Revision: 2.127
Committed: Tue Apr 7 00:49:09 2020 UTC (4 years, 11 months ago) by greg
Changes since 2.126: +6 -2 lines
Disable overture calculation if -aa 0 set in render options
2 static const char RCSid[] = "$Id: rad.c,v 2.126 2019/02/26 23:31:11 greg Exp $";
5 * Executive program for oconv, rpict and pfilt
6 */
7
8 #include "standard.h"
9
10 #include <ctype.h>
11 #include <time.h>
12 #include <signal.h>
13
14 #include "platform.h"
15 #include "rtprocess.h"
16 #include "view.h"
17 #include "paths.h"
18 #include "vars.h"
19
20 #if defined(_WIN32) || defined(_WIN64)
21 #define DELCMD "del"
22 #define RENAMECMD "rename"
23 #else
24 #define DELCMD "rm -f"
25 #define RENAMECMD "mv"
26 #include <sys/types.h>
27 #include <sys/wait.h>
28 #include <signal.h>
29 #endif
30
31 /* variables (alphabetical by name) */
32 #define AMBFILE 0 /* ambient file name */
33 #define DETAIL 1 /* level of scene detail */
34 #define EXPOSURE 2 /* picture exposure setting */
35 #define EYESEP 3 /* interocular distance */
36 #define ILLUM 4 /* mkillum input files */
37 #define INDIRECT 5 /* indirection in lighting */
38 #define MATERIAL 6 /* material files */
39 #define MKILLUM 7 /* mkillum options */
40 #define MKPMAP 8 /* mkpmap options */
41 #define OBJECT 9 /* object files */
42 #define OCONV 10 /* oconv options */
43 #define OCTREE 11 /* octree file name */
44 #define OPTFILE 12 /* rendering options file */
45 #define PCMAP 13 /* caustic photon map */
46 #define PENUMBRAS 14 /* shadow penumbras are desired */
47 #define PFILT 15 /* pfilt options */
48 #define PGMAP 16 /* global photon map */
49 #define PICTURE 17 /* picture file root name */
50 #define QUALITY 18 /* desired rendering quality */
51 #define RAWFILE 19 /* raw picture file root name */
52 #define RENDER 20 /* rendering options */
53 #define REPORT 21 /* report frequency and errfile */
54 #define RESOLUTION 22 /* maximum picture resolution */
55 #define RPICT 23 /* rpict parameters */
56 #define RVU 24 /* rvu parameters */
57 #define SCENE 25 /* scene files */
58 #define UP 26 /* view up (X, Y or Z) */
59 #define VARIABILITY 27 /* level of light variability */
60 #define VIEWS 28 /* view(s) for picture(s) */
61 #define ZFILE 29 /* distance file root name */
62 #define ZONE 30 /* simulation zone */
63 /* total number of variables */
64 int NVARS = 31;
65
66 VARIABLE vv[] = { /* variable-value pairs */
67 {"AMBFILE", 3, 0, NULL, onevalue},
68 {"DETAIL", 3, 0, NULL, qualvalue},
69 {"EXPOSURE", 3, 0, NULL, fltvalue},
70 {"EYESEP", 3, 0, NULL, fltvalue},
71 {"illum", 3, 0, NULL, catvalues},
72 {"INDIRECT", 3, 0, NULL, intvalue},
73 {"materials", 3, 0, NULL, catvalues},
74 {"mkillum", 3, 0, NULL, catvalues},
75 {"mkpmap", 3, 0, NULL, catvalues},
76 {"objects", 3, 0, NULL, catvalues},
77 {"oconv", 3, 0, NULL, catvalues},
78 {"OCTREE", 3, 0, NULL, onevalue},
79 {"OPTFILE", 3, 0, NULL, onevalue},
80 {"PCMAP", 2, 0, NULL, onevalue},
81 {"PENUMBRAS", 3, 0, NULL, boolvalue},
82 {"pfilt", 2, 0, NULL, catvalues},
83 {"PGMAP", 2, 0, NULL, onevalue},
84 {"PICTURE", 3, 0, NULL, onevalue},
85 {"QUALITY", 3, 0, NULL, qualvalue},
86 {"RAWFILE", 3, 0, NULL, onevalue},
87 {"render", 3, 0, NULL, catvalues},
88 {"REPORT", 3, 0, NULL, onevalue},
89 {"RESOLUTION", 3, 0, NULL, onevalue},
90 {"rpict", 3, 0, NULL, catvalues},
91 {"rvu", 3, 0, NULL, catvalues},
