root/radiance/ray/src/util/radcompare.c
Revision: 2.33
Committed: Tue Nov 21 19:22:38 2023 UTC (6 months, 1 week ago) by greg
Changes since 2.32: +117 -4 lines
feat(radcompare): Added ability to compare spectral images (untested)
2 static const char RCSid[] = "$Id: radcompare.c,v 2.32 2023/03/08 19:59:48 greg Exp $";
5 * Compare Radiance files for significant differences
6 *
7 * G. Ward
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtmath.h"
13 #include "platform.h"
14 #include "rtio.h"
15 #include "resolu.h"
16 #include "color.h"
17 #include "depthcodec.h"
18 #include "normcodec.h"
19 #include "lookup.h"
20 /* Reporting levels */
21 #define REP_QUIET 0 /* no reporting */
22 #define REP_ERROR 1 /* report errors only */
23 #define REP_WARN 2 /* report warnings as well */
24 #define REP_VERBOSE 3 /* verbose reporting */
25
26 int report = REP_WARN; /* reporting level */
27
28 int ign_header = 0; /* ignore header differences? */
29
30 int escape_newlines = 0; /* allow backslash to skip newlines */
31
32 double rel_min = 1e-5; /* positive for relative comparisons */
33
34 double rms_lim = 0.01; /* RMS difference limit */
35
36 double max_lim = 0.25; /* difference limit if non-negative */
37
38 int lin1cnt=0, lin2cnt=0; /* file line position */
39
40 int comment_c = '\0'; /* comment delimiter for text files */
41
42 const char nsuffix[10][3] = { /* 1st, 2nd, 3rd, etc. */
43 "th","st","nd","rd","th","th","th","th","th","th"
44 };
45 #define num_sfx(n) nsuffix[(n)%10]
46
47 /* file types */
48 const char *file_type[] = {
49 "Unrecognized",
50 "TEXT_generic",
51 "ascii",
52 COLRFMT,
53 CIEFMT,
54 SPECFMT,
55 DEPTH16FMT,
56 NORMAL32FMT,
57 "float",
58 "double",
59 "BSDF_RBFmesh",
60 "Radiance_octree",
61 "Radiance_tmesh",
62 "8-bit_indexed_name",
63 "16-bit_indexed_name",
64 "24-bit_indexed_name",
65 "BINARY_unknown",
66 NULL /* terminator */
67 };
68 /* keep consistent with above */
69 enum {TYP_UNKNOWN, TYP_TEXT, TYP_ASCII, TYP_RGBE, TYP_XYZE, TYP_SPEC,
70 TYP_DEPTH, TYP_NORM, TYP_FLOAT, TYP_DOUBLE,
71 TYP_RBFMESH, TYP_OCTREE, TYP_TMESH,
72 TYP_ID8, TYP_ID16, TYP_ID24, TYP_BINARY};
73
74 #define has_header(t) (!( 1L<<(t) & (1L<<TYP_TEXT | 1L<<TYP_BINARY) ))
75
76 /* header variables to always ignore */
77 const char *hdr_ignkey[] = {
78 "SOFTWARE",
79 "CAPDATE",
80 "GMT",
81 "FRAME",
82 NULL /* terminator */
83 };
84 /* header variable settings */
85 LUTAB hdr1 = LU_SINIT(free,free);
86 LUTAB hdr2 = LU_SINIT(free,free);
87
88 /* advance appropriate file line count */
89 #define adv_linecnt(htp) (lin1cnt += (htp == &hdr1), \
90 lin2cnt += (htp == &hdr2))
91
92 typedef struct { /* dynamic line buffer */
93 char *str;
94 int len;
95 int siz;
96 } LINEBUF;
97
98 #define init_line(bp) ((bp)->str = NULL, (bp)->siz = 0)
99 /* 100 MByte limit on line buffer */
100 #define MAXBUF (100L<<20)
101
102 /* input files */
103 char *progname = NULL;
104 const char stdin_name[] = "<stdin>";
105 const char *f1name=NULL, *f2name=NULL;
106 FILE *f1in=NULL, *f2in=NULL;
107 int f1swap=0, f2swap=0;
108
109 /* running real differences */
110 double diff2sum = 0;
111 long nsum = 0;
112
113 /* Report usage and exit */
114 static void
115 usage()
116 {
117 fputs("Usage: ", stderr);
118 fputs(progname, stderr);
119 fputs(" [-h][-c#][-s|-w|-v][-rel min_test][-rms epsilon][-max epsilon] reference test\n",
120 stderr);
121 exit(2);
122 }
123
124 /* Read a text line, increasing buffer size as necessary */
125 static int
126 read_line(LINEBUF *bp, FILE *fp)
127 {
128 static int doneWarn = 0;
129
130 bp->len = 0;
131 if (!bp->str) {
132 bp->str = (char *)malloc(bp->siz = 512);
133 if (!bp->str)
134 goto memerr;
135 }
136 while (fgets(bp->str + bp->len, bp->siz - bp->len, fp)) {
137 bp->len += strlen(bp->str + bp->len);
138 if (bp->str[bp->len-1] == '\n') {
139 if (bp->len > 1 && bp->str[bp->len-2] == '\r') {
140 bp->str[--bp->len] = '\0';
141 bp->str[bp->len-1] = '\n';
