--- ray/src/util/radcompare.c 2019/08/14 18:20:02 2.20 +++ ray/src/util/radcompare.c 2020/07/09 17:29:04 2.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: radcompare.c,v 2.20 2019/08/14 18:20:02 greg Exp $"; +static const char RCSid[] = "$Id: radcompare.c,v 2.25 2020/07/09 17:29:04 greg Exp $"; #endif /* * Compare Radiance files for significant differences @@ -224,12 +224,12 @@ color_check(COLOR c1, COLOR c2) static int norm_check(FVECT nv1, FVECT nv2) { - double max2 = nv1[2]*nv1[2]; + double max2 = nv1[2]*nv2[2]; int imax = 2; int i = 2; /* identify largest component */ while (i--) { - double tm2 = nv1[i]*nv1[i]; + double tm2 = nv1[i]*nv2[i]; if (tm2 > max2) { imax = i; max2 = tm2; @@ -317,6 +317,7 @@ equiv_string(char *s1, char *s2) static int setheadvar(char *val, void *p) { + char newval[128]; LUTAB *htp = (LUTAB *)p; LUENT *tep; char *key; @@ -359,8 +360,13 @@ setheadvar(char *val, void *p) return(-1); /* memory allocation error */ if (!tep->key) tep->key = strcpy(malloc(kln+1), key); - if (tep->data) + if (tep->data) { /* check for special cases */ + if (!strcmp(key, "EXPOSURE")) { + sprintf(newval, "%f", atof(tep->data)*atof(val)); + vln = strlen(val = newval); + } free(tep->data); + } tep->data = strcpy(malloc(vln+1), val); return(1); } @@ -469,7 +475,6 @@ identify_type(const char *name, FILE *fin, LUTAB *htp) } if (c) return(TYP_BINARY); - SET_FILE_TEXT(fin); /* originally set to binary */ return(TYP_TEXT); badeof: if (report != REP_QUIET) { @@ -554,6 +559,8 @@ compare_text() fputs(progname, stdout); fputs(": comparing inputs as ASCII text\n", stdout); } + SET_FILE_TEXT(f1in); /* originally set to binary */ + SET_FILE_TEXT(f2in); init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */ while (read_line(&l1buf, f1in)) { lin1cnt++; @@ -696,7 +703,7 @@ set_refdepth(DEPTHCODEC *dcp, LUTAB *htp) static char depthvar[] = DEPTHSTR; const char *drval; - depthvar[LDEPTHSTR] = '\0'; + depthvar[LDEPTHSTR-1] = '\0'; drval = (const char *)lu_find(htp, depthvar)->data; if (!drval) return(0); @@ -953,7 +960,7 @@ main(int argc, char *argv[]) return(2); if (typ1 != typ2) { if (report != REP_QUIET) - printf("%s: '%s' is %s and '%s' is %s\n", + printf("%s: '%s' format is %s and '%s' is %s\n", progname, f1name, file_type[typ1], f2name, file_type[typ2]); return(1); @@ -969,10 +976,17 @@ main(int argc, char *argv[]) printf("%s: warning - unrecognized format\n", progname); } - if (report >= REP_VERBOSE) - printf("%s: input file type is %s\n", - progname, file_type[typ1]); - + if (report >= REP_VERBOSE) { + printf("%s: data format is %s\n", progname, file_type[typ1]); + if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) { + if (f1swap) + printf("%s: input '%s' is byte-swapped\n", + progname, f1name); + if (f2swap) + printf("%s: input '%s' is byte-swapped\n", + progname, f2name); + } + } switch (typ1) { /* compare based on type */ case TYP_BINARY: case TYP_TMESH:
