root/radiance/ray/src/util/radcompare.c
Revision: 2.32
Committed: Wed Mar 8 19:59:48 2023 UTC (15 months, 1 week ago) by greg
Changes since 2.31: +7 -4 lines
feat: made it so line number in ASCII file is not repeated if the same
2 static const char RCSid[] = "$Id: radcompare.c,v 2.31 2022/05/27 17:27:53 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 int escape_newlines = 0; /* allow backslash to skip newlines */
31
32 double rel_min = 1e-5; /* positive for relative comparisons */
33
34 double rms_lim = 0.01; /* RMS difference limit */
35
36 double max_lim = 0.25; /* difference limit if non-negative */
37
38 int lin1cnt=0, lin2cnt=0; /* file line position */
39
40 int comment_c = '\0'; /* comment delimiter for text files */
41
42 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
43 "th","st","nd","rd","th","th","th","th","th","th"
44 };
45 #define num_sfx(n) nsuffix[(n)%10]
46
47 /* file types */
48 const char *file_type[] = {
49 "Unrecognized",
50 "TEXT_generic",
51 "ascii",
52 COLRFMT,
53 CIEFMT,
54 DEPTH16FMT,
55 NORMAL32FMT,
56 "float",
57 "double",
58 "BSDF_RBFmesh",
59 "Radiance_octree",
60 "Radiance_tmesh",
61 "8-bit_indexed_name",
62 "16-bit_indexed_name",
63 "24-bit_indexed_name",
64 "BINARY_unknown",
65 NULL /* terminator */
66 };
67 /* keep consistent with above */
68 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE,
69 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
70 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
71 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
72
73 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
74
75 /* header variables to always ignore */
76 const char *hdr_ignkey[] = {
77 "SOFTWARE",
78 "CAPDATE",
79 "GMT",
80 "FRAME",
81 NULL /* terminator */
82 };
83 /* header variable settings */
84 LUTAB hdr1 = LU_SINIT(free,free);
85 LUTAB hdr2 = LU_SINIT(free,free);
86
87 /* advance appropriate file line count */
88 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
89 lin2cnt += (htp == &hdr2))
90
91 typedef struct { /* dynamic line buffer */
92 char *str;
93 int len;
94 int siz;
95 } LINEBUF;
96
97 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
98 /* 100 MByte limit on line buffer */
99 #define MAXBUF (100L<<20)
100
101 /* input files */
102 char *progname = NULL;
103 const char stdin_name[] = "<stdin>";
104 const char *f1name=NULL, *f2name=NULL;
105 FILE *f1in=NULL, *f2in=NULL;
106 int f1swap=0, f2swap=0;
107
108 /* running real differences */
109 double diff2sum = 0;
110 long nsum = 0;
111
112 /* Report usage and exit */
113 static void
114 usage()
115 {
116 fputs("Usage: ", stderr);
117 fputs(progname, stderr);
118 fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
119 stderr);
120 exit(2);
121 }
122
123 /* Read a text line, increasing buffer size as necessary */
124 static int
125 read_line(LINEBUF *bp, FILE *fp)
126 {
127 static int doneWarn = 0;
128
129 bp->len = 0;
130 if (!bp->str) {
131 bp->str = (char *)malloc(bp->siz = 512);
132 if (!bp->str)
133 goto memerr;
134 }
135 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
136 bp->len += strlen(bp->str + bp->len);
137 if (bp->str[bp->len-1] == '\n') {
138 if (bp->len > 1 && bp->str[bp->len-2] == '\r') {
139 bp->str[--bp->len] = '\0';
140 bp->str[bp->len-1] = '\n';
141 }
142 if (escape_newlines && bp->len > 1 &&
143 bp->str[bp->len-2] == '\\') {
144 bp->str[--bp->len] = '\0';
145 bp->str[bp->len-1] = ' ';
