root/radiance/ray/src/util/radcompare.c
Revision: 2.24
Committed: Tue Jun 30 22:53:05 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.23: +8 -2 lines
fix(radcompare): added special case for EXPOSURE header value
2 static const char RCSid[] = "$Id: radcompare.c,v 2.23 2020/06/30 01:17:54 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 double rel_min = 1e-5; /* positive for relative comparisons */
31
32 double rms_lim = 0.01; /* RMS difference limit */
33
34 double max_lim = 0.25; /* difference limit if non-negative */
35
36 int lin1cnt=0, lin2cnt=0; /* file line position */
37
38 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
39 "th","st","nd","rd","th","th","th","th","th","th"
40 };
41 #define num_sfx(n) nsuffix[(n)%10]
42
43 /* file types */
44 const char *file_type[] = {
45 "Unrecognized",
46 "TEXT_generic",
47 "ascii",
48 COLRFMT,
49 CIEFMT,
50 DEPTH16FMT,
51 NORMAL32FMT,
52 "float",
53 "double",
54 "BSDF_RBFmesh",
55 "Radiance_octree",
56 "Radiance_tmesh",
57 "8-bit_indexed_name",
58 "16-bit_indexed_name",
59 "24-bit_indexed_name",
60 "BINARY_unknown",
61 NULL /* terminator */
62 };
63 /* keep consistent with above */
64 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE,
65 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
66 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
67 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
68
69 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
70
71 /* header variables to always ignore */
72 const char *hdr_ignkey[] = {
73 "SOFTWARE",
74 "CAPDATE",
75 "GMT",
76 "FRAME",
77 NULL /* terminator */
78 };
79 /* header variable settings */
80 LUTAB hdr1 = LU_SINIT(free,free);
81 LUTAB hdr2 = LU_SINIT(free,free);
82
83 /* advance appropriate file line count */
84 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
85 lin2cnt += (htp == &hdr2))
86
87 typedef struct { /* dynamic line buffer */
88 char *str;
89 int len;
90 int siz;
91 } LINEBUF;
92
93 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
94 /* 100 MByte limit on line buffer */
95 #define MAXBUF (100L<<20)
96
97 /* input files */
98 char *progname = NULL;
99 const char stdin_name[] = "<stdin>";
100 const char *f1name=NULL, *f2name=NULL;
101 FILE *f1in=NULL, *f2in=NULL;
102 int f1swap=0, f2swap=0;
103
104 /* running real differences */
105 double diff2sum = 0;
106 long nsum = 0;
107
108 /* Report usage and exit */
109 static void
110 usage()
111 {
112 fputs("Usage: ", stderr);
113 fputs(progname, stderr);
114 fputs(" [-h][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
115 stderr);
116 exit(2);
117 }
118
119 /* Read a text line, increasing buffer size as necessary */
120 static int
121 read_line(LINEBUF *bp, FILE *fp)
122 {
123 static int doneWarn = 0;
124
125 bp->len = 0;
126 if (!bp->str) {
127 bp->str = (char *)malloc(bp->siz = 512);
128 if (!bp->str)
129 goto memerr;
130 }
131 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
132 bp->len += strlen(bp->str + bp->len);
133 if (bp->str[bp->len-1] == '\n')
134 break; /* found EOL */
135 if (bp->len < bp->siz - 4)
136 continue; /* at EOF? */
137 if (bp->siz >= MAXBUF) {
138 if ((report >= REP_WARN) & !doneWarn) {
139 fprintf(stderr,
140 "%s: warning - input line(s) past %ld MByte limit\n",
141 progname, MAXBUF>>20);
