root/radiance/ray/src/util/radcompare.c
Revision: 2.7
Committed: Tue Oct 16 00:20:52 2018 UTC (6 years, 6 months ago) by greg
Fixed check of two standard inputs
2 static const char RCSid[] = "$Id: radcompare.c,v 2.6 2018/10/15 22:38:31 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "lookup.h"
18 /* Reporting levels */
19 #define REP_QUIET 0 /* no reporting */
20 #define REP_ERROR 1 /* report errors only */
21 #define REP_WARN 2 /* report warnings as well */
22 #define REP_VERBOSE 3 /* verbose reporting */
23
24 int report = REP_WARN; /* reporting level */
25
26 int ign_header = 0; /* ignore header differences? */
27
28 double rel_min = 1e-5; /* positive for relative comparisons */
29
30 double rms_lim = 0.01; /* RMS difference limit */
31
32 double max_lim = 0.25; /* difference limit if non-negative */
33
34 int lin1cnt=0, lin2cnt=0; /* file line position */
35
36 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
37 "th","st","nd","rd","th","th","th","th","th","th"
38 };
39 #define num_sfx(n) nsuffix[(n)%10]
40
41 /* file types */
42 const char *file_type[] = {
43 "Unrecognized",
44 "TEXT_generic",
45 "ascii",
46 COLRFMT,
47 CIEFMT,
48 "float",
49 "double",
50 "BSDF_RBFmesh",
51 "Radiance_octree",
52 "Radiance_tmesh",
53 "BINARY_unknown",
54 NULL /* terminator */
55 };
56 /* keep consistent with above */
57 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE, TYP_FLOAT,
58 TYP_DOUBLE, TYP_RBFMESH, TYP_OCTREE, TYP_TMESH, TYP_BINARY};
59
60 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
61
62 /* header variables to always ignore */
63 const char *hdr_ignkey[] = {
64 "SOFTWARE",
65 "CAPDATE",
66 "GMT",
67 NULL /* terminator */
68 };
69 /* header variable settings */
70 LUTAB hdr1 = LU_SINIT(free,free);
71 LUTAB hdr2 = LU_SINIT(free,free);
72
73 /* advance appropriate file line count */
74 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
75 lin2cnt += (htp == &hdr2))
76
77 /* input files */
78 char *progname = NULL;
79 const char stdin_name[] = "<stdin>";
80 const char *f1name=NULL, *f2name=NULL;
81 FILE *f1in=NULL, *f2in=NULL;
82
83 /* running real differences */
84 double diff2sum = 0;
85 int nsum = 0;
86
87 /* Report usage and exit */
88 static void
89 usage()
90 {
91 fputs("Usage: ", stderr);
92 fputs(progname, stderr);
93 fputs(" [-h][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
94 stderr);
95 exit(1);
96 }
97
98 /* Get type ID from name (or 0 if not found) */
99 static int
100 xlate_type(const char *nm)
101 {
102 int i;
103
104 if (!nm || !*nm)
105 return(TYP_UNKNOWN);
106 for (i = 1; file_type[i]; i++)
107 if (!strcmp(nm, file_type[i]))
108 return(i);
109 return(TYP_UNKNOWN);
110 }
111
112 /* Compare real values and keep track of differences */
113 static int
114 real_check(double r1, double r2)
115 {
116 double diff2 = (r1 - r2)*(r1 - r2);
117
118 if (rel_min > 0) { /* doing relative differences? */
119 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
120 if (av2 > rel_min*rel_min)
121 diff2 /= av2;
122 }
123 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
124 if (report != REP_QUIET)
125 printf(
126 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
127 progname,
128 (rel_min > 0) ? "relative " : "",
129 r1, r2, max_lim);
130 return(0);
131 }
132 diff2sum += diff2;
133 nsum++;
134 return(1);
135 }
136
137 /* Compare two strings for equivalence */
138 static int
139 equiv_string(char *s1, char *s2)
140 {
141 #define CLS_STR 0
142 #define CLS_INT 1
143 #define CLS_FLT 2
144 /* skip whitespace at beginning */
145 while (isspace(*s1)) s1++;
146 while (isspace(*s2)) s2++;
147 while (*s1) { /* check each word */
148 int inquote;
149 if (!*s2) /* unexpected EOL in s2? */
150 return(0);
151 inquote = *s1;
152 if ((inquote != '\'') & (inquote != '"'))
153 inquote = 0;
154 if (inquote) { /* quoted text must match exactly */
155 if (*s1++ != *s2++)
156 return(0);
157 while (*s1 != inquote) {
158 if (!*s1)
159 return(0);
160 if (*s1++ != *s2++)
161 return(0);
162 }
163 s1++;
164 if (*s2++ != inquote)
165 return(0);
166 } else { /* else classify word type */
167 char *s1s = s1;
168 char *s2s = s2;
169 int cls = CLS_STR;
170 s1 = sskip(s1);
171 s2 = sskip(s2);
172 if (iskip(s1s) == s1) {
173 if (iskip(s2s) == s2)
174 cls = CLS_INT;
175 else if (fskip(s2s) == s2)
176 cls = CLS_FLT;
177 } else if (fskip(s1s) == s1) {
178 if (fskip(s2s) != s2)
179 return(0);
180 cls = CLS_FLT;
181 }
182 switch (cls) {
183 case CLS_INT: /* strncmp() faster */
184 case CLS_STR:
185 if (s1 - s1s != s2 - s2s)
186 return(0);
187 if (strncmp(s1s, s2s, s1 - s1s))
188 return(0);
189 break;
190 case CLS_FLT:
191 if (!real_check(atof(s1s), atof(s2s)))
192 return(0);
193 break;
194 }
195 }
196 while (isspace(*s1)) s1++;
197 while (isspace(*s2)) s2++;
198 }
199 return(!*s2); /* match if we reached the end of s2, too */
200 #undef CLS_STR
201 #undef CLS_INT
202 #undef CLS_FLT
203 }
204
205 /* Check if string is var=value pair and set if not in ignore list */
206 static int
207 setheadvar(char *val, void *p)
208 {
209 LUTAB *htp = (LUTAB *)p;
210 LUENT *tep;
211 char *key;
212 int kln, vln;
213 int n;
214
215 adv_linecnt(htp); /* side-effect is to count lines */
216 if (!isalpha(*val)) /* key must start line */
217 return(0);
218 key = val++;
219 while (*val && !isspace(*val) & (*val != '='))
220 val++;
221 kln = val - key;
222 while (isspace(*val)) /* check for value */
223 *val++ = '\0';
224 if (*val != '=')
225 return(0);
226 *val++ = '\0';
227 while (isspace(*val))
228 val++;
229 if (!*val) /* nothing set? */
230 return(0);
231 /* check if key to ignore */
232 for (n = 0; hdr_ignkey[n]; n++)
233 if (!strcmp(key, hdr_ignkey[n]))
234 return(0);
235 vln = strlen(val); /* eliminate space and newline at end */
236 while (isspace(val[--vln]))
237 ;
238 val[++vln] = '\0';
239 if (!(tep = lu_find(htp, key)))
240 return(-1); /* memory allocation error */
241 if (!tep->key)
242 tep->key = strcpy(malloc(kln+1), key);
243 if (tep->data)
244 free(tep->data);
245 tep->data = strcpy(malloc(vln+1), val);
246 return(1);
247 }
248
249 /* Lookup correspondent in other header */
250 static int
251 match_val(const LUENT *ep1, void *p2)
252 {
253 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
254 if (!ep2 || !ep2->data) {
255 if (report != REP_QUIET)
256 printf("%s: variable '%s' missing in '%s'\n",
257 progname, ep1->key, f2name);
258 return(-1);
259 }
260 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
261 if (report != REP_QUIET) {
262 printf("%s: header variable '%s' has different values\n",
263 progname, ep1->key);
264 if (report >= REP_VERBOSE) {
265 printf("%s: %s=%s\n", f1name,
266 ep1->key, (char *)ep1->data);
267 printf("%s: %s=%s\n", f2name,
268 ep2->key, (char *)ep2->data);
269 }
270 }
271 return(-1);
272 }
273 return(1); /* good match */
274 }
275
276 /* Compare two sets of header variables */
277 static int
278 headers_match(LUTAB *hp1, LUTAB *hp2)
279 {
280 int ne = lu_doall(hp1, match_val, hp2);
281 if (ne < 0)
282 return(0); /* something didn't match! */
283 /* non-fatal if second header has extra */
284 if (report >= REP_WARN && (ne = lu_doall(hp2, NULL, NULL) - ne))
285 printf("%s: warning - '%s' has %d extra header setting(s)\n",
286 progname, f2name, ne);
287 return(1); /* good match */
288 }
289
290 /* Check generic input to determine if it is binary, -1 on error */
291 static int
292 input_is_binary(FILE *fin)
293 {
294 int n = 0;
295 int c = 0;
296
297 while ((c = getc(fin)) != EOF) {
298 ++n;
299 if (!c | (c > 127))
300 break; /* non-ascii character */
301 if (n >= 10240)
302 break; /* enough to be confident */
303 }
304 if (!n)
305 return(-1); /* first read failed */
306 if (fseek(fin, 0L, 0) < 0)
307 return(-1); /* rewind failed */
