--- ray/src/util/radcompare.c 2023/03/08 19:59:48 2.32 +++ ray/src/util/radcompare.c 2023/11/21 19:22:38 2.33 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: radcompare.c,v 2.32 2023/03/08 19:59:48 greg Exp $"; +static const char RCSid[] = "$Id: radcompare.c,v 2.33 2023/11/21 19:22:38 greg Exp $"; #endif /* * Compare Radiance files for significant differences @@ -51,6 +51,7 @@ const char *file_type[] = { "ascii", COLRFMT, CIEFMT, + SPECFMT, DEPTH16FMT, NORMAL32FMT, "float", @@ -65,7 +66,7 @@ const char *file_type[] = { NULL /* terminator */ }; /* keep consistent with above */ -enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE, +enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE, TYP_SPEC, TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE, TYP_RBFMESH, TYP_OCTREE, TYP_TMESH, TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY}; @@ -244,6 +245,23 @@ color_check(COLOR c1, COLOR c2) return(real_check(colval(c1,p), colval(c2,p))); } +/* Compare two color spectra for equivalence */ +static int +spec_check(COLORV *sc1, COLORV *sc2) +{ + int p, k; + + if (!real_check(scolor_mean(sc1), scolor_mean(sc2))) + return(0); + + p = 0; /* find max. component */ + for (k = NCSAMP; --k; ) + if (sc1[k] > sc1[p]) + p = k; + + return(real_check(sc1[p], sc2[p])); +} + /* Compare two normal directions for equivalence */ static int norm_check(FVECT nv1, FVECT nv2) @@ -650,6 +668,24 @@ compare_text() return(good_RMS()); /* final check for reals */ } +/* Set resolution based on NROWS, NCOLS in header */ +static int +set_resolu(RESOLU *rs, LUTAB *htp) +{ + const char *val; + + rs->rt = PIXSTANDARD; + val = (const char *)lu_find(htp, "NROWS")->data; + if (!val) return(0); + rs->yr = atoi(val); + if (rs->yr <= 0) return(-1); + val = (const char *)lu_find(htp, "NCOLS")->data; + if (!val) return(0); + rs->xr = atoi(val); + if (rs->xr <= 0) return(-1); + return(1); +} + /* Check image/map resolutions */ static int check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p) @@ -707,8 +743,7 @@ compare_hdr() if (color_check(scan1[x], scan2[x])) continue; if (report != REP_QUIET) { - printf( - "%s: pixels at scanline %d offset %d differ\n", + printf("%s: pixels at scanline %d offset %d differ\n", progname, y, x); if (report >= REP_VERBOSE) { printf("%s: (R,G,B)=(%g,%g,%g)\n", @@ -731,6 +766,82 @@ compare_hdr() return(good_RMS()); /* final check of RMS */ } +/* Compare two inputs that are known to be spectral images */ +static int +compare_spec() +{ + static char NCstr[] = NCOMPSTR; + RESOLU rs1, rs2; + COLORV *scan1, *scan2; + const char *val; + int x, y; + + if (report >= REP_VERBOSE) { + fputs(progname, stdout); + fputs(": comparing inputs as spectral images\n", stdout); + } + if (!(set_resolu(&rs1, &hdr1) || fgetsresolu(&rs1, f1in))) + return(0); + if (!(set_resolu(&rs2, &hdr2) || fgetsresolu(&rs2, f2in))) + return(0); + if (!check_resolu("Spectral image", &rs1, &rs2)) + return(0); + NCstr[LNCOMPSTR-1] = '\0'; + val = (const char *)lu_find(&hdr1, NCstr)->data; + if (!val || (NCSAMP = atoi(val)) < 3) { + if (report != REP_QUIET) { + if (val) + printf("%s: illegal # components (%d) for spectral image\n", + progname, NCSAMP); + else + printf("%s: missing %s in header for spectral image\n", + progname, NCstr); + } + return(0); + } + scan1 = (COLORV *)malloc(sizeof(COLORV)*NCSAMP*scanlen(&rs1)); + scan2 = (COLORV *)malloc(sizeof(COLORV)*NCSAMP*scanlen(&rs2)); + if (!scan1 | !scan2) { + fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname); + exit(2); + } + for (y = 0; y < numscans(&rs1); y++) { + if ((freadsscan(scan1, NCSAMP, scanlen(&rs1), f1in) < 0) | + (freadsscan(scan2, NCSAMP, scanlen(&rs2), f2in) < 0)) { + if (report != REP_QUIET) + printf("%s: unexpected end-of-file\n", progname); + free(scan1); + free(scan2); + return(0); + } + for (x = 0; x < scanlen(&rs1); x++) { + if (spec_check(scan1+x*NCSAMP, scan2+x*NCSAMP)) + continue; + if (report != REP_QUIET) { + int k; + printf("%s: spectra at scanline %d offset %d differ\n", + progname, y, x); + if (report >= REP_VERBOSE) { + printf("%s: spectrum =", f1name); + for (k = 0; k < NCSAMP; k++) + printf(" %g", scan1[x*NCSAMP+k]); + fputc('\n', stdout); + printf("%s: spectrum =", f2name); + for (k = 0; k < NCSAMP; k++) + printf(" %g", scan2[x*NCSAMP+k]); + fputc('\n', stdout); + } + } + free(scan1); + free(scan2); + return(0); + } + } + free(scan1); + free(scan2); + return(good_RMS()); /* final check of RMS */ +} + /* Set reference depth based on header variable */ static int set_refdepth(DEPTHCODEC *dcp, LUTAB *htp) @@ -1044,6 +1155,8 @@ main(int argc, char *argv[]) case TYP_RGBE: case TYP_XYZE: return( !compare_hdr() ); + case TYP_SPEC: + return( !compare_spec() ); case TYP_DEPTH: return( !compare_depth() ); case TYP_NORM:
