root/Development/ray/src/util/radcompare.c
Revision: 2.26
Committed: Mon Jul 27 16:49:56 2020 UTC (5 years, 3 months ago) by greg
Changes since 2.25: +22 -3 lines
feat(radcompare): added -c option to ignore comments
2 static const char RCSid[] = "$Id: radcompare.c,v 2.25 2020/07/09 17:29:04 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 double rel_min = 1e-5; /* positive for relative comparisons */
31
32 double rms_lim = 0.01; /* RMS difference limit */
33
34 double max_lim = 0.25; /* difference limit if non-negative */
35
36 int lin1cnt=0, lin2cnt=0; /* file line position */
37
38 int comment_c = '\0'; /* comment delimiter for text files */
39
40 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
41 "th","st","nd","rd","th","th","th","th","th","th"
42 };
43 #define num_sfx(n) nsuffix[(n)%10]
44
45 /* file types */
46 const char *file_type[] = {
47 "Unrecognized",
48 "TEXT_generic",
49 "ascii",
50 COLRFMT,
51 CIEFMT,
52 DEPTH16FMT,
53 NORMAL32FMT,
54 "float",
55 "double",
56 "BSDF_RBFmesh",
57 "Radiance_octree",
58 "Radiance_tmesh",
59 "8-bit_indexed_name",
60 "16-bit_indexed_name",
61 "24-bit_indexed_name",
62 "BINARY_unknown",
63 NULL /* terminator */
64 };
65 /* keep consistent with above */
66 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE,
67 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
68 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
69 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
70
71 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
72
73 /* header variables to always ignore */
74 const char *hdr_ignkey[] = {
75 "SOFTWARE",
76 "CAPDATE",
77 "GMT",
78 "FRAME",
79 NULL /* terminator */
80 };
81 /* header variable settings */
82 LUTAB hdr1 = LU_SINIT(free,free);
83 LUTAB hdr2 = LU_SINIT(free,free);
84
85 /* advance appropriate file line count */
86 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
87 lin2cnt += (htp == &hdr2))
88
89 typedef struct { /* dynamic line buffer */
90 char *str;
91 int len;
92 int siz;
93 } LINEBUF;
94
95 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
96 /* 100 MByte limit on line buffer */
97 #define MAXBUF (100L<<20)
98
99 /* input files */
100 char *progname = NULL;
101 const char stdin_name[] = "<stdin>";
102 const char *f1name=NULL, *f2name=NULL;
103 FILE *f1in=NULL, *f2in=NULL;
104 int f1swap=0, f2swap=0;
105
106 /* running real differences */
107 double diff2sum = 0;
108 long nsum = 0;
109
110 /* Report usage and exit */
111 static void
112 usage()
113 {
114 fputs("Usage: ", stderr);
115 fputs(progname, stderr);
116 fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
117 stderr);
118 exit(2);
119 }
120
121 /* Read a text line, increasing buffer size as necessary */
122 static int
123 read_line(LINEBUF *bp, FILE *fp)
124 {
125 static int doneWarn = 0;
126
127 bp->len = 0;
128 if (!bp->str) {
129 bp->str = (char *)malloc(bp->siz = 512);
130 if (!bp->str)
131 goto memerr;
132 }
133 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
134 bp->len += strlen(bp->str + bp->len);
135 if (bp->str[bp->len-1] == '\n')
136 break; /* found EOL */
137 if (bp->len < bp->siz - 4)
138 continue; /* at EOF? */
139 if (bp->siz >= MAXBUF) {
140 if ((report >= REP_WARN) & !doneWarn) {
141 fprintf(stderr,
142 "%s: warning - input line(s) past %ld MByte limit\n",
143 progname, MAXBUF>>20);
