root/radiance/ray/src/util/radcompare.c
Revision: 2.29
Committed: Thu Mar 3 00:01:48 2022 UTC (2 years, 1 month ago) by greg
Changes since 2.28: +20 -2 lines
feat(radcompare): Added '-n' option to allow escaped newlines
2 static const char RCSid[] = "$Id: radcompare.c,v 2.28 2021/09/27 19:00:04 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 int escape_newlines = 0; /* allow backslash to skip newlines */
31
32 double rel_min = 1e-5; /* positive for relative comparisons */
33
34 double rms_lim = 0.01; /* RMS difference limit */
35
36 double max_lim = 0.25; /* difference limit if non-negative */
37
38 int lin1cnt=0, lin2cnt=0; /* file line position */
39
40 int comment_c = '\0'; /* comment delimiter for text files */
41
42 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
43 "th","st","nd","rd","th","th","th","th","th","th"
44 };
45 #define num_sfx(n) nsuffix[(n)%10]
46
47 /* file types */
48 const char *file_type[] = {
49 "Unrecognized",
50 "TEXT_generic",
51 "ascii",
52 COLRFMT,
53 CIEFMT,
54 DEPTH16FMT,
55 NORMAL32FMT,
56 "float",
57 "double",
58 "BSDF_RBFmesh",
59 "Radiance_octree",
60 "Radiance_tmesh",
61 "8-bit_indexed_name",
62 "16-bit_indexed_name",
63 "24-bit_indexed_name",
64 "BINARY_unknown",
65 NULL /* terminator */
66 };
67 /* keep consistent with above */
68 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE,
69 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
70 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
71 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
72
73 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
74
75 /* header variables to always ignore */
76 const char *hdr_ignkey[] = {
77 "SOFTWARE",
78 "CAPDATE",
79 "GMT",
80 "FRAME",
81 NULL /* terminator */
82 };
83 /* header variable settings */
84 LUTAB hdr1 = LU_SINIT(free,free);
85 LUTAB hdr2 = LU_SINIT(free,free);
86
87 /* advance appropriate file line count */
88 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
89 lin2cnt += (htp == &hdr2))
90
91 typedef struct { /* dynamic line buffer */
92 char *str;
93 int len;
94 int siz;
95 } LINEBUF;
96
97 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
98 /* 100 MByte limit on line buffer */
99 #define MAXBUF (100L<<20)
100
101 /* input files */
102 char *progname = NULL;
103 const char stdin_name[] = "<stdin>";
104 const char *f1name=NULL, *f2name=NULL;
105 FILE *f1in=NULL, *f2in=NULL;
106 int f1swap=0, f2swap=0;
107
108 /* running real differences */
109 double diff2sum = 0;
110 long nsum = 0;
111
112 /* Report usage and exit */
113 static void
114 usage()
115 {
116 fputs("Usage: ", stderr);
117 fputs(progname, stderr);
118 fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
119 stderr);
120 exit(2);
121 }
122
123 /* Read a text line, increasing buffer size as necessary */
124 static int
125 read_line(LINEBUF *bp, FILE *fp)
126 {
127 static int doneWarn = 0;
128
129 bp->len = 0;
130 if (!bp->str) {
131 bp->str = (char *)malloc(bp->siz = 512);
132 if (!bp->str)
133 goto memerr;
134 }
135 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
136 bp->len += strlen(bp->str + bp->len);
137 if (bp->str[bp->len-1] == '\n') {
138 if (bp->len > 1 && bp->str[bp->len-2] == '\r') {
139 bp->str[--bp->len] = '\0';
140 bp->str[bp->len-1] = '\n';
141 }
142 if (escape_newlines && bp->len > 1 &&
143 bp->str[bp->len-2] == '\\') {
144 bp->str[--bp->len] = '\0';
145 bp->str[bp->len-1] = ' ';