92 {"scene", 3, 0, NULL, catvalues},
93 {"UP", 2, 0, NULL, onevalue},
94 {"VARIABILITY", 3, 0, NULL, qualvalue},
95 {"view", 2, 0, NULL, NULL},
96 {"ZFILE", 2, 0, NULL, onevalue},
97 {"ZONE", 2, 0, NULL, onevalue},
98 };
99
100 /* overture calculation file */
101 #ifdef NULL_DEVICE
102 char overfile[] = NULL_DEVICE;
103 #else
104 char overfile[] = "overture.unf";
105 #endif
106
107
108 time_t scenedate; /* date of latest scene or object file */
109 time_t octreedate; /* date of octree */
110 time_t matdate; /* date of latest material file */
111 time_t illumdate; /* date of last illum file */
112
113 char *oct0name; /* name of pre-mkillum octree */
114 time_t oct0date; /* date of pre-mkillum octree */
115 char *oct1name; /* name of post-mkillum octree */
116 time_t oct1date; /* date of post-mkillum octree (>= matdate) */
117
118 char *pgmapname; /* name of global photon map */
119 time_t pgmapdate; /* date of global photon map (>= oct1date) */
120 char *pcmapname; /* name of caustic photon map */
121 time_t pcmapdate; /* date of caustic photon map (>= oct1date) */
122
123 int nowarn = 0; /* no warnings */
124 int explicate = 0; /* explicate variables */
125 int silent = 0; /* do work silently */
126 int touchonly = 0; /* touch files only */
127 int nprocs = 1; /* maximum executing processes */
128 int sayview = 0; /* print view out */
129 char *rvdevice = NULL; /* rvu output device */
130 char *viewselect = NULL; /* specific view only */
131
132 #define DEF_RPICT_PATH "rpict" /* default rpict path */
133
134 /* command paths */
135 char c_oconv[256] = "oconv";
136 char c_mkillum[256] = "mkillum";
137 char c_mkpmap[256] = "mkpmap";
138 char c_rvu[256] = "rvu";
139 char c_rpict[256] = DEF_RPICT_PATH;
140 char c_rpiece[] = "rpiece";
141 char c_pfilt[256] = "pfilt";
142
143 int overture = 0; /* overture calculation needed */
144
145 int children_running = 0; /* set negative in children */
146
147 char *progname; /* global argv[0] */
148 char *rifname; /* global rad input file name */
149
150 char radname[PATH_MAX]; /* root Radiance file name */
151
152 #define inchild() (children_running < 0)
153
154 static void rootname(char *rn, char *fn);
155 static time_t checklast(char *fnames);
156 static char * newfname(char *orig, int pred);
157 static void checkfiles(void);
158 static void getoctcube(double org[3], double *sizp);
159 static void setdefaults(void);
160 static void oconv(void);
161 static void mkpmap(void);
162 static char * addarg(char *op, char *arg);
163 static void oconvopts(char *oo);
164 static void mkillumopts(char *mo);
165 static void mkpmapopts(char *mo);
166 static void checkambfile(void);
167 static double ambval(void);
168 static void renderopts(char *op, char *po);
169 static void lowqopts(char *op, char *po);
170 static void medqopts(char *op, char *po);
171 static void hiqopts(char *op, char *po);
172 static void xferopts(char *ro);
173 static void pfiltopts(char *po);
174 static int matchword(char *s1, char *s2);
175 static char * specview(char *vs);
176 static char * getview(int n, char *vn);
177 static int myprintview(char *vopts, FILE *fp);
178 static void rvu(char *opts, char *po);
179 static void rpict(char *opts, char *po);
180 static int touch(char *fn);
181 static int runcom(char *cs);
182 static int rmfile(char *fn);