144 doneWarn++;
145 }
146 break; /* return MAXBUF partial line */
147 }
148 if ((bp->siz += bp->siz/2) > MAXBUF)
149 bp->siz = MAXBUF;
150 bp->str = (char *)realloc(bp->str, bp->siz);
151 if (!bp->str)
152 goto memerr;
153 }
154 if (comment_c) { /* elide comment? */
155 char *cp = sskip2(bp->str,0);
156 if (*cp == comment_c) {
157 *cp++ = '\n';
158 *cp = '\0';
159 bp->len = cp - bp->str;
160 }
161 }
162 return(bp->len);
163 memerr:
164 fprintf(stderr,
165 "%s: out of memory in read_line() allocating %d byte buffer\n",
166 progname, bp->siz);
167 exit(2);
168 }
169
170 /* Free line buffer */
171 static void
172 free_line(LINEBUF *bp)
173 {
174 if (bp->str) free(bp->str);
175 init_line(bp);
176 }
177
178 /* Get type ID from name (or 0 if not found) */
179 static int
180 xlate_type(const char *nm)
181 {
182 int i;
183
184 if (!nm || !*nm)
185 return(TYP_UNKNOWN);
186 for (i = 1; file_type[i]; i++)
187 if (!strcmp(nm, file_type[i]))
188 return(i);
189 return(TYP_UNKNOWN);
190 }
191
192 /* Compare real values and keep track of differences */
193 static int
194 real_check(double r1, double r2)
195 {
196 double diff2 = (r1 - r2)*(r1 - r2);
197
198 if (rel_min > 0) { /* doing relative differences? */
199 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
200 if (av2 > rel_min*rel_min)
201 diff2 /= av2;
202 }
203 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
204 if (report != REP_QUIET)
205 printf(
206 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
207 progname,
208 (rel_min > 0) ? "relative " : "",
209 r1, r2, max_lim);
210 return(0);
211 }
212 diff2sum += diff2;
213 nsum++;
214 return(1);
215 }
216
217 /* Compare two color values for equivalence */
218 static int
219 color_check(COLOR c1, COLOR c2)
220 {
221 int p;
222
223 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
224 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
225 return(0);
226
227 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
228 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
229
230 return(real_check(colval(c1,p), colval(c2,p)));
231 }
232
233 /* Compare two normal directions for equivalence */
234 static int
235 norm_check(FVECT nv1, FVECT nv2)
236 {
237 double max2 = nv1[2]*nv2[2];
238 int imax = 2;
239 int i = 2;
240 /* identify largest component */
241 while (i--) {
242 double tm2 = nv1[i]*nv2[i];
243 if (tm2 > max2) {
244 imax = i;
245 max2 = tm2;
246 }
247 }
248 i = 3; /* compare smaller components */
249 while (i--) {
250 if (i == imax)
251 continue;
252 if (!real_check(nv1[i], nv2[i]))
253 return(0);
254 }
255 return(1);
256 }
257
258 /* Compare two strings for equivalence */
259 static int
260 equiv_string(char *s1, char *s2)
261 {
262 #define CLS_STR 0
263 #define CLS_INT 1
264 #define CLS_FLT 2
265 /* skip whitespace at beginning */
266 while (isspace(*s1)) s1++;
267 while (isspace(*s2)) s2++;
268 while (*s1) { /* check each word */
269 int inquote;
270 if (!*s2) /* unexpected EOL in s2? */
271 return(0);
272 inquote = *s1;
273 if ((inquote != '\'') & (inquote != '"'))
274 inquote = 0;
275 if (inquote) { /* quoted text must match exactly */
276 if (*s1++ != *s2++)
277 return(0);
278 while (*s1 != inquote) {
279 if (!*s1)
280 return(0);
281 if (*s1++ != *s2++)
282 return(0);
283 }
284 s1++;
285 if (*s2++ != inquote)
286 return(0);
287 } else { /* else classify word type */