146 continue;
147 }
148 break; /* found EOL */
149 }
150 if (bp->len < bp->siz - 4)
151 continue; /* at EOF? */
152 if (bp->siz >= MAXBUF) {
153 if ((report >= REP_WARN) & !doneWarn) {
154 fprintf(stderr,
155 "%s: warning - input line(s) past %ld MByte limit\n",
156 progname, MAXBUF>>20);
157 doneWarn++;
158 }
159 break; /* return MAXBUF partial line */
160 }
161 if ((bp->siz += bp->siz/2) > MAXBUF)
162 bp->siz = MAXBUF;
163 bp->str = (char *)realloc(bp->str, bp->siz);
164 if (!bp->str)
165 goto memerr;
166 }
167 if (comment_c) { /* elide comment? */
168 char *cp = sskip2(bp->str,0);
169 if (*cp == comment_c) {
170 *cp++ = '\n';
171 *cp = '\0';
172 bp->len = cp - bp->str;
173 }
174 }
175 return(bp->len);
176 memerr:
177 fprintf(stderr,
178 "%s: out of memory in read_line() allocating %d byte buffer\n",
179 progname, bp->siz);
180 exit(2);
181 }
182
183 /* Free line buffer */
184 static void
185 free_line(LINEBUF *bp)
186 {
187 if (bp->str) free(bp->str);
188 init_line(bp);
189 }
190
191 /* Get type ID from name (or 0 if not found) */
192 static int
193 xlate_type(const char *nm)
194 {
195 int i;
196
197 if (!nm || !*nm)
198 return(TYP_UNKNOWN);
199 for (i = 1; file_type[i]; i++)
200 if (!strcmp(nm, file_type[i]))
201 return(i);
202 return(TYP_UNKNOWN);
203 }
204
205 /* Compare real values and keep track of differences */
206 static int
207 real_check(double r1, double r2)
208 {
209 double diff2 = (r1 - r2)*(r1 - r2);
210
211 if (rel_min > 0) { /* doing relative differences? */
212 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
213 if (av2 < rel_min*rel_min)
214 av2 = rel_min*rel_min;
215 diff2 /= av2;
216 }
217 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
218 if (report != REP_QUIET)
219 printf(
220 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
221 progname,
222 (rel_min > 0) ? "relative " : "",
223 r1, r2, max_lim);
224 return(0);
225 }
226 diff2sum += diff2;
227 nsum++;
228 return(1);
229 }
230
231 /* Compare two color values for equivalence */
232 static int
233 color_check(COLOR c1, COLOR c2)
234 {
235 int p;
236
237 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
238 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
239 return(0);
240
241 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
242 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
243
244 return(real_check(colval(c1,p), colval(c2,p)));
245 }
246
247 /* Compare two normal directions for equivalence */
248 static int
249 norm_check(FVECT nv1, FVECT nv2)
250 {
251 double max2 = nv1[2]*nv2[2];
252 int imax = 2;
253 int i = 2;
254 /* identify largest component */
255 while (i--) {
256 double tm2 = nv1[i]*nv2[i];
257 if (tm2 > max2) {
258 imax = i;
259 max2 = tm2;
260 }
261 }
262 i = 3; /* compare smaller components */
263 while (i--) {
264 if (i == imax)
265 continue;
266 if (!real_check(nv1[i], nv2[i]))
267 return(0);
268 }
269 return(1);
270 }
271
272 /* Compare two strings for equivalence */
273 static int
274 equiv_string(char *s1, char *s2)
275 {
276 #define CLS_STR 0
277 #define CLS_INT 1
278 #define CLS_FLT 2
279 /* skip whitespace at beginning */
280 while (isspace(*s1)) s1++;
281 while (isspace(*s2)) s2++;
282 while (*s1) { /* check each word */
283 int inquote;
284 if (!*s2) /* unexpected EOL in s2? */
285 return(0);
286 inquote = *s1;
287 if ((inquote != '\'') & (inquote != '"'))
288 inquote = 0;
289 if (inquote) { /* quoted text must match exactly */
