 139 |
goto userr;
| 140 |
cfname = argv[i];
| 141 |
/* load variables */
| 142 |
loadvars(cfname);
| 143 |
/* did we get DIRECTORY? */
| 144 |
checkdir();
| 145 |
/* check status */
| 146 |
if (getastat() < 0) {
| 147 |
fprintf(stderr, "%s: exiting\n", progname);
| 148 |
quit(1);
| 149 |
| 150 |
/* pfilt always if options given */
| 151 |
pfiltalways = vdef(PFILT);
| 152 |
/* load RIF if any */
| 153 |
if (vdef(RIF))
| 154 |
getradfile(vval(RIF));
| 155 |
/* set defaults */
| 156 |
setdefaults();
| 157 |
| 158 |
if (explicate)
| 159 |
printvars(stdout);
| 160 |
/* set up process servers */
| 161 |
sethosts();
| 162 |
/* run animation */
| 163 |
animate();
| 164 |
/* all done */
| 165 |
if (vdef(NEXTANIM)) {
| 166 |
argv[i] = vval(NEXTANIM); /* just change input file */
| 167 |
if (!silent)
| 168 |
printargs(argc, argv, stdout);
| 169 |
execvp(progname, argv); /* pass to next */
| 170 |
quit(1); /* shouldn't return */
| 171 |
| 172 |
quit(0);
| 173 |
userr:
| 174 |
fprintf(stderr, "Usage: %s [-s][-n][-w][-e] anim_file\n", progname);
| 175 |
quit(1);
| 176 |
| 177 |
| 178 |
| 179 |
getastat() /* check/set animation status */
| 180 |
| 181 |
char buf[256];
| 182 |
FILE *fp;
| 183 |
| 184 |
sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME);
| 185 |
if ((fp = fopen(buf, "r")) == NULL) {
| 186 |
if (errno != ENOENT) {
| 187 |
perror(buf);
| 188 |
return(-1);
| 189 |
| 190 |
astat.rnext = astat.fnext = astat.tnext = 0;
| 191 |
goto setours;
| 192 |
| 193 |
if (fscanf(fp, "Control host: %s\n", astat.host) != 1)
| 194 |
goto fmterr;
| 195 |
if (fscanf(fp, "Control PID: %d\n", &astat.pid) != 1)
| 196 |
goto fmterr;
| 197 |
if (fscanf(fp, "Control file: %s\n", astat.cfname) != 1)
| 198 |
goto fmterr;
| 199 |
if (fscanf(fp, "Next render: %d\n", &astat.rnext) != 1)
| 200 |
goto fmterr;
| 201 |
if (fscanf(fp, "Next filter: %d\n", &astat.fnext) != 1)
| 202 |
goto fmterr;
| 203 |
if (fscanf(fp, "Next transfer: %d\n", &astat.tnext) != 1)
| 204 |
goto fmterr;
| 205 |
fclose(fp);
| 206 |
if (astat.pid != 0) { /* thinks it's still running */
| 207 |
gethostname(buf, sizeof(buf));
| 208 |
if (strcmp(buf, astat.host)) {
| 209 |
fprintf(stderr,
| 210 |
"%s: process %d may still be running on host %s\n",
| 211 |
progname, astat.pid, astat.host);
| 212 |
return(-1);
| 213 |
| 214 |
if (kill(astat.pid, 0) != -1 || errno != ESRCH) {
| 215 |
fprintf(stderr, "%s: process %d is still running\n",
| 216 |
progname, astat.pid);
| 217 |
return(-1);
| 218 |
| 219 |
/* assume it is dead */
| 220 |
| 221 |
if (strcmp(cfname, astat.cfname) && astat.tnext != 0) { /* other's */
| 222 |
fprintf(stderr, "%s: unfinished job \"%s\"\n",
| 223 |
progname, astat.cfname);
| 224 |
return(-1);
| 225 |
| 226 |
setours: /* set our values */
| 227 |
gethostname(astat.host, sizeof(astat.host));
| 228 |
astat.pid = getpid();
| 229 |
strcpy(astat.cfname, cfname);
| 230 |
return(0);
| 231 |
fmterr:
| 232 |
fprintf(stderr, "%s: format error in status file \"%s\"\n",
| 233 |
progname, buf);
| 234 |
fclose(fp);
| 235 |
return(-1);
| 236 |
| 237 |
| 238 |
| 239 |
putastat() /* put out current status */
| 240 |
| 241 |
char buf[256];
| 242 |
FILE *fp;
| 243 |
| 244 |
if (noaction)
| 245 |
return;
| 246 |
| 247 |
if ((fp = fopen(buf, "w")) == NULL) {
| 248 |
perror(buf);
| 249 |
quit(1);
| 250 |
| 251 |
fprintf(fp, "Control host: %s\n", astat.host);
| 252 |
fprintf(fp, "Control PID: %d\n", astat.pid);
| 253 |
fprintf(fp, "Control file: %s\n", astat.cfname);
| 254 |
fprintf(fp, "Next render: %d\n", astat.rnext);
| 255 |
fprintf(fp, "Next filter: %d\n", astat.fnext);
| 256 |
fprintf(fp, "Next transfer: %d\n", astat.tnext);
| 257 |
fclose(fp);
| 258 |
| 259 |
| 260 |
| 261 |
checkdir() /* make sure we have our directory */
| 262 |
| 263 |
struct stat stb;
| 264 |
| 265 |
if (!vdef(DIRECTORY)) {
| 266 |
fprintf(stderr, "%s: %s undefined\n",
| 267 |
progname, vnam(DIRECTORY));
| 268 |
quit(1);
| 269 |
| 270 |
if (stat(vval(DIRECTORY), &stb) == -1) {
| 271 |
if (errno == ENOENT && mkdir(vval(DIRECTORY), 0777) == 0)
| 272 |
return;
| 273 |
perror(vval(DIRECTORY));
| 274 |
quit(1);
