root/radiance/ray/src/util/radcompare.c
Revision: 2.1
Committed: Mon Oct 15 17:52:52 2018 UTC (5 years, 7 months ago) by greg
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <math.h>
12 #include <ctype.h>
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "lookup.h"
18 /* Reporting levels */
19 #define REP_QUIET 0 /* no reporting */
20 #define REP_ERROR 1 /* report errors only */
21 #define REP_WARN 2 /* report warnings as well */
22 #define REP_VERBOSE 3 /* verbose reporting */
23
24 int report = REP_WARN; /* reporting level */
25
26 int ign_header = 0; /* ignore header differences? */
27
28 double rel_min = 1e-5; /* positive for relative comparisons */
29
30 double rms_lim = 0.01; /* RMS difference limit */
31
32 double max_lim = 0.25; /* difference limit if non-negative */
33
34 int lin1cnt=0, lin2cnt=0; /* file line position */
35
36 /* file types */
37 const char *file_type[] = {
38 "Unrecognized",
39 "TEXT_generic",
40 "ascii",
41 COLRFMT,
42 CIEFMT,
43 "BINARY_float",
44 "BINARY_double",
45 "BSDF_RBFmesh",
46 "Radiance_octree",
47 "Radiance_tmesh",
48 "BINARY_unknown",
49 NULL /* terminator */
50 };
51
52 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE, TYP_FLOAT,
53 TYP_DOUBLE, TYP_RBFMESH, TYP_OCTREE, TYP_TMESH, TYP_BINARY};
54
55 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
56
57 /* header variables to always ignore */
58 const char *hdr_ignkey[] = {
59 "SOFTWARE",
60 "CAPDATE",
61 "GMT",
62 NULL /* terminator */
63 };
64 /* header variable settings */
65 LUTAB hdr1 = LU_SINIT(free,free);
66 LUTAB hdr2 = LU_SINIT(free,free);
67
68 /* advance appropriate file line count */
69 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
70 lin2cnt += (htp == &hdr2))
71
72 /* input files */
73 char *progname = NULL;
74 const char stdin_name[] = "<stdin>";
75 const char *f1name=NULL, *f2name=NULL;
76 FILE *f1in=NULL, *f2in=NULL;
77 /* running real differences */
78 double diff2sum = 0;
79 int nsum = 0;
80
81 /* Report usage and exit */
82 static void
83 usage()
84 {
85 fputs("Usage: ", stderr);
86 fputs(progname, stderr);
87 fputs(" [-h][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] file1 file2\n",
88 stderr);
89 exit(1);
90 }
91
92 /* Get type ID from name (or 0 if not found) */
93 static int
94 xlate_type(const char *nm)
95 {
96 int i;
97
98 if (!nm || !*nm)
99 return(TYP_UNKNOWN);
100 for (i = 1; file_type[i]; i++)
101 if (!strcmp(nm, file_type[i]))
102 return(i);
103 return(TYP_UNKNOWN);
104 }
105
106 /* Compare real values and keep track of differences */
107 static int
108 real_check(double r1, double r2)
109 {
110 double diff2 = (r1 - r2)*(r1 - r2);
111
112 if (rel_min > 0) { /* doing relative differences? */
113 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
114 if (av2 > rel_min*rel_min)
115 diff2 /= av2;
116 }
117 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
118 if (report != REP_QUIET)
119 fprintf(stderr,
120 "%s: %sdifference between %.8g and %.8g exceeds epsilon\n",
121 progname,
122 (rel_min > 0) ? "relative " : "",
123 r1, r2);
124 return(0);
125 }
126 diff2sum += diff2;
127 nsum++;
128 return(1);
129 }
130
131 /* Compare two strings for equivalence */
132 static int
133 equiv_string(char *s1, char *s2)
134 {
135 #define CLS_STR 0
136 #define CLS_INT 1
137 #define CLS_FLT 2
138 /* skip whitespace at beginning */
139 while (isspace(*s1)) s1++;
140 while (isspace(*s2)) s2++;
141 if (!strcmp(s1, s2)) /* quick check */
142 return(1);
143 while (*s1) { /* check each word */
144 int inquote = *s1;
145 if ((inquote != '\'') & (inquote != '"'))
146 inquote = 0;
147 if (inquote) { /* quoted text must match exactly */
148 if (*s1++ != *s2++)
149 return(0);
150 while (*s1 != inquote) {
151 if (!*s1)