290 if (*s1++ != *s2++)
291 return(0);
292 while (*s1 != inquote) {
293 if (!*s1)
294 return(0);
295 if (*s1++ != *s2++)
296 return(0);
297 }
298 s1++;
299 if (*s2++ != inquote)
300 return(0);
301 } else { /* else classify word type */
302 char *s1s = s1;
303 char *s2s = s2;
304 int cls = CLS_STR;
305 s1 = sskip(s1);
306 s2 = sskip(s2);
307 if (iskip(s1s) == s1) {
308 if (iskip(s2s) == s2)
309 cls = CLS_INT;
310 else if (fskip(s2s) == s2)
311 cls = CLS_FLT;
312 } else if (fskip(s1s) == s1) {
313 if (fskip(s2s) != s2)
314 return(0);
315 cls = CLS_FLT;
316 }
317 switch (cls) {
318 case CLS_INT: /* strncmp() faster */
319 case CLS_STR:
320 if (s1 - s1s != s2 - s2s)
321 return(0);
322 if (strncmp(s1s, s2s, s1 - s1s))
323 return(0);
324 break;
325 case CLS_FLT:
326 if (!real_check(atof(s1s), atof(s2s)))
327 return(0);
328 break;
329 }
330 }
331 while (isspace(*s1)) s1++;
332 while (isspace(*s2)) s2++;
333 }
334 return(!*s2); /* match if we reached the end of s2, too */
335 #undef CLS_STR
336 #undef CLS_INT
337 #undef CLS_FLT
338 }
339
340 /* Check if string is var=value pair and set if not in ignore list */
341 static int
342 setheadvar(char *val, void *p)
343 {
344 char newval[128];
345 LUTAB *htp = (LUTAB *)p;
346 LUENT *tep;
347 char *key;
348 int kln, vln;
349 int n;
350
351 adv_linecnt(htp); /* side-effect is to count lines */
352 if (!isalpha(*val)) /* key must start line */
353 return(0);
354 /* check if we need to swap binary data */
355 if ((n = isbigendian(val)) >= 0) {
356 if (nativebigendian() == n)
357 return(0);
358 f1swap += (htp == &hdr1);
359 f2swap += (htp == &hdr2);
360 return(0);
361 }
362 key = val++;
363 while (*val && !isspace(*val) & (*val != '='))
364 val++;
365 kln = val - key;
366 while (isspace(*val)) /* check for value */
367 *val++ = '\0';
368 if (*val != '=')
369 return(0);
370 *val++ = '\0';
371 while (isspace(*val))
372 val++;
373 if (!*val) /* nothing set? */
374 return(0);
375 /* check if key to ignore */
376 for (n = 0; hdr_ignkey[n]; n++)
377 if (!strcmp(key, hdr_ignkey[n]))
378 return(0);
379 vln = strlen(val); /* eliminate space and newline at end */
380 while (isspace(val[--vln]))
381 ;
382 val[++vln] = '\0';
383 if (!(tep = lu_find(htp, key)))
384 return(-1); /* memory allocation error */
385 if (!tep->key)
386 tep->key = strcpy(malloc(kln+1), key);
387 if (tep->data) { /* check for special cases */
388 if (!strcmp(key, "EXPOSURE")) {
389 sprintf(newval, "%.6e", atof(tep->data)*atof(val));
390 vln = strlen(val = newval);
391 }
392 free(tep->data);
393 }
394 tep->data = strcpy(malloc(vln+1), val);
395 return(1);
396 }
397
398 /* Lookup correspondent in other header */
399 static int
400 match_val(const LUENT *ep1, void *p2)
401 {
402 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
403 if (!ep2 || !ep2->data) {
404 if (report != REP_QUIET)
405 printf("%s: variable '%s' missing in '%s'\n",
406 progname, ep1->key, f2name);
407 return(-1);
408 }
409 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
410 if (report != REP_QUIET) {
411 printf("%s: header variable '%s' has different values\n",
412 progname, ep1->key);
413 if (report >= REP_VERBOSE) {
414 printf("%s: %s=%s\n", f1name,
415 ep1->key, (char *)ep1->data);
416 printf("%s: %s=%s\n", f2name,
417 ep2->key, (char *)ep2->data);
418 }
419 }
420 return(-1);
421 }
422 return(1); /* good match */
423 }
424