142 }
143 if (escape_newlines && bp->len > 1 &&
144 bp->str[bp->len-2] == '\\') {
145 bp->str[--bp->len] = '\0';
146 bp->str[bp->len-1] = ' ';
147 continue;
148 }
149 break; /* found EOL */
150 }
151 if (bp->len < bp->siz - 4)
152 continue; /* at EOF? */
153 if (bp->siz >= MAXBUF) {
154 if ((report >= REP_WARN) & !doneWarn) {
155 fprintf(stderr,
156 "%s: warning - input line(s) past %ld MByte limit\n",
157 progname, MAXBUF>>20);
158 doneWarn++;
159 }
160 break; /* return MAXBUF partial line */
161 }
162 if ((bp->siz += bp->siz/2) > MAXBUF)
163 bp->siz = MAXBUF;
164 bp->str = (char *)realloc(bp->str, bp->siz);
165 if (!bp->str)
166 goto memerr;
167 }
168 if (comment_c) { /* elide comment? */
169 char *cp = sskip2(bp->str,0);
170 if (*cp == comment_c) {
171 *cp++ = '\n';
172 *cp = '\0';
173 bp->len = cp - bp->str;
174 }
175 }
176 return(bp->len);
177 memerr:
178 fprintf(stderr,
179 "%s: out of memory in read_line() allocating %d byte buffer\n",
180 progname, bp->siz);
181 exit(2);
182 }
183
184 /* Free line buffer */
185 static void
186 free_line(LINEBUF *bp)
187 {
188 if (bp->str) free(bp->str);
189 init_line(bp);
190 }
191
192 /* Get type ID from name (or 0 if not found) */
193 static int
194 xlate_type(const char *nm)
195 {
196 int i;
197
198 if (!nm || !*nm)
199 return(TYP_UNKNOWN);
200 for (i = 1; file_type[i]; i++)
201 if (!strcmp(nm, file_type[i]))
202 return(i);
203 return(TYP_UNKNOWN);
204 }
205
206 /* Compare real values and keep track of differences */
207 static int
208 real_check(double r1, double r2)
209 {
210 double diff2 = (r1 - r2)*(r1 - r2);
211
212 if (rel_min > 0) { /* doing relative differences? */
213 double av2 = .25*(r1*r1 + 2.*fabs(r1*r2) + r2*r2);
214 if (av2 < rel_min*rel_min)
215 av2 = rel_min*rel_min;
216 diff2 /= av2;
217 }
218 if (max_lim >= 0 && diff2 > max_lim*max_lim) {
219 if (report != REP_QUIET)
220 printf(
221 "%s: %sdifference between %.8g and %.8g exceeds epsilon of %.8g\n",
222 progname,
223 (rel_min > 0) ? "relative " : "",
224 r1, r2, max_lim);
225 return(0);
226 }
227 diff2sum += diff2;
228 nsum++;
229 return(1);
230 }
231
232 /* Compare two color values for equivalence */
233 static int
234 color_check(COLOR c1, COLOR c2)
235 {
236 int p;
237
238 if (!real_check((colval(c1,RED)+colval(c1,GRN)+colval(c1,BLU))*(1./3.),
239 (colval(c2,RED)+colval(c2,GRN)+colval(c2,BLU))*(1./3.)))
240 return(0);
241
242 p = (colval(c1,GRN) > colval(c1,RED)) ? GRN : RED;
243 if (colval(c1,BLU) > colval(c1,p)) p = BLU;
244
245 return(real_check(colval(c1,p), colval(c2,p)));
246 }
247
248 /* Compare two color spectra for equivalence */
249 static int
250 spec_check(COLORV *sc1, COLORV *sc2)
251 {
252 int p, k;
253
254 if (!real_check(scolor_mean(sc1), scolor_mean(sc2)))
255 return(0);
256
257 p = 0; /* find max. component */
258 for (k = NCSAMP; --k; )
259 if (sc1[k] > sc1[p])
260 p = k;
261
262 return(real_check(sc1[p], sc2[p]));
263 }
264
265 /* Compare two normal directions for equivalence */
266 static int
267 norm_check(FVECT nv1, FVECT nv2)
268 {
269 double max2 = nv1[2]*nv2[2];
270 int imax = 2;
271 int i = 2;
272 /* identify largest component */
273 while (i--) {
274 double tm2 = nv1[i]*nv2[i];
275 if (tm2 > max2) {
276 imax = i;
277 max2 = tm2;
278 }
279 }
280 i = 3; /* compare smaller components */
281 while (i--) {
282 if (i == imax)
283 continue;
284 if (!real_check(nv1[i], nv2[i]))
285 return(0);
286 }
287 return(1);
288 }
289
290 /* Compare two strings for equivalence */
291 static int
292 equiv_string(char *s1, char *s2)
293 {
294 #define CLS_STR 0
295 #define CLS_INT 1
296 #define CLS_FLT 2
297 /* skip whitespace at beginning */
298 while (isspace(*s1)) s1++;
299 while (isspace(*s2)) s2++;
300 while (*s1) { /* check each word */
301 int inquote;
302 if (!*s2) /* unexpected EOL in s2? */
303 return(0);
304 inquote = *s1;
305 if ((inquote != '\'') & (inquote != '"'))
306 inquote = 0;
