--- ray/src/util/ranimate.c 2004/03/26 21:36:20 2.46 +++ ray/src/util/ranimate.c 2005/01/18 03:59:41 2.48 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ranimate.c,v 2.46 2004/03/26 21:36:20 schorsch Exp $"; +static const char RCSid[] = "$Id: ranimate.c,v 2.48 2005/01/18 03:59:41 greg Exp $"; #endif /* * Radiance animation control program @@ -23,9 +23,7 @@ static const char RCSid[] = "$Id: ranimate.c,v 2.46 20 #include "platform.h" #include "paths.h" -#include "rtio.h" -#include "rterror.h" -#include "rtmisc.h" +#include "standard.h" #include "view.h" #include "vars.h" #include "netproc.h" @@ -39,33 +37,35 @@ static const char RCSid[] = "$Id: ranimate.c,v 2.46 20 #define ANIMATE 0 /* animation command */ #define ARCHIVE 1 /* archiving command */ #define BASENAME 2 /* output image base name */ -#define DIRECTORY 3 /* working (sub)directory */ -#define DISKSPACE 4 /* how much disk space to use */ -#define END 5 /* ending frame number */ -#define EXPOSURE 6 /* how to compute exposure */ -#define HOST 7 /* rendering host machine */ -#define INTERP 8 /* # frames to interpolate */ -#define MBLUR 9 /* motion blur parameters */ -#define NEXTANIM 10 /* next animation file */ -#define OCTREE 11 /* octree file name */ -#define OVERSAMP 12 /* # times to oversample image */ -#define PFILT 13 /* pfilt options */ -#define PINTERP 14 /* pinterp options */ -#define RENDER 15 /* rendering options */ -#define RESOLUTION 16 /* desired final resolution */ -#define RIF 17 /* rad input file */ -#define RSH 18 /* remote shell script or program */ -#define RTRACE 19 /* use rtrace with pinterp? */ -#define START 20 /* starting frame number */ -#define TRANSFER 21 /* frame transfer command */ -#define VIEWFILE 22 /* animation frame views */ +#define DBLUR 3 /* depth of field blur */ +#define DIRECTORY 4 /* working (sub)directory */ +#define DISKSPACE 5 /* how much disk space to use */ +#define END 6 /* ending frame number */ +#define EXPOSURE 7 /* how to compute exposure */ +#define HOST 8 /* rendering host machine */ +#define INTERP 9 /* # frames to interpolate */ +#define MBLUR 10 /* motion blur parameters */ +#define NEXTANIM 11 /* next animation file */ +#define OCTREE 12 /* octree file name */ +#define OVERSAMP 13 /* # times to oversample image */ +#define PFILT 14 /* pfilt options */ +#define PINTERP 15 /* pinterp options */ +#define RENDER 16 /* rendering options */ +#define RESOLUTION 17 /* desired final resolution */ +#define RIF 18 /* rad input file */ +#define RSH 19 /* remote shell script or program */ +#define RTRACE 20 /* use rtrace with pinterp? */ +#define START 21 /* starting frame number */ +#define TRANSFER 22 /* frame transfer command */ +#define VIEWFILE 23 /* animation frame views */ -int NVARS = 23; /* total number of variables */ +int NVARS = 24; /* total number of variables */ VARIABLE vv[] = { /* variable-value pairs */ {"ANIMATE", 2, 0, NULL, onevalue}, {"ARCHIVE", 2, 0, NULL, onevalue}, {"BASENAME", 3, 0, NULL, onevalue}, + {"DBLUR", 2, 0, NULL, onevalue}, {"DIRECTORY", 3, 0, NULL, onevalue}, {"DISKSPACE", 3, 0, NULL, fltvalue}, {"END", 2, 0, NULL, intvalue}, @@ -131,7 +131,7 @@ static VIEW * getview(int n); static char * dirfile(char *df, register char *path); static char * getexp(int n); -static int getblur(double *bf); +static int getblur(double *mbf, double *dbf); static int getastat(void); static void getradfile(char *rfargs); static void badvalue(int vc); @@ -569,7 +569,7 @@ animate(void) /* run animation */ } /* figure # frames per batch */ d1 = mult*xres*mult*yres*4; /* space for orig. picture */ - if ((i=vint(INTERP)) || getblur(NULL) > 1) + if ((i=vint(INTERP)) || getblur(NULL, NULL) > 1) d1 += mult*xres*mult*yres*sizeof(float); /* Z-buffer */ d2 = xres*yres*4; /* space for final picture */ frames_batch = (i+1)*(vflt(DISKSPACE)*1048576.