425 /* Compare two sets of header variables */
426 static int
427 headers_match()
428 {
429 int ne = lu_doall(&hdr1, match_val, &hdr2);
430 if (ne < 0)
431 return(0); /* something didn't match! */
432 /* non-fatal if second header has extra */
433 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
434 printf("%s: warning - '%s' has %d extra header setting(s)\n",
435 progname, f2name, ne);
436 return(1); /* good match */
437 }
438
439 /* Check generic input to determine if it is binary, -1 on error */
440 static int
441 input_is_binary(FILE *fin)
442 {
443 int n = 0;
444 int c = 0;
445
446 while ((c = getc(fin)) != EOF) {
447 ++n;
448 if (!c | (c > 127))
449 break; /* non-ascii character */
450 if (n >= 10240)
451 break; /* enough to be confident */
452 }
453 if (!n)
454 return(-1); /* first read failed */
455 if (fseek(fin, 0L, 0) < 0)
456 return(-1); /* rewind failed */
457 return(!c | (c > 127));
458 }
459
460 /* Identify and return data type from header (if one) */
461 static int
462 identify_type(const char *name, FILE *fin, LUTAB *htp)
463 {
464 extern const char HDRSTR[];
465 int c;
466 /* check magic header start */
467 if ((c = getc(fin)) != HDRSTR[0]) {
468 if (c == EOF) goto badeof;
469 ungetc(c, fin);
470 c = 0;
471 } else if ((c = getc(fin)) != HDRSTR[1]) {
472 if (c == EOF) goto badeof;
473 ungetc(c, fin); ungetc(HDRSTR[0], fin);
474 c = 0;
475 }
476 if (c) { /* appears to have a header */
477 char sbuf[32];
478 if (!fgets(sbuf, sizeof(sbuf), fin))
479 goto badeof;
480 adv_linecnt(htp); /* for #?ID string */
481 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
482 fputs(name, stdout);
483 fputs(": warning - unexpected header ID: ", stdout);
484 fputs(sbuf, stdout);
485 }
486 if (getheader(fin, setheadvar, htp) < 0) {
487 fputs(name, stderr);
488 fputs(": unknown error reading header\n", stderr);
489 return(-1);
490 }
491 adv_linecnt(htp); /* for trailing emtpy line */
492 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
493 }
494 c = input_is_binary(fin); /* else peek to see if binary */
495 if (c < 0) {
496 fputs(name, stderr);
497 fputs(": read/seek error\n", stderr);
498 return(-1);
499 }
500 if (c)
501 return(TYP_BINARY);
502 return(TYP_TEXT);
503 badeof:
504 if (report != REP_QUIET) {
505 fputs(name, stdout);
506 fputs(": unexpected end-of-file\n", stdout);
507 }
508 return(-1);
509 }
510
511 /* Check that overall RMS error is below threshold */
512 static int
513 good_RMS()
514 {
515 if (!nsum)
516 return(1);
517 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
518 if (report != REP_QUIET)
519 printf(
520 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
521 progname,
522 (rel_min > 0) ? "relative " : "",
523 f1name, f2name,
524 sqrt(diff2sum/(double)nsum), rms_lim);
525 return(0);
526 }
527 if (report >= REP_VERBOSE)
528 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
529 progname, (rel_min > 0) ? "relative " : "",
530 f1name, f2name, sqrt(diff2sum/(double)nsum));
531 return(1);
532 }
533
534 /* Compare two inputs as generic binary files */
535 static int
536 compare_binary()
537 {
538 int c1=0, c2=0;
539
540 if (report >= REP_VERBOSE) {
541 fputs(progname, stdout);
542 fputs(": comparing inputs as binary\n", stdout);
543 }
544 for ( ; ; ) { /* exact byte matching */
545 c1 = getc(f1in);
546 c2 = getc(f2in);
547 if (c1 == EOF) {
548 if (c2 == EOF)
549 return(1); /* success! */
550 if (report != REP_QUIET) {
