root/radiance/ray/src/util/ranimate.c
Revision: 2.53
Committed: Thu Feb 21 01:22:06 2008 UTC (17 years, 5 months ago) by greg
Changes since 2.52: +1 -2 lines
2 static const char RCSid[] = "$Id: ranimate.c,v 2.52 2006/04/18 04:30:35 greg Exp $";
5 * Radiance animation control program
6 *
7 * The main difference between this program and ranimove is that
8 * we have many optimizations here for camera motion in static
9 * environments, calling rpict and pinterp on multiple processors,
10 * where ranimove puts its emphasis on object motion, and does
11 * not use any external programs for image generation.
12 *
13 * See the ranimate(1) man page for further details.
14 */
15
16 #include "copyright.h"
17
18 #include <stdio.h>
19 #include <ctype.h>
20 #include <sys/stat.h>
21 #include <time.h>
22 #include <signal.h>
23
24 #include "platform.h"
25 #include "rtprocess.h"
26 #include "paths.h"
27 #include "standard.h"
28 #include "view.h"
29 #include "vars.h"
30 #include "netproc.h"
31 /* default blur samples */
32 #ifndef DEF_NBLUR
33 #define DEF_NBLUR 5
34 #endif
35 /* default remote shell */
36 #ifndef REMSH
37 #define REMSH "ssh"
38 #endif
39 /* input variables (alphabetical by name) */
40 #define ANIMATE 0 /* animation command */
41 #define ARCHIVE 1 /* archiving command */
42 #define BASENAME 2 /* output image base name */
43 #define DBLUR 3 /* depth of field blur */
44 #define DIRECTORY 4 /* working (sub)directory */
45 #define DISKSPACE 5 /* how much disk space to use */
46 #define END 6 /* ending frame number */
47 #define EXPOSURE 7 /* how to compute exposure */
48 #define HOST 8 /* rendering host machine */
49 #define INTERP 9 /* # frames to interpolate */
50 #define MBLUR 10 /* motion blur parameters */
51 #define NEXTANIM 11 /* next animation file */
52 #define OCTREE 12 /* octree file name */
53 #define OVERSAMP 13 /* # times to oversample image */
54 #define PFILT 14 /* pfilt options */
55 #define PINTERP 15 /* pinterp options */
56 #define RENDER 16 /* rendering options */
57 #define RESOLUTION 17 /* desired final resolution */
58 #define RIF 18 /* rad input file */
59 #define RSH 19 /* remote shell script or program */
60 #define RTRACE 20 /* use rtrace with pinterp? */
61 #define START 21 /* starting frame number */
62 #define TRANSFER 22 /* frame transfer command */
63 #define VIEWFILE 23 /* animation frame views */
64
65 int NVARS = 24; /* total number of variables */
66
67 VARIABLE vv[] = { /* variable-value pairs */
68 {"ANIMATE", 2, 0, NULL, onevalue},
69 {"ARCHIVE", 2, 0, NULL, onevalue},
70 {"BASENAME", 3, 0, NULL, onevalue},
71 {"DBLUR", 2, 0, NULL, onevalue},
72 {"DIRECTORY", 3, 0, NULL, onevalue},
73 {"DISKSPACE", 3, 0, NULL, fltvalue},
74 {"END", 2, 0, NULL, intvalue},
75 {"EXPOSURE", 3, 0, NULL, onevalue},
76 {"host", 4, 0, NULL, NULL},
77 {"INTERPOLATE", 3, 0, NULL, intvalue},
78 {"MBLUR", 2, 0, NULL, onevalue},
79 {"NEXTANIM", 3, 0, NULL, onevalue},
80 {"OCTREE", 3, 0, NULL, onevalue},
81 {"OVERSAMPLE", 2, 0, NULL, fltvalue},
82 {"pfilt", 2, 0, NULL, catvalues},
83 {"pinterp", 2, 0, NULL, catvalues},
84 {"render", 3, 0, NULL, catvalues},
85 {"RESOLUTION", 3, 0, NULL, onevalue},
86 {"RIF", 3, 0, NULL, onevalue},
87 {"RSH", 3, 0, NULL, onevalue},
88 {"RTRACE", 2, 0, NULL, boolvalue},
89 {"START", 2, 0, NULL, intvalue},
90 {"TRANSFER", 2, 0, NULL, onevalue},
91 {"VIEWFILE", 2, 0, NULL, onevalue},
92 };
93
94 #define SFNAME "STATUS" /* status file name */
95
96 struct {
97 char host[64]; /* control host name */
98 RT_PID pid; /* control process id */
99 char cfname[128]; /* control file name */
100 int rnext; /* next frame to render */
101 int fnext; /* next frame to filter */
102 int tnext; /* next frame to transfer */
103 } astat; /* animation status */
104
105 char *progname; /* our program name */
106 char *cfname; /* our control file name */
107
108 int nowarn = 0; /* turn warnings off? */
109 int silent = 0; /* silent mode? */
110 int noaction = 0; /* take no action? */
111
112 char *remsh; /* remote shell program/script */
113 char rendopt[2048]; /* rendering options */
114 char rresopt[32]; /* rendering resolution options */
115 char fresopt[32]; /* filter resolution options */
116 int pfiltalways; /* always use pfilt? */
117
118 char arcargs[10240]; /* files to archive */
119 char *arcfirst, *arcnext; /* pointers to first and next argument */
120
121 struct pslot {
122 RT_PID pid; /* process ID (0 if empty) */
123 int fout; /* output frame number */
124 int (*rcvf)(); /* recover function */
125 } *pslot; /* process slots */
126 int npslots; /* number of process slots */
127
128 #define phostname(ps) ((ps)->hostname[0] ? (ps)->hostname : astat.host)
129 PSERVER *lastpserver; /* last process server with error */
130
131 static struct pslot * findpslot(RT_PID pid);
132 static void checkdir(void);
133 static VIEW * getview(int n);
134
135 static char * dirfile(char *df, register char *path);
136 static char * getexp(int n);
137 static int getblur(double *mbf, double *dbf);
138 static int getastat(void);
139 static void getradfile(char *rfargs);
140 static void badvalue(int vc);
141 static int rmfile(char *fn);
142 static int runcom(char *cs);
