Revision: 2.21
Committed: Tue Aug 24 22:14:21 1993 UTC (30 years, 7 months ago) by greg
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Executive program for oconv, rpict and pfilt
9 */
10
11 #include "standard.h"
12 #include "paths.h"
13 #include <ctype.h>
14
15
16 typedef struct {
17 char *name; /* variable name */
18 short nick; /* # characters required for nickname */
19 short nass; /* # assignments made */
20 char *value; /* assigned value(s) */
21 int (*fixval)(); /* assignment checking function */
22 } VARIABLE;
23
24 int onevalue(), catvalues();
25
26 /* variables */
27 #define OBJECT 0 /* object files */
28 #define SCENE 1 /* scene files */
29 #define MATERIAL 2 /* material files */
30 #define RENDER 3 /* rendering options */
31 #define OCONV 4 /* oconv options */
32 #define PFILT 5 /* pfilt options */
33 #define VIEW 6 /* view(s) for picture(s) */
34 #define ZONE 7 /* simulation zone */
35 #define QUALITY 8 /* desired rendering quality */
36 #define OCTREE 9 /* octree file name */
37 #define PICTURE 10 /* picture file name */
38 #define AMBFILE 11 /* ambient file name */
39 #define OPTFILE 12 /* rendering options file */
40 #define EXPOSURE 13 /* picture exposure setting */
41 #define RESOLUTION 14 /* maximum picture resolution */
42 #define UP 15 /* view up (X, Y or Z) */
43 #define INDIRECT 16 /* indirection in lighting */
44 #define DETAIL 17 /* level of scene detail */
45 #define PENUMBRAS 18 /* shadow penumbras are desired */
46 #define VARIABILITY 19 /* level of light variability */
47 #define REPORT 20 /* report frequency and errfile */
48 /* total number of variables */
49 #define NVARS 21
50
51 VARIABLE vv[NVARS] = { /* variable-value pairs */
52 {"objects", 3, 0, NULL, catvalues},
53 {"scene", 3, 0, NULL, catvalues},
54 {"materials", 3, 0, NULL, catvalues},
55 {"render", 3, 0, NULL, catvalues},
56 {"oconv", 3, 0, NULL, catvalues},
57 {"pfilt", 2, 0, NULL, catvalues},
58 {"view", 2, 0, NULL, NULL},
59 {"ZONE", 2, 0, NULL, onevalue},
60 {"QUALITY", 3, 0, NULL, onevalue},
61 {"OCTREE", 3, 0, NULL, onevalue},
62 {"PICTURE", 3, 0, NULL, onevalue},
63 {"AMBFILE", 3, 0, NULL, onevalue},
64 {"OPTFILE", 3, 0, NULL, onevalue},
65 {"EXPOSURE", 3, 0, NULL, onevalue},
66 {"RESOLUTION", 3, 0, NULL, onevalue},
67 {"UP", 2, 0, NULL, onevalue},
68 {"INDIRECT", 3, 0, NULL, onevalue},
69 {"DETAIL", 3, 0, NULL, onevalue},
70 {"PENUMBRAS", 3, 0, NULL, onevalue},
71 {"VARIABILITY", 3, 0, NULL, onevalue},
72 {"REPORT", 3, 0, NULL, onevalue},
73 };
74
75 VARIABLE *matchvar();
76 char *nvalue();
77 int vscale();
78
79 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
80
81 #define vnam(vc) (vv[vc].name)
82 #define vdef(vc) (vv[vc].nass)
83 #define vval(vc) (vv[vc].value)
84 #define vint(vc) atoi(vval(vc))
85 #define vlet(vc) UPPER(vval(vc)[0])
86 #define vbool(vc) (vlet(vc)=='T')
87
88 #define HIGH 2
89 #define MEDIUM 1
90 #define LOW 0
91
92 int lowqopts(), medqopts(), hiqopts();
93 int (*setqopts[3])() = {lowqopts, medqopts, hiqopts};
94
95 #define renderopts (*setqopts[vscale(QUALITY)])
96
97 /* overture calculation file */
98 #ifdef NIX
99 char overfile[] = "overture.raw";
100 #else
101 char overfile[] = "/dev/null";
102 #endif
103
104 extern long fdate(), time();
105
106 long scenedate; /* date of latest scene or object file */
107 long octreedate; /* date of octree */
108 long matdate; /* date of latest material file */
109
110 int explicate = 0; /* explicate variables */
111 int silent = 0; /* do work silently */
112 int noaction = 0; /* don't do anything */
113 int sayview = 0; /* print view out */
114 char *rvdevice = NULL; /* rview output device */
115 char *viewselect = NULL; /* specific view only */
116
117 int overture = 0; /* overture calculation needed */
118
119 char *progname; /* global argv[0] */