551 fputs(f1name, stdout);
552 fputs(": unexpected end-of-file\n", stdout);
553 }
554 return(0);
555 }
556 if (c2 == EOF) {
557 if (report != REP_QUIET) {
558 fputs(f2name, stdout);
559 fputs(": unexpected end-of-file\n", stdout);
560 }
561 return(0);
562 }
563 if (c1 != c2)
564 break; /* quit and report difference */
565 }
566 if (report == REP_QUIET)
567 return(0);
568 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
569 progname, f1name, f2name, ftell(f1in), ftell(f2in));
570 if (report >= REP_VERBOSE)
571 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
572 progname, f1name, c1, f2name, c2);
573 return(0);
574 }
575
576 /* Compare two inputs as generic text files */
577 static int
578 compare_text()
579 {
580 LINEBUF l1buf, l2buf;
581
582 if (report >= REP_VERBOSE) {
583 fputs(progname, stdout);
584 fputs(": comparing inputs as ASCII text", stdout);
585 if (escape_newlines)
586 fputs(", allowing escaped newlines", stdout);
587 if (comment_c) {
588 fputs(", ignoring comments starting with '", stdout);
589 fputc(comment_c, stdout);
590 fputc('\'', stdout);
591 }
592 fputc('\n', stdout);
593 }
594 SET_FILE_TEXT(f1in); /* originally set to binary */
595 SET_FILE_TEXT(f2in);
596 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
597 while (read_line(&l1buf, f1in)) {
598 lin1cnt++;
599 if (!*sskip2(l1buf.str,0))
600 continue; /* ignore empty lines */
601
602 while (read_line(&l2buf, f2in)) {
603 lin2cnt++;
604 if (*sskip2(l2buf.str,0))
605 break; /* found other non-empty line */
606 }
607 if (!l2buf.len) { /* input 2 EOF? */
608 if (report != REP_QUIET) {
609 fputs(f2name, stdout);
610 fputs(": unexpected end-of-file\n", stdout);
611 }
612 free_line(&l1buf); free_line(&l2buf);
613 return(0);
614 }
615 /* compare non-empty lines */
616 if (!equiv_string(l1buf.str, l2buf.str)) {
617 if (report != REP_QUIET) {
618 printf("%s: inputs '%s' and '%s' differ at line %d|%d\n",
619 progname, f1name, f2name,
620 lin1cnt, lin2cnt);
621 if ( report >= REP_VERBOSE &&
622 (l1buf.len < 256) &
623 (l2buf.len < 256) ) {
624 fputs("------------- Mismatch -------------\n", stdout);
625 printf("%s@%d:\t%s", f1name,
626 lin1cnt, l1buf.str);
627 printf("%s@%d:\t%s", f2name,
628 lin2cnt, l2buf.str);
629 }
630 }
631 free_line(&l1buf); free_line(&l2buf);
632 return(0);
633 }
634 }
635 free_line(&l1buf); /* check for EOF on input 2 */
636 while (read_line(&l2buf, f2in)) {
637 if (!*sskip2(l2buf.str,0))
638 continue;
639 if (report != REP_QUIET) {
640 fputs(f1name, stdout);
641 fputs(": unexpected end-of-file\n", stdout);
642 }
643 free_line(&l2buf);
644 return(0);
645 }
646 free_line(&l2buf);
647 return(good_RMS()); /* final check for reals */
648 }
649
650 /* Check image/map resolutions */
651 static int
652 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
653 {
654 if (r1p->rt != r2p->rt) {
655 if (report != REP_QUIET)
656 printf(
657 "%s: %ss '%s' and '%s' have different pixel ordering\n",
658 progname, class, f1name, f2name);
659 return(0);
660 }
661 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
662 if (report != REP_QUIET)
663 printf(
664 "%s: %ss '%s' and '%s' are different sizes\n",
665 progname, class, f1name, f2name);
666 return(0);
667 }
668 return(1);
669 }
670
671 /* Compare two inputs that are known to be RGBE or XYZE images */
672 static int
673 compare_hdr()
674 {
675 RESOLU rs1, rs2;
676 COLOR *scan1, *scan2;
677 int x, y;
678
