Revision: 2.6
Committed: Tue Mar 30 13:16:26 1993 UTC (31 years, 2 months ago) by greg
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include <ctype.h>
14
15
16 typedef struct {
17 char *name; /* variable name */
18 short nick; /* # characters required for nickname */
19 short nass; /* # assignments made */
20 char *value; /* assigned value(s) */
21 int (*fixval)(); /* assignment checking function */
22 } VARIABLE;
23
24 int onevalue(), catvalues();
25
26 /* variables */
27 #define OBJECT 0 /* object files */
28 #define SCENE 1 /* scene files */
29 #define MATERIAL 2 /* material files */
30 #define RENDER 3 /* rendering options */
31 #define OCONV 4 /* oconv options */
32 #define PFILT 5 /* pfilt options */
33 #define VIEW 6 /* view(s) for picture(s) */
34 #define ZONE 7 /* simulation zone */
35 #define QUALITY 8 /* desired rendering quality */
36 #define OCTREE 9 /* octree file name */
37 #define PICTURE 10 /* picture file name */
38 #define AMBFILE 11 /* ambient file name */
39 #define OPTFILE 12 /* rendering options file */
40 #define EXPOSURE 13 /* picture exposure setting */
41 #define RESOLUTION 14 /* maximum picture resolution */
42 #define UP 15 /* view up (X, Y or Z) */
43 #define INDIRECT 16 /* indirection in lighting */
44 #define DETAIL 17 /* level of scene detail */
45 #define PENUMBRAS 18 /* shadow penumbras are desired */
46 #define VARIABILITY 19 /* level of light variability */
47 #define REPORT 20 /* report frequency and errfile */
48 /* total number of variables */
49 #define NVARS 21
50
51 VARIABLE vv[NVARS] = { /* variable-value pairs */
52 {"objects", 3, 0, NULL, catvalues},
53 {"scene", 3, 0, NULL, catvalues},
54 {"materials", 3, 0, NULL, catvalues},
55 {"render", 3, 0, NULL, catvalues},
56 {"oconv", 3, 0, NULL, catvalues},
57 {"pfilt", 2, 0, NULL, catvalues},
58 {"view", 2, 0, NULL, NULL},
59 {"ZONE", 2, 0, NULL, onevalue},
60 {"QUALITY", 3, 0, NULL, onevalue},
61 {"OCTREE", 3, 0, NULL, onevalue},
62 {"PICTURE", 3, 0, NULL, onevalue},
63 {"AMBFILE", 3, 0, NULL, onevalue},
64 {"OPTFILE", 3, 0, NULL, onevalue},
65 {"EXPOSURE", 3, 0, NULL, onevalue},
66 {"RESOLUTION", 3, 0, NULL, onevalue},
67 {"UP", 2, 0, NULL, onevalue},
68 {"INDIRECT", 3, 0, NULL, onevalue},
69 {"DETAIL", 3, 0, NULL, onevalue},
70 {"PENUMBRAS", 3, 0, NULL, onevalue},
71 {"VARIABILITY", 3, 0, NULL, onevalue},
72 {"REPORT", 3, 0, NULL, onevalue},
73 };
74
75 VARIABLE *matchvar();
76 char *nvalue();
77 int vscale();
78
79 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
80
81 #define vnam(vc) (vv[vc].name)
82 #define vdef(vc) (vv[vc].nass)
83 #define vval(vc) (vv[vc].value)
84 #define vint(vc) atoi(vval(vc))
85 #define vlet(vc) UPPER(vval(vc)[0])
86 #define vbool(vc) (vlet(vc)=='T')
87
88 #define HIGH 2
89 #define MEDIUM 1
90 #define LOW 0
91
92 int lowqopts(), medqopts(), hiqopts();
93 int (*setqopts[3])() = {lowqopts, medqopts, hiqopts};
94
95 #define renderopts (*setqopts[vscale(QUALITY)])
96
97 /* overture calculation file */
98 #ifdef NIX
99 char overfile[] = "overture.raw";
100 #else
101 char overfile[] = "/dev/null";
102 #endif
103
104 extern long fdate(), time();
105
106 long scenedate; /* date of latest scene or object file */
107 long octreedate; /* date of octree */
108
