root/radiance/ray/src/util/rambpos.cal
Wed Sep 3 14:05:55 2014 UTC (10 years, 8 months ago) by greg
CVS Tags: HEAD, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.6: +5 -2 lines
Added corral flag highlighting
Thu May 15 17:30:53 2014 UTC (10 years, 11 months ago) by greg
CVS Tags: rad4R2
Changes since 2.5: +19 -15 lines
Improved geometry
Fri May 9 23:49:05 2014 UTC (11 years ago) by greg
Additional checks to avoid errors
Thu May 1 02:52:03 2014 UTC (11 years ago) by greg
Changes since 2.3: +4 -2 lines
Fixed a number of issues with zero values and corrected direction gradient
Fri Apr 25 22:56:06 2014 UTC (11 years ago) by greg
Changed ambient value color to match 50% diffuse surface
Fri Apr 25 18:13:47 2014 UTC (11 years ago) by greg
Diff to previous 2.1
Added -w option and changed arrow to reflect weight
Thu Apr 24 23:15:42 2014 UTC (11 years ago) by greg
Deprecated genambpos and put new Perl script in its place
