root/radiance/ray/src/util/radcompare.c
Revision: 2.19
Committed: Wed Aug 14 04:18:12 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.18: +194 -18 lines
2 static const char RCSid[] = "$Id: radcompare.c,v 2.18 2018/12/01 21:09:53 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 double rel_min = 1e-5; /* positive for relative comparisons */
31
32 double rms_lim = 0.01; /* RMS difference limit */
33
34 double max_lim = 0.25; /* difference limit if non-negative */
35
36 int lin1cnt=0, lin2cnt=0; /* file line position */
37
38 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
39 "th","st","nd","rd","th","th","th","th","th","th"
40 };
41 #define num_sfx(n) nsuffix[(n)%10]
42
43 /* file types */
44 const char *file_type[] = {
45 "Unrecognized",
46 "TEXT_generic",
47 "ascii",
48 COLRFMT,
49 CIEFMT,
50 DEPTH16FMT,
51 NORMAL32FMT,
52 "float",
53 "double",
54 "BSDF_RBFmesh",
55 "Radiance_octree",
56 "Radiance_tmesh",
57 "8-bit_indexed_name",
58 "16-bit_indexed_name",
59 "24-bit_indexed_name",
60 "BINARY_unknown",
61 NULL /* terminator */
62 };
63 /* keep consistent with above */
64 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE,
65 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
66 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
67 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
68
69 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
70
71 /* header variables to always ignore */
72 const char *hdr_ignkey[] = {
73 "SOFTWARE",
74 "CAPDATE",
75 "GMT",
76 "FRAME",
77 NULL /* terminator */
78 };
79 /* header variable settings */
80 LUTAB hdr1 = LU_SINIT(free,free);
81 LUTAB hdr2 = LU_SINIT(free,free);
82
83 /* advance appropriate file line count */
84 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
85 lin2cnt += (htp == &hdr2))
86
87 typedef struct { /* dynamic line buffer */
88 char *str;
89 int len;
90 int siz;
91 } LINEBUF;
92
93 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
94 /* 100 MByte limit on line buffer */
95 #define MAXBUF (100L<<20)
96
97 /* input files */
98 char *progname = NULL;
99 const char stdin_name[] = "<stdin>";
100 const char *f1name=NULL, *f2name=NULL;
101 FILE *f1in=NULL, *f2in=NULL;
102
103 /* running real differences */
104 double diff2sum = 0;
105 long nsum = 0;
106
107 /* Report usage and exit */
108 static void
109 usage()
110 {
111 fputs("Usage: ", stderr);
112 fputs(progname, stderr);
113 fputs(" [-h][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
114 stderr);
115 exit(2);
116 }
117
118 /* Read a text line, increasing buffer size as necessary */
119 static int
120 read_line(LINEBUF *bp, FILE *fp)
121 {
122 static int doneWarn = 0;
123
124 bp->len = 0;
125 if (!bp->str) {
126 bp->str = (char *)malloc(bp->siz = 512);
127 if (!bp->str)
128 goto memerr;
129 }
130 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
131 bp->len += strlen(bp->str + bp->len);
132 if (bp->str[bp->len-1] == '\n')
133 break; /* found EOL */
134 if (bp->len < bp->siz - 4)
135 continue; /* at EOF? */
136 if (bp->siz >= MAXBUF) {
137 if ((report >= REP_WARN) & !doneWarn) {
138 fprintf(stderr,
139 "%s: warning - input line(s) past %ld MByte limit\n",
140 progname, MAXBUF>>20);
141 doneWarn++;
142 }
143 break; /* return MAXBUF partial line */
144 }
145 if ((bp->siz += bp->siz/2) > MAXBUF)
146 bp->siz = MAXBUF;
147 bp->str = (char *)realloc(bp->str, bp->siz);
148 if (!bp->str)
149 goto memerr;
150 }
151 return(bp->len);
152 memerr:
153 fprintf(stderr,
154 "%s: out of memory in read_line() allocating %d byte buffer\n",
155 progname, bp->siz);
156 exit(2);
157 }
158
159 /* Free line buffer */
