Revision: 2.32
Committed: Tue Nov 16 11:44:08 1993 UTC (31 years, 6 months ago) by greg
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include <ctype.h>
14
15
16 typedef struct {
17 char *name; /* variable name */
18 short nick; /* # characters required for nickname */
19 short nass; /* # assignments made */
20 char *value; /* assigned value(s) */
21 int (*fixval)(); /* assignment checking function */
22 } VARIABLE;
23
24 int onevalue(), catvalues(), boolvalue(),
25 qualvalue(), fltvalue(), intvalue();
26
27 /* variables */
28 #define OBJECT 0 /* object files */
29 #define SCENE 1 /* scene files */
30 #define MATERIAL 2 /* material files */
31 #define ILLUM 3 /* mkillum input files */
32 #define MKILLUM 4 /* mkillum options */
33 #define RENDER 5 /* rendering options */
34 #define OCONV 6 /* oconv options */
35 #define PFILT 7 /* pfilt options */
36 #define VIEW 8 /* view(s) for picture(s) */
37 #define ZONE 9 /* simulation zone */
38 #define QUALITY 10 /* desired rendering quality */
39 #define OCTREE 11 /* octree file name */
40 #define PICTURE 12 /* picture file name */
41 #define AMBFILE 13 /* ambient file name */
42 #define OPTFILE 14 /* rendering options file */
43 #define EXPOSURE 15 /* picture exposure setting */
44 #define RESOLUTION 16 /* maximum picture resolution */
45 #define UP 17 /* view up (X, Y or Z) */
46 #define INDIRECT 18 /* indirection in lighting */
47 #define DETAIL 19 /* level of scene detail */
48 #define PENUMBRAS 20 /* shadow penumbras are desired */
49 #define VARIABILITY 21 /* level of light variability */
50 #define REPORT 22 /* report frequency and errfile */
51 /* total number of variables */
52 #define NVARS 23
53
54 VARIABLE vv[NVARS] = { /* variable-value pairs */
55 {"objects", 3, 0, NULL, catvalues},
56 {"scene", 3, 0, NULL, catvalues},
57 {"materials", 3, 0, NULL, catvalues},
58 {"illum", 3, 0, NULL, catvalues},
59 {"mkillum", 3, 0, NULL, catvalues},
60 {"render", 3, 0, NULL, catvalues},
61 {"oconv", 3, 0, NULL, catvalues},
62 {"pfilt", 2, 0, NULL, catvalues},
63 {"view", 2, 0, NULL, NULL},
64 {"ZONE", 2, 0, NULL, onevalue},
65 {"QUALITY", 3, 0, NULL, qualvalue},
66 {"OCTREE", 3, 0, NULL, onevalue},
67 {"PICTURE", 3, 0, NULL, onevalue},
68 {"AMBFILE", 3, 0, NULL, onevalue},
69 {"OPTFILE", 3, 0, NULL, onevalue},
70 {"EXPOSURE", 3, 0, NULL, fltvalue},
71 {"RESOLUTION", 3, 0, NULL, onevalue},
72 {"UP", 2, 0, NULL, onevalue},
73 {"INDIRECT", 3, 0, NULL, intvalue},
74 {"DETAIL", 3, 0, NULL, qualvalue},
75 {"PENUMBRAS", 3, 0, NULL, boolvalue},
76 {"VARIABILITY", 3, 0, NULL, qualvalue},
77 {"REPORT", 3, 0, NULL, onevalue},
78 };
79
80 VARIABLE *matchvar();
81 char *nvalue();
82
83 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
84
85 #define vnam(vc) (vv[vc].name)
86 #define vdef(vc) (vv[vc].nass)
87 #define vval(vc) (vv[vc].value)
88 #define vint(vc) atoi(vval(vc))
89 #define vlet(vc) UPPER(vval(vc)[0])
90 #define vscale vlet
91 #define vbool(vc) (vlet(vc)=='T')
92
93 #define HIGH 'H'
94 #define MEDIUM 'M'
95 #define LOW 'L'
96
97 /* overture calculation file */
98 #ifdef NIX
99 char overfile[] = "overture.raw";
100 #else
101 char overfile[] = "/dev/null";
102 #endif
103
104 extern unsigned long fdate(), time();
105
106 unsigned long scenedate; /* date of latest scene or object file */
107 unsigned long octreedate; /* date of octree */
108 unsigned long matdate; /* date of latest material file */
109 unsigned long illumdate; /* date of last illum file */
110
111 char *oct0name; /* name of pre-mkillum octree */
112 unsigned long oct0date; /* date of pre-mkillum octree */
113 char *oct1name; /* name of post-mkillum octree */
114 unsigned long oct1date; /* date of post-mkillum octree (>= matdate) */
115
116 int explicate = 0; /* explicate variables */
117 int silent = 0; /* do work silently */
118 int noaction = 0; /* don't do anything */
119 int sayview = 0; /* print view out */
120 char *rvdevice = NULL; /* rview output device */
121 char *viewselect = NULL; /* specific view only */
122
123 int overture = 0; /* overture calculation needed */
124
125 char *progname; /* global argv[0] */
126 char *rifname; /* global rad input file name */
127
128 char radname[MAXPATH]; /* root Radiance file name */
129
130
131 main(argc, argv)
132 int argc;
133 char *argv[];
134 {
135 char ropts[512];
136 int i;
137
138 progname = argv[0];
139 /* get options */
140 for (i = 1; i < argc && argv[i][0] == '-'; i++)
141 switch (argv[i][1]) {
142 case 's':
143 silent++;
144 break;
145 case 'n':
146 noaction++;
147 break;
148 case 'e':
149 explicate++;
150 break;
151 case 'o':
152 rvdevice = argv[++i];
153 break;
154 case 'V':
155 sayview++;
156 break;
157 case 'v':
158 viewselect = argv[++i];
159 break;
160 default:
161 goto userr;
162 }
163 if (i >= argc)
164 goto userr;
165 rifname = argv[i];
166 /* assign Radiance root file name */
167 rootname(radname, rifname);
168 /* load variable values */
169 load(rifname);
170 /* get any additional assignments */
171 for (i++; i < argc; i++)
172 setvariable(argv[i]);
173 /* check assignments */
174 checkvalues();
175 /* check files and dates */
176 checkfiles();
177 /* set default values as necessary */
178 setdefaults();
179 /* print all values if requested */
180 if (explicate)
181 printvals();
182 /* build octree (and run mkillum) */
183 oconv();
184 /* check date on ambient file */
185 checkambfile();
186 /* run simulation */
187 renderopts(ropts);
188 xferopts(ropts);
189 if (rvdevice != NULL)
190 rview(ropts);
191 else
192 rpict(ropts);
193 exit(0);
194 userr:
195 fprintf(stderr,
196 "Usage: %s [-s][-n][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n",
197 progname);
198 exit(1);
199 }
200
201
202 rootname(rn, fn) /* remove tail from end of fn */
203 register char *rn, *fn;
204 {
205 char *tp, *dp;
206
207 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
208 if (ISDIRSEP(*rn))
209 dp = rn;
210 else if (*rn == '.')