143 static int pruncom(char *com, char *ppins, int maxcopies);
144 static void bwait(int ncoms);
145 static RT_PID bruncom(char *com, int fout, int (*rf)());
146 static int serverdown(void);
147 static pscompfunc donecom;
148 static int countviews(void);
149 static int dofilt(int frame, int rvr);
150 static void archive(void);
151 static int frecover(int frame);
152 static int recover(int frame);
153 static void sethosts(void);
154 static void walkwait(int first, int last, char *vfn);
155 static void animrend(int frame, VIEW *vp);
156 static void transferframes(void);
157 static void filterframes(void);
158 static void renderframes(int nframes);
159 static void animate(void);
160 static void setdefaults(void);
161 static void putastat(void);
162
163
164 int
165 main(
166 int argc,
167 char *argv[]
168 )
169 {
170 int explicate = 0;
171 int i;
172
173 progname = argv[0]; /* get arguments */
174 for (i = 1; i < argc && argv[i][0] == '-'; i++)
175 switch (argv[i][1]) {
176 case 'e': /* print variables */
177 explicate++;
178 break;
179 case 'w': /* turn off warnings */
180 nowarn++;
181 break;
182 case 's': /* silent mode */
183 silent++;
184 break;
185 case 'n': /* take no action */
186 noaction++;
187 break;
188 default:
189 goto userr;
190 }
191 if (i != argc-1)
192 goto userr;
193 cfname = argv[i];
194 /* load variables */
195 loadvars(cfname);
196 /* check variables */
197 checkvalues();
198 /* did we get DIRECTORY? */
199 checkdir();
200 /* check status */
201 if (getastat() < 0) {
202 fprintf(stderr, "%s: exiting\n", progname);
203 quit(1);
204 }
205 /* pfilt always if options given */
206 pfiltalways = vdef(PFILT);
207 /* load RIF if any */
208 if (vdef(RIF))
209 getradfile(vval(RIF));
210 /* set defaults */
211 setdefaults();
212 /* print variables */
213 if (explicate)
214 printvars(stdout);
215 /* set up process servers */
216 sethosts();
217 /* run animation */
218 animate();
219 /* all done */
220 if (vdef(NEXTANIM)) {
221 char *fullp;
222 argv[i] = vval(NEXTANIM); /* just change input file */
223 if (!silent)
224 printargs(argc, argv, stdout);
225 fflush(stdout);
226 if ((fullp = getpath(argv[0],getenv("PATH"),X_OK)) == NULL)
227 fprintf(stderr, "%s: command not found\n", argv[0]);
228 else
229 execv(fullp, argv);
230 quit(1);
231 }
232 quit(0);
233 return(0); /* pro forma return */
234 userr:
235 fprintf(stderr, "Usage: %s [-s][-n][-w][-e] anim_file\n", progname);
236 quit(1);
237 return 1; /* pro forma return */
238 }
239
240
241 static int
242 getastat(void) /* check/set animation status */
243 {
244 char sfname[256];
245 FILE *fp;
246
247 sprintf(sfname, "%s/%s", vval(DIRECTORY), SFNAME);
248 if ((fp = fopen(sfname, "r")) == NULL) {
249 if (errno != ENOENT) {
250 perror(sfname);
251 return(-1);
252 }
253 astat.rnext = astat.fnext = astat.tnext = 0;
254 goto setours;
255 }
256 if (fscanf(fp, "Control host: %s\n", astat.host) != 1)
257 goto fmterr;
258 if (fscanf(fp, "Control PID: %d\n", &astat.pid) != 1)
259 goto fmterr;
260 if (fscanf(fp, "Control file: %s\n", astat.cfname) != 1)
261 goto fmterr;
262 if (fscanf(fp, "Next render: %d\n", &astat.rnext) != 1)
263 goto fmterr;
264 if (fscanf(fp, "Next filter: %d\n", &astat.fnext) != 1)
265 goto fmterr;
266 if (fscanf(fp, "Next transfer: %d\n", &astat.tnext) != 1)
267 goto fmterr;
268 fclose(fp);
269 if (astat.pid != 0) { /* thinks it's still running */
270 if (strcmp(myhostname(), astat.host)) {
271 fprintf(stderr,
272 "%s: process %d may still be running on host %s\n",
273 progname, astat.pid, astat.host);
274 return(-1);
275 }
276 if (kill(astat.pid, 0) != -1 || errno != ESRCH) {
277 fprintf(stderr, "%s: process %d is still running\n",
278 progname, astat.pid);
279 return(-1);
280 }
281 /* assume it is dead */
282 }
283 if (strcmp(cfname, astat.cfname) && astat.pid != 0) { /* other's */
284 fprintf(stderr, "%s: unfinished job \"%s\"\n",
285 progname, astat.cfname);
286 return(-1);
287 }
288 /* check control file mods. */
289 if (!nowarn && fdate(cfname) > fdate(sfname))
290 fprintf(stderr,
291 "%s: warning - control file modified since last run\n",
292 progname);
293 setours: /* set our values */
294 strcpy(astat.host, myhostname());
295 astat.pid = getpid();
296 strcpy(astat.cfname, cfname);
297 return(0);
298 fmterr:
299 fprintf(stderr, "%s: format error in status file \"%s\"\n",
300 progname, sfname);
301 fclose(fp);
302 return(-1);
303 }
304
305
306 static void
307 putastat(void) /* put out current status */
308 {
309 char buf[256];
310 FILE *fp;
311
312 if (noaction)
313 return;
314 sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME);
315 if ((fp = fopen(buf, "w")) == NULL) {
316 perror(buf);
317 quit(1);
318 }
319 fprintf(fp, "Control host: %s\n", astat.host);
320 fprintf(fp, "Control PID: %d\n", astat.pid);
321 fprintf(fp, "Control file: %s\n", astat.cfname);
322 fprintf(fp, "Next render: %d\n", astat.rnext);
323 fprintf(fp, "Next filter: %d\n", astat.fnext);
324 fprintf(fp, "Next transfer: %d\n", astat.tnext);
325 fclose(fp);
326 }
327
328
329 static void
330 checkdir(void) /* make sure we have our directory */
331 {
332 struct stat stb;
333
334 if (!vdef(DIRECTORY)) {