183 static int mvfile(char *fold, char *fnew);
184 static int next_process(int reserve);
185 static void wait_process(int all);
186 static void finish_process(void);
187 static void badvalue(int vc);
188 static void syserr(char *s);
189
190
191 int
192 main(
193 int argc,
194 char *argv[]
195 )
196 {
197 char ropts[512];
198 char popts[64];
199 int i;
200
201 progname = argv[0];
202 /* get options */
203 for (i = 1; i < argc && argv[i][0] == '-'; i++)
204 switch (argv[i][1]) {
205 case 's':
206 silent++;
207 break;
208 case 'n':
209 nprocs = 0;
210 break;
211 case 'N':
212 nprocs = atoi(argv[++i]);
213 if (nprocs < 0)
214 nprocs = 0;
215 break;
216 case 't':
217 touchonly++;
218 break;
219 case 'e':
220 explicate++;
221 break;
222 case 'o':
223 rvdevice = argv[++i];
224 break;
225 case 'V':
226 sayview++;
227 break;
228 case 'v':
229 viewselect = argv[++i];
230 break;
231 case 'w':
232 nowarn++;
233 break;
234 default:
235 goto userr;
236 }
237 if (i >= argc)
238 goto userr;
239 rifname = argv[i];
240 /* assign Radiance root file name */
241 rootname(radname, rifname);
242 /* load variable values */
243 loadvars(rifname);
244 /* get any additional assignments */
245 for (i++; i < argc; i++)
246 if (setvariable(argv[i], matchvar) < 0) {
247 fprintf(stderr, "%s: unknown variable: %s\n",
248 progname, argv[i]);
249 quit(1);
250 }
251 /* check assignments */
252 checkvalues();
253 /* check files and dates */
254 checkfiles();
255 /* set default values as necessary */
256 setdefaults();
257 /* print all values if requested */
258 if (explicate)
259 printvars(stdout);
260 /* build octree (and run mkillum) */
261 oconv();
262 /* run mkpmap if indicated */
263 mkpmap();
264 /* check date on ambient file */
265 checkambfile();
266 /* run simulation */
267 renderopts(ropts, popts);
268 xferopts(ropts);
269 if (rvdevice != NULL)
270 rvu(ropts, popts);
271 else
272 rpict(ropts, popts);
273 quit(0);
274 userr:
275 fprintf(stderr,
276 "Usage: %s [-w][-s][-n|-N npr][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n",
277 progname);
278 quit(1);
279 return 1; /* pro forma return */
280 }
281
282
283 static void
284 rootname( /* remove tail from end of fn */
285 char *rn,
286 char *fn
287 )
288 {
289 char *tp, *dp;
290
291 for (tp = NULL, dp = rn; (*rn = *fn++); rn++)
292 if (ISDIRSEP(*rn))
293 dp = rn;
294 else if (*rn == '.')
295 tp = rn;
296 if (tp != NULL && tp > dp)
297 *tp = '\0';
298 }
299
300
301 static time_t
302 checklast( /* check files and find most recent */
303 char *fnames
304 )
305 {
306 char thisfile[PATH_MAX];
307 time_t thisdate, lastdate = 0;
308
309 if (fnames == NULL)
310 return(0);
311 while ((fnames = nextword(thisfile, PATH_MAX, fnames)) != NULL) {
312 if (thisfile[0] == '!' ||
313 (thisfile[0] == '\\' && thisfile[1] == '!')) {
314 if (!lastdate)
315 lastdate = 1;
316 continue;
317 }
318 if (!(thisdate = fdate(thisfile)))
319 syserr(thisfile);
320 if (thisdate > lastdate)
321 lastdate = thisdate;
322 }
323 return(lastdate);
324 }
325
326
327 static char *
328 newfname( /* create modified file name */
329 char *orig,
330 int pred
331 )
332 {
333 char *cp;
334 int n;
335 int suffix;
336
337 n = 0; cp = orig; suffix = -1; /* suffix position, length */
338 while (*cp) {
339 if (*cp == '.') suffix = n;
340 else if (ISDIRSEP(*cp)) suffix = -1;
341 cp++; n++;