146 continue;
147 }
148 break; /* found EOL */
149 }
150 if (bp->len < bp->siz - 4)
151 continue; /* at EOF? */
152 if (bp->siz >= MAXBUF) {
153 if ((report >= REP_WARN) & !doneWarn) {
154 fprintf(stderr,
155 "%s: warning - input line(s) past %ld MByte limit\n",
156 progname, MAXBUF>>20);
157 doneWarn++;
158 }
159 break; /* return MAXBUF partial line */
160 }
161 if ((bp->siz += bp->siz/2) > MAXBUF)
162 bp->siz = MAXBUF;
163 bp->str = (char *)realloc(bp->str, bp->siz);
164 if (!bp->str)
165 goto memerr;
166 }
167 if (comment_c) { /* elide comment? */
168 char *cp = sskip2(bp->str,0);
169 if (*cp == comment_c) {
170 *cp++ = '\n';
171 *cp = '\0';
172 bp->len = cp - bp->str;
173 }
174 }
175 return(bp->len);
176 memerr:
177 fprintf(stderr,
178 "%s: out of memory in read_line() allocating %d byte buffer\n",
179 progname, bp->siz);
180 exit(2);
181 }
182
183 /* Free line buffer */
184 static void
185 free_line(LINEBUF *bp)
186 {
187 if (bp->str) free(bp->str);
188 init_line(bp);
189 }
190
191 /* Get type ID from name (or 0 if not found) */
192 static int
193 xlate_type(const char *nm)
194 {
195 int i;
196
197 if (!nm || !*nm)
198 return(TYP_UNKNOWN);
199 for (i = 1; file_type[i]; i++)
200 if (!strcmp(nm, file_type[i]))
201 return(i);
202 return(TYP_UNKNOWN);
203 }
204
205 /* Compare real values and keep track of differences */
206 static int
207 real_check(double r1, double r2)
208 {
209 double diff2 = (r1 - r2)*(r1 - r2);
210
211 if (rel_min > 0) { /* doing relative differences? */
212 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
213 if (av2 < rel_min*rel_min)
214 av2 = rel_min*rel_min;
215 diff2 /= av2;
216 }
217 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
218 if (report != REP_QUIET)
219 printf(
220 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
221 progname,
222 (rel_min > 0) ? "relative " : "",
223 r1, r2, max_lim);
224 return(0);
225 }
226 diff2sum += diff2;
227 nsum++;
228 return(1);
229 }
230
231 /* Compare two color values for equivalence */
232 static int
233 color_check(COLOR c1, COLOR c2)
234 {
235 int p;
236
237 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
238 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
239 return(0);
240
241 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
242 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
243
244 return(real_check(colval(c1,p), colval(c2,p)));
245 }
246
247 /* Compare two normal directions for equivalence */
248 static int
249 norm_check(FVECT nv1, FVECT nv2)
250 {
251 double max2 = nv1[2]*nv2[2];
252 int imax = 2;
253 int i = 2;
254 /* identify largest component */
255 while (i--) {
256 double tm2 = nv1[i]*nv2[i];
257 if (tm2 > max2) {
258 imax = i;
259 max2 = tm2;
260 }
261 }
262 i = 3; /* compare smaller components */
263 while (i--) {
264 if (i == imax)
265 continue;
266 if (!real_check(nv1[i], nv2[i]))
267 return(0);
268 }
269 return(1);
270 }
271
272 /* Compare two strings for equivalence */
273 static int
274 equiv_string(char *s1, char *s2)
275 {
276 #define CLS_STR 0
277 #define CLS_INT 1
278 #define CLS_FLT 2
279 /* skip whitespace at beginning */
280 while (isspace(*s1)) s1++;
281 while (isspace(*s2)) s2++;
282 while (*s1) { /* check each word */
283 int inquote;
284 if (!*s2) /* unexpected EOL in s2? */
285 return(0);
286 inquote = *s1;
287 if ((inquote != '\'') & (inquote != '"'))
288 inquote = 0;
289 if (inquote) { /* quoted text must match exactly */