120
121 char radname[MAXPATH]; /* root Radiance file name */
122
123
124 main(argc, argv)
125 int argc;
126 char *argv[];
127 {
128 char ropts[512];
129 int i;
130
131 progname = argv[0];
132 /* get options */
133 for (i = 1; i < argc && argv[i][0] == '-'; i++)
134 switch (argv[i][1]) {
135 case 's':
136 silent++;
137 break;
138 case 'n':
139 noaction++;
140 break;
141 case 'e':
142 explicate++;
143 break;
144 case 'o':
145 rvdevice = argv[++i];
146 break;
147 case 'V':
148 sayview++;
149 break;
150 case 'v':
151 viewselect = argv[++i];
152 break;
153 default:
154 goto userr;
155 }
156 if (i >= argc)
157 goto userr;
158 /* assign Radiance root file name */
159 rootname(radname, argv[i]);
160 /* load variable values */
161 load(argv[i]);
162 /* get any additional assignments */
163 for (i++; i < argc; i++)
164 setvariable(argv[i]);
165 /* check assignments */
166 checkvalues();
167 /* check files and dates */
168 checkfiles();
169 /* set default values as necessary */
170 setdefaults();
171 /* print all values if requested */
172 if (explicate)
173 printvals();
174 /* build octree */
175 oconv();
176 /* check date on ambient file */
177 checkambfile();
178 /* run simulation */
179 renderopts(ropts);
180 xferopts(ropts);
181 if (rvdevice != NULL)
182 rview(ropts);
183 else
184 rpict(ropts);
185 exit(0);
186 userr:
187 fprintf(stderr,
188 "Usage: %s [-s][-n][-e][-v view][-o dev] rfile [VAR=value ..]\n",
189 progname);
190 exit(1);
191 }
192
193
194 rootname(rn, fn) /* remove tail from end of fn */
195 register char *rn, *fn;
196 {
197 char *tp, *dp;
198
199 for (tp = NULL, dp = rn; *rn = *fn++; rn++)
200 if (ISDIRSEP(*rn))
201 dp = rn;
202 else if (*rn == '.')
203 tp = rn;
204 if (tp != NULL && tp > dp)
205 *tp = '\0';
206 }
207
208
209 load(rfname) /* load Radiance simulation file */
210 char *rfname;
211 {
212 FILE *fp;
213 char buf[512];
214 register char *cp;
215
216 if (rfname == NULL)
217 fp = stdin;
218 else if ((fp = fopen(rfname, "r")) == NULL)
219 syserr(rfname);
220 while (fgetline(buf, sizeof(buf), fp) != NULL) {
221 for (cp = buf; *cp; cp++) {
222 switch (*cp) {
223 case '\\':
224 case '\n':
225 *cp = ' ';
226 continue;
227 case '#':
228 *cp = '\0';
229 break;
230 default:
231 continue;
232 }
233 break;
234 }
235 setvariable(buf);
236 }
237 fclose(fp);
238 }
239
240
241 setvariable(ass) /* assign variable according to string */
242 register char *ass;
243 {
244 char varname[32];
245 register char *cp;
246 register VARIABLE *vp;
247 register int i;
248 int n;
249
250 while (isspace(*ass)) /* skip leading space */
251 ass++;
252 cp = varname; /* extract name */
253 while (cp < varname+sizeof(varname)-1
254 && *ass && !isspace(*ass) && *ass != '=')
255 *cp++ = *ass++;
256 *cp = '\0';
257 if (!varname[0])
258 return; /* no variable name! */
259 /* trim value */
260 while (isspace(*ass) || *ass == '=')
261 ass++;
262 cp = ass + strlen(ass);
263 do
264 *cp-- = '\0';
265 while (cp >= ass && isspace(*cp));
266 n = cp - ass + 1;
267 if (!n) {
268 fprintf(stderr, "%s: warning - missing value for variable '%s'\n",
269 progname, varname);
270 return;
271 }
272 /* match variable from list */
273 vp = matchvar(varname);
274 if (vp == NULL) {
275 fprintf(stderr, "%s: unknown variable '%s'\n",
276 progname, varname);
277 exit(1);
278 }
279 /* assign new value */
280 if (i = vp->nass) {
281 cp = vp->value;
282 while (i--)
283 while (*cp++)
284 ;
285 i = cp - vp->value;
286 vp->value = realloc(vp->value, i+n+1);
287 } else
288 vp->value = malloc(n+1);
289 if (vp->value == NULL)
290 syserr(progname);
291 strcpy(vp->value+i, ass);
292 vp->nass++;
293 }
294
295
296 VARIABLE *
297 matchvar(nam) /* match a variable by its name */
298 char *nam;
299 {
300 int n = strlen(nam);
301 register int i;
302