342 }
343 if (suffix == -1) suffix = n;
344 if ((cp = bmalloc(n+2)) == NULL)
345 syserr(progname);
346 strncpy(cp, orig, suffix);
347 cp[suffix] = pred; /* root name + pred + suffix */
348 strcpy(cp+suffix+1, orig+suffix);
349 return(cp);
350 }
351
352
353 static void
354 checkfiles(void) /* check for existence and modified times */
355 {
356 char fntemp[256];
357 time_t objdate;
358
359 if (!vdef(OCTREE)) {
360 if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL)
361 syserr(progname);
362 sprintf(vval(OCTREE), "%s.oct", radname);
363 vdef(OCTREE)++;
364 } else if (vval(OCTREE)[0] == '!') {
365 fprintf(stderr, "%s: illegal '%s' specification\n",
366 progname, vnam(OCTREE));
367 quit(1);
368 }
369 octreedate = fdate(vval(OCTREE));
370 if (vdef(ILLUM)) { /* illum requires secondary octrees */
371 oct0name = newfname(vval(OCTREE), '0');
372 oct1name = newfname(vval(OCTREE), '1');
373 oct0date = fdate(oct0name);
374 oct1date = fdate(oct1name);
375 } else
376 oct0name = oct1name = vval(OCTREE);
377 if ((scenedate = checklast(vval(SCENE))) &&
378 (objdate = checklast(vval(OBJECT))) > scenedate)
379 scenedate = objdate;
380 illumdate = checklast(vval(ILLUM));
381 if (!octreedate & !scenedate & !illumdate) {
382 fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname,
383 vnam(OCTREE), vnam(SCENE), vnam(ILLUM));
384 quit(1);
385 }
386 if (vdef(PGMAP)) {
387 if (!*sskip2(vval(PGMAP),1)) {
388 fprintf(stderr, "%s: '%s' missing # photons argument\n",
389 progname, vnam(PGMAP));
390 quit(1);
391 }
392 atos(fntemp, sizeof(fntemp), vval(PGMAP));
393 pgmapname = savqstr(fntemp);
394 pgmapdate = fdate(pgmapname);
395 }
396 if (vdef(PCMAP)) {
397 if (!*sskip2(vval(PCMAP),1)) {
398 fprintf(stderr, "%s: '%s' missing # photons argument\n",
399 progname, vnam(PCMAP));
400 quit(1);
401 }
402 atos(fntemp, sizeof(fntemp), vval(PCMAP));
403 pcmapname = savqstr(fntemp);
404 pcmapdate = fdate(pcmapname);
405 }
406 matdate = checklast(vval(MATERIAL));
407 }
408
409
410 static void
411 getoctcube( /* get octree bounding cube */
412 double org[3],
413 double *sizp
414 )
415 {
416 static double oorg[3], osiz = 0.;
417 double min[3], max[3];
418 char buf[1024];
419 FILE *fp;
420 int i;
421
422 if (osiz <= FTINY) {
423 if (!nprocs && fdate(oct1name) <
424 (scenedate>illumdate?scenedate:illumdate)) {
425 /* run getbbox */
426 sprintf(buf, "getbbox -w -h %s",
427 vdef(SCENE) ? vval(SCENE) : vval(ILLUM));
428 if ((fp = popen(buf, "r")) == NULL)
429 syserr("getbbox");
430 if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
431 &min[0], &max[0], &min[1], &max[1],
432 &min[2], &max[2]) != 6) {
433 fprintf(stderr,
434 "%s: error reading bounding box from getbbox\n",
435 progname);
436 quit(1);
437 }
438 for (i = 0; i < 3; i++)
439 if (max[i] - min[i] > osiz)
440 osiz = max[i] - min[i];
441 for (i = 0; i < 3; i++)
442 oorg[i] = (max[i]+min[i]-osiz)*.5;
443 pclose(fp);
444 } else { /* from octree */
445 oconv(); /* does nothing if done already */
446 sprintf(buf, "getinfo -d < %s", oct1name);
447 if ((fp = popen(buf, "r")) == NULL)
448 syserr("getinfo");
449 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
450 &oorg[2], &osiz) != 4) {
451 fprintf(stderr,
452 "%s: error reading bounding cube from getinfo\n",
453 progname);
454 quit(1);
455 }
456 pclose(fp);
457 }
458 }