290 if (*s1++ != *s2++)
291 return(0);
292 while (*s1 != inquote) {
293 if (!*s1)
294 return(0);
295 if (*s1++ != *s2++)
296 return(0);
297 }
298 s1++;
299 if (*s2++ != inquote)
300 return(0);
301 } else { /* else classify word type */
302 char *s1s = s1;
303 char *s2s = s2;
304 int cls = CLS_STR;
305 s1 = sskip(s1);
306 s2 = sskip(s2);
307 if (iskip(s1s) == s1) {
308 if (iskip(s2s) == s2)
309 cls = CLS_INT;
310 else if (fskip(s2s) == s2)
311 cls = CLS_FLT;
312 } else if (fskip(s1s) == s1) {
313 if (fskip(s2s) != s2)
314 return(0);
315 cls = CLS_FLT;
316 }
317 switch (cls) {
318 case CLS_INT: /* strncmp() faster */
319 case CLS_STR:
320 if (s1 - s1s != s2 - s2s)
321 return(0);
322 if (strncmp(s1s, s2s, s1 - s1s))
323 return(0);
324 break;
325 case CLS_FLT:
326 if (!real_check(atof(s1s), atof(s2s)))
327 return(0);
328 break;
329 }
330 }
331 while (isspace(*s1)) s1++;
332 while (isspace(*s2)) s2++;
333 }
334 return(!*s2); /* match if we reached the end of s2, too */
335 #undef CLS_STR
336 #undef CLS_INT
337 #undef CLS_FLT
338 }
339
340 /* Check if string is var=value pair and set if not in ignore list */
341 static int
342 setheadvar(char *val, void *p)
343 {
344 char newval[128];
345 LUTAB *htp = (LUTAB *)p;
346 LUENT *tep;
347 char *key;
348 int kln, vln;
349 int n;
350
351 adv_linecnt(htp); /* side-effect is to count lines */
352 if (!isalpha(*val)) /* key must start line */
353 return(0);
354 /* check if we need to swap binary data */
355 if ((n = isbigendian(val)) >= 0) {
356 if (nativebigendian() == n)
357 return(0);
358 f1swap += (htp == &hdr1);
359 f2swap += (htp == &hdr2);
360 return(0);
361 }
362 key = val++;
363 while (*val && !isspace(*val) & (*val != '='))
364 val++;
365 kln = val - key;
366 while (isspace(*val)) /* check for value */
367 *val++ = '\0';
368 if (*val != '=')
369 return(0);
370 *val++ = '\0';
371 while (isspace(*val))
372 val++;
373 if (!*val) /* nothing set? */
374 return(0);
375 /* check if key to ignore */
376 for (n = 0; hdr_ignkey[n]; n++)
377 if (!strcmp(key, hdr_ignkey[n]))
378 return(0);
379 vln = strlen(val); /* eliminate space and newline at end */
380 while (isspace(val[--vln]))
381 ;
382 val[++vln] = '\0';
383 if (!(tep = lu_find(htp, key)))
384 return(-1); /* memory allocation error */
385 if (!tep->key)
386 tep->key = strcpy(malloc(kln+1), key);
387 if (tep->data) { /* check for special cases */
388 if (!strcmp(key, "EXPOSURE")) {
389 sprintf(newval, "%.6e", atof(tep->data)*atof(val));
390 vln = strlen(val = newval);
391 }
392 free(tep->data);
393 }
394 tep->data = strcpy(malloc(vln+1), val);
395 return(1);
396 }
397
398 /* Lookup correspondent in other header */
399 static int
400 match_val(const LUENT *ep1, void *p2)
401 {
402 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
403 if (!ep2 || !ep2->data) {
404 if (report != REP_QUIET)
405 printf("%s: variable '%s' missing in '%s'\n",
406 progname, ep1->key, f2name);
407 return(-1);
408 }
409 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
410 if (report != REP_QUIET) {
411 printf("%s: header variable '%s' has different values\n",
412 progname, ep1->key);
413 if (report >= REP_VERBOSE) {
414 printf("%s: %s=%s\n", f1name,
415 ep1->key, (char *)ep1->data);
416 printf("%s: %s=%s\n", f2name,
417 ep2->key, (char *)ep2->data);
418 }
419 }
420 return(-1);
421 }
422 return(1); /* good match */
423 }
424
425 /* Compare two sets of header variables */