142 doneWarn++;
143 }
144 break; /* return MAXBUF partial line */
145 }
146 if ((bp->siz += bp->siz/2) > MAXBUF)
147 bp->siz = MAXBUF;
148 bp->str = (char *)realloc(bp->str, bp->siz);
149 if (!bp->str)
150 goto memerr;
151 }
152 return(bp->len);
153 memerr:
154 fprintf(stderr,
155 "%s: out of memory in read_line() allocating %d byte buffer\n",
156 progname, bp->siz);
157 exit(2);
158 }
159
160 /* Free line buffer */
161 static void
162 free_line(LINEBUF *bp)
163 {
164 if (bp->str) free(bp->str);
165 init_line(bp);
166 }
167
168 /* Get type ID from name (or 0 if not found) */
169 static int
170 xlate_type(const char *nm)
171 {
172 int i;
173
174 if (!nm || !*nm)
175 return(TYP_UNKNOWN);
176 for (i = 1; file_type[i]; i++)
177 if (!strcmp(nm, file_type[i]))
178 return(i);
179 return(TYP_UNKNOWN);
180 }
181
182 /* Compare real values and keep track of differences */
183 static int
184 real_check(double r1, double r2)
185 {
186 double diff2 = (r1 - r2)*(r1 - r2);
187
188 if (rel_min > 0) { /* doing relative differences? */
189 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
190 if (av2 > rel_min*rel_min)
191 diff2 /= av2;
192 }
193 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
194 if (report != REP_QUIET)
195 printf(
196 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
197 progname,
198 (rel_min > 0) ? "relative " : "",
199 r1, r2, max_lim);
200 return(0);
201 }
202 diff2sum += diff2;
203 nsum++;
204 return(1);
205 }
206
207 /* Compare two color values for equivalence */
208 static int
209 color_check(COLOR c1, COLOR c2)
210 {
211 int p;
212
213 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
214 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
215 return(0);
216
217 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
218 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
219
220 return(real_check(colval(c1,p), colval(c2,p)));
221 }
222
223 /* Compare two normal directions for equivalence */
224 static int
225 norm_check(FVECT nv1, FVECT nv2)
226 {
227 double max2 = nv1[2]*nv2[2];
228 int imax = 2;
229 int i = 2;
230 /* identify largest component */
231 while (i--) {
232 double tm2 = nv1[i]*nv2[i];
233 if (tm2 > max2) {
234 imax = i;
235 max2 = tm2;
236 }
237 }
238 i = 3; /* compare smaller components */
239 while (i--) {
240 if (i == imax)
241 continue;
242 if (!real_check(nv1[i], nv2[i]))
243 return(0);
244 }
245 return(1);
246 }
247
248 /* Compare two strings for equivalence */
249 static int
250 equiv_string(char *s1, char *s2)
251 {
252 #define CLS_STR 0
253 #define CLS_INT 1
254 #define CLS_FLT 2
255 /* skip whitespace at beginning */
256 while (isspace(*s1)) s1++;
257 while (isspace(*s2)) s2++;
258 while (*s1) { /* check each word */
259 int inquote;
260 if (!*s2) /* unexpected EOL in s2? */
261 return(0);
262 inquote = *s1;
263 if ((inquote != '\'') & (inquote != '"'))
264 inquote = 0;
265 if (inquote) { /* quoted text must match exactly */
266 if (*s1++ != *s2++)
267 return(0);
268 while (*s1 != inquote) {
269 if (!*s1)
270 return(0);
271 if (*s1++ != *s2++)
272 return(0);
273 }
274 s1++;
275 if (*s2++ != inquote)
276 return(0);
277 } else { /* else classify word type */
278 char *s1s = s1;
279 char *s2s = s2;
280 int cls = CLS_STR;
281 s1 = sskip(s1);
