root/Development/ray/src/util/radcompare.c
Revision: 2.26
Committed: Mon Jul 27 16:49:56 2020 UTC (5 years, 4 months ago) by greg
Changes since 2.25: +22 -3 lines
feat(radcompare): added -c option to ignore comments
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.26 static const char RCSid[] = "$Id: radcompare.c,v 2.25 2020/07/09 17:29:04 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Compare Radiance files for significant differences
6     *
7     * G. Ward
8     */
9
10     #include <stdlib.h>
11     #include <ctype.h>
12 greg 2.19 #include "rtmath.h"
13 greg 2.1 #include "platform.h"
14     #include "rtio.h"
15     #include "resolu.h"
16     #include "color.h"
17 greg 2.19 #include "depthcodec.h"
18     #include "normcodec.h"
19 greg 2.1 #include "lookup.h"
20     /* Reporting levels */
21     #define REP_QUIET 0 /* no reporting */
22     #define REP_ERROR 1 /* report errors only */
23     #define REP_WARN 2 /* report warnings as well */
24     #define REP_VERBOSE 3 /* verbose reporting */
25
26     int report = REP_WARN; /* reporting level */
27
28     int ign_header = 0; /* ignore header differences? */
29
30     double rel_min = 1e-5; /* positive for relative comparisons */
31
32     double rms_lim = 0.01; /* RMS difference limit */
33
34     double max_lim = 0.25; /* difference limit if non-negative */
35
36     int lin1cnt=0, lin2cnt=0; /* file line position */
37
38 greg 2.26 int comment_c = '\0'; /* comment delimiter for text files */
39
40 greg 2.6 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
41     "th","st","nd","rd","th","th","th","th","th","th"
42     };
43     #define num_sfx(n) nsuffix[(n)%10]
44
45 greg 2.1 /* file types */
46     const char *file_type[] = {
47     "Unrecognized",
48     "TEXT_generic",
49     "ascii",
50     COLRFMT,
51     CIEFMT,
52 greg 2.19 DEPTH16FMT,
53     NORMAL32FMT,
54 greg 2.4 "float",
55     "double",
56 greg 2.1 "BSDF_RBFmesh",
57     "Radiance_octree",
58     "Radiance_tmesh",
59 greg 2.19 "8-bit_indexed_name",
60     "16-bit_indexed_name",
61     "24-bit_indexed_name",
62 greg 2.1 "BINARY_unknown",
63     NULL /* terminator */
64     };
65 greg 2.6 /* keep consistent with above */
66 greg 2.19 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE,
67     TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
68     TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
69     TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
70 greg 2.1
71     #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
72
73     /* header variables to always ignore */
74     const char *hdr_ignkey[] = {
75     "SOFTWARE",
76     "CAPDATE",
77     "GMT",
78 greg 2.18 "FRAME",
79 greg 2.1 NULL /* terminator */
80     };
81     /* header variable settings */
82     LUTAB hdr1 = LU_SINIT(free,free);
83     LUTAB hdr2 = LU_SINIT(free,free);
84
85     /* advance appropriate file line count */
86     #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
87     lin2cnt += (htp == &hdr2))
88
89 greg 2.12 typedef struct { /* dynamic line buffer */
90 greg 2.14 char *str;
91 greg 2.12 int len;
92     int siz;
93     } LINEBUF;
94
95 greg 2.14 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
96 greg 2.12 /* 100 MByte limit on line buffer */
97     #define MAXBUF (100L<<20)
98
99 greg 2.1 /* input files */
100     char *progname = NULL;
101     const char stdin_name[] = "<stdin>";
102     const char *f1name=NULL, *f2name=NULL;
103     FILE *f1in=NULL, *f2in=NULL;
104 greg 2.20 int f1swap=0, f2swap=0;
105 greg 2.3
106 greg 2.1 /* running real differences */
107     double diff2sum = 0;
108 greg 2.8 long nsum = 0;
109 greg 2.1
110     /* Report usage and exit */
111     static void
112     usage()
113     {
114     fputs("Usage: ", stderr);
115     fputs(progname, stderr);
116 greg 2.26 fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
117 greg 2.1 stderr);
118 greg 2.9 exit(2);
119 greg 2.1 }
120
121 greg 2.12 /* Read a text line, increasing buffer size as necessary */
122     static int
123     read_line(LINEBUF *bp, FILE *fp)
124     {