426 static int
427 headers_match()
428 {
429 int ne = lu_doall(&hdr1, match_val, &hdr2);
430 if (ne < 0)
431 return(0); /* something didn't match! */
432 /* non-fatal if second header has extra */
433 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
434 printf("%s: warning - '%s' has %d extra header setting(s)\n",
435 progname, f2name, ne);
436 return(1); /* good match */
437 }
438
439 /* Check generic input to determine if it is binary, -1 on error */
440 static int
441 input_is_binary(FILE *fin)
442 {
443 int n = 0;
444 int c = 0;
445
446 while ((c = getc(fin)) != EOF) {
447 ++n;
448 if (!c | (c > 127))
449 break; /* non-ascii character */
450 if (n >= 10240)
451 break; /* enough to be confident */
452 }
453 if (!n)
454 return(-1); /* first read failed */
455 if (fseek(fin, 0L, 0) < 0)
456 return(-1); /* rewind failed */
457 return(!c | (c > 127));
458 }
459
460 /* Identify and return data type from header (if one) */
461 static int
462 identify_type(const char *name, FILE *fin, LUTAB *htp)
463 {
464 extern const char HDRSTR[];
465 int c;
466 /* check magic header start */
467 if ((c = getc(fin)) != HDRSTR[0]) {
468 if (c == EOF) goto badeof;
469 ungetc(c, fin);
470 c = 0;
471 } else if ((c = getc(fin)) != HDRSTR[1]) {
472 if (c == EOF) goto badeof;
473 ungetc(c, fin); ungetc(HDRSTR[0], fin);
474 c = 0;
475 }
476 if (c) { /* appears to have a header */
477 char sbuf[32];
478 if (!fgets(sbuf, sizeof(sbuf), fin))
479 goto badeof;
480 adv_linecnt(htp); /* for #?ID string */
481 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
482 fputs(name, stdout);
483 fputs(": warning - unexpected header ID: ", stdout);
484 fputs(sbuf, stdout);
485 }
486 if (getheader(fin, setheadvar, htp) < 0) {
487 fputs(name, stderr);
488 fputs(": unknown error reading header\n", stderr);
489 return(-1);
490 }
491 adv_linecnt(htp); /* for trailing emtpy line */
492 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
493 }
494 c = input_is_binary(fin); /* else peek to see if binary */
495 if (c < 0) {
496 fputs(name, stderr);
497 fputs(": read/seek error\n", stderr);
498 return(-1);
499 }
500 if (c)
501 return(TYP_BINARY);
502 return(TYP_TEXT);
503 badeof:
504 if (report != REP_QUIET) {
505 fputs(name, stdout);
506 fputs(": unexpected end-of-file\n", stdout);
507 }
508 return(-1);
509 }
510
511 /* Check that overall RMS error is below threshold */
512 static int
513 good_RMS()
514 {
515 if (!nsum)
516 return(1);
517 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
518 if (report != REP_QUIET)
519 printf(
520 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
521 progname,
522 (rel_min > 0) ? "relative " : "",
523 f1name, f2name,
524 sqrt(diff2sum/(double)nsum), rms_lim);
525 return(0);
526 }
527 if (report >= REP_VERBOSE)
528 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
529 progname, (rel_min > 0) ? "relative " : "",
530 f1name, f2name, sqrt(diff2sum/(double)nsum));
531 return(1);
532 }
533
534 /* Compare two inputs as generic binary files */
535 static int
536 compare_binary()
537 {
538 int c1=0, c2=0;
539
540 if (report >= REP_VERBOSE) {
541 fputs(progname, stdout);
542 fputs(": comparing inputs as binary\n", stdout);
543 }
544 for ( ; ; ) { /* exact byte matching */
545 c1 = getc(f1in);
546 c2 = getc(f2in);
547 if (c1 == EOF) {
548 if (c2 == EOF)
549 return(1); /* success! */
550 if (report != REP_QUIET) {
551 fputs(f1name, stdout);