160 static void
161 free_line(LINEBUF *bp)
162 {
163 if (bp->str) free(bp->str);
164 init_line(bp);
165 }
166
167 /* Get type ID from name (or 0 if not found) */
168 static int
169 xlate_type(const char *nm)
170 {
171 int i;
172
173 if (!nm || !*nm)
174 return(TYP_UNKNOWN);
175 for (i = 1; file_type[i]; i++)
176 if (!strcmp(nm, file_type[i]))
177 return(i);
178 return(TYP_UNKNOWN);
179 }
180
181 /* Compare real values and keep track of differences */
182 static int
183 real_check(double r1, double r2)
184 {
185 double diff2 = (r1 - r2)*(r1 - r2);
186
187 if (rel_min > 0) { /* doing relative differences? */
188 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
189 if (av2 > rel_min*rel_min)
190 diff2 /= av2;
191 }
192 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
193 if (report != REP_QUIET)
194 printf(
195 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
196 progname,
197 (rel_min > 0) ? "relative " : "",
198 r1, r2, max_lim);
199 return(0);
200 }
201 diff2sum += diff2;
202 nsum++;
203 return(1);
204 }
205
206 /* Compare two color values for equivalence */
207 static int
208 color_check(COLOR c1, COLOR c2)
209 {
210 int p;
211
212 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
213 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
214 return(0);
215
216 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
217 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
218
219 return(real_check(colval(c1,p), colval(c2,p)));
220 }
221
222 /* Compare two normal directions for equivalence */
223 static int
224 norm_check(FVECT nv1, FVECT nv2)
225 {
226 double max2 = nv1[2]*nv1[2];
227 int imax = 2;
228 int i = 2;
229 /* identify largest component */
230 while (i--) {
231 double tm2 = nv1[i]*nv1[i];
232 if (tm2 > max2) {
233 imax = i;
234 max2 = tm2;
235 }
236 }
237 i = 3; /* compare smaller components */
238 while (i--) {
239 if (i == imax)
240 continue;
241 if (!real_check(nv1[i], nv2[i]))
242 return(0);
243 }
244 return(1);
245 }
246
247 /* Compare two strings for equivalence */
248 static int
249 equiv_string(char *s1, char *s2)
250 {
251 #define CLS_STR 0
252 #define CLS_INT 1
253 #define CLS_FLT 2
254 /* skip whitespace at beginning */
255 while (isspace(*s1)) s1++;
256 while (isspace(*s2)) s2++;
257 while (*s1) { /* check each word */
258 int inquote;
259 if (!*s2) /* unexpected EOL in s2? */
260 return(0);
261 inquote = *s1;
262 if ((inquote != '\'') & (inquote != '"'))
263 inquote = 0;
264 if (inquote) { /* quoted text must match exactly */
265 if (*s1++ != *s2++)
266 return(0);
267 while (*s1 != inquote) {
268 if (!*s1)
269 return(0);
270 if (*s1++ != *s2++)
271 return(0);
272 }
273 s1++;
274 if (*s2++ != inquote)
275 return(0);
276 } else { /* else classify word type */
277 char *s1s = s1;
278 char *s2s = s2;
279 int cls = CLS_STR;
280 s1 = sskip(s1);
281 s2 = sskip(s2);
282 if (iskip(s1s) == s1) {
283 if (iskip(s2s) == s2)
284 cls = CLS_INT;
285 else if (fskip(s2s) == s2)
286 cls = CLS_FLT;
287 } else if (fskip(s1s) == s1) {
288 if (fskip(s2s) != s2)
289 return(0);
290 cls = CLS_FLT;
291 }
292 switch (cls) {
293 case CLS_INT: /* strncmp() faster */
294 case CLS_STR:
295 if (s1 - s1s != s2 - s2s)
296 return(0);
297 if (strncmp(s1s, s2s, s1 - s1s))
298 return(0);
299 break;
300 case CLS_FLT:
301 if (!real_check(atof(s1s), atof(s2s)))
302 return(0);
303 break;
304 }
305 }
306 while (isspace(*s1)) s1++;
307 while (isspace(*s2)) s2++;
308 }
309 return(!*s2); /* match if we reached the end of s2, too */
310 #undef CLS_STR
311 #undef CLS_INT
312 #undef CLS_FLT
313 }
314
