root/radiance/ray/src/util/ranimate.c
Revision: 2.22
Committed: Thu Mar 20 14:53:17 1997 UTC (28 years, 1 month ago) by greg
added call to check variable assignments
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Radiance animation control program
9 */
10
11 #include "standard.h"
12 #include <ctype.h>
13 #include <sys/types.h>
14 #include <sys/stat.h>
15 #include "view.h"
16 #include "vars.h"
17 #include "netproc.h"
18 /* default remote shell */
19 #ifdef _AUX_SOURCE
20 #define REMSH "remsh"
21 #else
22 #define REMSH "rsh"
23 #endif
24 /* input variables */
25 #define HOST 0 /* rendering host machine */
26 #define RENDER 1 /* rendering options */
27 #define PFILT 2 /* pfilt options */
28 #define PINTERP 3 /* pinterp options */
29 #define OCTREE 4 /* octree file name */
30 #define DIRECTORY 5 /* working (sub)directory */
31 #define BASENAME 6 /* output image base name */
32 #define VIEWFILE 7 /* animation frame views */
33 #define START 8 /* starting frame number */
34 #define END 9 /* ending frame number */
35 #define RIF 10 /* rad input file */
36 #define NEXTANIM 11 /* next animation file */
37 #define ANIMATE 12 /* animation command */
38 #define TRANSFER 13 /* frame transfer command */
39 #define ARCHIVE 14 /* archiving command */
40 #define INTERP 15 /* # frames to interpolate */
41 #define OVERSAMP 16 /* # times to oversample image */
42 #define MBLUR 17 /* samples for motion blur */
43 #define RTRACE 18 /* use rtrace with pinterp? */
44 #define DISKSPACE 19 /* how much disk space to use */
45 #define RESOLUTION 20 /* desired final resolution */
46 #define EXPOSURE 21 /* how to compute exposure */
47 #define RSH 22 /* remote shell script or program */
48
49 int NVARS = 23; /* total number of variables */
50
51 VARIABLE vv[] = { /* variable-value pairs */
52 {"host", 4, 0, NULL, NULL},
53 {"render", 3, 0, NULL, catvalues},
54 {"pfilt", 2, 0, NULL, catvalues},
55 {"pinterp", 2, 0, NULL, catvalues},
56 {"OCTREE", 3, 0, NULL, onevalue},
57 {"DIRECTORY", 3, 0, NULL, onevalue},
58 {"BASENAME", 3, 0, NULL, onevalue},
59 {"VIEWFILE", 2, 0, NULL, onevalue},
60 {"START", 2, 0, NULL, intvalue},
61 {"END", 2, 0, NULL, intvalue},
62 {"RIF", 3, 0, NULL, onevalue},
63 {"NEXTANIM", 3, 0, NULL, onevalue},
64 {"ANIMATE", 2, 0, NULL, onevalue},
65 {"TRANSFER", 2, 0, NULL, onevalue},
66 {"ARCHIVE", 2, 0, NULL, onevalue},
67 {"INTERPOLATE", 3, 0, NULL, intvalue},
68 {"OVERSAMPLE", 2, 0, NULL, fltvalue},
69 {"MBLUR", 2, 0, NULL, onevalue},
70 {"RTRACE", 2, 0, NULL, boolvalue},
71 {"DISKSPACE", 3, 0, NULL, fltvalue},
72 {"RESOLUTION", 3, 0, NULL, onevalue},
73 {"EXPOSURE", 3, 0, NULL, onevalue},
74 {"RSH", 3, 0, NULL, onevalue},
75 };
76
77 #define SFNAME "STATUS" /* status file name */
78
79 struct {
80 char host[64]; /* control host name */
81 int pid; /* control process id */
82 char cfname[128]; /* control file name */
83 int rnext; /* next frame to render */
84 int fnext; /* next frame to filter */
85 int tnext; /* next frame to transfer */
86 } astat; /* animation status */
87
88 char *progname; /* our program name */
89 char *cfname; /* our control file name */
90
91 int nowarn = 0; /* turn warnings off? */
92 int silent = 0; /* silent mode? */
93 int noaction = 0; /* take no action? */
94
95 char *remsh; /* remote shell program/script */
96 char rendopt[2048]; /* rendering options */
97 char rresopt[32]; /* rendering resolution options */
98 char fresopt[32]; /* filter resolution options */
99 int pfiltalways; /* always use pfilt? */
100
101 char arcargs[10240]; /* files to archive */
102 char *arcfirst, *arcnext; /* pointers to first and next argument */
103
104 struct pslot {
105 int pid; /* process ID (0 if empty) */
106 int fout; /* output frame number */
107 int (*rcvf)(); /* recover function */
108 } *pslot; /* process slots */
109 int npslots; /* number of process slots */
110
111 #define phostname(ps) ((ps)->hostname[0] ? (ps)->hostname : astat.host)
112
113 struct pslot *findpslot();
114
115 PSERVER *lastpserver; /* last process server with error */
116
117 VIEW *getview();
118 char *getexp();
119
120 extern time_t fdate(), time();
121
122
123 main(argc, argv)
124 int argc;
125 char *argv[];
126 {
127 int explicate = 0;
128 int i;
129
130 progname = argv[0]; /* get arguments */
131 for (i = 1; i < argc && argv[i][0] == '-'; i++)
132 switch (argv[i][1]) {
133 case 'e': /* print variables */
134 explicate++;
135 break;
136 case 'w': /* turn off warnings */
137 nowarn++;
138 break;