335 fprintf(stderr, "%s: %s undefined\n",
336 progname, vnam(DIRECTORY));
337 quit(1);
338 }
339 if (stat(vval(DIRECTORY), &stb) == -1) {
340 if (errno == ENOENT && mkdir(vval(DIRECTORY), 0777) == 0)
341 return;
342 perror(vval(DIRECTORY));
343 quit(1);
344 }
345 if (!(stb.st_mode & S_IFDIR)) {
346 fprintf(stderr, "%s: not a directory\n", vval(DIRECTORY));
347 quit(1);
348 }
349 }
350
351
352 static void
353 setdefaults(void) /* set default values */
354 {
355 extern char *atos();
356 int decades;
357 char buf[256];
358
359 if (vdef(ANIMATE)) {
360 vval(OCTREE) = NULL;
361 vdef(OCTREE) = 0;
362 } else if (!vdef(OCTREE)) {
363 fprintf(stderr, "%s: either %s or %s must be defined\n",
364 progname, vnam(OCTREE), vnam(ANIMATE));
365 quit(1);
366 }
367 if (!vdef(VIEWFILE)) {
368 fprintf(stderr, "%s: %s undefined\n", progname, vnam(VIEWFILE));
369 quit(1);
370 }
371 if (!vdef(HOST)) {
372 vval(HOST) = LHOSTNAME;
373 vdef(HOST)++;
374 }
375 if (!vdef(START)) {
376 vval(START) = "1";
377 vdef(START)++;
378 }
379 if (!vdef(END)) {
380 sprintf(buf, "%d", countviews()+vint(START)-1);
381 vval(END) = savqstr(buf);
382 vdef(END)++;
383 }
384 if (vint(END) < vint(START)) {
385 fprintf(stderr, "%s: ending frame less than starting frame\n",
386 progname);
387 quit(1);
388 }
389 if (!vdef(BASENAME)) {
390 decades = (int)log10((double)vint(END)) + 1;
391 if (decades < 3) decades = 3;
392 sprintf(buf, "%s/frame%%0%dd", vval(DIRECTORY), decades);
393 vval(BASENAME) = savqstr(buf);
394 vdef(BASENAME)++;
395 }
396 if (!vdef(RESOLUTION)) {
397 vval(RESOLUTION) = "640";
398 vdef(RESOLUTION)++;
399 }
400 if (!vdef(OVERSAMP)) {
401 vval(OVERSAMP) = "2";
402 vdef(OVERSAMP)++;
403 }
404 if (!vdef(INTERP)) {
405 vval(INTERP) = "0";
406 vdef(INTERP)++;
407 }
408 if (!vdef(MBLUR)) {
409 vval(MBLUR) = "0";
410 vdef(MBLUR)++;
411 }
412 if (!vdef(RTRACE)) {
413 vval(RTRACE) = "F";
414 vdef(RTRACE)++;
415 }
416 if (!vdef(DISKSPACE)) {
417 if (!nowarn)
418 fprintf(stderr,
419 "%s: warning - no %s setting, assuming 100 Mbytes available\n",
420 progname, vnam(DISKSPACE));
421 vval(DISKSPACE) = "100";
422 vdef(DISKSPACE)++;
423 }
424 if (!vdef(RSH)) {
425 vval(RSH) = REMSH;
426 vdef(RSH)++;
427 }
428 /* locate remote shell program */
429 atos(buf, sizeof(buf), vval(RSH));
430 if ((remsh = getpath(buf, getenv("PATH"), X_OK)) != NULL)
431 remsh = savqstr(remsh);
432 else
433 remsh = vval(RSH); /* will generate error if used */
434
435 /* append rendering options */
436 if (vdef(RENDER))
437 sprintf(rendopt+strlen(rendopt), " %s", vval(RENDER));
438 }
439
440
441 static void
442 sethosts(void) /* set up process servers */
443 {
444 extern char *iskip();
445 char buf[256], *dir, *uname;
446 int np;
447 register char *cp;
448 int i;
449
450 npslots = 0;
451 if (noaction)
452 return;
453 for (i = 0; i < vdef(HOST); i++) { /* add each host */
454 dir = uname = NULL;
455 np = 1;
456 strcpy(cp=buf, nvalue(HOST, i)); /* copy to buffer */
457 cp = sskip(cp); /* skip host name */
458 while (isspace(*cp))
459 *cp++ = '\0';
460 if (*cp) { /* has # processes? */
461 np = atoi(cp);
462 if ((cp = iskip(cp)) == NULL || (*cp && !isspace(*cp)))
463 badvalue(HOST);
464 while (isspace(*cp))
465 cp++;
466 if (*cp) { /* has directory? */
467 dir = cp;
468 cp = sskip(cp); /* skip dir. */
469 while (isspace(*cp))
470 *cp++ = '\0';
471 if (*cp) { /* has user? */
472 uname = cp;
473 if (*sskip(cp))
474 badvalue(HOST);
475 }
476 }
477 }
478 if (addpserver(buf, dir, uname, np) == NULL) {
479 if (!nowarn)
480 fprintf(stderr,
481 "%s: cannot execute on host \"%s\"\n",
482 progname, buf);
483 } else
484 npslots += np;
485 }
486 if (npslots == 0) {
487 fprintf(stderr, "%s: no working process servers\n", progname);
488 quit(1);
489 }
490 pslot = (struct pslot *)calloc(npslots, sizeof(struct pslot));
491 if (pslot == NULL) {
492 perror("malloc");
493 quit(1);
494 }
495 }
496
497 static void
498 getradfile(char *rfargs) /* run rad and get needed variables */
499 {
500 static short mvar[] = {OCTREE,PFILT,RESOLUTION,EXPOSURE,-1};
501 char combuf[256];
502 register int i;
503 register char *cp;
504 char *pippt = NULL;
505 /* create rad command */
506 sprintf(rendopt, " @%s/render.opt", vval(DIRECTORY));
507 sprintf(combuf,
508 "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
509 rfargs, rendopt+2);
510 cp = combuf;
511 while (*cp) {
512 if (*cp == '|') pippt = cp;
513 cp++;
514 } /* match unset variables */
515 for (i = 0; mvar[i] >= 0; i++)
516 if (!vdef(mvar[i])) {
517 *cp++ = '|';
518 strcpy(cp, vnam(mvar[i]));
519 while (*cp) cp++;
520 pippt = NULL;
521 }
522 if (pippt != NULL)
523 strcpy(pippt, "> " NULL_DEVICE); /* nothing to match */
524 else {
525 sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY));
526 cp += 11; /* point to file name */
527 }
528 system(combuf); /* ignore exit code */
529 if (pippt == NULL) { /* load variables and remove file */
530 loadvars(cp);
531 unlink(cp);
532 }
533 }
534
535
536 static void
537 animate(void) /* run animation */
538 {
539 int xres, yres;
540 float pa, mult;
541 int frames_batch;
542 register int i;
543 double d1, d2;
544 /* compute rpict resolution */
