root/radiance/ray/src/util/ranimate.c
Revision: 2.5
Committed: Tue Jan 23 16:14:28 1996 UTC (28 years, 5 months ago) by greg
Changes since 2.4: +16 -8 lines
minor improvements
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Radiance animation control program
9 */
10
11 #include "standard.h"
12 #include <ctype.h>
13 #include <sys/types.h>
14 #include <sys/stat.h>
15 #include "view.h"
16 #include "vars.h"
17 #include "netproc.h"
18 /* input variables */
19 #define HOST 0 /* rendering host machine */
20 #define RENDER 1 /* rendering options */
21 #define PFILT 2 /* pfilt options */
22 #define PINTERP 3 /* pinterp options */
23 #define OCTREE 4 /* octree file name */
24 #define DIRECTORY 5 /* working (sub)directory */
25 #define BASENAME 6 /* output image base name */
26 #define VIEWFILE 7 /* animation frame views */
27 #define START 8 /* starting frame number */
28 #define END 9 /* ending frame number */
29 #define RIF 10 /* rad input file */
30 #define NEXTANIM 11 /* next animation file */
31 #define ANIMATE 12 /* animation command */
32 #define TRANSFER 13 /* frame transfer command */
33 #define ARCHIVE 14 /* archiving command */
34 #define INTERP 15 /* # frames to interpolate */
35 #define OVERSAMP 16 /* # times to oversample image */
36 #define MBLUR 17 /* samples for motion blur */
37 #define RTRACE 18 /* use rtrace with pinterp? */
38 #define DISKSPACE 19 /* how much disk space to use */
39 #define RESOLUTION 20 /* desired final resolution */
40 #define EXPOSURE 21 /* how to compute exposure */
41
42 int NVARS = 22; /* total number of variables */
43
44 VARIABLE vv[] = { /* variable-value pairs */
45 {"host", 4, 0, NULL, NULL},
46 {"render", 3, 0, NULL, catvalues},
47 {"pfilt", 2, 0, NULL, catvalues},
48 {"pinterp", 2, 0, NULL, catvalues},
49 {"OCTREE", 3, 0, NULL, onevalue},
50 {"DIRECTORY", 3, 0, NULL, onevalue},
51 {"BASENAME", 3, 0, NULL, onevalue},
52 {"VIEWFILE", 2, 0, NULL, onevalue},
53 {"START", 2, 0, NULL, intvalue},
54 {"END", 2, 0, NULL, intvalue},
55 {"RIF", 3, 0, NULL, onevalue},
56 {"NEXTANIM", 3, 0, NULL, onevalue},
57 {"ANIMATE", 2, 0, NULL, onevalue},
58 {"TRANSFER", 2, 0, NULL, onevalue},
59 {"ARCHIVE", 2, 0, NULL, onevalue},
60 {"INTERPOLATE", 3, 0, NULL, intvalue},
61 {"OVERSAMPLE", 2, 0, NULL, fltvalue},
62 {"MBLUR", 2, 0, NULL, onevalue},
63 {"RTRACE", 2, 0, NULL, boolvalue},
64 {"DISKSPACE", 3, 0, NULL, fltvalue},
65 {"RESOLUTION", 3, 0, NULL, onevalue},
66 {"EXPOSURE", 3, 0, NULL, onevalue},
67 };
68
69 #define SFNAME "STATUS" /* status file name */
70
71 struct {
72 char host[64]; /* control host name */
73 int pid; /* control process id */
74 char cfname[128]; /* control file name */
75 int rnext; /* next frame to render */
76 int fnext; /* next frame to filter */
77 int tnext; /* next frame to transfer */
78 } astat; /* animation status */
79
80 char *progname; /* our program name */
81 char *cfname; /* our control file name */
82
83 int nowarn = 0; /* turn warnings off? */
84 int silent = 0; /* silent mode? */
85 int noaction = 0; /* take no action? */
86
87 char rendopt[2048] = ""; /* rendering options */
88 char rresopt[32]; /* rendering resolution options */
89 char fresopt[32]; /* filter resolution options */
90 int pfiltalways; /* always use pfilt? */
91
92 struct pslot {
93 int pid; /* process ID (0 if empty) */
94 int fout; /* output frame number */
95 int (*rcvf)(); /* recover function */
96 } *pslot; /* process slots */
97 int npslots; /* number of process slots */
98
99 int lastpid; /* ID of last completed background process */
100 PSERVER *lastpserver; /* last process server used */
101
102 #define phostname(ps) ((ps)->hostname[0] ? (ps)->hostname : astat.host)
103
104 struct pslot *findpslot();
105
106 VIEW *getview();
107 char *getexp();
108
109
110 main(argc, argv)
111 int argc;
112 char *argv[];
113 {
114 int explicate = 0;
115 int i;
116
117 progname = argv[0]; /* get arguments */
118 for (i = 1; i < argc && argv[i][0] == '-'; i++)
119 switch (argv[i][1]) {
120 case 'e': /* print variables */
121 explicate++;
122 break;
123 case 'w': /* turn off warnings */
124 nowarn++;
125 break;
126 case 's': /* silent mode */
127 silent++;
128 break;
129 case 'n': /* take no action */
130 noaction++;
131 break;