139 case 's': /* silent mode */
140 silent++;
141 break;
142 case 'n': /* take no action */
143 noaction++;
144 break;
145 default:
146 goto userr;
147 }
148 if (i != argc-1)
149 goto userr;
150 cfname = argv[i];
151 /* load variables */
152 loadvars(cfname);
153 /* check variables */
154 checkvalues();
155 /* did we get DIRECTORY? */
156 checkdir();
157 /* check status */
158 if (getastat() < 0) {
159 fprintf(stderr, "%s: exiting\n", progname);
160 quit(1);
161 }
162 /* pfilt always if options given */
163 pfiltalways = vdef(PFILT);
164 /* load RIF if any */
165 if (vdef(RIF))
166 getradfile(vval(RIF));
167 /* set defaults */
168 setdefaults();
169 /* print variables */
170 if (explicate)
171 printvars(stdout);
172 /* set up process servers */
173 sethosts();
174 /* run animation */
175 animate();
176 /* all done */
177 if (vdef(NEXTANIM)) {
178 argv[i] = vval(NEXTANIM); /* just change input file */
179 if (!silent)
180 printargs(argc, argv, stdout);
181 if ((argv[0] = getpath(progname,getenv("PATH"),X_OK)) == NULL)
182 fprintf(stderr, "%s: command not found\n", progname);
183 else
184 execv(progname, argv);
185 quit(1);
186 }
187 quit(0);
188 userr:
189 fprintf(stderr, "Usage: %s [-s][-n][-w][-e] anim_file\n", progname);
190 quit(1);
191 }
192
193
194 getastat() /* check/set animation status */
195 {
196 char sfname[256];
197 FILE *fp;
198
199 sprintf(sfname, "%s/%s", vval(DIRECTORY), SFNAME);
200 if ((fp = fopen(sfname, "r")) == NULL) {
201 if (errno != ENOENT) {
202 perror(sfname);
203 return(-1);
204 }
205 astat.rnext = astat.fnext = astat.tnext = 0;
206 goto setours;
207 }
208 if (fscanf(fp, "Control host: %s\n", astat.host) != 1)
209 goto fmterr;
210 if (fscanf(fp, "Control PID: %d\n", &astat.pid) != 1)
211 goto fmterr;
212 if (fscanf(fp, "Control file: %s\n", astat.cfname) != 1)
213 goto fmterr;
214 if (fscanf(fp, "Next render: %d\n", &astat.rnext) != 1)
215 goto fmterr;
216 if (fscanf(fp, "Next filter: %d\n", &astat.fnext) != 1)
217 goto fmterr;
218 if (fscanf(fp, "Next transfer: %d\n", &astat.tnext) != 1)
219 goto fmterr;
220 fclose(fp);
221 if (astat.pid != 0) { /* thinks it's still running */
222 if (strcmp(myhostname(), astat.host)) {
223 fprintf(stderr,
224 "%s: process %d may still be running on host %s\n",
225 progname, astat.pid, astat.host);
226 return(-1);
227 }
228 if (kill(astat.pid, 0) != -1 || errno != ESRCH) {
229 fprintf(stderr, "%s: process %d is still running\n",
230 progname, astat.pid);
231 return(-1);
232 }
233 /* assume it is dead */
234 }
235 if (strcmp(cfname, astat.cfname) && astat.pid != 0) { /* other's */
236 fprintf(stderr, "%s: unfinished job \"%s\"\n",
237 progname, astat.cfname);
238 return(-1);
239 }
240 /* check control file mods. */
241 if (!nowarn && fdate(cfname) > fdate(sfname))
242 fprintf(stderr,
243 "%s: warning - control file modified since last run\n",
244 progname);
245 setours: /* set our values */
246 strcpy(astat.host, myhostname());
247 astat.pid = getpid();
248 strcpy(astat.cfname, cfname);
249 return(0);
250 fmterr:
251 fprintf(stderr, "%s: format error in status file \"%s\"\n",
252 progname, sfname);
253 fclose(fp);
254 return(-1);
255 }
256
257
258 putastat() /* put out current status */
259 {
260 char buf[256];
261 FILE *fp;
262
263 if (noaction)
264 return;
265 sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME);
266 if ((fp = fopen(buf, "w")) == NULL) {
267 perror(buf);
268 quit(1);
269 }
270 fprintf(fp, "Control host: %s\n", astat.host);
271 fprintf(fp, "Control PID: %d\n", astat.pid);
272 fprintf(fp, "Control file: %s\n", astat.cfname);
273 fprintf(fp, "Next render: %d\n", astat.rnext);
274 fprintf(fp, "Next filter: %d\n", astat.fnext);
275 fprintf(fp, "Next transfer: %d\n", astat.tnext);
276 fclose(fp);
277 }
278
279
280 checkdir() /* make sure we have our directory */
281 {
282 struct stat stb;
283
284 if (!vdef(DIRECTORY)) {
285 fprintf(stderr, "%s: %s undefined\n",
286 progname, vnam(DIRECTORY));
287 quit(1);
288 }
289 if (stat(vval(DIRECTORY), &stb) == -1) {
290 if (errno == ENOENT && mkdir(vval(DIRECTORY), 0777) == 0)
291 return;
292 perror(vval(DIRECTORY));
293 quit(1);
294 }
295 if (!(stb.st_mode & S_IFDIR)) {
296 fprintf(stderr, "%s: not a directory\n", vval(DIRECTORY));
297 quit(1);
298 }
299 }
300
301
302 setdefaults() /* set default values */
303 {
304 extern char *atos();
305 int decades;
306 char buf[256];
307
308 if (vdef(ANIMATE)) {
309 vval(OCTREE) = NULL;
310 vdef(OCTREE) = 0;
311 } else if (!vdef(OCTREE)) {