315 /* Check if string is var=value pair and set if not in ignore list */
316 static int
317 setheadvar(char *val, void *p)
318 {
319 LUTAB *htp = (LUTAB *)p;
320 LUENT *tep;
321 char *key;
322 int kln, vln;
323 int n;
324
325 adv_linecnt(htp); /* side-effect is to count lines */
326 if (!isalpha(*val)) /* key must start line */
327 return(0);
328 key = val++;
329 while (*val && !isspace(*val) & (*val != '='))
330 val++;
331 kln = val - key;
332 while (isspace(*val)) /* check for value */
333 *val++ = '\0';
334 if (*val != '=')
335 return(0);
336 *val++ = '\0';
337 while (isspace(*val))
338 val++;
339 if (!*val) /* nothing set? */
340 return(0);
341 /* check if key to ignore */
342 for (n = 0; hdr_ignkey[n]; n++)
343 if (!strcmp(key, hdr_ignkey[n]))
344 return(0);
345 vln = strlen(val); /* eliminate space and newline at end */
346 while (isspace(val[--vln]))
347 ;
348 val[++vln] = '\0';
349 if (!(tep = lu_find(htp, key)))
350 return(-1); /* memory allocation error */
351 if (!tep->key)
352 tep->key = strcpy(malloc(kln+1), key);
353 if (tep->data)
354 free(tep->data);
355 tep->data = strcpy(malloc(vln+1), val);
356 return(1);
357 }
358
359 /* Lookup correspondent in other header */
360 static int
361 match_val(const LUENT *ep1, void *p2)
362 {
363 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
364 if (!ep2 || !ep2->data) {
365 if (report != REP_QUIET)
366 printf("%s: variable '%s' missing in '%s'\n",
367 progname, ep1->key, f2name);
368 return(-1);
369 }
370 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
371 if (report != REP_QUIET) {
372 printf("%s: header variable '%s' has different values\n",
373 progname, ep1->key);
374 if (report >= REP_VERBOSE) {
375 printf("%s: %s=%s\n", f1name,
376 ep1->key, (char *)ep1->data);
377 printf("%s: %s=%s\n", f2name,
378 ep2->key, (char *)ep2->data);
379 }
380 }
381 return(-1);
382 }
383 return(1); /* good match */
384 }
385
386 /* Compare two sets of header variables */
387 static int
388 headers_match()
389 {
390 int ne = lu_doall(&hdr1, match_val, &hdr2);
391 if (ne < 0)
392 return(0); /* something didn't match! */
393 /* non-fatal if second header has extra */
394 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
395 printf("%s: warning - '%s' has %d extra header setting(s)\n",
396 progname, f2name, ne);
397 return(1); /* good match */
398 }
399
400 /* Check generic input to determine if it is binary, -1 on error */
401 static int
402 input_is_binary(FILE *fin)
403 {
404 int n = 0;
405 int c = 0;
406
407 while ((c = getc(fin)) != EOF) {
408 ++n;
409 if (!c | (c > 127))
410 break; /* non-ascii character */
411 if (n >= 10240)
412 break; /* enough to be confident */
413 }
414 if (!n)
415 return(-1); /* first read failed */
416 if (fseek(fin, 0L, 0) < 0)
417 return(-1); /* rewind failed */
418 return(!c | (c > 127));
419 }
420
421 /* Identify and return data type from header (if one) */
422 static int
423 identify_type(const char *name, FILE *fin, LUTAB *htp)
424 {
425 extern const char HDRSTR[];
426 int c;
427 /* check magic header start */
428 if ((c = getc(fin)) != HDRSTR[0]) {
429 if (c == EOF) goto badeof;
430 ungetc(c, fin);
431 c = 0;
432 } else if ((c = getc(fin)) != HDRSTR[1]) {
433 if (c == EOF) goto badeof;
434 ungetc(c, fin); ungetc(HDRSTR[0], fin);
435 c = 0;
436 }
437 if (c) { /* appears to have a header */
438 char sbuf[32];
439 if (!fgets(sbuf, sizeof(sbuf), fin))
440 goto badeof;
441 adv_linecnt(htp); /* for #?ID string */
442 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
443 fputs(name, stdout);
444 fputs(": warning - unexpected header ID: ", stdout);
445 fputs(sbuf, stdout);
446 }