679 if (report >= REP_VERBOSE) {
680 fputs(progname, stdout);
681 fputs(": comparing inputs as HDR images\n", stdout);
682 }
683 fgetsresolu(&rs1, f1in);
684 fgetsresolu(&rs2, f2in);
685 if (!check_resolu("HDR image", &rs1, &rs2))
686 return(0);
687 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
688 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
689 if (!scan1 | !scan2) {
690 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
691 exit(2);
692 }
693 for (y = 0; y < numscans(&rs1); y++) {
694 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
695 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
696 if (report != REP_QUIET)
697 printf("%s: unexpected end-of-file\n",
698 progname);
699 free(scan1);
700 free(scan2);
701 return(0);
702 }
703 for (x = 0; x < scanlen(&rs1); x++) {
704 if (color_check(scan1[x], scan2[x]))
705 continue;
706 if (report != REP_QUIET) {
707 printf(
708 "%s: pixels at scanline %d offset %d differ\n",
709 progname, y, x);
710 if (report >= REP_VERBOSE) {
711 printf("%s: (R,G,B)=(%g,%g,%g)\n",
712 f1name, colval(scan1[x],RED),
713 colval(scan1[x],GRN),
714 colval(scan1[x],BLU));
715 printf("%s: (R,G,B)=(%g,%g,%g)\n",
716 f2name, colval(scan2[x],RED),
717 colval(scan2[x],GRN),
718 colval(scan2[x],BLU));
719 }
720 }
721 free(scan1);
722 free(scan2);
723 return(0);
724 }
725 }
726 free(scan1);
727 free(scan2);
728 return(good_RMS()); /* final check of RMS */
729 }
730
731 /* Set reference depth based on header variable */
732 static int
733 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
734 {
735 static char depthvar[] = DEPTHSTR;
736 const char *drval;
737
738 depthvar[LDEPTHSTR-1] = '\0';
739 drval = (const char *)lu_find(htp, depthvar)->data;
740 if (!drval)
741 return(0);
742 dcp->refdepth = atof(drval);
743 if (dcp->refdepth <= 0) {
744 if (report != REP_QUIET) {
745 fputs(dcp->inpname, stderr);
746 fputs(": bad reference depth '", stderr);
747 fputs(drval, stderr);
748 fputs("'\n", stderr);
749 }
750 return(-1);
751 }
752 return(1);
753 }
754
755 /* Compare two encoded depth maps */
756 static int
757 compare_depth()
758 {
759 long nread = 0;
760 DEPTHCODEC dc1, dc2;
761
762 if (report >= REP_VERBOSE) {
763 fputs(progname, stdout);
764 fputs(": comparing inputs as depth maps\n", stdout);
765 }
766 set_dc_defaults(&dc1);
767 dc1.hdrflags = HF_RESIN;
768 dc1.finp = f1in;
769 dc1.inpname = f1name;
770 set_dc_defaults(&dc2);
771 dc2.hdrflags = HF_RESIN;
772 dc2.finp = f2in;
773 dc2.inpname = f2name;
774 if (report != REP_QUIET) {
775 dc1.hdrflags |= HF_STDERR;
776 dc2.hdrflags |= HF_STDERR;
777 }
778 if (!process_dc_header(&dc1, 0, NULL))
779 return(0);
780 if (!process_dc_header(&dc2, 0, NULL))
781 return(0);
782 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
783 return(0);
784 if (set_refdepth(&dc1, &hdr1) < 0)
785 return(0);
786 if (set_refdepth(&dc2, &hdr2) < 0)
787 return(0);
788 while (nread < dc1.res.xr*dc1.res.yr) {
789 double d1 = decode_depth_next(&dc1);
790 double d2 = decode_depth_next(&dc2);
791 if ((d1 < 0) | (d2 < 0)) {
792 if (report != REP_QUIET)
793 printf("%s: unexpected end-of-file\n",
794 progname);
795 return(0);
796 }
797 ++nread;
798 if (real_check(d1, d2))
799 continue;
800 if (report != REP_QUIET)
801 printf("%s: %ld%s depth values differ\n",
802 progname, nread, num_sfx(nread));
803 return(0);
804 }
805 return(good_RMS()); /* final check of RMS */
806 }
807
808 /* Compare two encoded normal maps */
809 static int
810 compare_norm()
811 {
812 long nread = 0;
813 NORMCODEC nc1, nc2;
814
815 if (report >= REP_VERBOSE) {
816 fputs(progname, stdout);
817 fputs(": comparing inputs as normal maps\n", stdout);
818 }
819 set_nc_defaults(&nc1);
820 nc1.hdrflags = HF_RESIN;
821 nc1.finp = f1in;
822 nc1.inpname = f1name;
823 set_nc_defaults(&nc2);
824 nc2.hdrflags = HF_RESIN;
825 nc2.finp = f2in;
826 nc2.inpname = f2name;
827 if (report != REP_QUIET) {
828 nc1.hdrflags |= HF_STDERR;
829 nc2.hdrflags |= HF_STDERR;
830 }
831 if (!process_nc_header(&nc1, 0, NULL))
832 return(0);
833 if (!process_nc_header(&nc2, 0, NULL))
834 return(0);
835 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
836 return(0);
837 while (nread < nc1.res.xr*nc1.res.yr) {
838 FVECT nv1, nv2;
839 int rv1 = decode_normal_next(nv1, &nc1);
840 int rv2 = decode_normal_next(nv2, &nc2);
841 if ((rv1 < 0) | (rv2 < 0)) {
842 if (report != REP_QUIET)
843 printf("%s: unexpected end-of-file\n",
844 progname);
845 return(0);
846 }
847 ++nread;
848 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
849 continue;
850 if (report != REP_QUIET)
851 printf("%s: %ld%s normal vectors differ\n",
852 progname, nread, num_sfx(nread));
853 return(0);
854 }
855 return(good_RMS()); /* final check of RMS */
856 }
857
858 /* Compare two inputs that are known to be 32-bit floating-point data */
859 static int
860 compare_float()
861 {
862 long nread = 0;
863 float f1, f2;
864
865 if (report >= REP_VERBOSE) {
866 fputs(progname, stdout);
867 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
868 }
869 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
870 if (!getbinary(&f2, sizeof(f2), 1, f2in))
871 goto badeof;
872 ++nread;
873 if (f1swap) swap32((char *)&f1, 1);
874 if (f2swap) swap32((char *)&f2, 1);
875 if (real_check(f1, f2))
876 continue;
877 if (report != REP_QUIET)
878 printf("%s: %ld%s float values differ\n",
879 progname, nread, num_sfx(nread));
880 return(0);
881 }
882 if (!getbinary(&f2, sizeof(f2), 1, f2in))
883 return(good_RMS()); /* final check of RMS */
884 badeof:
885 if (report != REP_QUIET)
886 printf("%s: unexpected end-of-file\n", progname);
887 return(0);
888 }
889
890 /* Compare two inputs that are known to be 64-bit floating-point data */
891 static int
892 compare_double()
893 {
894 long nread = 0;
895 double f1, f2;
896
897 if (report >= REP_VERBOSE) {
898 fputs(progname, stdout);
899 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
900 }
901 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
902 if (!getbinary(&f2, sizeof(f2), 1, f2in))
903 goto badeof;
904 ++nread;
905 if (f1swap) swap64((char *)&f1, 1);
906 if (f2swap) swap64((char *)&f2, 1);
907 if (real_check(f1, f2))
908 continue;
909 if (report != REP_QUIET)
910 printf("%s: %ld%s double values differ\n",
911 progname, nread, num_sfx(nread));
912 return(0);
913 }
914 if (!getbinary(&f2, sizeof(f2), 1, f2in))
915 return(good_RMS()); /* final check of RMS */
916 badeof:
917 if (report != REP_QUIET)
918 printf("%s: unexpected end-of-file\n", progname);
919 return(0);
920 }
921
922 /* Compare two Radiance files for equivalence */
923 int
924 main(int argc, char *argv[])
925 {
926 int typ1, typ2;
927 int a;
928
929 progname = argv[0];
930 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
931 switch (argv[a][1]) {
932 case 'h': /* ignore header info. */