282 s2 = sskip(s2);
283 if (iskip(s1s) == s1) {
284 if (iskip(s2s) == s2)
285 cls = CLS_INT;
286 else if (fskip(s2s) == s2)
287 cls = CLS_FLT;
288 } else if (fskip(s1s) == s1) {
289 if (fskip(s2s) != s2)
290 return(0);
291 cls = CLS_FLT;
292 }
293 switch (cls) {
294 case CLS_INT: /* strncmp() faster */
295 case CLS_STR:
296 if (s1 - s1s != s2 - s2s)
297 return(0);
298 if (strncmp(s1s, s2s, s1 - s1s))
299 return(0);
300 break;
301 case CLS_FLT:
302 if (!real_check(atof(s1s), atof(s2s)))
303 return(0);
304 break;
305 }
306 }
307 while (isspace(*s1)) s1++;
308 while (isspace(*s2)) s2++;
309 }
310 return(!*s2); /* match if we reached the end of s2, too */
311 #undef CLS_STR
312 #undef CLS_INT
313 #undef CLS_FLT
314 }
315
316 /* Check if string is var=value pair and set if not in ignore list */
317 static int
318 setheadvar(char *val, void *p)
319 {
320 char newval[128];
321 LUTAB *htp = (LUTAB *)p;
322 LUENT *tep;
323 char *key;
324 int kln, vln;
325 int n;
326
327 adv_linecnt(htp); /* side-effect is to count lines */
328 if (!isalpha(*val)) /* key must start line */
329 return(0);
330 /* check if we need to swap binary data */
331 if ((n = isbigendian(val)) >= 0) {
332 if (nativebigendian() == n)
333 return(0);
334 f1swap += (htp == &hdr1);
335 f2swap += (htp == &hdr2);
336 return(0);
337 }
338 key = val++;
339 while (*val && !isspace(*val) & (*val != '='))
340 val++;
341 kln = val - key;
342 while (isspace(*val)) /* check for value */
343 *val++ = '\0';
344 if (*val != '=')
345 return(0);
346 *val++ = '\0';
347 while (isspace(*val))
348 val++;
349 if (!*val) /* nothing set? */
350 return(0);
351 /* check if key to ignore */
352 for (n = 0; hdr_ignkey[n]; n++)
353 if (!strcmp(key, hdr_ignkey[n]))
354 return(0);
355 vln = strlen(val); /* eliminate space and newline at end */
356 while (isspace(val[--vln]))
357 ;
358 val[++vln] = '\0';
359 if (!(tep = lu_find(htp, key)))
360 return(-1); /* memory allocation error */
361 if (!tep->key)
362 tep->key = strcpy(malloc(kln+1), key);
363 if (tep->data) { /* check for special cases */
364 if (!strcmp(key, "EXPOSURE")) {
365 sprintf(newval, "%f", atof(tep->data)*atof(val));
366 vln = strlen(val = newval);
367 }
368 free(tep->data);
369 }
370 tep->data = strcpy(malloc(vln+1), val);
371 return(1);
372 }
373
374 /* Lookup correspondent in other header */
375 static int
376 match_val(const LUENT *ep1, void *p2)
377 {
378 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
379 if (!ep2 || !ep2->data) {
380 if (report != REP_QUIET)
381 printf("%s: variable '%s' missing in '%s'\n",
382 progname, ep1->key, f2name);
383 return(-1);
384 }
385 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
386 if (report != REP_QUIET) {
387 printf("%s: header variable '%s' has different values\n",
388 progname, ep1->key);
389 if (report >= REP_VERBOSE) {
390 printf("%s: %s=%s\n", f1name,
391 ep1->key, (char *)ep1->data);
392 printf("%s: %s=%s\n", f2name,
393 ep2->key, (char *)ep2->data);
394 }
395 }
396 return(-1);
397 }
398 return(1); /* good match */
399 }
400
401 /* Compare two sets of header variables */
402 static int
403 headers_match()
404 {
405 int ne = lu_doall(&hdr1, match_val, &hdr2);
406 if (ne < 0)
407 return(0); /* something didn't match! */
408 /* non-fatal if second header has extra */