312 fprintf(stderr, "%s: either %s or %s must be defined\n",
313 progname, vnam(OCTREE), vnam(ANIMATE));
314 quit(1);
315 }
316 if (!vdef(VIEWFILE)) {
317 fprintf(stderr, "%s: %s undefined\n", progname, vnam(VIEWFILE));
318 quit(1);
319 }
320 if (!vdef(HOST)) {
321 vval(HOST) = LHOSTNAME;
322 vdef(HOST)++;
323 }
324 if (!vdef(START)) {
325 vval(START) = "1";
326 vdef(START)++;
327 }
328 if (!vdef(END)) {
329 sprintf(buf, "%d", countviews()+vint(START)-1);
330 vval(END) = savqstr(buf);
331 vdef(END)++;
332 }
333 if (vint(END) < vint(START)) {
334 fprintf(stderr, "%s: ending frame less than starting frame\n",
335 progname);
336 quit(1);
337 }
338 if (!vdef(BASENAME)) {
339 decades = (int)log10((double)vint(END)) + 1;
340 if (decades < 3) decades = 3;
341 sprintf(buf, "%s/frame%%0%dd", vval(DIRECTORY), decades);
342 vval(BASENAME) = savqstr(buf);
343 vdef(BASENAME)++;
344 }
345 if (!vdef(RESOLUTION)) {
346 vval(RESOLUTION) = "640";
347 vdef(RESOLUTION)++;
348 }
349 if (!vdef(OVERSAMP)) {
350 vval(OVERSAMP) = "2";
351 vdef(OVERSAMP)++;
352 }
353 if (!vdef(INTERP)) {
354 vval(INTERP) = "0";
355 vdef(INTERP)++;
356 }
357 if (!vdef(MBLUR)) {
358 vval(MBLUR) = "0";
359 vdef(MBLUR)++;
360 }
361 if (!vdef(RTRACE)) {
362 vval(RTRACE) = "F";
363 vdef(RTRACE)++;
364 }
365 if (!vdef(DISKSPACE)) {
366 if (!nowarn)
367 fprintf(stderr,
368 "%s: warning - no %s setting, assuming 100 Mbytes available\n",
369 progname, vnam(DISKSPACE));
370 vval(DISKSPACE) = "100";
371 vdef(DISKSPACE)++;
372 }
373 if (!vdef(RSH)) {
374 vval(RSH) = REMSH;
375 vdef(RSH)++;
376 }
377 /* locate remote shell program */
378 atos(buf, sizeof(buf), vval(RSH));
379 if ((remsh = getpath(buf, getenv("PATH"), X_OK)) != NULL)
380 remsh = savqstr(remsh);
381 else
382 remsh = vval(RSH); /* will generate error if used */
383
384 /* append rendering options */
385 if (vdef(RENDER))
386 sprintf(rendopt+strlen(rendopt), " %s", vval(RENDER));
387 }
388
389
390 sethosts() /* set up process servers */
391 {
392 extern char *iskip();
393 char buf[256], *dir, *uname;
394 int np;
395 register char *cp;
396 int i;
397
398 npslots = 0;
399 if (noaction)
400 return;
401 for (i = 0; i < vdef(HOST); i++) { /* add each host */
402 dir = uname = NULL;
403 np = 1;
404 strcpy(cp=buf, nvalue(HOST, i)); /* copy to buffer */
405 cp = sskip(cp); /* skip host name */
406 while (isspace(*cp))
407 *cp++ = '\0';
408 if (*cp) { /* has # processes? */
409 np = atoi(cp);
410 if ((cp = iskip(cp)) == NULL || (*cp && !isspace(*cp)))
411 badvalue(HOST);
412 while (isspace(*cp))
413 cp++;
414 if (*cp) { /* has directory? */
415 dir = cp;
416 cp = sskip(cp); /* skip dir. */
417 while (isspace(*cp))
418 *cp++ = '\0';
419 if (*cp) { /* has user? */
420 uname = cp;
421 if (*sskip(cp))
422 badvalue(HOST);
423 }
424 }
425 }
426 if (addpserver(buf, dir, uname, np) == NULL) {
427 if (!nowarn)
428 fprintf(stderr,
429 "%s: cannot execute on host \"%s\"\n",
430 progname, buf);
431 } else
432 npslots += np;
433 }
434 if (npslots == 0) {
435 fprintf(stderr, "%s: no working process servers\n", progname);
436 quit(1);
437 }
438 pslot = (struct pslot *)calloc(npslots, sizeof(struct pslot));
439 if (pslot == NULL) {
440 perror("malloc");
441 quit(1);
442 }
443 }
444
445
446 getradfile(rfargs) /* run rad and get needed variables */
447 char *rfargs;
448 {
449 static short mvar[] = {OCTREE,PFILT,RESOLUTION,EXPOSURE,-1};
450 char combuf[256];
451 register int i;
452 register char *cp;
453 /* create rad command */
454 sprintf(rendopt, " @%s/render.opt", vval(DIRECTORY));
455 sprintf(combuf,
456 "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
457 rfargs, rendopt+2);
458 cp = combuf;
459 while (*cp) cp++; /* match unset variables */
460 for (i = 0; mvar[i] >= 0; i++)
461 if (!vdef(mvar[i])) {
462 *cp++ = '|';
463 strcpy(cp, vnam(mvar[i]));
464 while (*cp) cp++;
465 }
466 sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY));
467 cp += 11; /* point to file name */
468 if (system(combuf)) {
469 fprintf(stderr, "%s: error executing rad command:\n\t%s\n",
470 progname, combuf);
471 quit(1);
472 }
473 loadvars(cp); /* load variables and remove file */
474 unlink(cp);
475 }
476
477
478 animate() /* run animation */
479 {
480 int xres, yres;
481 float pa, mult;
482 int frames_batch;
483 register int i;
484 double d1, d2;
485 /* compute rpict resolution */
486 i = sscanf(vval(RESOLUTION), "%d %d %f", &xres, &yres, &pa);
487 mult = vflt(OVERSAMP);
488 if (i == 3) {