| 275 |
| 276 |
if (!(stb.st_mode & S_IFDIR)) {
| 277 |
fprintf(stderr, "%s: not a directory\n", vval(DIRECTORY));
| 278 |
quit(1);
| 279 |
| 280 |
| 281 |
| 282 |
| 283 |
setdefaults() /* set default values */
| 284 |
| 285 |
char buf[256];
| 286 |
| 287 |
if (vdef(ANIMATE)) {
| 288 |
vval(OCTREE) = NULL;
| 289 |
vdef(OCTREE) = 0;
| 290 |
} else if (!vdef(OCTREE)) {
| 291 |
fprintf(stderr, "%s: either %s or %s must be defined\n",
| 292 |
progname, vnam(OCTREE), vnam(ANIMATE));
| 293 |
quit(1);
| 294 |
| 295 |
if (!vdef(VIEWFILE)) {
| 296 |
fprintf(stderr, "%s: %s undefined\n", progname, vnam(VIEWFILE));
| 297 |
quit(1);
| 298 |
| 299 |
if (!vdef(HOST)) {
| 300 |
vval(HOST) = LHOSTNAME;
| 301 |
vdef(HOST)++;
| 302 |
| 303 |
if (!vdef(START)) {
| 304 |
vval(START) = "1";
| 305 |
vdef(START)++;
| 306 |
| 307 |
if (!vdef(END)) {
| 308 |
sprintf(buf, "%d", countviews()+vint(START)-1);
| 309 |
vval(END) = savqstr(buf);
| 310 |
vdef(END)++;
| 311 |
| 312 |
if (vint(END) < vint(START)) {
| 313 |
fprintf(stderr, "%s: ending frame less than starting frame\n",
| 314 |
progname);
| 315 |
quit(1);
| 316 |
| 317 |
if (!vdef(BASENAME)) {
| 318 |
sprintf(buf, "%s/frame%%03d", vval(DIRECTORY));
| 319 |
vval(BASENAME) = savqstr(buf);
| 320 |
vdef(BASENAME)++;
| 321 |
| 322 |
if (!vdef(RESOLUTION)) {
| 323 |
vval(RESOLUTION) = "640";
| 324 |
vdef(RESOLUTION)++;
| 325 |
| 326 |
if (!vdef(OVERSAMP)) {
| 327 |
vval(OVERSAMP) = "2";
| 328 |
vdef(OVERSAMP)++;
| 329 |
| 330 |
if (!vdef(INTERP)) {
| 331 |
vval(INTERP) = "0";
| 332 |
vdef(INTERP)++;
| 333 |
| 334 |
if (!vdef(MBLUR)) {
| 335 |
vval(MBLUR) = "0";
| 336 |
vdef(MBLUR)++;
| 337 |
| 338 |
if (!vdef(RTRACE)) {
| 339 |
vval(RTRACE) = "F";
| 340 |
vdef(RTRACE)++;
| 341 |
| 342 |
if (!vdef(DISKSPACE)) {
| 343 |
if (!nowarn)
| 344 |
fprintf(stderr,
| 345 |
"%s: warning - no %s setting, assuming 100 Mbytes available\n",
| 346 |
progname, vnam(DISKSPACE));
| 347 |
vval(DISKSPACE) = "100";
| 348 |
vdef(DISKSPACE)++;
| 349 |
| 350 |
/* append rendering options */
| 351 |
if (vdef(RENDER))
| 352 |
sprintf(rendopt+strlen(rendopt), " %s", vval(RENDER));
| 353 |
| 354 |
| 355 |
| 356 |
sethosts() /* set up process servers */
| 357 |
| 358 |
extern char *iskip();
| 359 |
char buf[256], *dir, *uname;
| 360 |
int np;
| 361 |
register char *cp;
| 362 |
int i;
| 363 |
| 364 |
npslots = 0;
| 365 |
if (noaction)
| 366 |
return;
| 367 |
for (i = 0; i < vdef(HOST); i++) { /* add each host */
| 368 |
dir = uname = NULL;
| 369 |
np = 1;
| 370 |
strcpy(cp=buf, nvalue(HOST, i)); /* copy to buffer */
| 371 |
cp = sskip(cp); /* skip host name */
| 372 |
while (isspace(*cp))
| 373 |
*cp++ = '\0';
| 374 |
if (*cp) { /* has # processes? */
| 375 |
np = atoi(cp);
| 376 |
if ((cp = iskip(cp)) == NULL || (*cp && !isspace(*cp)))
| 377 |
badvalue(HOST);
| 378 |
| 379 |
cp++;
| 380 |
if (*cp) { /* has directory? */
| 381 |
dir = cp;
| 382 |
cp = sskip(cp); /* skip dir. */
| 383 |
| 384 |
*cp++ = '\0';
| 385 |
if (*cp) { /* has user? */
| 386 |
uname = cp;
| 387 |
if (*sskip(cp))
| 388 |
badvalue(HOST);
| 389 |
| 390 |
| 391 |
| 392 |
if (addpserver(buf, dir, uname, np) == NULL) {
| 393 |
if (!nowarn)
| 394 |
fprintf(stderr,
| 395 |
"%s: cannot execute on host \"%s\"\n",
| 396 |
progname, buf);
| 397 |
} else
| 398 |
npslots += np;
| 399 |
| 400 |
if (npslots == 0) {
| 401 |
fprintf(stderr, "%s: no working process servers\n", progname);
| 402 |
quit(1);
| 403 |
| 404 |
pslot = (struct pslot *)calloc(npslots, sizeof(struct pslot));
| 405 |
if (pslot == NULL) {
| 406 |
perror("malloc");
| 407 |
quit(1);
| 408 |
| 409 |
| 410 |
| 411 |
| 412 |
getradfile(rfargs) /* run rad and get needed variables */
| 413 |
char *rfargs;
| 414 |
| 415 |
static short mvar[] = {OCTREE,PFILT,RESOLUTION,EXPOSURE,-1};
| 416 |
char combuf[256];
| 417 |
register int i;
| 418 |
register char *cp;
| 419 |
/* create rad command */
| 420 |
sprintf(rendopt, " @%s/render.opt", vval(DIRECTORY));
| 421 |
sprintf(combuf,
| 422 |
"rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
| 423 |
rfargs, rendopt+2);
| 424 |
cp = combuf;
| 425 |
while (*cp) cp++; /* match unset variables */
| 426 |
for (i = 0; mvar[i] >= 0; i++)
| 427 |
if (!vdef(mvar[i])) {
| 428 |
*cp++ = '|';
| 429 |
strcpy(cp, vnam(mvar[i]));
| 430 |
while (*cp) cp++;
| 431 |
| 432 |
sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY));
| 433 |
cp += 11; /* point to file name */
| 434 |
if (system(combuf)) {
| 435 |
fprintf(stderr, "%s: error executing rad command:\n\t%s\n",
| 436 |
progname, combuf);
| 437 |
quit(1);
| 438 |
| 439 |
loadvars(cp); /* load variables and remove file */
| 440 |
unlink(cp);
| 441 |
| 442 |
| 443 |
| 444 |
animate() /* run animation */
| 445 |
| 446 |
int xres, yres;
| 447 |
float pa, mult;
| 448 |
int frames_batch;
| 449 |
register int i;
| 450 |
double d1, d2;
| 451 |
/* compute rpict resolution */
| 452 |
i = sscanf(vval(RESOLUTION), "%d %d %f", &xres, &yres, &pa);
| 453 |
mult = vflt(OVERSAMP);
| 454 |
if (i == 3) {
| 455 |
sprintf(rresopt, "-x %d -y %d -pa %f", (int)(mult*xres),
| 456 |
(int)(mult*yres), pa);
| 457 |
sprintf(fresopt, "-x %d -y %d -pa %f", xres, yres, pa);
| 458 |
} else if (i) {
| 459 |
if (i == 1) yres = xres;
| 460 |
sprintf(rresopt, "-x %d -y %d", (int)(mult*xres),
| 461 |
(int)(mult*yres));
| 462 |
sprintf(fresopt, "-x %d -y %d -pa 1", xres, yres);
| 463 |
} else
| 464 |
badvalue(RESOLUTION);
| 465 |
/* consistency checks */
| 466 |
| 467 |
if (vint(INTERP)) {
| 468 |
if (!nowarn)
| 469 |
fprintf(stderr,
| 470 |
"%s: resetting %s=0 for animation\n",
| 471 |
progname, vnam(INTERP));
| 472 |
vval(INTERP) = "0";
| 473 |
| 474 |
if (atoi(vval(MBLUR))) { /* can't handle this yet */
| 475 |
if (!nowarn)
| 476 |
fprintf(stderr,
| 477 |
| 478 |
progname, vnam(MBLUR));
| 479 |
vval(MBLUR) = "0";
| 480 |
| 481 |
| 482 |
/* figure # frames per batch */
| 483 |
d1 = mult*xres*mult*yres*4; /* space for orig. picture */
| 484 |
if ((i=vint(INTERP)) || atoi(vval(MBLUR)))
| 485 |
d1 += mult*xres*mult*yres*4; /* space for z-buffer */
| 486 |
d2 = xres*yres*4; /* space for final picture */
| 487 |
frames_batch = (i+1)*(vflt(DISKSPACE)*1048576.-d1)/(d1+i*d2);
| 488 |
if (frames_batch < i+2) {
| 489 |
fprintf(stderr, "%s: insufficient disk space allocated\n",
| 490 |
progname);
| 491 |
quit(1);
| 492 |
| 493 |
/* initialize archive argument list */
| 494 |
i = 16;
| 495 |
if (vdef(ARCHIVE) && strlen(vval(ARCHIVE)) > i)
| 496 |
i = strlen(vval(ARCHIVE));
| 497 |
arcnext = arcfirst = arcargs + i;
| 498 |
/* initialize status file */
| 499 |
if (astat.rnext == 0)
| 500 |
astat.rnext = astat.fnext = astat.tnext = vint(START);
| 501 |
putastat();
| 502 |
/* render in batches */
| 503 |
while (astat.tnext <= vint(END)) {
| 504 |
renderframes(frames_batch);
| 505 |
filterframes();
| 506 |
transferframes();
| 507 |
| 508 |
/* mark status as finished */
| 509 |
astat.pid = 0;
| 510 |
putastat();
| 511 |
/* close open files */
| 512 |
getview(0);
| 513 |
getexp(0);
| 514 |
| 515 |
| 516 |
| 517 |
renderframes(nframes) /* render next nframes frames */
| 518 |
int nframes;
| 519 |
| 520 |
static char vendbuf[16];
| 521 |
VIEW *vp;
| 522 |
FILE *fp = NULL;
| 523 |
char vfname[128];
| 524 |
int lastframe;
| 525 |
register int i;
| 526 |
| 527 |
if (astat.tnext < astat.rnext) /* other work to do first */
| 528 |
return;
| 529 |
/* create batch view file */
| 530 |
if (!vdef(ANIMATE)) {
| 531 |
sprintf(vfname, "%s/anim.vf", vval(DIRECTORY));
| 532 |
if ((fp = fopen(vfname, "w")) == NULL) {
| 533 |
perror(vfname);
| 534 |
quit(1);
| 535 |
| 536 |
| 537 |
/* bound batch properly */
| 538 |
lastframe = astat.rnext + nframes - 1;
| 539 |
if ((lastframe-1) % (vint(INTERP)+1)) /* need even interval */
| 540 |
lastframe += vint(INTERP)+1 - ((lastframe-1)%(vint(INTERP)+1));
| 541 |
if (lastframe > vint(END)) /* check for end */
| 542 |
lastframe = vint(END);
| 543 |
/* render each view */
| 544 |
for (i = astat.rnext; i <= lastframe; i++) {
| 545 |
if ((vp = getview(i)) == NULL) {
| 546 |
if (!nowarn)
| 547 |
fprintf(stderr,
| 548 |
"%s: ran out of views before last frame\n",
| 549 |
progname);
| 550 |
sprintf(vval(END)=vendbuf, "%d", i-1);
| 551 |
lastframe = i - 1;
| 552 |
break;
| 553 |
| 554 |
