root/radiance/ray/src/util/radcompare.c
Revision: 2.30
Committed: Tue May 24 22:34:18 2022 UTC (3 years, 2 months ago) by greg
Changes since 2.29: +2 -1 lines
perf(radcompare): Added "FORMAT" to ignored header variables, since it's dealt with separately
2 static const char RCSid[] = "$Id: radcompare.c,v 2.29 2022/03/03 00:01:48 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 int escape_newlines = 0; /* allow backslash to skip newlines */
31
32 double rel_min = 1e-5; /* positive for relative comparisons */
33
34 double rms_lim = 0.01; /* RMS difference limit */
35
36 double max_lim = 0.25; /* difference limit if non-negative */
37
38 int lin1cnt=0, lin2cnt=0; /* file line position */
39
40 int comment_c = '\0'; /* comment delimiter for text files */
41
42 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
43 "th","st","nd","rd","th","th","th","th","th","th"
44 };
45 #define num_sfx(n) nsuffix[(n)%10]
46
47 /* file types */
48 const char *file_type[] = {
49 "Unrecognized",
50 "TEXT_generic",
51 "ascii",
52 COLRFMT,
53 CIEFMT,
54 DEPTH16FMT,
55 NORMAL32FMT,
56 "float",
57 "double",
58 "BSDF_RBFmesh",
59 "Radiance_octree",
60 "Radiance_tmesh",
61 "8-bit_indexed_name",
62 "16-bit_indexed_name",
63 "24-bit_indexed_name",
64 "BINARY_unknown",
65 NULL /* terminator */
66 };
67 /* keep consistent with above */
68 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE,
69 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
70 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
71 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
72
73 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
74
75 /* header variables to always ignore */
76 const char *hdr_ignkey[] = {
77 "FORMAT",
78 "SOFTWARE",
79 "CAPDATE",
80 "GMT",
81 "FRAME",
82 NULL /* terminator */
83 };
84 /* header variable settings */
85 LUTAB hdr1 = LU_SINIT(free,free);
86 LUTAB hdr2 = LU_SINIT(free,free);
87
88 /* advance appropriate file line count */
89 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
90 lin2cnt += (htp == &hdr2))
91
92 typedef struct { /* dynamic line buffer */
93 char *str;
94 int len;
95 int siz;
96 } LINEBUF;
97
98 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
99 /* 100 MByte limit on line buffer */
100 #define MAXBUF (100L<<20)
101
102 /* input files */
103 char *progname = NULL;
104 const char stdin_name[] = "<stdin>";
105 const char *f1name=NULL, *f2name=NULL;
106 FILE *f1in=NULL, *f2in=NULL;
107 int f1swap=0, f2swap=0;
108
109 /* running real differences */
110 double diff2sum = 0;
111 long nsum = 0;
112
113 /* Report usage and exit */
114 static void
115 usage()
116 {
117 fputs("Usage: ", stderr);
118 fputs(progname, stderr);
119 fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
120 stderr);
121 exit(2);
122 }
123
124 /* Read a text line, increasing buffer size as necessary */
125 static int
126 read_line(LINEBUF *bp, FILE *fp)
127 {
128 static int doneWarn = 0;
129
130 bp->len = 0;
131 if (!bp->str) {
132 bp->str = (char *)malloc(bp->siz = 512);
133 if (!bp->str)
134 goto memerr;
135 }
136 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
137 bp->len += strlen(bp->str + bp->len);
138 if (bp->str[bp->len-1] == '\n') {
139 if (bp->len > 1 && bp->str[bp->len-2] == '\r') {
140 bp->str[--bp->len] = '\0';
141 bp->str[bp->len-1] = '\n';
142 }
143 if (escape_newlines && bp->len > 1 &&
144 bp->str[bp->len-2] == '\\') {
145 bp->str[--bp->len] = '\0';