933 ign_header = !ign_header;
934 continue;
935 case 'n': /* allow newline escapes */
936 escape_newlines = !escape_newlines;
937 continue;
938 case 'c': /* ignore comments */
939 comment_c = argv[a][2];
940 continue;
941 case 's': /* silent operation */
942 report = REP_QUIET;
943 continue;
944 case 'w': /* turn off warnings */
945 if (report > REP_ERROR)
946 report = REP_ERROR;
947 continue;
948 case 'v': /* turn on verbose mode */
949 report = REP_VERBOSE;
950 continue;
951 case 'm': /* maximum epsilon */
952 max_lim = atof(argv[++a]);
953 continue;
954 case 'r':
955 if (argv[a][2] == 'e') /* relative difference */
956 rel_min = atof(argv[++a]);
957 else if (argv[a][2] == 'm') /* RMS limit */
958 rms_lim = atof(argv[++a]);
959 else
960 usage();
961 continue;
962 case '\0': /* first file from stdin */
963 f1in = stdin;
964 f1name = stdin_name;
965 break;
966 default:
967 usage();
968 }
969 break;
970 }
971 if (a != argc-2) /* make sure of two inputs */
972 usage();
973 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
974 if (report >= REP_WARN)
975 printf("%s: warning - identical inputs given\n",
976 progname);
977 return(0);
978 }
979 if (!f1name) f1name = argv[a];
980 if (!f2name) f2name = argv[a+1];
981 /* open inputs */
982 SET_FILE_BINARY(stdin); /* in case we're using it */
983 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
984 fprintf(stderr, "%s: cannot open for reading\n", f1name);
985 return(2);
986 }
987 if (!strcmp(f2name, "-")) {
988 f2in = stdin;
989 f2name = stdin_name;
990 } else if (!(f2in = fopen(f2name, "rb"))) {
991 fprintf(stderr, "%s: cannot open for reading\n", f2name);
992 return(2);
993 }
994 /* load headers */
995 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
996 return(2);
997 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
998 return(2);
999 if (typ1 != typ2) {
1000 if (report != REP_QUIET)
1001 printf("%s: '%s' format is %s and '%s' is %s\n",
1002 progname, f1name, file_type[typ1],
1003 f2name, file_type[typ2]);
1004 return(1);
1005 }
1006 ign_header |= !has_header(typ1); /* check headers if indicated */
1007 if (!ign_header && !headers_match())
1008 return(1);
1009 if (!ign_header & (report >= REP_WARN)) {
1010 if (lin1cnt != lin2cnt)
1011 printf("%s: warning - headers are different lengths\n",
1012 progname);
1013 if (typ1 == TYP_UNKNOWN)
1014 printf("%s: warning - unrecognized format\n",
1015 progname);
1016 }
1017 if (report >= REP_VERBOSE) {
1018 printf("%s: data format is %s\n", progname, file_type[typ1]);
1019 if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
1020 if (f1swap)
1021 printf("%s: input '%s' is byte-swapped\n",
1022 progname, f1name);
1023 if (f2swap)
1024 printf("%s: input '%s' is byte-swapped\n",
1025 progname, f2name);
1026 }
1027 }
1028 switch (typ1) { /* compare based on type */
1029 case TYP_BINARY:
1030 case TYP_TMESH:
1031 case TYP_OCTREE:
1032 case TYP_RBFMESH:
1033 case TYP_ID8:
1034 case TYP_ID16:
1035 case TYP_ID24:
1036 case TYP_UNKNOWN:
1037 return( !compare_binary() );
1038 case TYP_TEXT:
1039 case TYP_ASCII:
1040 return( !compare_text() );
1041 case TYP_RGBE:
1042 case TYP_XYZE:
1043 return( !compare_hdr() );
1044 case TYP_DEPTH:
1045 return( !compare_depth() );
1046 case TYP_NORM:
1047 return( !compare_norm() );
1048 case TYP_FLOAT:
1049 return( !compare_float() );
1050 case TYP_DOUBLE:
1051 return( !compare_double() );
1052 }
1053 return(1);
1054 }