109 int explicate = 0; /* explicate variables */
110 int silent = 0; /* do work silently */
111 int noaction = 0; /* don't do anything */
112 char *rvdevice = NULL; /* rview output device */
113 char *viewselect = NULL; /* specific view only */
114
115 int overture = 0; /* overture calculation needed */
116
117 char *progname; /* global argv[0] */
118
119 char radname[MAXPATH]; /* root Radiance file name */
120
121
122 main(argc, argv)
123 int argc;
124 char *argv[];
125 {
126 char ropts[512];
127 int i;
128
129 progname = argv[0];
130 /* get options */
131 for (i = 1; i < argc && argv[i][0] == '-'; i++)
132 switch (argv[i][1]) {
133 case 's':
134 silent++;
135 break;
136 case 'n':
137 noaction++;
138 break;
139 case 'e':
140 explicate++;
141 break;
142 case 'o':
143 rvdevice = argv[++i];
144 break;
145 case 'v':
146 viewselect = argv[++i];
147 break;
148 default:
149 goto userr;
150 }
151 if (i >= argc)
152 goto userr;
153 /* assign Radiance root file name */
154 rootname(radname, argv[i]);
155 /* load variable values */
156 load(argv[i]);
157 /* get any additional assignments */
158 for (i++; i < argc; i++)
159 setvariable(argv[i]);
160 /* check assignments */
161 checkvalues();
162 /* check files and dates */
163 checkfiles();
164 /* set default values as necessary */
165 setdefaults();
166 /* print all values if requested */
167 if (explicate)
168 printvals();
169 /* run simulation */
170 oconv();
171 renderopts(ropts);
172 xferopts(ropts);
173 if (rvdevice != NULL)
174 rview(ropts);
175 else
176 rpict(ropts);
177 exit(0);
178 userr:
179 fprintf(stderr,
180 "Usage: %s [-s][-n][-e][-v view][-o dev] rfile [VAR=value ..]\n",
181 progname);
182 exit(1);
183 }
184
185
186 rootname(rn, fn) /* remove tail from end of fn */
187 register char *rn, *fn;
188 {
189 char *tp, *dp;
190
191 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
192 if (ISDIRSEP(*rn))
193 dp = rn;
194 else if (*rn == '.')
195 tp = rn;
196 if (tp != NULL && tp > dp)
197 *tp = '\0';
198 }
199
200
201 load(rfname) /* load Radiance simulation file */
202 char *rfname;
203 {
204 FILE *fp;
205 char buf[512];
206 register char *cp;
207
208 if (rfname == NULL)
209 fp = stdin;
210 else if ((fp = fopen(rfname, "r")) == NULL)
211 syserr(rfname);
212 while (fgetline(buf, sizeof(buf), fp) != NULL) {
213 for (cp = buf; *cp; cp++) {
214 switch (*cp) {
215 case '\\':
216 case '\n':
217 *cp = ' ';
218 continue;
219 case '#':
220 *cp = '\0';
221 break;
222 default:
223 continue;
224 }
225 break;
226 }
227 setvariable(buf);
228 }
229 fclose(fp);
230 }
231
232
233 setvariable(ass) /* assign variable according to string */
234 register char *ass;
235 {
236 char varname[32];
237 register char *cp;
238 register VARIABLE *vp;
239 register int i;
240 int n;
241
242 while (isspace(*ass)) /* skip leading space */
243 ass++;
244 cp = varname; /* extract name */
245 while (cp < varname+sizeof(varname)-1
246 && *ass && !isspace(*ass) && *ass != '=')
247 *cp++ = *ass++;
248 *cp = '\0';
249 if (!varname[0])
250 return; /* no variable name! */
251 /* trim value */
252 while (isspace(*ass) || *ass == '=')
253 ass++;
254 cp = ass + strlen(ass);
255 do
256 *cp-- = '\0';
257 while (cp >= ass && isspace(*cp));
258 n = cp - ass + 1;
259 if (!n) {
260 fprintf(stderr, "%s: warning - missing value for variable '%s'\n",