545 i = sscanf(vval(RESOLUTION), "%d %d %f", &xres, &yres, &pa);
546 mult = vflt(OVERSAMP);
547 if (i == 3) {
548 sprintf(rresopt, "-x %d -y %d -pa %.3f", (int)(mult*xres),
549 (int)(mult*yres), pa);
550 sprintf(fresopt, "-x %d -y %d -pa %.3f", xres, yres, pa);
551 } else if (i) {
552 if (i == 1) yres = xres;
553 sprintf(rresopt, "-x %d -y %d", (int)(mult*xres),
554 (int)(mult*yres));
555 sprintf(fresopt, "-x %d -y %d -pa 1", xres, yres);
556 } else
557 badvalue(RESOLUTION);
558 /* consistency checks */
559 if (vdef(ANIMATE)) {
560 if (vint(INTERP)) {
561 if (!nowarn)
562 fprintf(stderr,
563 "%s: resetting %s=0 for animation\n",
564 progname, vnam(INTERP));
565 vval(INTERP) = "0";
566 }
567 if (strcmp(vval(MBLUR),"0")) { /* can't handle this */
568 if (!nowarn)
569 fprintf(stderr,
570 "%s: resetting %s=0 for animation\n",
571 progname, vnam(MBLUR));
572 vval(MBLUR) = "0";
573 }
574 }
575 /* figure # frames per batch */
576 d1 = mult*xres*mult*yres*4; /* space for orig. picture */
577 if ((i=vint(INTERP)) || getblur(NULL, NULL) > 1)
578 d1 += mult*xres*mult*yres*sizeof(float); /* Z-buffer */
579 d2 = xres*yres*4; /* space for final picture */
580 frames_batch = (i+1)*(vflt(DISKSPACE)*1048576.-d1)/(d1+i*d2);
581 if (frames_batch < i+2) {
582 fprintf(stderr, "%s: insufficient disk space allocated\n",
583 progname);
584 quit(1);
585 }
586 /* initialize archive argument list */
587 i = vdef(ARCHIVE) ? strlen(vval(ARCHIVE))+132 : 132;
588 arcnext = arcfirst = arcargs + i;
589 /* initialize status file */
590 if (astat.rnext == 0)
591 astat.rnext = astat.fnext = astat.tnext = vint(START);
592 putastat();
593 /* render in batches */
594 while (astat.tnext <= vint(END)) {
595 renderframes(frames_batch);
596 filterframes();
597 transferframes();
598 }
599 /* mark status as finished */
600 astat.pid = 0;
601 putastat();
602 /* close open files */
603 getview(0);
604 getexp(0);
605 }
606
607
608 static void
609 renderframes(int nframes) /* render next nframes frames */
610 {
611 static char vendbuf[16];
612 VIEW *vp;
613 FILE *fp = NULL;
614 char vfname[128];
615 int lastframe;
616 register int i;
617
618 if (astat.tnext < astat.rnext) /* other work to do first */
619 return;
620 /* create batch view file */
621 if (!vdef(ANIMATE)) {
622 sprintf(vfname, "%s/anim.vf", vval(DIRECTORY));
623 if ((fp = fopen(vfname, "w")) == NULL) {
624 perror(vfname);
625 quit(1);
626 }
627 }
628 /* bound batch properly */
629 lastframe = astat.rnext + nframes - 1;
630 if ((lastframe-1) % (vint(INTERP)+1)) /* need even interval */
631 lastframe += vint(INTERP)+1 - ((lastframe-1)%(vint(INTERP)+1));
632 if (lastframe > vint(END)) /* check for end */
633 lastframe = vint(END);
634 /* render each view */
635 for (i = astat.rnext; i <= lastframe; i++) {
636 if ((vp = getview(i)) == NULL) {
637 if (!nowarn)
638 fprintf(stderr,
639 "%s: ran out of views before last frame\n",
640 progname);
641 sprintf(vval(END)=vendbuf, "%d", i-1);
642 lastframe = i - 1;
643 break;
644 }
645 if (vdef(ANIMATE)) /* animate frame */
646 animrend(i, vp);
647 else { /* else record it */
648 fputs(VIEWSTR, fp);
649 fprintview(vp, fp);
650 putc('\n', fp);
651 }
652 }
653 if (vdef(ANIMATE)) /* wait for renderings to finish */
654 bwait(0);
655 else { /* else if walk-through */
656 fclose(fp); /* close view file */
657 walkwait(astat.rnext, lastframe, vfname); /* walk it */
658 unlink(vfname); /* remove view file */
659 }
660 astat.rnext = i; /* update status */
661 putastat();
662 }
663
664
665 static void
666 filterframes(void) /* catch up with filtering */
667 {
668 register int i;
669
670 if (astat.tnext < astat.fnext) /* other work to do first */
671 return;
672 /* filter each view */
673 for (i = astat.fnext; i < astat.rnext; i++)
674 dofilt(i, 0);
675
676 bwait(0); /* wait for filter processes */
677 archive(); /* archive originals */
678 astat.fnext = i; /* update status */
679 putastat();
680 }
681
682
683 static void
684 transferframes(void) /* catch up with picture transfers */
685 {
686 char combuf[10240], *fbase;
687 register char *cp;
688 register int i;
689
690 if (astat.tnext >= astat.fnext) /* nothing to do, yet */
691 return;
692 if (!vdef(TRANSFER)) { /* no transfer function -- leave 'em */
693 astat.tnext = astat.fnext;
694 putastat(); /* update status */
695 return;
696 }
697 strcpy(combuf, "cd "); /* start transfer command */
698 fbase = dirfile(cp = combuf+3, vval(BASENAME));
699 if (*cp) {
700 while (*++cp) ;
701 *cp++ = ';'; *cp++ = ' ';
702 } else
703 cp = combuf;
704 strcpy(cp, vval(TRANSFER));
705 while (*cp) cp++;
706 /* make argument list */
707 for (i = astat.tnext; i < astat.fnext; i++) {
708 *cp++ = ' ';
709 sprintf(cp, fbase, i);
710 while (*cp) cp++;
711 strcpy(cp, ".pic");
712 cp += 4;
713 }
714 if (runcom(combuf)) { /* transfer frames */
715 fprintf(stderr, "%s: error running transfer command\n",
716 progname);
717 quit(1);
718 }
719 astat.tnext = i; /* update status */
720 putastat();
721 }
722
723
724 static void
725 animrend( /* start animation frame */
726 int frame,
727 VIEW *vp
728 )
729 {
730 char combuf[2048];
731 char fname[128];
732
733 sprintf(fname, vval(BASENAME), frame);