303 for (i = 0; i < NVARS; i++)
304 if (n >= vv[i].nick && !strncmp(nam, vv[i].name, n))
305 return(vv+i);
306 return(NULL);
307 }
308
309
310 char *
311 nvalue(vp, n) /* return nth variable value */
312 VARIABLE *vp;
313 register int n;
314 {
315 register char *cp;
316
317 if (vp == NULL | n < 0 | n >= vp->nass)
318 return(NULL);
319 cp = vp->value;
320 while (n--)
321 while (*cp++)
322 ;
323 return(cp);
324 }
325
326
327 int
328 vscale(vc) /* return scale for variable vc */
329 int vc;
330 {
331 switch(vlet(vc)) {
332 case 'H':
333 return(HIGH);
334 case 'M':
335 return(MEDIUM);
336 case 'L':
337 return(LOW);
338 }
339 badvalue(vc);
340 }
341
342
343 checkvalues() /* check assignments */
344 {
345 register int i;
346
347 for (i = 0; i < NVARS; i++)
348 if (vv[i].fixval != NULL)
349 (*vv[i].fixval)(vv+i);
350 }
351
352
353 onevalue(vp) /* only one assignment for this variable */
354 register VARIABLE *vp;
355 {
356 if (vp->nass < 2)
357 return;
358 fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n",
359 progname, vp->name);
360 do
361 vp->value += strlen(vp->value)+1;
362 while (--vp->nass > 1);
363 }
364
365
366 catvalues(vp) /* concatenate variable values */
367 register VARIABLE *vp;
368 {
369 register char *cp;
370
371 if (vp->nass < 2)
372 return;
373 for (cp = vp->value; vp->nass > 1; vp->nass--) {
374 while (*cp)
375 cp++;
376 *cp++ = ' ';
377 }
378 }
379
380
381 long
382 checklast(fnames) /* check files and find most recent */
383 register char *fnames;
384 {
385 char thisfile[MAXPATH];
386 long thisdate, lastdate = -1;
387 register char *cp;
388
389 while (*fnames) {
390 while (isspace(*fnames)) fnames++;
391 cp = thisfile;
392 while (*fnames && !isspace(*fnames))
393 *cp++ = *fnames++;
394 *cp = '\0';
395 if ((thisdate = fdate(thisfile)) < 0)
396 syserr(thisfile);
397 if (thisdate > lastdate)
398 lastdate = thisdate;
399 }
400 return(lastdate);
401 }
402
403
404 checkfiles() /* check for existence and modified times */
405 {
406 char *cp;
407 long objdate;
408
409 if (!vdef(OCTREE)) {
410 if ((cp = bmalloc(strlen(radname)+5)) == NULL)
411 syserr(progname);
412 sprintf(cp, "%s.oct", radname);
413 vval(OCTREE) = cp;
414 vdef(OCTREE)++;
415 }
416 octreedate = fdate(vval(OCTREE));
417 scenedate = -1;
418 if (vdef(SCENE)) {
419 scenedate = checklast(vval(SCENE));
420 if (vdef(OBJECT)) {
421 objdate = checklast(vval(OBJECT));
422 if (objdate > scenedate)
423 scenedate = objdate;
424 }
425 }
426 if (octreedate < 0 & scenedate < 0) {
427 fprintf(stderr, "%s: need '%s' or '%s'\n", progname,
428 vnam(OCTREE), vnam(SCENE));
429 exit(1);
430 }
431 matdate = -1;
432 if (vdef(MATERIAL))
433 matdate = checklast(vval(MATERIAL));
434 }
435
436
437 getoctcube(org, sizp) /* get octree bounding cube */
438 double org[3], *sizp;
439 {
440 extern FILE *popen();
441 static double oorg[3], osiz = 0.;
442 char buf[MAXPATH+16];
443 FILE *fp;
444
445 if (osiz <= FTINY) {
446 oconv(); /* does nothing if done already */
447 sprintf(buf, "getinfo -d < %s", vval(OCTREE));
448 if ((fp = popen(buf, "r")) == NULL)
449 syserr("getinfo");
450 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
451 &oorg[2], &osiz) != 4) {
452 fprintf(stderr,
453 "%s: error reading bounding cube from getinfo\n",
454 progname);
455 exit(1);
456 }
457 pclose(fp);
458 }
459 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
460 }
461
462
463 setdefaults() /* set default values for unassigned var's */
464 {
465 double org[3], size;
466 char buf[128];
467
468 if (!vdef(ZONE)) {
469 getoctcube(org, &size);
470 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
471 org[1], org[1]+size, org[2], org[2]+size);
472 vval(ZONE) = savqstr(buf);
473 vdef(ZONE)++;
474 }
475 if (!vdef(INDIRECT)) {
476 vval(INDIRECT) = "0";
477 vdef(INDIRECT)++;
478 }