489 sprintf(rresopt, "-x %d -y %d -pa %.3f", (int)(mult*xres),
490 (int)(mult*yres), pa);
491 sprintf(fresopt, "-x %d -y %d -pa %.3f", xres, yres, pa);
492 } else if (i) {
493 if (i == 1) yres = xres;
494 sprintf(rresopt, "-x %d -y %d", (int)(mult*xres),
495 (int)(mult*yres));
496 sprintf(fresopt, "-x %d -y %d -pa 1", xres, yres);
497 } else
498 badvalue(RESOLUTION);
499 /* consistency checks */
500 if (vdef(ANIMATE)) {
501 if (vint(INTERP)) {
502 if (!nowarn)
503 fprintf(stderr,
504 "%s: resetting %s=0 for animation\n",
505 progname, vnam(INTERP));
506 vval(INTERP) = "0";
507 }
508 if (atoi(vval(MBLUR))) { /* can't handle this yet */
509 if (!nowarn)
510 fprintf(stderr,
511 "%s: resetting %s=0 for animation\n",
512 progname, vnam(MBLUR));
513 vval(MBLUR) = "0";
514 }
515 }
516 /* figure # frames per batch */
517 d1 = mult*xres*mult*yres*4; /* space for orig. picture */
518 if ((i=vint(INTERP)) || atoi(vval(MBLUR)))
519 d1 += mult*xres*mult*yres*sizeof(float); /* Z-buffer */
520 d2 = xres*yres*4; /* space for final picture */
521 frames_batch = (i+1)*(vflt(DISKSPACE)*1048576.-d1)/(d1+i*d2);
522 if (frames_batch < i+2) {
523 fprintf(stderr, "%s: insufficient disk space allocated\n",
524 progname);
525 quit(1);
526 }
527 /* initialize archive argument list */
528 i = 16;
529 if (vdef(ARCHIVE) && strlen(vval(ARCHIVE)) > i)
530 i = strlen(vval(ARCHIVE));
531 arcnext = arcfirst = arcargs + i;
532 /* initialize status file */
533 if (astat.rnext == 0)
534 astat.rnext = astat.fnext = astat.tnext = vint(START);
535 putastat();
536 /* render in batches */
537 while (astat.tnext <= vint(END)) {
538 renderframes(frames_batch);
539 filterframes();
540 transferframes();
541 }
542 /* mark status as finished */
543 astat.pid = 0;
544 putastat();
545 /* close open files */
546 getview(0);
547 getexp(0);
548 }
549
550
551 renderframes(nframes) /* render next nframes frames */
552 int nframes;
553 {
554 static char vendbuf[16];
555 VIEW *vp;
556 FILE *fp = NULL;
557 char vfname[128];
558 int lastframe;
559 register int i;
560
561 if (astat.tnext < astat.rnext) /* other work to do first */
562 return;
563 /* create batch view file */
564 if (!vdef(ANIMATE)) {
565 sprintf(vfname, "%s/anim.vf", vval(DIRECTORY));
566 if ((fp = fopen(vfname, "w")) == NULL) {
567 perror(vfname);
568 quit(1);
569 }
570 }
571 /* bound batch properly */
572 lastframe = astat.rnext + nframes - 1;
573 if ((lastframe-1) % (vint(INTERP)+1)) /* need even interval */
574 lastframe += vint(INTERP)+1 - ((lastframe-1)%(vint(INTERP)+1));
575 if (lastframe > vint(END)) /* check for end */
576 lastframe = vint(END);
577 /* render each view */
578 for (i = astat.rnext; i <= lastframe; i++) {
579 if ((vp = getview(i)) == NULL) {
580 if (!nowarn)
581 fprintf(stderr,
582 "%s: ran out of views before last frame\n",
583 progname);
584 sprintf(vval(END)=vendbuf, "%d", i-1);
585 lastframe = i - 1;
586 break;
587 }
588 if (vdef(ANIMATE)) /* animate frame */
589 animrend(i, vp);
590 else { /* else record it */
591 fputs(VIEWSTR, fp);
592 fprintview(vp, fp);
593 putc('\n', fp);
594 }
595 }
596 if (vdef(ANIMATE)) /* wait for renderings to finish */
597 bwait(0);
598 else { /* else if walk-through */
599 fclose(fp); /* close view file */
600 walkwait(astat.rnext, lastframe, vfname); /* walk it */
601 unlink(vfname); /* remove view file */
602 }
603 astat.rnext = i; /* update status */
604 putastat();
605 }
606
607
608 filterframes() /* catch up with filtering */
609 {
610 VIEW *vp;
611 register int i;
612
613 if (astat.tnext < astat.fnext) /* other work to do first */
614 return;
615 /* filter each view */
616 for (i = astat.fnext; i < astat.rnext; i++) {
617 if ((vp = getview(i)) == NULL) { /* get view i */
618 fprintf(stderr,
619 "%s: unexpected error reading view for frame %d\n",
620 progname, i);
621 quit(1);
622 }
623 dofilt(i, vp, getexp(i), 0); /* filter frame */
624 }
625 bwait(0); /* wait for filter processes */
626 archive(); /* archive originals */
627 astat.fnext = i; /* update status */
628 putastat();
629 }
630
631
632 transferframes() /* catch up with picture transfers */
633 {
634 char combuf[10240];
635 register char *cp;
636 register int i;
637
638 if (astat.tnext >= astat.fnext) /* nothing to do, yet */
639 return;
640 if (!vdef(TRANSFER)) { /* no transfer function -- leave 'em */
641 astat.tnext = astat.fnext;
642 putastat(); /* update status */
643 return;
644 }
645 strcpy(combuf, vval(TRANSFER)); /* start transfer command */
646 cp = combuf + strlen(combuf);