132 default:
133 goto userr;
134 }
135 if (i != argc-1)
136 goto userr;
137 cfname = argv[i];
138 /* load variables */
139 loadvars(cfname);
140 /* did we get DIRECTORY? */
141 checkdir();
142 /* check status */
143 if (getastat() < 0) {
144 fprintf(stderr, "%s: exiting\n", progname);
145 quit(1);
146 }
147 /* pfilt always if options given */
148 pfiltalways = vdef(PFILT);
149 /* load RIF if any */
150 if (vdef(RIF))
151 getradfile(vval(RIF));
152 /* set defaults */
153 setdefaults();
154 /* print variables */
155 if (explicate)
156 printvars(stdout);
157 /* set up process servers */
158 sethosts();
159 /* run animation */
160 animate();
161 /* all done */
162 if (vdef(NEXTANIM)) {
163 argv[i] = vval(NEXTANIM); /* just change input file */
164 if (!silent)
165 printargs(argc, argv, stdout);
166 execvp(progname, argv); /* pass to next */
167 quit(1); /* shouldn't return */
168 }
169 quit(0);
170 userr:
171 fprintf(stderr, "Usage: %s [-s][-n][-w][-e] anim_file\n", progname);
172 quit(1);
173 }
174
175
176 getastat() /* check/set animation status */
177 {
178 char buf[256];
179 FILE *fp;
180
181 sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME);
182 if ((fp = fopen(buf, "r")) == NULL) {
183 if (errno != ENOENT) {
184 perror(buf);
185 return(-1);
186 }
187 astat.rnext = astat.fnext = astat.tnext = 0;
188 goto setours;
189 }
190 if (fscanf(fp, "Control host: %s\n", astat.host) != 1)
191 goto fmterr;
192 if (fscanf(fp, "Control PID: %d\n", &astat.pid) != 1)
193 goto fmterr;
194 if (fscanf(fp, "Control file: %s\n", astat.cfname) != 1)
195 goto fmterr;
196 if (fscanf(fp, "Next render: %d\n", &astat.rnext) != 1)
197 goto fmterr;
198 if (fscanf(fp, "Next filter: %d\n", &astat.fnext) != 1)
199 goto fmterr;
200 if (fscanf(fp, "Next transfer: %d\n", &astat.tnext) != 1)
201 goto fmterr;
202 fclose(fp);
203 if (astat.pid != 0) { /* thinks it's still running */
204 gethostname(buf, sizeof(buf));
205 if (strcmp(buf, astat.host)) {
206 fprintf(stderr,
207 "%s: process %d may still be running on host %s\n",
208 progname, astat.pid, astat.host);
209 return(-1);
210 }
211 if (kill(astat.pid, 0) != -1 || errno != ESRCH) {
212 fprintf(stderr, "%s: process %d is still running\n",
213 progname, astat.pid);
214 return(-1);
215 }
216 /* assume it is dead */
217 }
218 if (strcmp(cfname, astat.cfname) && astat.tnext != 0) { /* other's */
219 fprintf(stderr, "%s: unfinished job \"%s\"\n",
220 progname, astat.cfname);
221 return(-1);
222 }
223 setours: /* set our values */
224 gethostname(astat.host, sizeof(astat.host));
225 astat.pid = getpid();
226 strcpy(astat.cfname, cfname);
227 return(0);
228 fmterr:
229 fprintf(stderr, "%s: format error in status file \"%s\"\n",
230 progname, buf);
231 fclose(fp);
232 return(-1);
233 }
234
235
236 putastat() /* put out current status */
237 {
238 char buf[256];
239 FILE *fp;
240
241 if (noaction)
242 return;
243 sprintf(buf, "%s/%s", vval(DIRECTORY), SFNAME);
244 if ((fp = fopen(buf, "w")) == NULL) {
245 perror(buf);
246 quit(1);
247 }
248 fprintf(fp, "Control host: %s\n", astat.host);
249 fprintf(fp, "Control PID: %d\n", astat.pid);
250 fprintf(fp, "Control file: %s\n", astat.cfname);
251 fprintf(fp, "Next render: %d\n", astat.rnext);
252 fprintf(fp, "Next filter: %d\n", astat.fnext);
253 fprintf(fp, "Next transfer: %d\n", astat.tnext);
254 fclose(fp);
255 }
256
257
258 checkdir() /* make sure we have our directory */
259 {
260 struct stat stb;
261
262 if (!vdef(DIRECTORY)) {
263 fprintf(stderr, "%s: %s undefined\n",
264 progname, vnam(DIRECTORY));
265 quit(1);
266 }
267 if (stat(vval(DIRECTORY), &stb) == -1) {
268 if (errno == ENOENT && mkdir(vval(DIRECTORY), 0777) == 0)
269 return;
270 perror(vval(DIRECTORY));
271 quit(1);
272 }
273 if (!(stb.st_mode & S_IFDIR)) {
274 fprintf(stderr, "%s: not a directory\n", vval(DIRECTORY));
275 quit(1);
276 }
277 }
278
279
280 setdefaults() /* set default values */
281 {
282 char buf[256];
283
284 if (vdef(ANIMATE)) {
285 vval(OCTREE) = NULL;
286 vdef(OCTREE) = 0;
287 } else if (!vdef(OCTREE)) {
288 fprintf(stderr, "%s: either %s or %s must be defined\n",
289 progname, vnam(OCTREE), vnam(ANIMATE));
290 quit(1);
291 }
292 if (!vdef(VIEWFILE)) {
293 fprintf(stderr, "%s: %s undefined\n", progname, vnam(VIEWFILE));