146 bp->str[bp->len-1] = ' ';
147 continue;
148 }
149 break; /* found EOL */
150 }
151 if (bp->len < bp->siz - 4)
152 continue; /* at EOF? */
153 if (bp->siz >= MAXBUF) {
154 if ((report >= REP_WARN) & !doneWarn) {
155 fprintf(stderr,
156 "%s: warning - input line(s) past %ld MByte limit\n",
157 progname, MAXBUF>>20);
158 doneWarn++;
159 }
160 break; /* return MAXBUF partial line */
161 }
162 if ((bp->siz += bp->siz/2) > MAXBUF)
163 bp->siz = MAXBUF;
164 bp->str = (char *)realloc(bp->str, bp->siz);
165 if (!bp->str)
166 goto memerr;
167 }
168 if (comment_c) { /* elide comment? */
169 char *cp = sskip2(bp->str,0);
170 if (*cp == comment_c) {
171 *cp++ = '\n';
172 *cp = '\0';
173 bp->len = cp - bp->str;
174 }
175 }
176 return(bp->len);
177 memerr:
178 fprintf(stderr,
179 "%s: out of memory in read_line() allocating %d byte buffer\n",
180 progname, bp->siz);
181 exit(2);
182 }
183
184 /* Free line buffer */
185 static void
186 free_line(LINEBUF *bp)
187 {
188 if (bp->str) free(bp->str);
189 init_line(bp);
190 }
191
192 /* Get type ID from name (or 0 if not found) */
193 static int
194 xlate_type(const char *nm)
195 {
196 int i;
197
198 if (!nm || !*nm)
199 return(TYP_UNKNOWN);
200 for (i = 1; file_type[i]; i++)
201 if (!strcmp(nm, file_type[i]))
202 return(i);
203 return(TYP_UNKNOWN);
204 }
205
206 /* Compare real values and keep track of differences */
207 static int
208 real_check(double r1, double r2)
209 {
210 double diff2 = (r1 - r2)*(r1 - r2);
211
212 if (rel_min > 0) { /* doing relative differences? */
213 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
214 if (av2 < rel_min*rel_min)
215 av2 = rel_min*rel_min;
216 diff2 /= av2;
217 }
218 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
219 if (report != REP_QUIET)
220 printf(
221 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
222 progname,
223 (rel_min > 0) ? "relative " : "",
224 r1, r2, max_lim);
225 return(0);
226 }
227 diff2sum += diff2;
228 nsum++;
229 return(1);
230 }
231
232 /* Compare two color values for equivalence */
233 static int
234 color_check(COLOR c1, COLOR c2)
235 {
236 int p;
237
238 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
239 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
240 return(0);
241
242 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
243 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
244
245 return(real_check(colval(c1,p), colval(c2,p)));
246 }
247
248 /* Compare two normal directions for equivalence */
249 static int
250 norm_check(FVECT nv1, FVECT nv2)
251 {
252 double max2 = nv1[2]*nv2[2];
253 int imax = 2;
254 int i = 2;
255 /* identify largest component */
256 while (i--) {
257 double tm2 = nv1[i]*nv2[i];
258 if (tm2 > max2) {
259 imax = i;
260 max2 = tm2;
261 }
262 }
263 i = 3; /* compare smaller components */
264 while (i--) {
265 if (i == imax)
266 continue;
267 if (!real_check(nv1[i], nv2[i]))
268 return(0);
269 }
270 return(1);
271 }
272
273 /* Compare two strings for equivalence */
274 static int
275 equiv_string(char *s1, char *s2)
276 {
277 #define CLS_STR 0
278 #define CLS_INT 1
279 #define CLS_FLT 2
280 /* skip whitespace at beginning */
281 while (isspace(*s1)) s1++;
282 while (isspace(*s2)) s2++;
283 while (*s1) { /* check each word */
284 int inquote;
285 if (!*s2) /* unexpected EOL in s2? */
286 return(0);
287 inquote = *s1;
288 if ((inquote != '\'') & (inquote != '"'))
289 inquote = 0;