459 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
460 }
461
462
463 static void
464 setdefaults(void) /* set default values for unassigned var's */
465 {
466 double org[3], lim[3], size;
467 char buf[128];
468
469 if (!vdef(ZONE)) {
470 getoctcube(org, &size);
471 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
472 org[1], org[1]+size, org[2], org[2]+size);
473 vval(ZONE) = savqstr(buf);
474 vdef(ZONE)++;
475 }
476 if (!vdef(EYESEP)) {
477 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
478 &org[0], &lim[0], &org[1], &lim[1],
479 &org[2], &lim[2]) != 6)
480 badvalue(ZONE);
481 sprintf(buf, "%f",
482 0.01*(lim[0]-org[0]+lim[1]-org[1]+lim[2]-org[2]));
483 vval(EYESEP) = savqstr(buf);
484 vdef(EYESEP)++;
485 }
486 if (!vdef(INDIRECT)) {
487 vval(INDIRECT) = "0";
488 vdef(INDIRECT)++;
489 }
490 if (!vdef(QUALITY)) {
491 vval(QUALITY) = "L";
492 vdef(QUALITY)++;
493 }
494 if (!vdef(RESOLUTION)) {
495 vval(RESOLUTION) = "512";
496 vdef(RESOLUTION)++;
497 }
498 if (!vdef(PICTURE)) {
499 vval(PICTURE) = radname;
500 vdef(PICTURE)++;
501 }
502 if (!vdef(VIEWS)) {
503 vval(VIEWS) = "X";
504 vdef(VIEWS)++;
505 }
506 if (!vdef(DETAIL)) {
507 vval(DETAIL) = "M";
508 vdef(DETAIL)++;
509 }
510 if (!vdef(PENUMBRAS)) {
511 vval(PENUMBRAS) = "F";
512 vdef(PENUMBRAS)++;
513 }
514 if (!vdef(VARIABILITY)) {
515 vval(VARIABILITY) = "L";
516 vdef(VARIABILITY)++;
517 }
518 }
519
520
521 static void
522 oconv(void) /* run oconv and mkillum if necessary */
523 {
524 static char illumtmp[] = "ilXXXXXX";
525 char combuf[PATH_MAX], ocopts[64], mkopts[1024];
526
527 oconvopts(ocopts); /* get options */
528 if (octreedate < scenedate) { /* check date on original octree */
529 if (touchonly && octreedate)
530 touch(vval(OCTREE));
531 else { /* build command */
532 if (vdef(MATERIAL))
533 sprintf(combuf, "%s%s %s %s > %s", c_oconv,
534 ocopts, vval(MATERIAL),
535 vval(SCENE), vval(OCTREE));
536 else
537 sprintf(combuf, "%s%s %s > %s", c_oconv, ocopts,
538 vval(SCENE), vval(OCTREE));
539
540 if (runcom(combuf)) { /* run it */
541 fprintf(stderr,
542 "%s: error generating octree\n\t%s removed\n",
543 progname, vval(OCTREE));
544 unlink(vval(OCTREE));
545 quit(1);
546 }
547 }
548 octreedate = time((time_t *)NULL);
549 if (octreedate < scenedate) /* in case clock is off */
550 octreedate = scenedate;
551 }
552 if (oct1name == vval(OCTREE)) /* no mkillum? */
553 oct1date = octreedate > matdate ? octreedate : matdate;
554 if ((oct1date >= octreedate) & (oct1date >= matdate)
555 & (oct1date >= illumdate)) /* all done */
556 return;
557 /* make octree0 */
558 if ((oct0date < scenedate) | (oct0date < illumdate)) {
559 if (touchonly && (oct0date || oct1date)) {
560 if (oct0date)
561 touch(oct0name);
562 } else { /* build command */
563 if (octreedate)
564 sprintf(combuf, "%s%s -i %s %s > %s", c_oconv,
565 ocopts, vval(OCTREE),
566 vval(ILLUM), oct0name);
567 else if (vdef(MATERIAL))
568 sprintf(combuf, "%s%s %s %s > %s", c_oconv,
569 ocopts, vval(MATERIAL),
570 vval(ILLUM), oct0name);
571 else
572 sprintf(combuf, "%s%s %s > %s", c_oconv,
573 ocopts, vval(ILLUM), oct0name);
574 if (runcom(combuf)) { /* run it */
575 fprintf(stderr,
576 "%s: error generating octree\n\t%s removed\n",
577 progname, oct0name);
578 unlink(oct0name);
579 quit(1);
580 }
581 }
582 oct0date = time((time_t *)NULL);