294 quit(1);
295 }
296 if (!vdef(HOST)) {
297 vval(HOST) = LHOSTNAME;
298 vdef(HOST)++;
299 }
300 if (!vdef(START)) {
301 vval(START) = "1";
302 vdef(START)++;
303 }
304 if (!vdef(END)) {
305 sprintf(buf, "%d", countviews()+vint(START)-1);
306 vval(END) = savqstr(buf);
307 vdef(END)++;
308 }
309 if (vint(END) < vint(START)) {
310 fprintf(stderr, "%s: ending frame less than starting frame\n",
311 progname);
312 quit(1);
313 }
314 if (!vdef(BASENAME)) {
315 sprintf(buf, "%s/frame%%03d", vval(DIRECTORY));
316 vval(BASENAME) = savqstr(buf);
317 vdef(BASENAME)++;
318 }
319 if (!vdef(RESOLUTION)) {
320 vval(RESOLUTION) = "640";
321 vdef(RESOLUTION)++;
322 }
323 if (!vdef(OVERSAMP)) {
324 vval(OVERSAMP) = "2";
325 vdef(OVERSAMP)++;
326 }
327 if (!vdef(INTERP)) {
328 vval(INTERP) = "0";
329 vdef(INTERP)++;
330 }
331 if (!vdef(MBLUR)) {
332 vval(MBLUR) = "0";
333 vdef(MBLUR)++;
334 }
335 if (!vdef(RTRACE)) {
336 vval(RTRACE) = "F";
337 vdef(RTRACE)++;
338 }
339 if (!vdef(DISKSPACE)) {
340 if (!nowarn)
341 fprintf(stderr,
342 "%s: warning - no %s setting, assuming 100 Mbytes available\n",
343 progname, vnam(DISKSPACE));
344 vval(DISKSPACE) = "100";
345 vdef(DISKSPACE)++;
346 }
347 /* append rendering options */
348 if (vdef(RENDER))
349 sprintf(rendopt+strlen(rendopt), " %s", vval(RENDER));
350 }
351
352
353 sethosts() /* set up process servers */
354 {
355 extern char *iskip();
356 char buf[256], *dir, *uname;
357 int np;
358 register char *cp;
359 int i;
360
361 npslots = 0;
362 if (noaction)
363 return;
364 for (i = 0; i < vdef(HOST); i++) { /* add each host */
365 dir = uname = NULL;
366 np = 1;
367 strcpy(cp=buf, nvalue(HOST, i)); /* copy to buffer */
368 cp = sskip(cp); /* skip host name */
369 while (isspace(*cp))
370 *cp++ = '\0';
371 if (*cp) { /* has # processes? */
372 np = atoi(cp);
373 if ((cp = iskip(cp)) == NULL || (*cp && !isspace(*cp)))
374 badvalue(HOST);
375 while (isspace(*cp))
376 cp++;
377 if (*cp) { /* has directory? */
378 dir = cp;
379 cp = sskip(cp); /* skip dir. */
380 while (isspace(*cp))
381 *cp++ = '\0';
382 if (*cp) { /* has user? */
383 uname = cp;
384 if (*sskip(cp))
385 badvalue(HOST);
386 }
387 }
388 }
389 if (addpserver(buf, dir, uname, np) == NULL) {
390 if (!nowarn)
391 fprintf(stderr,
392 "%s: cannot execute on host \"%s\"\n",
393 progname, buf);
394 } else
395 npslots += np;
396 }
397 if (npslots == 0) {
398 fprintf(stderr, "%s: no working process servers\n", progname);
399 quit(1);
400 }
401 pslot = (struct pslot *)calloc(npslots, sizeof(struct pslot));
402 if (pslot == NULL) {
403 perror("malloc");
404 quit(1);
405 }
406 }
407
408
409 getradfile(rfname) /* run rad and get needed variables */
410 char *rfname;
411 {
412 static short mvar[] = {OCTREE,PFILT,RESOLUTION,EXPOSURE,-1};
413 char combuf[256];
414 register int i;
415 register char *cp;
416 /* create rad command */
417 sprintf(rendopt, " @%s/render.opt", vval(DIRECTORY));
418 sprintf(combuf,
419 "rad -v 0 -s -e -w %s OPTFILE=%s | egrep '^[ \t]*(NOMATCH",
420 rfname, rendopt+2);
421 cp = combuf;
422 while (*cp) cp++; /* match unset variables */
423 for (i = 0; mvar[i] >= 0; i++)
424 if (!vdef(mvar[i])) {
425 *cp++ = '|';
426 strcpy(cp, vnam(mvar[i]));
427 while (*cp) cp++;
428 }
429 sprintf(cp, ")[ \t]*=' > %s/radset.var", vval(DIRECTORY));
430 cp += 11; /* point to file name */
431 if (system(combuf)) {
432 fprintf(stderr, "%s: bad rad input file \"%s\"\n",
433 progname, rfname);
434 quit(1);
435 }
436 loadvars(cp); /* load variables and remove file */
437 unlink(cp);
438 }
439
440
441 animate() /* run animation */
442 {
443 int xres, yres;
444 float pa, mult;
445 int frames_batch;
446 register int i;
447 double d1, d2;
448 /* compute rpict resolution */
449 i = sscanf(vval(RESOLUTION), "%d %d %f", &xres, &yres, &pa);
450 mult = vflt(OVERSAMP);
451 if (i == 3) {
452 sprintf(rresopt, "-x %d -y %d -pa %f", (int)(mult*xres),
453 (int)(mult*yres), pa);
454 sprintf(fresopt, "-x %d -y %d -pa %f", xres, yres, pa);
455 } else if (i) {
456 if (i == 1) yres = xres;
457 sprintf(rresopt, "-x %d -y %d", (int)(mult*xres),
458 (int)(mult*yres));
459 sprintf(fresopt, "-x %d -y %d -pa 1", xres, yres);
460 } else
461 badvalue(RESOLUTION);
462 /* consistency checks */