-d1)/(d1+i*d2); @@ -742,8 +742,8 @@ int last, char *vfn ) { - double blurf; - int nblur = getblur(&blurf); + double mblurf, dblurf; + int nblur = getblur(&mblurf, &dblurf); char combuf[2048]; register char *inspoint; register int i; @@ -761,8 +761,10 @@ char *vfn inspoint = combuf; while (*inspoint) inspoint++; if (nblur) { - sprintf(inspoint, " -pm %.3f", blurf/nblur); + sprintf(inspoint, " -pm %.3f", mblurf/nblur); while (*inspoint) inspoint++; + sprintf(inspoint, " -pd %.3f", dblurf/nblur); + while (*inspoint) inspoint++; } if (nblur > 1 || vint(INTERP)) { sprintf(inspoint, " -z %s.zbf", vval(BASENAME)); @@ -795,8 +797,8 @@ recover(int frame) /* recover the specified frame */ { static int *rfrm; /* list of recovered frames */ static int nrfrms = 0; - double blurf; - int nblur = getblur(&blurf); + double mblurf, dblurf; + int nblur = getblur(&mblurf, &dblurf); char combuf[2048]; char fname[128]; register char *cp; @@ -815,8 +817,10 @@ recover(int frame) /* recover the specified frame */ cp = combuf; while (*cp) cp++; if (nblur) { - sprintf(cp, " -pm %.3f", blurf/nblur); + sprintf(cp, " -pm %.3f", mblurf/nblur); while (*cp) cp++; + sprintf(cp, " -pd %.3f", dblurf/nblur); + while (*cp) cp++; } if (nblur > 1 || vint(INTERP)) { sprintf(cp, " -z %s.zbf", fname); @@ -904,8 +908,8 @@ int rvr ) { static int iter = 0; - double blurf; - int nblur = getblur(&blurf); + double mblurf, dblurf; + int nblur = getblur(&mblurf, &dblurf); VIEW *vp = getview(frame); char *ep = getexp(frame); char fnbefore[128], fnafter[128], *fbase; @@ -964,7 +968,7 @@ int rvr if (usepinterp) { /* using pinterp */ if (rvr == 2 && recover(frseq[1])) /* recover after? */ return(1); - if (nblur > 1) { /* with pmblur */ + if (nblur > 1) { /* with pdmblur */ sprintf(fname0, "%s/vw0%c", vval(DIRECTORY), 'a'+(iter%26)); sprintf(fname1, "%s/vw1%c", vval(DIRECTORY), @@ -991,8 +995,8 @@ int rvr putc('\n', fp); fclose(fp); } sprintf(combuf, - "(pmblur %.3f %d %s %s; rm -f %s %s) | pinterp -B -a", - blurf, nblur, + "(pmdblur %.3f %.3f %d %s %s; rm -f %s %s) | pinterp -B -a", + mblurf, dblurf, nblur, fname0, fname1, fname0, fname1); iter++; } else /* no blurring */ @@ -1444,29 +1448,35 @@ register char *path static int -getblur(double *bf) /* get # blur samples (and fraction) */ +getblur(double *mbf, double *dbf) /* get # blur samples (and fraction) */ { - double blurf; - int nblur; + double mblurf, dblurf; + int nmblur, ndblur; char *s; - - if (!vdef(MBLUR)) { - if (bf != NULL) - *bf = 0.0; - return(0); - } - blurf = atof(vval(MBLUR)); - if (blurf < 0.0) - blurf = 0.0; - if (bf != NULL) - *bf = blurf; - if (blurf <= FTINY) - return(0); - s = sskip(vval(MBLUR)); - if (!*s) - return(DEF_NBLUR); - nblur = atoi(s); - if (nblur <= 0) + /* get motion blur */ + if (!vdef(MBLUR) || (mblurf = atof(vval(MBLUR))) < 0.0) + mblurf = 0.0; + if (mbf != NULL) + *mbf = mblurf; + if (mblurf <= FTINY) + nmblur = 0; + else if (!*(s = sskip(vval(MBLUR)))) + nmblur = DEF_NBLUR; + else if ((nmblur = atoi(s)) <= 0) + nmblur = 1; + /* get depth-of-field blur */ + if (!vdef(DBLUR) || (dblurf = atof(vval(DBLUR))) < 0.0) + dblurf = 0.0; + if (dbf != NULL) + *dbf = dblurf; + if (dblurf <= FTINY) + ndblur = 0; + else if (!*(s = sskip(vval(DBLUR)))) + ndblur = DEF_NBLUR; + else if ((ndblur = atoi(s)) <= 0) + ndblur = 1; + if ((nmblur == 1) & (ndblur == 1)) return(1); - return(nblur); + /* return combined samples */ + return(nmblur + ndblur); }