if (vdef(ANIMATE)) /* animate frame */
| 555 |
animrend(i, vp);
| 556 |
else { /* else record it */
| 557 |
fputs(VIEWSTR, fp);
| 558 |
fprintview(vp, fp);
| 559 |
putc('\n', fp);
| 560 |
| 561 |
| 562 |
if (vdef(ANIMATE)) /* wait for renderings to finish */
| 563 |
bwait(0);
| 564 |
else { /* else if walk-through */
| 565 |
fclose(fp); /* close view file */
| 566 |
walkwait(astat.rnext, lastframe, vfname); /* walk it */
| 567 |
unlink(vfname); /* remove view file */
| 568 |
| 569 |
astat.rnext = i; /* update status */
| 570 |
putastat();
| 571 |
| 572 |
| 573 |
| 574 |
filterframes() /* catch up with filtering */
| 575 |
| 576 |
VIEW *vp;
| 577 |
register int i;
| 578 |
| 579 |
if (astat.tnext < astat.fnext) /* other work to do first */
| 580 |
return;
| 581 |
/* filter each view */
| 582 |
for (i = astat.fnext; i < astat.rnext; i++) {
| 583 |
if ((vp = getview(i)) == NULL) { /* get view i */
| 584 |
fprintf(stderr,
| 585 |
"%s: unexpected error reading view for frame %d\n",
| 586 |
progname, i);
| 587 |
quit(1);
| 588 |
| 589 |
dofilt(i, vp, getexp(i), 0); /* filter frame */
| 590 |
| 591 |
bwait(0); /* wait for filter processes */
| 592 |
archive(); /* archive originals */
| 593 |
astat.fnext = i; /* update status */
| 594 |
putastat();
| 595 |
| 596 |
| 597 |
| 598 |
transferframes() /* catch up with picture transfers */
| 599 |
| 600 |
char combuf[10240];
| 601 |
register char *cp;
| 602 |
register int i;
| 603 |
| 604 |
if (astat.tnext >= astat.fnext) /* nothing to do, yet */
| 605 |
return;
| 606 |
if (!vdef(TRANSFER)) { /* no transfer function -- leave 'em */
| 607 |
astat.tnext = astat.fnext;
| 608 |
putastat(); /* update status */
| 609 |
return;
| 610 |
| 611 |
strcpy(combuf, vval(TRANSFER)); /* start transfer command */
| 612 |
cp = combuf + strlen(combuf);
| 613 |
/* make argument list */
| 614 |
for (i = astat.tnext; i < astat.fnext; i++) {
| 615 |
*cp++ = ' ';
| 616 |
sprintf(cp, vval(BASENAME), i);
| 617 |
while (*cp) cp++;
| 618 |
strcpy(cp, ".pic");
| 619 |
cp += 4;
| 620 |
| 621 |
if (runcom(combuf)) { /* transfer frames */
| 622 |
fprintf(stderr, "%s: error running transfer command\n",
| 623 |
progname);
| 624 |
quit(1);
| 625 |
| 626 |
astat.tnext = i; /* update status */
| 627 |
putastat();
| 628 |
| 629 |
| 630 |
| 631 |
animrend(frame, vp) /* start animation frame */
| 632 |
int frame;
| 633 |
VIEW *vp;
| 634 |
| 635 |
extern int recover();
| 636 |
char combuf[2048];
| 637 |
char fname[128];
| 638 |
| 639 |
sprintf(fname, vval(BASENAME), frame);
| 640 |
strcat(fname, ".unf");
| 641 |
if (access(fname, F_OK) == 0)
| 642 |
return;
| 643 |
sprintf(combuf, "%s %d | rpict%s%s -w0 %s > %s", vval(ANIMATE), frame,
| 644 |
rendopt, viewopt(vp), rresopt, fname);
| 645 |
bruncom(combuf, frame, recover); /* run in background */
| 646 |
| 647 |
| 648 |
| 649 |
walkwait(first, last, vfn) /* walk-through frames */
| 650 |
int first, last;
| 651 |
char *vfn;
| 652 |
| 653 |
char combuf[2048];
| 654 |
char *inspoint;
| 655 |
register int i;
| 656 |
| 657 |
if (!noaction && vint(INTERP)) /* create dummy frames */
| 658 |
for (i = first; i <= last; i++)
| 659 |
if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
| 660 |
sprintf(combuf, vval(BASENAME), i);
| 661 |
strcat(combuf, ".unf");
| 662 |
close(open(combuf, O_RDONLY|O_CREAT, 0666));
| 663 |
| 664 |
/* create command */
| 665 |
sprintf(combuf, "rpict%s -w0", rendopt);
| 666 |
if (vint(INTERP) || atoi(vval(MBLUR)))
| 667 |
sprintf(combuf+strlen(combuf), " -z %s.zbf", vval(BASENAME));
| 668 |
sprintf(combuf+strlen(combuf), " -o %s.unf %s -S %d",
| 669 |
vval(BASENAME), rresopt, first);
| 670 |
inspoint = combuf + strlen(combuf);
| 671 |
sprintf(inspoint, " %s < %s", vval(OCTREE), vfn);
| 672 |
/* run in parallel */
| 673 |
i = (last-first+1)/(vint(INTERP)+1);
| 674 |
if (i < 1) i = 1;
| 675 |
if (pruncom(combuf, inspoint, i)) {
| 676 |
fprintf(stderr, "%s: error rendering frames %d through %d\n",
| 677 |
progname, first, last);
| 678 |
quit(1);
| 679 |
| 680 |
if (!noaction && vint(INTERP)) /* remove dummy frames */
| 681 |
| 682 |
| 683 |
| 684 |
| 685 |