152 return(0);
153 if (*s1++ != *s2++)
154 return(0);
155 }
156 s1++;
157 if (*s2++ != inquote)
158 return(0);
159 } else { /* else classify word type */
160 char *s1s = s1;
161 char *s2s = s2;
162 int cls = CLS_STR;
163 s1 = sskip(s1);
164 s2 = sskip(s2);
165 if (iskip(s1s) == s1) {
166 if (iskip(s2s) == s2)
167 cls = CLS_INT;
168 else if (fskip(s2s) == s2)
169 cls = CLS_FLT;
170 } else if (fskip(s1s) == s1) {
171 if (fskip(s2s) != s2)
172 return(0);
173 cls = CLS_FLT;
174 }
175 switch (cls) {
176 case CLS_INT: /* strncmp() faster */
177 case CLS_STR:
178 if (s1 - s1s != s2 - s2s)
179 return(0);
180 if (strncmp(s1s, s2s, s1 - s1s))
181 return(0);
182 break;
183 case CLS_FLT:
184 if (!real_check(atof(s1s), atof(s2s)))
185 return(0);
186 break;
187 }
188 }
189 while (isspace(*s1)) s1++;
190 while (isspace(*s2)) s2++;
191 }
192 return(!*s2); /* match if we reached the end of s2, too */
193 #undef CLS_STR
194 #undef CLS_INT
195 #undef CLS_FLT
196 }
197
198 /* Check if string is var=value pair and set if not in ignore list */
199 static int
200 setheadvar(char *val, void *p)
201 {
202 LUTAB *htp = (LUTAB *)p;
203 LUENT *tep;
204 char *key;
205 int kln, vln;
206 int n;
207
208 if (!isalpha(*val)) /* key must start line */
209 return(0);
210 key = val++;
211 while (*val && !isspace(*val) & (*val != '='))
212 val++;
213 kln = val - key;
214 while (isspace(*val)) /* check for value */
215 *val++ = '\0';
216 if (*val != '=')
217 return(0);
218 *val++ = '\0';
219 while (isspace(*val))
220 val++;
221 if (!*val) /* nothing set? */
222 return(0);
223 vln = strlen(val); /* eliminate space and newline at end */
224 while (--vln > 0 && isspace(val[vln]))
225 ;
226 val[++vln] = '\0';
227 /* check if key to ignore */
228 for (n = 0; hdr_ignkey[n]; n++)
229 if (!strcmp(key, hdr_ignkey[n]))
230 return(0);
231 if (!(tep = lu_find(htp, key)))
232 return(-1);
233 if (!tep->key)
234 tep->key = strcpy(malloc(kln+1), key);
235 if (tep->data)
236 free(tep->data);
237 tep->data = strcpy(malloc(vln+1), val);
238 adv_linecnt(htp);
239 return(1);
240 }
241
242 /* Lookup correspondent in other header */
243 static int
244 match_val(const LUENT *ep1, void *p2)
245 {
246 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
247 if (!ep2 || !ep2->data) {
248 if (report != REP_QUIET)
249 fprintf(stderr, "%s: Variable '%s' missing in '%s'\n",
250 progname, ep1->key, f2name);
251 return(-1);
252 }
253 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
254 if (report != REP_QUIET)
255 fprintf(stderr, "%s: Header variables '%s' have different values\n",
256 progname, ep1->key);
257 return(-1);
258 }
259 return(1); /* good match */
260 }
261
262 /* Compare two sets of header variables */
263 static int
264 headers_match(LUTAB *hp1, LUTAB *hp2)
265 {
266 int ne = lu_doall(hp1, match_val, hp2);
267 if (ne < 0)
268 return(0); /* something didn't match! */
269 ne = lu_doall(hp2, NULL, NULL) - ne;
270 if (ne) {
271 if (report != REP_QUIET)
272 fprintf(stderr, "%s: '%s' has %d extra header variable(s)\n",
273 progname, f2name, ne);
274 return(0);
275 }
276 return(1); /* good match */
277 }
278
279 /* Check generic input to determine if it is binary, -1 on error */
280 static int
281 input_is_binary(FILE *fin)
282 {
283 int n = 0;
284 int c = 0;
285
286 while ((c = getc(fin)) != EOF) {
287 if (!c | (c > 127))
288 break; /* non-ascii character */
289 if (++n >= 10240)
290 break; /* enough to be confident */
291 }
292 if (!n)
293 return(-1); /* first read failed */
294 if (fseek(fin, 0L, 0) < 0)
295 return(-1); /* rewind failed */
296 return(!c | (c > 127));
297 }
298
299 /* Identify and return data type from header (if one) */
300 static int
301 identify_type(const char *name, FILE *fin, LUTAB *htp)
302 {