552 fputs(": unexpected end-of-file\n", stdout);
553 }
554 return(0);
555 }
556 if (c2 == EOF) {
557 if (report != REP_QUIET) {
558 fputs(f2name, stdout);
559 fputs(": unexpected end-of-file\n", stdout);
560 }
561 return(0);
562 }
563 if (c1 != c2)
564 break; /* quit and report difference */
565 }
566 if (report == REP_QUIET)
567 return(0);
568 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
569 progname, f1name, f2name, ftell(f1in), ftell(f2in));
570 if (report >= REP_VERBOSE)
571 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
572 progname, f1name, c1, f2name, c2);
573 return(0);
574 }
575
576 /* Compare two inputs as generic text files */
577 static int
578 compare_text()
579 {
580 LINEBUF l1buf, l2buf;
581
582 if (report >= REP_VERBOSE) {
583 fputs(progname, stdout);
584 fputs(": comparing inputs as ASCII text", stdout);
585 if (escape_newlines)
586 fputs(", allowing escaped newlines", stdout);
587 if (comment_c) {
588 fputs(", ignoring comments starting with '", stdout);
589 fputc(comment_c, stdout);
590 fputc('\'', stdout);
591 }
592 fputc('\n', stdout);
593 }
594 SET_FILE_TEXT(f1in); /* originally set to binary */
595 SET_FILE_TEXT(f2in);
596 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
597 while (read_line(&l1buf, f1in)) {
598 lin1cnt++;
599 if (!*sskip2(l1buf.str,0))
600 continue; /* ignore empty lines */
601
602 while (read_line(&l2buf, f2in)) {
603 lin2cnt++;
604 if (*sskip2(l2buf.str,0))
605 break; /* found other non-empty line */
606 }
607 if (!l2buf.len) { /* input 2 EOF? */
608 if (report != REP_QUIET) {
609 fputs(f2name, stdout);
610 fputs(": unexpected end-of-file\n", stdout);
611 }
612 free_line(&l1buf); free_line(&l2buf);
613 return(0);
614 }
615 /* compare non-empty lines */
616 if (!equiv_string(l1buf.str, l2buf.str)) {
617 if (report != REP_QUIET) {
618 printf("%s: inputs '%s' and '%s' differ at line %d",
619 progname, f1name, f2name, lin1cnt);
620 if (lin1cnt != lin2cnt)
621 printf("|%d\n", lin2cnt);
622 else
623 putchar('\n');
624 if ( report >= REP_VERBOSE &&
625 (l1buf.len < 256) &
626 (l2buf.len < 256) ) {
627 fputs("------------- Mismatch -------------\n", stdout);
628 printf("%s@%d:\t%s", f1name,
629 lin1cnt, l1buf.str);
630 printf("%s@%d:\t%s", f2name,
631 lin2cnt, l2buf.str);
632 }
633 }
634 free_line(&l1buf); free_line(&l2buf);
635 return(0);
636 }
637 }
638 free_line(&l1buf); /* check for EOF on input 2 */
639 while (read_line(&l2buf, f2in)) {
640 if (!*sskip2(l2buf.str,0))
641 continue;
642 if (report != REP_QUIET) {
643 fputs(f1name, stdout);
644 fputs(": unexpected end-of-file\n", stdout);
645 }
646 free_line(&l2buf);
647 return(0);
648 }
649 free_line(&l2buf);
650 return(good_RMS()); /* final check for reals */
651 }
652
653 /* Check image/map resolutions */
654 static int
655 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
656 {
657 if (r1p->rt != r2p->rt) {
658 if (report != REP_QUIET)
659 printf(
660 "%s: %ss '%s' and '%s' have different pixel ordering\n",
661 progname, class, f1name, f2name);
662 return(0);
663 }
664 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
665 if (report != REP_QUIET)
666 printf(
667 "%s: %ss '%s' and '%s' are different sizes\n",
668 progname, class, f1name, f2name);
669 return(0);
670 }
671 return(1);
672 }
673
674 /* Compare two inputs that are known to be RGBE or XYZE images */
675 static int
676 compare_hdr()
677 {
678 RESOLU rs1, rs2;
679 COLOR *scan1, *scan2;