unlink(combuf);
| 686 |
| 687 |
| 688 |
| 689 |
| 690 |
int
| 691 |
recover(frame) /* recover the specified frame */
| 692 |
int frame;
| 693 |
| 694 |
static int *rfrm; /* list of recovered frames */
| 695 |
static int nrfrms = 0;
| 696 |
char combuf[2048];
| 697 |
char fname[128];
| 698 |
register char *cp;
| 699 |
register int i;
| 700 |
/* check to see if recovered already */
| 701 |
for (i = nrfrms; i--; )
| 702 |
if (rfrm[i] == frame)
| 703 |
return(0);
| 704 |
/* build command */
| 705 |
| 706 |
if (vdef(ANIMATE))
| 707 |
sprintf(combuf, "%s %d | rpict%s -w0",
| 708 |
vval(ANIMATE), frame, rendopt);
| 709 |
else
| 710 |
| 711 |
| 712 |
if (vint(INTERP) || atoi(vval(MBLUR))) {
| 713 |
sprintf(cp, " -z %s.zbf", fname);
| 714 |
while (*cp) cp++;
| 715 |
| 716 |
sprintf(cp, " -ro %s.unf", fname);
| 717 |
while (*cp) cp++;
| 718 |
| 719 |
*cp++ = ' ';
| 720 |
strcpy(cp, vval(OCTREE));
| 721 |
| 722 |
if (runcom(combuf)) /* run command */
| 723 |
return(1);
| 724 |
/* add frame to recovered list */
| 725 |
if (nrfrms)
| 726 |
rfrm = (int *)realloc((char *)rfrm, (nrfrms+1)*sizeof(int));
| 727 |
else
| 728 |
rfrm = (int *)malloc(sizeof(int));
| 729 |
if (rfrm == NULL) {
| 730 |
perror("malloc");
| 731 |
quit(1);
| 732 |
| 733 |
rfrm[nrfrms++] = frame;
| 734 |
return(0);
| 735 |
| 736 |
| 737 |
| 738 |
int
| 739 |
frecover(frame) /* recover filtered frame */
| 740 |
int frame;
| 741 |
| 742 |
VIEW *vp;
| 743 |
char *ex;
| 744 |
| 745 |
vp = getview(frame);
| 746 |
ex = getexp(frame);
| 747 |
if (dofilt(frame, vp, ex, 2) && dofilt(frame, vp, ex, 1))
| 748 |
return(1);
| 749 |
return(0);
| 750 |
| 751 |
| 752 |
| 753 |
archive() /* archive and remove renderings */
| 754 |
| 755 |
#define RMCOML (sizeof(rmcom)-1)
| 756 |
static char rmcom[] = "rm -f";
| 757 |
register int i;
| 758 |
| 759 |
if (arcnext == arcfirst)
| 760 |
return; /* nothing to do */
| 761 |
if (vdef(ARCHIVE)) { /* run archive command */
| 762 |
| 763 |
strncpy(arcfirst-i, vval(ARCHIVE), i);
| 764 |
if (runcom(arcfirst-i)) {
| 765 |
fprintf(stderr, "%s: error running archive command\n",
| 766 |
progname);
| 767 |
quit(1);
| 768 |
| 769 |
| 770 |
/* run remove command */
| 771 |
strncpy(arcfirst-RMCOML, rmcom, RMCOML);
| 772 |
runcom(arcfirst-RMCOML);
| 773 |
arcnext = arcfirst; /* reset argument list */
| 774 |
#undef RMCOML
| 775 |
| 776 |
| 777 |
| 778 |
int
| 779 |
dofilt(frame, vp, ep, rvr) /* filter frame */
| 780 |
int frame;
| 781 |
VIEW *vp;
| 782 |
char *ep;
| 783 |
int rvr;
| 784 |
| 785 |
extern int frecover();
| 786 |
static int iter = 0;
| 787 |
char fnbefore[128], fnafter[128];
| 788 |
char combuf[1024], fname0[128], fname1[128];
| 789 |
int usepinterp, usepfilt, nora_rgbe;
| 790 |
int frseq[2];
| 791 |
/* check what is needed */
| 792 |
usepinterp = atoi(vval(MBLUR));
| 793 |
usepfilt = pfiltalways | ep==NULL;
| 794 |
if (ep != NULL && !strcmp(ep, "1"))
| 795 |
ep = "+0";
| 796 |
nora_rgbe = strcmp(vval(OVERSAMP),"1") || ep==NULL ||
| 797 |
*ep != '+' || *ep != '-' || !isint(ep);
| 798 |
/* compute rendered views */
| 799 |
frseq[0] = frame - ((frame-1) % (vint(INTERP)+1));
| 800 |
frseq[1] = frseq[0] + vint(INTERP) + 1;
| 801 |
if (frseq[1] > vint(END))
| 802 |
frseq[1] = vint(END);
| 803 |
if (frseq[1] == frame) { /* pfilt only */
| 804 |
frseq[0] = frseq[1];
| 805 |
usepinterp = 0; /* update what's needed */
| 806 |
usepfilt |= nora_rgbe;
| 807 |
} else if (frseq[0] == frame) { /* no interpolation needed */
| 808 |
if (!rvr && frame > 1+vint(INTERP)) { /* archive previous */
| 809 |
*arcnext++ = ' ';
| 810 |
sprintf(arcnext, vval(BASENAME), frame-vint(INTERP)-1);
| 811 |
while (*arcnext) arcnext++;
| 812 |
strcpy(arcnext, ".unf");
| 813 |
arcnext += 4;
| 814 |
if (usepinterp || vint(INTERP)) { /* and z-buf */
| 815 |
*arcnext++ = ' ';
| 816 |
| 817 |
| 818 |
| 819 |
strcpy(arcnext, ".zbf");
| 820 |
arcnext += 4;
| 821 |
| 822 |
| 823 |
if (!usepinterp) /* update what's needed */
| 824 |
| 825 |
} else /* interpolation needed */
| 826 |
usepinterp++;
| 827 |
if (frseq[1] >= astat.rnext) /* next batch unavailable */
| 828 |
frseq[1] = frseq[0];
| 829 |
sprintf(fnbefore, vval(BASENAME), frseq[0]);
| 830 |
sprintf(fnafter, vval(BASENAME), frseq[1]);
| 831 |
if (rvr == 1 && recover(frseq[0])) /* recover before frame? */
| 832 |
return(1);
| 833 |
/* generate command */
| 834 |
if (usepinterp) { /* using pinterp */
| 835 |
if (rvr == 2 && recover(frseq[1])) /* recover after? */
| 836 |
return(1);
| 837 |
| 838 |
FILE *fp; /* motion blurring */
| 839 |
sprintf(fname0, "%s/vw0%c", vval(DIRECTORY),
| 840 |
'a'+(iter%26));
| 841 |
if ((fp = fopen(fname0, "w")) == NULL) {
| 842 |
perror(fname0); quit(1);
| 843 |
| 844 |
fputs(VIEWSTR, fp);
| 845 |
fprintview(vp, fp);
| 846 |
putc('\n', fp); fclose(fp);
| 847 |
if ((vp = getview(frame+1)) == NULL) {
| 848 |
fprintf(stderr,
| 849 |
| 850 |
progname, frame+1);
| 851 |
quit(1);
| 852 |
| 853 |
sprintf(fname1, "%s/vw1%c", vval(DIRECTORY),
| 854 |
'a'+(iter%26));
| 855 |
if ((fp = fopen(fname1, "w")) == NULL) {
| 856 |
perror(fname1); quit(1);
| 857 |
| 858 |
fputs(VIEWSTR, fp);
| 859 |
fprintview(vp, fp);
| 860 |
| 861 |
sprintf(combuf,
| 862 |
"(pmblur %s %d %s %s; rm -f %s %s) | pinterp -B",
| 863 |
*sskip(vval(MBLUR)) ? sskip2(vval(MBLUR),1) : "1",
| 864 |
atoi(vval(MBLUR)),
| 865 |
fname0, fname1, fname0, fname1);
| 866 |
iter++;
| 867 |
} else /* no blurring */
| 868 |
strcpy(combuf, "pinterp");
| 869 |
strcat(combuf, viewopt(vp));
| 870 |
if (vbool(RTRACE))
| 871 |
sprintf(combuf+strlen(combuf), " -ff -fr '%s -w0 %s'",
| 872 |
rendopt, vval(OCTREE));
| 873 |
if (vdef(PINTERP))
| 874 |
sprintf(combuf+strlen(combuf), " %s", vval(PINTERP));
| 875 |
if (usepfilt)
| 876 |
sprintf(combuf+strlen(combuf), " %s", rresopt);
| 877 |
else
| 878 |
sprintf(combuf+strlen(combuf), " %s -e %s",
| 879 |
fresopt, ep);
| 880 |
sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
| 881 |
fnbefore, fnbefore);
| 882 |
if (frseq[1] != frseq[0])
| 883 |
| 884 |
fnafter, fnafter);
| 885 |
if (usepfilt) { /* also pfilt */
| 886 |
if (vdef(PFILT))
| 887 |
sprintf(combuf+strlen(combuf), " | pfilt %s",
| 888 |
vval(PFILT));
| 889 |
else
| 890 |
strcat(combuf, " | pfilt");
| 891 |
if (ep != NULL)
| 892 |
sprintf(combuf+strlen(combuf), " -1 -e %s %s",
| 893 |
ep, fresopt);
| 894 |
else
| 895 |
sprintf(combuf+strlen(combuf), " %s", fresopt);
| 896 |
| 897 |
} else if (usepfilt) { /* pfilt only */
| 898 |
if (rvr == 2)
| 899 |
return(1);
| 900 |
if (vdef(PFILT))
| 901 |
sprintf(combuf, "pfilt %s", vval(PFILT));
| 902 |
else
| 903 |
strcpy(combuf, "pfilt");
| 904 |
if (ep != NULL)
| 905 |
sprintf(combuf+strlen(combuf), " -1 -e %s %s %s.unf",
| 906 |
ep, fresopt, fnbefore);
| 907 |
else
| 908 |
sprintf(combuf+strlen(combuf), " %s %s.unf",
| 909 |
fresopt, fnbefore);
| 910 |
} else { /* else just check it */
| 911 |
if (rvr == 2)
| 912 |
return(1);
| 913 |
sprintf(combuf, "ra_rgbe -e %s -r %s.unf", ep, fnbefore);
| 914 |
| 915 |
/* output file name */
| 916 |
sprintf(fname0, vval(BASENAME), frame);
| 917 |
sprintf(combuf+strlen(combuf), " > %s.pic", fname0);
| 918 |
if (rvr) /* in recovery */
| 919 |
return(runcom(combuf));
| 920 |
bruncom(combuf, frame, frecover); /* else run in background */
| 921 |
return(0);
| 922 |
| 923 |
| 924 |
| 925 |
VIEW *
| 926 |
getview(n) /* get view number n */
| 927 |
int n;
| 928 |
| 929 |
static FILE *viewfp = NULL; /* view file pointer */
| 930 |
static int viewnum = 0; /* current view number */
| 931 |
static VIEW curview = STDVIEW; /* current view */
| 932 |
char linebuf[256];
| 933 |
| 934 |
if (n == 0) { /* signal to close file and clean up */
| 935 |
if (viewfp != NULL) {
| 936 |
fclose(viewfp);
| 937 |
viewfp = NULL;
| 938 |
viewnum = 0;
| 939 |
copystruct(&curview, &stdview);
| 940 |
| 941 |
return(NULL);
| 942 |
| 943 |
if (viewfp == NULL) { /* open file */
| 944 |
if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) {
| 945 |
perror(vval(VIEWFILE));
| 946 |
quit(1);
| 947 |
| 948 |
} else if (n < viewnum) { /* rewind file */
| 949 |
if (fseek(viewfp, 0L, 0) == EOF) {
| 950 |
| 951 |
quit(1);
| 952 |
| 953 |
| 954 |
viewnum = 0;
| 955 |
| 956 |
while (n > viewnum) { /* scan to desired view */
| 957 |