647 /* make argument list */
648 for (i = astat.tnext; i < astat.fnext; i++) {
649 *cp++ = ' ';
650 sprintf(cp, vval(BASENAME), i);
651 while (*cp) cp++;
652 strcpy(cp, ".pic");
653 cp += 4;
654 }
655 if (runcom(combuf)) { /* transfer frames */
656 fprintf(stderr, "%s: error running transfer command\n",
657 progname);
658 quit(1);
659 }
660 astat.tnext = i; /* update status */
661 putastat();
662 }
663
664
665 animrend(frame, vp) /* start animation frame */
666 int frame;
667 VIEW *vp;
668 {
669 extern int recover();
670 char combuf[2048];
671 char fname[128];
672
673 sprintf(fname, vval(BASENAME), frame);
674 strcat(fname, ".unf");
675 if (access(fname, F_OK) == 0)
676 return;
677 sprintf(combuf, "%s %d | rpict%s%s -w0 %s > %s", vval(ANIMATE), frame,
678 rendopt, viewopt(vp), rresopt, fname);
679 bruncom(combuf, frame, recover); /* run in background */
680 }
681
682
683 walkwait(first, last, vfn) /* walk-through frames */
684 int first, last;
685 char *vfn;
686 {
687 char combuf[2048];
688 char *inspoint;
689 register int i;
690
691 if (!noaction && vint(INTERP)) /* create dummy frames */
692 for (i = first; i <= last; i++)
693 if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
694 sprintf(combuf, vval(BASENAME), i);
695 strcat(combuf, ".unf");
696 close(open(combuf, O_RDONLY|O_CREAT, 0666));
697 }
698 /* create command */
699 sprintf(combuf, "rpict%s -w0", rendopt);
700 if (vint(INTERP) || atoi(vval(MBLUR)))
701 sprintf(combuf+strlen(combuf), " -z %s.zbf", vval(BASENAME));
702 sprintf(combuf+strlen(combuf), " -o %s.unf %s -S %d",
703 vval(BASENAME), rresopt, first);
704 inspoint = combuf + strlen(combuf);
705 sprintf(inspoint, " %s < %s", vval(OCTREE), vfn);
706 /* run in parallel */
707 i = (last-first+1)/(vint(INTERP)+1);
708 if (i < 1) i = 1;
709 if (pruncom(combuf, inspoint, i)) {
710 fprintf(stderr, "%s: error rendering frames %d through %d\n",
711 progname, first, last);
712 quit(1);
713 }
714 if (!noaction && vint(INTERP)) /* remove dummy frames */
715 for (i = first; i <= last; i++)
716 if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
717 sprintf(combuf, vval(BASENAME), i);
718 strcat(combuf, ".unf");
719 unlink(combuf);
720 }
721 }
722
723
724 int
725 recover(frame) /* recover the specified frame */
726 int frame;
727 {
728 static int *rfrm; /* list of recovered frames */
729 static int nrfrms = 0;
730 char combuf[2048];
731 char fname[128];
732 register char *cp;
733 register int i;
734 /* check to see if recovered already */
735 for (i = nrfrms; i--; )
736 if (rfrm[i] == frame)
737 return(0);
738 /* build command */
739 sprintf(fname, vval(BASENAME), frame);
740 if (vdef(ANIMATE))
741 sprintf(combuf, "%s %d | rpict%s -w0",
742 vval(ANIMATE), frame, rendopt);
743 else
744 sprintf(combuf, "rpict%s -w0", rendopt);
745 cp = combuf + strlen(combuf);
746 if (vint(INTERP) || atoi(vval(MBLUR))) {
747 sprintf(cp, " -z %s.zbf", fname);
748 while (*cp) cp++;
749 }
750 sprintf(cp, " -ro %s.unf", fname);
751 while (*cp) cp++;
752 if (!vdef(ANIMATE)) {
753 *cp++ = ' ';
754 strcpy(cp, vval(OCTREE));
755 }
756 if (runcom(combuf)) /* run command */
757 return(1);
758 /* add frame to recovered list */
759 if (nrfrms)
760 rfrm = (int *)realloc((char *)rfrm, (nrfrms+1)*sizeof(int));
761 else
762 rfrm = (int *)malloc(sizeof(int));
763 if (rfrm == NULL) {
764 perror("malloc");
765 quit(1);
766 }
767 rfrm[nrfrms++] = frame;
768 return(0);
769 }
770
771
772 int
773 frecover(frame) /* recover filtered frame */
774 int frame;
775 {
776 VIEW *vp;
777 char *ex;
778
779 vp = getview(frame);
780 ex = getexp(frame);
781 if (dofilt(frame, vp, ex, 2) && dofilt(frame, vp, ex, 1))
782 return(1);
783 return(0);
784 }
785
786
787 archive() /* archive and remove renderings */
788 {
789 #define RMCOML (sizeof(rmcom)-1)
790 static char rmcom[] = "rm -f";
791 register int i;
792
793 if (arcnext == arcfirst)
794 return; /* nothing to do */
795 if (vdef(ARCHIVE)) { /* run archive command */
796 i = strlen(vval(ARCHIVE));
797 strncpy(arcfirst-i, vval(ARCHIVE), i);
798 if (runcom(arcfirst-i)) {
799 fprintf(stderr, "%s: error running archive command\n",
800 progname);
801 quit(1);
802 }
803 }
804 /* run remove command */
805 strncpy(arcfirst-RMCOML, rmcom, RMCOML);
806 runcom(arcfirst-RMCOML);
807 arcnext = arcfirst; /* reset argument list */
808 #undef RMCOML
809 }
810
811
812 int
813 dofilt(frame, vp, ep, rvr) /* filter frame */
814 int frame;
815 VIEW *vp;
816 char *ep;
817 int rvr;
818 {
819 extern int frecover();