125 greg 2.15 static int doneWarn = 0;
126
127 greg 2.12 bp->len = 0;
128 greg 2.14 if (!bp->str) {
129     bp->str = (char *)malloc(bp->siz = 512);
130     if (!bp->str)
131 greg 2.12 goto memerr;
132     }
133 greg 2.14 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
134     bp->len += strlen(bp->str + bp->len);
135     if (bp->str[bp->len-1] == '\n')
136 greg 2.12 break; /* found EOL */
137     if (bp->len < bp->siz - 4)
138     continue; /* at EOF? */
139 greg 2.15 if (bp->siz >= MAXBUF) {
140     if ((report >= REP_WARN) & !doneWarn) {
141     fprintf(stderr,
142     "%s: warning - input line(s) past %ld MByte limit\n",
143     progname, MAXBUF>>20);
144     doneWarn++;
145     }
146     break; /* return MAXBUF partial line */
147     }
148 greg 2.12 if ((bp->siz += bp->siz/2) > MAXBUF)
149     bp->siz = MAXBUF;
150 greg 2.14 bp->str = (char *)realloc(bp->str, bp->siz);
151     if (!bp->str)
152 greg 2.12 goto memerr;
153     }
154 greg 2.26 if (comment_c) { /* elide comment? */
155     char *cp = sskip2(bp->str,0);
156     if (*cp == comment_c) {
157     *cp++ = '\n';
158     *cp = '\0';
159     bp->len = cp - bp->str;
160     }
161     }
162 greg 2.12 return(bp->len);
163     memerr:
164     fprintf(stderr,
165     "%s: out of memory in read_line() allocating %d byte buffer\n",
166     progname, bp->siz);
167     exit(2);
168     }
169
170     /* Free line buffer */
171     static void
172     free_line(LINEBUF *bp)
173     {
174 greg 2.14 if (bp->str) free(bp->str);
175 greg 2.13 init_line(bp);
176 greg 2.12 }
177
178 greg 2.1 /* Get type ID from name (or 0 if not found) */
179     static int
180     xlate_type(const char *nm)
181     {
182     int i;
183
184     if (!nm || !*nm)
185     return(TYP_UNKNOWN);
186     for (i = 1; file_type[i]; i++)
187     if (!strcmp(nm, file_type[i]))
188     return(i);
189     return(TYP_UNKNOWN);
190     }
191
192     /* Compare real values and keep track of differences */
193     static int
194     real_check(double r1, double r2)
195     {
196     double diff2 = (r1 - r2)*(r1 - r2);
197
198     if (rel_min > 0) { /* doing relative differences? */
199     double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
200     if (av2 > rel_min*rel_min)
201     diff2 /= av2;
202     }
203     if (max_lim >= 0 && diff2 > max_lim*max_lim) {
204     if (report != REP_QUIET)
205 greg 2.4 printf(
206 greg 2.5 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
207 greg 2.1 progname,
208     (rel_min > 0) ? "relative " : "",
209 greg 2.5 r1, r2, max_lim);
210 greg 2.1 return(0);
211     }
212     diff2sum += diff2;
213     nsum++;
214     return(1);
215     }
216
217 greg 2.8 /* Compare two color values for equivalence */
218     static int
219     color_check(COLOR c1, COLOR c2)
220     {
221     int p;
222
223 greg 2.17 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
224     (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
225 greg 2.8 return(0);
226
227     p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
228     if (colval(c1,BLU) > colval(c1,p)) p = BLU;
229
230     return(real_check(colval(c1,p), colval(c2,p)));
231     }
232
233 greg 2.19 /* Compare two normal directions for equivalence */
234     static int
235     norm_check(FVECT nv1, FVECT nv2)
236     {
237 greg 2.22 double max2 = nv1[2]*nv2[2];
238 greg 2.19 int imax = 2;
239     int i = 2;
240     /* identify largest component */
241     while (i--) {
242 greg 2.22 double tm2 = nv1[i]*nv2[i];
243 greg 2.19 if (tm2 > max2) {
244     imax = i;
245     max2 = tm2;
246     }
247     }
248     i = 3; /* compare smaller components */
249     while (i--) {
250     if (i == imax)
251     continue;
252     if (!real_check(nv1[i], nv2[i]))
253     return(0);
254     }
255     return(1);
256     }
257
258 greg 2.1 /* Compare two strings for equivalence */
259     static int
260     equiv_string(char *s1, char *s2)
261     {
262     #define CLS_STR 0
263     #define CLS_INT 1
264     #define CLS_FLT 2
265     /* skip whitespace at beginning */
266     while (isspace(*s1)) s1++;