479 if (!vdef(QUALITY)) {
480 vval(QUALITY) = "L";
481 vdef(QUALITY)++;
482 }
483 if (!vdef(RESOLUTION)) {
484 vval(RESOLUTION) = "512";
485 vdef(RESOLUTION)++;
486 }
487 if (!vdef(PICTURE)) {
488 vval(PICTURE) = radname;
489 vdef(PICTURE)++;
490 }
491 if (!vdef(VIEW)) {
492 vval(VIEW) = "X";
493 vdef(VIEW)++;
494 }
495 if (!vdef(DETAIL)) {
496 vval(DETAIL) = "M";
497 vdef(DETAIL)++;
498 }
499 if (!vdef(PENUMBRAS)) {
500 vval(PENUMBRAS) = "F";
501 vdef(PENUMBRAS)++;
502 }
503 if (!vdef(VARIABILITY)) {
504 vval(VARIABILITY) = "L";
505 vdef(VARIABILITY)++;
506 }
507 }
508
509
510 printvals() /* print variable values */
511 {
512 register int i, j;
513
514 for (i = 0; i < NVARS; i++)
515 for (j = 0; j < vdef(i); j++)
516 printf("%s= %s\n", vnam(i), nvalue(vv+i, j));
517 fflush(stdout);
518 }
519
520
521 oconv() /* run oconv if necessary */
522 {
523 char combuf[512], ocopts[64];
524
525 if (octreedate >= scenedate) /* check dates */
526 return;
527 /* build command */
528 oconvopts(ocopts);
529 if (vdef(MATERIAL))
530 sprintf(combuf, "oconv%s %s %s > %s", ocopts,
531 vval(MATERIAL), vval(SCENE), vval(OCTREE));
532 else
533 sprintf(combuf, "oconv%s %s > %s", ocopts,
534 vval(SCENE), vval(OCTREE));
535
536 if (runcom(combuf)) { /* run it */
537 fprintf(stderr, "%s: error generating octree\n\t%s removed\n",
538 progname, vval(OCTREE));
539 unlink(vval(OCTREE));
540 exit(1);
541 }
542 octreedate = time(0);
543 }
544
545
546 char *
547 addarg(op, arg) /* add argument and advance pointer */
548 register char *op, *arg;
549 {
550 *op = ' ';
551 while (*++op = *arg++)
552 ;
553 return(op);
554 }
555
556
557 oconvopts(oo) /* get oconv options */
558 register char *oo;
559 {
560 /* BEWARE: This may be called via setdefaults(), so no assumptions */
561
562 *oo = '\0';
563 if (vdef(OCONV))
564 addarg(oo, vval(OCONV));
565 }
566
567
568 checkambfile() /* check date on ambient file */
569 {
570 long afdate;
571
572 if (!vdef(AMBFILE))
573 return;
574 if ((afdate = fdate(vval(AMBFILE))) < 0)
575 return;
576 if (octreedate > afdate | matdate > afdate)
577 rmfile(vval(AMBFILE));
578 }
579
580
581 double
582 ambval() /* compute ambient value */
583 {
584 if (vdef(EXPOSURE)) {
585 if (!isflt(vval(EXPOSURE)))
586 badvalue(EXPOSURE);
587 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
588 return(.5/pow(2.,atof(vval(EXPOSURE))));
589 return(.5/atof(vval(EXPOSURE)));
590 }
591 if (vlet(ZONE) == 'E')
592 return(10.);
593 if (vlet(ZONE) == 'I')
594 return(.01);
595 badvalue(ZONE);
596 }
597
598
599 lowqopts(op) /* low quality rendering options */
600 register char *op;
601 {
602 double d, org[3], siz[3];
603
604 *op = '\0';
605 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
606 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
607 badvalue(ZONE);
608 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
609 getoctcube(org, &d);
610 d *= 3./(siz[0]+siz[1]+siz[2]);
611 switch (vscale(DETAIL)) {
612 case LOW:
613 op = addarg(op, "-ps 16 -dp 16");
614 sprintf(op, " -ar %d", (int)(4*d));
615 op += strlen(op);
616 break;
617 case MEDIUM:
618 op = addarg(op, "-ps 8 -dp 32");
619 sprintf(op, " -ar %d", (int)(8*d));
620 op += strlen(op);
621 break;
622 case HIGH:
623 op = addarg(op, "-ps 4 -dp 64");
624 sprintf(op, " -ar %d", (int)(16*d));
625 op += strlen(op);
626 break;
627 }
628 op = addarg(op, "-pt .16");
629 if (vbool(PENUMBRAS))
630 op = addarg(op, "-ds .4");
631 else
632 op = addarg(op, "-ds 0");
633 op = addarg(op, "-dt .2 -dc .25 -dr 0 -sj 0 -st .5");
634 if (vdef(AMBFILE)) {
635 sprintf(op, " -af %s", vval(AMBFILE));
636 op += strlen(op);
637 } else
638 overture = 0;
639 switch (vscale(VARIABILITY)) {
640 case LOW:
641 op = addarg(op, "-aa .4 -ad 64");
642 break;
643 case MEDIUM:
644 op = addarg(op, "-aa .3 -ad 128");
645 break;