308 return(!c | (c > 127));
309 }
310
311 /* Identify and return data type from header (if one) */
312 static int
313 identify_type(const char *name, FILE *fin, LUTAB *htp)
314 {
315 extern const char HDRSTR[];
316 int c;
317 /* check magic header start */
318 if ((c = getc(fin)) != HDRSTR[0]) {
319 if (c == EOF) goto badeof;
320 ungetc(c, fin);
321 c = 0;
322 } else if ((c = getc(fin)) != HDRSTR[1]) {
323 if (c == EOF) goto badeof;
324 ungetc(c, fin); ungetc(HDRSTR[0], fin);
325 c = 0;
326 }
327 if (c) { /* appears to have a header */
328 char sbuf[32];
329 if (!fgets(sbuf, sizeof(sbuf), fin))
330 goto badeof;
331 adv_linecnt(htp); /* for #?ID string */
332 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
333 fputs(name, stdout);
334 fputs(": warning - unexpected header ID: ", stdout);
335 fputs(sbuf, stdout);
336 }
337 if (getheader(fin, setheadvar, htp) < 0) {
338 fputs(name, stderr);
339 fputs(": unknown error reading header\n", stderr);
340 return(-1);
341 }
342 adv_linecnt(htp); /* for trailing emtpy line */
343 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
344 }
345 c = input_is_binary(fin); /* else peek to see if binary */
346 if (c < 0) {
347 fputs(name, stderr);
348 fputs(": read/seek error\n", stderr);
349 return(-1);
350 }
351 if (c)
352 return(TYP_BINARY);
353 SET_FILE_TEXT(fin); /* originally set to binary */
354 return(TYP_TEXT);
355 badeof:
356 if (report != REP_QUIET) {
357 fputs(name, stdout);
358 fputs(": unexpected end-of-file\n", stdout);
359 }
360 return(-1);
361 }
362
363 /* Check that overall RMS error is below threshold */
364 static int
365 good_RMS()
366 {
367 if (!nsum)
368 return(1);
369 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
370 if (report != REP_QUIET)
371 printf(
372 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
373 progname,
374 (rel_min > 0) ? "relative " : "",
375 f1name, f2name,
376 sqrt(diff2sum/(double)nsum), rms_lim);
377 return(0);
378 }
379 if (report >= REP_VERBOSE)
380 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
381 progname, (rel_min > 0) ? "relative " : "",
382 f1name, f2name, sqrt(diff2sum/(double)nsum));
383 return(1);
384 }
385
386 /* Compare two inputs as generic binary files */
387 static int
388 compare_binary()
389 {
390 int c1=0, c2=0;
391
392 if (report >= REP_VERBOSE) {
393 fputs(progname, stdout);
394 fputs(": comparing inputs as binary\n", stdout);
395 }
396 for ( ; ; ) { /* exact byte matching */
397 c1 = getc(f1in);
398 c2 = getc(f2in);
399 if (c1 == EOF) {
400 if (c2 == EOF)
401 return(1); /* success! */
402 if (report != REP_QUIET) {
403 fputs(f1name, stdout);
404 fputs(": unexpected end-of-file\n", stdout);
405 }
406 return(0);
407 }
408 if (c2 == EOF) {
409 if (report != REP_QUIET) {
410 fputs(f2name, stdout);
411 fputs(": unexpected end-of-file\n", stdout);
412 }
413 return(0);
414 }
415 if (c1 != c2)
416 break; /* quit and report difference */
417 }
418 if (report == REP_QUIET)
419 return(0);
420 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
421 progname, f1name, f2name, ftell(f1in), ftell(f2in));
422 if (report >= REP_VERBOSE)
423 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
424 progname, f1name, c1, f2name, c2);
425 return(0);
426 }
427
428 /* Compare two inputs as generic text files */
429 static int
430 compare_text()
431 {
432 char l1buf[4096], l2buf[4096];
433
434 if (report >= REP_VERBOSE) {
435 fputs(progname, stdout);
436 fputs(": comparing inputs as ASCII text\n", stdout);
437 }
438 /* compare a line at a time */
439 while (fgets(l1buf, sizeof(l1buf), f1in)) {
440 lin1cnt++;
441 if (!*sskip2(l1buf,0))
442 continue; /* ignore empty lines */
443 while (fgets(l2buf, sizeof(l2buf), f2in)) {
444 lin2cnt++;
445 if (*sskip2(l2buf,0))
446 break; /* found other non-empty line */
447 }
448 if (feof(f2in)) {
449 if (report != REP_QUIET) {
450 fputs(f2name, stdout);