267     while (isspace(*s2)) s2++;
268     while (*s1) { /* check each word */
269 greg 2.2 int inquote;
270     if (!*s2) /* unexpected EOL in s2? */
271     return(0);
272     inquote = *s1;
273 greg 2.1 if ((inquote != '\'') & (inquote != '"'))
274     inquote = 0;
275     if (inquote) { /* quoted text must match exactly */
276     if (*s1++ != *s2++)
277     return(0);
278     while (*s1 != inquote) {
279     if (!*s1)
280     return(0);
281     if (*s1++ != *s2++)
282     return(0);
283     }
284     s1++;
285     if (*s2++ != inquote)
286     return(0);
287     } else { /* else classify word type */
288     char *s1s = s1;
289     char *s2s = s2;
290     int cls = CLS_STR;
291     s1 = sskip(s1);
292     s2 = sskip(s2);
293     if (iskip(s1s) == s1) {
294     if (iskip(s2s) == s2)
295     cls = CLS_INT;
296     else if (fskip(s2s) == s2)
297     cls = CLS_FLT;
298     } else if (fskip(s1s) == s1) {
299     if (fskip(s2s) != s2)
300     return(0);
301     cls = CLS_FLT;
302     }
303     switch (cls) {
304     case CLS_INT: /* strncmp() faster */
305     case CLS_STR:
306     if (s1 - s1s != s2 - s2s)
307     return(0);
308     if (strncmp(s1s, s2s, s1 - s1s))
309     return(0);
310     break;
311     case CLS_FLT:
312     if (!real_check(atof(s1s), atof(s2s)))
313     return(0);
314     break;
315     }
316     }
317     while (isspace(*s1)) s1++;
318     while (isspace(*s2)) s2++;
319     }
320     return(!*s2); /* match if we reached the end of s2, too */
321     #undef CLS_STR
322     #undef CLS_INT
323     #undef CLS_FLT
324     }
325
326     /* Check if string is var=value pair and set if not in ignore list */
327     static int
328     setheadvar(char *val, void *p)
329     {
330 greg 2.24 char newval[128];
331 greg 2.1 LUTAB *htp = (LUTAB *)p;
332     LUENT *tep;
333     char *key;
334     int kln, vln;
335     int n;
336
337 greg 2.3 adv_linecnt(htp); /* side-effect is to count lines */
338 greg 2.1 if (!isalpha(*val)) /* key must start line */
339     return(0);
340 greg 2.20 /* check if we need to swap binary data */
341     if ((n = isbigendian(val)) >= 0) {
342     if (nativebigendian() == n)
343     return(0);
344     f1swap += (htp == &hdr1);
345     f2swap += (htp == &hdr2);
346     return(0);
347     }
348 greg 2.1 key = val++;
349     while (*val && !isspace(*val) & (*val != '='))
350     val++;
351     kln = val - key;
352     while (isspace(*val)) /* check for value */
353     *val++ = '\0';
354     if (*val != '=')
355     return(0);
356     *val++ = '\0';
357     while (isspace(*val))
358     val++;
359     if (!*val) /* nothing set? */
360     return(0);
361     /* check if key to ignore */
362     for (n = 0; hdr_ignkey[n]; n++)
363     if (!strcmp(key, hdr_ignkey[n]))
364     return(0);
365 greg 2.6 vln = strlen(val); /* eliminate space and newline at end */
366     while (isspace(val[--vln]))
367     ;
368     val[++vln] = '\0';
369 greg 2.1 if (!(tep = lu_find(htp, key)))
370 greg 2.4 return(-1); /* memory allocation error */
371 greg 2.1 if (!tep->key)
372     tep->key = strcpy(malloc(kln+1), key);
373 greg 2.24 if (tep->data) { /* check for special cases */
374     if (!strcmp(key, "EXPOSURE")) {
375     sprintf(newval, "%f", atof(tep->data)*atof(val));
376     vln = strlen(val = newval);
377     }
378 greg 2.1 free(tep->data);
379 greg 2.24 }
380 greg 2.1 tep->data = strcpy(malloc(vln+1), val);
381     return(1);
382     }
383
384     /* Lookup correspondent in other header */
385     static int
386     match_val(const LUENT *ep1, void *p2)
387     {
388     const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
389     if (!ep2 || !ep2->data) {
390     if (report != REP_QUIET)
391 greg 2.5 printf("%s: variable '%s' missing in '%s'\n",
392 greg 2.1 progname, ep1->key, f2name);
393     return(-1);
394     }
395     if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
396 greg 2.4 if (report != REP_QUIET) {
397 greg 2.5 printf("%s: header variable '%s' has different values\n",
398 greg 2.1 progname, ep1->key);
399 greg 2.4 if (report >= REP_VERBOSE) {
400     printf("%s: %s=%s\n", f1name,
401     ep1->key, (char *)ep1->data);
402     printf("%s: %s=%s\n", f2name,
403     ep2->key, (char *)ep2->data);
404     }
405     }
406 greg 2.1 return(-1);
407     }
408     return(1); /* good match */
409     }
410
411     /* Compare two sets of header variables */
412     static int
413 greg 2.10 headers_match()
414 greg 2.1 {
415 greg 2.10 int ne = lu_doall(&hdr1, match_val, &hdr2);
416 greg 2.1 if (ne < 0)
417     return(0); /* something didn't match! */
418 greg 2.4 /* non-fatal if second header has extra */
419 greg 2.10 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
420 greg 2.5 printf("%s: warning - '%s' has %d extra header setting(s)\n",
421 greg 2.1 progname, f2name, ne);
422     return(1); /* good match */
423     }
424
425     /* Check generic input to determine if it is binary, -1 on error */
426     static int
427     input_is_binary(FILE *fin)
428     {
429     int n = 0;
430     int c = 0;
431
432     while ((c = getc(fin)) != EOF) {
433 greg 2.5 ++n;
434 greg 2.1 if (!c | (c > 127))
435     break; /* non-ascii character */
436 greg 2.5 if (n >= 10240)
437 greg 2.1 break; /* enough to be confident */
438     }
439     if (!n)
440     return(-1); /* first read failed */
441     if (fseek(fin, 0L, 0) < 0)
442     return(-1); /* rewind failed */
443     return(!c | (c > 127));
444     }
445
446     /* Identify and return data type from header (if one) */
447     static int
448     identify_type(const char *name, FILE *fin, LUTAB *htp)
449     {
450     extern const char HDRSTR[];
451     int c;
452     /* check magic header start */
453     if ((c = getc(fin)) != HDRSTR[0]) {
454     if (c == EOF) goto badeof;
455     ungetc(c, fin);
456     c = 0;
457     } else if ((c = getc(fin)) != HDRSTR[1]) {
458     if (c == EOF) goto badeof;
459     ungetc(c, fin); ungetc(HDRSTR[0], fin);
460     c = 0;
461     }
462     if (c) { /* appears to have a header */
463     char sbuf[32];
464     if (!fgets(sbuf, sizeof(sbuf), fin))
465     goto badeof;
466 greg 2.3 adv_linecnt(htp); /* for #?ID string */
467 greg 2.1 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
468 greg 2.4 fputs(name, stdout);
469     fputs(": warning - unexpected header ID: ", stdout);
470     fputs(sbuf, stdout);
471 greg 2.1 }
472     if (getheader(fin, setheadvar, htp) < 0) {
473     fputs(name, stderr);
474 greg 2.6 fputs(": unknown error reading header\n", stderr);
475 greg 2.1 return(-1);
476     }
477     adv_linecnt(htp); /* for trailing emtpy line */
478     return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
479     }
480     c = input_is_binary(fin); /* else peek to see if binary */
481     if (c < 0) {
482     fputs(name, stderr);
483     fputs(": read/seek error\n", stderr);
484     return(-1);
485     }
486     if (c)
487     return(TYP_BINARY);
488     return(TYP_TEXT);
489     badeof:
490     if (report != REP_QUIET) {
491 greg 2.4 fputs(name, stdout);
492 greg 2.6 fputs(": unexpected end-of-file\n", stdout);
493 greg 2.1 }
494     return(-1);
495     }
496
497     /* Check that overall RMS error is below threshold */
498     static int
499     good_RMS()
500     {
501     if (!nsum)
502     return(1);
503     if (diff2sum/(double)nsum > rms_lim*rms_lim) {
504     if (report != REP_QUIET)
505 greg 2.4 printf(
506 greg 2.5 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
507 greg 2.1 progname,
508     (rel_min > 0) ? "relative " : "",
509     f1name, f2name,
510 greg 2.5 sqrt(diff2sum/(double)nsum), rms_lim);
511 greg 2.1 return(0);
512     }
513     if (report >= REP_VERBOSE)
514 greg 2.4 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
515 greg 2.1 progname, (rel_min > 0) ? "relative " : "",
516     f1name, f2name, sqrt(diff2sum/(double)nsum));
517     return(1);
518     }
519
520     /* Compare two inputs as generic binary files */
521     static int
522     compare_binary()
523     {
524 greg 2.5 int c1=0, c2=0;
525
526 greg 2.1 if (report >= REP_VERBOSE) {
527 greg 2.4 fputs(progname, stdout);
528     fputs(": comparing inputs as binary\n", stdout);
