| 1 | #ifndef lint |
| 2 | static const char RCSid[] = "$Id: radcompare.c,v 2.6 2018/10/15 22:38:31 greg Exp $"; |
| 3 | #endif |
| 4 | /* |
| 5 | * Compare Radiance files for significant differences |
| 6 | * |
| 7 | *      G. Ward |
| 8 | */ |
| 9 |  |
| 10 | #include <stdlib.h> |
| 11 | #include <math.h> |
| 12 | #include <ctype.h> |
| 13 | #include "platform.h" |
| 14 | #include "rtio.h" |
| 15 | #include "resolu.h" |
| 16 | #include "color.h" |
| 17 | #include "lookup.h" |
| 18 | /* Reporting levels */ |
| 19 | #define REP_QUIET       0       /* no reporting */ |
| 20 | #define REP_ERROR       1       /* report errors only */ |
| 21 | #define REP_WARN        2       /* report warnings as well */ |
| 22 | #define REP_VERBOSE     3       /* verbose reporting */ |
| 23 |  |
| 24 | int     report = REP_WARN;      /* reporting level */ |
| 25 |  |
| 26 | int     ign_header = 0;         /* ignore header differences? */ |
| 27 |  |
| 28 | double  rel_min = 1e-5;         /* positive for relative comparisons */ |
| 29 |  |
| 30 | double  rms_lim = 0.01;         /* RMS difference limit */ |
| 31 |  |
| 32 | double  max_lim = 0.25;         /* difference limit if non-negative */ |
| 33 |  |
| 34 | int     lin1cnt=0, lin2cnt=0;   /* file line position */ |
| 35 |  |
| 36 | const char      nsuffix[10][3] = {              /* 1st, 2nd, 3rd, etc. */ |
| 37 | "th","st","nd","rd","th","th","th","th","th","th" |
| 38 | }; |
| 39 | #define num_sfx(n)      nsuffix[(n)%10] |
| 40 |  |
| 41 | /* file types */ |
| 42 | const char      *file_type[] = { |
| 43 | "Unrecognized", |
| 44 | "TEXT_generic", |
| 45 | "ascii", |
| 46 | COLRFMT, |
| 47 | CIEFMT, |
| 48 | "float", |
| 49 | "double", |
| 50 | "BSDF_RBFmesh", |
| 51 | "Radiance_octree", |
| 52 | "Radiance_tmesh", |
| 53 | "BINARY_unknown", |
| 54 | NULL    /* terminator */ |
| 55 | }; |
| 56 | /* keep consistent with above */ |
| 57 | enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE, TYP_FLOAT, |
| 58 | TYP_DOUBLE, TYP_RBFMESH, TYP_OCTREE, TYP_TMESH, TYP_BINARY}; |
| 59 |  |
| 60 | #define has_header(t)   (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) )) |
| 61 |  |
| 62 | /* header variables to always ignore */ |
| 63 | const char      *hdr_ignkey[] = { |
| 64 | "SOFTWARE", |
| 65 | "CAPDATE", |
| 66 | "GMT", |
| 67 | NULL    /* terminator */ |
| 68 | }; |
| 69 | /* header variable settings */ |
| 70 | LUTAB   hdr1 = LU_SINIT(free,free); |
| 71 | LUTAB   hdr2 = LU_SINIT(free,free); |
| 72 |  |
| 73 | /* advance appropriate file line count */ |
| 74 | #define adv_linecnt(htp)        (lin1cnt += (htp == &hdr1), \ |
| 75 | lin2cnt += (htp == &hdr2)) |
| 76 |  |
| 77 | /* input files */ |
| 78 | char            *progname = NULL; |
| 79 | const char      stdin_name[] = "<stdin>"; |
| 80 | const char      *f1name=NULL, *f2name=NULL; |
| 81 | FILE            *f1in=NULL, *f2in=NULL; |
| 82 |  |
| 83 | /* running real differences */ |
| 84 | double  diff2sum = 0; |
| 85 | int     nsum = 0; |
| 86 |  |
| 87 | /* Report usage and exit */ |
| 88 | static void |
| 89 | usage() |
| 90 | { |
| 91 | fputs("Usage: ", stderr); |