290 if (inquote) { /* quoted text must match exactly */
291 if (*s1++ != *s2++)
292 return(0);
293 while (*s1 != inquote) {
294 if (!*s1)
295 return(0);
296 if (*s1++ != *s2++)
297 return(0);
298 }
299 s1++;
300 if (*s2++ != inquote)
301 return(0);
302 } else { /* else classify word type */
303 char *s1s = s1;
304 char *s2s = s2;
305 int cls = CLS_STR;
306 s1 = sskip(s1);
307 s2 = sskip(s2);
308 if (iskip(s1s) == s1) {
309 if (iskip(s2s) == s2)
310 cls = CLS_INT;
311 else if (fskip(s2s) == s2)
312 cls = CLS_FLT;
313 } else if (fskip(s1s) == s1) {
314 if (fskip(s2s) != s2)
315 return(0);
316 cls = CLS_FLT;
317 }
318 switch (cls) {
319 case CLS_INT: /* strncmp() faster */
320 case CLS_STR:
321 if (s1 - s1s != s2 - s2s)
322 return(0);
323 if (strncmp(s1s, s2s, s1 - s1s))
324 return(0);
325 break;
326 case CLS_FLT:
327 if (!real_check(atof(s1s), atof(s2s)))
328 return(0);
329 break;
330 }
331 }
332 while (isspace(*s1)) s1++;
333 while (isspace(*s2)) s2++;
334 }
335 return(!*s2); /* match if we reached the end of s2, too */
336 #undef CLS_STR
337 #undef CLS_INT
338 #undef CLS_FLT
339 }
340
341 /* Check if string is var=value pair and set if not in ignore list */
342 static int
343 setheadvar(char *val, void *p)
344 {
345 char newval[128];
346 LUTAB *htp = (LUTAB *)p;
347 LUENT *tep;
348 char *key;
349 int kln, vln;
350 int n;
351
352 adv_linecnt(htp); /* side-effect is to count lines */
353 if (!isalpha(*val)) /* key must start line */
354 return(0);
355 /* check if we need to swap binary data */
356 if ((n = isbigendian(val)) >= 0) {
357 if (nativebigendian() == n)
358 return(0);
359 f1swap += (htp == &hdr1);
360 f2swap += (htp == &hdr2);
361 return(0);
362 }
363 key = val++;
364 while (*val && !isspace(*val) & (*val != '='))
365 val++;
366 kln = val - key;
367 while (isspace(*val)) /* check for value */
368 *val++ = '\0';
369 if (*val != '=')
370 return(0);
371 *val++ = '\0';
372 while (isspace(*val))
373 val++;
374 if (!*val) /* nothing set? */
375 return(0);
376 /* check if key to ignore */
377 for (n = 0; hdr_ignkey[n]; n++)
378 if (!strcmp(key, hdr_ignkey[n]))
379 return(0);
380 vln = strlen(val); /* eliminate space and newline at end */
381 while (isspace(val[--vln]))
382 ;
383 val[++vln] = '\0';
384 if (!(tep = lu_find(htp, key)))
385 return(-1); /* memory allocation error */
386 if (!tep->key)
387 tep->key = strcpy(malloc(kln+1), key);
388 if (tep->data) { /* check for special cases */
389 if (!strcmp(key, "EXPOSURE")) {
390 sprintf(newval, "%.6e", atof(tep->data)*atof(val));
391 vln = strlen(val = newval);
392 }
393 free(tep->data);
394 }
395 tep->data = strcpy(malloc(vln+1), val);
396 return(1);
397 }
398
399 /* Lookup correspondent in other header */
400 static int
401 match_val(const LUENT *ep1, void *p2)
402 {
403 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
404 if (!ep2 || !ep2->data) {
405 if (report != REP_QUIET)
406 printf("%s: variable '%s' missing in '%s'\n",
407 progname, ep1->key, f2name);
408 return(-1);
409 }
410 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
411 if (report != REP_QUIET) {
412 printf("%s: header variable '%s' has different values\n",
413 progname, ep1->key);
414 if (report >= REP_VERBOSE) {
415 printf("%s: %s=%s\n", f1name,
416 ep1->key, (char *)ep1->data);
417 printf("%s: %s=%s\n", f2name,
418 ep2->key, (char *)ep2->data);
419 }
420 }
421 return(-1);
422 }
423 return(1); /* good match */