447 if (getheader(fin, setheadvar, htp) < 0) {
448 fputs(name, stderr);
449 fputs(": unknown error reading header\n", stderr);
450 return(-1);
451 }
452 adv_linecnt(htp); /* for trailing emtpy line */
453 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
454 }
455 c = input_is_binary(fin); /* else peek to see if binary */
456 if (c < 0) {
457 fputs(name, stderr);
458 fputs(": read/seek error\n", stderr);
459 return(-1);
460 }
461 if (c)
462 return(TYP_BINARY);
463 SET_FILE_TEXT(fin); /* originally set to binary */
464 return(TYP_TEXT);
465 badeof:
466 if (report != REP_QUIET) {
467 fputs(name, stdout);
468 fputs(": unexpected end-of-file\n", stdout);
469 }
470 return(-1);
471 }
472
473 /* Check that overall RMS error is below threshold */
474 static int
475 good_RMS()
476 {
477 if (!nsum)
478 return(1);
479 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
480 if (report != REP_QUIET)
481 printf(
482 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
483 progname,
484 (rel_min > 0) ? "relative " : "",
485 f1name, f2name,
486 sqrt(diff2sum/(double)nsum), rms_lim);
487 return(0);
488 }
489 if (report >= REP_VERBOSE)
490 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
491 progname, (rel_min > 0) ? "relative " : "",
492 f1name, f2name, sqrt(diff2sum/(double)nsum));
493 return(1);
494 }
495
496 /* Compare two inputs as generic binary files */
497 static int
498 compare_binary()
499 {
500 int c1=0, c2=0;
501
502 if (report >= REP_VERBOSE) {
503 fputs(progname, stdout);
504 fputs(": comparing inputs as binary\n", stdout);
505 }
506 for ( ; ; ) { /* exact byte matching */
507 c1 = getc(f1in);
508 c2 = getc(f2in);
509 if (c1 == EOF) {
510 if (c2 == EOF)
511 return(1); /* success! */
512 if (report != REP_QUIET) {
513 fputs(f1name, stdout);
514 fputs(": unexpected end-of-file\n", stdout);
515 }
516 return(0);
517 }
518 if (c2 == EOF) {
519 if (report != REP_QUIET) {
520 fputs(f2name, stdout);
521 fputs(": unexpected end-of-file\n", stdout);
522 }
523 return(0);
524 }
525 if (c1 != c2)
526 break; /* quit and report difference */
527 }
528 if (report == REP_QUIET)
529 return(0);
530 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
531 progname, f1name, f2name, ftell(f1in), ftell(f2in));
532 if (report >= REP_VERBOSE)
533 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
534 progname, f1name, c1, f2name, c2);
535 return(0);
536 }
537
538 /* Compare two inputs as generic text files */
539 static int
540 compare_text()
541 {
542 LINEBUF l1buf, l2buf;
543
544 if (report >= REP_VERBOSE) {
545 fputs(progname, stdout);
546 fputs(": comparing inputs as ASCII text\n", stdout);
547 }
548 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
549 while (read_line(&l1buf, f1in)) {
550 lin1cnt++;
551 if (!*sskip2(l1buf.str,0))
552 continue; /* ignore empty lines */
553
554 while (read_line(&l2buf, f2in)) {
555 lin2cnt++;
556 if (*sskip2(l2buf.str,0))
557 break; /* found other non-empty line */
558 }
559 if (!l2buf.len) { /* input 2 EOF? */
560 if (report != REP_QUIET) {
561 fputs(f2name, stdout);
562 fputs(": unexpected end-of-file\n", stdout);
563 }
564 free_line(&l1buf); free_line(&l2buf);
565 return(0);
566 }
567 /* compare non-empty lines */
568 if (!equiv_string(l1buf.str, l2buf.str)) {
569 if (report != REP_QUIET) {
570 printf("%s: inputs '%s' and '%s' differ at line %d|%d\n",
571 progname, f1name, f2name,
572 lin1cnt, lin2cnt);
573 if ( report >= REP_VERBOSE &&
574 (l1buf.len < 256) &
575 (l2buf.len < 256) ) {
576 fputs("------------- Mismatch -------------\n", stdout);
577 printf("%s@%d:\t%s", f1name,
578 lin1cnt, l1buf.str);