| 92 | fputs(progname, stderr); |
| 93 | fputs(" [-h][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n", |
| 94 | stderr); |
| 95 | exit(1); |
| 96 | } |
| 97 |  |
| 98 | /* Get type ID from name (or 0 if not found) */ |
| 99 | static int |
| 100 | xlate_type(const char *nm) |
| 101 | { |
| 102 | int     i; |
| 103 |  |
| 104 | if (!nm || !*nm) |
| 105 | return(TYP_UNKNOWN); |
| 106 | for (i = 1; file_type[i]; i++) |
| 107 | if (!strcmp(nm, file_type[i])) |
| 108 | return(i); |
| 109 | return(TYP_UNKNOWN); |
| 110 | } |
| 111 |  |
| 112 | /* Compare real values and keep track of differences */ |
| 113 | static int |
| 114 | real_check(double r1, double r2) |
| 115 | { |
| 116 | double  diff2 = (r1 - r2)*(r1 - r2); |
| 117 |  |
| 118 | if (rel_min > 0) {      /* doing relative differences? */ |
| 119 | double  av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2); |
| 120 | if (av2 > rel_min*rel_min) |
| 121 | diff2 /= av2; |
| 122 | } |
| 123 | if (max_lim >= 0 && diff2 > max_lim*max_lim) { |
| 124 | if (report != REP_QUIET) |
| 125 | printf( |
| 126 | "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n", |
| 127 | progname, |
| 128 | (rel_min > 0) ? "relative " : "", |
| 129 | r1, r2, max_lim); |
| 130 | return(0); |
| 131 | } |
| 132 | diff2sum += diff2; |
| 133 | nsum++; |
| 134 | return(1); |
| 135 | } |
| 136 |  |
| 137 | /* Compare two strings for equivalence */ |
| 138 | static int |
| 139 | equiv_string(char *s1, char *s2) |
| 140 | { |
| 141 | #define CLS_STR         0 |
| 142 | #define CLS_INT         1 |
| 143 | #define CLS_FLT         2 |
| 144 | /* skip whitespace at beginning */ |
| 145 | while (isspace(*s1)) s1++; |
| 146 | while (isspace(*s2)) s2++; |
| 147 | while (*s1) {           /* check each word */ |
| 148 | int     inquote; |
| 149 | if (!*s2)       /* unexpected EOL in s2? */ |
| 150 | return(0); |
| 151 | inquote = *s1; |
| 152 | if ((inquote != '\'') & (inquote != '"')) |
| 153 | inquote = 0; |
| 154 | if (inquote) {  /* quoted text must match exactly */ |
| 155 | if (*s1++ != *s2++) |
| 156 | return(0); |
| 157 | while (*s1 != inquote) { |
| 158 | if (!*s1) |
| 159 | return(0); |
| 160 | if (*s1++ != *s2++) |
| 161 | return(0); |
| 162 | } |
| 163 | s1++; |
| 164 | if (*s2++ != inquote) |
| 165 | return(0); |
| 166 | } else {        /* else classify word type */ |
| 167 | char    *s1s = s1; |
| 168 | char    *s2s = s2; |
| 169 | int     cls = CLS_STR; |
| 170 | s1 = sskip(s1); |
| 171 | s2 = sskip(s2); |
| 172 | if (iskip(s1s) == s1) { |
| 173 | if (iskip(s2s) == s2) |
| 174 | cls = CLS_INT; |
| 175 | else if (fskip(s2s) == s2) |
| 176 | cls = CLS_FLT; |
| 177 | } else if (fskip(s1s) == s1) { |
| 178 | if (fskip(s2s) != s2) |
| 179 | return(0); |
| 180 | cls = CLS_FLT; |
| 181 | } |
| 182 | switch (cls) { |
| 183 | case CLS_INT:           /* strncmp() faster */ |
| 184 | case CLS_STR: |
| 185 | if (s1 - s1s != s2 - s2s) |
| 186 | return(0); |
| 187 | if (strncmp(s1s, s2s, s1 - s1s)) |
| 188 | return(0); |
| 189 | break; |
| 190 | case CLS_FLT: |
| 191 | if (!real_check(atof(s1s), atof(s2s))) |