288 char *s1s = s1;
289 char *s2s = s2;
290 int cls = CLS_STR;
291 s1 = sskip(s1);
292 s2 = sskip(s2);
293 if (iskip(s1s) == s1) {
294 if (iskip(s2s) == s2)
295 cls = CLS_INT;
296 else if (fskip(s2s) == s2)
297 cls = CLS_FLT;
298 } else if (fskip(s1s) == s1) {
299 if (fskip(s2s) != s2)
300 return(0);
301 cls = CLS_FLT;
302 }
303 switch (cls) {
304 case CLS_INT: /* strncmp() faster */
305 case CLS_STR:
306 if (s1 - s1s != s2 - s2s)
307 return(0);
308 if (strncmp(s1s, s2s, s1 - s1s))
309 return(0);
310 break;
311 case CLS_FLT:
312 if (!real_check(atof(s1s), atof(s2s)))
313 return(0);
314 break;
315 }
316 }
317 while (isspace(*s1)) s1++;
318 while (isspace(*s2)) s2++;
319 }
320 return(!*s2); /* match if we reached the end of s2, too */
321 #undef CLS_STR
322 #undef CLS_INT
323 #undef CLS_FLT
324 }
325
326 /* Check if string is var=value pair and set if not in ignore list */
327 static int
328 setheadvar(char *val, void *p)
329 {
330 char newval[128];
331 LUTAB *htp = (LUTAB *)p;
332 LUENT *tep;
333 char *key;
334 int kln, vln;
335 int n;
336
337 adv_linecnt(htp); /* side-effect is to count lines */
338 if (!isalpha(*val)) /* key must start line */
339 return(0);
340 /* check if we need to swap binary data */
341 if ((n = isbigendian(val)) >= 0) {
342 if (nativebigendian() == n)
343 return(0);
344 f1swap += (htp == &hdr1);
345 f2swap += (htp == &hdr2);
346 return(0);
347 }
348 key = val++;
349 while (*val && !isspace(*val) & (*val != '='))
350 val++;
351 kln = val - key;
352 while (isspace(*val)) /* check for value */
353 *val++ = '\0';
354 if (*val != '=')
355 return(0);
356 *val++ = '\0';
357 while (isspace(*val))
358 val++;
359 if (!*val) /* nothing set? */
360 return(0);
361 /* check if key to ignore */
362 for (n = 0; hdr_ignkey[n]; n++)
363 if (!strcmp(key, hdr_ignkey[n]))
364 return(0);
365 vln = strlen(val); /* eliminate space and newline at end */
366 while (isspace(val[--vln]))
367 ;
368 val[++vln] = '\0';
369 if (!(tep = lu_find(htp, key)))
370 return(-1); /* memory allocation error */
371 if (!tep->key)
372 tep->key = strcpy(malloc(kln+1), key);
373 if (tep->data) { /* check for special cases */
374 if (!strcmp(key, "EXPOSURE")) {
375 sprintf(newval, "%f", atof(tep->data)*atof(val));
376 vln = strlen(val = newval);
377 }
378 free(tep->data);
379 }
380 tep->data = strcpy(malloc(vln+1), val);
381 return(1);
382 }
383
384 /* Lookup correspondent in other header */
385 static int
386 match_val(const LUENT *ep1, void *p2)
387 {
388 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
389 if (!ep2 || !ep2->data) {
390 if (report != REP_QUIET)
391 printf("%s: variable '%s' missing in '%s'\n",
392 progname, ep1->key, f2name);
393 return(-1);
394 }
395 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
396 if (report != REP_QUIET) {
397 printf("%s: header variable '%s' has different values\n",
398 progname, ep1->key);
399 if (report >= REP_VERBOSE) {
400 printf("%s: %s=%s\n", f1name,
401 ep1->key, (char *)ep1->data);
402 printf("%s: %s=%s\n", f2name,
403 ep2->key, (char *)ep2->data);
404 }
405 }
406 return(-1);
407 }
408 return(1); /* good match */
409 }
410
411 /* Compare two sets of header variables */
412 static int
413 headers_match()
414 {
415 int ne = lu_doall(&hdr1, match_val, &hdr2);
416 if (ne < 0)
417 return(0); /* something didn't match! */