734 strcat(fname, ".unf");
735 if (access(fname, F_OK) == 0)
736 return;
737 sprintf(combuf, "%s %d | rpict%s%s -w0 %s > %s", vval(ANIMATE), frame,
738 rendopt, viewopt(vp), rresopt, fname);
739 bruncom(combuf, frame, recover); /* run in background */
740 }
741
742
743 static void
744 walkwait( /* walk-through frames */
745 int first,
746 int last,
747 char *vfn
748 )
749 {
750 double mblurf, dblurf;
751 int nblur = getblur(&mblurf, &dblurf);
752 char combuf[2048];
753 register char *inspoint;
754 register int i;
755
756 if (!noaction && vint(INTERP)) /* create dummy frames */
757 for (i = first; i <= last; i++)
758 if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
759 sprintf(combuf, vval(BASENAME), i);
760 strcat(combuf, ".unf");
761 close(open(combuf, O_RDONLY|O_CREAT, 0666));
762 }
763 /* create command */
764 sprintf(combuf, "rpict%s%s -w0", rendopt,
765 viewopt(getview(first>1 ? first-1 : 1)));
766 inspoint = combuf;
767 while (*inspoint) inspoint++;
768 if (nblur) {
769 sprintf(inspoint, " -pm %.3f", mblurf/nblur);
770 while (*inspoint) inspoint++;
771 sprintf(inspoint, " -pd %.3f", dblurf/nblur);
772 while (*inspoint) inspoint++;
773 }
774 if (nblur > 1 || vint(INTERP)) {
775 sprintf(inspoint, " -z %s.zbf", vval(BASENAME));
776 while (*inspoint) inspoint++;
777 }
778 sprintf(inspoint, " -o %s.unf %s -S %d",
779 vval(BASENAME), rresopt, first);
780 while (*inspoint) inspoint++;
781 sprintf(inspoint, " %s < %s", vval(OCTREE), vfn);
782 /* run in parallel */
783 i = (last-first+1)/(vint(INTERP)+1);
784 if (i < 1) i = 1;
785 if (pruncom(combuf, inspoint, i)) {
786 fprintf(stderr, "%s: error rendering frames %d through %d\n",
787 progname, first, last);
788 quit(1);
789 }
790 if (!noaction && vint(INTERP)) /* remove dummy frames */
791 for (i = first; i <= last; i++)
792 if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
793 sprintf(combuf, vval(BASENAME), i);
794 strcat(combuf, ".unf");
795 unlink(combuf);
796 }
797 }
798
799
800 static int
801 recover(int frame) /* recover the specified frame */
802 {
803 static int *rfrm; /* list of recovered frames */
804 static int nrfrms = 0;
805 double mblurf, dblurf;
806 int nblur = getblur(&mblurf, &dblurf);
807 char combuf[2048];
808 char fname[128];
809 register char *cp;
810 register int i;
811 /* check to see if recovered already */
812 for (i = nrfrms; i--; )
813 if (rfrm[i] == frame)
814 return(0);
815 /* build command */
816 sprintf(fname, vval(BASENAME), frame);
817 if (vdef(ANIMATE))
818 sprintf(combuf, "%s %d | rpict%s -w0",
819 vval(ANIMATE), frame, rendopt);
820 else
821 sprintf(combuf, "rpict%s -w0", rendopt);
822 cp = combuf;
823 while (*cp) cp++;
824 if (nblur) {
825 sprintf(cp, " -pm %.3f", mblurf/nblur);
826 while (*cp) cp++;
827 sprintf(cp, " -pd %.3f", dblurf/nblur);
828 while (*cp) cp++;
829 }
830 if (nblur > 1 || vint(INTERP)) {
831 sprintf(cp, " -z %s.zbf", fname);
832 while (*cp) cp++;
833 }
834 sprintf(cp, " -ro %s.unf", fname);
835 while (*cp) cp++;
836 if (!vdef(ANIMATE)) {
837 *cp++ = ' ';
838 strcpy(cp, vval(OCTREE));
839 }
840 if (runcom(combuf)) /* run command */
841 return(1);
842 /* add frame to recovered list */
843 if (nrfrms)
844 rfrm = (int *)realloc((void *)rfrm, (nrfrms+1)*sizeof(int));
845 else
846 rfrm = (int *)malloc(sizeof(int));
847 if (rfrm == NULL) {
848 perror("malloc");
849 quit(1);
850 }
851 rfrm[nrfrms++] = frame;
852 return(0);
853 }
854
855
856 static int
857 frecover(int frame) /* recover filtered frame */
858 {
859 if (dofilt(frame, 2) && dofilt(frame, 1))
860 return(1);
861 return(0);
862 }
863
864
865 static void
866 archive(void) /* archive and remove renderings */
867 {
868 #define RMCOML (sizeof(rmcom)-1)
869 static char rmcom[] = "rm -f";
870 char basedir[128];
871 int dlen, alen;
872 register int j;
873
874 if (arcnext == arcfirst)
875 return; /* nothing to do */
876 dirfile(basedir, vval(BASENAME));
877 dlen = strlen(basedir);
878 if (vdef(ARCHIVE)) { /* run archive command */
879 alen = strlen(vval(ARCHIVE));
880 if (dlen) {
881 j = alen + dlen + 5;
882 strncpy(arcfirst-j, "cd ", 3);
883 strncpy(arcfirst-j+3, basedir, dlen);
884 (arcfirst-j)[dlen+3] = ';'; (arcfirst-j)[dlen+4] = ' ';
885 } else
886 j = alen;
887 strncpy(arcfirst-alen, vval(ARCHIVE), alen);
888 if (runcom(arcfirst-j)) {
889 fprintf(stderr, "%s: error running archive command\n",
890 progname);
891 quit(1);
892 }
893 }
894 if (dlen) {
895 j = RMCOML + dlen + 5;
896 strncpy(arcfirst-j, "cd ", 3);
897 strncpy(arcfirst-j+3, basedir, dlen);
898 (arcfirst-j)[dlen+3] = ';'; (arcfirst-j)[dlen+4] = ' ';
899 } else
900 j = RMCOML;
901 /* run remove command */
902 strncpy(arcfirst-RMCOML, rmcom, RMCOML);
903 runcom(arcfirst-j);
904 arcnext = arcfirst; /* reset argument list */
905 #undef RMCOML
906 }
907
908
909 static int
910 dofilt( /* filter frame */
911 int frame,
912 int rvr
913 )
914 {
915 static int iter = 0;
916 double mblurf, dblurf;
917 int nblur = getblur(&mblurf, &dblurf);
918 VIEW *vp = getview(frame);
919 char *ep = getexp(frame);
920 char fnbefore[128], fnafter[128], *fbase;
921 char combuf[1024], fname0[128], fname1[128];
922 int usepinterp, usepfilt, nora_rgbe;
923 int frseq[2];