| 192 | return(0); |
| 193 | break; |
| 194 | } |
| 195 | } |
| 196 | while (isspace(*s1)) s1++; |
| 197 | while (isspace(*s2)) s2++; |
| 198 | } |
| 199 | return(!*s2);           /* match if we reached the end of s2, too */ |
| 200 | #undef CLS_STR |
| 201 | #undef CLS_INT |
| 202 | #undef CLS_FLT |
| 203 | } |
| 204 |  |
| 205 | /* Check if string is var=value pair and set if not in ignore list */ |
| 206 | static int |
| 207 | setheadvar(char *val, void *p) |
| 208 | { |
| 209 | LUTAB   *htp = (LUTAB *)p; |
| 210 | LUENT   *tep; |
| 211 | char    *key; |
| 212 | int     kln, vln; |
| 213 | int     n; |
| 214 |  |
| 215 | adv_linecnt(htp);       /* side-effect is to count lines */ |
| 216 | if (!isalpha(*val))     /* key must start line */ |
| 217 | return(0); |
| 218 | key = val++; |
| 219 | while (*val && !isspace(*val) & (*val != '=')) |
| 220 | val++; |
| 221 | kln = val - key; |
| 222 | while (isspace(*val))   /* check for value */ |
| 223 | *val++ = '\0'; |
| 224 | if (*val != '=') |
| 225 | return(0); |
| 226 | *val++ = '\0'; |
| 227 | while (isspace(*val)) |
| 228 | val++; |
| 229 | if (!*val)              /* nothing set? */ |
| 230 | return(0); |
| 231 | /* check if key to ignore */ |
| 232 | for (n = 0; hdr_ignkey[n]; n++) |
| 233 | if (!strcmp(key, hdr_ignkey[n])) |
| 234 | return(0); |
| 235 | vln = strlen(val);      /* eliminate space and newline at end */ |
| 236 | while (isspace(val[--vln])) |
| 237 | ; |
| 238 | val[++vln] = '\0'; |
| 239 | if (!(tep = lu_find(htp, key))) |
| 240 | return(-1);     /* memory allocation error */ |
| 241 | if (!tep->key) |
| 242 | tep->key = strcpy(malloc(kln+1), key); |
| 243 | if (tep->data) |
| 244 | free(tep->data); |
| 245 | tep->data = strcpy(malloc(vln+1), val); |
| 246 | return(1); |
| 247 | } |
| 248 |  |
| 249 | /* Lookup correspondent in other header */ |
| 250 | static int |
| 251 | match_val(const LUENT *ep1, void *p2) |
| 252 | { |
| 253 | const LUENT     *ep2 = lu_find((LUTAB *)p2, ep1->key); |
| 254 | if (!ep2 || !ep2->data) { |
| 255 | if (report != REP_QUIET) |
| 256 | printf("%s: variable '%s' missing in '%s'\n", |
| 257 | progname, ep1->key, f2name); |
| 258 | return(-1); |
| 259 | } |
| 260 | if (!equiv_string((char *)ep1->data, (char *)ep2->data)) { |
| 261 | if (report != REP_QUIET) { |
| 262 | printf("%s: header variable '%s' has different values\n", |
| 263 | progname, ep1->key); |
| 264 | if (report >= REP_VERBOSE) { |
| 265 | printf("%s: %s=%s\n", f1name, |
| 266 | ep1->key, (char *)ep1->data); |
| 267 | printf("%s: %s=%s\n", f2name, |
| 268 | ep2->key, (char *)ep2->data); |
| 269 | } |
| 270 | } |
| 271 | return(-1); |
| 272 | } |
| 273 | return(1);              /* good match */ |
| 274 | } |
| 275 |  |
| 276 | /* Compare two sets of header variables */ |
| 277 | static int |
| 278 | headers_match(LUTAB *hp1, LUTAB *hp2) |
| 279 | { |
| 280 | int     ne = lu_doall(hp1, match_val, hp2); |
| 281 | if (ne < 0) |
| 282 | return(0);      /* something didn't match! */ |
| 283 | /* non-fatal if second header has extra */ |
| 284 | if (report >= REP_WARN && (ne = lu_doall(hp2, NULL, NULL) - ne)) |