579 printf("%s@%d:\t%s", f2name,
580 lin2cnt, l2buf.str);
581 }
582 }
583 free_line(&l1buf); free_line(&l2buf);
584 return(0);
585 }
586 }
587 free_line(&l1buf); /* check for EOF on input 2 */
588 while (read_line(&l2buf, f2in)) {
589 if (!*sskip2(l2buf.str,0))
590 continue;
591 if (report != REP_QUIET) {
592 fputs(f1name, stdout);
593 fputs(": unexpected end-of-file\n", stdout);
594 }
595 free_line(&l2buf);
596 return(0);
597 }
598 free_line(&l2buf);
599 return(good_RMS()); /* final check for reals */
600 }
601
602 /* Check image/map resolutions */
603 static int
604 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
605 {
606 if (r1p->rt != r2p->rt) {
607 if (report != REP_QUIET)
608 printf(
609 "%s: %ss '%s' and '%s' have different pixel ordering\n",
610 progname, class, f1name, f2name);
611 return(0);
612 }
613 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
614 if (report != REP_QUIET)
615 printf(
616 "%s: %ss '%s' and '%s' are different sizes\n",
617 progname, class, f1name, f2name);
618 return(0);
619 }
620 return(1);
621 }
622
623 /* Compare two inputs that are known to be RGBE or XYZE images */
624 static int
625 compare_hdr()
626 {
627 RESOLU rs1, rs2;
628 COLOR *scan1, *scan2;
629 int x, y;
630
631 if (report >= REP_VERBOSE) {
632 fputs(progname, stdout);
633 fputs(": comparing inputs as HDR images\n", stdout);
634 }
635 fgetsresolu(&rs1, f1in);
636 fgetsresolu(&rs2, f2in);
637 if (!check_resolu("HDR image", &rs1, &rs2))
638 return(0);
639 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
640 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
641 if (!scan1 | !scan2) {
642 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
643 exit(2);
644 }
645 for (y = 0; y < numscans(&rs1); y++) {
646 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
647 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
648 if (report != REP_QUIET)
649 printf("%s: unexpected end-of-file\n",
650 progname);
651 free(scan1);
652 free(scan2);
653 return(0);
654 }
655 for (x = 0; x < scanlen(&rs1); x++) {
656 if (color_check(scan1[x], scan2[x]))
657 continue;
658 if (report != REP_QUIET) {
659 printf(
660 "%s: pixels at scanline %d offset %d differ\n",
661 progname, y, x);
662 if (report >= REP_VERBOSE) {
663 printf("%s: (R,G,B)=(%g,%g,%g)\n",
664 f1name, colval(scan1[x],RED),
665 colval(scan1[x],GRN),
666 colval(scan1[x],BLU));
667 printf("%s: (R,G,B)=(%g,%g,%g)\n",
668 f2name, colval(scan2[x],RED),
669 colval(scan2[x],GRN),
670 colval(scan2[x],BLU));
671 }
672 }
673 free(scan1);
674 free(scan2);
675 return(0);
676 }
677 }
678 free(scan1);
679 free(scan2);
680 return(good_RMS()); /* final check of RMS */
681 }
682
683 /* Set reference depth based on header variable */
684 static int
685 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
686 {
687 static char depthvar[] = DEPTHSTR;
688 const char *drval;
689
690 depthvar[LDEPTHSTR] = '\0';
691 drval = (const char *)lu_find(htp, depthvar)->data;
692 if (!drval)
693 return(0);
694 dcp->refdepth = atof(drval);
695 if (dcp->refdepth <= 0) {
696 if (report != REP_QUIET) {
697 fputs(dcp->inpname, stderr);
698 fputs(": bad reference depth '", stderr);
699 fputs(drval, stderr);
700 fputs("'\n", stderr);
701 }
702 return(-1);
703 }
704 return(1);
705 }
706
707 /* Compare two encoded depth maps */
708 static int
709 compare_depth()
710 {
711 long nread = 0;
712 DEPTHCODEC dc1, dc2;
713
714 if (report >= REP_VERBOSE) {
715 fputs(progname, stdout);
716 fputs(": comparing inputs as depth maps\n", stdout);
717 }
718 set_dc_defaults(&dc1);
719 dc1.hdrflags = HF_RESIN;
720 dc1.finp = f1in;