211 tp = rn;
212 if (tp != NULL && tp > dp)
213 *tp = '\0';
214 }
215
216
217 #define NOCHAR 127 /* constant for character to delete */
218
219
220 load(rfname) /* load Radiance simulation file */
221 char *rfname;
222 {
223 FILE *fp;
224 char buf[512];
225 register char *cp;
226
227 if (rfname == NULL)
228 fp = stdin;
229 else if ((fp = fopen(rfname, "r")) == NULL)
230 syserr(rfname);
231 while (fgetline(buf, sizeof(buf), fp) != NULL) {
232 for (cp = buf; *cp; cp++) {
233 switch (*cp) {
234 case '\\':
235 *cp++ = NOCHAR;
236 continue;
237 case '#':
238 *cp = '\0';
239 break;
240 default:
241 continue;
242 }
243 break;
244 }
245 setvariable(buf);
246 }
247 fclose(fp);
248 }
249
250
251 setvariable(ass) /* assign variable according to string */
252 register char *ass;
253 {
254 char varname[32];
255 char varval[512];
256 int n;
257 register char *cp;
258 register VARIABLE *vp;
259 register int i;
260
261 while (isspace(*ass)) /* skip leading space */
262 ass++;
263 cp = varname; /* extract name */
264 while (cp < varname+sizeof(varname)-1
265 && *ass && !isspace(*ass) && *ass != '=')
266 *cp++ = *ass++;
267 *cp = '\0';
268 if (!varname[0])
269 return; /* no variable name! */
270 /* trim value */
271 while (isspace(*ass) || *ass == '=')
272 ass++;
273 for (n = strlen(ass); n > 0; n--)
274 if (!isspace(ass[n-1]))
275 break;
276 if (!n) {
277 fprintf(stderr, "%s: warning - missing value for variable '%s'\n",
278 progname, varname);
279 return;
280 }
281 /* match variable from list */
282 vp = matchvar(varname);
283 if (vp == NULL) {
284 fprintf(stderr, "%s: unknown variable '%s'\n",
285 progname, varname);
286 exit(1);
287 }
288 /* assign new value */
289 if (i = vp->nass) {
290 cp = vp->value;
291 while (i--)
292 while (*cp++)
293 ;
294 i = cp - vp->value;
295 vp->value = realloc(vp->value, i+n+1);
296 } else
297 vp->value = malloc(n+1);
298 if (vp->value == NULL)
299 syserr(progname);
300 cp = vp->value+i; /* copy value, squeezing spaces */
301 *cp = *ass;
302 for (i = 1; i <= n; i++) {
303 if (ass[i] == NOCHAR)
304 continue;
305 if (isspace(*cp))
306 while (isspace(ass[i]))
307 i++;
308 *++cp = ass[i];
309 }
310 if (isspace(*cp)) /* remove trailing space */
311 *cp = '\0';
312 vp->nass++;
313 }
314
315
316 VARIABLE *
317 matchvar(nam) /* match a variable by its name */
318 char *nam;
319 {
320 int n = strlen(nam);
321 register int i;
322
323 for (i = 0; i < NVARS; i++)
324 if (n >= vv[i].nick && !strncmp(nam, vv[i].name, n))
325 return(vv+i);
326 return(NULL);
327 }
328
329
330 char *
331 nvalue(vp, n) /* return nth variable value */
332 VARIABLE *vp;
333 register int n;
334 {
335 register char *cp;
336
337 if (vp == NULL | n < 0 | n >= vp->nass)
338 return(NULL);
339 cp = vp->value;
340 while (n--)
341 while (*cp++)
342 ;
343 return(cp);
344 }
345
346
347 checkvalues() /* check assignments */
348 {
349 register int i;
350
351 for (i = 0; i < NVARS; i++)
352 if (vv[i].fixval != NULL)
353 (*vv[i].fixval)(vv+i);
354 }
355
356
357 onevalue(vp) /* only one assignment for this variable */
358 register VARIABLE *vp;
359 {
360 if (vp->nass < 2)
361 return;
362 fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n",
363 progname, vp->name);
364 do
365 vp->value += strlen(vp->value)+1;
366 while (--vp->nass > 1);
367 }
368
369
370 catvalues(vp) /* concatenate variable values */
371 register VARIABLE *vp;
372 {
373 register char *cp;
374
375 if (vp->nass < 2)
376 return;
377 for (cp = vp->value; vp->nass > 1; vp->nass--) {
378 while (*cp)
379 cp++;
380 *cp++ = ' ';
381 }
382 }
383
384
385 int
386 badmatch(tv, cv) /* case insensitive truncated comparison */
387 register char *tv, *cv;
388 {
389 if (!*tv) return(1); /* null string cannot match */
390 do
391 if (UPPER(*tv) != *cv++)
392 return(1);
393 while (*++tv);
394 return(0); /* OK */
395 }
396
397
398 boolvalue(vp) /* check boolean for legal values */
399 register VARIABLE *vp;
400 {
401 if (!vp->nass) return;
402 onevalue(vp);
403 switch (UPPER(vp->value[0])) {
404 case 'T':
405 if (badmatch(vp->value, "TRUE")) break;
406 return;
407 case 'F':
408 if (badmatch(vp->value, "FALSE")) break;
409 return;
410 }
411 fprintf(stderr, "%s: illegal value for boolean variable '%s'\n",
412 progname, vp->name);
413 exit(1);
414 }
415
416
417 qualvalue(vp) /* check qualitative var. for legal values */
418 register VARIABLE *vp;
419 {
420 if (!vp->nass) return;
421 onevalue(vp);
422 switch (UPPER(vp->value[0])) {
423 case 'L':
424 if (badmatch(vp->value, "LOW")) break;
425 return;
426 case 'M':
427 if (badmatch(vp->value, "MEDIUM")) break;
428 return;
429 case 'H':
430 if (badmatch(vp->value, "HIGH")) break;
431 return;
432 }
433 fprintf(stderr, "%s: illegal value for qualitative variable '%s'\n",
434 progname, vp->name);
435 exit(1);
436 }
437
438
439 intvalue(vp) /* check integer variable for legal values */
440 register VARIABLE *vp;
441 {
442 if (!vp->nass) return;
443 onevalue(vp);
444 if (isint(vp->value)) return;
445 fprintf(stderr, "%s: illegal value for integer variable '%s'\n",
446 progname, vp->name);
447 exit(1);
448 }
449
450
451 fltvalue(vp) /* check float variable for legal values */
452 register VARIABLE *vp;
453 {
454 if (!vp->nass) return;
455 onevalue(vp);
456 if (isflt(vp->value)) return;
457 fprintf(stderr, "%s: illegal value for real variable '%s'\n",
458 progname, vp->name);
459 exit(1);
460 }
461
462
463 unsigned long
464 checklast(fnames) /* check files and find most recent */
465 register char *fnames;
466 {
467 char thisfile[MAXPATH];
468 unsigned long thisdate, lastdate = 0;
469 register char *cp;
470
471 if (fnames == NULL)
472 return(0);
473 while (*fnames) {
474 while (isspace(*fnames)) fnames++;
475 cp = thisfile;
476 while (*fnames && !isspace(*fnames))
477 *cp++ = *fnames++;
478 *cp = '\0';
479 if (!(thisdate = fdate(thisfile)))
480 syserr(thisfile);
481 if (thisdate > lastdate)
482 lastdate = thisdate;
483 }
484 return(lastdate);
485 }
486
487
488 char *
489 newfname(orig, pred) /* create modified file name */
490 char *orig;
491 int pred;
492 {
493 extern char *rindex();
494 register char *cp;
495 register int n;
496 int suffix;
497
498 n = 0; cp = orig; suffix = -1; /* suffix position, length */
499 while (*cp) {
500 if (*cp == '.') suffix = n;
501 else if (ISDIRSEP(*cp)) suffix = -1;
502 cp++; n++;
503 }
504 if (suffix == -1) suffix = n;
505 if ((cp = bmalloc(n+2)) == NULL)
506 syserr(progname);
507 strncpy(cp, orig, suffix);
508 cp[suffix] = pred; /* root name + pred + suffix */
509 strcpy(cp+suffix+1, orig+suffix);
510 return(cp);
511 }
512
513
514 checkfiles() /* check for existence and modified times */
515 {
516 unsigned long objdate;
517
518 if (!vdef(OCTREE)) {
519 if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL)
520 syserr(progname);
521 sprintf(vval(OCTREE), "%s.oct", radname);
522 vdef(OCTREE)++;
523 }
524 octreedate = fdate(vval(OCTREE));
525 if (vdef(ILLUM)) { /* illum requires secondary octrees */
526 oct0name = newfname(vval(OCTREE), '0');
527 oct1name = newfname(vval(OCTREE), '1');
528 oct0date = fdate(oct0name);
529 oct1date = fdate(oct1name);
530 } else
531 oct0name = oct1name = vval(OCTREE);
532 if ((scenedate = checklast(vval(SCENE))) &&
533 (objdate = checklast(vval(OBJECT))) > scenedate)
534 scenedate = objdate;
535 illumdate = checklast(vval(ILLUM));
536 if (!octreedate & !scenedate & !illumdate) {
537 fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname,
538 vnam(OCTREE), vnam(SCENE), vnam(ILLUM));
539 exit(1);
540 }
541 matdate = checklast(vval(MATERIAL));
542 }
543
544
545 getoctcube(org, sizp) /* get octree bounding cube */
546 double org[3], *sizp;
547 {
548 extern FILE *popen();
549 static double oorg[3], osiz = 0.;
550 double min[3], max[3];
551 char buf[512];
552 FILE *fp;
553 register int i;
554
555 if (osiz <= FTINY)
556 if (noaction && fdate(oct1name) <
557 (scenedate>illumdate?scenedate:illumdate)) {
558 /* run getbbox */
559 sprintf(buf, "getbbox -w -h %s",
560 vdef(SCENE) ? vval(SCENE) : vval(ILLUM));
561 if ((fp = popen(buf, "r")) == NULL)
562 syserr("getbbox");
563 if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
564 &min[0], &max[0], &min[1], &max[1],
565 &min[2], &max[2]) != 6) {
566 fprintf(stderr,
567 "%s: error reading bounding box from getbbox\n",
568 progname);
569 exit(1);
570 }
571 for (i = 0; i < 3; i++)
572 if (max[i] - min[i] > osiz)
573 osiz = max[i] - min[i];
574 for (i = 0; i < 3; i++)
575 oorg[i] = (max[i]+min[i]-osiz)*.5;
576 pclose(fp);
577 } else { /* from octree */
578 oconv(); /* does nothing if done already */
579 sprintf(buf, "getinfo -d < %s", oct1name);
580 if ((fp = popen(buf, "r")) == NULL)
581 syserr("getinfo");
582 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
583 &oorg[2], &osiz) != 4) {
584 fprintf(stderr,
585 "%s: error reading bounding cube from getinfo\n",
586 progname);
587 exit(1);
588 }
589 pclose(fp);
590 }
591 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
592 }
593