646 case HIGH:
647 op = addarg(op, "-aa .25 -ad 256");
648 break;
649 }
650 op = addarg(op, "-as 0");
651 d = ambval();
652 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
653 op += strlen(op);
654 op = addarg(op, "-lr 3 -lw .02");
655 if (vdef(RENDER))
656 op = addarg(op, vval(RENDER));
657 }
658
659
660 medqopts(op) /* medium quality rendering options */
661 register char *op;
662 {
663 double d, org[3], siz[3];
664
665 *op = '\0';
666 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
667 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
668 badvalue(ZONE);
669 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
670 getoctcube(org, &d);
671 d *= 3./(siz[0]+siz[1]+siz[2]);
672 switch (vscale(DETAIL)) {
673 case LOW:
674 op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
675 op = addarg(op, "-dp 64");
676 sprintf(op, " -ar %d", (int)(8*d));
677 op += strlen(op);
678 break;
679 case MEDIUM:
680 op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
681 op = addarg(op, "-dp 128");
682 sprintf(op, " -ar %d", (int)(16*d));
683 op += strlen(op);
684 break;
685 case HIGH:
686 op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
687 op = addarg(op, "-dp 256");
688 sprintf(op, " -ar %d", (int)(32*d));
689 op += strlen(op);
690 break;
691 }
692 op = addarg(op, "-pt .08");
693 if (vbool(PENUMBRAS))
694 op = addarg(op, "-ds .2 -dj .35");
695 else
696 op = addarg(op, "-ds .3");
697 op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1");
698 if (overture = vint(INDIRECT)) {
699 sprintf(op, " -ab %d", overture);
700 op += strlen(op);
701 }
702 if (vdef(AMBFILE)) {
703 sprintf(op, " -af %s", vval(AMBFILE));
704 op += strlen(op);
705 } else
706 overture = 0;
707 switch (vscale(VARIABILITY)) {
708 case LOW:
709 op = addarg(op, "-aa .25 -ad 196 -as 0");
710 break;
711 case MEDIUM:
712 op = addarg(op, "-aa .2 -ad 400 -as 64");
713 break;
714 case HIGH:
715 op = addarg(op, "-aa .15 -ad 768 -as 196");
716 break;
717 }
718 d = ambval();
719 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
720 op += strlen(op);
721 op = addarg(op, "-lr 6 -lw .002");
722 if (vdef(RENDER))
723 op = addarg(op, vval(RENDER));
724 }
725
726
727 hiqopts(op) /* high quality rendering options */
728 register char *op;
729 {
730 double d, org[3], siz[3];
731
732 *op = '\0';
733 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
734 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
735 badvalue(ZONE);
736 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
737 getoctcube(org, &d);
738 d *= 3./(siz[0]+siz[1]+siz[2]);
739 switch (vscale(DETAIL)) {
740 case LOW:
741 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
742 op = addarg(op, "-dp 256");
743 sprintf(op, " -ar %d", (int)(16*d));
744 op += strlen(op);
745 break;
746 case MEDIUM:
747 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
748 op = addarg(op, "-dp 512");
749 sprintf(op, " -ar %d", (int)(32*d));
750 op += strlen(op);
751 break;
752 case HIGH:
753 op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
754 op = addarg(op, "-dp 1024");
755 sprintf(op, " -ar %d", (int)(64*d));
756 op += strlen(op);
757 break;
758 }
759 op = addarg(op, "-pt .04");
760 if (vbool(PENUMBRAS))
761 op = addarg(op, "-ds .1 -dj .7");
762 else
763 op = addarg(op, "-ds .2");
764 op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01");
765 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
766 op += strlen(op);
767 if (vdef(AMBFILE)) {
768 sprintf(op, " -af %s", vval(AMBFILE));
769 op += strlen(op);
770 } else
771 overture = 0;
772 switch (vscale(VARIABILITY)) {
773 case LOW:
774 op = addarg(op, "-aa .15 -ad 256 -as 0");
775 break;
776 case MEDIUM:
777 op = addarg(op, "-aa .125 -ad 512 -as 256");
778 break;
779 case HIGH:
780 op = addarg(op, "-aa .08 -ad 1024 -as 512");