924 /* check what is needed */
925 if (vp == NULL) {
926 fprintf(stderr,
927 "%s: unexpected error reading view for frame %d\n",
928 progname, frame);
929 quit(1);
930 }
931 usepinterp = (nblur > 1);
932 usepfilt = pfiltalways | (ep==NULL);
933 if (ep != NULL && !strcmp(ep, "1"))
934 ep = "+0";
935 nora_rgbe = strcmp(vval(OVERSAMP),"1") || ep==NULL ||
936 *ep != '+' || *ep != '-' || !isint(ep);
937 /* compute rendered views */
938 frseq[0] = frame - ((frame-1) % (vint(INTERP)+1));
939 frseq[1] = frseq[0] + vint(INTERP) + 1;
940 fbase = dirfile(NULL, vval(BASENAME));
941 if (frseq[1] > vint(END))
942 frseq[1] = vint(END);
943 if (frseq[1] == frame) { /* pfilt only */
944 frseq[0] = frseq[1];
945 usepinterp = 0; /* update what's needed */
946 usepfilt |= nora_rgbe;
947 } else if (frseq[0] == frame) { /* no interpolation needed */
948 if (!rvr && frame > 1+vint(INTERP)) { /* archive previous */
949 if (arcnext - arcargs +
950 strlen(fbase) >= sizeof(arcargs)-8) {
951 fprintf(stderr,
952 "%s: too many filenames in archive command -- reduce %s variable\n",
953 progname, vnam(DISKSPACE));
954 quit(1);
955 }
956 *arcnext++ = ' ';
957 sprintf(arcnext, fbase, frame-vint(INTERP)-1);
958 while (*arcnext) arcnext++;
959 strcpy(arcnext, ".unf");
960 arcnext += 4;
961 if (usepinterp || vint(INTERP)) { /* and Z-buf */
962 *arcnext++ = ' ';
963 sprintf(arcnext, fbase, frame-vint(INTERP)-1);
964 while (*arcnext) arcnext++;
965 strcpy(arcnext, ".zbf");
966 arcnext += 4;
967 }
968 }
969 if (!usepinterp) /* update what's needed */
970 usepfilt |= nora_rgbe;
971 } else /* interpolation needed */
972 usepinterp++;
973 if (frseq[1] >= astat.rnext) /* next batch unavailable */
974 frseq[1] = frseq[0];
975 sprintf(fnbefore, vval(BASENAME), frseq[0]);
976 sprintf(fnafter, vval(BASENAME), frseq[1]);
977 if (rvr == 1 && recover(frseq[0])) /* recover before frame? */
978 return(1);
979 /* generate command */
980 if (usepinterp) { /* using pinterp */
981 if (rvr == 2 && recover(frseq[1])) /* recover after? */
982 return(1);
983 if (nblur > 1) { /* with pdmblur */
984 sprintf(fname0, "%s/vw0%c", vval(DIRECTORY),
985 'a'+(iter%26));
986 sprintf(fname1, "%s/vw1%c", vval(DIRECTORY),
987 'a'+(iter%26));
988 if (!noaction) {
989 FILE *fp; /* motion blurring */
990 if ((fp = fopen(fname0, "w")) == NULL) {
991 perror(fname0); quit(1);
992 }
993 fputs(VIEWSTR, fp);
994 fprintview(vp, fp);
995 putc('\n', fp); fclose(fp);
996 if ((vp = getview(frame+1)) == NULL) {
997 fprintf(stderr,
998 "%s: unexpected error reading view for frame %d\n",
999 progname, frame+1);
1000 quit(1);
1001 }
1002 if ((fp = fopen(fname1, "w")) == NULL) {
1003 perror(fname1); quit(1);
1004 }
1005 fputs(VIEWSTR, fp);
1006 fprintview(vp, fp);
1007 putc('\n', fp); fclose(fp);
1008 }
1009 sprintf(combuf,
1010 "(pmdblur %.3f %.3f %d %s %s; rm -f %s %s) | pinterp -B -a",
1011 mblurf, dblurf, nblur,
1012 fname0, fname1, fname0, fname1);
1013 iter++;
1014 } else /* no blurring */
1015 strcpy(combuf, "pinterp");
1016 strcat(combuf, viewopt(vp));
1017 if (vbool(RTRACE))
1018 sprintf(combuf+strlen(combuf), " -ff -fr '%s -w0 %s'",
1019 rendopt+1, vval(OCTREE));
1020 if (vdef(PINTERP))
1021 sprintf(combuf+strlen(combuf), " %s", vval(PINTERP));
1022 if (usepfilt)
1023 sprintf(combuf+strlen(combuf), " %s", rresopt);
1024 else
1025 sprintf(combuf+strlen(combuf), " -a %s -e %s",
1026 fresopt, ep);
1027 sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
1028 fnbefore, fnbefore);
1029 if (frseq[1] != frseq[0])
1030 sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
1031 fnafter, fnafter);
1032 if (usepfilt) { /* also pfilt */
1033 if (vdef(PFILT))
1034 sprintf(combuf+strlen(combuf), " | pfilt %s",
1035 vval(PFILT));
1036 else
1037 strcat(combuf, " | pfilt");
1038 if (ep != NULL)
1039 sprintf(combuf+strlen(combuf), " -1 -e %s %s",
1040 ep, fresopt);
1041 else
1042 sprintf(combuf+strlen(combuf), " %s", fresopt);
1043 }
1044 } else if (usepfilt) { /* pfilt only */
1045 if (rvr == 2)
1046 return(1);
1047 if (vdef(PFILT))
1048 sprintf(combuf, "pfilt %s", vval(PFILT));
1049 else
1050 strcpy(combuf, "pfilt");
1051 if (ep != NULL)
1052 sprintf(combuf+strlen(combuf), " -1 -e %s %s %s.unf",
1053 ep, fresopt, fnbefore);
1054 else
1055 sprintf(combuf+strlen(combuf), " %s %s.unf",
1056 fresopt, fnbefore);
1057 } else { /* else just check it */
1058 if (rvr == 2)
1059 return(1);
1060 sprintf(combuf, "ra_rgbe -e %s -r %s.unf", ep, fnbefore);
1061 }
1062 /* output file name */
1063 sprintf(fname0, vval(BASENAME), frame);
1064 sprintf(combuf+strlen(combuf), " > %s.pic", fname0);
1065 if (rvr) /* in recovery */
1066 return(runcom(combuf));
1067 bruncom(combuf, frame, frecover); /* else run in background */
1068 return(0);
1069 }
1070
1071
1072 static VIEW *
1073 getview(int n) /* get view number n */
1074 {
1075 static FILE *viewfp = NULL; /* view file pointer */
1076 static int viewnum = 0; /* current view number */
1077 static VIEW curview = STDVIEW; /* current view */
1078 char linebuf[256];
1079
1080 if (n == 0) { /* signal to close file and clean up */
1081 if (viewfp != NULL) {
1082 fclose(viewfp);
1083 viewfp = NULL;
1084 viewnum = 0;