418 /* non-fatal if second header has extra */
419 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
420 printf("%s: warning - '%s' has %d extra header setting(s)\n",
421 progname, f2name, ne);
422 return(1); /* good match */
423 }
424
425 /* Check generic input to determine if it is binary, -1 on error */
426 static int
427 input_is_binary(FILE *fin)
428 {
429 int n = 0;
430 int c = 0;
431
432 while ((c = getc(fin)) != EOF) {
433 ++n;
434 if (!c | (c > 127))
435 break; /* non-ascii character */
436 if (n >= 10240)
437 break; /* enough to be confident */
438 }
439 if (!n)
440 return(-1); /* first read failed */
441 if (fseek(fin, 0L, 0) < 0)
442 return(-1); /* rewind failed */
443 return(!c | (c > 127));
444 }
445
446 /* Identify and return data type from header (if one) */
447 static int
448 identify_type(const char *name, FILE *fin, LUTAB *htp)
449 {
450 extern const char HDRSTR[];
451 int c;
452 /* check magic header start */
453 if ((c = getc(fin)) != HDRSTR[0]) {
454 if (c == EOF) goto badeof;
455 ungetc(c, fin);
456 c = 0;
457 } else if ((c = getc(fin)) != HDRSTR[1]) {
458 if (c == EOF) goto badeof;
459 ungetc(c, fin); ungetc(HDRSTR[0], fin);
460 c = 0;
461 }
462 if (c) { /* appears to have a header */
463 char sbuf[32];
464 if (!fgets(sbuf, sizeof(sbuf), fin))
465 goto badeof;
466 adv_linecnt(htp); /* for #?ID string */
467 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
468 fputs(name, stdout);
469 fputs(": warning - unexpected header ID: ", stdout);
470 fputs(sbuf, stdout);
471 }
472 if (getheader(fin, setheadvar, htp) < 0) {
473 fputs(name, stderr);
474 fputs(": unknown error reading header\n", stderr);
475 return(-1);
476 }
477 adv_linecnt(htp); /* for trailing emtpy line */
478 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
479 }
480 c = input_is_binary(fin); /* else peek to see if binary */
481 if (c < 0) {
482 fputs(name, stderr);
483 fputs(": read/seek error\n", stderr);
484 return(-1);
485 }
486 if (c)
487 return(TYP_BINARY);
488 return(TYP_TEXT);
489 badeof:
490 if (report != REP_QUIET) {
491 fputs(name, stdout);
492 fputs(": unexpected end-of-file\n", stdout);
493 }
494 return(-1);
495 }
496
497 /* Check that overall RMS error is below threshold */
498 static int
499 good_RMS()
500 {
501 if (!nsum)
502 return(1);
503 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
504 if (report != REP_QUIET)
505 printf(
506 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
507 progname,
508 (rel_min > 0) ? "relative " : "",
509 f1name, f2name,
510 sqrt(diff2sum/(double)nsum), rms_lim);
511 return(0);
512 }
513 if (report >= REP_VERBOSE)
514 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
515 progname, (rel_min > 0) ? "relative " : "",
516 f1name, f2name, sqrt(diff2sum/(double)nsum));
517 return(1);
518 }
519
520 /* Compare two inputs as generic binary files */
521 static int
522 compare_binary()
523 {
524 int c1=0, c2=0;
525
526 if (report >= REP_VERBOSE) {
527 fputs(progname, stdout);
528 fputs(": comparing inputs as binary\n", stdout);
529 }
530 for ( ; ; ) { /* exact byte matching */
531 c1 = getc(f1in);
532 c2 = getc(f2in);
533 if (c1 == EOF) {
534 if (c2 == EOF)
535 return(1); /* success! */
536 if (report != REP_QUIET) {
537 fputs(f1name, stdout);
538 fputs(": unexpected end-of-file\n", stdout);
539 }
540 return(0);
541 }