529 greg 2.1 }
530     for ( ; ; ) { /* exact byte matching */
531 greg 2.5 c1 = getc(f1in);
532     c2 = getc(f2in);
533 greg 2.1 if (c1 == EOF) {
534     if (c2 == EOF)
535     return(1); /* success! */
536     if (report != REP_QUIET) {
537 greg 2.4 fputs(f1name, stdout);
538 greg 2.6 fputs(": unexpected end-of-file\n", stdout);
539 greg 2.1 }
540     return(0);
541     }
542     if (c2 == EOF) {
543     if (report != REP_QUIET) {
544 greg 2.4 fputs(f2name, stdout);
545 greg 2.6 fputs(": unexpected end-of-file\n", stdout);
546 greg 2.1 }
547     return(0);
548     }
549     if (c1 != c2)
550     break; /* quit and report difference */
551     }
552     if (report == REP_QUIET)
553     return(0);
554 greg 2.5 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
555 greg 2.1 progname, f1name, f2name, ftell(f1in), ftell(f2in));
556 greg 2.5 if (report >= REP_VERBOSE)
557     printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
558     progname, f1name, c1, f2name, c2);
559 greg 2.1 return(0);
560     }
561
562     /* Compare two inputs as generic text files */
563     static int
564     compare_text()
565     {
566 greg 2.12 LINEBUF l1buf, l2buf;
567 greg 2.1
568     if (report >= REP_VERBOSE) {
569 greg 2.4 fputs(progname, stdout);
570 greg 2.26 fputs(": comparing inputs as ASCII text", stdout);
571     if (comment_c) {
572     fputs(", ignoring comments starting with '", stdout);
573     fputc(comment_c, stdout);
574     fputc('\'', stdout);
575     }
576     fputc('\n', stdout);
577 greg 2.1 }
578 greg 2.25 SET_FILE_TEXT(f1in); /* originally set to binary */
579     SET_FILE_TEXT(f2in);
580 greg 2.12 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
581     while (read_line(&l1buf, f1in)) {
582     lin1cnt++;
583 greg 2.14 if (!*sskip2(l1buf.str,0))
584 greg 2.1 continue; /* ignore empty lines */
585 greg 2.12
586     while (read_line(&l2buf, f2in)) {
587     lin2cnt++;
588 greg 2.14 if (*sskip2(l2buf.str,0))
589 greg 2.1 break; /* found other non-empty line */
590     }
591 greg 2.13 if (!l2buf.len) { /* input 2 EOF? */
592 greg 2.1 if (report != REP_QUIET) {
593 greg 2.4 fputs(f2name, stdout);
594 greg 2.6 fputs(": unexpected end-of-file\n", stdout);
595 greg 2.1 }
596 greg 2.12 free_line(&l1buf); free_line(&l2buf);
597 greg 2.1 return(0);
598     }
599     /* compare non-empty lines */
600 greg 2.14 if (!equiv_string(l1buf.str, l2buf.str)) {
601 greg 2.1 if (report != REP_QUIET) {
602 greg 2.4 printf("%s: inputs '%s' and '%s' differ at line %d|%d\n",
603 greg 2.1 progname, f1name, f2name,
604     lin1cnt, lin2cnt);
605 greg 2.12 if ( report >= REP_VERBOSE &&
606     (l1buf.len < 256) &
607     (l2buf.len < 256) ) {
608 greg 2.4 fputs("------------- Mismatch -------------\n", stdout);
609 greg 2.5 printf("%s@%d:\t%s", f1name,
610 greg 2.14 lin1cnt, l1buf.str);
611 greg 2.5 printf("%s@%d:\t%s", f2name,
612 greg 2.14 lin2cnt, l2buf.str);
613 greg 2.1 }
614     }
615 greg 2.12 free_line(&l1buf); free_line(&l2buf);
616 greg 2.1 return(0);
617     }
618     }
619 greg 2.13 free_line(&l1buf); /* check for EOF on input 2 */
620 greg 2.12 while (read_line(&l2buf, f2in)) {
621 greg 2.14 if (!*sskip2(l2buf.str,0))
622 greg 2.1 continue;
623     if (report != REP_QUIET) {
624 greg 2.4 fputs(f1name, stdout);
625 greg 2.6 fputs(": unexpected end-of-file\n", stdout);
626 greg 2.1 }
627 greg 2.13 free_line(&l2buf);
628 greg 2.1 return(0);
629     }
630 greg 2.13 free_line(&l2buf);
631 greg 2.1 return(good_RMS()); /* final check for reals */
632     }
633
634 greg 2.19 /* Check image/map resolutions */
635     static int
636     check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
637     {
638     if (r1p->rt != r2p->rt) {
639     if (report != REP_QUIET)
640     printf(
641     "%s: %ss '%s' and '%s' have different pixel ordering\n",
642     progname, class, f1name, f2name);
643     return(0);
644     }
645     if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
646     if (report != REP_QUIET)
647     printf(
648     "%s: %ss '%s' and '%s' are different sizes\n",
