root/radiance/ray/src/util/ranimate.c
Tue Feb 25 02:47:24 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.30: +1 -56 lines
Diff to previous 2.30 , to selected 2.24
Mon Feb 24 16:44:40 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.29 , to selected 2.24
Added missing -a option to pinterp calls
Changes since 2.28: +135 -22 lines
Diff to previous 2.28 , to selected 2.24
Mon Jul 6 18:17:39 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.27: +3 -7 lines
Diff to previous 2.27 , to selected 2.24
fixed bug by eliminated exit code check on rad (sigh)
Wed Jun 3 16:37:51 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 2.26: +41 -41 lines
Diff to previous 2.26 , to selected 2.24
Tue Mar 3 19:36:43 1998 UTC (26 years, 1 month ago) by gwlarson
Changes since 2.25: +2 -1 lines
Diff to previous 2.25 , to selected 2.24
added last view to rpict command line for -pm option
Tue Mar 3 11:44:46 1998 UTC (26 years, 1 month ago) by gwlarson
Changes since 2.24: +84 -35 lines
Diff to previous 2.24
change directories before running transfer or archive commands
Revision 2.24 - (view) (download) (annotate) - [selected]
Thu Feb 26 10:27:45 1998 UTC (26 years, 1 month ago) by gwlarson
Changes since 2.23: +13 -4 lines
Diff to previous 2.23
fixed infinite loop in countviews()
Fri Oct 31 15:02:43 1997 UTC (26 years, 5 months ago) by gregl
Changes since 2.22: +16 -5 lines
Diff to previous 2.22 , to selected 2.24
fixed minor bug in getradfile() for matchless rad runs
Thu Mar 20 14:53:17 1997 UTC (27 years, 1 month ago) by greg
Diff to previous 2.21 , to selected 2.24
added call to check variable assignments
Tue Jul 30 21:27:13 1996 UTC (27 years, 8 months ago) by greg
Diff to previous 2.20 , to selected 2.24
fixed bug in passing of -fr option to pinterp
Wed Jul 17 17:45:11 1996 UTC (27 years, 9 months ago) by greg
Diff to previous 2.19 , to selected 2.24
bug fix in status check on finished job
Wed Jul 10 15:14:59 1996 UTC (27 years, 9 months ago) by greg
Diff to previous 2.18 , to selected 2.24
made default BASENAME respond to number of END frame
Mon Jul 8 14:53:17 1996 UTC (27 years, 9 months ago) by greg
Changes since 2.17: +42 -36 lines
Diff to previous 2.17 , to selected 2.24
fixed problem in multiple recovery by putting important code in donecom()
Wed Jul 3 15:26:44 1996 UTC (27 years, 9 months ago) by greg
Changes since 2.16: +24 -11 lines
Diff to previous 2.16 , to selected 2.24
fixed bug in -PP option of rpict
Thu Jun 27 06:49:50 1996 UTC (27 years, 9 months ago) by greg
Diff to previous 2.15 , to selected 2.24
changed formatting on -pa option
Mon Jun 24 09:19:36 1996 UTC (27 years, 10 months ago) by greg
Diff to previous 2.14 , to selected 2.24
fixed NULL pointer for AIX
Thu May 30 17:00:10 1996 UTC (27 years, 10 months ago) by greg
Diff to previous 2.13 , to selected 2.24
bug paranoia in getexp()
Tue May 21 14:27:19 1996 UTC (27 years, 11 months ago) by greg
Diff to previous 2.12 , to selected 2.24
changed "4" to sizeof(float) in space computation
Mon May 20 11:50:19 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.11: +12 -5 lines
Diff to previous 2.11 , to selected 2.24
added warning about updates to control file
Tue Apr 16 10:38:19 1996 UTC (28 years ago) by greg
Changes since 2.10: +6 -3 lines
Diff to previous 2.10 , to selected 2.24
changed call to execvp() to getpath() + execv()
Tue Feb 20 16:13:53 1996 UTC (28 years, 2 months ago) by greg
Changes since 2.9: +22 -1 lines
Diff to previous 2.9 , to selected 2.24
added RSH variable to rename or replace remote shell execution
Wed Feb 7 16:42:41 1996 UTC (28 years, 2 months ago) by greg
Diff to previous 2.8 , to selected 2.24
moved host name stuff to lib routine
Wed Jan 24 14:31:36 1996 UTC (28 years, 3 months ago) by greg
Diff to previous 2.7 , to selected 2.24
added exception for VIEWFILE with just one view
Wed Jan 24 12:22:15 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.6: +52 -50 lines
Diff to previous 2.6 , to selected 2.24
more bug fixes
Tue Jan 23 17:01:33 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.5: +17 -16 lines
Diff to previous 2.5 , to selected 2.24
fixed pmblur view file naming problem
Tue Jan 23 16:14:28 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.4: +16 -8 lines
Diff to previous 2.4 , to selected 2.24
minor improvements
Mon Jan 22 17:19:37 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.3: +31 -13 lines
Diff to previous 2.3 , to selected 2.24
hopefully added -PP option to parallel machine runs
Fri Jan 19 17:24:19 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.2: +33 -15 lines
Diff to previous 2.2 , to selected 2.24
improved process recording
Thu Jan 18 11:25:11 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.1: +329 -100 lines
Diff to previous 2.1 , to selected 2.24
Fri Jan 12 12:16:17 1996 UTC (28 years, 3 months ago) by greg
Diff to selected 2.24