583 if (oct0date < octreedate) /* in case clock is off */
584 oct0date = octreedate;
585 if (oct0date < illumdate) /* ditto */
586 oct0date = illumdate;
587 }
588 if (touchonly && oct1date)
589 touch(oct1name);
590 else {
591 mkillumopts(mkopts); /* build mkillum command */
592 mktemp(illumtmp);
593 sprintf(combuf, "%s%s %s \"<\" %s > %s", c_mkillum, mkopts,
594 oct0name, vval(ILLUM), illumtmp);
595 if (runcom(combuf)) { /* run it */
596 fprintf(stderr, "%s: error running %s\n",
597 progname, c_mkillum);
598 unlink(illumtmp);
599 quit(1);
600 }
601 rmfile(oct0name);
602 /* make octree1 (frozen) */
603 if (octreedate)
604 sprintf(combuf, "%s%s -f -i %s %s > %s", c_oconv,
605 ocopts, vval(OCTREE), illumtmp, oct1name);
606 else if (vdef(MATERIAL))
607 sprintf(combuf, "%s%s -f %s %s > %s", c_oconv,
608 ocopts, vval(MATERIAL), illumtmp, oct1name);
609 else
610 sprintf(combuf, "%s%s -f %s > %s", c_oconv, ocopts,
611 illumtmp, oct1name);
612 if (runcom(combuf)) { /* run it */
613 fprintf(stderr,
614 "%s: error generating octree\n\t%s removed\n",
615 progname, oct1name);
616 unlink(oct1name);
617 unlink(illumtmp);
618 quit(1);
619 }
620 rmfile(illumtmp);
621 }
622 oct1date = time((time_t *)NULL);
623 if (oct1date < oct0date) /* in case clock is off */
624 oct1date = oct0date;
625 }
626
627
628 static void
629 mkpmap(void) /* run mkpmap if indicated */
630 {
631 char combuf[2048], *cp;
632 time_t tnow;
633 /* nothing to do? */
634 if ((pgmapname == NULL) | (pgmapdate >= oct1date) &&
635 (pcmapname == NULL) | (pcmapdate >= oct1date))
636 return;
637 /* just update existing file dates? */
638 if (touchonly && (pgmapname == NULL) | (pgmapdate > 0) &&
639 (pcmapname == NULL) | (pcmapdate > 0)) {
640 if (pgmapname != NULL)
641 touch(pgmapname);
642 if (pcmapname != NULL)
643 touch(pcmapname);
644 } else { /* else need to (re)run pkpmap */
645 strcpy(combuf, c_mkpmap);
646 for (cp = combuf; *cp; cp++)
647 ;
648 mkpmapopts(cp);
649 /* force file overwrite */
650 cp = addarg(cp, "-fo+");
651 if (vdef(REPORT)) {
652 char errfile[256];
653 int n;
654 double minutes;
655 n = sscanf(vval(REPORT), "%lf %s", &minutes, errfile);
656 if (n == 2)
657 sprintf(cp, " -t %d -e %s", (int)(minutes*60), errfile);
658 else if (n == 1)
659 sprintf(cp, " -t %d", (int)(minutes*60));
660 else
661 badvalue(REPORT);
662 }
663 if (pgmapname != NULL && pgmapdate < oct1date) {
664 cp = addarg(cp, "-apg");
665 addarg(cp, vval(PGMAP));
666 cp = sskip(sskip(cp)); /* remove any bandwidth */
667 *cp = '\0';
668 }
669 if (pcmapname != NULL && pcmapdate < oct1date) {
670 cp = addarg(cp, "-apc");
671 addarg(cp, vval(PCMAP));
672 cp = sskip(sskip(cp)); /* remove any bandwidth */
673 *cp = '\0';
674 }
675 cp = addarg(cp, oct1name);
676 if (runcom(combuf)) {
677 fprintf(stderr, "%s: error running %s\n",
678 progname, c_mkpmap);
679 if (pgmapname != NULL && pgmapdate < oct1date)
680 unlink(pgmapname);
681 if (pcmapname != NULL && pcmapdate < oct1date)
682 unlink(pcmapname);
683 quit(1);
684 }
685 }
686 tnow = time((time_t *)NULL);
687 if (pgmapname != NULL)
688 pgmapdate = tnow;
689 if (pcmapname != NULL)
690 pcmapdate = tnow;
691 oct1date = tnow; /* trigger ambient file removal if needed */
692 }
693
694
695 static char *
696 addarg( /* append argument and advance pointer */
697 char *op,
698 char *arg
699 )
700 {