424 }
425
426 /* Compare two sets of header variables */
427 static int
428 headers_match()
429 {
430 int ne = lu_doall(&hdr1, match_val, &hdr2);
431 if (ne < 0)
432 return(0); /* something didn't match! */
433 /* non-fatal if second header has extra */
434 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
435 printf("%s: warning - '%s' has %d extra header setting(s)\n",
436 progname, f2name, ne);
437 return(1); /* good match */
438 }
439
440 /* Check generic input to determine if it is binary, -1 on error */
441 static int
442 input_is_binary(FILE *fin)
443 {
444 int n = 0;
445 int c = 0;
446
447 while ((c = getc(fin)) != EOF) {
448 ++n;
449 if (!c | (c > 127))
450 break; /* non-ascii character */
451 if (n >= 10240)
452 break; /* enough to be confident */
453 }
454 if (!n)
455 return(-1); /* first read failed */
456 if (fseek(fin, 0L, 0) < 0)
457 return(-1); /* rewind failed */
458 return(!c | (c > 127));
459 }
460
461 /* Identify and return data type from header (if one) */
462 static int
463 identify_type(const char *name, FILE *fin, LUTAB *htp)
464 {
465 extern const char HDRSTR[];
466 int c;
467 /* check magic header start */
468 if ((c = getc(fin)) != HDRSTR[0]) {
469 if (c == EOF) goto badeof;
470 ungetc(c, fin);
471 c = 0;
472 } else if ((c = getc(fin)) != HDRSTR[1]) {
473 if (c == EOF) goto badeof;
474 ungetc(c, fin); ungetc(HDRSTR[0], fin);
475 c = 0;
476 }
477 if (c) { /* appears to have a header */
478 char sbuf[32];
479 if (!fgets(sbuf, sizeof(sbuf), fin))
480 goto badeof;
481 adv_linecnt(htp); /* for #?ID string */
482 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
483 fputs(name, stdout);
484 fputs(": warning - unexpected header ID: ", stdout);
485 fputs(sbuf, stdout);
486 }
487 if (getheader(fin, setheadvar, htp) < 0) {
488 fputs(name, stderr);
489 fputs(": unknown error reading header\n", stderr);
490 return(-1);
491 }
492 adv_linecnt(htp); /* for trailing emtpy line */
493 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
494 }
495 c = input_is_binary(fin); /* else peek to see if binary */
496 if (c < 0) {
497 fputs(name, stderr);
498 fputs(": read/seek error\n", stderr);
499 return(-1);
500 }
501 if (c)
502 return(TYP_BINARY);
503 return(TYP_TEXT);
504 badeof:
505 if (report != REP_QUIET) {
506 fputs(name, stdout);
507 fputs(": unexpected end-of-file\n", stdout);
508 }
509 return(-1);
510 }
511
512 /* Check that overall RMS error is below threshold */
513 static int
514 good_RMS()
515 {
516 if (!nsum)
517 return(1);
518 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
519 if (report != REP_QUIET)
520 printf(
521 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
522 progname,
523 (rel_min > 0) ? "relative " : "",
524 f1name, f2name,
525 sqrt(diff2sum/(double)nsum), rms_lim);
526 return(0);
527 }
528 if (report >= REP_VERBOSE)
529 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
530 progname, (rel_min > 0) ? "relative " : "",
531 f1name, f2name, sqrt(diff2sum/(double)nsum));
532 return(1);
533 }
534
535 /* Compare two inputs as generic binary files */
536 static int
537 compare_binary()
538 {
539 int c1=0, c2=0;
540
541 if (report >= REP_VERBOSE) {
542 fputs(progname, stdout);
543 fputs(": comparing inputs as binary\n", stdout);
544 }
545 for ( ; ; ) { /* exact byte matching */
546 c1 = getc(f1in);
547 c2 = getc(f2in);
548 if (c1 == EOF) {
549 if (c2 == EOF)
550 return(1); /* success! */