594
595 setdefaults() /* set default values for unassigned var's */
596 {
597 double org[3], size;
598 char buf[128];
599
600 if (!vdef(ZONE)) {
601 getoctcube(org, &size);
602 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
603 org[1], org[1]+size, org[2], org[2]+size);
604 vval(ZONE) = savqstr(buf);
605 vdef(ZONE)++;
606 }
607 if (!vdef(INDIRECT)) {
608 vval(INDIRECT) = "0";
609 vdef(INDIRECT)++;
610 }
611 if (!vdef(QUALITY)) {
612 vval(QUALITY) = "L";
613 vdef(QUALITY)++;
614 }
615 if (!vdef(RESOLUTION)) {
616 vval(RESOLUTION) = "512";
617 vdef(RESOLUTION)++;
618 }
619 if (!vdef(PICTURE)) {
620 vval(PICTURE) = radname;
621 vdef(PICTURE)++;
622 }
623 if (!vdef(VIEW)) {
624 vval(VIEW) = "X";
625 vdef(VIEW)++;
626 }
627 if (!vdef(DETAIL)) {
628 vval(DETAIL) = "M";
629 vdef(DETAIL)++;
630 }
631 if (!vdef(PENUMBRAS)) {
632 vval(PENUMBRAS) = "F";
633 vdef(PENUMBRAS)++;
634 }
635 if (!vdef(VARIABILITY)) {
636 vval(VARIABILITY) = "L";
637 vdef(VARIABILITY)++;
638 }
639 }
640
641
642 printvals() /* print variable values */
643 {
644 register int i, j;
645
646 for (i = 0; i < NVARS; i++)
647 for (j = 0; j < vdef(i); j++)
648 printf("%s= %s\n", vnam(i), nvalue(vv+i, j));
649 fflush(stdout);
650 }
651
652
653 oconv() /* run oconv and mkillum if necessary */
654 {
655 static char illumtmp[] = "ilXXXXXX";
656 char combuf[512], ocopts[64], mkopts[64];
657
658 oconvopts(ocopts); /* get options */
659 if (octreedate < scenedate) { /* check date on original octree */
660 /* build command */
661 if (vdef(MATERIAL))
662 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
663 vval(MATERIAL), vval(SCENE), vval(OCTREE));
664 else
665 sprintf(combuf, "oconv%s %s > %s", ocopts,
666 vval(SCENE), vval(OCTREE));
667
668 if (runcom(combuf)) { /* run it */
669 fprintf(stderr,
670 "%s: error generating octree\n\t%s removed\n",
671 progname, vval(OCTREE));
672 unlink(vval(OCTREE));
673 exit(1);
674 }
675 octreedate = time(0);
676 }
677 if (oct1name == vval(OCTREE)) /* no mkillum? */
678 oct1date = octreedate > matdate ? octreedate : matdate;
679 if (oct1date >= octreedate & oct1date >= matdate
680 & oct1date >= illumdate) /* all done */
681 return;
682 /* make octree0 */
683 if (oct0date < scenedate | oct0date < illumdate) {
684 /* build command */
685 if (octreedate)
686 sprintf(combuf, "oconv%s -i %s %s > %s", ocopts,
687 vval(OCTREE), vval(ILLUM), oct0name);
688 else if (vdef(MATERIAL))
689 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
690 vval(MATERIAL), vval(ILLUM), oct0name);
691 else
692 sprintf(combuf, "oconv%s %s > %s", ocopts,
693 vval(ILLUM), oct0name);
694 if (runcom(combuf)) { /* run it */
695 fprintf(stderr,
696 "%s: error generating octree\n\t%s removed\n",
697 progname, oct0name);
698 unlink(oct0name);
699 exit(1);
700 }
701 oct0date = time(0);
702 }
703 mkillumopts(mkopts); /* build mkillum command */
704 mktemp(illumtmp);
705 sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts,
706 oct0name, vval(ILLUM), illumtmp);
707 if (runcom(combuf)) { /* run it */
708 fprintf(stderr, "%s: error running mkillum\n", progname);
709 unlink(illumtmp);
710 exit(1);
711 }
712 /* make octree1 (frozen) */
713 if (octreedate)
714 sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts,
715 vval(OCTREE), illumtmp, oct1name);
716 else if (vdef(MATERIAL))
717 sprintf(combuf, "oconv%s -f %s %s > %s", ocopts,
718 vval(MATERIAL), illumtmp, oct1name);
719 else
720 sprintf(combuf, "oconv%s -f %s > %s", ocopts,
721 illumtmp, oct1name);
722 if (runcom(combuf)) { /* run it */
723 fprintf(stderr,
724 "%s: error generating octree\n\t%s removed\n",
725 progname, oct1name);
726 unlink(oct1name);
727 exit(1);
728 }
729 oct1date = time(0);
730 rmfile(illumtmp);
731 }
732
733
734 char *
735 addarg(op, arg) /* add argument and advance pointer */
736 register char *op, *arg;
737 {
738 *op = ' ';
739 while (*++op = *arg++)
740 ;
741 return(op);
742 }
743
744
745 oconvopts(oo) /* get oconv options */
746 register char *oo;
747 {
748 /* BEWARE: This may be called via setdefaults(), so no assumptions */
749
750 *oo = '\0';
751 if (vdef(OCONV))
752 addarg(oo, vval(OCONV));
753 }
754
755
756 mkillumopts(mo) /* get mkillum options */
757 register char *mo;
758 {
759 /* BEWARE: This may be called via setdefaults(), so no assumptions */
760
761 *mo = '\0';
762 if (vdef(MKILLUM))
763 addarg(mo, vval(MKILLUM));
764 }
765
766
767 checkambfile() /* check date on ambient file */
768 {
769 unsigned long afdate;
770
