Fri Aug 26 22:39:56 2011 UTC (12 years, 8 months ago) by greg
Changes since 2.106: +4 -4 lines
Diff to previous 2.106
Minor changes
Wed Aug 24 05:54:42 2011 UTC (12 years, 8 months ago) by greg
Changes since 2.105: +33 -2 lines
Diff to previous 2.105
Added check of incomplete rendering from rpiece
Fri Feb 25 06:51:51 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.104: +4 -4 lines
Diff to previous 2.104
Decreased -lw default
Sat Jan 29 16:44:20 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.103: +20 -17 lines
Diff to previous 2.103
Corrected problem with image size when using rpiece
Sun Oct 10 15:36:18 2010 UTC (13 years, 6 months ago) by greg
Changes since 2.102: +5 -2 lines
Diff to previous 2.102
Need to remove outdated rpiece output
Sun Oct 10 09:25:45 2010 UTC (13 years, 6 months ago) by greg
Changes since 2.101: +11 -4 lines
Diff to previous 2.101
Avoid possible overwrite of previous partial output by rpiece
Sat Oct 9 17:14:01 2010 UTC (13 years, 6 months ago) by greg
Changes since 2.100: +13 -16 lines
Diff to previous 2.100
Changed overture calculation with rpiece to use single process
Fri Oct 8 23:06:53 2010 UTC (13 years, 6 months ago) by greg
Changes since 2.99: +3 -3 lines
Diff to previous 2.99
Increased specular sampling for high quality setting
Fri Oct 8 22:11:57 2010 UTC (13 years, 6 months ago) by greg
Changes since 2.98: +4 -4 lines
Diff to previous 2.98
Changed -sj option to -ss
Sun Sep 12 18:42:40 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.97: +10 -11 lines
Diff to previous 2.97
Minor code clean-up -- should not affect behavior
Fri May 28 17:29:14 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.96: +9 -1 lines
Diff to previous 2.96
Added multi-processing for single-view overture calculation
Tue May 18 18:57:27 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.95: +2 -2 lines
Diff to previous 2.95
Minor fix to last change
Tue May 18 18:54:35 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.94: +6 -2 lines
Diff to previous 2.94
Added echo of writing to sync file for rpiece
Tue May 18 04:24:17 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.93: +8 -12 lines
Diff to previous 2.93
Minor tweaks to last change with -N and rpiece
Tue May 18 00:01:02 2010 UTC (13 years, 11 months ago) by greg
Changes since 2.92: +83 -33 lines
Diff to previous 2.92
Mon Feb 9 16:41:29 2009 UTC (15 years, 2 months ago) by greg
Changes since 2.91: +16 -10 lines
Diff to previous 2.91
Thu Dec 18 23:26:57 2008 UTC (15 years, 4 months ago) by greg
Changes since 2.90: +92 -55 lines
Diff to previous 2.90
Fri Dec 12 15:49:48 2008 UTC (15 years, 4 months ago) by greg
Diff to previous 2.89
Corrected new setting of -dj for PEN=T and QUA=Hi
Sat Dec 6 01:08:53 2008 UTC (15 years, 4 months ago) by greg
Changes since 2.88: +2 -2 lines
Diff to previous 2.88
Fri Dec 5 00:51:59 2008 UTC (15 years, 4 months ago) by greg
Diff to previous 2.87
Fixed resetting of number of processes with view passed to rvu
Mon Nov 10 19:08:19 2008 UTC (15 years, 5 months ago) by greg
Changes since 2.86: +3 -3 lines
Diff to previous 2.86
Thu Aug 21 07:05:59 2008 UTC (15 years, 8 months ago) by greg
Changes since 2.85: +3 -1 lines
Diff to previous 2.85
Mon Apr 21 07:31:30 2008 UTC (16 years ago) by schorsch
Changes since 2.84: +5 -4 lines
Diff to previous 2.84
Scons update for mingw.
Tue Mar 11 12:42:07 2008 UTC (16 years, 1 month ago) by greg
Changes since 2.83: +19 -9 lines
Diff to previous 2.83
Switched to using defined view types
Tue Mar 11 02:21:47 2008 UTC (16 years, 1 month ago) by greg
Diff to previous 2.82
Thu Dec 8 17:06:11 2005 UTC (18 years, 4 months ago) by greg
Changes since 2.81: +5 -7 lines
Diff to previous 2.81
Added some additional (and probably unnecessary) fflush() calls
Mon Sep 12 14:40:13 2005 UTC (18 years, 7 months ago) by schorsch
Changes since 2.80: +5 -5 lines
Diff to previous 2.80
Using RT_PID instead of int.