409 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
410 printf("%s: warning - '%s' has %d extra header setting(s)\n",
411 progname, f2name, ne);
412 return(1); /* good match */
413 }
414
415 /* Check generic input to determine if it is binary, -1 on error */
416 static int
417 input_is_binary(FILE *fin)
418 {
419 int n = 0;
420 int c = 0;
421
422 while ((c = getc(fin)) != EOF) {
423 ++n;
424 if (!c | (c > 127))
425 break; /* non-ascii character */
426 if (n >= 10240)
427 break; /* enough to be confident */
428 }
429 if (!n)
430 return(-1); /* first read failed */
431 if (fseek(fin, 0L, 0) < 0)
432 return(-1); /* rewind failed */
433 return(!c | (c > 127));
434 }
435
436 /* Identify and return data type from header (if one) */
437 static int
438 identify_type(const char *name, FILE *fin, LUTAB *htp)
439 {
440 extern const char HDRSTR[];
441 int c;
442 /* check magic header start */
443 if ((c = getc(fin)) != HDRSTR[0]) {
444 if (c == EOF) goto badeof;
445 ungetc(c, fin);
446 c = 0;
447 } else if ((c = getc(fin)) != HDRSTR[1]) {
448 if (c == EOF) goto badeof;
449 ungetc(c, fin); ungetc(HDRSTR[0], fin);
450 c = 0;
451 }
452 if (c) { /* appears to have a header */
453 char sbuf[32];
454 if (!fgets(sbuf, sizeof(sbuf), fin))
455 goto badeof;
456 adv_linecnt(htp); /* for #?ID string */
457 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
458 fputs(name, stdout);
459 fputs(": warning - unexpected header ID: ", stdout);
460 fputs(sbuf, stdout);
461 }
462 if (getheader(fin, setheadvar, htp) < 0) {
463 fputs(name, stderr);
464 fputs(": unknown error reading header\n", stderr);
465 return(-1);
466 }
467 adv_linecnt(htp); /* for trailing emtpy line */
468 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
469 }
470 c = input_is_binary(fin); /* else peek to see if binary */
471 if (c < 0) {
472 fputs(name, stderr);
473 fputs(": read/seek error\n", stderr);
474 return(-1);
475 }
476 if (c)
477 return(TYP_BINARY);
478 SET_FILE_TEXT(fin); /* originally set to binary */
479 return(TYP_TEXT);
480 badeof:
481 if (report != REP_QUIET) {
482 fputs(name, stdout);
483 fputs(": unexpected end-of-file\n", stdout);
484 }
485 return(-1);
486 }
487
488 /* Check that overall RMS error is below threshold */
489 static int
490 good_RMS()
491 {
492 if (!nsum)
493 return(1);
494 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
495 if (report != REP_QUIET)
496 printf(
497 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
498 progname,
499 (rel_min > 0) ? "relative " : "",
500 f1name, f2name,
501 sqrt(diff2sum/(double)nsum), rms_lim);
502 return(0);
503 }
504 if (report >= REP_VERBOSE)
505 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
506 progname, (rel_min > 0) ? "relative " : "",
507 f1name, f2name, sqrt(diff2sum/(double)nsum));
508 return(1);
509 }
510
511 /* Compare two inputs as generic binary files */
512 static int
513 compare_binary()
514 {
515 int c1=0, c2=0;
516
517 if (report >= REP_VERBOSE) {
518 fputs(progname, stdout);
519 fputs(": comparing inputs as binary\n", stdout);
520 }
521 for ( ; ; ) { /* exact byte matching */
522 c1 = getc(f1in);
523 c2 = getc(f2in);
524 if (c1 == EOF) {
525 if (c2 == EOF)
526 return(1); /* success! */
527 if (report != REP_QUIET) {
528 fputs(f1name, stdout);
