root/radiance/ray/src/util/radcompare.c
Tue Jun 3 21:31:51 2025 UTC (2 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.35: +3 -4 lines
Diff to previous 2.35
Mon Dec 9 00:29:30 2024 UTC (8 months ago) by greg
Changes since 2.34: +2 -1 lines
Diff to previous 2.34
fix(radcompare): Added "TILED" to the list of ignored header variables
Tue Nov 21 20:01:39 2023 UTC (20 months, 3 weeks ago) by greg
Changes since 2.33: +22 -1 lines
Diff to previous 2.33
refactor(radcompare): introduced alternate spectral comparison (commented out)
Tue Nov 21 19:22:38 2023 UTC (20 months, 3 weeks ago) by greg
Changes since 2.32: +117 -4 lines
Diff to previous 2.32
feat(radcompare): Added ability to compare spectral images (untested)
Wed Mar 8 19:59:48 2023 UTC (2 years, 5 months ago) by greg
Changes since 2.31: +7 -4 lines
Diff to previous 2.31
feat: made it so line number in ASCII file is not repeated if the same
Fri May 27 17:27:53 2022 UTC (3 years, 2 months ago) by greg
Changes since 2.30: +1 -2 lines
Diff to previous 2.30
fix(radcompare): backed out last change - didn't realize FORMAT entry was used
Tue May 24 22:34:18 2022 UTC (3 years, 2 months ago) by greg
Changes since 2.29: +2 -1 lines
Diff to previous 2.29
perf(radcompare): Added "FORMAT" to ignored header variables, since it's dealt with separately
Thu Mar 3 00:01:48 2022 UTC (3 years, 5 months ago) by greg
Changes since 2.28: +20 -2 lines
Diff to previous 2.28
feat(radcompare): Added '-n' option to allow escaped newlines
Mon Sep 27 19:00:04 2021 UTC (3 years, 10 months ago) by greg
Diff to previous 2.27
perf(radcompare): minor improvement in handling of EXPOSURE header info
Thu Feb 18 23:16:35 2021 UTC (4 years, 5 months ago) by greg
Changes since 2.26: +4 -3 lines
Diff to previous 2.26
fix: relative minimum was not being used correctly
Mon Jul 27 16:49:56 2020 UTC (5 years ago) by greg
Changes since 2.25: +22 -3 lines
Diff to previous 2.25
feat(radcompare): added -c option to ignore comments
Thu Jul 9 17:29:04 2020 UTC (5 years, 1 month ago) by greg
Diff to previous 2.24
fix(radcompare): was not switching back to text input mode in cases with header
Tue Jun 30 22:53:05 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.23: +8 -2 lines
Diff to previous 2.23
fix(radcompare): added special case for EXPOSURE header value
Tue Jun 30 01:17:54 2020 UTC (5 years, 1 month ago) by greg
Diff to previous 2.22
fix(radcompare): missing reference depth setting
Sat Aug 24 02:22:02 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.21: +3 -3 lines
Diff to previous 2.21
Fixed issue of some very different vectors as nearly equal
Thu Aug 15 17:28:45 2019 UTC (6 years ago) by greg
Changes since 2.20: +13 -6 lines
Diff to previous 2.20
Added mention of byte-swapping on input(s)
Wed Aug 14 18:20:02 2019 UTC (6 years ago) by greg
Changes since 2.19: +14 -1 lines
Diff to previous 2.19
Wed Aug 14 04:18:12 2019 UTC (6 years ago) by greg
Changes since 2.18: +194 -18 lines
Diff to previous 2.18
Sat Dec 1 21:09:53 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 2.17
Added FRAME to ignored header variables
Sat Nov 17 20:22:17 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 2.16
Fixed misplaced parentheses in color comparison
Fri Oct 26 23:45:56 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.15: +5 -5 lines
Diff to previous 2.15
Slight change in warning message
Sat Oct 20 15:17:27 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.14: +12 -3 lines
Diff to previous 2.14
Added warning about too-long input lines
Fri Oct 19 23:56:15 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.13: +18 -18 lines
Diff to previous 2.13
Renamed ptr to str
Fri Oct 19 23:50:32 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.12: +7 -9 lines
Diff to previous 2.12
Minor corrections related to last change
Fri Oct 19 22:15:30 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.11: +74 -41 lines
Dynamic input line buffers up to 100 MBytes
Fri Oct 19 20:32:16 2018 UTC (6 years, 9 months ago) by greg
Changes since 2.10: +32 -6 lines
Version with line backtracking for word boundaries
Wed Oct 17 17:39:23 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.9: +5 -5 lines
Made more sense to use globals for header variables
Tue Oct 16 16:52:05 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.8: +6 -6 lines
Made exit value more consistent -- 1 for difference, 2 for error
Tue Oct 16 16:23:17 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.7: +19 -8 lines
Created more robust color-comparison for RGBE/XYZE images
Tue Oct 16 00:20:52 2018 UTC (6 years, 10 months ago) by greg
Fixed check of two standard inputs
Mon Oct 15 22:38:31 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.5: +35 -22 lines
Additional reporting tweaks
Mon Oct 15 22:21:45 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.4: +21 -15 lines
Fix for files whose first character is binary, and a few output tweaks
Mon Oct 15 21:47:52 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.3: +58 -55 lines
Fixed detection of float/double inputs and changed all regular output to stdout
Mon Oct 15 18:31:15 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.2: +4 -3 lines
Fixed innaccurate header line count
Mon Oct 15 18:21:01 2018 UTC (6 years, 10 months ago) by greg
Minor fixes in string/real comparisons
Mon Oct 15 17:52:52 2018 UTC (6 years, 10 months ago) by greg