Sat Oct 23 18:55:53 2004 UTC (19 years, 6 months ago) by schorsch
Diff to previous 2.79
Mon Oct 4 04:42:33 2004 UTC (19 years, 7 months ago) by greg
Diff to previous 2.78
Fri Sep 17 21:43:50 2004 UTC (19 years, 7 months ago) by greg
Diff to previous 2.77
Thu Sep 9 20:08:21 2004 UTC (19 years, 7 months ago) by greg
Diff to previous 2.76
Fri Mar 26 21:36:19 2004 UTC (20 years, 1 month ago) by schorsch
Diff to previous 2.75
Continued ANSIfication.
Diff to previous 2.74
Mon Oct 27 10:32:06 2003 UTC (20 years, 6 months ago) by schorsch
Diff to previous 2.73
Sat Oct 18 04:46:24 2003 UTC (20 years, 6 months ago) by greg
Diff to previous 2.72
Minor comment changes
Diff to previous 2.71
Diff to previous 2.70
Diff to previous 2.69
Mon Jul 14 20:02:30 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 2.68
Thu Jul 3 22:41:45 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.67
Thu Jul 3 18:03:58 2003 UTC (20 years, 10 months ago) by greg
Diff to previous 2.66
Diff to previous 2.65
Diff to previous 2.64
Diff to previous 2.63
Diff to previous 2.62
Fri Mar 21 18:48:46 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.61
Diff to previous 2.60
Tue Feb 2 08:57:56 1999 UTC (25 years, 3 months ago) by gwlarson
Diff to previous 2.59
Tue Jan 19 17:46:13 1999 UTC (25 years, 3 months ago) by gwlarson
Diff to previous 2.58
Mon Oct 19 16:21:41 1998 UTC (25 years, 6 months ago) by gwlarson
Diff to previous 2.57
Wed Jun 10 17:51:06 1998 UTC (25 years, 10 months ago) by gwlarson
Diff to previous 2.56
Wed Jun 3 16:37:51 1998 UTC (25 years, 11 months ago) by gwlarson
Diff to previous 2.55
Fri Jan 23 17:17:32 1998 UTC (26 years, 3 months ago) by gregl
Diff to previous 2.54
Fri Jan 23 15:15:59 1998 UTC (26 years, 3 months ago) by gregl
Diff to previous 2.53
Thu Mar 20 12:50:07 1997 UTC (27 years, 1 month ago) by greg
Diff to previous 2.52
Wed Feb 14 16:34:05 1996 UTC (28 years, 2 months ago) by greg
Diff to previous 2.51
Wed Jan 17 10:22:06 1996 UTC (28 years, 3 months ago) by greg
Diff to previous 2.50
changed parameter to nvalue()
Fri Jan 5 14:43:03 1996 UTC (28 years, 4 months ago) by greg
Diff to previous 2.49
added vflt() macro
Tue Dec 12 15:13:32 1995 UTC (28 years, 4 months ago) by greg
Diff to previous 2.48
Tue Dec 12 13:30:14 1995 UTC (28 years, 4 months ago) by greg
Diff to previous 2.47
Fri Dec 8 19:55:50 1995 UTC (28 years, 5 months ago) by greg
Diff to previous 2.46
Tue Nov 7 18:22:24 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.45
Mon Aug 28 10:12:40 1995 UTC (28 years, 8 months ago) by greg
Diff to previous 2.44
added ZFILE variable to rad
Fri Aug 18 10:39:56 1995 UTC (28 years, 8 months ago) by greg
Diff to previous 2.43
added cylindrical view type
Thu Jul 6 12:15:40 1995 UTC (28 years, 10 months ago) by greg
Diff to previous 2.42
Fri Dec 23 09:20:06 1994 UTC (29 years, 4 months ago) by greg
Diff to previous 2.41
Mon Oct 24 13:49:16 1994 UTC (29 years, 6 months ago) by greg
Diff to previous 2.40
added -t (touch) option
Thu Apr 21 12:22:44 1994 UTC (30 years ago) by greg
Diff to previous 2.39
Thu Mar 24 12:28:22 1994 UTC (30 years, 1 month ago) by greg
Diff to previous 2.38
Sat Jan 1 12:12:32 1994 UTC (30 years, 4 months ago) by greg
Diff to previous 2.37
Sat Jan 1 09:16:50 1994 UTC (30 years, 4 months ago) by greg
Diff to previous 2.36
Thu Dec 30 08:20:45 1993 UTC (30 years, 4 months ago) by greg
Diff to previous 2.35
Tue Nov 23 09:26:38 1993 UTC (30 years, 5 months ago) by greg
Diff to previous 2.34
compatibility fixes
Thu Nov 18 13:28:30 1993 UTC (30 years, 5 months ago) by greg
Diff to previous 2.33
fixed PC bug in time() call
Thu Nov 18 10:00:21 1993 UTC (30 years, 5 months ago) by greg
Diff to previous 2.32
fixed minor compiler warning
Tue Nov 16 11:44:08 1993 UTC (30 years, 5 months ago) by greg
Diff to previous 2.31
Thu Nov 11 13:17:01 1993 UTC (30 years, 5 months ago) by greg
Diff to previous 2.30
Thu Nov 11 10:20:06 1993 UTC (30 years, 5 months ago) by greg
Diff to previous 2.29
Sat Oct 30 10:47:05 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.28
added -pe option to rview
Thu Oct 28 11:48:29 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.27
Sat Sep 25 13:21:35 1993 UTC (30 years, 7 months ago) by greg
Diff to previous 2.26
Fri Sep 24 16:49:02 1993 UTC (30 years, 7 months ago) by greg
Diff to previous 2.25
Wed Sep 15 15:11:47 1993 UTC (30 years, 7 months ago) by greg
Diff to previous 2.24
Thu Sep 9 13:07:13 1993 UTC (30 years, 7 months ago) by greg
Diff to previous 2.23
fixed view echoing for MS-DOS
Tue Sep 7 11:57:04 1993 UTC (30 years, 8 months ago) by greg
Diff to previous 2.22
Wed Aug 25 13:48:37 1993 UTC (30 years, 8 months ago) by greg
Diff to previous 2.21
added -R option to rview
Tue Aug 24 22:14:21 1993 UTC (30 years, 8 months ago) by greg
Diff to previous 2.20
Tue Aug 24 21:44:55 1993 UTC (30 years, 8 months ago) by greg
Diff to previous 2.19
Tue Aug 24 20:29:22 1993 UTC (30 years, 8 months ago) by greg
Diff to previous 2.18
Fri Aug 13 09:19:30 1993 UTC (30 years, 8 months ago) by greg
Diff to previous 2.17
Mon Aug 9 17:50:09 1993 UTC (30 years, 8 months ago) by greg
Diff to previous 2.16
Thu Jul 22 12:39:51 1993 UTC (30 years, 9 months ago) by greg
Diff to previous 2.15
Fri Jul 16 12:41:21 1993 UTC (30 years, 9 months ago) by greg
Diff to previous 2.14
Thu Jul 15 18:32:57 1993 UTC (30 years, 9 months ago) by greg
Diff to previous 2.13
Fri Jul 2 14:50:49 1993 UTC (30 years, 10 months ago) by greg
Diff to previous 2.12
Fri Jun 25 17:35:49 1993 UTC (30 years, 10 months ago) by greg
Mon Jun 14 10:49:08 1993 UTC (30 years, 10 months ago) by greg
Thu May 27 17:41:46 1993 UTC (30 years, 11 months ago) by greg
Wed May 26 11:37:42 1993 UTC (30 years, 11 months ago) by greg
Tue May 18 13:07:56 1993 UTC (30 years, 11 months ago) by greg
Tue Apr 6 17:21:04 1993 UTC (31 years, 1 month ago) by greg
Tue Mar 30 13:16:26 1993 UTC (31 years, 1 month ago) by greg
Sat Mar 13 09:33:17 1993 UTC (31 years, 1 month ago) by greg
Fri Mar 12 13:37:03 1993 UTC (31 years, 1 month ago) by greg
Thu Mar 11 17:23:33 1993 UTC (31 years, 1 month ago) by greg
Thu Mar 11 11:39:48 1993 UTC (31 years, 1 month ago) by greg
Thu Mar 11 09:11:00 1993 UTC (31 years, 1 month ago) by greg