781 break;
782 }
783 d = ambval();
784 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
785 op += strlen(op);
786 op = addarg(op, "-lr 12 -lw .0005");
787 if (vdef(RENDER))
788 op = addarg(op, vval(RENDER));
789 }
790
791
792 xferopts(ro) /* transfer options if indicated */
793 char *ro;
794 {
795 int fd, n;
796 register char *cp;
797
798 n = strlen(ro);
799 if (n < 2)
800 return;
801 if (vdef(OPTFILE)) {
802 for (cp = ro; cp[1]; cp++)
803 if (isspace(cp[1]) && cp[2] == '-' && isalpha(cp[3]))
804 *cp = '\n';
805 else
806 *cp = cp[1];
807 *cp = '\n';
808 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
809 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
810 syserr(vval(OPTFILE));
811 sprintf(ro, " @%s", vval(OPTFILE));
812 }
813 #ifdef MSDOS
814 else if (n > 50) {
815 setenv("ROPT", ro+1);
816 strcpy(ro, " $ROPT");
817 }
818 #endif
819 }
820
821
822 pfiltopts(po) /* get pfilt options */
823 register char *po;
824 {
825 *po = '\0';
826 if (vdef(EXPOSURE)) {
827 po = addarg(po, "-1 -e");
828 po = addarg(po, vval(EXPOSURE));
829 }
830 switch (vscale(QUALITY)) {
831 case MEDIUM:
832 po = addarg(po, "-r 1");
833 break;
834 case HIGH:
835 po = addarg(po, "-m .25");
836 break;
837 }
838 if (vdef(PFILT))
839 po = addarg(po, vval(PFILT));
840 }
841
842
843 matchword(s1, s2) /* match white-delimited words */
844 register char *s1, *s2;
845 {
846 while (isspace(*s1)) s1++;
847 while (isspace(*s2)) s2++;
848 while (*s1 && !isspace(*s1))
849 if (*s1++ != *s2++)
850 return(0);
851 return(!*s2 || isspace(*s2));
852 }
853
854
855 char *
856 specview(vs) /* get proper view spec from vs */
857 register char *vs;
858 {
859 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
860 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
861 static char viewopts[128];
862 register char *cp;
863 int xpos, ypos, zpos, viewtype, upax;
864 register int i;
865 double cent[3], dim[3], mult, d;
866
867 if (vs == NULL || *vs == '-')
868 return(vs);
869 upax = 0; /* get the up vector */
870 if (vdef(UP)) {
871 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
872 upax = 1-'X'+UPPER(vval(UP)[1]);
873 else
874 upax = 1-'X'+vlet(UP);
875 if (upax < 1 | upax > 3)
876 badvalue(UP);
877 if (vval(UP)[0] == '-')
878 upax = -upax;
879 }
880 /* check standard view names */
881 xpos = ypos = zpos = 0;
882 if (*vs == 'X') {
883 xpos = 1; vs++;
884 } else if (*vs == 'x') {
885 xpos = -1; vs++;
886 }
887 if (*vs == 'Y') {
888 ypos = 1; vs++;
889 } else if (*vs == 'y') {
890 ypos = -1; vs++;
891 }
892 if (*vs == 'Z') {
893 zpos = 1; vs++;
894 } else if (*vs == 'z') {
895 zpos = -1; vs++;
896 }
897 viewtype = 'v';
898 if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h')
899 viewtype = *vs++;
900 cp = viewopts;
901 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
902 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
903 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
904 &cent[0], &dim[0], &cent[1], &dim[1],
905 &cent[2], &dim[2]) != 6)
906 badvalue(ZONE);
907 for (i = 0; i < 3; i++) {
908 dim[i] -= cent[i];
909 cent[i] += .5*dim[i];
910 }
911 mult = vlet(ZONE)=='E' ? 2. : .45 ;
912 sprintf(cp, " -vp %.2g %.2g %.2g -vd %.2g %.2g %.2g",
913 cent[0]+xpos*mult*dim[0],
914 cent[1]+ypos*mult*dim[1],
915 cent[2]+zpos*mult*dim[2],
916 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
917 cp += strlen(cp);
918 /* redirect up axis if necessary */
919 switch (upax) {
920 case 3: /* plus or minus Z axis */
921 case -3:
922 case 0:
923 if (!(xpos|ypos))
924 upax = 2;
925 break;
926 case 2: /* plus or minus Y axis */
927 case -2:
928 if (!(xpos|zpos))
929 upax = 1;
930 break;
931 case 1: /* plus or minus X axis */
932 case -1:
933 if (!(ypos|zpos))
934 upax = 3;
935 break;
936 }
937 cp = addarg(cp, vup[upax+3]);
938 switch (viewtype) {
939 case 'v':
940 cp = addarg(cp, "-vh 45 -vv 45");
941 break;
942 case 'l':
943 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
944 sprintf(cp, " -vh %.2g -vv %.2g", d, d);
945 cp += strlen(cp);
946 break;
947 case 'a':
948 case 'h':
949 cp = addarg(cp, "-vh 180 -vv 180");
950 break;
951 }
952 } else {
953 while (!isspace(*vs)) /* else skip id */
954 if (!*vs++)
955 return(NULL);
956 if (upax) { /* specify up vector */
957 strcpy(cp, vup[upax+3]);
958 cp += strlen(cp);
959 }
960 }
961 strcpy(cp, vs); /* append any additional options */
962 #ifdef MSDOS
963 if (strlen(viewopts) > 40) {
964 setenv("VIEW", viewopts);
965 return("$VIEW");
966 }
967 #endif
968 return(viewopts);
969 }
970
971
972 char *
973 getview(n, vn) /* get view n, or NULL if none */
974 int n;
975 char *vn; /* returned view name */
976 {
977 register char *mv;
978
979 if (viewselect != NULL) { /* command-line selected */
980 if (n) /* only do one */
981 return(NULL);
982 if (viewselect[0] == '-') { /* already specified */
983 if (vn != NULL) *vn = '\0';
984 return(viewselect);
985 }
986 if (vn != NULL) {
987 for (mv = viewselect; *mv && !isspace(*mv);
988 *vn++ = *mv++)
989 ;
990 *vn = '\0';
991 }
992 /* view number? */
993 if (isint(viewselect))
994 return(specview(nvalue(vv+VIEW, atoi(viewselect)-1)));
995 /* check list */
996 while ((mv = nvalue(vv+VIEW, n++)) != NULL)
997 if (matchword(viewselect, mv))
998 return(specview(mv));
999 return(specview(viewselect)); /* standard view? */
1000 }
1001 mv = nvalue(vv+VIEW, n); /* use view n */
1002 if (vn != NULL & mv != NULL) {
1003 register char *mv2 = mv;
1004 if (*mv2 != '-')
1005 while (*mv2 && !isspace(*mv2))
1006 *vn++ = *mv2++;
1007 *vn = '\0';
1008 }
1009 return(specview(mv));
1010 }
1011
1012
1013 printview(vopts) /* print out selected view */
1014 register char *vopts;
1015 {
1016 extern char *atos();
1017 char buf[256];
1018 FILE *fp;
1019 register char *cp;
1020
1021 if (vopts == NULL)
1022 return(-1);
1023 fputs("VIEW=", stdout);
1024 do {
1025 if (matchword(vopts, "-vf")) { /* expand view file */
1026 vopts = sskip(vopts);
1027 if (!*atos(buf, sizeof(buf), vopts))
1028 return(-1);
1029 if ((fp = fopen(buf, "r")) == NULL)
1030 return(-1);
1031 for (buf[sizeof(buf)-2] = '\n';
1032 fgets(buf, sizeof(buf), fp) != NULL &&
1033 buf[0] != '\n';
1034 buf[sizeof(buf)-2] = '\n') {
1035 if (buf[sizeof(buf)-2] != '\n') {
1036 ungetc(buf[sizeof(buf)-2], fp);
1037 buf[sizeof(buf)-2] = '\0';
1038 }
1039 if (matchword(buf, "VIEW=") ||
1040 matchword(buf, "rview")) {
1041 for (cp = sskip(buf); *cp && *cp != '\n'; cp++)
1042 putchar(*cp);
1043 }
1044 }
1045 fclose(fp);
1046 vopts = sskip(vopts);
1047 } else {
1048 while (isspace(*vopts))
1049 vopts++;
1050 putchar(' ');
1051 while (*vopts && !isspace(*vopts))
1052 putchar(*vopts++);
1053 }
1054 } while (*vopts++);
1055 putchar('\n');
1056 return(0);
1057 }
1058
1059
1060 rview(opts) /* run rview with first view */
1061 char *opts;
1062 {
1063 char *vw;
1064 char combuf[512];
1065 /* build command */
1066 if ((vw = getview(0, NULL)) == NULL)
1067 return;
1068 if (sayview)
1069 printview(vw);
1070 sprintf(combuf, "rview %s%s ", vw, opts);
1071 if (rvdevice != NULL)
1072 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1073 strcat(combuf, vval(OCTREE));
1074 if (runcom(combuf)) { /* run it */
1075 fprintf(stderr, "%s: error running rview\n", progname);
1076 exit(1);
1077 }
1078 }
1079
1080
1081 rpict(opts) /* run rpict and pfilt for each view */
1082 char *opts;
1083 {
1084 char combuf[1024];
1085 char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32];
1086 char pfopts[128];
1087 char vs[32], *vw;
1088 int vn, mult;
1089 long lastdate;
1090 /* get pfilt options */
1091 pfiltopts(pfopts);
1092 /* get resolution, reporting */