| 285 | printf("%s: warning - '%s' has %d extra header setting(s)\n", |
| 286 | progname, f2name, ne); |
| 287 | return(1);              /* good match */ |
| 288 | } |
| 289 |  |
| 290 | /* Check generic input to determine if it is binary, -1 on error */ |
| 291 | static int |
| 292 | input_is_binary(FILE *fin) |
| 293 | { |
| 294 | int     n = 0; |
| 295 | int     c = 0; |
| 296 |  |
| 297 | while ((c = getc(fin)) != EOF) { |
| 298 | ++n; |
| 299 | if (!c | (c > 127)) |
| 300 | break;                  /* non-ascii character */ |
| 301 | if (n >= 10240) |
| 302 | break;                  /* enough to be confident */ |
| 303 | } |
| 304 | if (!n) |
| 305 | return(-1);                     /* first read failed */ |
| 306 | if (fseek(fin, 0L, 0) < 0) |
| 307 | return(-1);                     /* rewind failed */ |
| 308 | return(!c | (c > 127)); |
| 309 | } |
| 310 |  |
| 311 | /* Identify and return data type from header (if one) */ |
| 312 | static int |
| 313 | identify_type(const char *name, FILE *fin, LUTAB *htp) |
| 314 | { |
| 315 | extern const char       HDRSTR[]; |
| 316 | int                     c; |
| 317 | /* check magic header start */ |
| 318 | if ((c = getc(fin)) != HDRSTR[0]) { |
| 319 | if (c == EOF) goto badeof; |
| 320 | ungetc(c, fin); |
| 321 | c = 0; |
| 322 | } else if ((c = getc(fin)) != HDRSTR[1]) { |
| 323 | if (c == EOF) goto badeof; |
| 324 | ungetc(c, fin); ungetc(HDRSTR[0], fin); |
| 325 | c = 0; |
| 326 | } |
| 327 | if (c) {                                /* appears to have a header */ |
| 328 | char    sbuf[32]; |
| 329 | if (!fgets(sbuf, sizeof(sbuf), fin)) |
| 330 | goto badeof; |
| 331 | adv_linecnt(htp);               /* for #?ID string */ |
| 332 | if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) { |
| 333 | fputs(name, stdout); |
| 334 | fputs(": warning - unexpected header ID: ", stdout); |
| 335 | fputs(sbuf, stdout); |
| 336 | } |
| 337 | if (getheader(fin, setheadvar, htp) < 0) { |
| 338 | fputs(name, stderr); |
| 339 | fputs(": unknown error reading header\n", stderr); |
| 340 | return(-1); |
| 341 | } |
| 342 | adv_linecnt(htp);               /* for trailing emtpy line */ |
| 343 | return(xlate_type((const char *)lu_find(htp,"FORMAT")->data)); |
| 344 | } |
| 345 | c = input_is_binary(fin);               /* else peek to see if binary */ |
| 346 | if (c < 0) { |
| 347 | fputs(name, stderr); |
| 348 | fputs(": read/seek error\n", stderr); |
| 349 | return(-1); |
| 350 | } |
| 351 | if (c) |
| 352 | return(TYP_BINARY); |
| 353 | SET_FILE_TEXT(fin);                     /* originally set to binary */ |
| 354 | return(TYP_TEXT); |
| 355 | badeof: |
| 356 | if (report != REP_QUIET) { |
| 357 | fputs(name, stdout); |
| 358 | fputs(": unexpected end-of-file\n", stdout); |
| 359 | } |
| 360 | return(-1); |
| 361 | } |
| 362 |  |
| 363 | /* Check that overall RMS error is below threshold */ |
| 364 | static int |
| 365 | good_RMS() |
| 366 | { |
| 367 | if (!nsum) |
| 368 | return(1); |
| 369 | if (diff2sum/(double)nsum > rms_lim*rms_lim) { |
| 370 | if (report != REP_QUIET) |
| 371 | printf( |