680 int x, y;
681
682 if (report >= REP_VERBOSE) {
683 fputs(progname, stdout);
684 fputs(": comparing inputs as HDR images\n", stdout);
685 }
686 fgetsresolu(&rs1, f1in);
687 fgetsresolu(&rs2, f2in);
688 if (!check_resolu("HDR image", &rs1, &rs2))
689 return(0);
690 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
691 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
692 if (!scan1 | !scan2) {
693 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
694 exit(2);
695 }
696 for (y = 0; y < numscans(&rs1); y++) {
697 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
698 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
699 if (report != REP_QUIET)
700 printf("%s: unexpected end-of-file\n",
701 progname);
702 free(scan1);
703 free(scan2);
704 return(0);
705 }
706 for (x = 0; x < scanlen(&rs1); x++) {
707 if (color_check(scan1[x], scan2[x]))
708 continue;
709 if (report != REP_QUIET) {
710 printf(
711 "%s: pixels at scanline %d offset %d differ\n",
712 progname, y, x);
713 if (report >= REP_VERBOSE) {
714 printf("%s: (R,G,B)=(%g,%g,%g)\n",
715 f1name, colval(scan1[x],RED),
716 colval(scan1[x],GRN),
717 colval(scan1[x],BLU));
718 printf("%s: (R,G,B)=(%g,%g,%g)\n",
719 f2name, colval(scan2[x],RED),
720 colval(scan2[x],GRN),
721 colval(scan2[x],BLU));
722 }
723 }
724 free(scan1);
725 free(scan2);
726 return(0);
727 }
728 }
729 free(scan1);
730 free(scan2);
731 return(good_RMS()); /* final check of RMS */
732 }
733
734 /* Set reference depth based on header variable */
735 static int
736 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
737 {
738 static char depthvar[] = DEPTHSTR;
739 const char *drval;
740
741 depthvar[LDEPTHSTR-1] = '\0';
742 drval = (const char *)lu_find(htp, depthvar)->data;
743 if (!drval)
744 return(0);
745 dcp->refdepth = atof(drval);
746 if (dcp->refdepth <= 0) {
747 if (report != REP_QUIET) {
748 fputs(dcp->inpname, stderr);
749 fputs(": bad reference depth '", stderr);
750 fputs(drval, stderr);
751 fputs("'\n", stderr);
752 }
753 return(-1);
754 }
755 return(1);
756 }
757
758 /* Compare two encoded depth maps */
759 static int
760 compare_depth()
761 {
762 long nread = 0;
763 DEPTHCODEC dc1, dc2;
764
765 if (report >= REP_VERBOSE) {
766 fputs(progname, stdout);
767 fputs(": comparing inputs as depth maps\n", stdout);
768 }
769 set_dc_defaults(&dc1);
770 dc1.hdrflags = HF_RESIN;
771 dc1.finp = f1in;
772 dc1.inpname = f1name;
773 set_dc_defaults(&dc2);
774 dc2.hdrflags = HF_RESIN;
775 dc2.finp = f2in;
776 dc2.inpname = f2name;
777 if (report != REP_QUIET) {
778 dc1.hdrflags |= HF_STDERR;
779 dc2.hdrflags |= HF_STDERR;
780 }
781 if (!process_dc_header(&dc1, 0, NULL))
782 return(0);
783 if (!process_dc_header(&dc2, 0, NULL))
784 return(0);
785 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
786 return(0);
787 if (set_refdepth(&dc1, &hdr1) < 0)
788 return(0);
789 if (set_refdepth(&dc2, &hdr2) < 0)
790 return(0);
791 while (nread < dc1.res.xr*dc1.res.yr) {
792 double d1 = decode_depth_next(&dc1);
793 double d2 = decode_depth_next(&dc2);
794 if ((d1 < 0) | (d2 < 0)) {
795 if (report != REP_QUIET)
796 printf("%s: unexpected end-of-file\n",
797 progname);
798 return(0);
799 }
800 ++nread;
801 if (real_check(d1, d2))
802 continue;
803 if (report != REP_QUIET)
804 printf("%s: %ld%s depth values differ\n",
805 progname, nread, num_sfx(nread));
806 return(0);
807 }
808 return(good_RMS()); /* final check of RMS */
809 }
810
811 /* Compare two encoded normal maps */
812 static int
813 compare_norm()
814 {
815 long nread = 0;
816 NORMCODEC nc1, nc2;
817
818 if (report >= REP_VERBOSE) {
819 fputs(progname, stdout);
820 fputs(": comparing inputs as normal maps\n", stdout);
821 }
822 set_nc_defaults(&nc1);
823 nc1.hdrflags = HF_RESIN;
824 nc1.finp = f1in;
825 nc1.inpname = f1name;
826 set_nc_defaults(&nc2);
827 nc2.hdrflags = HF_RESIN;
828 nc2.finp = f2in;
829 nc2.inpname = f2name;
830 if (report != REP_QUIET) {
831 nc1.hdrflags |= HF_STDERR;
832 nc2.hdrflags |= HF_STDERR;
833 }
834 if (!process_nc_header(&nc1, 0, NULL))
835 return(0);
836 if (!process_nc_header(&nc2, 0, NULL))
837 return(0);
838 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
839 return(0);
840 while (nread < nc1.res.xr*nc1.res.yr) {
841 FVECT nv1, nv2;
842 int rv1 = decode_normal_next(nv1, &nc1);
843 int rv2 = decode_normal_next(nv2, &nc2);
844 if ((rv1 < 0) | (rv2 < 0)) {
845 if (report != REP_QUIET)
846 printf("%s: unexpected end-of-file\n",
847 progname);
848 return(0);
849 }
850 ++nread;
851 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
852 continue;
853 if (report != REP_QUIET)
854 printf("%s: %ld%s normal vectors differ\n",
855 progname, nread, num_sfx(nread));
856 return(0);
857 }
858 return(good_RMS()); /* final check of RMS */
859 }
860
861 /* Compare two inputs that are known to be 32-bit floating-point data */
862 static int
863 compare_float()
864 {
865 long nread = 0;
866 float f1, f2;
867
868 if (report >= REP_VERBOSE) {
869 fputs(progname, stdout);
870 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
871 }
872 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
873 if (!getbinary(&f2, sizeof(f2), 1, f2in))
874 goto badeof;
875 ++nread;
876 if (f1swap) swap32((char *)&f1, 1);
877 if (f2swap) swap32((char *)&f2, 1);
878 if (real_check(f1, f2))
879 continue;
880 if (report != REP_QUIET)
881 printf("%s: %ld%s float values differ\n",
882 progname, nread, num_sfx(nread));
883 return(0);
884 }
885 if (!getbinary(&f2, sizeof(f2), 1, f2in))
886 return(good_RMS()); /* final check of RMS */
887 badeof:
888 if (report != REP_QUIET)
889 printf("%s: unexpected end-of-file\n", progname);
890 return(0);
891 }
892
893 /* Compare two inputs that are known to be 64-bit floating-point data */
894 static int
895 compare_double()
896 {
897 long nread = 0;
898 double f1, f2;
899
900 if (report >= REP_VERBOSE) {
901 fputs(progname, stdout);
902 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
903 }
904 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
905 if (!getbinary(&f2, sizeof(f2), 1, f2in))
906 goto badeof;
907 ++nread;
908 if (f1swap) swap64((char *)&f1, 1);
909 if (f2swap) swap64((char *)&f2, 1);
910 if (real_check(f1, f2))
911 continue;
912 if (report != REP_QUIET)
913 printf("%s: %ld%s double values differ\n",
914 progname, nread, num_sfx(nread));
915 return(0);
916 }
917 if (!getbinary(&f2, sizeof(f2), 1, f2in))
918 return(good_RMS()); /* final check of RMS */
919 badeof:
920 if (report != REP_QUIET)
921 printf("%s: unexpected end-of-file\n", progname);
922 return(0);
923 }
924
925 /* Compare two Radiance files for equivalence */
926 int
927 main(int argc, char *argv[])
928 {
929 int typ1, typ2;
930 int a;
931
932 progname = argv[0];
933 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
934 switch (argv[a][1]) {
935 case 'h': /* ignore header info. */
