--- ray/src/util/ranimate.c 1996/01/23 17:01:33 2.6 +++ ray/src/util/ranimate.c 1998/02/26 10:27:45 2.24 @@ -1,4 +1,4 @@ -/* Copyright (c) 1995 Regents of the University of California */ +/* Copyright (c) 1996 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,6 +15,12 @@ static char SCCSid[] = "$SunId$ LBL"; #include "view.h" #include "vars.h" #include "netproc.h" + /* default remote shell */ +#ifdef _AUX_SOURCE +#define REMSH "remsh" +#else +#define REMSH "rsh" +#endif /* input variables */ #define HOST 0 /* rendering host machine */ #define RENDER 1 /* rendering options */ @@ -38,8 +44,9 @@ static char SCCSid[] = "$SunId$ LBL"; #define DISKSPACE 19 /* how much disk space to use */ #define RESOLUTION 20 /* desired final resolution */ #define EXPOSURE 21 /* how to compute exposure */ +#define RSH 22 /* remote shell script or program */ -int NVARS = 22; /* total number of variables */ +int NVARS = 23; /* total number of variables */ VARIABLE vv[] = { /* variable-value pairs */ {"host", 4, 0, NULL, NULL}, @@ -64,6 +71,7 @@ VARIABLE vv[] = { /* variable-value pairs */ {"DISKSPACE", 3, 0, NULL, fltvalue}, {"RESOLUTION", 3, 0, NULL, onevalue}, {"EXPOSURE", 3, 0, NULL, onevalue}, + {"RSH", 3, 0, NULL, onevalue}, }; #define SFNAME "STATUS" /* status file name */ @@ -84,11 +92,15 @@ int nowarn = 0; /* turn warnings off? */ int silent = 0; /* silent mode? */ int noaction = 0; /* take no action? */ -char rendopt[2048] = ""; /* rendering options */ +char *remsh; /* remote shell program/script */ +char rendopt[2048]; /* rendering options */ char rresopt[32]; /* rendering resolution options */ char fresopt[32]; /* filter resolution options */ int pfiltalways; /* always use pfilt? */ +char arcargs[10240]; /* files to archive */ +char *arcfirst, *arcnext; /* pointers to first and next argument */ + struct pslot { int pid; /* process ID (0 if empty) */ int fout; /* output frame number */ @@ -96,17 +108,18 @@ struct pslot { } *pslot; /* process slots */ int npslots; /* number of process slots */ -int lastpid; /* ID of last completed background process */ -PSERVER *lastpserver; /* last process server used */ - #define phostname(ps) ((ps)->hostname[0] ? (ps)->hostname : astat.host) struct pslot *findpslot(); +PSERVER *lastpserver; /* last process server with error */ + VIEW *getview(); char *getexp(); +extern time_t fdate(), time(); + main(argc, argv) int argc; char *argv[]; @@ -137,6 +150,8 @@ char *argv[]; cfname = argv[i]; /* load variables */ loadvars(cfname); + /* check variables */ + checkvalues(); /* did we get DIRECTORY? */ checkdir(); /* check status */ @@ -163,8 +178,11 @@ char *argv[]; argv[i] = vval(NEXTANIM); /* just change input file */ if (!silent) printargs(argc, argv, stdout); - execvp(progname, argv); /* pass to next */ - quit(1); /* shouldn't return */ + if ((argv[0] = getpath(progname,getenv("PATH"),X_OK)) == NULL) + fprintf(stderr, "%s: command not found\n", progname); + else + execv(progname, argv); + quit(1); } quit(0); userr: @@ -175,13 +193,13 @@ userr: getastat() /* check/set animation status */ { - char buf[256]; + char sfname[256]; FILE *fp; - sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME); - if ((fp = fopen(buf, "r")) == NULL) { + sprintf(sfname, "%s/%s", vval(DIRECTORY), SFNAME); + if ((fp = fopen(sfname, "r")) == NULL) { if (errno != ENOENT) { - perror(buf); + perror(sfname); return(-1); } astat.rnext = astat.fnext = astat.tnext = 0; @@ -201,8 +219,7 @@ getastat() /* check/set animation status */ goto fmterr; fclose(fp); if (astat.pid != 0) { /* thinks it's still running */ - gethostname(buf, sizeof(buf)); - if (strcmp(buf, astat.host)) { + if (strcmp(myhostname(), astat.host)) { fprintf(stderr, "%s: process %d may still be running on host %s\n", progname, astat.pid, astat.host); @@ -215,19 +232,24 @@ getastat() /* check/set animation status */ } /* assume it is dead */ } - if (strcmp(cfname, astat.cfname) && astat.tnext != 0) { /* other's */ + if (strcmp(cfname, astat.cfname) && astat.pid != 0) { /* other's */ fprintf(stderr, "%s: unfinished job \"%s\"\n", progname, astat.cfname); return(-1); } + /* check control file mods. */ + if (!nowarn && fdate(cfname) > fdate(sfname)) + fprintf(stderr, + "%s: warning - control file modified since last run\n", + progname); setours: /* set our values */ - gethostname(astat.host, sizeof(astat.host)); + strcpy(astat.host, myhostname()); astat.pid = getpid(); strcpy(astat.cfname, cfname); return(0); fmterr: fprintf(stderr, "%s: format error in status file \"%s\"\n", - progname, buf); + progname, sfname); fclose(fp); return(-1); } @@ -279,6 +301,8 @@ checkdir() /* make sure we have our directory */ setdefaults() /* set default values */ { + extern char *atos(); + int decades; char buf[256]; if (vdef(ANIMATE)) { @@ -312,7 +336,9 @@ setdefaults() /* set default values */ quit(1); } if (!vdef(BASENAME)) { - sprintf(buf, "%s/frame%%03d", vval(DIRECTORY)); + decades = (int)log10((double)vint(END)) + 1; + if (decades < 3) decades = 3; + sprintf(buf, "%s/frame%%0%dd", vval(DIRECTORY), decades); vval(BASENAME) = savqstr(buf); vdef(BASENAME)++; } @@ -344,6 +370,17 @@ setdefaults() /* set default values */ vval(DISKSPACE) = "100"; vdef(DISKSPACE)++; } + if (!vdef(RSH)) { + vval(RSH) = REMSH; + vdef(RSH)++; + } + /* locate remote shell program */ + atos(buf, sizeof(buf), vval(RSH)); + if ((remsh = getpath(buf, getenv("PATH"), X_OK)) != NULL) + remsh = savqstr(remsh); + else + remsh = vval(RSH); /* will generate error if used */ + /* append rendering options */ if (vdef(RENDER)) sprintf(rendopt+strlen(rendopt), " %s", vval(RENDER)); @@ -406,35 +443,46 @@ sethosts() /* set up process servers */ } -getradfile(rfname) /* run rad and get needed variables */ -char *rfname; +getradfile(rfargs) /* run rad and get needed variables */ +char *rfargs; { static short mvar[] = {OCTREE,PFILT,RESOLUTION,EXPOSURE,-1}; char combuf[256]; register int i; register char *cp; + char *pippt; /* create rad command */ sprintf(rendopt, " @%s/render.opt", vval(DIRECTORY)); sprintf(combuf, "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH", - rfname, rendopt+2); + rfargs, rendopt+2); cp = combuf; - while (*cp) cp++; /* match unset variables */ + while (*cp) { + if (*cp == '|') pippt = cp; + cp++; + } /* match unset variables */ for (i = 0; mvar[i] >= 0; i++) if (!vdef(mvar[i])) { *cp++ = '|'; strcpy(cp, vnam(mvar[i])); while (*cp) cp++; + pippt = NULL; } - sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY)); - cp += 11; /* point to file name */ + if (pippt != NULL) + strcpy(pippt, "> /dev/null"); /* nothing to match */ + else { + sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY)); + cp += 11; /* point to file name */ + } if (system(combuf)) { - fprintf(stderr, "%s: bad rad input file \"%s\"\n", - progname, rfname); + fprintf(stderr, "%s: error executing rad command:\n\t%s\n", + progname, combuf); quit(1); } - loadvars(cp); /* load variables and remove file */ - unlink(cp); + if (pippt == NULL) { /* load variables and remove file */ + loadvars(cp); + unlink(cp); + } } @@ -449,9 +497,9 @@ animate() /* run animation */ i = sscanf(vval(RESOLUTION), "%d %d %f", &xres, &yres, &pa); mult = vflt(OVERSAMP); if (i == 3) { - sprintf(rresopt, "-x %d -y %d -pa %f", (int)(mult*xres), + sprintf(rresopt, "-x %d -y %d -pa %.3f", (int)(mult*xres), (int)(mult*yres), pa); - sprintf(fresopt, "-x %d -y %d -pa %f", xres, yres, pa); + sprintf(fresopt, "-x %d -y %d -pa %.3f", xres, yres, pa); } else if (i) { if (i == 1) yres = xres; sprintf(rresopt, "-x %d -y %d", (int)(mult*xres), @@ -479,7 +527,7 @@ animate() /* run animation */ /* figure # frames per batch */ d1 = mult*xres*mult*yres*4; /* space for orig. picture */ if ((i=vint(INTERP)) || atoi(vval(MBLUR))) - d1 += mult*xres*mult*yres*4; /* space for z-buffer */ + d1 += mult*xres*mult*yres*sizeof(float); /* Z-buffer */ d2 = xres*yres*4; /* space for final picture */ frames_batch = (i+1)*(vflt(DISKSPACE)*1048576.-d1)/(d1+i*d2); if (frames_batch < i+2) { @@ -487,6 +535,11 @@ animate() /* run animation */ progname); quit(1); } + /* initialize archive argument list */ + i = 16; + if (vdef(ARCHIVE) && strlen(vval(ARCHIVE)) > i) + i = strlen(vval(ARCHIVE)); + arcnext = arcfirst = arcargs + i; /* initialize status file */ if (astat.rnext == 0) astat.rnext = astat.fnext = astat.tnext = vint(START); @@ -581,7 +634,7 @@ filterframes() /* catch up with filtering */ dofilt(i, vp, getexp(i), 0); /* filter frame */ } bwait(0); /* wait for filter processes */ - archive(astat.fnext, i-1); /* archive originals */ + archive(); /* archive originals */ astat.fnext = i; /* update status */ putastat(); } @@ -662,7 +715,9 @@ char *vfn; inspoint = combuf + strlen(combuf); sprintf(inspoint, " %s < %s", vval(OCTREE), vfn); /* run in parallel */ - if (pruncom(combuf, inspoint, (last-first+1)/(vint(INTERP)+1))) { + i = (last-first+1)/(vint(INTERP)+1); + if (i < 1) i = 1; + if (pruncom(combuf, inspoint, i)) { fprintf(stderr, "%s: error rendering frames %d through %d\n", progname, first, last); quit(1); @@ -740,53 +795,27 @@ int frame; } -archive(first, last) /* archive and remove renderings */ -int first, last; +archive() /* archive and remove renderings */ { #define RMCOML (sizeof(rmcom)-1) static char rmcom[] = "rm -f"; - int offset = RMCOML; - char combuf[10240]; - struct stat stb; - register char *cp; register int i; - if (noaction) - return; - if (vdef(ARCHIVE) && strlen(vval(ARCHIVE)) > offset) - offset = strlen(vval(ARCHIVE)); - cp = combuf + offset; - *cp++ = ' '; /* make argument list */ - for (i = first; i <= last; i++) { - sprintf(cp, vval(BASENAME), i); - strcat(cp, ".unf"); - if (stat(cp, &stb) == 0 && stb.st_size > 0) { /* non-zero? */ - while (*cp) cp++; - *cp++ = ' '; - sprintf(cp, vval(BASENAME), i); - strcat(cp, ".zbf"); - if (access(cp, F_OK) == 0) { /* exists? */ - while (*cp) cp++; - *cp++ = ' '; - } - } - } - *--cp = '\0'; - if (cp <= combuf + offset) /* no files? */ - return; + if (arcnext == arcfirst) + return; /* nothing to do */ if (vdef(ARCHIVE)) { /* run archive command */ i = strlen(vval(ARCHIVE)); - strncpy(combuf+offset-i, vval(ARCHIVE), i); - if (runcom(combuf+offset-i)) { - fprintf(stderr, - "%s: error running archive command on frames %d through %d\n", - progname, first, last); + strncpy(arcfirst-i, vval(ARCHIVE), i); + if (runcom(arcfirst-i)) { + fprintf(stderr, "%s: error running archive command\n", + progname); quit(1); } } /* run remove command */ - strncpy(combuf+offset-RMCOML, rmcom, RMCOML); - runcom(combuf+offset-RMCOML); + strncpy(arcfirst-RMCOML, rmcom, RMCOML); + runcom(arcfirst-RMCOML); + arcnext = arcfirst; /* reset argument list */ #undef RMCOML } @@ -802,11 +831,15 @@ int rvr; static int iter = 0; char fnbefore[128], fnafter[128]; char combuf[1024], fname0[128], fname1[128]; - int usepinterp, usepfilt; + int usepinterp, usepfilt, nora_rgbe; int frseq[2]; /* check what is needed */ usepinterp = atoi(vval(MBLUR)); usepfilt = pfiltalways | ep==NULL; + if (ep != NULL && !strcmp(ep, "1")) + ep = "+0"; + nora_rgbe = strcmp(vval(OVERSAMP),"1") || ep==NULL || + *ep != '+' || *ep != '-' || !isint(ep); /* compute rendered views */ frseq[0] = frame - ((frame-1) % (vint(INTERP)+1)); frseq[1] = frseq[0] + vint(INTERP) + 1; @@ -815,11 +848,25 @@ int rvr; if (frseq[1] == frame) { /* pfilt only */ frseq[0] = frseq[1]; usepinterp = 0; /* update what's needed */ - usepfilt |= vflt(OVERSAMP)>1.01 || strcmp(ep,"1"); - } else if (frseq[0] == frame) { /* no interpolation */ - /* update what's needed */ - if (!usepinterp) - usepfilt |= vflt(OVERSAMP)>1.01 || strcmp(ep,"1"); + usepfilt |= nora_rgbe; + } else if (frseq[0] == frame) { /* no interpolation needed */ + if (!rvr && frame > 1+vint(INTERP)) { /* archive previous */ + *arcnext++ = ' '; + sprintf(arcnext, vval(BASENAME), frame-vint(INTERP)-1); + while (*arcnext) arcnext++; + strcpy(arcnext, ".unf"); + arcnext += 4; + if (usepinterp || vint(INTERP)) { /* and Z-buf */ + *arcnext++ = ' '; + sprintf(arcnext, vval(BASENAME), + frame-vint(INTERP)-1); + while (*arcnext) arcnext++; + strcpy(arcnext, ".zbf"); + arcnext += 4; + } + } + if (!usepinterp) /* update what's needed */ + usepfilt |= nora_rgbe; } else /* interpolation needed */ usepinterp++; if (frseq[1] >= astat.rnext) /* next batch unavailable */ @@ -867,7 +914,7 @@ int rvr; strcat(combuf, viewopt(vp)); if (vbool(RTRACE)) sprintf(combuf+strlen(combuf), " -ff -fr '%s -w0 %s'", - rendopt, vval(OCTREE)); + rendopt+1, vval(OCTREE)); if (vdef(PINTERP)) sprintf(combuf+strlen(combuf), " %s", vval(PINTERP)); if (usepfilt) @@ -908,7 +955,7 @@ int rvr; } else { /* else just check it */ if (rvr == 2) return(1); - sprintf(combuf, "ra_rgbe -r %s.unf", fnbefore); + sprintf(combuf, "ra_rgbe -e %s -r %s.unf", ep, fnbefore); } /* output file name */ sprintf(fname0, vval(BASENAME), frame); @@ -938,12 +985,14 @@ int n; } return(NULL); } - if (viewfp == NULL) { /* open file */ + if (viewfp == NULL) { /* open file */ if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) { perror(vval(VIEWFILE)); quit(1); } - } else if (n < viewnum) { /* rewind file */ + } else if (n > 0 && n < viewnum) { /* rewind file */ + if (viewnum == 1 && feof(viewfp)) + return(&curview); /* just one view */ if (fseek(viewfp, 0L, 0) == EOF) { perror(vval(VIEWFILE)); quit(1); @@ -951,9 +1000,16 @@ int n; copystruct(&curview, &stdview); viewnum = 0; } + if (n < 0) { /* get next view */ + register int c = getc(viewfp); + if (c == EOF) + return((VIEW *)NULL); /* that's it */ + ungetc(c, viewfp); + n = viewnum + 1; + } while (n > viewnum) { /* scan to desired view */ if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL) - return(NULL); + return(viewnum==1 ? &curview : (VIEW *)NULL); if (isview(linebuf) && sscanview(&curview, linebuf) > 0) viewnum++; } @@ -964,9 +1020,11 @@ int n; int countviews() /* count views in view file */ { - register int n = 0; + int n; - while (getview(n+1) != NULL) + if (getview(n=1) == NULL) + return(0); + while (getview(-1) != NULL) n++; return(n); } @@ -986,10 +1044,12 @@ int n; if (n == 0) { /* signal to close file */ if (expfp != NULL) { fclose(expfp); + free((char *)exppos); expfp = NULL; } return(NULL); - } + } else if (n > vint(END)) /* request past end (error?) */ + return(NULL); if (!vdef(EXPOSURE)) /* no setting (auto) */ return(NULL); if (isflt(vval(EXPOSURE))) /* always the same */ @@ -1027,13 +1087,15 @@ int n; } curfrm++; cp = fskip(expval); /* check format */ - if (cp == NULL || *cp != '\n') { + if (cp != NULL) + while (isspace(*cp)) + *cp++ = '\0'; + if (cp == NULL || *cp) { fprintf(stderr, "%s: exposure format error on line %d\n", vval(EXPOSURE), curfrm); quit(1); } - *cp = '\0'; } return(expval); /* return value */ } @@ -1063,6 +1125,7 @@ int pn; int status; { register PROC *pp; + register struct pslot *psl; pp = ps->proc + pn; if (pp->elen) { /* pass errors */ @@ -1074,9 +1137,24 @@ int status; if (ps->hostname[0]) status = 1; /* because rsh doesn't return status */ } + lastpserver = NULL; + psl = findpslot(pp->pid); /* check for bruncom() slot */ + if (psl->pid) { + if (status) { + if (psl->rcvf != NULL) /* attempt recovery */ + status = (*psl->rcvf)(psl->fout); + if (status) { + fprintf(stderr, + "%s: error rendering frame %d\n", + progname, psl->fout); + quit(1); + } + lastpserver = ps; + } + psl->pid = 0; /* free process slot */ + } else if (status) + lastpserver = ps; freestr(pp->com); /* free command string */ - lastpid = pp->pid; /* record PID for bwait() */ - lastpserver = ps; /* record server for serverdown() */ return(status); } @@ -1084,6 +1162,8 @@ int status; int serverdown() /* check status of last process server */ { + if (lastpserver == NULL || !lastpserver->hostname[0]) + return(0); if (pserverOK(lastpserver)) /* server still up? */ return(0); delpserver(lastpserver); /* else delete it */ @@ -1110,8 +1190,8 @@ int (*rf)(); printf("\t%s\n", com); /* echo command */ return(0); } - /* else start it when we can */ - while ((pid = startjob(NULL, savestr(com), donecom)) == -1) + com = savestr(com); /* else start it when we can */ + while ((pid = startjob(NULL, com, donecom)) == -1) bwait(1); if (!silent) { /* echo command */ PSERVER *ps; @@ -1133,24 +1213,13 @@ bwait(ncoms) /* wait for batch job(s) to finish */ int ncoms; { int status; - register struct pslot *psl; if (noaction) return; while ((status = wait4job(NULL, -1)) != -1) { - psl = findpslot(lastpid); - if (status) { /* attempt recovery */ - serverdown(); /* check server */ - if (psl->rcvf == NULL || (*psl->rcvf)(psl->fout)) { - fprintf(stderr, - "%s: error rendering frame %d\n", - progname, psl->fout); - quit(1); - } - } - psl->pid = 0; /* free process slot */ - if (!--ncoms) - return; /* done enough */ + serverdown(); /* update server status */ + if (--ncoms == 0) + break; /* done enough */ } } @@ -1162,8 +1231,10 @@ int maxcopies; { int retstatus = 0; int hostcopies; - char com1buf[10240], *com1, *endcom1; + char buf[10240], *com1, *s; int status; + int pfd; + register int n; register PSERVER *ps; if (!silent) @@ -1175,25 +1246,23 @@ int maxcopies; for (ps = pslist; ps != NULL; ps = ps->next) { hostcopies = 0; if (maxcopies > 1 && ps->nprocs > 1 && ppins != NULL) { - strcpy(com1=com1buf, com); /* build -PP command */ + strcpy(com1=buf, com); /* build -PP command */ sprintf(com1+(ppins-com), " -PP %s/%s.persist", vval(DIRECTORY), phostname(ps)); strcat(com1, ppins); - endcom1 = com1 + strlen(com1); - sprintf(endcom1, "; kill `sed -n '1s/^[^ ]* //p' %s/%s.persist`", - vval(DIRECTORY), phostname(ps)); - } else { + } else com1 = com; - endcom1 = NULL; + while (maxcopies > 0) { + s = savestr(com1); + if (startjob(ps, s, donecom) != -1) { + sleep(20); + hostcopies++; + maxcopies--; + } else { + freestr(s); + break; + } } - while (maxcopies > 0 && - startjob(ps, savestr(com1), donecom) != -1) { - sleep(10); - hostcopies++; - maxcopies--; - if (endcom1 != NULL) - *endcom1 = '\0'; - } if (!silent && hostcopies) { if (hostcopies > 1) printf("\t%d duplicate processes", hostcopies); @@ -1205,8 +1274,21 @@ int maxcopies; } /* wait for jobs to finish */ while ((status = wait4job(NULL, -1)) != -1) - if (status) - retstatus += !serverdown(); /* check server */ + retstatus += status && !serverdown(); + /* terminate parallel rpict's */ + for (ps = pslist; ps != NULL; ps = ps->next) { + sprintf(buf, "%s/%s.persist", vval(DIRECTORY), phostname(ps)); + if ((pfd = open(buf, O_RDONLY)) >= 0) { + n = read(pfd, buf, sizeof(buf)-1); /* get PID */ + buf[n] = '\0'; + close(pfd); + for (n = 0; buf[n] && !isspace(buf[n]); n++) + ; + /* terminate */ + sprintf(buf, "kill -ALRM %d", atoi(buf+n)); + wait4job(ps, startjob(ps, buf, NULL)); + } + } return(retstatus); }