529 fputs(": unexpected end-of-file\n", stdout);
530 }
531 return(0);
532 }
533 if (c2 == EOF) {
534 if (report != REP_QUIET) {
535 fputs(f2name, stdout);
536 fputs(": unexpected end-of-file\n", stdout);
537 }
538 return(0);
539 }
540 if (c1 != c2)
541 break; /* quit and report difference */
542 }
543 if (report == REP_QUIET)
544 return(0);
545 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
546 progname, f1name, f2name, ftell(f1in), ftell(f2in));
547 if (report >= REP_VERBOSE)
548 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
549 progname, f1name, c1, f2name, c2);
550 return(0);
551 }
552
553 /* Compare two inputs as generic text files */
554 static int
555 compare_text()
556 {
557 LINEBUF l1buf, l2buf;
558
559 if (report >= REP_VERBOSE) {
560 fputs(progname, stdout);
561 fputs(": comparing inputs as ASCII text\n", stdout);
562 }
563 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
564 while (read_line(&l1buf, f1in)) {
565 lin1cnt++;
566 if (!*sskip2(l1buf.str,0))
567 continue; /* ignore empty lines */
568
569 while (read_line(&l2buf, f2in)) {
570 lin2cnt++;
571 if (*sskip2(l2buf.str,0))
572 break; /* found other non-empty line */
573 }
574 if (!l2buf.len) { /* input 2 EOF? */
575 if (report != REP_QUIET) {
576 fputs(f2name, stdout);
577 fputs(": unexpected end-of-file\n", stdout);
578 }
579 free_line(&l1buf); free_line(&l2buf);
580 return(0);
581 }
582 /* compare non-empty lines */
583 if (!equiv_string(l1buf.str, l2buf.str)) {
584 if (report != REP_QUIET) {
585 printf("%s: inputs '%s' and '%s' differ at line %d|%d\n",
586 progname, f1name, f2name,
587 lin1cnt, lin2cnt);
588 if ( report >= REP_VERBOSE &&
589 (l1buf.len < 256) &
590 (l2buf.len < 256) ) {
591 fputs("------------- Mismatch -------------\n", stdout);
592 printf("%s@%d:\t%s", f1name,
593 lin1cnt, l1buf.str);
594 printf("%s@%d:\t%s", f2name,
595 lin2cnt, l2buf.str);
596 }
597 }
598 free_line(&l1buf); free_line(&l2buf);
599 return(0);
600 }
601 }
602 free_line(&l1buf); /* check for EOF on input 2 */
603 while (read_line(&l2buf, f2in)) {
604 if (!*sskip2(l2buf.str,0))
605 continue;
606 if (report != REP_QUIET) {
607 fputs(f1name, stdout);
608 fputs(": unexpected end-of-file\n", stdout);
609 }
610 free_line(&l2buf);
611 return(0);
612 }
613 free_line(&l2buf);
614 return(good_RMS()); /* final check for reals */
615 }
616
617 /* Check image/map resolutions */
618 static int
619 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
620 {
621 if (r1p->rt != r2p->rt) {
622 if (report != REP_QUIET)
623 printf(
624 "%s: %ss '%s' and '%s' have different pixel ordering\n",
625 progname, class, f1name, f2name);
626 return(0);
627 }
628 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
629 if (report != REP_QUIET)
630 printf(
631 "%s: %ss '%s' and '%s' are different sizes\n",
632 progname, class, f1name, f2name);
633 return(0);
634 }
635 return(1);
636 }
637
638 /* Compare two inputs that are known to be RGBE or XYZE images */
639 static int
640 compare_hdr()
641 {
642 RESOLU rs1, rs2;
643 COLOR *scan1, *scan2;
644 int x, y;
645
646 if (report >= REP_VERBOSE) {
647 fputs(progname, stdout);
648 fputs(": comparing inputs as HDR images\n", stdout);
649 }
650 fgetsresolu(&rs1, f1in);
651 fgetsresolu(&rs2, f2in);