if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL)
| 958 |
return(NULL);
| 959 |
if (isview(linebuf) && sscanview(&curview, linebuf) > 0)
| 960 |
viewnum++;
| 961 |
| 962 |
return(&curview); /* return it */
| 963 |
| 964 |
| 965 |
| 966 |
int
| 967 |
countviews() /* count views in view file */
| 968 |
| 969 |
register int n = 0;
| 970 |
| 971 |
while (getview(n+1) != NULL)
| 972 |
n++;
| 973 |
return(n);
| 974 |
| 975 |
| 976 |
| 977 |
char *
| 978 |
getexp(n) /* get exposure for nth frame */
| 979 |
int n;
| 980 |
| 981 |
extern char *fskip();
| 982 |
static char expval[32];
| 983 |
static FILE *expfp = NULL;
| 984 |
static long *exppos;
| 985 |
static int curfrm;
| 986 |
register char *cp;
| 987 |
| 988 |
if (n == 0) { /* signal to close file */
| 989 |
if (expfp != NULL) {
| 990 |
fclose(expfp);
| 991 |
expfp = NULL;
| 992 |
| 993 |
return(NULL);
| 994 |
| 995 |
if (!vdef(EXPOSURE)) /* no setting (auto) */
| 996 |
return(NULL);
| 997 |
if (isflt(vval(EXPOSURE))) /* always the same */
| 998 |
return(vval(EXPOSURE));
| 999 |
if (expfp == NULL) { /* open exposure file */
| 1000 |
if ((expfp = fopen(vval(EXPOSURE), "r")) == NULL) {
| 1001 |
fprintf(stderr,
| 1002 |
"%s: cannot open exposure file \"%s\"\n",
| 1003 |
progname, vval(EXPOSURE));
| 1004 |
quit(1);
| 1005 |
| 1006 |
curfrm = vint(END) + 1; /* init lookup tab. */
| 1007 |
exppos = (long *)malloc(curfrm*sizeof(long *));
| 1008 |
if (exppos == NULL) {
| 1009 |
perror(progname);
| 1010 |
quit(1);
| 1011 |
| 1012 |
while (curfrm--)
| 1013 |
exppos[curfrm] = -1L;
| 1014 |
curfrm = 0;
| 1015 |
| 1016 |
/* find position in file */
| 1017 |
if (n-1 != curfrm && n != curfrm && exppos[n-1] >= 0 &&
| 1018 |
fseek(expfp, exppos[curfrm=n-1], 0) == EOF) {
| 1019 |
fprintf(stderr, "%s: seek error on exposure file\n", progname);
| 1020 |
quit(1);
| 1021 |
| 1022 |
while (n > curfrm) { /* read exposure */
| 1023 |
if (exppos[curfrm] < 0)
| 1024 |
exppos[curfrm] = ftell(expfp);
| 1025 |
if (fgets(expval, sizeof(expval), expfp) == NULL) {
| 1026 |
fprintf(stderr, "%s: too few exposures\n",
| 1027 |
vval(EXPOSURE));
| 1028 |
quit(1);
| 1029 |
| 1030 |
curfrm++;
| 1031 |
cp = fskip(expval); /* check format */
| 1032 |
if (cp == NULL || *cp != '\n') {
| 1033 |
fprintf(stderr,
| 1034 |
"%s: exposure format error on line %d\n",
| 1035 |
vval(EXPOSURE), curfrm);
| 1036 |
quit(1);
| 1037 |
| 1038 |
*cp = '\0';
| 1039 |
| 1040 |
return(expval); /* return value */
| 1041 |
| 1042 |
| 1043 |
| 1044 |
struct pslot *
| 1045 |
findpslot(pid) /* find or allocate a process slot */
| 1046 |
int pid;
| 1047 |
| 1048 |
register struct pslot *psempty = NULL;
| 1049 |
register int i;
| 1050 |
| 1051 |
for (i = 0; i < npslots; i++) { /* look for match */
| 1052 |
if (pslot[i].pid == pid)
| 1053 |
return(pslot+i);
| 1054 |
if (psempty == NULL && pslot[i].pid == 0)
| 1055 |
psempty = pslot+i;
| 1056 |
| 1057 |
return(psempty); /* return emtpy slot (error if NULL) */
| 1058 |
| 1059 |
| 1060 |
| 1061 |
int
| 1062 |
donecom(ps, pn, status) /* clean up after finished process */
| 1063 |
PSERVER *ps;
| 1064 |
int pn;
| 1065 |
int status;
| 1066 |
| 1067 |
register PROC *pp;
| 1068 |
| 1069 |
pp = ps->proc + pn;
| 1070 |
if (pp->elen) { /* pass errors */
| 1071 |
if (ps->hostname[0])
| 1072 |
fprintf(stderr, "%s: ", ps->hostname);
| 1073 |
fprintf(stderr, "Error output from: %s\n", pp->com);
| 1074 |
fputs(pp->errs, stderr);
| 1075 |
fflush(stderr);
| 1076 |
| 1077 |
status = 1; /* because rsh doesn't return status */
| 1078 |
| 1079 |
freestr(pp->com); /* free command string */
| 1080 |
lastpid = pp->pid; /* record PID for bwait() */
| 1081 |
lastpserver = ps; /* record server for serverdown() */
| 1082 |
return(status);
| 1083 |
| 1084 |
| 1085 |
| 1086 |
int
| 1087 |
serverdown() /* check status of last process server */
| 1088 |
| 1089 |
if (pserverOK(lastpserver)) /* server still up? */
| 1090 |
return(0);
| 1091 |
delpserver(lastpserver); /* else delete it */
| 1092 |
if (pslist == NULL) {
| 1093 |
fprintf(stderr, "%s: all process servers are down\n",
| 1094 |
progname);
| 1095 |
quit(1);
| 1096 |
| 1097 |
return(1);