463 if (vdef(ANIMATE)) {
464 if (vint(INTERP)) {
465 if (!nowarn)
466 fprintf(stderr,
467 "%s: resetting %s=0 for animation\n",
468 progname, vnam(INTERP));
469 vval(INTERP) = "0";
470 }
471 if (atoi(vval(MBLUR))) { /* can't handle this yet */
472 if (!nowarn)
473 fprintf(stderr,
474 "%s: resetting %s=0 for animation\n",
475 progname, vnam(MBLUR));
476 vval(MBLUR) = "0";
477 }
478 }
479 /* figure # frames per batch */
480 d1 = mult*xres*mult*yres*4; /* space for orig. picture */
481 if ((i=vint(INTERP)) || atoi(vval(MBLUR)))
482 d1 += mult*xres*mult*yres*4; /* space for z-buffer */
483 d2 = xres*yres*4; /* space for final picture */
484 frames_batch = (i+1)*(vflt(DISKSPACE)*1048576.-d1)/(d1+i*d2);
485 if (frames_batch < i+2) {
486 fprintf(stderr, "%s: insufficient disk space allocated\n",
487 progname);
488 quit(1);
489 }
490 /* initialize status file */
491 if (astat.rnext == 0)
492 astat.rnext = astat.fnext = astat.tnext = vint(START);
493 putastat();
494 /* render in batches */
495 while (astat.tnext <= vint(END)) {
496 renderframes(frames_batch);
497 filterframes();
498 transferframes();
499 }
500 /* mark status as finished */
501 astat.pid = 0;
502 putastat();
503 /* close open files */
504 getview(0);
505 getexp(0);
506 }
507
508
509 renderframes(nframes) /* render next nframes frames */
510 int nframes;
511 {
512 static char vendbuf[16];
513 VIEW *vp;
514 FILE *fp = NULL;
515 char vfname[128];
516 int lastframe;
517 register int i;
518
519 if (astat.tnext < astat.rnext) /* other work to do first */
520 return;
521 /* create batch view file */
522 if (!vdef(ANIMATE)) {
523 sprintf(vfname, "%s/anim.vf", vval(DIRECTORY));
524 if ((fp = fopen(vfname, "w")) == NULL) {
525 perror(vfname);
526 quit(1);
527 }
528 }
529 /* bound batch properly */
530 lastframe = astat.rnext + nframes - 1;
531 if ((lastframe-1) % (vint(INTERP)+1)) /* need even interval */
532 lastframe += vint(INTERP)+1 - ((lastframe-1)%(vint(INTERP)+1));
533 if (lastframe > vint(END)) /* check for end */
534 lastframe = vint(END);
535 /* render each view */
536 for (i = astat.rnext; i <= lastframe; i++) {
537 if ((vp = getview(i)) == NULL) {
538 if (!nowarn)
539 fprintf(stderr,
540 "%s: ran out of views before last frame\n",
541 progname);
542 sprintf(vval(END)=vendbuf, "%d", i-1);
543 lastframe = i - 1;
544 break;
545 }
546 if (vdef(ANIMATE)) /* animate frame */
547 animrend(i, vp);
548 else { /* else record it */
549 fputs(VIEWSTR, fp);
550 fprintview(vp, fp);
551 putc('\n', fp);
552 }
553 }
554 if (vdef(ANIMATE)) /* wait for renderings to finish */
555 bwait(0);
556 else { /* else if walk-through */
557 fclose(fp); /* close view file */
558 walkwait(astat.rnext, lastframe, vfname); /* walk it */
559 unlink(vfname); /* remove view file */
560 }
561 astat.rnext = i; /* update status */
562 putastat();
563 }
564
565
566 filterframes() /* catch up with filtering */
567 {
568 VIEW *vp;
569 register int i;
570
571 if (astat.tnext < astat.fnext) /* other work to do first */
572 return;
573 /* filter each view */
574 for (i = astat.fnext; i < astat.rnext; i++) {
575 if ((vp = getview(i)) == NULL) { /* get view i */
576 fprintf(stderr,
577 "%s: unexpected error reading view for frame %d\n",
578 progname, i);
579 quit(1);
580 }
581 dofilt(i, vp, getexp(i), 0); /* filter frame */
582 }
583 bwait(0); /* wait for filter processes */
584 archive(astat.fnext, i-1); /* archive originals */
585 astat.fnext = i; /* update status */
586 putastat();
587 }
588
589
590 transferframes() /* catch up with picture transfers */
591 {
592 char combuf[10240];
593 register char *cp;
594 register int i;
595
596 if (astat.tnext >= astat.fnext) /* nothing to do, yet */
597 return;
598 if (!vdef(TRANSFER)) { /* no transfer function -- leave 'em */
599 astat.tnext = astat.fnext;
600 putastat(); /* update status */
601 return;
602 }
603 strcpy(combuf, vval(TRANSFER)); /* start transfer command */
604 cp = combuf + strlen(combuf);
605 /* make argument list */
606 for (i = astat.tnext; i < astat.fnext; i++) {
607 *cp++ = ' ';
608 sprintf(cp, vval(BASENAME), i);
609 while (*cp) cp++;
610 strcpy(cp, ".pic");
611 cp += 4;
612 }
613 if (runcom(combuf)) { /* transfer frames */
614 fprintf(stderr, "%s: error running transfer command\n",