551 if (report != REP_QUIET) {
552 fputs(f1name, stdout);
553 fputs(": unexpected end-of-file\n", stdout);
554 }
555 return(0);
556 }
557 if (c2 == EOF) {
558 if (report != REP_QUIET) {
559 fputs(f2name, stdout);
560 fputs(": unexpected end-of-file\n", stdout);
561 }
562 return(0);
563 }
564 if (c1 != c2)
565 break; /* quit and report difference */
566 }
567 if (report == REP_QUIET)
568 return(0);
569 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
570 progname, f1name, f2name, ftell(f1in), ftell(f2in));
571 if (report >= REP_VERBOSE)
572 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
573 progname, f1name, c1, f2name, c2);
574 return(0);
575 }
576
577 /* Compare two inputs as generic text files */
578 static int
579 compare_text()
580 {
581 LINEBUF l1buf, l2buf;
582
583 if (report >= REP_VERBOSE) {
584 fputs(progname, stdout);
585 fputs(": comparing inputs as ASCII text", stdout);
586 if (escape_newlines)
587 fputs(", allowing escaped newlines", stdout);
588 if (comment_c) {
589 fputs(", ignoring comments starting with '", stdout);
590 fputc(comment_c, stdout);
591 fputc('\'', stdout);
592 }
593 fputc('\n', stdout);
594 }
595 SET_FILE_TEXT(f1in); /* originally set to binary */
596 SET_FILE_TEXT(f2in);
597 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
598 while (read_line(&l1buf, f1in)) {
599 lin1cnt++;
600 if (!*sskip2(l1buf.str,0))
601 continue; /* ignore empty lines */
602
603 while (read_line(&l2buf, f2in)) {
604 lin2cnt++;
605 if (*sskip2(l2buf.str,0))
606 break; /* found other non-empty line */
607 }
608 if (!l2buf.len) { /* input 2 EOF? */
609 if (report != REP_QUIET) {
610 fputs(f2name, stdout);
611 fputs(": unexpected end-of-file\n", stdout);
612 }
613 free_line(&l1buf); free_line(&l2buf);
614 return(0);
615 }
616 /* compare non-empty lines */
617 if (!equiv_string(l1buf.str, l2buf.str)) {
618 if (report != REP_QUIET) {
619 printf("%s: inputs '%s' and '%s' differ at line %d|%d\n",
620 progname, f1name, f2name,
621 lin1cnt, lin2cnt);
622 if ( report >= REP_VERBOSE &&
623 (l1buf.len < 256) &
624 (l2buf.len < 256) ) {
625 fputs("------------- Mismatch -------------\n", stdout);
626 printf("%s@%d:\t%s", f1name,
627 lin1cnt, l1buf.str);
628 printf("%s@%d:\t%s", f2name,
629 lin2cnt, l2buf.str);
630 }
631 }
632 free_line(&l1buf); free_line(&l2buf);
633 return(0);
634 }
635 }
636 free_line(&l1buf); /* check for EOF on input 2 */
637 while (read_line(&l2buf, f2in)) {
638 if (!*sskip2(l2buf.str,0))
639 continue;
640 if (report != REP_QUIET) {
641 fputs(f1name, stdout);
642 fputs(": unexpected end-of-file\n", stdout);
643 }
644 free_line(&l2buf);
645 return(0);
646 }
647 free_line(&l2buf);
648 return(good_RMS()); /* final check for reals */
649 }
650
651 /* Check image/map resolutions */
652 static int
653 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
654 {
655 if (r1p->rt != r2p->rt) {
656 if (report != REP_QUIET)
657 printf(
658 "%s: %ss '%s' and '%s' have different pixel ordering\n",
659 progname, class, f1name, f2name);
660 return(0);
661 }
662 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
663 if (report != REP_QUIET)
664 printf(
665 "%s: %ss '%s' and '%s' are different sizes\n",
666 progname, class, f1name, f2name);
667 return(0);
668 }
669 return(1);
670 }
671
672 /* Compare two inputs that are known to be RGBE or XYZE images */
673 static int
674 compare_hdr()
675 {
676 RESOLU rs1, rs2;
677 COLOR *scan1, *scan2;
678 int x, y;
679
680 if (report >= REP_VERBOSE) {
681 fputs(progname, stdout);
682 fputs(": comparing inputs as HDR images\n", stdout);
683 }
684 fgetsresolu(&rs1, f1in);
685 fgetsresolu(&rs2, f2in);
686 if (!check_resolu("HDR image", &rs1, &rs2))
687 return(0);
688 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
689 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
690 if (!scan1 | !scan2) {
691 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
692 exit(2);
693 }
694 for (y = 0; y < numscans(&rs1); y++) {
695 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
696 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
697 if (report != REP_QUIET)
698 printf("%s: unexpected end-of-file\n",
699 progname);
700 free(scan1);
701 free(scan2);
702 return(0);
703 }
704 for (x = 0; x < scanlen(&rs1); x++) {
705 if (color_check(scan1[x], scan2[x]))
706 continue;
707 if (report != REP_QUIET) {
708 printf(
709 "%s: pixels at scanline %d offset %d differ\n",
710 progname, y, x);
711 if (report >= REP_VERBOSE) {
712 printf("%s: (R,G,B)=(%g,%g,%g)\n",
713 f1name, colval(scan1[x],RED),
714 colval(scan1[x],GRN),
715 colval(scan1[x],BLU));
716 printf("%s: (R,G,B)=(%g,%g,%g)\n",
717 f2name, colval(scan2[x],RED),
718 colval(scan2[x],GRN),
719 colval(scan2[x],BLU));
720 }
721 }
722 free(scan1);
723 free(scan2);
724 return(0);
725 }
726 }
727 free(scan1);
728 free(scan2);
729 return(good_RMS()); /* final check of RMS */
730 }
731
732 /* Set reference depth based on header variable */
733 static int
734 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
735 {
736 static char depthvar[] = DEPTHSTR;
737 const char *drval;
738
739 depthvar[LDEPTHSTR-1] = '\0';
740 drval = (const char *)lu_find(htp, depthvar)->data;
741 if (!drval)
742 return(0);
743 dcp->refdepth = atof(drval);
744 if (dcp->refdepth <= 0) {
745 if (report != REP_QUIET) {
746 fputs(dcp->inpname, stderr);
747 fputs(": bad reference depth '", stderr);
748 fputs(drval, stderr);
749 fputs("'\n", stderr);
750 }
751 return(-1);
752 }
753 return(1);
754 }
755
756 /* Compare two encoded depth maps */
757 static int
758 compare_depth()
759 {
760 long nread = 0;
761 DEPTHCODEC dc1, dc2;
762
763 if (report >= REP_VERBOSE) {
764 fputs(progname, stdout);
765 fputs(": comparing inputs as depth maps\n", stdout);
766 }
767 set_dc_defaults(&dc1);
768 dc1.hdrflags = HF_RESIN;
769 dc1.finp = f1in;
770 dc1.inpname = f1name;
771 set_dc_defaults(&dc2);
772 dc2.hdrflags = HF_RESIN;
773 dc2.finp = f2in;
774 dc2.inpname = f2name;
775 if (report != REP_QUIET) {
776 dc1.hdrflags |= HF_STDERR;
777 dc2.hdrflags |= HF_STDERR;
778 }
779 if (!process_dc_header(&dc1, 0, NULL))
780 return(0);
781 if (!process_dc_header(&dc2, 0, NULL))
782 return(0);
783 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
784 return(0);
785 if (set_refdepth(&dc1, &hdr1) < 0)
786 return(0);
787 if (set_refdepth(&dc2, &hdr2) < 0)
788 return(0);
789 while (nread < dc1.res.xr*dc1.res.yr) {
790 double d1 = decode_depth_next(&dc1);
791 double d2 = decode_depth_next(&dc2);
792 if ((d1 < 0) | (d2 < 0)) {
793 if (report != REP_QUIET)
794 printf("%s: unexpected end-of-file\n",
795 progname);
796 return(0);
797 }
798 ++nread;
799 if (real_check(d1, d2))
800 continue;
801 if (report != REP_QUIET)
802 printf("%s: %ld%s depth values differ\n",
803 progname, nread, num_sfx(nread));
804 return(0);
805 }
806 return(good_RMS()); /* final check of RMS */