771 if (!vdef(AMBFILE))
772 return;
773 if (!(afdate = fdate(vval(AMBFILE))))
774 return;
775 if (oct1date > afdate)
776 rmfile(vval(AMBFILE));
777 }
778
779
780 double
781 ambval() /* compute ambient value */
782 {
783 if (vdef(EXPOSURE)) {
784 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
785 return(.5/pow(2.,atof(vval(EXPOSURE))));
786 return(.5/atof(vval(EXPOSURE)));
787 }
788 if (vlet(ZONE) == 'E')
789 return(10.);
790 if (vlet(ZONE) == 'I')
791 return(.01);
792 badvalue(ZONE);
793 }
794
795
796 renderopts(op) /* set rendering options */
797 char *op;
798 {
799 switch(vscale(QUALITY)) {
800 case LOW:
801 lowqopts(op);
802 break;
803 case MEDIUM:
804 medqopts(op);
805 break;
806 case HIGH:
807 hiqopts(op);
808 break;
809 }
810 }
811
812
813 lowqopts(op) /* low quality rendering options */
814 register char *op;
815 {
816 double d, org[3], siz[3];
817
818 *op = '\0';
819 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
820 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
821 badvalue(ZONE);
822 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
823 getoctcube(org, &d);
824 d *= 3./(siz[0]+siz[1]+siz[2]);
825 switch (vscale(DETAIL)) {
826 case LOW:
827 op = addarg(op, "-ps 16 -dp 64");
828 sprintf(op, " -ar %d", (int)(4*d));
829 op += strlen(op);
830 break;
831 case MEDIUM:
832 op = addarg(op, "-ps 8 -dp 128");
833 sprintf(op, " -ar %d", (int)(8*d));
834 op += strlen(op);
835 break;
836 case HIGH:
837 op = addarg(op, "-ps 4 -dp 256");
838 sprintf(op, " -ar %d", (int)(16*d));
839 op += strlen(op);
840 break;
841 }
842 op = addarg(op, "-pt .16");
843 if (vbool(PENUMBRAS))
844 op = addarg(op, "-ds .4");
845 else
846 op = addarg(op, "-ds 0");
847 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5");
848 if (vdef(AMBFILE)) {
849 sprintf(op, " -af %s", vval(AMBFILE));
850 op += strlen(op);
851 } else
852 overture = 0;
853 switch (vscale(VARIABILITY)) {
854 case LOW:
855 op = addarg(op, "-aa .4 -ad 64");
856 break;
857 case MEDIUM:
858 op = addarg(op, "-aa .3 -ad 128");
859 break;
860 case HIGH:
861 op = addarg(op, "-aa .25 -ad 256");
862 break;
863 }
864 op = addarg(op, "-as 0");
865 d = ambval();
866 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
867 op += strlen(op);
868 op = addarg(op, "-lr 3 -lw .02");
869 if (vdef(RENDER))
870 op = addarg(op, vval(RENDER));
871 }
872
873
874 medqopts(op) /* medium quality rendering options */
875 register char *op;
876 {
877 double d, org[3], siz[3];
878
879 *op = '\0';
880 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
881 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
882 badvalue(ZONE);
883 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
884 getoctcube(org, &d);
885 d *= 3./(siz[0]+siz[1]+siz[2]);
886 switch (vscale(DETAIL)) {
887 case LOW:
888 op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
889 op = addarg(op, "-dp 256");
890 sprintf(op, " -ar %d", (int)(8*d));
891 op += strlen(op);
892 break;
893 case MEDIUM:
894 op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
895 op = addarg(op, "-dp 512");
896 sprintf(op, " -ar %d", (int)(16*d));
897 op += strlen(op);
898 break;
899 case HIGH:
900 op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
901 op = addarg(op, "-dp 1024");
902 sprintf(op, " -ar %d", (int)(32*d));
903 op += strlen(op);
904 break;
905 }
906 op = addarg(op, "-pt .08");
907 if (vbool(PENUMBRAS))
908 op = addarg(op, "-ds .2 -dj .5");
909 else
910 op = addarg(op, "-ds .3");
911 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1");
912 if (overture = vint(INDIRECT)) {
913 sprintf(op, " -ab %d", overture);
914 op += strlen(op);
915 }
916 if (vdef(AMBFILE)) {
917 sprintf(op, " -af %s", vval(AMBFILE));
918 op += strlen(op);
919 } else
920 overture = 0;
921 switch (vscale(VARIABILITY)) {
922 case LOW:
923 op = addarg(op, "-aa .25 -ad 196 -as 0");
924 break;
925 case MEDIUM:
926 op = addarg(op, "-aa .2 -ad 400 -as 64");
927 break;
928 case HIGH:
929 op = addarg(op, "-aa .15 -ad 768 -as 196");
930 break;
931 }
932 d = ambval();
933 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
934 op += strlen(op);
935 op = addarg(op, "-lr 6 -lw .002");
936 if (vdef(RENDER))
937 op = addarg(op, vval(RENDER));
938 }
939
940
941 hiqopts(op) /* high quality rendering options */
942 register char *op;
943 {
944 double d, org[3], siz[3];
945
946 *op = '\0';
947 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
948 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