| 1098 |
| 1099 |
| 1100 |
| 1101 |
int
| 1102 |
bruncom(com, fout, rf) /* run a command in the background */
| 1103 |
char *com;
| 1104 |
int fout;
| 1105 |
int (*rf)();
| 1106 |
| 1107 |
int pid;
| 1108 |
register struct pslot *psl;
| 1109 |
| 1110 |
if (noaction) {
| 1111 |
if (!silent)
| 1112 |
printf("\t%s\n", com); /* echo command */
| 1113 |
return(0);
| 1114 |
| 1115 |
/* else start it when we can */
| 1116 |
while ((pid = startjob(NULL, savestr(com), donecom)) == -1)
| 1117 |
bwait(1);
| 1118 |
if (!silent) { /* echo command */
| 1119 |
PSERVER *ps;
| 1120 |
int psn = pid;
| 1121 |
ps = findjob(&psn);
| 1122 |
| 1123 |
printf("\tProcess started on %s\n", phostname(ps));
| 1124 |
fflush(stdout);
| 1125 |
| 1126 |
psl = findpslot(pid); /* record info. in appropriate slot */
| 1127 |
psl->pid = pid;
| 1128 |
psl->fout = fout;
| 1129 |
psl->rcvf = rf;
| 1130 |
return(pid);
| 1131 |
| 1132 |
| 1133 |
| 1134 |
bwait(ncoms) /* wait for batch job(s) to finish */
| 1135 |
int ncoms;
| 1136 |
| 1137 |
int status;
| 1138 |
| 1139 |
| 1140 |
if (noaction)
| 1141 |
return;
| 1142 |
while ((status = wait4job(NULL, -1)) != -1) {
| 1143 |
psl = findpslot(lastpid);
| 1144 |
if (status) { /* attempt recovery */
| 1145 |
serverdown(); /* check server */
| 1146 |
if (psl->rcvf == NULL || (*psl->rcvf)(psl->fout)) {
| 1147 |
fprintf(stderr,
| 1148 |
"%s: error rendering frame %d\n",
| 1149 |
progname, psl->fout);
| 1150 |
quit(1);
| 1151 |
| 1152 |
| 1153 |
psl->pid = 0; /* free process slot */
| 1154 |
if (!--ncoms)
| 1155 |
return; /* done enough */
| 1156 |
| 1157 |
| 1158 |
| 1159 |
| 1160 |
int
| 1161 |
pruncom(com, ppins, maxcopies) /* run a command in parallel over network */
| 1162 |
char *com, *ppins;
| 1163 |
int maxcopies;
| 1164 |
| 1165 |
int retstatus = 0;
| 1166 |
int hostcopies;
| 1167 |
char com1buf[10240], *com1, *endcom1;
| 1168 |
int status;
| 1169 |
register PSERVER *ps;
| 1170 |
| 1171 |
if (!silent)
| 1172 |
| 1173 |
if (noaction)
| 1174 |
return(0);
| 1175 |
fflush(stdout);
| 1176 |
/* start jobs on each server */
| 1177 |
for (ps = pslist; ps != NULL; ps = ps->next) {
| 1178 |
hostcopies = 0;
| 1179 |
if (maxcopies > 1 && ps->nprocs > 1 && ppins != NULL) {
| 1180 |
strcpy(com1=com1buf, com); /* build -PP command */
| 1181 |
sprintf(com1+(ppins-com), " -PP %s/%s.persist",
| 1182 |
vval(DIRECTORY), phostname(ps));
| 1183 |
strcat(com1, ppins);
| 1184 |
endcom1 = com1 + strlen(com1);
| 1185 |
sprintf(endcom1, "; kill `sed -n '1s/^[^ ]* //p' %s/%s.persist`",
| 1186 |
| 1187 |
} else {
| 1188 |
com1 = com;
| 1189 |
endcom1 = NULL;
| 1190 |
| 1191 |
while (maxcopies > 0 &&
| 1192 |
startjob(ps, savestr(com1), donecom) != -1) {
| 1193 |
sleep(10);
| 1194 |
hostcopies++;
| 1195 |
maxcopies--;
| 1196 |
if (endcom1 != NULL)
| 1197 |
*endcom1 = '\0';
| 1198 |
| 1199 |
if (!silent && hostcopies) {
| 1200 |
if (hostcopies > 1)
| 1201 |
printf("\t%d duplicate processes", hostcopies);
| 1202 |
else
| 1203 |
printf("\tProcess");
| 1204 |
printf(" started on %s\n", phostname(ps));
| 1205 |
fflush(stdout);
| 1206 |
| 1207 |
| 1208 |
/* wait for jobs to finish */
| 1209 |
| 1210 |
if (status)
| 1211 |
retstatus += !serverdown(); /* check server */
| 1212 |
return(retstatus);
| 1213 |
| 1214 |
| 1215 |
| 1216 |
runcom(cs) /* run a command locally and wait for it */
| 1217 |
char *cs;
| 1218 |
| 1219 |
if (!silent) /* echo it */
| 1220 |
printf("\t%s\n", cs);
| 1221 |
if (noaction)
| 1222 |
return(0);
| 1223 |
fflush(stdout); /* flush output and pass to shell */
| 1224 |
return(system(cs));
| 1225 |
| 1226 |
| 1227 |
| 1228 |
rmfile(fn) /* remove a file */
| 1229 |
char *fn;
| 1230 |
| 1231 |
if (!silent)
| 1232 |
#ifdef MSDOS
| 1233 |
printf("\tdel %s\n", fn);
| 1234 |
#else
| 1235 |
printf("\trm -f %s\n", fn);
| 1236 |
#endif
| 1237 |
if (noaction)
| 1238 |
return(0);
| 1239 |
return(unlink(fn));
| 1240 |
| 1241 |
| 1242 |
| 1243 |
badvalue(vc) /* report bad variable value and exit */
| 1244 |
int vc;
| 1245 |
| 1246 |
fprintf(stderr, "%s: bad value for variable '%s'\n",
| 1247 |
progname, vnam(vc));
| 1248 |
quit(1);
| 1249 |