542 if (c2 == EOF) {
543 if (report != REP_QUIET) {
544 fputs(f2name, stdout);
545 fputs(": unexpected end-of-file\n", stdout);
546 }
547 return(0);
548 }
549 if (c1 != c2)
550 break; /* quit and report difference */
551 }
552 if (report == REP_QUIET)
553 return(0);
554 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
555 progname, f1name, f2name, ftell(f1in), ftell(f2in));
556 if (report >= REP_VERBOSE)
557 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
558 progname, f1name, c1, f2name, c2);
559 return(0);
560 }
561
562 /* Compare two inputs as generic text files */
563 static int
564 compare_text()
565 {
566 LINEBUF l1buf, l2buf;
567
568 if (report >= REP_VERBOSE) {
569 fputs(progname, stdout);
570 fputs(": comparing inputs as ASCII text", stdout);
571 if (comment_c) {
572 fputs(", ignoring comments starting with '", stdout);
573 fputc(comment_c, stdout);
574 fputc('\'', stdout);
575 }
576 fputc('\n', stdout);
577 }
578 SET_FILE_TEXT(f1in); /* originally set to binary */
579 SET_FILE_TEXT(f2in);
580 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
581 while (read_line(&l1buf, f1in)) {
582 lin1cnt++;
583 if (!*sskip2(l1buf.str,0))
584 continue; /* ignore empty lines */
585
586 while (read_line(&l2buf, f2in)) {
587 lin2cnt++;
588 if (*sskip2(l2buf.str,0))
589 break; /* found other non-empty line */
590 }
591 if (!l2buf.len) { /* input 2 EOF? */
592 if (report != REP_QUIET) {
593 fputs(f2name, stdout);
594 fputs(": unexpected end-of-file\n", stdout);
595 }
596 free_line(&l1buf); free_line(&l2buf);
597 return(0);
598 }
599 /* compare non-empty lines */
600 if (!equiv_string(l1buf.str, l2buf.str)) {
601 if (report != REP_QUIET) {
602 printf("%s: inputs '%s' and '%s' differ at line %d|%d\n",
603 progname, f1name, f2name,
604 lin1cnt, lin2cnt);
605 if ( report >= REP_VERBOSE &&
606 (l1buf.len < 256) &
607 (l2buf.len < 256) ) {
608 fputs("------------- Mismatch -------------\n", stdout);
609 printf("%s@%d:\t%s", f1name,
610 lin1cnt, l1buf.str);
611 printf("%s@%d:\t%s", f2name,
612 lin2cnt, l2buf.str);
613 }
614 }
615 free_line(&l1buf); free_line(&l2buf);
616 return(0);
617 }
618 }
619 free_line(&l1buf); /* check for EOF on input 2 */
620 while (read_line(&l2buf, f2in)) {
621 if (!*sskip2(l2buf.str,0))
622 continue;
623 if (report != REP_QUIET) {
624 fputs(f1name, stdout);
625 fputs(": unexpected end-of-file\n", stdout);
626 }
627 free_line(&l2buf);
628 return(0);
629 }
630 free_line(&l2buf);
631 return(good_RMS()); /* final check for reals */
632 }
633
634 /* Check image/map resolutions */
635 static int
636 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
637 {
638 if (r1p->rt != r2p->rt) {
639 if (report != REP_QUIET)
640 printf(
641 "%s: %ss '%s' and '%s' have different pixel ordering\n",
642 progname, class, f1name, f2name);
643 return(0);
644 }
645 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
646 if (report != REP_QUIET)
647 printf(
648 "%s: %ss '%s' and '%s' are different sizes\n",
649 progname, class, f1name, f2name);
650 return(0);
651 }
652 return(1);
653 }
654
655 /* Compare two inputs that are known to be RGBE or XYZE images */
656 static int
657 compare_hdr()
658 {
659 RESOLU rs1, rs2;
660 COLOR *scan1, *scan2;
661 int x, y;
662
663 if (report >= REP_VERBOSE) {
664 fputs(progname, stdout);
665 fputs(": comparing inputs as HDR images\n", stdout);