649     progname, class, f1name, f2name);
650     return(0);
651     }
652     return(1);
653     }
654
655 greg 2.1 /* Compare two inputs that are known to be RGBE or XYZE images */
656     static int
657     compare_hdr()
658     {
659     RESOLU rs1, rs2;
660     COLOR *scan1, *scan2;
661     int x, y;
662
663 greg 2.6 if (report >= REP_VERBOSE) {
664     fputs(progname, stdout);
665     fputs(": comparing inputs as HDR images\n", stdout);
666     }
667 greg 2.1 fgetsresolu(&rs1, f1in);
668     fgetsresolu(&rs2, f2in);
669 greg 2.19 if (!check_resolu("HDR image", &rs1, &rs2))
670 greg 2.1 return(0);
671     scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
672     scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
673     if (!scan1 | !scan2) {
674     fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
675     exit(2);
676     }
677     for (y = 0; y < numscans(&rs1); y++) {
678     if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
679     (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
680     if (report != REP_QUIET)
681 greg 2.6 printf("%s: unexpected end-of-file\n",
682 greg 2.1 progname);
683     free(scan1);
684     free(scan2);
685     return(0);
686     }
687 greg 2.5 for (x = 0; x < scanlen(&rs1); x++) {
688 greg 2.8 if (color_check(scan1[x], scan2[x]))
689 greg 2.1 continue;
690     if (report != REP_QUIET) {
691 greg 2.4 printf(
692 greg 2.1 "%s: pixels at scanline %d offset %d differ\n",
693     progname, y, x);
694     if (report >= REP_VERBOSE) {
695 greg 2.4 printf("%s: (R,G,B)=(%g,%g,%g)\n",
696 greg 2.1 f1name, colval(scan1[x],RED),
697     colval(scan1[x],GRN),
698     colval(scan1[x],BLU));
699 greg 2.4 printf("%s: (R,G,B)=(%g,%g,%g)\n",
700 greg 2.1 f2name, colval(scan2[x],RED),
701     colval(scan2[x],GRN),
702     colval(scan2[x],BLU));
703     }
704     }
705     free(scan1);
706     free(scan2);
707     return(0);
708     }
709     }
710     free(scan1);
711     free(scan2);
712     return(good_RMS()); /* final check of RMS */
713     }
714
715 greg 2.19 /* Set reference depth based on header variable */
716     static int
717     set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
718     {
719     static char depthvar[] = DEPTHSTR;
720     const char *drval;
721
722 greg 2.23 depthvar[LDEPTHSTR-1] = '\0';
723 greg 2.19 drval = (const char *)lu_find(htp, depthvar)->data;
724     if (!drval)
725     return(0);
726     dcp->refdepth = atof(drval);
727     if (dcp->refdepth <= 0) {
728     if (report != REP_QUIET) {
729     fputs(dcp->inpname, stderr);
730     fputs(": bad reference depth '", stderr);
731     fputs(drval, stderr);
732     fputs("'\n", stderr);
733     }
734     return(-1);
735     }
736     return(1);
737     }
738
739     /* Compare two encoded depth maps */
740     static int
741     compare_depth()
742     {
743     long nread = 0;
744     DEPTHCODEC dc1, dc2;
745
746     if (report >= REP_VERBOSE) {
747     fputs(progname, stdout);
748     fputs(": comparing inputs as depth maps\n", stdout);
749     }
750     set_dc_defaults(&dc1);
751     dc1.hdrflags = HF_RESIN;
752     dc1.finp = f1in;
753     dc1.inpname = f1name;
754     set_dc_defaults(&dc2);
755     dc2.hdrflags = HF_RESIN;
756     dc2.finp = f2in;
757     dc2.inpname = f2name;
758     if (report != REP_QUIET) {
759     dc1.hdrflags |= HF_STDERR;
760     dc2.hdrflags |= HF_STDERR;
761     }
762     if (!process_dc_header(&dc1, 0, NULL))
763     return(0);
764     if (!process_dc_header(&dc2, 0, NULL))
765     return(0);
766     if (!check_resolu("Depth map", &dc1.res, &dc2.res))
767     return(0);
768     if (set_refdepth(&dc1, &hdr1) < 0)
769     return(0);
770     if (set_refdepth(&dc2, &hdr2) < 0)
771     return(0);
772     while (nread < dc1.res.xr*dc1.res.yr) {
773     double d1 = decode_depth_next(&dc1);
774     double d2 = decode_depth_next(&dc2);
775     if ((d1 < 0) | (d2 < 0)) {
776     if (report != REP_QUIET)
777     printf("%s: unexpected end-of-file\n",
778     progname);
779     return(0);
780     }
781     ++nread;
782     if (real_check(d1, d2))