303 extern const char HDRSTR[];
304 int c;
305 /* check magic header start */
306 if ((c = getc(fin)) != HDRSTR[0]) {
307 if (c == EOF) goto badeof;
308 ungetc(c, fin);
309 c = 0;
310 } else if ((c = getc(fin)) != HDRSTR[1]) {
311 if (c == EOF) goto badeof;
312 ungetc(c, fin); ungetc(HDRSTR[0], fin);
313 c = 0;
314 }
315 if (c) { /* appears to have a header */
316 char sbuf[32];
317 if (!fgets(sbuf, sizeof(sbuf), fin))
318 goto badeof;
319 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
320 fputs(name, stderr);
321 fputs(": warning - unexpected header ID: ", stderr);
322 fputs(sbuf, stderr);
323 }
324 adv_linecnt(htp); /* for #?ID string */
325 if (getheader(fin, setheadvar, htp) < 0) {
326 fputs(name, stderr);
327 fputs(": Unknown error reading header\n", stderr);
328 return(-1);
329 }
330 adv_linecnt(htp); /* for trailing emtpy line */
331 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
332 }
333 c = input_is_binary(fin); /* else peek to see if binary */
334 if (c < 0) {
335 fputs(name, stderr);
336 fputs(": read/seek error\n", stderr);
337 return(-1);
338 }
339 if (c)
340 return(TYP_BINARY);
341 SET_FILE_TEXT(fin); /* originally set to binary */
342 return(TYP_TEXT);
343 badeof:
344 if (report != REP_QUIET) {
345 fputs(name, stderr);
346 fputs(": Unexpected end-of-file\n", stderr);
347 }
348 return(-1);
349 }
350
351 /* Check that overall RMS error is below threshold */
352 static int
353 good_RMS()
354 {
355 if (!nsum)
356 return(1);
357 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
358 if (report != REP_QUIET)
359 fprintf(stderr,
360 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit\n",
361 progname,
362 (rel_min > 0) ? "relative " : "",
363 f1name, f2name,
364 sqrt(diff2sum/(double)nsum));
365 return(0);
366 }
367 if (report >= REP_VERBOSE)
368 fprintf(stderr,
369 "%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
370 progname, (rel_min > 0) ? "relative " : "",
371 f1name, f2name, sqrt(diff2sum/(double)nsum));
372 return(1);
373 }
374
375 /* Compare two inputs as generic binary files */
376 static int
377 compare_binary()
378 {
379 if (report >= REP_VERBOSE) {
380 fputs(progname, stderr);
381 fputs(": comparing inputs as binary\n", stderr);
382 }
383 for ( ; ; ) { /* exact byte matching */
384 int c1 = getc(f1in);
385 int c2 = getc(f2in);
386 if (c1 == EOF) {
387 if (c2 == EOF)
388 return(1); /* success! */
389 if (report != REP_QUIET) {
390 fputs(f1name, stderr);
391 fputs(": Unexpected end-of-file\n", stderr);
392 }
393 return(0);
394 }
395 if (c2 == EOF) {
396 if (report != REP_QUIET) {
397 fputs(f2name, stderr);
398 fputs(": Unexpected end-of-file\n", stderr);
399 }
400 return(0);
401 }
402 if (c1 != c2)
403 break; /* quit and report difference */
404 }
405 if (report == REP_QUIET)
406 return(0);
407 fprintf(stderr, "%s: binary files '%s' and '%s' differ at offset %ld|%ld\n",
408 progname, f1name, f2name, ftell(f1in), ftell(f2in));
409 return(0);
410 }
411
412 /* Compare two inputs as generic text files */
413 static int
414 compare_text()
415 {
416 char l1buf[4096], l2buf[4096];
417
418 if (report >= REP_VERBOSE) {
419 fputs(progname, stderr);
420 fputs(": comparing inputs as ASCII text\n", stderr);
421 }
422 /* compare a line at a time */
423 while (fgets(l1buf, sizeof(l1buf), f1in)) {
424 lin1cnt++;
425 if (!*sskip2(l1buf,0))
426 continue; /* ignore empty lines */
427 while (fgets(l2buf, sizeof(l2buf), f2in)) {
428 lin2cnt++;
429 if (*sskip2(l2buf,0))
430 break; /* found other non-empty line */
431 }
432 if (feof(f2in)) {
433 if (report != REP_QUIET) {
434 fputs(f2name, stderr);
435 fputs(": Unexpected end-of-file\n", stderr);
436 }
437 return(0);
438 }
439 /* compare non-empty lines */
440 if (!equiv_string(l1buf, l2buf)) {