666 }
667 fgetsresolu(&rs1, f1in);
668 fgetsresolu(&rs2, f2in);
669 if (!check_resolu("HDR image", &rs1, &rs2))
670 return(0);
671 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
672 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
673 if (!scan1 | !scan2) {
674 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
675 exit(2);
676 }
677 for (y = 0; y < numscans(&rs1); y++) {
678 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
679 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
680 if (report != REP_QUIET)
681 printf("%s: unexpected end-of-file\n",
682 progname);
683 free(scan1);
684 free(scan2);
685 return(0);
686 }
687 for (x = 0; x < scanlen(&rs1); x++) {
688 if (color_check(scan1[x], scan2[x]))
689 continue;
690 if (report != REP_QUIET) {
691 printf(
692 "%s: pixels at scanline %d offset %d differ\n",
693 progname, y, x);
694 if (report >= REP_VERBOSE) {
695 printf("%s: (R,G,B)=(%g,%g,%g)\n",
696 f1name, colval(scan1[x],RED),
697 colval(scan1[x],GRN),
698 colval(scan1[x],BLU));
699 printf("%s: (R,G,B)=(%g,%g,%g)\n",
700 f2name, colval(scan2[x],RED),
701 colval(scan2[x],GRN),
702 colval(scan2[x],BLU));
703 }
704 }
705 free(scan1);
706 free(scan2);
707 return(0);
708 }
709 }
710 free(scan1);
711 free(scan2);
712 return(good_RMS()); /* final check of RMS */
713 }
714
715 /* Set reference depth based on header variable */
716 static int
717 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
718 {
719 static char depthvar[] = DEPTHSTR;
720 const char *drval;
721
722 depthvar[LDEPTHSTR-1] = '\0';
723 drval = (const char *)lu_find(htp, depthvar)->data;
724 if (!drval)
725 return(0);
726 dcp->refdepth = atof(drval);
727 if (dcp->refdepth <= 0) {
728 if (report != REP_QUIET) {
729 fputs(dcp->inpname, stderr);
730 fputs(": bad reference depth '", stderr);
731 fputs(drval, stderr);
732 fputs("'\n", stderr);
733 }
734 return(-1);
735 }
736 return(1);
737 }
738
739 /* Compare two encoded depth maps */
740 static int
741 compare_depth()
742 {
743 long nread = 0;
744 DEPTHCODEC dc1, dc2;
745
746 if (report >= REP_VERBOSE) {
747 fputs(progname, stdout);
748 fputs(": comparing inputs as depth maps\n", stdout);
749 }
750 set_dc_defaults(&dc1);
751 dc1.hdrflags = HF_RESIN;
752 dc1.finp = f1in;
753 dc1.inpname = f1name;
754 set_dc_defaults(&dc2);
755 dc2.hdrflags = HF_RESIN;
756 dc2.finp = f2in;
757 dc2.inpname = f2name;
758 if (report != REP_QUIET) {
759 dc1.hdrflags |= HF_STDERR;
760 dc2.hdrflags |= HF_STDERR;
761 }
762 if (!process_dc_header(&dc1, 0, NULL))
763 return(0);
764 if (!process_dc_header(&dc2, 0, NULL))
765 return(0);
766 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
767 return(0);
768 if (set_refdepth(&dc1, &hdr1) < 0)
769 return(0);
770 if (set_refdepth(&dc2, &hdr2) < 0)
771 return(0);
772 while (nread < dc1.res.xr*dc1.res.yr) {
773 double d1 = decode_depth_next(&dc1);
774 double d2 = decode_depth_next(&dc2);
775 if ((d1 < 0) | (d2 < 0)) {
776 if (report != REP_QUIET)
777 printf("%s: unexpected end-of-file\n",
778 progname);
779 return(0);
780 }
781 ++nread;
782 if (real_check(d1, d2))
783 continue;
784 if (report != REP_QUIET)
785 printf("%s: %ld%s depth values differ\n",
786 progname, nread, num_sfx(nread));
787 return(0);
788 }
789 return(good_RMS()); /* final check of RMS */
790 }
791
792 /* Compare two encoded normal maps */