615 progname);
616 quit(1);
617 }
618 astat.tnext = i; /* update status */
619 putastat();
620 }
621
622
623 animrend(frame, vp) /* start animation frame */
624 int frame;
625 VIEW *vp;
626 {
627 extern int recover();
628 char combuf[2048];
629 char fname[128];
630
631 sprintf(fname, vval(BASENAME), frame);
632 strcat(fname, ".unf");
633 if (access(fname, F_OK) == 0)
634 return;
635 sprintf(combuf, "%s %d | rpict%s%s -w0 %s > %s", vval(ANIMATE), frame,
636 rendopt, viewopt(vp), rresopt, fname);
637 bruncom(combuf, frame, recover); /* run in background */
638 }
639
640
641 walkwait(first, last, vfn) /* walk-through frames */
642 int first, last;
643 char *vfn;
644 {
645 char combuf[2048];
646 char *inspoint;
647 register int i;
648
649 if (!noaction && vint(INTERP)) /* create dummy frames */
650 for (i = first; i <= last; i++)
651 if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
652 sprintf(combuf, vval(BASENAME), i);
653 strcat(combuf, ".unf");
654 close(open(combuf, O_RDONLY|O_CREAT, 0666));
655 }
656 /* create command */
657 sprintf(combuf, "rpict%s -w0", rendopt);
658 if (vint(INTERP) || atoi(vval(MBLUR)))
659 sprintf(combuf+strlen(combuf), " -z %s.zbf", vval(BASENAME));
660 sprintf(combuf+strlen(combuf), " -o %s.unf %s -S %d",
661 vval(BASENAME), rresopt, first);
662 inspoint = combuf + strlen(combuf);
663 sprintf(inspoint, " %s < %s", vval(OCTREE), vfn);
664 /* run in parallel */
665 if (pruncom(combuf, inspoint, (last-first+1)/(vint(INTERP)+1))) {
666 fprintf(stderr, "%s: error rendering frames %d through %d\n",
667 progname, first, last);
668 quit(1);
669 }
670 if (!noaction && vint(INTERP)) /* remove dummy frames */
671 for (i = first; i <= last; i++)
672 if (i < vint(END) && (i-1) % (vint(INTERP)+1)) {
673 sprintf(combuf, vval(BASENAME), i);
674 strcat(combuf, ".unf");
675 unlink(combuf);
676 }
677 }
678
679
680 int
681 recover(frame) /* recover the specified frame */
682 int frame;
683 {
684 static int *rfrm; /* list of recovered frames */
685 static int nrfrms = 0;
686 char combuf[2048];
687 char fname[128];
688 register char *cp;
689 register int i;
690 /* check to see if recovered already */
691 for (i = nrfrms; i--; )
692 if (rfrm[i] == frame)
693 return(0);
694 /* build command */
695 sprintf(fname, vval(BASENAME), frame);
696 if (vdef(ANIMATE))
697 sprintf(combuf, "%s %d | rpict%s -w0",
698 vval(ANIMATE), frame, rendopt);
699 else
700 sprintf(combuf, "rpict%s -w0", rendopt);
701 cp = combuf + strlen(combuf);
702 if (vint(INTERP) || atoi(vval(MBLUR))) {
703 sprintf(cp, " -z %s.zbf", fname);
704 while (*cp) cp++;
705 }
706 sprintf(cp, " -ro %s.unf", fname);
707 while (*cp) cp++;
708 if (!vdef(ANIMATE)) {
709 *cp++ = ' ';
710 strcpy(cp, vval(OCTREE));
711 }
712 if (runcom(combuf)) /* run command */
713 return(1);
714 /* add frame to recovered list */
715 if (nrfrms)
716 rfrm = (int *)realloc((char *)rfrm, (nrfrms+1)*sizeof(int));
717 else
718 rfrm = (int *)malloc(sizeof(int));
719 if (rfrm == NULL) {
720 perror("malloc");
721 quit(1);
722 }
723 rfrm[nrfrms++] = frame;
724 return(0);
725 }
726
727
728 int
729 frecover(frame) /* recover filtered frame */
730 int frame;
731 {
732 VIEW *vp;
733 char *ex;
734
735 vp = getview(frame);
736 ex = getexp(frame);
737 if (dofilt(frame, vp, ex, 2) && dofilt(frame, vp, ex, 1))
738 return(1);
739 return(0);
740 }
741
742
743 archive(first, last) /* archive and remove renderings */
744 int first, last;
745 {
746 #define RMCOML (sizeof(rmcom)-1)
747 static char rmcom[] = "rm -f";
748 int offset = RMCOML;
749 char combuf[10240];
750 struct stat stb;
751 register char *cp;
752 register int i;
753
754 if (noaction)
755 return;
756 if (vdef(ARCHIVE) && strlen(vval(ARCHIVE)) > offset)
757 offset = strlen(vval(ARCHIVE));
758 cp = combuf + offset;
759 *cp++ = ' '; /* make argument list */
760 for (i = first; i <= last; i++) {
761 sprintf(cp, vval(BASENAME), i);
762 strcat(cp, ".unf");
763 if (stat(cp, &stb) == 0 && stb.st_size > 0) { /* non-zero? */
764 while (*cp) cp++;
765 *cp++ = ' ';
766 sprintf(cp, vval(BASENAME), i);
767 strcat(cp, ".zbf");
768 if (access(cp, F_OK) == 0) { /* exists? */
769 while (*cp) cp++;
770 *cp++ = ' ';
771 }
772 }
773 }
774 *--cp = '\0';
775 if (cp <= combuf + offset) /* no files? */