451 fputs(": unexpected end-of-file\n", stdout);
452 }
453 return(0);
454 }
455 /* compare non-empty lines */
456 if (!equiv_string(l1buf, l2buf)) {
457 if (report != REP_QUIET) {
458 printf("%s: inputs '%s' and '%s' differ at line %d|%d\n",
459 progname, f1name, f2name,
460 lin1cnt, lin2cnt);
461 if (report >= REP_VERBOSE) {
462 fputs("------------- Mismatch -------------\n", stdout);
463 printf("%s@%d:\t%s", f1name,
464 lin1cnt, l1buf);
465 printf("%s@%d:\t%s", f2name,
466 lin2cnt, l2buf);
467 }
468 }
469 return(0);
470 }
471 }
472 /* check for EOF on input 2 */
473 while (fgets(l2buf, sizeof(l2buf), f2in)) {
474 if (!*sskip2(l2buf,0))
475 continue;
476 if (report != REP_QUIET) {
477 fputs(f1name, stdout);
478 fputs(": unexpected end-of-file\n", stdout);
479 }
480 return(0);
481 }
482 return(good_RMS()); /* final check for reals */
483 }
484
485 /* Compare two inputs that are known to be RGBE or XYZE images */
486 static int
487 compare_hdr()
488 {
489 RESOLU rs1, rs2;
490 COLOR *scan1, *scan2;
491 int x, y;
492
493 if (report >= REP_VERBOSE) {
494 fputs(progname, stdout);
495 fputs(": comparing inputs as HDR images\n", stdout);
496 }
497 fgetsresolu(&rs1, f1in);
498 fgetsresolu(&rs2, f2in);
499 if (rs1.rt != rs2.rt) {
500 if (report != REP_QUIET)
501 printf(
502 "%s: Images '%s' and '%s' have different pixel ordering\n",
503 progname, f1name, f2name);
504 return(0);
505 }
506 if ((rs1.xr != rs2.xr) | (rs1.yr != rs2.yr)) {
507 if (report != REP_QUIET)
508 printf(
509 "%s: Images '%s' and '%s' are different sizes\n",
510 progname, f1name, f2name);
511 return(0);
512 }
513 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
514 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
515 if (!scan1 | !scan2) {
516 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
517 exit(2);
518 }
519 for (y = 0; y < numscans(&rs1); y++) {
520 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
521 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
522 if (report != REP_QUIET)
523 printf("%s: unexpected end-of-file\n",
524 progname);
525 free(scan1);
526 free(scan2);
527 return(0);
528 }
529 for (x = 0; x < scanlen(&rs1); x++) {
530 if (real_check(colval(scan1[x],RED),
531 colval(scan2[x],RED)) &
532 real_check(colval(scan1[x],GRN),
533 colval(scan2[x],GRN)) &
534 real_check(colval(scan1[x],BLU),
535 colval(scan2[x],BLU)))
536 continue;
537 if (report != REP_QUIET) {
538 printf(
539 "%s: pixels at scanline %d offset %d differ\n",
540 progname, y, x);
541 if (report >= REP_VERBOSE) {
542 printf("%s: (R,G,B)=(%g,%g,%g)\n",
543 f1name, colval(scan1[x],RED),
544 colval(scan1[x],GRN),
545 colval(scan1[x],BLU));
546 printf("%s: (R,G,B)=(%g,%g,%g)\n",
547 f2name, colval(scan2[x],RED),
548 colval(scan2[x],GRN),
549 colval(scan2[x],BLU));
550 }
551 }
552 free(scan1);
553 free(scan2);
554 return(0);
555 }
556 }
557 free(scan1);
558 free(scan2);
559 return(good_RMS()); /* final check of RMS */
560 }
561
562 /* Compare two inputs that are known to be 32-bit floating-point data */
563 static int
564 compare_float()
565 {
566 long nread = 0;
567 float f1, f2;
568
569 if (report >= REP_VERBOSE) {
570 fputs(progname, stdout);
571 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
572 }
573 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
574 if (!getbinary(&f2, sizeof(f2), 1, f2in))
575 goto badeof;
576 ++nread;
577 if (real_check(f1, f2))
578 continue;
579 if (report != REP_QUIET)
580 printf("%s: %ld%s float values differ\n",
581 progname, nread, num_sfx(nread));
582 return(0);
583 }
584 if (!getbinary(&f2, sizeof(f2), 1, f2in))
585 return(good_RMS()); /* final check of RMS */
586 badeof:
587 if (report != REP_QUIET)
588 printf("%s: unexpected end-of-file\n", progname);
589 return(0);
590 }
591
592 /* Compare two inputs that are known to be 64-bit floating-point data */
593 static int