807 }
808
809 /* Compare two encoded normal maps */
810 static int
811 compare_norm()
812 {
813 long nread = 0;
814 NORMCODEC nc1, nc2;
815
816 if (report >= REP_VERBOSE) {
817 fputs(progname, stdout);
818 fputs(": comparing inputs as normal maps\n", stdout);
819 }
820 set_nc_defaults(&nc1);
821 nc1.hdrflags = HF_RESIN;
822 nc1.finp = f1in;
823 nc1.inpname = f1name;
824 set_nc_defaults(&nc2);
825 nc2.hdrflags = HF_RESIN;
826 nc2.finp = f2in;
827 nc2.inpname = f2name;
828 if (report != REP_QUIET) {
829 nc1.hdrflags |= HF_STDERR;
830 nc2.hdrflags |= HF_STDERR;
831 }
832 if (!process_nc_header(&nc1, 0, NULL))
833 return(0);
834 if (!process_nc_header(&nc2, 0, NULL))
835 return(0);
836 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
837 return(0);
838 while (nread < nc1.res.xr*nc1.res.yr) {
839 FVECT nv1, nv2;
840 int rv1 = decode_normal_next(nv1, &nc1);
841 int rv2 = decode_normal_next(nv2, &nc2);
842 if ((rv1 < 0) | (rv2 < 0)) {
843 if (report != REP_QUIET)
844 printf("%s: unexpected end-of-file\n",
845 progname);
846 return(0);
847 }
848 ++nread;
849 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
850 continue;
851 if (report != REP_QUIET)
852 printf("%s: %ld%s normal vectors differ\n",
853 progname, nread, num_sfx(nread));
854 return(0);
855 }
856 return(good_RMS()); /* final check of RMS */
857 }
858
859 /* Compare two inputs that are known to be 32-bit floating-point data */
860 static int
861 compare_float()
862 {
863 long nread = 0;
864 float f1, f2;
865
866 if (report >= REP_VERBOSE) {
867 fputs(progname, stdout);
868 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
869 }
870 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
871 if (!getbinary(&f2, sizeof(f2), 1, f2in))
872 goto badeof;
873 ++nread;
874 if (f1swap) swap32((char *)&f1, 1);
875 if (f2swap) swap32((char *)&f2, 1);
876 if (real_check(f1, f2))
877 continue;
878 if (report != REP_QUIET)
879 printf("%s: %ld%s float values differ\n",
880 progname, nread, num_sfx(nread));
881 return(0);
882 }
883 if (!getbinary(&f2, sizeof(f2), 1, f2in))
884 return(good_RMS()); /* final check of RMS */
885 badeof:
886 if (report != REP_QUIET)
887 printf("%s: unexpected end-of-file\n", progname);
888 return(0);
889 }
890
891 /* Compare two inputs that are known to be 64-bit floating-point data */
892 static int
893 compare_double()
894 {
895 long nread = 0;
896 double f1, f2;
897
898 if (report >= REP_VERBOSE) {
899 fputs(progname, stdout);
900 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
901 }
902 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
903 if (!getbinary(&f2, sizeof(f2), 1, f2in))
904 goto badeof;
905 ++nread;
906 if (f1swap) swap64((char *)&f1, 1);
907 if (f2swap) swap64((char *)&f2, 1);
908 if (real_check(f1, f2))
909 continue;
910 if (report != REP_QUIET)
911 printf("%s: %ld%s double values differ\n",
912 progname, nread, num_sfx(nread));
913 return(0);
914 }
915 if (!getbinary(&f2, sizeof(f2), 1, f2in))
916 return(good_RMS()); /* final check of RMS */
917 badeof:
918 if (report != REP_QUIET)
919 printf("%s: unexpected end-of-file\n", progname);
920 return(0);
921 }
922
923 /* Compare two Radiance files for equivalence */
924 int
925 main(int argc, char *argv[])
926 {
927 int typ1, typ2;
928 int a;
929
930 progname = argv[0];
931 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
932 switch (argv[a][1]) {
933 case 'h': /* ignore header info. */