441 if (report != REP_QUIET) {
442 fprintf(stderr, "%s: inputs '%s' and '%s' differ at line %d|%d\n",
443 progname, f1name, f2name,
444 lin1cnt, lin2cnt);
445 if (report >= REP_VERBOSE) {
446 fputs("------------- Mismatch -------------\n", stderr);
447 fprintf(stderr, "%s(%d):\t%s", f1name,
448 lin1cnt, l1buf);
449 fprintf(stderr, "%s(%d):\t%s", f2name,
450 lin2cnt, l2buf);
451 }
452 }
453 return(0);
454 }
455 }
456 /* check for EOF on input 2 */
457 while (fgets(l2buf, sizeof(l2buf), f2in)) {
458 if (!*sskip2(l2buf,0))
459 continue;
460 if (report != REP_QUIET) {
461 fputs(f1name, stderr);
462 fputs(": Unexpected end-of-file\n", stderr);
463 }
464 return(0);
465 }
466 return(good_RMS()); /* final check for reals */
467 }
468
469 /* Compare two inputs that are known to be RGBE or XYZE images */
470 static int
471 compare_hdr()
472 {
473 RESOLU rs1, rs2;
474 COLOR *scan1, *scan2;
475 int x, y;
476
477 fgetsresolu(&rs1, f1in);
478 fgetsresolu(&rs2, f2in);
479 if (rs1.rt != rs2.rt) {
480 if (report != REP_QUIET)
481 fprintf(stderr,
482 "%s: Images '%s' and '%s' have different pixel ordering\n",
483 progname, f1name, f2name);
484 return(0);
485 }
486 if ((rs1.xr != rs2.xr) | (rs1.yr != rs2.yr)) {
487 if (report != REP_QUIET)
488 fprintf(stderr,
489 "%s: Images '%s' and '%s' are different sizes\n",
490 progname, f1name, f2name);
491 return(0);
492 }
493 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
494 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
495 if (!scan1 | !scan2) {
496 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
497 exit(2);
498 }
499 for (y = 0; y < numscans(&rs1); y++) {
500 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
501 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
502 if (report != REP_QUIET)
503 fprintf(stderr, "%s: Unexpected end-of-file\n",
504 progname);
505 free(scan1);
506 free(scan2);
507 return(0);
508 }
509 for (x = scanlen(&rs1); x--; ) {
510 if (real_check(colval(scan1[x],RED),
511 colval(scan2[x],RED)) &
512 real_check(colval(scan1[x],GRN),
513 colval(scan2[x],GRN)) &
514 real_check(colval(scan1[x],BLU),
515 colval(scan2[x],BLU)))
516 continue;
517 if (report != REP_QUIET) {
518 fprintf(stderr,
519 "%s: pixels at scanline %d offset %d differ\n",
520 progname, y, x);
521 if (report >= REP_VERBOSE) {
522 fprintf(stderr, "%s: (R,G,B)=(%g,%g,%g)\n",
523 f1name, colval(scan1[x],RED),
524 colval(scan1[x],GRN),
525 colval(scan1[x],BLU));
526 fprintf(stderr, "%s: (R,G,B)=(%g,%g,%g)\n",
527 f2name, colval(scan2[x],RED),
528 colval(scan2[x],GRN),
529 colval(scan2[x],BLU));
530 }
531 }
532 free(scan1);
533 free(scan2);
534 return(0);
535 }
536 }
537 free(scan1);
538 free(scan2);
539 return(good_RMS()); /* final check of RMS */
540 }
541
542 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
543 "th","st","nd","rd","th","th","th","th","th","th"
544 };
545
546 /* Compare two inputs that are known to be 32-bit floating-point data */
547 static int
548 compare_float()
549 {
550 long nread = 0;
551 float f1, f2;
552
553 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
554 if (!getbinary(&f2, sizeof(f2), 1, f2in))
555 goto badeof;
556 ++nread;
557 if (real_check(f1, f2))
558 continue;
559 if (report != REP_QUIET)
560 fprintf(stderr, "%s: %ld%s float values differ\n",
561 progname, nread, nsuffix[nread%10]);
562 return(0);
563 }
564 if (!getbinary(&f2, sizeof(f2), 1, f2in))
565 return(good_RMS()); /* final check of RMS */
566 badeof:
567 if (report != REP_QUIET)
568 fprintf(stderr, "%s: Unexpected end-of-file\n", progname);
569 return(0);
570 }
571
572 /* Compare two inputs that are known to be 64-bit floating-point data */
573 static int
574 compare_double()
575 {
576 long nread = 0;