1085 curview = stdview;
1086 }
1087 return(NULL);
1088 }
1089 if (viewfp == NULL) { /* open file */
1090 if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) {
1091 perror(vval(VIEWFILE));
1092 quit(1);
1093 }
1094 } else if (n > 0 && n < viewnum) { /* rewind file */
1095 if (viewnum == 1 && feof(viewfp))
1096 return(&curview); /* just one view */
1097 if (fseek(viewfp, 0L, 0) == EOF) {
1098 perror(vval(VIEWFILE));
1099 quit(1);
1100 }
1101 curview = stdview;
1102 viewnum = 0;
1103 }
1104 if (n < 0) { /* get next view */
1105 register int c = getc(viewfp);
1106 if (c == EOF)
1107 return((VIEW *)NULL); /* that's it */
1108 ungetc(c, viewfp);
1109 n = viewnum + 1;
1110 }
1111 while (n > viewnum) { /* scan to desired view */
1112 if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL)
1113 return(viewnum==1 ? &curview : (VIEW *)NULL);
1114 if (isview(linebuf) && sscanview(&curview, linebuf) > 0)
1115 viewnum++;
1116 }
1117 return(&curview); /* return it */
1118 }
1119
1120
1121 static int
1122 countviews(void) /* count views in view file */
1123 {
1124 int n;
1125
1126 if (getview(n=1) == NULL)
1127 return(0);
1128 while (getview(-1) != NULL)
1129 n++;
1130 return(n);
1131 }
1132
1133
1134 static char *
1135 getexp(int n) /* get exposure for nth frame */
1136 {
1137 static char expval[32];
1138 static FILE *expfp = NULL;
1139 static long *exppos;
1140 static int curfrm;
1141 register char *cp;
1142
1143 if (n == 0) { /* signal to close file */
1144 if (expfp != NULL) {
1145 fclose(expfp);
1146 free((void *)exppos);
1147 expfp = NULL;
1148 }
1149 return(NULL);
1150 } else if (n > vint(END)) /* request past end (error?) */
1151 return(NULL);
1152 if (!vdef(EXPOSURE)) /* no setting (auto) */
1153 return(NULL);
1154 if (isflt(vval(EXPOSURE))) /* always the same */
1155 return(vval(EXPOSURE));
1156 if (expfp == NULL) { /* open exposure file */
1157 if ((expfp = fopen(vval(EXPOSURE), "r")) == NULL) {
1158 fprintf(stderr,
1159 "%s: cannot open exposure file \"%s\"\n",
1160 progname, vval(EXPOSURE));
1161 quit(1);
1162 }
1163 curfrm = vint(END) + 1; /* init lookup tab. */
1164 exppos = (long *)malloc(curfrm*sizeof(long *));
1165 if (exppos == NULL) {
1166 perror(progname);
1167 quit(1);
1168 }
1169 while (curfrm--)
1170 exppos[curfrm] = -1L;
1171 curfrm = 0;
1172 }
1173 /* find position in file */
1174 if (n-1 != curfrm && n != curfrm && exppos[n-1] >= 0 &&
1175 fseek(expfp, exppos[curfrm=n-1], 0) == EOF) {
1176 fprintf(stderr, "%s: seek error on exposure file\n", progname);
1177 quit(1);
1178 }
1179 while (n > curfrm) { /* read exposure */
1180 if (exppos[curfrm] < 0)
1181 exppos[curfrm] = ftell(expfp);
1182 if (fgets(expval, sizeof(expval), expfp) == NULL) {
1183 fprintf(stderr, "%s: too few exposures\n",
1184 vval(EXPOSURE));
1185 quit(1);
1186 }
1187 curfrm++;
1188 cp = fskip(expval); /* check format */
1189 if (cp != NULL)
1190 while (isspace(*cp))
1191 *cp++ = '\0';
1192 if (cp == NULL || *cp) {
1193 fprintf(stderr,
1194 "%s: exposure format error on line %d\n",
1195 vval(EXPOSURE), curfrm);
1196 quit(1);
1197 }
1198 }
1199 return(expval); /* return value */
1200 }
1201
1202
1203 static struct pslot *
1204 findpslot(RT_PID pid) /* find or allocate a process slot */
1205 {
1206 register struct pslot *psempty = NULL;
1207 register int i;
1208
1209 for (i = 0; i < npslots; i++) { /* look for match */
1210 if (pslot[i].pid == pid)
1211 return(pslot+i);
1212 if (psempty == NULL && pslot[i].pid == 0)
1213 psempty = pslot+i;
1214 }
1215 return(psempty); /* return emtpy slot (error if NULL) */
1216 }
1217
1218
1219 static int
1220 donecom( /* clean up after finished process */
1221 PSERVER *ps,
1222 int pn,
1223 int status
1224 )
1225 {
1226 register NETPROC *pp;
1227 register struct pslot *psl;
1228
1229 pp = ps->proc + pn;
1230 if (pp->elen) { /* pass errors */
1231 if (ps->hostname[0])
1232 fprintf(stderr, "%s: ", ps->hostname);
1233 fprintf(stderr, "Error output from: %s\n", pp->com);
1234 fputs(pp->errs, stderr);
1235 fflush(stderr);
1236 if (ps->hostname[0])
1237 status = 1; /* because rsh doesn't return status */
1238 }
1239 lastpserver = NULL;
1240 psl = findpslot(pp->pid); /* check for bruncom() slot */
1241 if (psl->pid) {
1242 if (status) {
1243 if (psl->rcvf != NULL) /* attempt recovery */
1244 status = (*psl->rcvf)(psl->fout);
1245 if (status) {
1246 fprintf(stderr,
1247 "%s: error rendering frame %d\n",
1248 progname, psl->fout);
1249 quit(1);
1250 }
1251 lastpserver = ps;
1252 }
1253 psl->pid = 0; /* free process slot */
1254 } else if (status)
1255 lastpserver = ps;
1256 freestr(pp->com); /* free command string */
1257 return(status);
1258 }
1259
1260
1261 static int
1262 serverdown(void) /* check status of last process server */
1263 {
1264 if (lastpserver == NULL || !lastpserver->hostname[0])
1265 return(0);
1266 if (pserverOK(lastpserver)) /* server still up? */
1267 return(0);
1268 delpserver(lastpserver); /* else delete it */
1269 if (pslist == NULL) {
1270 fprintf(stderr, "%s: all process servers are down\n",
1271 progname);
1272 quit(1);
1273 }
1274 return(1);
1275 }
1276
1277
1278 static RT_PID
1279 bruncom( /* run a command in the background */