261 progname, varname);
262 return;
263 }
264 /* match variable from list */
265 vp = matchvar(varname);
266 if (vp == NULL) {
267 fprintf(stderr, "%s: unknown variable '%s'\n",
268 progname, varname);
269 exit(1);
270 }
271 /* assign new value */
272 if (i = vp->nass) {
273 cp = vp->value;
274 while (i--)
275 while (*cp++)
276 ;
277 i = cp - vp->value;
278 vp->value = realloc(vp->value, i+n+1);
279 } else
280 vp->value = malloc(n+1);
281 if (vp->value == NULL)
282 syserr(progname);
283 strcpy(vp->value+i, ass);
284 vp->nass++;
285 }
286
287
288 VARIABLE *
289 matchvar(nam) /* match a variable by its name */
290 char *nam;
291 {
292 int n = strlen(nam);
293 register int i;
294
295 for (i = 0; i < NVARS; i++)
296 if (n >= vv[i].nick && !strncmp(nam, vv[i].name, n))
297 return(vv+i);
298 return(NULL);
299 }
300
301
302 char *
303 nvalue(vp, n) /* return nth variable value */
304 VARIABLE *vp;
305 register int n;
306 {
307 register char *cp;
308
309 if (vp == NULL || n < 0 || n >= vp->nass)
310 return(NULL);
311 cp = vp->value;
312 while (n--)
313 while (*cp++)
314 ;
315 return(cp);
316 }
317
318
319 int
320 vscale(vc) /* return scale for variable vc */
321 int vc;
322 {
323 switch(vlet(vc)) {
324 case 'H':
325 return(HIGH);
326 case 'M':
327 return(MEDIUM);
328 case 'L':
329 return(LOW);
330 }
331 badvalue(vc);
332 }
333
334
335 checkvalues() /* check assignments */
336 {
337 register int i;
338
339 for (i = 0; i < NVARS; i++)
340 if (vv[i].fixval != NULL)
341 (*vv[i].fixval)(vv+i);
342 }
343
344
345 onevalue(vp) /* only one assignment for this variable */
346 register VARIABLE *vp;
347 {
348 if (vp->nass < 2)
349 return;
350 fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n",
351 progname, vp->name);
352 do
353 vp->value += strlen(vp->value)+1;
354 while (--vp->nass > 1);
355 }
356
357
358 catvalues(vp) /* concatenate variable values */
359 register VARIABLE *vp;
360 {
361 register char *cp;
362
363 if (vp->nass < 2)
364 return;
365 for (cp = vp->value; vp->nass > 1; vp->nass--) {
366 while (*cp)
367 cp++;
368 *cp++ = ' ';
369 }
370 }
371
372
373 long
374 checklast(fnames) /* check files and find most recent */
375 register char *fnames;
376 {
377 char thisfile[MAXPATH];
378 long thisdate, lastdate = -1;
379 register char *cp;
380
381 while (*fnames) {
382 while (isspace(*fnames)) fnames++;
383 cp = thisfile;
384 while (*fnames && !isspace(*fnames))
385 *cp++ = *fnames++;
386 *cp = '\0';
387 if ((thisdate = fdate(thisfile)) < 0)
388 syserr(thisfile);
389 if (thisdate > lastdate)
390 lastdate = thisdate;
391 }
392 return(lastdate);
393 }
394
395
396 checkfiles() /* check for existence and modified times */
397 {
398 char *cp;
399 long objdate;
400
401 if (!vdef(OCTREE)) {
402 if ((cp = bmalloc(strlen(radname)+5)) == NULL)
403 syserr(progname);
404 sprintf(cp, "%s.oct", radname);
405 vval(OCTREE) = cp;
406 vdef(OCTREE)++;
407 }
408 octreedate = fdate(vval(OCTREE));
409 scenedate = -1;
410 if (vdef(SCENE)) {
411 scenedate = checklast(vval(SCENE));
412 if (vdef(OBJECT)) {
413 objdate = checklast(vval(OBJECT));
414 if (objdate > scenedate)
415 scenedate = objdate;
416 }
417 }
418 if (octreedate < 0 & scenedate < 0) {
419 fprintf(stderr, "%s: need '%s' or '%s'\n", progname,