1093 mult = vscale(QUALITY)+1;
1094 {
1095 int xres, yres;
1096 double aspect;
1097 int n;
1098 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1099 if (n == 3)
1100 sprintf(res, "-x %d -y %d -pa %.3f",
1101 mult*xres, mult*yres, aspect);
1102 else if (n) {
1103 if (n == 1) yres = xres;
1104 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1105 } else
1106 badvalue(RESOLUTION);
1107 }
1108 rep[0] = '\0';
1109 if (vdef(REPORT)) {
1110 double minutes;
1111 int n;
1112 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1113 if (n == 2)
1114 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1115 else if (n == 1)
1116 sprintf(rep, " -t %d", (int)(minutes*60));
1117 else
1118 badvalue(REPORT);
1119 }
1120 /* get update time */
1121 lastdate = octreedate > matdate ? octreedate : matdate;
1122 /* do each view */
1123 vn = 0;
1124 while ((vw = getview(vn++, vs)) != NULL) {
1125 if (sayview)
1126 printview(vw);
1127 if (!vs[0])
1128 sprintf(vs, "%d", vn);
1129 sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs);
1130 /* check date on picture */
1131 if (fdate(picfile) >= lastdate)
1132 continue;
1133 /* build rpict command */
1134 sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs);
1135 if (fdate(rawfile) >= octreedate) /* recover */
1136 sprintf(combuf, "rpict%s%s -ro %s %s",
1137 rep, opts, rawfile, vval(OCTREE));
1138 else {
1139 if (overture) { /* run overture calculation */
1140 sprintf(combuf,
1141 "rpict%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1142 rep, vw, opts,
1143 vval(OCTREE), overfile);
1144 if (runcom(combuf)) {
1145 fprintf(stderr,
1146 "%s: error in overture for view %s\n",
1147 progname, vs);
1148 exit(1);
1149 }
1150 #ifdef NIX
1151 rmfile(overfile);
1152 #endif
1153 }
1154 sprintf(combuf, "rpict%s %s %s%s %s > %s",
1155 rep, vw, res, opts,
1156 vval(OCTREE), rawfile);
1157 }
1158 if (runcom(combuf)) { /* run rpict */
1159 fprintf(stderr, "%s: error rendering view %s\n",
1160 progname, vs);
1161 exit(1);
1162 }
1163 /* build pfilt command */
1164 if (mult > 1)
1165 sprintf(combuf, "pfilt%s -x /%d -y /%d %s > %s",
1166 pfopts, mult, mult, rawfile, picfile);
1167 else
1168 sprintf(combuf, "pfilt%s %s > %s", pfopts,
1169 rawfile, picfile);
1170 if (runcom(combuf)) { /* run pfilt */
1171 fprintf(stderr,
1172 "%s: error filtering view %s\n\t%s removed\n",
1173 progname, vs, picfile);
1174 unlink(picfile);
1175 exit(1);
1176 }
1177 /* remove raw file */
1178 rmfile(rawfile);
1179 }
1180 }
1181
1182
1183 runcom(cs) /* run command */
1184 char *cs;
1185 {
1186 if (!silent) /* echo it */
1187 printf("\t%s\n", cs);
1188 if (noaction)
1189 return(0);
1190 fflush(stdout); /* flush output and pass to shell */
1191 return(system(cs));
1192 }
1193
1194
1195 rmfile(fn) /* remove a file */
1196 char *fn;
1197 {
1198 if (!silent)
1199 #ifdef MSDOS
1200 printf("\tdel %s\n", fn);
1201 #else
1202 printf("\trm -f %s\n", fn);
1203 #endif
1204 if (noaction)
1205 return(0);
1206 return(unlink(fn));
1207 }
1208
1209
1210 #ifdef MSDOS
1211 setenv(vname, value) /* set an environment variable */
1212 char *vname, *value;
1213 {
1214 register char *evp;
1215
1216 evp = bmalloc(strlen(vname)+strlen(value)+2);
1217 if (evp == NULL)
1218 syserr(progname);
1219 sprintf(evp, "%s=%s", vname, value);
1220 if (putenv(evp) != 0) {
1221 fprintf(stderr, "%s: out of environment space\n", progname);
1222 exit(1);
1223 }
1224 if (!silent)
1225 printf("set %s\n", evp);
1226 }
1227 #endif
1228
1229
1230 badvalue(vc) /* report bad variable value and exit */
1231 int vc;
1232 {
1233 fprintf(stderr, "%s: bad value for variable '%s'\n",
1234 progname, vnam(vc));
1235 exit(1);
1236 }
1237
1238
1239 syserr(s) /* report a system error and exit */
1240 char *s;
1241 {
1242 perror(s);
1243 exit(1);
1244 }
