--- ray/src/util/radcompare.c 2018/10/15 22:38:31 2.6 +++ ray/src/util/radcompare.c 2018/10/16 00:20:52 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: radcompare.c,v 2.6 2018/10/15 22:38:31 greg Exp $"; +static const char RCSid[] = "$Id: radcompare.c,v 2.7 2018/10/16 00:20:52 greg Exp $"; #endif /* * Compare Radiance files for significant differences @@ -568,7 +568,7 @@ compare_float() if (report >= REP_VERBOSE) { fputs(progname, stdout); - fputs(": comparing inputs as 32-bit IEEE float\n", stdout); + fputs(": comparing inputs as 32-bit IEEE floats\n", stdout); } while (getbinary(&f1, sizeof(f1), 1, f1in)) { if (!getbinary(&f2, sizeof(f2), 1, f2in)) @@ -598,7 +598,7 @@ compare_double() if (report >= REP_VERBOSE) { fputs(progname, stdout); - fputs(": comparing inputs as 64-bit IEEE double\n", stdout); + fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout); } while (getbinary(&f1, sizeof(f1), 1, f1in)) { if (!getbinary(&f2, sizeof(f2), 1, f2in)) @@ -662,17 +662,16 @@ main(int argc, char *argv[]) } break; } - if (a != argc-2) + if (a != argc-2) /* make sure of two inputs */ usage(); - if (!f1name) f1name = argv[a]; - if (!f2name) f2name = argv[a+1]; - - if (!strcmp(f1name, f2name)) { /* inputs are same? */ + if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */ if (report >= REP_WARN) printf("%s: warning - identical inputs given\n", progname); return(0); } + if (!f1name) f1name = argv[a]; + if (!f2name) f2name = argv[a+1]; /* open inputs */ SET_FILE_BINARY(stdin); /* in case we're using it */ if (!f1in && !(f1in = fopen(f1name, "rb"))) {