577 double f1, f2;
578
579 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
580 if (!getbinary(&f2, sizeof(f2), 1, f2in))
581 goto badeof;
582 ++nread;
583 if (real_check(f1, f2))
584 continue;
585 if (report != REP_QUIET)
586 fprintf(stderr, "%s: %ld%s float values differ\n",
587 progname, nread, nsuffix[nread%10]);
588 return(0);
589 }
590 if (!getbinary(&f2, sizeof(f2), 1, f2in))
591 return(good_RMS()); /* final check of RMS */
592 badeof:
593 if (report != REP_QUIET)
594 fprintf(stderr, "%s: Unexpected end-of-file\n", progname);
595 return(0);
596 }
597
598 /* Compare two Radiance files for equivalence */
599 int
600 main(int argc, char *argv[])
601 {
602 int typ1, typ2;
603 int a;
604
605 progname = argv[0];
606 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
607 switch (argv[a][1]) {
608 case 'h': /* ignore header info. */
609 ign_header = !ign_header;
610 continue;
611 case 's': /* silent operation */
612 report = REP_QUIET;
613 continue;
614 case 'w': /* turn off warnings */
615 if (report > REP_ERROR)
616 report = REP_ERROR;
617 continue;
618 case 'v': /* turn on verbose mode */
619 report = REP_VERBOSE;
620 continue;
621 case 'm': /* maximum epsilon */
622 max_lim = atof(argv[++a]);
623 continue;
624 case 'r':
625 if (argv[a][2] == 'e') /* relative difference */
626 rel_min = atof(argv[++a]);
627 else if (argv[a][2] == 'm') /* RMS limit */
628 rms_lim = atof(argv[++a]);
629 else
630 usage();
631 continue;
632 case '\0': /* first file from stdin */
633 f1in = stdin;
634 f1name = stdin_name;
635 break;
636 default:
637 usage();
638 }
639 break;
640 }
641 if (a != argc-2)
642 usage();
643 if (!f1name) f1name = argv[a];
644 if (!f2name) f2name = argv[a+1];
645
646 if (!strcmp(f1name, f2name)) { /* inputs are same? */
647 if (report >= REP_WARN)
648 fprintf(stderr, "%s: warning - identical inputs given\n",
649 progname);
650 return(0);
651 }
652 /* open inputs */
653 SET_FILE_BINARY(stdin); /* in case we're using it */
654 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
655 fprintf(stderr, "%s: cannot open for reading\n", f1name);
656 return(1);
657 }
658 if (!strcmp(f2name, "-")) {
659 f2in = stdin;
660 f2name = stdin_name;
661 } else if (!(f2in = fopen(f2name, "rb"))) {
662 fprintf(stderr, "%s: cannot open for reading\n", f2name);
663 return(1);
664 }
665 /* load headers */
666 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
667 return(1);
668 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
669 return(1);
670 if (typ1 != typ2) {
671 if (report != REP_QUIET)
672 fprintf(stderr, "%s: '%s' is %s and '%s' is %s\n",
673 progname, f1name, file_type[typ1],
674 f2name, file_type[typ2]);
675 return(1);
676 }
677 ign_header |= !has_header(typ1); /* check headers if indicated */
678 if (!ign_header && !headers_match(&hdr1, &hdr2))
679 return(1);
680 lu_done(&hdr1); lu_done(&hdr2);
681 if (!ign_header & (report >= REP_WARN)) {
682 if (typ1 == TYP_UNKNOWN)
683 fprintf(stderr, "%s: warning - unrecognized format, comparing as binary\n",
684 progname);
685 if (lin1cnt != lin2cnt)
686 fprintf(stderr, "%s: warning - headers are different lengths\n",
687 progname);
688 }
689 if (report >= REP_VERBOSE)
690 fprintf(stderr, "%s: input file type is %s\n",
691 progname, file_type[typ1]);
692
693 switch (typ1) { /* compare based on type */
694 case TYP_BINARY:
695 case TYP_TMESH:
696 case TYP_OCTREE:
697 case TYP_RBFMESH:
698 case TYP_UNKNOWN:
699 return( !compare_binary() );
700 case TYP_TEXT:
701 case TYP_ASCII:
702 return( !compare_text() );
703 case TYP_RGBE:
704 case TYP_XYZE:
705 return( !compare_hdr() );
706 case TYP_FLOAT:
707 return( !compare_float() );
708 case TYP_DOUBLE:
709 return( !compare_double() );
710 }
711 return(1);
712 }