949 badvalue(ZONE);
950 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
951 getoctcube(org, &d);
952 d *= 3./(siz[0]+siz[1]+siz[2]);
953 switch (vscale(DETAIL)) {
954 case LOW:
955 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
956 op = addarg(op, "-dp 1024");
957 sprintf(op, " -ar %d", (int)(16*d));
958 op += strlen(op);
959 break;
960 case MEDIUM:
961 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
962 op = addarg(op, "-dp 2048");
963 sprintf(op, " -ar %d", (int)(32*d));
964 op += strlen(op);
965 break;
966 case HIGH:
967 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
968 op = addarg(op, "-dp 4096");
969 sprintf(op, " -ar %d", (int)(64*d));
970 op += strlen(op);
971 break;
972 }
973 op = addarg(op, "-pt .04");
974 if (vbool(PENUMBRAS))
975 op = addarg(op, "-ds .1 -dj .7");
976 else
977 op = addarg(op, "-ds .2");
978 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01");
979 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
980 op += strlen(op);
981 if (vdef(AMBFILE)) {
982 sprintf(op, " -af %s", vval(AMBFILE));
983 op += strlen(op);
984 } else
985 overture = 0;
986 switch (vscale(VARIABILITY)) {
987 case LOW:
988 op = addarg(op, "-aa .15 -ad 256 -as 0");
989 break;
990 case MEDIUM:
991 op = addarg(op, "-aa .125 -ad 512 -as 256");
992 break;
993 case HIGH:
994 op = addarg(op, "-aa .08 -ad 1024 -as 512");
995 break;
996 }
997 d = ambval();
998 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
999 op += strlen(op);
1000 op = addarg(op, "-lr 12 -lw .0005");
1001 if (vdef(RENDER))
1002 op = addarg(op, vval(RENDER));
1003 }
1004
1005
1006 xferopts(ro) /* transfer options if indicated */
1007 char *ro;
1008 {
1009 int fd, n;
1010 register char *cp;
1011
1012 n = strlen(ro);
1013 if (n < 2)
1014 return;
1015 if (vdef(OPTFILE)) {
1016 for (cp = ro; cp[1]; cp++)
1017 if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3]))
1018 *cp = '\n';
1019 else
1020 *cp = cp[1];
1021 *cp = '\n';
1022 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
1023 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
1024 syserr(vval(OPTFILE));
1025 sprintf(ro, " @%s", vval(OPTFILE));
1026 }
1027 #ifdef MSDOS
1028 else if (n > 50) {
1029 setenv("ROPT", ro+1);
1030 strcpy(ro, " $ROPT");
1031 }
1032 #endif
1033 }
1034
1035
1036 pfiltopts(po) /* get pfilt options */
1037 register char *po;
1038 {
1039 *po = '\0';
1040 if (vdef(EXPOSURE)) {
1041 po = addarg(po, "-1 -e");
1042 po = addarg(po, vval(EXPOSURE));
1043 }
1044 switch (vscale(QUALITY)) {
1045 case MEDIUM:
1046 po = addarg(po, "-r 1");
1047 break;
1048 case HIGH:
1049 po = addarg(po, "-m .25");
1050 break;
1051 }
1052 if (vdef(PFILT))
1053 po = addarg(po, vval(PFILT));
1054 }
1055
1056
1057 matchword(s1, s2) /* match white-delimited words */
1058 register char *s1, *s2;
1059 {
1060 while (isspace(*s1)) s1++;
1061 while (isspace(*s2)) s2++;
1062 while (*s1 && !isspace(*s1))
1063 if (*s1++ != *s2++)
1064 return(0);
1065 return(!*s2 || isspace(*s2));
1066 }
1067
1068
1069 char *
1070 specview(vs) /* get proper view spec from vs */
1071 register char *vs;
1072 {
1073 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
1074 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
1075 static char viewopts[128];
1076 register char *cp;
1077 int xpos, ypos, zpos, viewtype, upax;
1078 register int i;
1079 double cent[3], dim[3], mult, d;
1080
1081 if (vs == NULL || *vs == '-')
1082 return(vs);
1083 upax = 0; /* get the up vector */
1084 if (vdef(UP)) {
1085 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
1086 upax = 1-'X'+UPPER(vval(UP)[1]);
1087 else
1088 upax = 1-'X'+vlet(UP);
1089 if (upax < 1 | upax > 3)
1090 badvalue(UP);
1091 if (vval(UP)[0] == '-')
1092 upax = -upax;
1093 }
1094 /* check standard view names */
1095 xpos = ypos = zpos = 0;
1096 if (*vs == 'X') {
1097 xpos = 1; vs++;
1098 } else if (*vs == 'x') {
1099 xpos = -1; vs++;
1100 }
1101 if (*vs == 'Y') {
1102 ypos = 1; vs++;
1103 } else if (*vs == 'y') {
1104 ypos = -1; vs++;
1105 }
1106 if (*vs == 'Z') {
1107 zpos = 1; vs++;
1108 } else if (*vs == 'z') {
1109 zpos = -1; vs++;
1110 }
1111 viewtype = 'v';
1112 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h')
1113 viewtype = *vs++;
1114 cp = viewopts;
1115 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
1116 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
1117 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
1118 &cent[0], &dim[0], &cent[1], &dim[1],
1119 &cent[2], &dim[2]) != 6)