652 if (!check_resolu("HDR image", &rs1, &rs2))
653 return(0);
654 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
655 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
656 if (!scan1 | !scan2) {
657 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
658 exit(2);
659 }
660 for (y = 0; y < numscans(&rs1); y++) {
661 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
662 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
663 if (report != REP_QUIET)
664 printf("%s: unexpected end-of-file\n",
665 progname);
666 free(scan1);
667 free(scan2);
668 return(0);
669 }
670 for (x = 0; x < scanlen(&rs1); x++) {
671 if (color_check(scan1[x], scan2[x]))
672 continue;
673 if (report != REP_QUIET) {
674 printf(
675 "%s: pixels at scanline %d offset %d differ\n",
676 progname, y, x);
677 if (report >= REP_VERBOSE) {
678 printf("%s: (R,G,B)=(%g,%g,%g)\n",
679 f1name, colval(scan1[x],RED),
680 colval(scan1[x],GRN),
681 colval(scan1[x],BLU));
682 printf("%s: (R,G,B)=(%g,%g,%g)\n",
683 f2name, colval(scan2[x],RED),
684 colval(scan2[x],GRN),
685 colval(scan2[x],BLU));
686 }
687 }
688 free(scan1);
689 free(scan2);
690 return(0);
691 }
692 }
693 free(scan1);
694 free(scan2);
695 return(good_RMS()); /* final check of RMS */
696 }
697
698 /* Set reference depth based on header variable */
699 static int
700 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
701 {
702 static char depthvar[] = DEPTHSTR;
703 const char *drval;
704
705 depthvar[LDEPTHSTR-1] = '\0';
706 drval = (const char *)lu_find(htp, depthvar)->data;
707 if (!drval)
708 return(0);
709 dcp->refdepth = atof(drval);
710 if (dcp->refdepth <= 0) {
711 if (report != REP_QUIET) {
712 fputs(dcp->inpname, stderr);
713 fputs(": bad reference depth '", stderr);
714 fputs(drval, stderr);
715 fputs("'\n", stderr);
716 }
717 return(-1);
718 }
719 return(1);
720 }
721
722 /* Compare two encoded depth maps */
723 static int
724 compare_depth()
725 {
726 long nread = 0;
727 DEPTHCODEC dc1, dc2;
728
729 if (report >= REP_VERBOSE) {
730 fputs(progname, stdout);
731 fputs(": comparing inputs as depth maps\n", stdout);
732 }
733 set_dc_defaults(&dc1);
734 dc1.hdrflags = HF_RESIN;
735 dc1.finp = f1in;
736 dc1.inpname = f1name;
737 set_dc_defaults(&dc2);
738 dc2.hdrflags = HF_RESIN;
739 dc2.finp = f2in;
740 dc2.inpname = f2name;
741 if (report != REP_QUIET) {
742 dc1.hdrflags |= HF_STDERR;
743 dc2.hdrflags |= HF_STDERR;
744 }
745 if (!process_dc_header(&dc1, 0, NULL))
746 return(0);
747 if (!process_dc_header(&dc2, 0, NULL))
748 return(0);
749 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
750 return(0);
751 if (set_refdepth(&dc1, &hdr1) < 0)
752 return(0);
753 if (set_refdepth(&dc2, &hdr2) < 0)
754 return(0);
755 while (nread < dc1.res.xr*dc1.res.yr) {
756 double d1 = decode_depth_next(&dc1);
757 double d2 = decode_depth_next(&dc2);
758 if ((d1 < 0) | (d2 < 0)) {
759 if (report != REP_QUIET)
760 printf("%s: unexpected end-of-file\n",
761 progname);
762 return(0);
763 }
764 ++nread;
765 if (real_check(d1, d2))
766 continue;
767 if (report != REP_QUIET)
768 printf("%s: %ld%s depth values differ\n",
769 progname, nread, num_sfx(nread));
770 return(0);
771 }
772 return(good_RMS()); /* final check of RMS */
773 }
774
775 /* Compare two encoded normal maps */
776 static int