420 vnam(OCTREE), vnam(SCENE));
421 exit(1);
422 }
423 }
424
425
426 getoctcube(org, sizp) /* get octree bounding cube */
427 double org[3], *sizp;
428 {
429 extern FILE *popen();
430 static double oorg[3], osiz = 0.;
431 char buf[MAXPATH+16];
432 FILE *fp;
433
434 if (osiz <= FTINY) {
435 oconv(); /* does nothing if done already */
436 sprintf(buf, "getinfo -d < %s", vval(OCTREE));
437 if ((fp = popen(buf, "r")) == NULL)
438 syserr("getinfo");
439 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
440 &oorg[2], &osiz) != 4) {
441 fprintf(stderr,
442 "%s: error reading bounding cube from getinfo\n",
443 progname);
444 exit(1);
445 }
446 pclose(fp);
447 }
448 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
449 }
450
451
452 setdefaults() /* set default values for unassigned var's */
453 {
454 double org[3], size;
455 char buf[128];
456
457 if (!vdef(ZONE)) {
458 getoctcube(org, &size);
459 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
460 org[1], org[1]+size, org[2], org[2]+size);
461 vval(ZONE) = savqstr(buf);
462 vdef(ZONE)++;
463 }
464 if (!vdef(INDIRECT)) {
465 vval(INDIRECT) = "0";
466 vdef(INDIRECT)++;
467 }
468 if (!vdef(QUALITY)) {
469 vval(QUALITY) = "L";
470 vdef(QUALITY)++;
471 }
472 if (!vdef(RESOLUTION)) {
473 vval(RESOLUTION) = "512";
474 vdef(RESOLUTION)++;
475 }
476 if (!vdef(PICTURE)) {
477 vval(PICTURE) = radname;
478 vdef(PICTURE)++;
479 }
480 if (!vdef(VIEW)) {
481 vval(VIEW) = "X";
482 vdef(VIEW)++;
483 }
484 if (!vdef(DETAIL)) {
485 vval(DETAIL) = "M";
486 vdef(DETAIL)++;
487 }
488 if (!vdef(PENUMBRAS)) {
489 vval(PENUMBRAS) = "F";
490 vdef(PENUMBRAS)++;
491 }
492 if (!vdef(VARIABILITY)) {
493 vval(VARIABILITY) = "L";
494 vdef(VARIABILITY)++;
495 }
496 }
497
498
499 printvals() /* print variable values */
500 {
501 register int i, j;
502
503 for (i = 0; i < NVARS; i++)
504 for (j = 0; j < vdef(i); j++)
505 printf("%s= %s\n", vnam(i), nvalue(vv+i, j));
506 fflush(stdout);
507 }
508
509
510 oconv() /* run oconv if necessary */
511 {
512 char combuf[512], ocopts[64];
513
514 if (octreedate >= scenedate) /* check dates */
515 return;
516 /* build command */
517 oconvopts(ocopts);
518 if (vdef(MATERIAL))
519 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
520 vval(MATERIAL), vval(SCENE), vval(OCTREE));
521 else
522 sprintf(combuf, "oconv%s %s > %s", ocopts,
523 vval(SCENE), vval(OCTREE));
524
525 if (runcom(combuf)) { /* run it */
526 fprintf(stderr, "%s: error generating octree\n\t%s removed\n",
527 progname, vval(OCTREE));
528 unlink(vval(OCTREE));
529 exit(1);
530 }
531 octreedate = time(0);
532 }
533
534
535 char *
536 addarg(op, arg) /* add argument and advance pointer */
537 register char *op, *arg;
538 {
539 *op = ' ';
540 while (*++op = *arg++)
541 ;
542 return(op);
543 }
544
545
546 oconvopts(oo) /* get oconv options */
547 register char *oo;
548 {
549 /* BEWARE: This may be called via setdefaults(), so no assumptions */
550
551 *oo = '\0';
552 if (vdef(OCONV))
553 addarg(oo, vval(OCONV));
554 }
555
556
557 double
558 ambval() /* compute ambient value */
559 {
560 if (vdef(EXPOSURE)) {
561 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
562 return(.5/pow(2.,atof(vval(EXPOSURE))));
563 if (isdigit(vval(EXPOSURE)[0]) || vval(EXPOSURE)[0] == '.')