1120 badvalue(ZONE);
1121 for (i = 0; i < 3; i++) {
1122 dim[i] -= cent[i];
1123 cent[i] += .5*dim[i];
1124 }
1125 mult = vlet(ZONE)=='E' ? 2. : .45 ;
1126 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
1127 cent[0]+xpos*mult*dim[0],
1128 cent[1]+ypos*mult*dim[1],
1129 cent[2]+zpos*mult*dim[2],
1130 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
1131 cp += strlen(cp);
1132 /* redirect up axis if necessary */
1133 switch (upax) {
1134 case 3: /* plus or minus Z axis */
1135 case -3:
1136 case 0:
1137 if (!(xpos|ypos))
1138 upax = 2;
1139 break;
1140 case 2: /* plus or minus Y axis */
1141 case -2:
1142 if (!(xpos|zpos))
1143 upax = 1;
1144 break;
1145 case 1: /* plus or minus X axis */
1146 case -1:
1147 if (!(ypos|zpos))
1148 upax = 3;
1149 break;
1150 }
1151 cp = addarg(cp, vup[upax+3]);
1152 switch (viewtype) {
1153 case 'v':
1154 cp = addarg(cp, "-vh 45 -vv 45");
1155 break;
1156 case 'l':
1157 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
1158 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
1159 cp += strlen(cp);
1160 break;
1161 case 'a':
1162 case 'h':
1163 cp = addarg(cp, "-vh 180 -vv 180");
1164 break;
1165 }
1166 } else {
1167 while (!isspace(*vs)) /* else skip id */
1168 if (!*vs++)
1169 return(NULL);
1170 if (upax) { /* specify up vector */
1171 strcpy(cp, vup[upax+3]);
1172 cp += strlen(cp);
1173 }
1174 }
1175 if (cp == viewopts) /* append any additional options */
1176 vs++; /* skip prefixed space if unneeded */
1177 strcpy(cp, vs);
1178 #ifdef MSDOS
1179 if (strlen(viewopts) > 40) {
1180 setenv("VIEW", viewopts);
1181 return("$VIEW");
1182 }
1183 #endif
1184 return(viewopts);
1185 }
1186
1187
1188 char *
1189 getview(n, vn) /* get view n, or NULL if none */
1190 int n;
1191 char *vn; /* returned view name */
1192 {
1193 register char *mv;
1194
1195 if (viewselect != NULL) { /* command-line selected */
1196 if (n) /* only do one */
1197 return(NULL);
1198 if (viewselect[0] == '-') { /* already specified */
1199 if (vn != NULL) *vn = '\0';
1200 return(viewselect);
1201 }
1202 if (vn != NULL) {
1203 for (mv = viewselect; *mv && !isspace(*mv);
1204 *vn++ = *mv++)
1205 ;
1206 *vn = '\0';
1207 }
1208 /* view number? */
1209 if (isint(viewselect))
1210 return(specview(nvalue(vv+VIEW, atoi(viewselect)-1)));
1211 /* check list */
1212 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
1213 if (matchword(viewselect, mv))
1214 return(specview(mv));
1215 return(specview(viewselect)); /* standard view? */
1216 }
1217 mv = nvalue(vv+VIEW, n); /* use view n */
1218 if (vn != NULL & mv != NULL) {
1219 register char *mv2 = mv;
1220 if (*mv2 != '-')
1221 while (*mv2 && !isspace(*mv2))
1222 *vn++ = *mv2++;
1223 *vn = '\0';
1224 }
1225 return(specview(mv));
1226 }
1227
1228
1229 printview(vopts) /* print out selected view */
1230 register char *vopts;
1231 {
1232 extern char *atos(), *getenv();
1233 char buf[256];
1234 FILE *fp;
1235 register char *cp;
1236
1237 if (vopts == NULL)
1238 return(-1);
1239 fputs("VIEW=", stdout);
1240 do {
1241 if (matchword(vopts, "-vf")) { /* expand view file */
1242 vopts = sskip(vopts);
1243 if (!*atos(buf, sizeof(buf), vopts))
1244 return(-1);
1245 if ((fp = fopen(buf, "r")) == NULL)
1246 return(-1);
1247 for (buf[sizeof(buf)-2] = '\n';
1248 fgets(buf, sizeof(buf), fp) != NULL &&
1249 buf[0] != '\n';
1250 buf[sizeof(buf)-2] = '\n') {
1251 if (buf[sizeof(buf)-2] != '\n') {
1252 ungetc(buf[sizeof(buf)-2], fp);
1253 buf[sizeof(buf)-2] = '\0';
1254 }
1255 if (matchword(buf, "VIEW=") ||
1256 matchword(buf, "rview")) {
1257 for (cp = sskip(buf); *cp && *cp != '\n'; cp++)
1258 putchar(*cp);
1259 }
1260 }
1261 fclose(fp);
1262 vopts = sskip(vopts);
1263 } else {
1264 while (isspace(*vopts))
1265 vopts++;
1266 putchar(' ');
1267 #ifdef MSDOS
1268 if (*vopts == '$') { /* expand env. var. */
1269 if (!*atos(buf, sizeof(buf), vopts+1))
1270 return(-1);
1271 if ((cp = getenv(buf)) == NULL)
1272 return(-1);
1273 fputs(cp, stdout);
1274 vopts = sskip(vopts);
1275 } else
1276 #endif
1277 while (*vopts && !isspace(*vopts))
1278 putchar(*vopts++);
1279 }
1280 } while (*vopts++);
1281 putchar('\n');
1282 return(0);
1283 }
1284
1285
1286 rview(opts) /* run rview with first view */
1287 char *opts;
1288 {
1289 char *vw;
1290 char combuf[512];
1291 /* build command */
1292 if ((vw = getview(0, NULL)) == NULL)
1293 return;
1294 if (sayview)
1295 printview(vw);
1296 sprintf(combuf, "rview %s%s -R %s ", vw, opts, rifname);
1297 if (rvdevice != NULL)