793 static int
794 compare_norm()
795 {
796 long nread = 0;
797 NORMCODEC nc1, nc2;
798
799 if (report >= REP_VERBOSE) {
800 fputs(progname, stdout);
801 fputs(": comparing inputs as normal maps\n", stdout);
802 }
803 set_nc_defaults(&nc1);
804 nc1.hdrflags = HF_RESIN;
805 nc1.finp = f1in;
806 nc1.inpname = f1name;
807 set_nc_defaults(&nc2);
808 nc2.hdrflags = HF_RESIN;
809 nc2.finp = f2in;
810 nc2.inpname = f2name;
811 if (report != REP_QUIET) {
812 nc1.hdrflags |= HF_STDERR;
813 nc2.hdrflags |= HF_STDERR;
814 }
815 if (!process_nc_header(&nc1, 0, NULL))
816 return(0);
817 if (!process_nc_header(&nc2, 0, NULL))
818 return(0);
819 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
820 return(0);
821 while (nread < nc1.res.xr*nc1.res.yr) {
822 FVECT nv1, nv2;
823 int rv1 = decode_normal_next(nv1, &nc1);
824 int rv2 = decode_normal_next(nv2, &nc2);
825 if ((rv1 < 0) | (rv2 < 0)) {
826 if (report != REP_QUIET)
827 printf("%s: unexpected end-of-file\n",
828 progname);
829 return(0);
830 }
831 ++nread;
832 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
833 continue;
834 if (report != REP_QUIET)
835 printf("%s: %ld%s normal vectors differ\n",
836 progname, nread, num_sfx(nread));
837 return(0);
838 }
839 return(good_RMS()); /* final check of RMS */
840 }
841
842 /* Compare two inputs that are known to be 32-bit floating-point data */
843 static int
844 compare_float()
845 {
846 long nread = 0;
847 float f1, f2;
848
849 if (report >= REP_VERBOSE) {
850 fputs(progname, stdout);
851 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
852 }
853 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
854 if (!getbinary(&f2, sizeof(f2), 1, f2in))
855 goto badeof;
856 ++nread;
857 if (f1swap) swap32((char *)&f1, 1);
858 if (f2swap) swap32((char *)&f2, 1);
859 if (real_check(f1, f2))
860 continue;
861 if (report != REP_QUIET)
862 printf("%s: %ld%s float values differ\n",
863 progname, nread, num_sfx(nread));
864 return(0);
865 }
866 if (!getbinary(&f2, sizeof(f2), 1, f2in))
867 return(good_RMS()); /* final check of RMS */
868 badeof:
869 if (report != REP_QUIET)
870 printf("%s: unexpected end-of-file\n", progname);
871 return(0);
872 }
873
874 /* Compare two inputs that are known to be 64-bit floating-point data */
875 static int
876 compare_double()
877 {
878 long nread = 0;
879 double f1, f2;
880
881 if (report >= REP_VERBOSE) {
882 fputs(progname, stdout);
883 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
884 }
885 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
886 if (!getbinary(&f2, sizeof(f2), 1, f2in))
887 goto badeof;
888 ++nread;
889 if (f1swap) swap64((char *)&f1, 1);
890 if (f2swap) swap64((char *)&f2, 1);
891 if (real_check(f1, f2))
892 continue;
893 if (report != REP_QUIET)
894 printf("%s: %ld%s double values differ\n",
895 progname, nread, num_sfx(nread));
896 return(0);
897 }
898 if (!getbinary(&f2, sizeof(f2), 1, f2in))
899 return(good_RMS()); /* final check of RMS */
900 badeof:
901 if (report != REP_QUIET)
902 printf("%s: unexpected end-of-file\n", progname);
903 return(0);
904 }
905
906 /* Compare two Radiance files for equivalence */
907 int
908 main(int argc, char *argv[])
909 {
910 int typ1, typ2;
911 int a;
912
913 progname = argv[0];
914 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
915 switch (argv[a][1]) {