307 if (inquote) { /* quoted text must match exactly */
308 if (*s1++ != *s2++)
309 return(0);
310 while (*s1 != inquote) {
311 if (!*s1)
312 return(0);
313 if (*s1++ != *s2++)
314 return(0);
315 }
316 s1++;
317 if (*s2++ != inquote)
318 return(0);
319 } else { /* else classify word type */
320 char *s1s = s1;
321 char *s2s = s2;
322 int cls = CLS_STR;
323 s1 = sskip(s1);
324 s2 = sskip(s2);
325 if (iskip(s1s) == s1) {
326 if (iskip(s2s) == s2)
327 cls = CLS_INT;
328 else if (fskip(s2s) == s2)
329 cls = CLS_FLT;
330 } else if (fskip(s1s) == s1) {
331 if (fskip(s2s) != s2)
332 return(0);
333 cls = CLS_FLT;
334 }
335 switch (cls) {
336 case CLS_INT: /* strncmp() faster */
337 case CLS_STR:
338 if (s1 - s1s != s2 - s2s)
339 return(0);
340 if (strncmp(s1s, s2s, s1 - s1s))
341 return(0);
342 break;
343 case CLS_FLT:
344 if (!real_check(atof(s1s), atof(s2s)))
345 return(0);
346 break;
347 }
348 }
349 while (isspace(*s1)) s1++;
350 while (isspace(*s2)) s2++;
351 }
352 return(!*s2); /* match if we reached the end of s2, too */
353 #undef CLS_STR
354 #undef CLS_INT
355 #undef CLS_FLT
356 }
357
358 /* Check if string is var=value pair and set if not in ignore list */
359 static int
360 setheadvar(char *val, void *p)
361 {
362 char newval[128];
363 LUTAB *htp = (LUTAB *)p;
364 LUENT *tep;
365 char *key;
366 int kln, vln;
367 int n;
368
369 adv_linecnt(htp); /* side-effect is to count lines */
370 if (!isalpha(*val)) /* key must start line */
371 return(0);
372 /* check if we need to swap binary data */
373 if ((n = isbigendian(val)) >= 0) {
374 if (nativebigendian() == n)
375 return(0);
376 f1swap += (htp == &hdr1);
377 f2swap += (htp == &hdr2);
378 return(0);
379 }
380 key = val++;
381 while (*val && !isspace(*val) & (*val != '='))
382 val++;
383 kln = val - key;
384 while (isspace(*val)) /* check for value */
385 *val++ = '\0';
386 if (*val != '=')
387 return(0);
388 *val++ = '\0';
389 while (isspace(*val))
390 val++;
391 if (!*val) /* nothing set? */
392 return(0);
393 /* check if key to ignore */
394 for (n = 0; hdr_ignkey[n]; n++)
395 if (!strcmp(key, hdr_ignkey[n]))
396 return(0);
397 vln = strlen(val); /* eliminate space and newline at end */
398 while (isspace(val[--vln]))
399 ;
400 val[++vln] = '\0';
401 if (!(tep = lu_find(htp, key)))
402 return(-1); /* memory allocation error */
403 if (!tep->key)
404 tep->key = strcpy(malloc(kln+1), key);
405 if (tep->data) { /* check for special cases */
406 if (!strcmp(key, "EXPOSURE")) {
407 sprintf(newval, "%.6e", atof(tep->data)*atof(val));
408 vln = strlen(val = newval);
409 }
410 free(tep->data);
411 }
412 tep->data = strcpy(malloc(vln+1), val);
413 return(1);
414 }
415
416 /* Lookup correspondent in other header */
417 static int
418 match_val(const LUENT *ep1, void *p2)
419 {
420 const LUENT *ep2 = lu_find((LUTAB *)p2, ep1->key);
421 if (!ep2 || !ep2->data) {
422 if (report != REP_QUIET)
423 printf("%s: variable '%s' missing in '%s'\n",
424 progname, ep1->key, f2name);
425 return(-1);
426 }
427 if (!equiv_string((char *)ep1->data, (char *)ep2->data)) {
428 if (report != REP_QUIET) {
429 printf("%s: header variable '%s' has different values\n",
430 progname, ep1->key);
431 if (report >= REP_VERBOSE) {
432 printf("%s: %s=%s\n", f1name,
433 ep1->key, (char *)ep1->data);
434 printf("%s: %s=%s\n", f2name,
435 ep2->key, (char *)ep2->data);
436 }
437 }
438 return(-1);
439 }
440 return(1); /* good match */
441 }
442
443 /* Compare two sets of header variables */
444 static int
445 headers_match()
446 {
447 int ne = lu_doall(&hdr1, match_val, &hdr2);
448 if (ne < 0)
449 return(0); /* something didn't match! */
450 /* non-fatal if second header has extra */
451 if (report >= REP_WARN && (ne = lu_doall(&hdr2, NULL, NULL) - ne))
452 printf("%s: warning - '%s' has %d extra header setting(s)\n",
453 progname, f2name, ne);
454 return(1); /* good match */
455 }
456
457 /* Check generic input to determine if it is binary, -1 on error */