934 ign_header = !ign_header;
935 continue;
936 case 'n': /* allow newline escapes */
937 escape_newlines = !escape_newlines;
938 continue;
939 case 'c': /* ignore comments */
940 comment_c = argv[a][2];
941 continue;
942 case 's': /* silent operation */
943 report = REP_QUIET;
944 continue;
945 case 'w': /* turn off warnings */
946 if (report > REP_ERROR)
947 report = REP_ERROR;
948 continue;
949 case 'v': /* turn on verbose mode */
950 report = REP_VERBOSE;
951 continue;
952 case 'm': /* maximum epsilon */
953 max_lim = atof(argv[++a]);
954 continue;
955 case 'r':
956 if (argv[a][2] == 'e') /* relative difference */
957 rel_min = atof(argv[++a]);
958 else if (argv[a][2] == 'm') /* RMS limit */
959 rms_lim = atof(argv[++a]);
960 else
961 usage();
962 continue;
963 case '\0': /* first file from stdin */
964 f1in = stdin;
965 f1name = stdin_name;
966 break;
967 default:
968 usage();
969 }
970 break;
971 }
972 if (a != argc-2) /* make sure of two inputs */
973 usage();
974 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
975 if (report >= REP_WARN)
976 printf("%s: warning - identical inputs given\n",
977 progname);
978 return(0);
979 }
980 if (!f1name) f1name = argv[a];
981 if (!f2name) f2name = argv[a+1];
982 /* open inputs */
983 SET_FILE_BINARY(stdin); /* in case we're using it */
984 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
985 fprintf(stderr, "%s: cannot open for reading\n", f1name);
986 return(2);
987 }
988 if (!strcmp(f2name, "-")) {
989 f2in = stdin;
990 f2name = stdin_name;
991 } else if (!(f2in = fopen(f2name, "rb"))) {
992 fprintf(stderr, "%s: cannot open for reading\n", f2name);
993 return(2);
994 }
995 /* load headers */
996 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
997 return(2);
998 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
999 return(2);
1000 if (typ1 != typ2) {
1001 if (report != REP_QUIET)
1002 printf("%s: '%s' format is %s and '%s' is %s\n",
1003 progname, f1name, file_type[typ1],
1004 f2name, file_type[typ2]);
1005 return(1);
1006 }
1007 ign_header |= !has_header(typ1); /* check headers if indicated */
1008 if (!ign_header && !headers_match())
1009 return(1);
1010 if (!ign_header & (report >= REP_WARN)) {
1011 if (lin1cnt != lin2cnt)
1012 printf("%s: warning - headers are different lengths\n",
1013 progname);
1014 if (typ1 == TYP_UNKNOWN)
1015 printf("%s: warning - unrecognized format\n",
1016 progname);
1017 }
1018 if (report >= REP_VERBOSE) {
1019 printf("%s: data format is %s\n", progname, file_type[typ1]);
1020 if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
1021 if (f1swap)
1022 printf("%s: input '%s' is byte-swapped\n",
1023 progname, f1name);
1024 if (f2swap)
1025 printf("%s: input '%s' is byte-swapped\n",
1026 progname, f2name);
1027 }
1028 }
1029 switch (typ1) { /* compare based on type */
1030 case TYP_BINARY:
1031 case TYP_TMESH:
1032 case TYP_OCTREE:
1033 case TYP_RBFMESH:
1034 case TYP_ID8:
1035 case TYP_ID16:
1036 case TYP_ID24:
1037 case TYP_UNKNOWN:
1038 return( !compare_binary() );
1039 case TYP_TEXT:
1040 case TYP_ASCII:
1041 return( !compare_text() );
1042 case TYP_RGBE:
1043 case TYP_XYZE:
1044 return( !compare_hdr() );
1045 case TYP_DEPTH:
1046 return( !compare_depth() );
1047 case TYP_NORM:
1048 return( !compare_norm() );
1049 case TYP_FLOAT:
1050 return( !compare_float() );
1051 case TYP_DOUBLE:
1052 return( !compare_double() );
1053 }
1054 return(1);
1055 }