594 compare_double()
595 {
596 long nread = 0;
597 double f1, f2;
598
599 if (report >= REP_VERBOSE) {
600 fputs(progname, stdout);
601 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
602 }
603 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
604 if (!getbinary(&f2, sizeof(f2), 1, f2in))
605 goto badeof;
606 ++nread;
607 if (real_check(f1, f2))
608 continue;
609 if (report != REP_QUIET)
610 printf("%s: %ld%s double values differ\n",
611 progname, nread, num_sfx(nread));
612 return(0);
613 }
614 if (!getbinary(&f2, sizeof(f2), 1, f2in))
615 return(good_RMS()); /* final check of RMS */
616 badeof:
617 if (report != REP_QUIET)
618 printf("%s: unexpected end-of-file\n", progname);
619 return(0);
620 }
621
622 /* Compare two Radiance files for equivalence */
623 int
624 main(int argc, char *argv[])
625 {
626 int typ1, typ2;
627 int a;
628
629 progname = argv[0];
630 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
631 switch (argv[a][1]) {
632 case 'h': /* ignore header info. */
633 ign_header = !ign_header;
634 continue;
635 case 's': /* silent operation */
636 report = REP_QUIET;
637 continue;
638 case 'w': /* turn off warnings */
639 if (report > REP_ERROR)
640 report = REP_ERROR;
641 continue;
642 case 'v': /* turn on verbose mode */
643 report = REP_VERBOSE;
644 continue;
645 case 'm': /* maximum epsilon */
646 max_lim = atof(argv[++a]);
647 continue;
648 case 'r':
649 if (argv[a][2] == 'e') /* relative difference */
650 rel_min = atof(argv[++a]);
651 else if (argv[a][2] == 'm') /* RMS limit */
652 rms_lim = atof(argv[++a]);
653 else
654 usage();
655 continue;
656 case '\0': /* first file from stdin */
657 f1in = stdin;
658 f1name = stdin_name;
659 break;
660 default:
661 usage();
662 }
663 break;
664 }
665 if (a != argc-2) /* make sure of two inputs */
666 usage();
667 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
668 if (report >= REP_WARN)
669 printf("%s: warning - identical inputs given\n",
670 progname);
671 return(0);
672 }
673 if (!f1name) f1name = argv[a];
674 if (!f2name) f2name = argv[a+1];
675 /* open inputs */
676 SET_FILE_BINARY(stdin); /* in case we're using it */
677 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
678 fprintf(stderr, "%s: cannot open for reading\n", f1name);
679 return(1);
680 }
681 if (!strcmp(f2name, "-")) {
682 f2in = stdin;
683 f2name = stdin_name;
684 } else if (!(f2in = fopen(f2name, "rb"))) {
685 fprintf(stderr, "%s: cannot open for reading\n", f2name);
686 return(1);
687 }
688 /* load headers */
689 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
690 return(1);
691 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
692 return(1);
693 if (typ1 != typ2) {
694 if (report != REP_QUIET)
695 printf("%s: '%s' is %s and '%s' is %s\n",
696 progname, f1name, file_type[typ1],
697 f2name, file_type[typ2]);
698 return(1);
699 }
700 ign_header |= !has_header(typ1); /* check headers if indicated */
701 if (!ign_header && !headers_match(&hdr1, &hdr2))
702 return(1);
703 lu_done(&hdr1); lu_done(&hdr2);
704 if (!ign_header & (report >= REP_WARN)) {
705 if (typ1 == TYP_UNKNOWN)
706 printf("%s: warning - unrecognized format, comparing as binary\n",
707 progname);
708 if (lin1cnt != lin2cnt)
709 printf("%s: warning - headers are different lengths\n",
710 progname);
711 }
712 if (report >= REP_VERBOSE)
713 printf("%s: input file type is %s\n",
714 progname, file_type[typ1]);
715
716 switch (typ1) { /* compare based on type */
717 case TYP_BINARY:
718 case TYP_TMESH:
719 case TYP_OCTREE:
720 case TYP_RBFMESH:
721 case TYP_UNKNOWN:
722 return( !compare_binary() );
723 case TYP_TEXT:
724 case TYP_ASCII:
725 return( !compare_text() );
726 case TYP_RGBE:
727 case TYP_XYZE:
728 return( !compare_hdr() );
729 case TYP_FLOAT:
730 return( !compare_float() );
731 case TYP_DOUBLE:
732 return( !compare_double() );
733 }
734 return(1);
735 }