776 return;
777 if (vdef(ARCHIVE)) { /* run archive command */
778 i = strlen(vval(ARCHIVE));
779 strncpy(combuf+offset-i, vval(ARCHIVE), i);
780 if (runcom(combuf+offset-i)) {
781 fprintf(stderr,
782 "%s: error running archive command on frames %d through %d\n",
783 progname, first, last);
784 quit(1);
785 }
786 }
787 /* run remove command */
788 strncpy(combuf+offset-RMCOML, rmcom, RMCOML);
789 runcom(combuf+offset-RMCOML);
790 #undef RMCOML
791 }
792
793
794 int
795 dofilt(frame, vp, ep, rvr) /* filter frame */
796 int frame;
797 VIEW *vp;
798 char *ep;
799 int rvr;
800 {
801 extern int frecover();
802 char fnbefore[128], fnafter[128];
803 char combuf[1024], fname[128];
804 int usepinterp, usepfilt;
805 int frseq[2];
806 /* check what is needed */
807 usepinterp = atoi(vval(MBLUR));
808 usepfilt = pfiltalways | ep==NULL;
809 /* compute rendered views */
810 frseq[0] = frame - ((frame-1) % (vint(INTERP)+1));
811 frseq[1] = frseq[0] + vint(INTERP) + 1;
812 if (frseq[1] > vint(END))
813 frseq[1] = vint(END);
814 if (frseq[1] == frame) { /* pfilt only */
815 frseq[0] = frseq[1];
816 usepinterp = 0; /* update what's needed */
817 usepfilt |= vflt(OVERSAMP)>1.01 || strcmp(ep,"1");
818 } else if (frseq[0] == frame) { /* no interpolation */
819 /* update what's needed */
820 if (!usepinterp)
821 usepfilt |= vflt(OVERSAMP)>1.01 || strcmp(ep,"1");
822 } else /* interpolation needed */
823 usepinterp++;
824 if (frseq[1] >= astat.rnext) /* next batch unavailable */
825 frseq[1] = frseq[0];
826 sprintf(fnbefore, vval(BASENAME), frseq[0]);
827 sprintf(fnafter, vval(BASENAME), frseq[1]);
828 if (rvr == 1 && recover(frseq[0])) /* recover before frame? */
829 return(1);
830 /* generate command */
831 if (usepinterp) { /* using pinterp */
832 if (rvr == 2 && recover(frseq[1])) /* recover after? */
833 return(1);
834 if (atoi(vval(MBLUR))) {
835 FILE *fp; /* motion blurring */
836 sprintf(fname, "%s/vw0", vval(DIRECTORY));
837 if (access(fname, F_OK) == 0)
838 sleep(10);
839 if ((fp = fopen(fname, "w")) == NULL) {
840 perror(fname); quit(1);
841 }
842 fputs(VIEWSTR, fp);
843 fprintview(vp, fp);
844 putc('\n', fp); fclose(fp);
845 if ((vp = getview(frame+1)) == NULL) {
846 fprintf(stderr,
847 "%s: unexpected error reading view for frame %d\n",
848 progname, frame+1);
849 quit(1);
850 }
851 sprintf(fname, "%s/vw1", vval(DIRECTORY));
852 if ((fp = fopen(fname, "w")) == NULL) {
853 perror(fname); quit(1);
854 }
855 fputs(VIEWSTR, fp);
856 fprintview(vp, fp);
857 putc('\n', fp); fclose(fp);
858 sprintf(combuf,
859 "(pmblur %s %d %s/vw0 %s/vw1; rm -f %s/vw0 %s/vw1) | pinterp -B",
860 *sskip(vval(MBLUR)) ? sskip2(vval(MBLUR),1) : "1",
861 atoi(vval(MBLUR)), vval(DIRECTORY),
862 vval(DIRECTORY), vval(DIRECTORY),
863 vval(DIRECTORY), vval(DIRECTORY));
864 } else /* no blurring */
865 strcpy(combuf, "pinterp");
866 strcat(combuf, viewopt(vp));
867 if (vbool(RTRACE))
868 sprintf(combuf+strlen(combuf), " -ff -fr '%s -w0 %s'",
869 rendopt, vval(OCTREE));
870 if (vdef(PINTERP))
871 sprintf(combuf+strlen(combuf), " %s", vval(PINTERP));
872 if (usepfilt)
873 sprintf(combuf+strlen(combuf), " %s", rresopt);
874 else
875 sprintf(combuf+strlen(combuf), " %s -e %s",
876 fresopt, ep);
877 sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
878 fnbefore, fnbefore);
879 if (frseq[1] != frseq[0])
880 sprintf(combuf+strlen(combuf), " %s.unf %s.zbf",
881 fnafter, fnafter);
882 if (usepfilt) { /* also pfilt */
883 if (vdef(PFILT))
884 sprintf(combuf+strlen(combuf), " | pfilt %s",
885 vval(PFILT));
886 else
887 strcat(combuf, " | pfilt");
888 if (ep != NULL)
889 sprintf(combuf+strlen(combuf), " -1 -e %s %s",
890 ep, fresopt);
891 else
892 sprintf(combuf+strlen(combuf), " %s", fresopt);
893 }
894 } else if (usepfilt) { /* pfilt only */
895 if (rvr == 2)
896 return(1);
897 if (vdef(PFILT))
898 sprintf(combuf, "pfilt %s", vval(PFILT));
899 else
900 strcpy(combuf, "pfilt");
901 if (ep != NULL)
902 sprintf(combuf+strlen(combuf), " -1 -e %s %s %s.unf",
903 ep, fresopt, fnbefore);
904 else
905 sprintf(combuf+strlen(combuf), " %s %s.unf",
906 fresopt, fnbefore);
907 } else { /* else just check it */
908 if (rvr == 2)
909 return(1);
910 sprintf(combuf, "ra_rgbe -r %s.unf", fnbefore);
911 }
912 /* output file name */
913 sprintf(fname, vval(BASENAME), frame);
914 sprintf(combuf+strlen(combuf), " > %s.pic", fname);
915 if (rvr) /* in recovery */
916 return(runcom(combuf));
917 bruncom(combuf, frame, frecover); /* else run in background */
918 return(0);
919 }
920
921
922 VIEW *
923 getview(n) /* get view number n */
924 int n;
925 {
926 static FILE *viewfp = NULL; /* view file pointer */
927 static int viewnum = 0; /* current view number */
928 static VIEW curview = STDVIEW; /* current view */
929 char linebuf[256];
930
931 if (n == 0) { /* signal to close file and clean up */
932 if (viewfp != NULL) {
933 fclose(viewfp);
934 viewfp = NULL;
935 viewnum = 0;
936 copystruct(&curview, &stdview);
937 }
938 return(NULL);
939 }
940 if (viewfp == NULL) { /* open file */
941 if ((viewfp = fopen(vval(VIEWFILE), "r")) == NULL) {
942 perror(vval(VIEWFILE));
943 quit(1);
944 }
945 } else if (n < viewnum) { /* rewind file */
946 if (fseek(viewfp, 0L, 0) == EOF) {
947 perror(vval(VIEWFILE));
948 quit(1);
949 }
950 copystruct(&curview, &stdview);
951 viewnum = 0;
952 }
953 while (n > viewnum) { /* scan to desired view */
954 if (fgets(linebuf, sizeof(linebuf), viewfp) == NULL)
955 return(NULL);
956 if (isview(linebuf) && sscanview(&curview, linebuf) > 0)
957 viewnum++;
958 }
959 return(&curview); /* return it */
960 }
961
962
963 int
964 countviews() /* count views in view file */
965 {
966 register int n = 0;
967
968 while (getview(n+1) != NULL)
969 n++;
970 return(n);
971 }
972
973
974 char *
975 getexp(n) /* get exposure for nth frame */
976 int n;
977 {
978 extern char *fskip();
979 static char expval[32];
980 static FILE *expfp = NULL;
981 static long *exppos;
982 static int curfrm;
983 register char *cp;
984
985 if (n == 0) { /* signal to close file */
986 if (expfp != NULL) {
987 fclose(expfp);
988 expfp = NULL;
989 }
990 return(NULL);
991 }
992 if (!vdef(EXPOSURE)) /* no setting (auto) */
993 return(NULL);
994 if (isflt(vval(EXPOSURE))) /* always the same */
995 return(vval(EXPOSURE));
996 if (expfp == NULL) { /* open exposure file */
997 if ((expfp = fopen(vval(EXPOSURE), "r")) == NULL) {
998 fprintf(stderr,
999 "%s: cannot open exposure file \"%s\"\n",
1000 progname, vval(EXPOSURE));
1001 quit(1);
1002 }
1003 curfrm = vint(END) + 1; /* init lookup tab. */
1004 exppos = (long *)malloc(curfrm*sizeof(long *));
1005 if (exppos == NULL) {
1006 perror(progname);
1007 quit(1);
1008 }
1009 while (curfrm--)
1010 exppos[curfrm] = -1L;
1011 curfrm = 0;
1012 }
1013 /* find position in file */
1014 if (n-1 != curfrm && n != curfrm && exppos[n-1] >= 0 &&
1015 fseek(expfp, exppos[curfrm=n-1], 0) == EOF) {
1016 fprintf(stderr, "%s: seek error on exposure file\n", progname);
1017 quit(1);
1018 }
1019 while (n > curfrm) { /* read exposure */
1020 if (exppos[curfrm] < 0)
1021 exppos[curfrm] = ftell(expfp);
1022 if (fgets(expval, sizeof(expval), expfp) == NULL) {
1023 fprintf(stderr, "%s: too few exposures\n",
1024 vval(EXPOSURE));
1025 quit(1);
1026 }
1027 curfrm++;
1028 cp = fskip(expval); /* check format */
1029 if (cp == NULL || *cp != '\n') {
1030 fprintf(stderr,
1031 "%s: exposure format error on line %d\n",
1032 vval(EXPOSURE), curfrm);
1033 quit(1);
1034 }
1035 *cp = '\0';
1036 }
1037 return(expval); /* return value */
1038 }
1039
1040
1041 struct pslot *
1042 findpslot(pid) /* find or allocate a process slot */
1043 int pid;
1044 {
1045 register struct pslot *psempty = NULL;
1046 register int i;
1047
1048 for (i = 0; i < npslots; i++) { /* look for match */
1049 if (pslot[i].pid == pid)
1050 return(pslot+i);
1051 if (psempty == NULL && pslot[i].pid == 0)
1052 psempty = pslot+i;
1053 }
1054 return(psempty); /* return emtpy slot (error if NULL) */
1055 }
1056
1057
1058 int
1059 donecom(ps, pn, status) /* clean up after finished process */
1060 PSERVER *ps;
1061 int pn;
1062 int status;
1063 {
1064 register PROC *pp;
1065
1066 pp = ps->proc + pn;
1067 if (pp->elen) { /* pass errors */
1068 if (ps->hostname[0])
1069 fprintf(stderr, "%s: ", ps->hostname);
1070 fprintf(stderr, "Error output from: %s\n", pp->com);
1071 fputs(pp->errs, stderr);
1072 fflush(stderr);
1073 if (ps->hostname[0])
1074 status = 1; /* because rsh doesn't return status */
1075 }