| 372 | "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n", |
| 373 | progname, |
| 374 | (rel_min > 0) ? "relative " : "", |
| 375 | f1name, f2name, |
| 376 | sqrt(diff2sum/(double)nsum), rms_lim); |
| 377 | return(0); |
| 378 | } |
| 379 | if (report >= REP_VERBOSE) |
| 380 | printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n", |
| 381 | progname, (rel_min > 0) ? "relative " : "", |
| 382 | f1name, f2name, sqrt(diff2sum/(double)nsum)); |
| 383 | return(1); |
| 384 | } |
| 385 |  |
| 386 | /* Compare two inputs as generic binary files */ |
| 387 | static int |
| 388 | compare_binary() |
| 389 | { |
| 390 | int     c1=0, c2=0; |
| 391 |  |
| 392 | if (report >= REP_VERBOSE) { |
| 393 | fputs(progname, stdout); |
| 394 | fputs(": comparing inputs as binary\n", stdout); |
| 395 | } |
| 396 | for ( ; ; ) {                           /* exact byte matching */ |
| 397 | c1 = getc(f1in); |
| 398 | c2 = getc(f2in); |
| 399 | if (c1 == EOF) { |
| 400 | if (c2 == EOF) |
| 401 | return(1);      /* success! */ |
| 402 | if (report != REP_QUIET) { |
| 403 | fputs(f1name, stdout); |
| 404 | fputs(": unexpected end-of-file\n", stdout); |
| 405 | } |
| 406 | return(0); |
| 407 | } |
| 408 | if (c2 == EOF) { |
| 409 | if (report != REP_QUIET) { |
| 410 | fputs(f2name, stdout); |
| 411 | fputs(": unexpected end-of-file\n", stdout); |
| 412 | } |
| 413 | return(0); |
| 414 | } |
| 415 | if (c1 != c2) |
| 416 | break;                  /* quit and report difference */ |
| 417 | } |
| 418 | if (report == REP_QUIET) |
| 419 | return(0); |
| 420 | printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n", |
| 421 | progname, f1name, f2name, ftell(f1in), ftell(f2in)); |
| 422 | if (report >= REP_VERBOSE) |
| 423 | printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n", |
| 424 | progname, f1name, c1, f2name, c2); |
| 425 | return(0); |
| 426 | } |
| 427 |  |
| 428 | /* Compare two inputs as generic text files */ |
| 429 | static int |
| 430 | compare_text() |
| 431 | { |
| 432 | char    l1buf[4096], l2buf[4096]; |
| 433 |  |
| 434 | if (report >= REP_VERBOSE) { |
| 435 | fputs(progname, stdout); |
| 436 | fputs(": comparing inputs as ASCII text\n", stdout); |
| 437 | } |
| 438 | /* compare a line at a time */ |
| 439 | while (fgets(l1buf, sizeof(l1buf), f1in)) { |
| 440 | lin1cnt++; |
| 441 | if (!*sskip2(l1buf,0)) |
| 442 | continue;               /* ignore empty lines */ |
| 443 | while (fgets(l2buf, sizeof(l2buf), f2in)) { |
| 444 | lin2cnt++; |
| 445 | if (*sskip2(l2buf,0)) |
| 446 | break;          /* found other non-empty line */ |
| 447 | } |
| 448 | if (feof(f2in)) { |
| 449 | if (report != REP_QUIET) { |
| 450 | fputs(f2name, stdout); |
| 451 | fputs(": unexpected end-of-file\n", stdout); |
| 452 | } |
| 453 | return(0); |
| 454 | } |
| 455 | /* compare non-empty lines */ |
| 456 | if (!equiv_string(l1buf, l2buf)) { |
| 457 | if (report != REP_QUIET) { |
| 458 | printf("%s: inputs '%s' and '%s' differ at line %d|%d\n", |
| 459 | progname, f1name, f2name, |
| 460 | lin1cnt, lin2cnt); |
| 461 | if (report >= REP_VERBOSE) { |