458 static int
459 input_is_binary(FILE *fin)
460 {
461 int n = 0;
462 int c = 0;
463
464 while ((c = getc(fin)) != EOF) {
465 ++n;
466 if (!c | (c > 127))
467 break; /* non-ascii character */
468 if (n >= 10240)
469 break; /* enough to be confident */
470 }
471 if (!n)
472 return(-1); /* first read failed */
473 if (fseek(fin, 0L, 0) < 0)
474 return(-1); /* rewind failed */
475 return(!c | (c > 127));
476 }
477
478 /* Identify and return data type from header (if one) */
479 static int
480 identify_type(const char *name, FILE *fin, LUTAB *htp)
481 {
482 extern const char HDRSTR[];
483 int c;
484 /* check magic header start */
485 if ((c = getc(fin)) != HDRSTR[0]) {
486 if (c == EOF) goto badeof;
487 ungetc(c, fin);
488 c = 0;
489 } else if ((c = getc(fin)) != HDRSTR[1]) {
490 if (c == EOF) goto badeof;
491 ungetc(c, fin); ungetc(HDRSTR[0], fin);
492 c = 0;
493 }
494 if (c) { /* appears to have a header */
495 char sbuf[32];
496 if (!fgets(sbuf, sizeof(sbuf), fin))
497 goto badeof;
498 adv_linecnt(htp); /* for #?ID string */
499 if (report >= REP_WARN && strncmp(sbuf, "RADIANCE", 8)) {
500 fputs(name, stdout);
501 fputs(": warning - unexpected header ID: ", stdout);
502 fputs(sbuf, stdout);
503 }
504 if (getheader(fin, setheadvar, htp) < 0) {
505 fputs(name, stderr);
506 fputs(": unknown error reading header\n", stderr);
507 return(-1);
508 }
509 adv_linecnt(htp); /* for trailing emtpy line */
510 return(xlate_type((const char *)lu_find(htp,"FORMAT")->data));
511 }
512 c = input_is_binary(fin); /* else peek to see if binary */
513 if (c < 0) {
514 fputs(name, stderr);
515 fputs(": read/seek error\n", stderr);
516 return(-1);
517 }
518 if (c)
519 return(TYP_BINARY);
520 return(TYP_TEXT);
521 badeof:
522 if (report != REP_QUIET) {
523 fputs(name, stdout);
524 fputs(": unexpected end-of-file\n", stdout);
525 }
526 return(-1);
527 }
528
529 /* Check that overall RMS error is below threshold */
530 static int
531 good_RMS()
532 {
533 if (!nsum)
534 return(1);
535 if (diff2sum/(double)nsum > rms_lim*rms_lim) {
536 if (report != REP_QUIET)
537 printf(
538 "%s: %sRMS difference between '%s' and '%s' of %.5g exceeds limit of %.5g\n",
539 progname,
540 (rel_min > 0) ? "relative " : "",
541 f1name, f2name,
542 sqrt(diff2sum/(double)nsum), rms_lim);
543 return(0);
544 }
545 if (report >= REP_VERBOSE)
546 printf("%s: %sRMS difference of reals in '%s' and '%s' is %.5g\n",
547 progname, (rel_min > 0) ? "relative " : "",
548 f1name, f2name, sqrt(diff2sum/(double)nsum));
549 return(1);
550 }
551
552 /* Compare two inputs as generic binary files */
553 static int
554 compare_binary()
555 {
556 int c1=0, c2=0;
557
558 if (report >= REP_VERBOSE) {
559 fputs(progname, stdout);
560 fputs(": comparing inputs as binary\n", stdout);
561 }
562 for ( ; ; ) { /* exact byte matching */
563 c1 = getc(f1in);
564 c2 = getc(f2in);
565 if (c1 == EOF) {
566 if (c2 == EOF)
567 return(1); /* success! */
568 if (report != REP_QUIET) {
569 fputs(f1name, stdout);
570 fputs(": unexpected end-of-file\n", stdout);
571 }
572 return(0);
573 }
574 if (c2 == EOF) {
575 if (report != REP_QUIET) {
576 fputs(f2name, stdout);
577 fputs(": unexpected end-of-file\n", stdout);
578 }
579 return(0);
580 }
581 if (c1 != c2)
582 break; /* quit and report difference */
583 }
584 if (report == REP_QUIET)
585 return(0);
586 printf("%s: binary files '%s' and '%s' differ at byte offset %ld|%ld\n",
587 progname, f1name, f2name, ftell(f1in), ftell(f2in));
588 if (report >= REP_VERBOSE)
589 printf("%s: byte in '%s' is 0x%X, byte in '%s' is 0x%X\n",
590 progname, f1name, c1, f2name, c2);
591 return(0);
592 }
593
594 /* Compare two inputs as generic text files */
595 static int
596 compare_text()
597 {
598 LINEBUF l1buf, l2buf;
599
600 if (report >= REP_VERBOSE) {
601 fputs(progname, stdout);
602 fputs(": comparing inputs as ASCII text", stdout);
603 if (escape_newlines)
604 fputs(", allowing escaped newlines", stdout);
605 if (comment_c) {
606 fputs(", ignoring comments starting with '", stdout);
607 fputc(comment_c, stdout);
608 fputc('\'', stdout);
609 }
610 fputc('\n', stdout);
611 }
612 SET_FILE_TEXT(f1in); /* originally set to binary */
613 SET_FILE_TEXT(f2in);
614 init_line(&l1buf); init_line(&l2buf); /* compare a line at a time */
615 while (read_line(&l1buf, f1in)) {
616 lin1cnt++;
617 if (!*sskip2(l1buf.str,0))
618 continue; /* ignore empty lines */
619
620 while (read_line(&l2buf, f2in)) {
621 lin2cnt++;
622 if (*sskip2(l2buf.str,0))
623 break; /* found other non-empty line */
624 }
625 if (!l2buf.len) { /* input 2 EOF? */
626 if (report != REP_QUIET) {
627 fputs(f2name, stdout);
628 fputs(": unexpected end-of-file\n", stdout);
629 }
630 free_line(&l1buf); free_line(&l2buf);
631 return(0);
632 }
633 /* compare non-empty lines */
634 if (!equiv_string(l1buf.str, l2buf.str)) {
635 if (report != REP_QUIET) {
636 printf("%s: inputs '%s' and '%s' differ at line %d",
637 progname, f1name, f2name, lin1cnt);
638 if (lin1cnt != lin2cnt)
639 printf("|%d\n", lin2cnt);
640 else
641 putchar('\n');
642 if ( report >= REP_VERBOSE &&
643 (l1buf.len < 256) &
644 (l2buf.len < 256) ) {
645 fputs("------------- Mismatch -------------\n", stdout);
646 printf("%s@%d:\t%s", f1name,
647 lin1cnt, l1buf.str);
648 printf("%s@%d:\t%s", f2name,
649 lin2cnt, l2buf.str);
650 }
651 }
652 free_line(&l1buf); free_line(&l2buf);
653 return(0);
654 }
655 }
656 free_line(&l1buf); /* check for EOF on input 2 */
657 while (read_line(&l2buf, f2in)) {
658 if (!*sskip2(l2buf.str,0))
659 continue;
660 if (report != REP_QUIET) {
661 fputs(f1name, stdout);
662 fputs(": unexpected end-of-file\n", stdout);
663 }
664 free_line(&l2buf);
665 return(0);
666 }
667 free_line(&l2buf);
668 return(good_RMS()); /* final check for reals */
669 }
670
671 /* Set resolution based on NROWS, NCOLS in header */
672 static int
673 set_resolu(RESOLU *rs, LUTAB *htp)
674 {
675 const char *val;
676
677 rs->rt = PIXSTANDARD;
678 val = (const char *)lu_find(htp, "NROWS")->data;
679 if (!val) return(0);
680 rs->yr = atoi(val);
681 if (rs->yr <= 0) return(-1);
682 val = (const char *)lu_find(htp, "NCOLS")->data;
683 if (!val) return(0);
684 rs->xr = atoi(val);
685 if (rs->xr <= 0) return(-1);
686 return(1);
687 }
688
689 /* Check image/map resolutions */
690 static int
691 check_resolu(const char *class, RESOLU *r1p, RESOLU *r2p)
692 {
693 if (r1p->rt != r2p->rt) {
694 if (report != REP_QUIET)
695 printf(
696 "%s: %ss '%s' and '%s' have different pixel ordering\n",
697 progname, class, f1name, f2name);
698 return(0);
699 }
700 if ((r1p->xr != r2p->xr) | (r1p->yr != r2p->yr)) {
701 if (report != REP_QUIET)
702 printf(
703 "%s: %ss '%s' and '%s' are different sizes\n",
704 progname, class, f1name, f2name);
705 return(0);
706 }
707 return(1);
708 }
709
710 /* Compare two inputs that are known to be RGBE or XYZE images */
711 static int
712 compare_hdr()
713 {
714 RESOLU rs1, rs2;
715 COLOR *scan1, *scan2;
716 int x, y;
717
718 if (report >= REP_VERBOSE) {
719 fputs(progname, stdout);
720 fputs(": comparing inputs as HDR images\n", stdout);
721 }
722 fgetsresolu(&rs1, f1in);
723 fgetsresolu(&rs2, f2in);
724 if (!check_resolu("HDR image", &rs1, &rs2))
725 return(0);
726 scan1 = (COLOR *)malloc(scanlen(&rs1)*sizeof(COLOR));
727 scan2 = (COLOR *)malloc(scanlen(&rs2)*sizeof(COLOR));
728 if (!scan1 | !scan2) {
729 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
730 exit(2);
731 }
732 for (y = 0; y < numscans(&rs1); y++) {
733 if ((freadscan(scan1, scanlen(&rs1), f1in) < 0) |
734 (freadscan(scan2, scanlen(&rs2), f2in) < 0)) {
735 if (report != REP_QUIET)
736 printf("%s: unexpected end-of-file\n",
737 progname);
738 free(scan1);
739 free(scan2);
740 return(0);
741 }
742 for (x = 0; x < scanlen(&rs1); x++) {
743 if (color_check(scan1[x], scan2[x]))
744 continue;
745 if (report != REP_QUIET) {
746 printf("%s: pixels at scanline %d offset %d differ\n",
747 progname, y, x);
748 if (report >= REP_VERBOSE) {
749 printf("%s: (R,G,B)=(%g,%g,%g)\n",
750 f1name, colval(scan1[x],RED),
751 colval(scan1[x],GRN),
752 colval(scan1[x],BLU));
753 printf("%s: (R,G,B)=(%g,%g,%g)\n",
754 f2name, colval(scan2[x],RED),
755 colval(scan2[x],GRN),
756 colval(scan2[x],BLU));
757 }
758 }
759 free(scan1);
760 free(scan2);
761 return(0);
762 }
763 }
764 free(scan1);
765 free(scan2);
766 return(good_RMS()); /* final check of RMS */
767 }
768
769 /* Compare two inputs that are known to be spectral images */
770 static int
771 compare_spec()
772 {
773 static char NCstr[] = NCOMPSTR;
774 RESOLU rs1, rs2;
775 COLORV *scan1, *scan2;
776 const char *val;
777 int x, y;
778
779 if (report >= REP_VERBOSE) {
780 fputs(progname, stdout);
781 fputs(": comparing inputs as spectral images\n", stdout);
782 }
783 if (!(set_resolu(&rs1, &hdr1) || fgetsresolu(&rs1, f1in)))
784 return(0);
785 if (!(set_resolu(&rs2, &hdr2) || fgetsresolu(&rs2, f2in)))
786 return(0);
787 if (!check_resolu("Spectral image", &rs1, &rs2))
788 return(0);
789 NCstr[LNCOMPSTR-1] = '\0';
790 val = (const char *)lu_find(&hdr1, NCstr)->data;
791 if (!val || (NCSAMP = atoi(val)) < 3) {
792 if (report != REP_QUIET) {
793 if (val)
794 printf("%s: illegal # components (%d) for spectral image\n",
795 progname, NCSAMP);
796 else
797 printf("%s: missing %s in header for spectral image\n",
798 progname, NCstr);
799 }
800 return(0);
801 }
802 scan1 = (COLORV *)malloc(sizeof(COLORV)*NCSAMP*scanlen(&rs1));
803 scan2 = (COLORV *)malloc(sizeof(COLORV)*NCSAMP*scanlen(&rs2));
804 if (!scan1 | !scan2) {
805 fprintf(stderr, "%s: out of memory in compare_hdr()\n", progname);
806 exit(2);
807 }
808 for (y = 0; y < numscans(&rs1); y++) {
809 if ((freadsscan(scan1, NCSAMP, scanlen(&rs1), f1in) < 0) |
810 (freadsscan(scan2, NCSAMP, scanlen(&rs2), f2in) < 0)) {
811 if (report != REP_QUIET)
812 printf("%s: unexpected end-of-file\n", progname);
813 free(scan1);
814 free(scan2);
815 return(0);
816 }
817 for (x = 0; x < scanlen(&rs1); x++) {
818 if (spec_check(scan1+x*NCSAMP, scan2+x*NCSAMP))
819 continue;
820 if (report != REP_QUIET) {
821 int k;
822 printf("%s: spectra at scanline %d offset %d differ\n",
823 progname, y, x);
824 if (report >= REP_VERBOSE) {
825 printf("%s: spectrum =", f1name);
826 for (k = 0; k < NCSAMP; k++)
827 printf(" %g", scan1[x*NCSAMP+k]);
828 fputc('\n', stdout);
829 printf("%s: spectrum =", f2name);
830 for (k = 0; k < NCSAMP; k++)
831 printf(" %g", scan2[x*NCSAMP+k]);
832 fputc('\n', stdout);
833 }
834 }
835 free(scan1);
836 free(scan2);
837 return(0);
838 }
839 }
840 free(scan1);
841 free(scan2);
842 return(good_RMS()); /* final check of RMS */
843 }
844
845 /* Set reference depth based on header variable */
846 static int
847 set_refdepth(DEPTHCODEC *dcp, LUTAB *htp)
848 {
849 static char depthvar[] = DEPTHSTR;
850 const char *drval;
851
852 depthvar[LDEPTHSTR-1] = '\0';
853 drval = (const char *)lu_find(htp, depthvar)->data;
854 if (!drval)
855 return(0);
856 dcp->refdepth = atof(drval);
857 if (dcp->refdepth <= 0) {
858 if (report != REP_QUIET) {
859 fputs(dcp->inpname, stderr);
860 fputs(": bad reference depth '", stderr);
861 fputs(drval, stderr);
862 fputs("'\n", stderr);
863 }
864 return(-1);
865 }
866 return(1);
867 }
868
869 /* Compare two encoded depth maps */
870 static int
871 compare_depth()
872 {
873 long nread = 0;
874 DEPTHCODEC dc1, dc2;
875
876 if (report >= REP_VERBOSE) {
877 fputs(progname, stdout);
878 fputs(": comparing inputs as depth maps\n", stdout);
879 }
880 set_dc_defaults(&dc1);
881 dc1.hdrflags = HF_RESIN;
882 dc1.finp = f1in;
883 dc1.inpname = f1name;
884 set_dc_defaults(&dc2);
885 dc2.hdrflags = HF_RESIN;
886 dc2.finp = f2in;
887 dc2.inpname = f2name;
888 if (report != REP_QUIET) {
889 dc1.hdrflags |= HF_STDERR;
890 dc2.hdrflags |= HF_STDERR;
891 }
892 if (!process_dc_header(&dc1, 0, NULL))
893 return(0);
894 if (!process_dc_header(&dc2, 0, NULL))
895 return(0);
896 if (!check_resolu("Depth map", &dc1.res, &dc2.res))
897 return(0);
898 if (set_refdepth(&dc1, &hdr1) < 0)
899 return(0);
900 if (set_refdepth(&dc2, &hdr2) < 0)
901 return(0);
902 while (nread < dc1.res.xr*dc1.res.yr) {
903 double d1 = decode_depth_next(&dc1);
904 double d2 = decode_depth_next(&dc2);
905 if ((d1 < 0) | (d2 < 0)) {
906 if (report != REP_QUIET)
907 printf("%s: unexpected end-of-file\n",
908 progname);
909 return(0);
910 }
911 ++nread;
912 if (real_check(d1, d2))
913 continue;
914 if (report != REP_QUIET)
915 printf("%s: %ld%s depth values differ\n",
916 progname, nread, num_sfx(nread));
917 return(0);
918 }
919 return(good_RMS()); /* final check of RMS */
920 }
921
922 /* Compare two encoded normal maps */
923 static int
924 compare_norm()
925 {
926 long nread = 0;
927 NORMCODEC nc1, nc2;
928
929 if (report >= REP_VERBOSE) {
930 fputs(progname, stdout);
931 fputs(": comparing inputs as normal maps\n", stdout);
932 }
933 set_nc_defaults(&nc1);
934 nc1.hdrflags = HF_RESIN;
935 nc1.finp = f1in;
936 nc1.inpname = f1name;
937 set_nc_defaults(&nc2);
938 nc2.hdrflags = HF_RESIN;
939 nc2.finp = f2in;
940 nc2.inpname = f2name;
941 if (report != REP_QUIET) {
942 nc1.hdrflags |= HF_STDERR;
943 nc2.hdrflags |= HF_STDERR;
944 }
945 if (!process_nc_header(&nc1, 0, NULL))
946 return(0);
947 if (!process_nc_header(&nc2, 0, NULL))
948 return(0);
949 if (!check_resolu("Normal map", &nc1.res, &nc2.res))
950 return(0);
951 while (nread < nc1.res.xr*nc1.res.yr) {
952 FVECT nv1, nv2;
953 int rv1 = decode_normal_next(nv1, &nc1);
954 int rv2 = decode_normal_next(nv2, &nc2);
955 if ((rv1 < 0) | (rv2 < 0)) {
956 if (report != REP_QUIET)
957 printf("%s: unexpected end-of-file\n",
958 progname);
959 return(0);
960 }
961 ++nread;
962 if (rv1 == rv2 && (!rv1 || norm_check(nv1, nv2)))
963 continue;
964 if (report != REP_QUIET)
965 printf("%s: %ld%s normal vectors differ\n",
966 progname, nread, num_sfx(nread));
967 return(0);
968 }
969 return(good_RMS()); /* final check of RMS */
970 }
971
972 /* Compare two inputs that are known to be 32-bit floating-point data */
973 static int
974 compare_float()
975 {
976 long nread = 0;
977 float f1, f2;
978
979 if (report >= REP_VERBOSE) {
980 fputs(progname, stdout);
981 fputs(": comparing inputs as 32-bit IEEE floats\n", stdout);
982 }
983 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
984 if (!getbinary(&f2, sizeof(f2), 1, f2in))
985 goto badeof;
986 ++nread;
987 if (f1swap) swap32((char *)&f1, 1);
988 if (f2swap) swap32((char *)&f2, 1);
989 if (real_check(f1, f2))
990 continue;
991 if (report != REP_QUIET)
992 printf("%s: %ld%s float values differ\n",
993 progname, nread, num_sfx(nread));
994 return(0);
995 }
996 if (!getbinary(&f2, sizeof(f2), 1, f2in))
997 return(good_RMS()); /* final check of RMS */
998 badeof:
999 if (report != REP_QUIET)
1000 printf("%s: unexpected end-of-file\n", progname);
1001 return(0);
1002 }
1003
1004 /* Compare two inputs that are known to be 64-bit floating-point data */
1005 static int
1006 compare_double()
1007 {
1008 long nread = 0;
1009 double f1, f2;
1010
1011 if (report >= REP_VERBOSE) {
1012 fputs(progname, stdout);
1013 fputs(": comparing inputs as 64-bit IEEE doubles\n", stdout);
1014 }
1015 while (getbinary(&f1, sizeof(f1), 1, f1in)) {
1016 if (!getbinary(&f2, sizeof(f2), 1, f2in))
1017 goto badeof;
1018 ++nread;
1019 if (f1swap) swap64((char *)&f1, 1);
1020 if (f2swap) swap64((char *)&f2, 1);
1021 if (real_check(f1, f2))
1022 continue;
1023 if (report != REP_QUIET)
1024 printf("%s: %ld%s double values differ\n",
1025 progname, nread, num_sfx(nread));
1026 return(0);
1027 }
1028 if (!getbinary(&f2, sizeof(f2), 1, f2in))
1029 return(good_RMS()); /* final check of RMS */
1030 badeof:
1031 if (report != REP_QUIET)
1032 printf("%s: unexpected end-of-file\n", progname);
1033 return(0);
1034 }
1035
1036 /* Compare two Radiance files for equivalence */
1037 int
1038 main(int argc, char *argv[])
1039 {
1040 int typ1, typ2;
1041 int a;
1042
1043 progname = argv[0];
1044 for (a = 1; a < argc && argv[a][0] == '-'; a++) {
1045 switch (argv[a][1]) {
1046 case 'h': /* ignore header info. */
1047 ign_header = !ign_header;
1048 continue;
1049 case 'n': /* allow newline escapes */
1050 escape_newlines = !escape_newlines;
1051 continue;
1052 case 'c': /* ignore comments */
1053 comment_c = argv[a][2];
1054 continue;
1055 case 's': /* silent operation */
1056 report = REP_QUIET;
1057 continue;
1058 case 'w': /* turn off warnings */
1059 if (report > REP_ERROR)
1060 report = REP_ERROR;
1061 continue;
1062 case 'v': /* turn on verbose mode */
1063 report = REP_VERBOSE;
1064 continue;
1065 case 'm': /* maximum epsilon */
1066 max_lim = atof(argv[++a]);
1067 continue;
1068 case 'r':
1069 if (argv[a][2] == 'e') /* relative difference */
1070 rel_min = atof(argv[++a]);
1071 else if (argv[a][2] == 'm') /* RMS limit */
1072 rms_lim = atof(argv[++a]);
1073 else
1074 usage();
1075 continue;
1076 case '\0': /* first file from stdin */
1077 f1in = stdin;
1078 f1name = stdin_name;
1079 break;
1080 default:
1081 usage();
1082 }
1083 break;
1084 }
1085 if (a != argc-2) /* make sure of two inputs */
1086 usage();
1087 if (!strcmp(argv[a], argv[a+1])) { /* inputs are same? */
1088 if (report >= REP_WARN)
1089 printf("%s: warning - identical inputs given\n",
1090 progname);
1091 return(0);
1092 }
1093 if (!f1name) f1name = argv[a];
1094 if (!f2name) f2name = argv[a+1];
1095 /* open inputs */
1096 SET_FILE_BINARY(stdin); /* in case we're using it */
1097 if (!f1in && !(f1in = fopen(f1name, "rb"))) {
1098 fprintf(stderr, "%s: cannot open for reading\n", f1name);
1099 return(2);
1100 }
1101 if (!strcmp(f2name, "-")) {
1102 f2in = stdin;
1103 f2name = stdin_name;
1104 } else if (!(f2in = fopen(f2name, "rb"))) {
1105 fprintf(stderr, "%s: cannot open for reading\n", f2name);
1106 return(2);
1107 }
1108 /* load headers */
1109 if ((typ1 = identify_type(f1name, f1in, &hdr1)) < 0)
1110 return(2);
1111 if ((typ2 = identify_type(f2name, f2in, &hdr2)) < 0)
1112 return(2);
1113 if (typ1 != typ2) {
1114 if (report != REP_QUIET)
1115 printf("%s: '%s' format is %s and '%s' is %s\n",
1116 progname, f1name, file_type[typ1],
1117 f2name, file_type[typ2]);
1118 return(1);
1119 }
1120 ign_header |= !has_header(typ1); /* check headers if indicated */
1121 if (!ign_header && !headers_match())
1122 return(1);
1123 if (!ign_header & (report >= REP_WARN)) {
1124 if (lin1cnt != lin2cnt)
1125 printf("%s: warning - headers are different lengths\n",
1126 progname);
1127 if (typ1 == TYP_UNKNOWN)
1128 printf("%s: warning - unrecognized format\n",
1129 progname);
1130 }
1131 if (report >= REP_VERBOSE) {
1132 printf("%s: data format is %s\n", progname, file_type[typ1]);
1133 if ((typ1 == TYP_FLOAT) | (typ1 == TYP_DOUBLE)) {
1134 if (f1swap)
1135 printf("%s: input '%s' is byte-swapped\n",
1136 progname, f1name);
1137 if (f2swap)
1138 printf("%s: input '%s' is byte-swapped\n",
1139 progname, f2name);
1140 }
1141 }
1142 switch (typ1) { /* compare based on type */
1143 case TYP_BINARY:
1144 case TYP_TMESH:
1145 case TYP_OCTREE:
1146 case TYP_RBFMESH:
1147 case TYP_ID8:
1148 case TYP_ID16:
1149 case TYP_ID24:
1150 case TYP_UNKNOWN:
1151 return( !compare_binary() );
1152 case TYP_TEXT:
1153 case TYP_ASCII:
1154 return( !compare_text() );
1155 case TYP_RGBE:
1156 case TYP_XYZE:
1157 return( !compare_hdr() );
1158 case TYP_SPEC:
1159 return( !compare_spec() );
1160 case TYP_DEPTH:
1161 return( !compare_depth() );
1162 case TYP_NORM:
1163 return( !compare_norm() );
1164 case TYP_FLOAT:
1165 return( !compare_float() );
1166 case TYP_DOUBLE:
1167 return( !compare_double() );
1168 }
1169 return(1);
1170 }