1280 char *com,
1281 int fout,
1282 int (*rf)()
1283 )
1284 {
1285 RT_PID pid;
1286 register struct pslot *psl;
1287
1288 if (noaction) {
1289 if (!silent)
1290 printf("\t%s\n", com); /* echo command */
1291 return(0);
1292 }
1293 com = savestr(com); /* else start it when we can */
1294 while ((pid = startjob(NULL, com, donecom)) == -1)
1295 bwait(1);
1296 if (!silent) { /* echo command */
1297 PSERVER *ps;
1298 RT_PID psn = pid;
1299 ps = findjob(&psn);
1300 printf("\t%s\n", com);
1301 printf("\tProcess started on %s\n", phostname(ps));
1302 fflush(stdout);
1303 }
1304 psl = findpslot(pid); /* record info. in appropriate slot */
1305 psl->pid = pid;
1306 psl->fout = fout;
1307 psl->rcvf = rf;
1308 return(pid);
1309 }
1310
1311
1312 static void
1313 bwait(int ncoms) /* wait for batch job(s) to finish */
1314 {
1315 int status;
1316
1317 if (noaction)
1318 return;
1319 while ((status = wait4job(NULL, -1)) != -1) {
1320 serverdown(); /* update server status */
1321 if (--ncoms == 0)
1322 break; /* done enough */
1323 }
1324 }
1325
1326
1327 static int
1328 pruncom( /* run a command in parallel over network */
1329 char *com,
1330 char *ppins,
1331 int maxcopies
1332 )
1333 {
1334 int retstatus = 0;
1335 int hostcopies;
1336 char buf[10240], *com1, *s;
1337 int status;
1338 int pfd;
1339 register int n;
1340 register PSERVER *ps;
1341
1342 if (!silent)
1343 printf("\t%s\n", com); /* echo command */
1344 if (noaction)
1345 return(0);
1346 fflush(stdout);
1347 /* start jobs on each server */
1348 for (ps = pslist; ps != NULL; ps = ps->next) {
1349 hostcopies = 0;
1350 if (maxcopies > 1 && ps->nprocs > 1 && ppins != NULL) {
1351 strcpy(com1=buf, com); /* build -PP command */
1352 sprintf(com1+(ppins-com), " -PP %s/%s.persist",
1353 vval(DIRECTORY), phostname(ps));
1354 unlink(com1+(ppins-com)+5);
1355 strcat(com1, ppins);
1356 } else
1357 com1 = com;
1358 while (maxcopies > 0) {
1359 s = savestr(com1);
1360 if (startjob(ps, s, donecom) != -1) {
1361 sleep(20);
1362 hostcopies++;
1363 maxcopies--;
1364 } else {
1365 freestr(s);
1366 break;
1367 }
1368 }
1369 if (!silent && hostcopies) {
1370 if (hostcopies > 1)
1371 printf("\t%d duplicate processes", hostcopies);
1372 else
1373 printf("\tProcess");
1374 printf(" started on %s\n", phostname(ps));
1375 fflush(stdout);
1376 }
1377 }
1378 /* wait for jobs to finish */
1379 while ((status = wait4job(NULL, -1)) != -1)
1380 retstatus += status && !serverdown();
1381 /* terminate parallel rpict's */
1382 for (ps = pslist; ps != NULL; ps = ps->next) {
1383 sprintf(buf, "%s/%s.persist", vval(DIRECTORY), phostname(ps));
1384 if ((pfd = open(buf, O_RDONLY)) >= 0) {
1385 n = read(pfd, buf, sizeof(buf)-1); /* get PID */
1386 buf[n] = '\0';
1387 close(pfd);
1388 for (n = 0; buf[n] && !isspace(buf[n]); n++)
1389 ;
1390 /* terminate */
1391 sprintf(buf, "kill -ALRM %d", atoi(buf+n));
1392 wait4job(ps, startjob(ps, buf, NULL));
1393 }
1394 }
1395 return(retstatus);
1396 }
1397
1398
1399 static int
1400 runcom(char *cs) /* run a command locally and wait for it */
1401 {
1402 if (!silent) /* echo it */
1403 printf("\t%s\n", cs);
1404 if (noaction)
1405 return(0);
1406 fflush(stdout); /* flush output and pass to shell */
1407 return(system(cs));
1408 }
1409
1410
1411 static int
1412 rmfile(char *fn) /* remove a file */
1413 {
1414 if (!silent)
1415 #ifdef _WIN32
1416 printf("\tdel %s\n", fn);
1417 #else
1418 printf("\trm -f %s\n", fn);
1419 #endif
1420 if (noaction)
1421 return(0);
1422 return(unlink(fn));
1423 }
1424
1425
1426 static void
1427 badvalue(int vc) /* report bad variable value and exit */
1428 {
1429 fprintf(stderr, "%s: bad value for variable '%s'\n",
1430 progname, vnam(vc));
1431 quit(1);
1432 }
1433
1434
1435 static char *
1436 dirfile( /* separate path into directory and file */
1437 char *df,
1438 register char *path
1439 )
1440 {
1441 register int i;
1442 int psep;
1443
1444 for (i = 0, psep = -1; path[i]; i++)
1445 if (path[i] == '/')
1446 psep = i;
1447 if (df != NULL) {
1448 if (psep == 0) {
1449 df[0] = '/';
1450 df[1] = '\0';
1451 } else if (psep > 0) {
1452 strncpy(df, path, psep);
1453 df[psep] = '\0';
1454 } else
1455 df[0] = '\0';
1456 }
1457 return(path+psep+1);
1458 }
1459
1460
1461 static int
1462 getblur(double *mbf, double *dbf) /* get # blur samples (and fraction) */
1463 {
1464 double mblurf, dblurf;
1465 int nmblur, ndblur;
1466 char *s;
1467 /* get motion blur */
1468 if (!vdef(MBLUR) || (mblurf = atof(vval(MBLUR))) < 0.0)
1469 mblurf = 0.0;
1470 if (mbf != NULL)
1471 *mbf = mblurf;
1472 if (mblurf <= FTINY)
1473 nmblur = 0;
1474 else if (!*(s = sskip(vval(MBLUR))))
1475 nmblur = DEF_NBLUR;
1476 else if ((nmblur = atoi(s)) <= 0)
1477 nmblur = 1;
1478 /* get depth-of-field blur */
1479 if (!vdef(DBLUR) || (dblurf = atof(vval(DBLUR))) < 0.0)
1480 dblurf = 0.0;
1481 if (dbf != NULL)
1482 *dbf = dblurf;
1483 if (dblurf <= FTINY)
1484 ndblur = 0;
1485 else if (!*(s = sskip(vval(DBLUR))))
1486 ndblur = DEF_NBLUR;
1487 else if ((ndblur = atoi(s)) <= 0)
1488 ndblur = 1;
1489 if ((nmblur == 1) & (ndblur == 1))
1490 return(1);
1491 /* return combined samples */
1492 return(nmblur + ndblur);
1493 }