1298 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1299 if (vdef(EXPOSURE))
1300 sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE));
1301 strcat(combuf, oct1name);
1302 if (runcom(combuf)) { /* run it */
1303 fprintf(stderr, "%s: error running rview\n", progname);
1304 exit(1);
1305 }
1306 }
1307
1308
1309 rpict(opts) /* run rpict and pfilt for each view */
1310 char *opts;
1311 {
1312 char combuf[1024];
1313 char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32];
1314 char pfopts[128];
1315 char vs[32], *vw;
1316 int vn, mult;
1317 /* get pfilt options */
1318 pfiltopts(pfopts);
1319 /* get resolution, reporting */
1320 switch (vscale(QUALITY)) {
1321 case LOW:
1322 mult = 1;
1323 break;
1324 case MEDIUM:
1325 mult = 2;
1326 break;
1327 case HIGH:
1328 mult = 3;
1329 break;
1330 }
1331 {
1332 int xres, yres;
1333 double aspect;
1334 int n;
1335 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1336 if (n == 3)
1337 sprintf(res, "-x %d -y %d -pa %.3f",
1338 mult*xres, mult*yres, aspect);
1339 else if (n) {
1340 if (n == 1) yres = xres;
1341 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1342 } else
1343 badvalue(RESOLUTION);
1344 }
1345 rep[0] = '\0';
1346 if (vdef(REPORT)) {
1347 double minutes;
1348 int n;
1349 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1350 if (n == 2)
1351 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1352 else if (n == 1)
1353 sprintf(rep, " -t %d", (int)(minutes*60));
1354 else
1355 badvalue(REPORT);
1356 }
1357 /* do each view */
1358 vn = 0;
1359 while ((vw = getview(vn++, vs)) != NULL) {
1360 if (sayview)
1361 printview(vw);
1362 if (!vs[0])
1363 sprintf(vs, "%d", vn);
1364 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1365 /* check date on picture */
1366 if (fdate(picfile) >= oct1date)
1367 continue;
1368 /* build rpict command */
1369 sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs);
1370 if (fdate(rawfile) >= oct1date) /* recover */
1371 sprintf(combuf, "rpict%s%s -ro %s %s",
1372 rep, opts, rawfile, oct1name);
1373 else {
1374 if (overture) { /* run overture calculation */
1375 sprintf(combuf,
1376 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1377 rep, vw, opts,
1378 oct1name, overfile);
1379 if (runcom(combuf)) {
1380 fprintf(stderr,
1381 "%s: error in overture for view %s\n",
1382 progname, vs);
1383 exit(1);
1384 }
1385 #ifdef NIX
1386 rmfile(overfile);
1387 #endif
1388 }
1389 sprintf(combuf, "rpict%s %s %s%s %s > %s",
1390 rep, vw, res, opts,
1391 oct1name, rawfile);
1392 }
1393 if (runcom(combuf)) { /* run rpict */
1394 fprintf(stderr, "%s: error rendering view %s\n",
1395 progname, vs);
1396 exit(1);
1397 }
1398 /* build pfilt command */
1399 if (mult > 1)
1400 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1401 pfopts, mult, mult, rawfile, picfile);
1402 else
1403 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1404 rawfile, picfile);
1405 if (runcom(combuf)) { /* run pfilt */
1406 fprintf(stderr,
1407 "%s: error filtering view %s\n\t%s removed\n",
1408 progname, vs, picfile);
1409 unlink(picfile);
1410 exit(1);
1411 }
1412 /* remove raw file */
1413 rmfile(rawfile);
1414 }
1415 }
1416
1417
1418 runcom(cs) /* run command */
1419 char *cs;
1420 {
1421 if (!silent) /* echo it */
1422 printf("\t%s\n", cs);
1423 if (noaction)
1424 return(0);
1425 fflush(stdout); /* flush output and pass to shell */
1426 return(system(cs));
1427 }
1428
1429
1430 rmfile(fn) /* remove a file */
1431 char *fn;
1432 {
1433 if (!silent)
1434 #ifdef MSDOS
1435 printf("\tdel %s\n", fn);
1436 #else
1437 printf("\trm -f %s\n", fn);
1438 #endif
1439 if (noaction)
1440 return(0);
1441 return(unlink(fn));
1442 }
1443
1444
1445 #ifdef MSDOS
1446 setenv(vname, value) /* set an environment variable */
1447 char *vname, *value;
1448 {
1449 register char *evp;
1450
1451 evp = bmalloc(strlen(vname)+strlen(value)+2);
1452 if (evp == NULL)
1453 syserr(progname);
1454 sprintf(evp, "%s=%s", vname, value);
1455 if (putenv(evp) != 0) {
1456 fprintf(stderr, "%s: out of environment space\n", progname);
1457 exit(1);
1458 }
1459 if (!silent)
1460 printf("set %s\n", evp);
1461 }
1462 #endif
1463
1464
1465 badvalue(vc) /* report bad variable value and exit */
1466 int vc;
1467 {
1468 fprintf(stderr, "%s: bad value for variable '%s'\n",
1469 progname, vnam(vc));
1470 exit(1);
1471 }
1472
1473
1474 syserr(s) /* report a system error and exit */
1475 char *s;
1476 {
1477 perror(s);
1478 exit(1);
1479 }