783     continue;
784     if (report != REP_QUIET)
785     printf("%s: %ld%s depth values differ\n",
786     progname, nread, num_sfx(nread));
787     return(0);
788     }
789     return(good_RMS()); /* final check of RMS */
790     }
791
792     /* Compare two encoded normal maps */
793     static int
794     compare_norm()
795     {
796     long nread = 0;
797     NORMCODEC nc1, nc2;
798
799     if (report >= REP_VERBOSE) {
800     fputs(progname, stdout);
801     fputs(": comparing inputs as normal maps\n", stdout);
802     }
803     set_nc_defaults(&nc1);
804     nc1.hdrflags = HF_RESIN;
805     nc1.finp = f1in;
806     nc1.inpname = f1name;
807     set_nc_defaults(&nc2);
808     nc2.hdrflags = HF_RESIN;
809     nc2.finp = f2in;
810     nc2.inpname = f2name;
811     if (report != REP_QUIET) {
812     nc1.hdrflags |= HF_STDERR;
813     nc2.hdrflags |= HF_STDERR;
814     }
815     if (!process_nc_header(&nc1, 0, NULL))
816     return(0);
817     if (!process_nc_header(&nc2, 0, NULL))
818     return(0);
819     if (!check_resolu("Normal map", &nc1.res, &nc2.res))
820     return(0);
821     while (nread < nc1.res.xr*nc1.res.yr) {
822     FVECT nv1, nv2;
823     int rv1 = decode_normal_next(nv1, &nc1);
824     int rv2 = decode_normal_next(nv2, &nc2);
825     if ((rv1 < 0) | (rv2 < 0)) {
826     if (report != REP_QUIET)
827     printf("%s: unexpected end-of-file\n",
828     progname);
829     return(0);
830     }
831     ++nread;
832     if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
833     continue;
834     if (report != REP_QUIET)
835     printf("%s: %ld%s normal vectors differ\n",
836     progname, nread, num_sfx(nread));
837     return(0);
838     }
839     return(good_RMS()); /* final check of RMS */
840     }
841
842 greg 2.1 /* Compare two inputs that are known to be 32-bit floating-point data */
843     static int
844     compare_float()
845     {
846     long nread = 0;
847     float f1, f2;
848
849 greg 2.6 if (report >= REP_VERBOSE) {
850     fputs(progname, stdout);
851 greg 2.7 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
852 greg 2.6 }
853 greg 2.1 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
854     if (!getbinary(&f2, sizeof(f2), 1, f2in))
855     goto badeof;
856     ++nread;
857 greg 2.20 if (f1swap) swap32((char *)&f1, 1);
858     if (f2swap) swap32((char *)&f2, 1);
859 greg 2.1 if (real_check(f1, f2))
860     continue;
861     if (report != REP_QUIET)
862 greg 2.4 printf("%s: %ld%s float values differ\n",
863 greg 2.6 progname, nread, num_sfx(nread));
864 greg 2.1 return(0);
865     }
866     if (!getbinary(&f2, sizeof(f2), 1, f2in))
867     return(good_RMS()); /* final check of RMS */
868     badeof:
869     if (report != REP_QUIET)
870 greg 2.6 printf("%s: unexpected end-of-file\n", progname);
871 greg 2.1 return(0);
872     }
873
874     /* Compare two inputs that are known to be 64-bit floating-point data */
875     static int
876     compare_double()
877     {
878     long nread = 0;
879     double f1, f2;
880
881 greg 2.6 if (report >= REP_VERBOSE) {
882     fputs(progname, stdout);
883 greg 2.7 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
884 greg 2.6 }
885 greg 2.1 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
886     if (!getbinary(&f2, sizeof(f2), 1, f2in))
887     goto badeof;
888     ++nread;
889 greg 2.20 if (f1swap) swap64((char *)&f1, 1);
890     if (f2swap) swap64((char *)&f2, 1);
891 greg 2.1 if (real_check(f1, f2))
892     continue;
893     if (report != REP_QUIET)
894 greg 2.6 printf("%s: %ld%s double values differ\n",
895     progname, nread, num_sfx(nread));
896 greg 2.1 return(0);
897     }
898     if (!getbinary(&f2, sizeof(f2), 1, f2in))
899     return(good_RMS()); /* final check of RMS */
900     badeof:
901     if (report != REP_QUIET)
902 greg 2.6 printf("%s: unexpected end-of-file\n", progname);
903 greg 2.1 return(0);
904     }
905
906     /* Compare two Radiance files for equivalence */
907     int
908     main(int argc, char *argv[])
909     {
910     int typ1, typ2;
911     int a;
912
913     progname = argv[0];