936 ign_header = !ign_header;
937 continue;
938 case 'n': /* allow newline escapes */
939 escape_newlines = !escape_newlines;
940 continue;
941 case 'c': /* ignore comments */
942 comment_c = argv[a][2];
943 continue;
944 case 's': /* silent operation */
945 report = REP_QUIET;
946 continue;
947 case 'w': /* turn off warnings */
948 if (report > REP_ERROR)
949 report = REP_ERROR;
950 continue;
951 case 'v': /* turn on verbose mode */
952 report = REP_VERBOSE;
953 continue;
954 case 'm': /* maximum epsilon */
955 max_lim = atof(argv[++a]);
956 continue;
957 case 'r':
958 if (argv[a][2] == 'e') /* relative difference */
959 rel_min = atof(argv[++a]);
960 else if (argv[a][2] == 'm') /* RMS limit */
961 rms_lim = atof(argv[++a]);
962 else
963 usage();
964 continue;
965 case '\0': /* first file from stdin */
966 f1in = stdin;
967 f1name = stdin_name;
968 break;
969 default:
970 usage();
971 }
972 break;
973 }
974 if (a != argc-2) /* make sure of two inputs */
975 usage();
976 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
977 if (report >= REP_WARN)
978 printf("%s: warning - identical inputs given\n",
979 progname);
980 return(0);
981 }
982 if (!f1name) f1name = argv[a];
983 if (!f2name) f2name = argv[a+1];
984 /* open inputs */
985 SET_FILE_BINARY(stdin); /* in case we're using it */
986 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
987 fprintf(stderr, "%s: cannot open for reading\n", f1name);
988 return(2);
989 }
990 if (!strcmp(f2name, "-")) {
991 f2in = stdin;
992 f2name = stdin_name;
993 } else if (!(f2in = fopen(f2name, "rb"))) {
994 fprintf(stderr, "%s: cannot open for reading\n", f2name);
995 return(2);
996 }
997 /* load headers */
998 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
999 return(2);
1000 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
1001 return(2);
1002 if (typ1 != typ2) {
1003 if (report != REP_QUIET)
1004 printf("%s: '%s' format is %s and '%s' is %s\n",
1005 progname, f1name, file_type[typ1],
1006 f2name, file_type[typ2]);
1007 return(1);
1008 }
1009 ign_header |= !has_header(typ1); /* check headers if indicated */
1010 if (!ign_header && !headers_match())
1011 return(1);
1012 if (!ign_header & (report >= REP_WARN)) {
1013 if (lin1cnt != lin2cnt)
1014 printf("%s: warning - headers are different lengths\n",
1015 progname);
1016 if (typ1 == TYP_UNKNOWN)
1017 printf("%s: warning - unrecognized format\n",
1018 progname);
1019 }
1020 if (report >= REP_VERBOSE) {
1021 printf("%s: data format is %s\n", progname, file_type[typ1]);
1022 if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
1023 if (f1swap)
1024 printf("%s: input '%s' is byte-swapped\n",
1025 progname, f1name);
1026 if (f2swap)
1027 printf("%s: input '%s' is byte-swapped\n",
1028 progname, f2name);
1029 }
1030 }
1031 switch (typ1) { /* compare based on type */
1032 case TYP_BINARY:
1033 case TYP_TMESH:
1034 case TYP_OCTREE:
1035 case TYP_RBFMESH:
1036 case TYP_ID8:
1037 case TYP_ID16:
1038 case TYP_ID24:
1039 case TYP_UNKNOWN:
1040 return( !compare_binary() );
1041 case TYP_TEXT:
1042 case TYP_ASCII:
1043 return( !compare_text() );
1044 case TYP_RGBE:
1045 case TYP_XYZE:
1046 return( !compare_hdr() );
1047 case TYP_DEPTH:
1048 return( !compare_depth() );
1049 case TYP_NORM:
1050 return( !compare_norm() );
1051 case TYP_FLOAT:
1052 return( !compare_float() );
1053 case TYP_DOUBLE:
1054 return( !compare_double() );
1055 }
1056 return(1);
1057 }