916 case 'h': /* ignore header info. */
917 ign_header = !ign_header;
918 continue;
919 case 'c': /* ignore comments */
920 comment_c = argv[a][2];
921 continue;
922 case 's': /* silent operation */
923 report = REP_QUIET;
924 continue;
925 case 'w': /* turn off warnings */
926 if (report > REP_ERROR)
927 report = REP_ERROR;
928 continue;
929 case 'v': /* turn on verbose mode */
930 report = REP_VERBOSE;
931 continue;
932 case 'm': /* maximum epsilon */
933 max_lim = atof(argv[++a]);
934 continue;
935 case 'r':
936 if (argv[a][2] == 'e') /* relative difference */
937 rel_min = atof(argv[++a]);
938 else if (argv[a][2] == 'm') /* RMS limit */
939 rms_lim = atof(argv[++a]);
940 else
941 usage();
942 continue;
943 case '\0': /* first file from stdin */
944 f1in = stdin;
945 f1name = stdin_name;
946 break;
947 default:
948 usage();
949 }
950 break;
951 }
952 if (a != argc-2) /* make sure of two inputs */
953 usage();
954 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
955 if (report >= REP_WARN)
956 printf("%s: warning - identical inputs given\n",
957 progname);
958 return(0);
959 }
960 if (!f1name) f1name = argv[a];
961 if (!f2name) f2name = argv[a+1];
962 /* open inputs */
963 SET_FILE_BINARY(stdin); /* in case we're using it */
964 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
965 fprintf(stderr, "%s: cannot open for reading\n", f1name);
966 return(2);
967 }
968 if (!strcmp(f2name, "-")) {
969 f2in = stdin;
970 f2name = stdin_name;
971 } else if (!(f2in = fopen(f2name, "rb"))) {
972 fprintf(stderr, "%s: cannot open for reading\n", f2name);
973 return(2);
974 }
975 /* load headers */
976 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
977 return(2);
978 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
979 return(2);
980 if (typ1 != typ2) {
981 if (report != REP_QUIET)
982 printf("%s: '%s' format is %s and '%s' is %s\n",
983 progname, f1name, file_type[typ1],
984 f2name, file_type[typ2]);
985 return(1);
986 }
987 ign_header |= !has_header(typ1); /* check headers if indicated */
988 if (!ign_header && !headers_match())
989 return(1);
990 if (!ign_header & (report >= REP_WARN)) {
991 if (lin1cnt != lin2cnt)
992 printf("%s: warning - headers are different lengths\n",
993 progname);
994 if (typ1 == TYP_UNKNOWN)
995 printf("%s: warning - unrecognized format\n",
996 progname);
997 }
998 if (report >= REP_VERBOSE) {
999 printf("%s: data format is %s\n", progname, file_type[typ1]);
1000 if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
1001 if (f1swap)
1002 printf("%s: input '%s' is byte-swapped\n",
1003 progname, f1name);
1004 if (f2swap)
1005 printf("%s: input '%s' is byte-swapped\n",
1006 progname, f2name);
1007 }
1008 }
1009 switch (typ1) { /* compare based on type */
1010 case TYP_BINARY:
1011 case TYP_TMESH:
1012 case TYP_OCTREE:
1013 case TYP_RBFMESH:
1014 case TYP_ID8:
1015 case TYP_ID16:
1016 case TYP_ID24:
1017 case TYP_UNKNOWN:
1018 return( !compare_binary() );
1019 case TYP_TEXT:
1020 case TYP_ASCII:
1021 return( !compare_text() );
1022 case TYP_RGBE:
1023 case TYP_XYZE:
1024 return( !compare_hdr() );
1025 case TYP_DEPTH:
1026 return( !compare_depth() );
1027 case TYP_NORM:
1028 return( !compare_norm() );
1029 case TYP_FLOAT:
1030 return( !compare_float() );
1031 case TYP_DOUBLE:
1032 return( !compare_double() );
1033 }
1034 return(1);
1035 }