| 462 | fputs("------------- Mismatch -------------\n", stdout); |
| 463 | printf("%s@%d:\t%s", f1name, |
| 464 | lin1cnt, l1buf); |
| 465 | printf("%s@%d:\t%s", f2name, |
| 466 | lin2cnt, l2buf); |
| 467 | } |
| 468 | } |
| 469 | return(0); |
| 470 | } |
| 471 | } |
| 472 | /* check for EOF on input 2 */ |
| 473 | while (fgets(l2buf, sizeof(l2buf), f2in)) { |
| 474 | if (!*sskip2(l2buf,0)) |
| 475 | continue; |
| 476 | if (report != REP_QUIET) { |
| 477 | fputs(f1name, stdout); |
| 478 | fputs(": unexpected end-of-file\n", stdout); |
| 479 | } |
| 480 | return(0); |
| 481 | } |
| 482 | return(good_RMS());                     /* final check for reals */ |
| 483 | } |
| 484 |  |
| 485 | /* Compare two inputs that are known to be RGBE or XYZE images */ |
| 486 | static int |
| 487 | compare_hdr() |
| 488 | { |
| 489 | RESOLU  rs1, rs2; |
| 490 | COLOR   *scan1, *scan2; |
| 491 | int     x, y; |
| 492 |  |
| 493 | if (report >= REP_VERBOSE) { |
| 494 | fputs(progname, stdout); |
| 495 | fputs(": comparing inputs as HDR images\n", stdout); |
| 496 | } |
| 497 | fgetsresolu(&rs1, f1in); |
| 498 | fgetsresolu(&rs2, f2in); |
| 499 | if (rs1.rt != rs2.rt) { |
| 500 | if (report != REP_QUIET) |
| 501 | printf( |
| 502 | "%s: Images '%s' and '%s' have different pixel ordering\n", |
| 503 | progname, f1name, f2name); |
| 504 | return(0); |
| 505 | } |
| 506 | if ((rs1.xr != rs2.xr) | (rs1.yr != rs2.yr)) { |
| 507 | if (report != REP_QUIET) |
| 508 | printf( |
| 509 | "%s: Images '%s' and '%s' are different sizes\n", |
| 510 | progname, f1name, f2name); |
| 511 | return(0); |
| 512 | } |
| 513 | scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR)); |
| 514 | scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR)); |
| 515 | if (!scan1 | !scan2) { |
| 516 | fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname); |
| 517 | exit(2); |
| 518 | } |
| 519 | for (y = 0; y < numscans(&rs1); y++) { |
| 520 | if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) | |
| 521 | (freadscan(scan2, scanlen(&rs2), f2in) < 0)) { |
| 522 | if (report != REP_QUIET) |
| 523 | printf("%s: unexpected end-of-file\n", |
| 524 | progname); |
| 525 | free(scan1); |
| 526 | free(scan2); |
| 527 | return(0); |
| 528 | } |
| 529 | for (x = 0; x < scanlen(&rs1); x++) { |
| 530 | if (real_check(colval(scan1[x],RED), |
| 531 | colval(scan2[x],RED)) & |
| 532 | real_check(colval(scan1[x],GRN), |
| 533 | colval(scan2[x],GRN)) & |
| 534 | real_check(colval(scan1[x],BLU), |
| 535 | colval(scan2[x],BLU))) |
| 536 | continue; |
| 537 | if (report != REP_QUIET) { |
| 538 | printf( |
| 539 | "%s: pixels at scanline %d offset %d differ\n", |
| 540 | progname, y, x); |
| 541 | if (report >= REP_VERBOSE) { |
| 542 | printf("%s: (R,G,B)=(%g,%g,%g)\n", |
| 543 | f1name, colval(scan1[x],RED), |
| 544 | colval(scan1[x],GRN), |
| 545 | colval(scan1[x],BLU)); |
| 546 | printf("%s: (R,G,B)=(%g,%g,%g)\n", |
| 547 | f2name, colval(scan2[x],RED), |
| 548 | colval(scan2[x],GRN), |
| 549 | colval(scan2[x],BLU)); |
| 550 | } |
| 551 | } |
| 552 | free(scan1); |
| 553 | free(scan2); |
| 554 | return(0); |
| 555 | } |
| 556 | } |
| 557 | free(scan1); |
| 558 | free(scan2); |
| 559 | return(good_RMS());                     /* final check of RMS */ |
| 560 | } |
| 561 |  |
| 562 | /* Compare two inputs that are known to be 32-bit floating-point data */ |
| 563 | static int |
| 564 | compare_float() |
| 565 | { |
| 566 | long    nread = 0; |
| 567 | float   f1, f2; |
| 568 |  |
| 569 | if (report >= REP_VERBOSE) { |
| 570 | fputs(progname, stdout); |
| 571 | fputs(": comparing inputs as 32-bit IEEE floats\n", stdout); |
| 572 | } |
| 573 | while (getbinary(&f1, sizeof(f1), 1, f1in)) { |
| 574 | if (!getbinary(&f2, sizeof(f2), 1, f2in)) |
| 575 | goto badeof; |
| 576 | ++nread; |
| 577 | if (real_check(f1, f2)) |
| 578 | continue; |
| 579 | if (report != REP_QUIET) |
| 580 | printf("%s: %ld%s float values differ\n", |
| 581 | progname, nread, num_sfx(nread)); |
| 582 | return(0); |
| 583 | } |
| 584 | if (!getbinary(&f2, sizeof(f2), 1, f2in)) |
| 585 | return(good_RMS());             /* final check of RMS */ |
| 586 | badeof: |
| 587 | if (report != REP_QUIET) |
| 588 | printf("%s: unexpected end-of-file\n", progname); |
| 589 | return(0); |
| 590 | } |
| 591 |  |
| 592 | /* Compare two inputs that are known to be 64-bit floating-point data */ |
| 593 | static int |
| 594 | compare_double() |
| 595 | { |
| 596 | long    nread = 0; |
| 597 | double  f1, f2; |
| 598 |  |
| 599 | if (report >= REP_VERBOSE) { |
| 600 | fputs(progname, stdout); |
| 601 | fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout); |
| 602 | } |
| 603 | while (getbinary(&f1, sizeof(f1), 1, f1in)) { |
| 604 | if (!getbinary(&f2, sizeof(f2), 1, f2in)) |
| 605 | goto badeof; |
| 606 | ++nread; |
| 607 | if (real_check(f1, f2)) |
| 608 | continue; |
| 609 | if (report != REP_QUIET) |
| 610 | printf("%s: %ld%s double values differ\n", |
| 611 | progname, nread, num_sfx(nread)); |
| 612 | return(0); |
| 613 | } |
| 614 | if (!getbinary(&f2, sizeof(f2), 1, f2in)) |
| 615 | return(good_RMS());             /* final check of RMS */ |
| 616 | badeof: |
| 617 | if (report != REP_QUIET) |
| 618 | printf("%s: unexpected end-of-file\n", progname); |
| 619 | return(0); |
| 620 | } |
| 621 |  |
| 622 | /* Compare two Radiance files for equivalence */ |
| 623 | int |
| 624 | main(int argc, char *argv[]) |
| 625 | { |
| 626 | int     typ1, typ2; |
| 627 | int     a; |
| 628 |  |
| 629 | progname = argv[0]; |
| 630 | for (a = 1; a < argc && argv[a][0] == '-'; a++) { |
| 631 | switch (argv[a][1]) { |
| 632 | case 'h':                       /* ignore header info. */ |
| 633 | ign_header = !ign_header; |
| 634 | continue; |
| 635 | case 's':                       /* silent operation */ |
| 636 | report = REP_QUIET; |
| 637 | continue; |
| 638 | case 'w':                       /* turn off warnings */ |
| 639 | if (report > REP_ERROR) |
| 640 | report = REP_ERROR; |
| 641 | continue; |
| 642 | case 'v':                       /* turn on verbose mode */ |
| 643 | report = REP_VERBOSE; |
| 644 | continue; |
| 645 | case 'm':                       /* maximum epsilon */ |
| 646 | max_lim = atof(argv[++a]); |
| 647 | continue; |