1076 freestr(pp->com); /* free command string */
1077 lastpid = pp->pid; /* record PID for bwait() */
1078 lastpserver = ps; /* record server for serverdown() */
1079 return(status);
1080 }
1081
1082
1083 int
1084 serverdown() /* check status of last process server */
1085 {
1086 if (pserverOK(lastpserver)) /* server still up? */
1087 return(0);
1088 delpserver(lastpserver); /* else delete it */
1089 if (pslist == NULL) {
1090 fprintf(stderr, "%s: all process servers are down\n",
1091 progname);
1092 quit(1);
1093 }
1094 return(1);
1095 }
1096
1097
1098 int
1099 bruncom(com, fout, rf) /* run a command in the background */
1100 char *com;
1101 int fout;
1102 int (*rf)();
1103 {
1104 int pid;
1105 register struct pslot *psl;
1106
1107 if (noaction) {
1108 if (!silent)
1109 printf("\t%s\n", com); /* echo command */
1110 return(0);
1111 }
1112 /* else start it when we can */
1113 while ((pid = startjob(NULL, savestr(com), donecom)) == -1)
1114 bwait(1);
1115 if (!silent) { /* echo command */
1116 PSERVER *ps;
1117 int psn = pid;
1118 ps = findjob(&psn);
1119 printf("\t%s\n", com);
1120 printf("\tProcess started on %s\n", phostname(ps));
1121 fflush(stdout);
1122 }
1123 psl = findpslot(pid); /* record info. in appropriate slot */
1124 psl->pid = pid;
1125 psl->fout = fout;
1126 psl->rcvf = rf;
1127 return(pid);
1128 }
1129
1130
1131 bwait(ncoms) /* wait for batch job(s) to finish */
1132 int ncoms;
1133 {
1134 int status;
1135 register struct pslot *psl;
1136
1137 if (noaction)
1138 return;
1139 while ((status = wait4job(NULL, -1)) != -1) {
1140 psl = findpslot(lastpid);
1141 if (status) { /* attempt recovery */
1142 serverdown(); /* check server */
1143 if (psl->rcvf == NULL || (*psl->rcvf)(psl->fout)) {
1144 fprintf(stderr,
1145 "%s: error rendering frame %d\n",
1146 progname, psl->fout);
1147 quit(1);
1148 }
1149 }
1150 psl->pid = 0; /* free process slot */
1151 if (!--ncoms)
1152 return; /* done enough */
1153 }
1154 }
1155
1156
1157 int
1158 pruncom(com, ppins, maxcopies) /* run a command in parallel over network */
1159 char *com, *ppins;
1160 int maxcopies;
1161 {
1162 int retstatus = 0;
1163 int hostcopies;
1164 char com1buf[10240], *com1, *endcom1;
1165 int status;
1166 register PSERVER *ps;
1167
1168 if (!silent)
1169 printf("\t%s &\n", com); /* echo command */
1170 if (noaction)
1171 return(0);
1172 fflush(stdout);
1173 /* start jobs on each server */
1174 for (ps = pslist; ps != NULL; ps = ps->next) {
1175 hostcopies = 0;
1176 if (maxcopies > 1 && ps->nprocs > 1 && ppins != NULL) {
1177 strcpy(com1=com1buf, com); /* build -PP command */
1178 sprintf(com1+(ppins-com), " -PP %s/%s.persist",
1179 vval(DIRECTORY), phostname(ps));
1180 strcat(com1, ppins);
1181 endcom1 = com1 + strlen(com1);
1182 sprintf(endcom1, "; kill `sed -n '1s/^[^ ]* //p' %s/%s.persist`",
1183 vval(DIRECTORY), phostname(ps));
1184 } else {
1185 com1 = com;
1186 endcom1 = NULL;
1187 }
1188 while (maxcopies > 0 &&
1189 startjob(ps, savestr(com1), donecom) != -1) {
1190 sleep(10);
1191 hostcopies++;
1192 maxcopies--;
1193 if (endcom1 != NULL)
1194 *endcom1 = '\0';
1195 }
1196 if (!silent && hostcopies) {
1197 if (hostcopies > 1)
1198 printf("\t%d duplicate processes", hostcopies);
1199 else
1200 printf("\tProcess");
1201 printf(" started on %s\n", phostname(ps));
1202 fflush(stdout);
1203 }
1204 }
1205 /* wait for jobs to finish */
1206 while ((status = wait4job(NULL, -1)) != -1)
1207 if (status)
1208 retstatus += !serverdown(); /* check server */
1209 return(retstatus);
1210 }
1211
1212
1213 runcom(cs) /* run a command locally and wait for it */
1214 char *cs;
1215 {
1216 if (!silent) /* echo it */
1217 printf("\t%s\n", cs);
1218 if (noaction)
1219 return(0);
1220 fflush(stdout); /* flush output and pass to shell */
1221 return(system(cs));
1222 }
1223
1224
1225 rmfile(fn) /* remove a file */
1226 char *fn;
1227 {
1228 if (!silent)
1229 #ifdef MSDOS
1230 printf("\tdel %s\n", fn);
1231 #else
1232 printf("\trm -f %s\n", fn);
1233 #endif
1234 if (noaction)
1235 return(0);
1236 return(unlink(fn));
1237 }
1238
1239
1240 badvalue(vc) /* report bad variable value and exit */
1241 int vc;
1242 {
1243 fprintf(stderr, "%s: bad value for variable '%s'\n",
1244 progname, vnam(vc));
1245 quit(1);
1246 }