820 static int iter = 0;
821 char fnbefore[128], fnafter[128];
822 char combuf[1024], fname0[128], fname1[128];
823 int usepinterp, usepfilt, nora_rgbe;
824 int frseq[2];
825 /* check what is needed */
826 usepinterp = atoi(vval(MBLUR));
827 usepfilt = pfiltalways | ep==NULL;
828 if (ep != NULL && !strcmp(ep, "1"))
829 ep = "+0";
830 nora_rgbe = strcmp(vval(OVERSAMP),"1") || ep==NULL ||
831 *ep != '+' || *ep != '-' || !isint(ep);
832 /* compute rendered views */
833 frseq[0] = frame - ((frame-1) % (vint(INTERP)+1));
834 frseq[1] = frseq[0] + vint(INTERP) + 1;
835 if (frseq[1] > vint(END))
836 frseq[1] = vint(END);
837 if (frseq[1] == frame) { /* pfilt only */
838 frseq[0] = frseq[1];
839 usepinterp = 0; /* update what's needed */
840 usepfilt |= nora_rgbe;
841 } else if (frseq[0] == frame) { /* no interpolation needed */
842 if (!rvr && frame > 1+vint(INTERP)) { /* archive previous */
843 *arcnext++ = ' ';
844 sprintf(arcnext, vval(BASENAME), frame-vint(INTERP)-1);
845 while (*arcnext) arcnext++;
846 strcpy(arcnext, ".unf");
847 arcnext += 4;
848 if (usepinterp || vint(INTERP)) { /* and Z-buf */
849 *arcnext++ = ' ';
850 sprintf(arcnext, vval(BASENAME),
851 frame-vint(INTERP)-1);
852 while (*arcnext) arcnext++;
853 strcpy(arcnext, ".zbf");
854 arcnext += 4;
855 }
856 }
857 if (!usepinterp) /* update what's needed */
858 usepfilt |= nora_rgbe;
859 } else /* interpolation needed */
860 usepinterp++;
861 if (frseq[1] >= astat.rnext) /* next batch unavailable */
862 frseq[1] = frseq[0];
863 sprintf(fnbefore, vval(BASENAME), frseq[0]);
864 sprintf(fnafter, vval(BASENAME), frseq[1]);
865 if (rvr == 1 && recover(frseq[0])) /* recover before frame? */
866 return(1);
867 /* generate command */
868 if (usepinterp) { /* using pinterp */
869 if (rvr == 2 && recover(frseq[1])) /* recover after? */
870 return(1);
871 if (atoi(vval(MBLUR))) {
872 FILE *fp; /* motion blurring */
873 sprintf(fname0, "%s/vw0%c", vval(DIRECTORY),
874 'a'+(iter%26));
875 if ((fp = fopen(fname0, "w")) == NULL) {
876 perror(fname0); quit(1);
877 }
878 fputs(VIEWSTR, fp);
879 fprintview(vp, fp);
880 putc('\n', fp); fclose(fp);
881 if ((vp = getview(frame+1)) == NULL) {
882 fprintf(stderr,
883 "%s: unexpected error reading view for frame %d\n",
884 progname, frame+1);
885 quit(1);
886 }
887 sprintf(fname1, "%s/vw1%c", vval(DIRECTORY),
888 'a'+(iter%26));
889 if ((fp = fopen(fname1, "w")) == NULL) {
890 perror(fname1); quit(1);
891 }
892 fputs(VIEWSTR, fp);
893 fprintview(vp, fp);
894 putc('\n', fp); fclose(fp);
895 sprintf(combuf,
896 "(pmblur %s %d %s %s; rm -f %s %s) | pinterp -B",
897 *sskip(vval(MBLUR)) ? sskip2(vval(MBLUR),1) : "1",
898 atoi(vval(MBLUR)),
899 fname0, fname1, fname0, fname1);
900 iter++;
901 } else /* no blurring */
902 strcpy(combuf, "pinterp");
903 strcat(combuf, viewopt(vp));
904 if (vbool(RTRACE))
905 sprintf(combuf+strlen(combuf), " -ff -fr '%s -w0 %s'",
906 rendopt+1, vval(OCTREE));
907 if (vdef(PINTERP))
908 sprintf(combuf+strlen(combuf), " %s", vval(PINTERP));
909 if (usepfilt)
910 sprintf(combuf+strlen(combuf), " %s", rresopt);
911 else
912 sprintf(combuf+strlen(combuf), " %s -e %s",
913 fresopt, ep);
914 sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
915 fnbefore, fnbefore);
916 if (frseq[1] != frseq[0])
917 sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
918 fnafter, fnafter);
919 if (usepfilt) { /* also pfilt */
920 if (vdef(PFILT))
921 sprintf(combuf+strlen(combuf), " | pfilt %s",
922 vval(PFILT));
923 else
924 strcat(combuf, " | pfilt");
925 if (ep != NULL)
926 sprintf(combuf+strlen(combuf), " -1 -e %s %s",
927 ep, fresopt);
928 else
929 sprintf(combuf+strlen(combuf), " %s", fresopt);
930 }
931 } else if (usepfilt) { /* pfilt only */
932 if (rvr == 2)
933 return(1);
934 if (vdef(PFILT))
935 sprintf(combuf, "pfilt %s", vval(PFILT));
936 else
937 strcpy(combuf, "pfilt");
938 if (ep != NULL)
939 sprintf(combuf+strlen(combuf), " -1 -e %s %s %s.unf",
940 ep, fresopt, fnbefore);
941 else
942 sprintf(combuf+strlen(combuf), " %s %s.unf",
943 fresopt, fnbefore);
944 } else { /* else just check it */
945 if (rvr == 2)
946 return(1);
947 sprintf(combuf, "ra_rgbe -e %s -r %s.unf", ep, fnbefore);
948 }
949 /* output file name */
950 sprintf(fname0, vval(BASENAME), frame);
951 sprintf(combuf+strlen(combuf), " > %s.pic", fname0);
952 if (rvr) /* in recovery */
953 return(runcom(combuf));
954 bruncom(combuf, frame, frecover); /* else run in background */
955 return(0);
956 }
957
958
959 VIEW *