701 while (*op)
702 op++;
703 *op = ' ';
704 while ( (*++op = *arg++) )
705 ;
706 return(op);
707 }
708
709
710 static void
711 oconvopts( /* get oconv options */
712 char *oo
713 )
714 {
715 /* BEWARE: This may be called via setdefaults(), so no assumptions */
716
717 *oo = '\0';
718 if (!vdef(OCONV))
719 return;
720 if (vval(OCONV)[0] != '-') {
721 atos(c_oconv, sizeof(c_oconv), vval(OCONV));
722 oo = addarg(oo, sskip2(vval(OCONV), 1));
723 } else
724 oo = addarg(oo, vval(OCONV));
725 }
726
727
728 static void
729 mkillumopts( /* get mkillum options */
730 char *mo
731 )
732 {
733 /* BEWARE: This may be called via setdefaults(), so no assumptions */
734
735 if (nprocs > 1)
736 sprintf(mo, " -n %d", nprocs);
737 else
738 *mo = '\0';
739 if (!vdef(MKILLUM))
740 return;
741 if (vval(MKILLUM)[0] != '-') {
742 atos(c_mkillum, sizeof(c_mkillum), vval(MKILLUM));
743 mo = addarg(mo, sskip2(vval(MKILLUM), 1));
744 } else
745 mo = addarg(mo, vval(MKILLUM));
746 }
747
748
749 static void
750 mkpmapopts( /* get mkpmap options */
751 char *mo
752 )
753 {
754 /* BEWARE: This may be called via setdefaults(), so no assumptions */
755
756 if (nprocs > 1)
757 sprintf(mo, " -n %d", nprocs);
758 else
759 *mo = '\0';
760 if (!vdef(MKPMAP))
761 return;
762 if (vval(MKPMAP)[0] != '-') {
763 atos(c_mkpmap, sizeof(c_mkpmap), vval(MKPMAP));
764 mo = addarg(mo, sskip2(vval(MKPMAP), 1));
765 } else
766 mo = addarg(mo, vval(MKPMAP));
767 }
768
769
770 static void
771 checkambfile(void) /* check date on ambient file */
772 {
773 time_t afdate;
774
775 if (!vdef(AMBFILE))
776 return;
777 if (!(afdate = fdate(vval(AMBFILE))))
778 return;
779 if (oct1date > afdate) {
780 if (touchonly)
781 touch(vval(AMBFILE));
782 else
783 rmfile(vval(AMBFILE));
784 }
785 }
786
787
788 static double
789 ambval(void) /* compute ambient value */
790 {
791 if (vdef(EXPOSURE)) {
792 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
793 return(.5/pow(2.,vflt(EXPOSURE)));
794 return(.5/vflt(EXPOSURE));
795 }
796 if (vlet(ZONE) == 'E')
797 return(10.);
798 if (vlet(ZONE) == 'I')
799 return(.01);
800 badvalue(ZONE);
801 return 0; /* pro forma return */
802 }
803
804
805 static void
806 renderopts( /* set rendering options */
807 char *op,
808 char *po
809 )
810 {
811 char pmapf[256], *bw;
812
813 if (vdef(PGMAP)) {
814 *op = '\0';
815 bw = sskip2(vval(PGMAP), 2);
816 atos(pmapf, sizeof(pmapf), vval(PGMAP));
817 op = addarg(addarg(op, "-ap"), pmapf);
818 if (atoi(bw) > 0) op = addarg(op, bw);
819 }
820 switch(vscale(QUALITY)) {
821 case LOW:
822 lowqopts(op, po);
823 break;
824 case MEDIUM:
825 medqopts(op, po);
826 break;
827 case HIGH:
828 hiqopts(op, po);
829 break;
830 }
831 if (vdef(PCMAP)) {
832 bw = sskip2(vval(PCMAP), 2);
833 atos(pmapf, sizeof(pmapf), vval(PCMAP));
834 op = addarg(addarg(op, "-ap"), pmapf);
835 if (atoi(bw) > 0) op = addarg(op, bw);
836 }
837 if (vdef(RENDER)) {
838 op = addarg(op, vval(RENDER));
839 bw = strstr(vval(RENDER), "-aa ");
840 if (bw != NULL && atof(bw+4) <= FTINY)
841 overture = 0;
842 }
843 if (rvdevice != NULL) {
844 if (vdef(RVU)) {
845 if (vval(RVU)[0] != '-') {
846 atos(c_rvu, sizeof(c_rvu), vval(RVU));
847 po = addarg(po, sskip2(vval(RVU), 1));
848 } else
849 po = addarg(po, vval(RVU));
850 }
851 } else {
852 if (vdef(RPICT)) {
853 if (vval(RPICT)[0] != '-') {