914     for (a = 1; a < argc && argv[a][0] == '-'; a++) {
915     switch (argv[a][1]) {
916     case 'h': /* ignore header info. */
917     ign_header = !ign_header;
918     continue;
919 greg 2.26 case 'c': /* ignore comments */
920     comment_c = argv[a][2];
921     continue;
922 greg 2.1 case 's': /* silent operation */
923     report = REP_QUIET;
924     continue;
925     case 'w': /* turn off warnings */
926     if (report > REP_ERROR)
927     report = REP_ERROR;
928     continue;
929     case 'v': /* turn on verbose mode */
930     report = REP_VERBOSE;
931     continue;
932     case 'm': /* maximum epsilon */
933     max_lim = atof(argv[++a]);
934     continue;
935     case 'r':
936     if (argv[a][2] == 'e') /* relative difference */
937     rel_min = atof(argv[++a]);
938     else if (argv[a][2] == 'm') /* RMS limit */
939     rms_lim = atof(argv[++a]);
940     else
941     usage();
942     continue;
943     case '\0': /* first file from stdin */
944     f1in = stdin;
945     f1name = stdin_name;
946     break;
947     default:
948     usage();
949     }
950     break;
951     }
952 greg 2.7 if (a != argc-2) /* make sure of two inputs */
953 greg 2.1 usage();
954 greg 2.7 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
955 greg 2.1 if (report >= REP_WARN)
956 greg 2.4 printf("%s: warning - identical inputs given\n",
957 greg 2.1 progname);
958     return(0);
959     }
960 greg 2.7 if (!f1name) f1name = argv[a];
961     if (!f2name) f2name = argv[a+1];
962 greg 2.1 /* open inputs */
963     SET_FILE_BINARY(stdin); /* in case we're using it */
964     if (!f1in && !(f1in = fopen(f1name, "rb"))) {
965     fprintf(stderr, "%s: cannot open for reading\n", f1name);
966 greg 2.9 return(2);
967 greg 2.1 }
968     if (!strcmp(f2name, "-")) {
969     f2in = stdin;
970     f2name = stdin_name;
971     } else if (!(f2in = fopen(f2name, "rb"))) {
972     fprintf(stderr, "%s: cannot open for reading\n", f2name);
973 greg 2.9 return(2);
974 greg 2.1 }
975     /* load headers */
976     if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
977 greg 2.9 return(2);
978 greg 2.1 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
979 greg 2.9 return(2);
980 greg 2.1 if (typ1 != typ2) {
981     if (report != REP_QUIET)
982 greg 2.21 printf("%s: '%s' format is %s and '%s' is %s\n",
983 greg 2.1 progname, f1name, file_type[typ1],
984     f2name, file_type[typ2]);
985     return(1);
986     }
987     ign_header |= !has_header(typ1); /* check headers if indicated */
988 greg 2.10 if (!ign_header && !headers_match())
989 greg 2.1 return(1);
990     if (!ign_header & (report >= REP_WARN)) {
991     if (lin1cnt != lin2cnt)
992 greg 2.4 printf("%s: warning - headers are different lengths\n",
993 greg 2.1 progname);
994 greg 2.16 if (typ1 == TYP_UNKNOWN)
995     printf("%s: warning - unrecognized format\n",
996     progname);
997 greg 2.1 }
998 greg 2.21 if (report >= REP_VERBOSE) {
999     printf("%s: data format is %s\n", progname, file_type[typ1]);
1000     if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
1001     if (f1swap)
1002     printf("%s: input '%s' is byte-swapped\n",
1003     progname, f1name);
1004     if (f2swap)
1005     printf("%s: input '%s' is byte-swapped\n",
1006     progname, f2name);
1007     }
1008     }
1009 greg 2.1 switch (typ1) { /* compare based on type */
1010     case TYP_BINARY:
1011     case TYP_TMESH:
1012     case TYP_OCTREE:
1013     case TYP_RBFMESH:
1014 greg 2.19 case TYP_ID8:
1015     case TYP_ID16:
1016     case TYP_ID24:
1017 greg 2.1 case TYP_UNKNOWN:
1018     return( !compare_binary() );
1019     case TYP_TEXT:
1020     case TYP_ASCII:
1021     return( !compare_text() );
1022     case TYP_RGBE:
1023     case TYP_XYZE:
1024     return( !compare_hdr() );
1025 greg 2.19 case TYP_DEPTH:
1026     return( !compare_depth() );
1027     case TYP_NORM:
1028     return( !compare_norm() );
1029 greg 2.1 case TYP_FLOAT:
1030     return( !compare_float() );
1031     case TYP_DOUBLE:
1032     return( !compare_double() );
1033     }
1034     return(1);
1035     }