721 dc1.inpname = f1name;
722 set_dc_defaults(&dc2);
723 dc2.hdrflags = HF_RESIN;
724 dc2.finp = f2in;
725 dc2.inpname = f2name;
726 if (report != REP_QUIET) {
727 dc1.hdrflags |= HF_STDERR;
728 dc2.hdrflags |= HF_STDERR;
729 }
730 if (!process_dc_header(&dc1, 0, NULL))
731 return(0);
732 if (!process_dc_header(&dc2, 0, NULL))
733 return(0);
734 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
735 return(0);
736 if (set_refdepth(&dc1, &hdr1) < 0)
737 return(0);
738 if (set_refdepth(&dc2, &hdr2) < 0)
739 return(0);
740 while (nread < dc1.res.xr*dc1.res.yr) {
741 double d1 = decode_depth_next(&dc1);
742 double d2 = decode_depth_next(&dc2);
743 if ((d1 < 0) | (d2 < 0)) {
744 if (report != REP_QUIET)
745 printf("%s: unexpected end-of-file\n",
746 progname);
747 return(0);
748 }
749 ++nread;
750 if (real_check(d1, d2))
751 continue;
752 if (report != REP_QUIET)
753 printf("%s: %ld%s depth values differ\n",
754 progname, nread, num_sfx(nread));
755 return(0);
756 }
757 return(good_RMS()); /* final check of RMS */
758 }
759
760 /* Compare two encoded normal maps */
761 static int
762 compare_norm()
763 {
764 long nread = 0;
765 NORMCODEC nc1, nc2;
766
767 if (report >= REP_VERBOSE) {
768 fputs(progname, stdout);
769 fputs(": comparing inputs as normal maps\n", stdout);
770 }
771 set_nc_defaults(&nc1);
772 nc1.hdrflags = HF_RESIN;
773 nc1.finp = f1in;
774 nc1.inpname = f1name;
775 set_nc_defaults(&nc2);
776 nc2.hdrflags = HF_RESIN;
777 nc2.finp = f2in;
778 nc2.inpname = f2name;
779 if (report != REP_QUIET) {
780 nc1.hdrflags |= HF_STDERR;
781 nc2.hdrflags |= HF_STDERR;
782 }
783 if (!process_nc_header(&nc1, 0, NULL))
784 return(0);
785 if (!process_nc_header(&nc2, 0, NULL))
786 return(0);
787 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
788 return(0);
789 while (nread < nc1.res.xr*nc1.res.yr) {
790 FVECT nv1, nv2;
791 int rv1 = decode_normal_next(nv1, &nc1);
792 int rv2 = decode_normal_next(nv2, &nc2);
793 if ((rv1 < 0) | (rv2 < 0)) {
794 if (report != REP_QUIET)
795 printf("%s: unexpected end-of-file\n",
796 progname);
797 return(0);
798 }
799 ++nread;
800 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
801 continue;
802 if (report != REP_QUIET)
803 printf("%s: %ld%s normal vectors differ\n",
804 progname, nread, num_sfx(nread));
805 return(0);
806 }
807 return(good_RMS()); /* final check of RMS */
808 }
809
810 /* Compare two inputs that are known to be 32-bit floating-point data */
811 static int
812 compare_float()
813 {
814 long nread = 0;
815 float f1, f2;
816
817 if (report >= REP_VERBOSE) {
818 fputs(progname, stdout);
819 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
820 }
821 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
822 if (!getbinary(&f2, sizeof(f2), 1, f2in))
823 goto badeof;
824 ++nread;
825 if (real_check(f1, f2))
826 continue;
827 if (report != REP_QUIET)
828 printf("%s: %ld%s float values differ\n",
829 progname, nread, num_sfx(nread));
830 return(0);
831 }
832 if (!getbinary(&f2, sizeof(f2), 1, f2in))
833 return(good_RMS()); /* final check of RMS */
834 badeof:
835 if (report != REP_QUIET)
836 printf("%s: unexpected end-of-file\n", progname);
837 return(0);
838 }
839
840 /* Compare two inputs that are known to be 64-bit floating-point data */
841 static int
842 compare_double()
843 {
844 long nread = 0;
845 double f1, f2;
846
847 if (report >= REP_VERBOSE) {
848 fputs(progname, stdout);
849 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
850 }
851 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
852 if (!getbinary(&f2, sizeof(f2), 1, f2in))
853 goto badeof;
854 ++nread;
855 if (real_check(f1, f2))