777 compare_norm()
778 {
779 long nread = 0;
780 NORMCODEC nc1, nc2;
781
782 if (report >= REP_VERBOSE) {
783 fputs(progname, stdout);
784 fputs(": comparing inputs as normal maps\n", stdout);
785 }
786 set_nc_defaults(&nc1);
787 nc1.hdrflags = HF_RESIN;
788 nc1.finp = f1in;
789 nc1.inpname = f1name;
790 set_nc_defaults(&nc2);
791 nc2.hdrflags = HF_RESIN;
792 nc2.finp = f2in;
793 nc2.inpname = f2name;
794 if (report != REP_QUIET) {
795 nc1.hdrflags |= HF_STDERR;
796 nc2.hdrflags |= HF_STDERR;
797 }
798 if (!process_nc_header(&nc1, 0, NULL))
799 return(0);
800 if (!process_nc_header(&nc2, 0, NULL))
801 return(0);
802 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
803 return(0);
804 while (nread < nc1.res.xr*nc1.res.yr) {
805 FVECT nv1, nv2;
806 int rv1 = decode_normal_next(nv1, &nc1);
807 int rv2 = decode_normal_next(nv2, &nc2);
808 if ((rv1 < 0) | (rv2 < 0)) {
809 if (report != REP_QUIET)
810 printf("%s: unexpected end-of-file\n",
811 progname);
812 return(0);
813 }
814 ++nread;
815 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
816 continue;
817 if (report != REP_QUIET)
818 printf("%s: %ld%s normal vectors differ\n",
819 progname, nread, num_sfx(nread));
820 return(0);
821 }
822 return(good_RMS()); /* final check of RMS */
823 }
824
825 /* Compare two inputs that are known to be 32-bit floating-point data */
826 static int
827 compare_float()
828 {
829 long nread = 0;
830 float f1, f2;
831
832 if (report >= REP_VERBOSE) {
833 fputs(progname, stdout);
834 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
835 }
836 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
837 if (!getbinary(&f2, sizeof(f2), 1, f2in))
838 goto badeof;
839 ++nread;
840 if (f1swap) swap32((char *)&f1, 1);
841 if (f2swap) swap32((char *)&f2, 1);
842 if (real_check(f1, f2))
843 continue;
844 if (report != REP_QUIET)
845 printf("%s: %ld%s float values differ\n",
846 progname, nread, num_sfx(nread));
847 return(0);
848 }
849 if (!getbinary(&f2, sizeof(f2), 1, f2in))
850 return(good_RMS()); /* final check of RMS */
851 badeof:
852 if (report != REP_QUIET)
853 printf("%s: unexpected end-of-file\n", progname);
854 return(0);
855 }
856
857 /* Compare two inputs that are known to be 64-bit floating-point data */
858 static int
859 compare_double()
860 {
861 long nread = 0;
862 double f1, f2;
863
864 if (report >= REP_VERBOSE) {
865 fputs(progname, stdout);
866 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
867 }
868 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
869 if (!getbinary(&f2, sizeof(f2), 1, f2in))
870 goto badeof;
871 ++nread;
872 if (f1swap) swap64((char *)&f1, 1);
873 if (f2swap) swap64((char *)&f2, 1);
874 if (real_check(f1, f2))
875 continue;
876 if (report != REP_QUIET)
877 printf("%s: %ld%s double values differ\n",
878 progname, nread, num_sfx(nread));
879 return(0);
880 }
881 if (!getbinary(&f2, sizeof(f2), 1, f2in))
882 return(good_RMS()); /* final check of RMS */
883 badeof:
884 if (report != REP_QUIET)
885 printf("%s: unexpected end-of-file\n", progname);
886 return(0);
887 }
888
889 /* Compare two Radiance files for equivalence */
890 int
891 main(int argc, char *argv[])
892 {
893 int typ1, typ2;
894 int a;
895
896 progname = argv[0];
897 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