| 648 | case 'r': |
| 649 | if (argv[a][2] == 'e')          /* relative difference */ |
| 650 | rel_min = atof(argv[++a]); |
| 651 | else if (argv[a][2] == 'm')     /* RMS limit */ |
| 652 | rms_lim = atof(argv[++a]); |
| 653 | else |
| 654 | usage(); |
| 655 | continue; |
| 656 | case '\0':                      /* first file from stdin */ |
| 657 | f1in = stdin; |
| 658 | f1name = stdin_name; |
| 659 | break; |
| 660 | default: |
| 661 | usage(); |
| 662 | } |
| 663 | break; |
| 664 | } |
| 665 | if (a != argc-2)                        /* make sure of two inputs */ |
| 666 | usage(); |
| 667 | if (!strcmp(argv[a], argv[a+1])) {      /* inputs are same? */ |
| 668 | if (report >= REP_WARN) |
| 669 | printf("%s: warning - identical inputs given\n", |
| 670 | progname); |
| 671 | return(0); |
| 672 | } |
| 673 | if (!f1name) f1name = argv[a]; |
| 674 | if (!f2name) f2name = argv[a+1]; |
| 675 | /* open inputs */ |
| 676 | SET_FILE_BINARY(stdin);                 /* in case we're using it */ |
| 677 | if (!f1in && !(f1in = fopen(f1name, "rb"))) { |
| 678 | fprintf(stderr, "%s: cannot open for reading\n", f1name); |
| 679 | return(1); |
| 680 | } |
| 681 | if (!strcmp(f2name, "-")) { |
| 682 | f2in = stdin; |
| 683 | f2name = stdin_name; |
| 684 | } else if (!(f2in = fopen(f2name, "rb"))) { |
| 685 | fprintf(stderr, "%s: cannot open for reading\n", f2name); |
| 686 | return(1); |
| 687 | } |
| 688 | /* load headers */ |
| 689 | if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0) |
| 690 | return(1); |
| 691 | if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0) |
| 692 | return(1); |
| 693 | if (typ1 != typ2) { |
| 694 | if (report != REP_QUIET) |
| 695 | printf("%s: '%s' is %s and '%s' is %s\n", |
| 696 | progname, f1name, file_type[typ1], |
| 697 | f2name, file_type[typ2]); |
| 698 | return(1); |
| 699 | } |
| 700 | ign_header |= !has_header(typ1);        /* check headers if indicated */ |
| 701 | if (!ign_header && !headers_match(&hdr1, &hdr2)) |
| 702 | return(1); |
| 703 | lu_done(&hdr1); lu_done(&hdr2); |
| 704 | if (!ign_header & (report >= REP_WARN)) { |
| 705 | if (typ1 == TYP_UNKNOWN) |
| 706 | printf("%s: warning - unrecognized format, comparing as binary\n", |
| 707 | progname); |
| 708 | if (lin1cnt != lin2cnt) |
| 709 | printf("%s: warning - headers are different lengths\n", |
| 710 | progname); |
| 711 | } |
| 712 | if (report >= REP_VERBOSE) |
| 713 | printf("%s: input file type is %s\n", |
| 714 | progname, file_type[typ1]); |
| 715 |  |
| 716 | switch (typ1) {                         /* compare based on type */ |
| 717 | case TYP_BINARY: |
| 718 | case TYP_TMESH: |
| 719 | case TYP_OCTREE: |
| 720 | case TYP_RBFMESH: |
| 721 | case TYP_UNKNOWN: |
| 722 | return( !compare_binary() ); |
| 723 | case TYP_TEXT: |
| 724 | case TYP_ASCII: |
| 725 | return( !compare_text() ); |
| 726 | case TYP_RGBE: |
| 727 | case TYP_XYZE: |
| 728 | return( !compare_hdr() ); |
| 729 | case TYP_FLOAT: |
| 730 | return( !compare_float() ); |
| 731 | case TYP_DOUBLE: |
| 732 | return( !compare_double() ); |
| 733 | } |
| 734 | return(1); |
| 735 | } |