856 continue;
857 if (report != REP_QUIET)
858 printf("%s: %ld%s double values differ\n",
859 progname, nread, num_sfx(nread));
860 return(0);
861 }
862 if (!getbinary(&f2, sizeof(f2), 1, f2in))
863 return(good_RMS()); /* final check of RMS */
864 badeof:
865 if (report != REP_QUIET)
866 printf("%s: unexpected end-of-file\n", progname);
867 return(0);
868 }
869
870 /* Compare two Radiance files for equivalence */
871 int
872 main(int argc, char *argv[])
873 {
874 int typ1, typ2;
875 int a;
876
877 progname = argv[0];
878 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
879 switch (argv[a][1]) {
880 case 'h': /* ignore header info. */
881 ign_header = !ign_header;
882 continue;
883 case 's': /* silent operation */
884 report = REP_QUIET;
885 continue;
886 case 'w': /* turn off warnings */
887 if (report > REP_ERROR)
888 report = REP_ERROR;
889 continue;
890 case 'v': /* turn on verbose mode */
891 report = REP_VERBOSE;
892 continue;
893 case 'm': /* maximum epsilon */
894 max_lim = atof(argv[++a]);
895 continue;
896 case 'r':
897 if (argv[a][2] == 'e') /* relative difference */
898 rel_min = atof(argv[++a]);
899 else if (argv[a][2] == 'm') /* RMS limit */
900 rms_lim = atof(argv[++a]);
901 else
902 usage();
903 continue;
904 case '\0': /* first file from stdin */
905 f1in = stdin;
906 f1name = stdin_name;
907 break;
908 default:
909 usage();
910 }
911 break;
912 }
913 if (a != argc-2) /* make sure of two inputs */
914 usage();
915 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
916 if (report >= REP_WARN)
917 printf("%s: warning - identical inputs given\n",
918 progname);
919 return(0);
920 }
921 if (!f1name) f1name = argv[a];
922 if (!f2name) f2name = argv[a+1];
923 /* open inputs */
924 SET_FILE_BINARY(stdin); /* in case we're using it */
925 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
926 fprintf(stderr, "%s: cannot open for reading\n", f1name);
927 return(2);
928 }
929 if (!strcmp(f2name, "-")) {
930 f2in = stdin;
931 f2name = stdin_name;
932 } else if (!(f2in = fopen(f2name, "rb"))) {
933 fprintf(stderr, "%s: cannot open for reading\n", f2name);
934 return(2);
935 }
936 /* load headers */
937 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
938 return(2);
939 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
940 return(2);
941 if (typ1 != typ2) {
942 if (report != REP_QUIET)
943 printf("%s: '%s' is %s and '%s' is %s\n",
944 progname, f1name, file_type[typ1],
945 f2name, file_type[typ2]);
946 return(1);
947 }
948 ign_header |= !has_header(typ1); /* check headers if indicated */
949 if (!ign_header && !headers_match())
950 return(1);
951 if (!ign_header & (report >= REP_WARN)) {
952 if (lin1cnt != lin2cnt)
953 printf("%s: warning - headers are different lengths\n",
954 progname);
955 if (typ1 == TYP_UNKNOWN)
956 printf("%s: warning - unrecognized format\n",
957 progname);
958 }
959 if (report >= REP_VERBOSE)
960 printf("%s: input file type is %s\n",
961 progname, file_type[typ1]);
962
963 switch (typ1) { /* compare based on type */
964 case TYP_BINARY:
965 case TYP_TMESH:
966 case TYP_OCTREE:
967 case TYP_RBFMESH:
968 case TYP_ID8:
969 case TYP_ID16:
970 case TYP_ID24:
971 case TYP_UNKNOWN:
972 return( !compare_binary() );
973 case TYP_TEXT:
974 case TYP_ASCII:
975 return( !compare_text() );
976 case TYP_RGBE:
977 case TYP_XYZE:
978 return( !compare_hdr() );
979 case TYP_DEPTH:
980 return( !compare_depth() );
981 case TYP_NORM:
982 return( !compare_norm() );
983 case TYP_FLOAT:
984 return( !compare_float() );
985 case TYP_DOUBLE:
986 return( !compare_double() );
987 }
988 return(1);
989 }