898 switch (argv[a][1]) {
899 case 'h': /* ignore header info. */
900 ign_header = !ign_header;
901 continue;
902 case 's': /* silent operation */
903 report = REP_QUIET;
904 continue;
905 case 'w': /* turn off warnings */
906 if (report > REP_ERROR)
907 report = REP_ERROR;
908 continue;
909 case 'v': /* turn on verbose mode */
910 report = REP_VERBOSE;
911 continue;
912 case 'm': /* maximum epsilon */
913 max_lim = atof(argv[++a]);
914 continue;
915 case 'r':
916 if (argv[a][2] == 'e') /* relative difference */
917 rel_min = atof(argv[++a]);
918 else if (argv[a][2] == 'm') /* RMS limit */
919 rms_lim = atof(argv[++a]);
920 else
921 usage();
922 continue;
923 case '\0': /* first file from stdin */
924 f1in = stdin;
925 f1name = stdin_name;
926 break;
927 default:
928 usage();
929 }
930 break;
931 }
932 if (a != argc-2) /* make sure of two inputs */
933 usage();
934 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
935 if (report >= REP_WARN)
936 printf("%s: warning - identical inputs given\n",
937 progname);
938 return(0);
939 }
940 if (!f1name) f1name = argv[a];
941 if (!f2name) f2name = argv[a+1];
942 /* open inputs */
943 SET_FILE_BINARY(stdin); /* in case we're using it */
944 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
945 fprintf(stderr, "%s: cannot open for reading\n", f1name);
946 return(2);
947 }
948 if (!strcmp(f2name, "-")) {
949 f2in = stdin;
950 f2name = stdin_name;
951 } else if (!(f2in = fopen(f2name, "rb"))) {
952 fprintf(stderr, "%s: cannot open for reading\n", f2name);
953 return(2);
954 }
955 /* load headers */
956 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
957 return(2);
958 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
959 return(2);
960 if (typ1 != typ2) {
961 if (report != REP_QUIET)
962 printf("%s: '%s' format is %s and '%s' is %s\n",
963 progname, f1name, file_type[typ1],
964 f2name, file_type[typ2]);
965 return(1);
966 }
967 ign_header |= !has_header(typ1); /* check headers if indicated */
968 if (!ign_header && !headers_match())
969 return(1);
970 if (!ign_header & (report >= REP_WARN)) {
971 if (lin1cnt != lin2cnt)
972 printf("%s: warning - headers are different lengths\n",
973 progname);
974 if (typ1 == TYP_UNKNOWN)
975 printf("%s: warning - unrecognized format\n",
976 progname);
977 }
978 if (report >= REP_VERBOSE) {
979 printf("%s: data format is %s\n", progname, file_type[typ1]);
980 if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
981 if (f1swap)
982 printf("%s: input '%s' is byte-swapped\n",
983 progname, f1name);
984 if (f2swap)
985 printf("%s: input '%s' is byte-swapped\n",
986 progname, f2name);
987 }
988 }
989 switch (typ1) { /* compare based on type */
990 case TYP_BINARY:
991 case TYP_TMESH:
992 case TYP_OCTREE:
993 case TYP_RBFMESH:
994 case TYP_ID8:
995 case TYP_ID16:
996 case TYP_ID24:
997 case TYP_UNKNOWN:
998 return( !compare_binary() );
999 case TYP_TEXT:
1000 case TYP_ASCII:
1001 return( !compare_text() );
1002 case TYP_RGBE:
1003 case TYP_XYZE:
1004 return( !compare_hdr() );
1005 case TYP_DEPTH:
1006 return( !compare_depth() );
1007 case TYP_NORM:
1008 return( !compare_norm() );
1009 case TYP_FLOAT:
1010 return( !compare_float() );
1011 case TYP_DOUBLE:
1012 return( !compare_double() );
1013 }
1014 return(1);
1015 }