564 return(.5/atof(vval(EXPOSURE)));
565 badvalue(EXPOSURE);
566 }
567 if (vlet(ZONE) == 'E')
568 return(10.);
569 if (vlet(ZONE) == 'I')
570 return(.01);
571 badvalue(ZONE);
572 }
573
574
575 lowqopts(op) /* low quality rendering options */
576 register char *op;
577 {
578 double d, org[3], siz[3];
579
580 *op = '\0';
581 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
582 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
583 badvalue(ZONE);
584 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
585 getoctcube(org, &d);
586 d *= 3./(siz[0]+siz[1]+siz[2]);
587 switch (vscale(DETAIL)) {
588 case LOW:
589 op = addarg(op, "-ps 16 -dp 16");
590 sprintf(op, " -ar %d", (int)(4*d));
591 op += strlen(op);
592 break;
593 case MEDIUM:
594 op = addarg(op, "-ps 8 -dp 32");
595 sprintf(op, " -ar %d", (int)(8*d));
596 op += strlen(op);
597 break;
598 case HIGH:
599 op = addarg(op, "-ps 4 -dp 64");
600 sprintf(op, " -ar %d", (int)(16*d));
601 op += strlen(op);
602 break;
603 }
604 op = addarg(op, "-pt .16");
605 if (vbool(PENUMBRAS))
606 op = addarg(op, "-ds .4");
607 else
608 op = addarg(op, "-ds 0");
609 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .7");
610 if (vdef(AMBFILE)) {
611 sprintf(op, " -af %s", vval(AMBFILE));
612 op += strlen(op);
613 } else
614 overture = 0;
615 switch (vscale(VARIABILITY)) {
616 case LOW:
617 op = addarg(op, "-aa .4 -ad 32");
618 break;
619 case MEDIUM:
620 op = addarg(op, "-aa .3 -ad 64");
621 break;
622 case HIGH:
623 op = addarg(op, "-aa .25 -ad 128");
624 break;
625 }
626 op = addarg(op, "-as 0");
627 d = ambval();
628 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
629 op += strlen(op);
630 op = addarg(op, "-lr 3 -lw .02");
631 if (vdef(RENDER))
632 op = addarg(op, vval(RENDER));
633 }
634
635
636 medqopts(op) /* medium quality rendering options */
637 register char *op;
638 {
639 double d, org[3], siz[3];
640
641 *op = '\0';
642 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
643 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
644 badvalue(ZONE);
645 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
646 getoctcube(org, &d);
647 d *= 3./(siz[0]+siz[1]+siz[2]);
648 switch (vscale(DETAIL)) {
649 case LOW:
650 op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
651 op = addarg(op, "-dp 64");
652 sprintf(op, " -ar %d", (int)(8*d));
653 op += strlen(op);
654 break;
655 case MEDIUM:
656 op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
657 op = addarg(op, "-dp 128");
658 sprintf(op, " -ar %d", (int)(16*d));
659 op += strlen(op);
660 break;
661 case HIGH:
662 op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
663 op = addarg(op, "-dp 256");
664 sprintf(op, " -ar %d", (int)(32*d));
665 op += strlen(op);
666 break;
667 }
668 op = addarg(op, "-pt .08");
669 if (vbool(PENUMBRAS))
670 op = addarg(op, "-ds .2 -dj .35");
671 else
672 op = addarg(op, "-ds .3");
673 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .15");
674 if (overture = vint(INDIRECT)) {
675 sprintf(op, " -ab %d", overture);
676 op += strlen(op);
677 }
678 if (vdef(AMBFILE)) {
679 sprintf(op, " -af %s", vval(AMBFILE));
680 op += strlen(op);
681 } else
682 overture = 0;
683 switch (vscale(VARIABILITY)) {
684 case LOW:
685 op = addarg(op, "-aa .25 -ad 128 -as 0");
686 break;
687 case MEDIUM:
688 op = addarg(op, "-aa .2 -ad 300 -as 64");
689 break;
690 case HIGH:
691 op = addarg(op, "-aa .15 -ad 500 -as 128");
692 break;
693 }
694 d = ambval();
695 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
696 op += strlen(op);
697 op = addarg(op, "-lr 6 -lw .002");
698 if (vdef(RENDER))
699 op = addarg(op, vval(RENDER));
700 }
701
702
703 hiqopts(op) /* high quality rendering options */
704 register char *op;
705 {
706 double d, org[3], siz[3];
707
708 *op = '\0';
709 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
710 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
711 badvalue(ZONE);
712 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
713 getoctcube(org, &d);
714 d *= 3./(siz[0]+siz[1]+siz[2]);
715 switch (vscale(DETAIL)) {
716 case LOW:
717 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
718 op = addarg(op, "-dp 256");
719 sprintf(op, " -ar %d", (int)(16*d));
720 op += strlen(op);
721 break;
722 case MEDIUM:
723 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
724 op = addarg(op, "-dp 512");
725 sprintf(op, " -ar %d", (int)(32*d));
726 op += strlen(op);
727 break;
728 case HIGH:
729 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
730 op = addarg(op, "-dp 1024");
731 sprintf(op, " -ar %d", (int)(64*d));
732 op += strlen(op);
733 break;
734 }
735 op = addarg(op, "-pt .04");
736 if (vbool(PENUMBRAS))
737 op = addarg(op, "-ds .1 -dj .7");
738 else
739 op = addarg(op, "-ds .2");
740 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .03");
741 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
742 op += strlen(op);
743 if (vdef(AMBFILE)) {
744 sprintf(op, " -af %s", vval(AMBFILE));
745 op += strlen(op);
746 } else
747 overture = 0;
748 switch (vscale(VARIABILITY)) {
749 case LOW:
750 op = addarg(op, "-aa .15 -ad 200 -as 0");
751 break;
752 case MEDIUM:
753 op = addarg(op, "-aa .125 -ad 512 -as 128");
754 break;
755 case HIGH:
756 op = addarg(op, "-aa .08 -ad 850 -as 256");
757 break;
758 }
759 d = ambval();
760 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
761 op += strlen(op);
762 op = addarg(op, "-lr 12 -lw .0005");
763 if (vdef(RENDER))
764 op = addarg(op, vval(RENDER));
765 }
766
767
768 xferopts(ro) /* transfer options if indicated */
769 char *ro;
770 {
771 int fd, n;
772
773 n = strlen(ro);
774 if (n < 2)
775 return;
776 if (vdef(OPTFILE)) {
777 if ((fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1)
778 syserr(vval(OPTFILE));
779 if (write(fd, ro+1, n-1) != n-1)
780 syserr(vval(OPTFILE));
781 write(fd, "\n", 1);
782 close(fd);
783 sprintf(ro, " \"^%s\"", vval(OPTFILE));
784 }
785 #ifdef MSDOS
786 else if (n > 50) {
787 register char *evp = bmalloc(n+6);
788 if (evp == NULL)
789 syserr(progname);
790 strcpy(evp, "ROPT=");
791 strcat(evp, ro);
792 if (putenv(evp) != 0) {
793 fprintf(stderr, "%s: out of environment space\n",
794 progname);
795 exit(1);
796 }
797 strcpy(ro, " $ROPT");
798 }
799 #endif
800 }
801
802
803 pfiltopts(po) /* get pfilt options */
804 register char *po;
805 {
806 *po = '\0';
807 if (vdef(EXPOSURE)) {
808 po = addarg(po, "-1 -e");
809 po = addarg(po, vval(EXPOSURE));
810 }
811 if (vscale(QUALITY) == HIGH)
812 po = addarg(po, "-r .65");
813 if (vdef(PFILT))
814 po = addarg(po, vval(PFILT));
815 }
816
817
818 matchword(s1, s2) /* match white-delimited words */
819 register char *s1, *s2;
820 {
821 while (isspace(*s1)) s1++;
822 while (isspace(*s2)) s2++;
823 while (*s1 && !isspace(*s1))
824 if (*s1++ != *s2++)
825 return(0);
826 return(!*s2 || isspace(*s2));
827 }
828
829
830 char *
831 specview(vs) /* get proper view spec from vs */
832 register char *vs;
833 {
834 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
835 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
836 static char viewopts[128];
837 register char *cp;
838 int xpos, ypos, zpos, viewtype, upax;
839 register int i;
840 double cent[3], dim[3], mult, d;
841
842 if (vs == NULL || *vs == '-')
843 return(vs);
844 upax = 0; /* get the up vector */
845 if (vdef(UP)) {
846 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
847 upax = 1-'X'+UPPER(vval(UP)[1]);
848 else
849 upax = 1-'X'+vlet(UP);
850 if (upax < 1 | upax > 3)
851 badvalue(UP);
852 if (vval(UP)[0] == '-')
853 upax = -upax;
854 }
855 /* check standard view names */
856 xpos = ypos = zpos = 0;
857 if (*vs == 'X') {
858 xpos = 1; vs++;
859 } else if (*vs == 'x') {
860 xpos = -1; vs++;
861 }
862 if (*vs == 'Y') {
863 ypos = 1; vs++;
864 } else if (*vs == 'y') {
865 ypos = -1; vs++;
866 }
867 if (*vs == 'Z') {
868 zpos = 1; vs++;
869 } else if (*vs == 'z') {
870 zpos = -1; vs++;
871 }
872 viewtype = 'v';
873 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h')
874 viewtype = *vs++;
875 cp = viewopts;
876 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
877 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
878 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
879 &cent[0], &dim[0], &cent[1], &dim[1],
880 &cent[2], &dim[2]) != 6)
881 badvalue(ZONE);
882 for (i = 0; i < 3; i++) {
883 dim[i] -= cent[i];
884 cent[i] += .5*dim[i];
885 }
886 mult = vlet(ZONE)=='E' ? 2. : .45 ;
887 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
888 cent[0]+xpos*mult*dim[0],
889 cent[1]+ypos*mult*dim[1],
890 cent[2]+zpos*mult*dim[2],
891 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
892 cp += strlen(cp);
893 /* redirect up axis if necessary */
894 switch (upax) {
895 case 3: /* plus or minus Z axis */
896 case -3:
897 case 0:
898 if (!(xpos|ypos))
899 upax = 2;
900 break;
901 case 2: /* plus or minus Y axis */
902 case -2:
903 if (!(xpos|zpos))
904 upax = 1;
905 break;
906 case 1: /* plus or minus X axis */
907 case -1:
908 if (!(ypos|zpos))
909 upax = 3;
910 break;
911 }
912 cp = addarg(cp, vup[upax+3]);
913 switch (viewtype) {
914 case 'v':
915 cp = addarg(cp, "-vh 45 -vv 45");
916 break;
917 case 'l':
918 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
919 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
920 cp += strlen(cp);
921 break;
922 case 'a':
923 case 'h':
924 cp = addarg(cp, "-vh 180 -vv 180");
925 break;
926 }
927 } else {
928 while (!isspace(*vs)) /* else skip id */
929 if (!*vs++)
930 return(NULL);
931 if (upax) { /* specify up vector */
932 strcpy(cp, vup[upax+3]);
933 cp += strlen(cp);
934 }
935 }
936 /* append any additional options */
937 strcpy(cp, vs);
938 return(viewopts);
939 }
940
941
942 char *
943 getview(n, vn) /* get view n, or NULL if none */
944 int n;
945 char *vn;
946 {
947 register char *mv;
948
949 if (viewselect != NULL) {
950 if (n) /* only do one */
951 return(NULL);
952 if (viewselect[0] == '-') { /* already specified */
953 if (vn != NULL) *vn = '\0';
954 return(viewselect);
955 }
956 if (vn != NULL) {
957 for (mv = viewselect; *mv && !isspace(*mv);
958 *vn++ = *mv++)
959 ;
960 *vn = '\0';
961 }
962 /* check list */
963 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
964 if (matchword(viewselect, mv))
965 return(specview(mv));
966 return(specview(viewselect)); /* standard view? */
967 }
968 if (vn != NULL && (mv = nvalue(vv+VIEW, n)) != NULL) {
969 if (*mv != '-')
970 while (*mv && !isspace(*mv))
971 *vn++ = *mv++;
972 *vn = '\0';
973 }
974 return(specview(nvalue(vv+VIEW, n))); /* use view n */
975 }
976
977
978 rview(opts) /* run rview with first view */
979 char *opts;
980 {
981 char combuf[512];
982 /* build command */
983 sprintf(combuf, "rview %s%s ", getview(0, NULL), opts);
984 if (rvdevice != NULL)
985 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
986 strcat(combuf, vval(OCTREE));
987 if (runcom(combuf)) { /* run it */
988 fprintf(stderr, "%s: error running rview\n", progname);
989 exit(1);
990 }
991 }
992
993
994 rpict(opts) /* run rpict and pfilt for each view */
995 char *opts;
996 {
997 char combuf[1024];
998 char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32];
999 char pfopts[128];
1000 char vs[32], *vw;
1001 int vn, mult;
1002 /* get pfilt options */
1003 pfiltopts(pfopts);
1004 /* get resolution, reporting */
1005 mult = vscale(QUALITY)+1;
1006 {
1007 int xres, yres;
1008 double aspect;
1009 int n;
1010 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1011 if (n == 3)
1012 sprintf(res, "-x %d -y %d -pa %.3f",
1013 mult*xres, mult*yres, aspect);
1014 else if (n) {
1015 if (n == 1) yres = xres;
1016 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1017 } else
1018 badvalue(RESOLUTION);
1019 }
1020 rep[0] = '\0';
1021 if (vdef(REPORT)) {
1022 double minutes;
1023 int n;
1024 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1025 if (n == 2)
1026 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1027 else if (n == 1)
1028 sprintf(rep, " -t %d", (int)(minutes*60));
1029 else
1030 badvalue(REPORT);
1031 }
1032 /* check date on ambient file */
1033 if (vdef(AMBFILE)) {
1034 long afdate = fdate(vval(AMBFILE));
1035 if (afdate >= 0 & octreedate > afdate)
1036 rmfile(vval(AMBFILE));
1037 }
1038 /* do each view */
1039 vn = 0;
1040 while ((vw = getview(vn++, vs)) != NULL) {
1041 if (!vs[0])
1042 sprintf(vs, "%d", vn);
1043 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1044 /* check date on picture */
1045 if (fdate(picfile) > octreedate)
1046 continue;
1047 /* build rpict command */
1048 sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs);
1049 if (fdate(rawfile) > octreedate) /* recover */
1050 sprintf(combuf, "rpict%s%s -ro %s %s",
1051 rep, opts, rawfile, vval(OCTREE));
1052 else {
1053 if (overture) { /* run overture calculation */
1054 sprintf(combuf,
1055 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1056 rep, vw, opts,
1057 vval(OCTREE), overfile);
1058 if (runcom(combuf)) {
1059 fprintf(stderr,
1060 "%s: error in overture for view %s\n",
1061 progname, vs);
1062 exit(1);
1063 }
1064 #ifdef NIX
1065 rmfile(overfile);
1066 #endif
1067 }
1068 sprintf(combuf, "rpict%s %s %s%s %s > %s",
1069 rep, vw, res, opts,
1070 vval(OCTREE), rawfile);
1071 }
1072 if (runcom(combuf)) { /* run rpict */
1073 fprintf(stderr, "%s: error rendering view %s\n",
1074 progname, vs);
1075 exit(1);
1076 }
1077 /* build pfilt command */
1078 if (mult > 1)
1079 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1080 pfopts, mult, mult, rawfile, picfile);
1081 else
1082 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1083 rawfile, picfile);
1084 if (runcom(combuf)) { /* run pfilt */
1085 fprintf(stderr,
1086 "%s: error filtering view %s\n\t%s removed\n",
1087 progname, vs, picfile);
1088 unlink(picfile);
1089 exit(1);
1090 }
1091 /* remove raw file */
1092 rmfile(rawfile);
1093 }
1094 }
1095
1096
1097 runcom(cs) /* run command */
1098 char *cs;
1099 {
1100 if (!silent) /* echo it */
1101 printf("\t%s\n", cs);
1102 if (noaction)
1103 return(0);
1104 fflush(stdout); /* flush output and pass to shell */
1105 return(system(cs));
1106 }
1107
1108
1109 rmfile(fn) /* remove a file */
1110 char *fn;
1111 {
1112 if (!silent)
1113 #ifdef MSDOS
1114 printf("\tdel %s\n", fn);
1115 #else
1116 printf("\trm -f %s\n", fn);
1117 #endif
1118 if (noaction)
1119 return(0);
1120 return(unlink(fn));
1121 }
1122
1123
1124 badvalue(vc) /* report bad variable value and exit */
1125 int vc;
1126 {
1127 fprintf(stderr, "%s: bad value for variable '%s'\n",
1128 progname, vnam(vc));
1129 exit(1);
1130 }
1131
1132
1133 syserr(s) /* report a system error and exit */
1134 char *s;
1135 {
1136 perror(s);
1137 exit(1);
1138 }