960 getview(n) /* get view number n */
961 int n;
962 {
963 static FILE *viewfp = NULL; /* view file pointer */
964 static int viewnum = 0; /* current view number */
965 static VIEW curview = STDVIEW; /* current view */
966 char linebuf[256];
967
968 if (n == 0) { /* signal to close file and clean up */
969 if (viewfp != NULL) {
970 fclose(viewfp);
971 viewfp = NULL;
972 viewnum = 0;
973 copystruct(&curview, &stdview);
974 }
975 return(NULL);
976 }
977 if (viewfp == NULL) { /* open file */
978 if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) {
979 perror(vval(VIEWFILE));
980 quit(1);
981 }
982 } else if (n < viewnum) { /* rewind file */
983 if (viewnum == 1 && feof(viewfp))
984 return(&curview); /* just one view */
985 if (fseek(viewfp, 0L, 0) == EOF) {
986 perror(vval(VIEWFILE));
987 quit(1);
988 }
989 copystruct(&curview, &stdview);
990 viewnum = 0;
991 }
992 while (n > viewnum) { /* scan to desired view */
993 if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL)
994 return(viewnum==1 ? &curview : (VIEW *)NULL);
995 if (isview(linebuf) && sscanview(&curview, linebuf) > 0)
996 viewnum++;
997 }
998 return(&curview); /* return it */
999 }
1000
1001
1002 int
1003 countviews() /* count views in view file */
1004 {
1005 register int n = 0;
1006
1007 while (getview(n+1) != NULL)
1008 n++;
1009 return(n);
1010 }
1011
1012
1013 char *
1014 getexp(n) /* get exposure for nth frame */
1015 int n;
1016 {
1017 extern char *fskip();
1018 static char expval[32];
1019 static FILE *expfp = NULL;
1020 static long *exppos;
1021 static int curfrm;
1022 register char *cp;
1023
1024 if (n == 0) { /* signal to close file */
1025 if (expfp != NULL) {
1026 fclose(expfp);
1027 free((char *)exppos);
1028 expfp = NULL;
1029 }
1030 return(NULL);
1031 } else if (n > vint(END)) /* request past end (error?) */
1032 return(NULL);
1033 if (!vdef(EXPOSURE)) /* no setting (auto) */
1034 return(NULL);
1035 if (isflt(vval(EXPOSURE))) /* always the same */
1036 return(vval(EXPOSURE));
1037 if (expfp == NULL) { /* open exposure file */
1038 if ((expfp = fopen(vval(EXPOSURE), "r")) == NULL) {
1039 fprintf(stderr,
1040 "%s: cannot open exposure file \"%s\"\n",
1041 progname, vval(EXPOSURE));
1042 quit(1);
1043 }
1044 curfrm = vint(END) + 1; /* init lookup tab. */
1045 exppos = (long *)malloc(curfrm*sizeof(long *));
1046 if (exppos == NULL) {
1047 perror(progname);
1048 quit(1);
1049 }
1050 while (curfrm--)
1051 exppos[curfrm] = -1L;
1052 curfrm = 0;
1053 }
1054 /* find position in file */
1055 if (n-1 != curfrm && n != curfrm && exppos[n-1] >= 0 &&
1056 fseek(expfp, exppos[curfrm=n-1], 0) == EOF) {
1057 fprintf(stderr, "%s: seek error on exposure file\n", progname);
1058 quit(1);
1059 }
1060 while (n > curfrm) { /* read exposure */
1061 if (exppos[curfrm] < 0)
1062 exppos[curfrm] = ftell(expfp);
1063 if (fgets(expval, sizeof(expval), expfp) == NULL) {
1064 fprintf(stderr, "%s: too few exposures\n",
1065 vval(EXPOSURE));
1066 quit(1);
1067 }
1068 curfrm++;
1069 cp = fskip(expval); /* check format */
1070 if (cp != NULL)
1071 while (isspace(*cp))
1072 *cp++ = '\0';
1073 if (cp == NULL || *cp) {
1074 fprintf(stderr,
1075 "%s: exposure format error on line %d\n",
1076 vval(EXPOSURE), curfrm);
1077 quit(1);
1078 }
1079 }
1080 return(expval); /* return value */
1081 }
1082
1083
1084 struct pslot *
1085 findpslot(pid) /* find or allocate a process slot */
1086 int pid;
1087 {
1088 register struct pslot *psempty = NULL;
1089 register int i;
1090
1091 for (i = 0; i < npslots; i++) { /* look for match */
1092 if (pslot[i].pid == pid)
1093 return(pslot+i);
1094 if (psempty == NULL && pslot[i].pid == 0)
1095 psempty = pslot+i;
1096 }
1097 return(psempty); /* return emtpy slot (error if NULL) */
1098 }
1099
1100
1101 int
1102 donecom(ps, pn, status) /* clean up after finished process */
1103 PSERVER *ps;
1104 int pn;
1105 int status;
1106 {
1107 register PROC *pp;
1108 register struct pslot *psl;
1109
1110 pp = ps->proc + pn;
1111 if (pp->elen) { /* pass errors */
1112 if (ps->hostname[0])
1113 fprintf(stderr, "%s: ", ps->hostname);
1114 fprintf(stderr, "Error output from: %s\n", pp->com);
1115 fputs(pp->errs, stderr);
1116 fflush(stderr);
1117 if (ps->hostname[0])
1118 status = 1; /* because rsh doesn't return status */
1119 }
1120 lastpserver = NULL;
1121 psl = findpslot(pp->pid); /* check for bruncom() slot */
1122 if (psl->pid) {
1123 if (status) {
1124 if (psl->rcvf != NULL) /* attempt recovery */
1125 status = (*psl->rcvf)(psl->fout);
1126 if (status) {
1127 fprintf(stderr,
1128 "%s: error rendering frame %d\n",
1129 progname, psl->fout);
1130 quit(1);
1131 }
1132 lastpserver = ps;
1133 }
1134 psl->pid = 0; /* free process slot */
1135 } else if (status)
1136 lastpserver = ps;
1137 freestr(pp->com); /* free command string */
1138 return(status);
1139 }
1140
1141
1142 int
1143 serverdown() /* check status of last process server */
1144 {
1145 if (lastpserver == NULL || !lastpserver->hostname[0])
1146 return(0);
1147 if (pserverOK(lastpserver)) /* server still up? */
1148 return(0);
1149 delpserver(lastpserver); /* else delete it */
1150 if (pslist == NULL) {
1151 fprintf(stderr, "%s: all process servers are down\n",
1152 progname);
1153 quit(1);
1154 }
1155 return(1);
1156 }
1157
1158
1159 int
1160 bruncom(com, fout, rf) /* run a command in the background */
1161 char *com;
1162 int fout;
1163 int (*rf)();
1164 {
1165 int pid;
1166 register struct pslot *psl;
1167
1168 if (noaction) {
1169 if (!silent)
1170 printf("\t%s\n", com); /* echo command */
1171 return(0);
1172 }
1173 com = savestr(com); /* else start it when we can */
1174 while ((pid = startjob(NULL, com, donecom)) == -1)
1175 bwait(1);
1176 if (!silent) { /* echo command */
1177 PSERVER *ps;
1178 int psn = pid;
1179 ps = findjob(&psn);
1180 printf("\t%s\n", com);
1181 printf("\tProcess started on %s\n", phostname(ps));
1182 fflush(stdout);
1183 }
1184 psl = findpslot(pid); /* record info. in appropriate slot */
1185 psl->pid = pid;
1186 psl->fout = fout;
1187 psl->rcvf = rf;
1188 return(pid);
1189 }
1190
1191
1192 bwait(ncoms) /* wait for batch job(s) to finish */
1193 int ncoms;
1194 {
1195 int status;
1196
1197 if (noaction)
1198 return;
1199 while ((status = wait4job(NULL, -1)) != -1) {
1200 serverdown(); /* update server status */
1201 if (--ncoms == 0)
1202 break; /* done enough */
1203 }
1204 }
1205
1206
1207 int
1208 pruncom(com, ppins, maxcopies) /* run a command in parallel over network */
1209 char *com, *ppins;
1210 int maxcopies;
1211 {
1212 int retstatus = 0;
1213 int hostcopies;
1214 char buf[10240], *com1, *s;
1215 int status;
1216 int pfd;
1217 register int n;
1218 register PSERVER *ps;
1219
1220 if (!silent)
1221 printf("\t%s\n", com); /* echo command */
1222 if (noaction)
1223 return(0);
1224 fflush(stdout);
1225 /* start jobs on each server */
1226 for (ps = pslist; ps != NULL; ps = ps->next) {
1227 hostcopies = 0;
1228 if (maxcopies > 1 && ps->nprocs > 1 && ppins != NULL) {
1229 strcpy(com1=buf, com); /* build -PP command */
1230 sprintf(com1+(ppins-com), " -PP %s/%s.persist",
1231 vval(DIRECTORY), phostname(ps));
1232 strcat(com1, ppins);
1233 } else
1234 com1 = com;
1235 while (maxcopies > 0) {
1236 s = savestr(com1);
1237 if (startjob(ps, s, donecom) != -1) {
1238 sleep(20);
1239 hostcopies++;
1240 maxcopies--;
1241 } else {
1242 freestr(s);
1243 break;
1244 }
1245 }
1246 if (!silent && hostcopies) {
1247 if (hostcopies > 1)
1248 printf("\t%d duplicate processes", hostcopies);
1249 else
1250 printf("\tProcess");
1251 printf(" started on %s\n", phostname(ps));
1252 fflush(stdout);
1253 }
1254 }
1255 /* wait for jobs to finish */
1256 while ((status = wait4job(NULL, -1)) != -1)
1257 retstatus += status && !serverdown();
1258 /* terminate parallel rpict's */
1259 for (ps = pslist; ps != NULL; ps = ps->next) {
1260 sprintf(buf, "%s/%s.persist", vval(DIRECTORY), phostname(ps));
1261 if ((pfd = open(buf, O_RDONLY)) >= 0) {
1262 n = read(pfd, buf, sizeof(buf)-1); /* get PID */
1263 buf[n] = '\0';
1264 close(pfd);
1265 for (n = 0; buf[n] && !isspace(buf[n]); n++)
1266 ;
1267 /* terminate */
1268 sprintf(buf, "kill -ALRM %d", atoi(buf+n));
1269 wait4job(ps, startjob(ps, buf, NULL));
1270 }
1271 }
1272 return(retstatus);
1273 }
1274
1275
1276 runcom(cs) /* run a command locally and wait for it */
1277 char *cs;
1278 {
1279 if (!silent) /* echo it */
1280 printf("\t%s\n", cs);
1281 if (noaction)
1282 return(0);
1283 fflush(stdout); /* flush output and pass to shell */
1284 return(system(cs));
1285 }
1286
1287
1288 rmfile(fn) /* remove a file */
1289 char *fn;
1290 {
1291 if (!silent)
1292 #ifdef MSDOS
1293 printf("\tdel %s\n", fn);
1294 #else
1295 printf("\trm -f %s\n", fn);
1296 #endif
1297 if (noaction)
1298 return(0);
1299 return(unlink(fn));
1300 }
1301
1302
1303 badvalue(vc) /* report bad variable value and exit */
1304 int vc;
1305 {
1306 fprintf(stderr, "%s: bad value for variable '%s'\n",
1307 progname, vnam(vc));
1308 quit(1);
1309 }