854 atos(c_rpict, sizeof(c_rpict), vval(RPICT));
855 po = addarg(po, sskip2(vval(RPICT), 1));
856 } else
857 po = addarg(po, vval(RPICT));
858 }
859 }
860 }
861
862
863 static void
864 lowqopts( /* low quality rendering options */
865 char *op,
866 char *po
867 )
868 {
869 double d, org[3], siz[3];
870
871 *op = '\0';
872 *po = '\0';
873 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
874 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
875 badvalue(ZONE);
876 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
877 if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY))
878 badvalue(ZONE);
879 getoctcube(org, &d);
880 d *= 3./(siz[0]+siz[1]+siz[2]);
881 switch (vscale(DETAIL)) {
882 case LOW:
883 po = addarg(po, "-ps 16");
884 op = addarg(op, "-dp 64");
885 sprintf(op, " -ar %d", (int)(8*d));
886 op += strlen(op);
887 break;
888 case MEDIUM:
889 po = addarg(po, "-ps 8");
890 op = addarg(op, "-dp 128");
891 sprintf(op, " -ar %d", (int)(16*d));
892 op += strlen(op);
893 break;
894 case HIGH:
895 po = addarg(po, "-ps 4");
896 op = addarg(op, "-dp 256");
897 sprintf(op, " -ar %d", (int)(32*d));
898 op += strlen(op);
899 break;
900 }
901 po = addarg(po, "-pt .16");
902 if (vbool(PENUMBRAS))
903 op = addarg(op, "-ds .4");
904 else
905 op = addarg(op, "-ds 0");
906 op = addarg(op, "-dt .2 -dc .25 -dr 0 -ss 0 -st .5");
907 if (vdef(AMBFILE)) {
908 sprintf(op, " -af %s", vval(AMBFILE));
909 op += strlen(op);
910 } else
911 overture = 0;
912 switch (vscale(VARIABILITY)) {
913 case LOW:
914 op = addarg(op, "-aa .3 -ad 256");
915 break;
916 case MEDIUM:
917 op = addarg(op, "-aa .25 -ad 512");
918 break;
919 case HIGH:
920 op = addarg(op, "-aa .2 -ad 1024");
921 break;
922 }
923 op = addarg(op, "-as 0");
924 d = ambval();
925 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
926 op += strlen(op);
927 op = addarg(op, "-lr 6 -lw .003");
928 }
929
930
931 static void
932 medqopts( /* medium quality rendering options */
933 char *op,
934 char *po
935 )
936 {
937 double d, org[3], siz[3], asz;
938
939 *op = '\0';
940 *po = '\0';
941 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
942 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
943 badvalue(ZONE);
944 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
945 if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY))
946 badvalue(ZONE);
947 getoctcube(org, &d);
948 asz = (siz[0]+siz[1]+siz[2])/3.;
949 d /= asz;
950 switch (vscale(DETAIL)) {
951 case LOW:
952 po = addarg(po, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
953 op = addarg(op, "-dp 256");
954 sprintf(op, " -ar %d", (int)(16*d));
955 op += strlen(op);
956 sprintf(op, " -ms %.2g", asz/20.);
957 op += strlen(op);
958 break;
959 case MEDIUM:
960 po = addarg(po, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
961 op = addarg(op, "-dp 512");
962 sprintf(op, " -ar %d", (int)(32*d));
963 op += strlen(op);
964 sprintf(op, " -ms %.2g", asz/40.);
965 op += strlen(op);
966 break;
967 case HIGH:
968 po = addarg(po, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
969 op = addarg(op, "-dp 1024");
970 sprintf(op, " -ar %d", (int)(64*d));
971 op += strlen(op);
972 sprintf(op, " -ms %.2g", asz/80.);
973 op += strlen(op);
974 break;
975 }
976 po = addarg(po, "-pt .08");
977 if (vbool(PENUMBRAS))
978 op = addarg(op, "-ds .2 -dj .9");
979 else
980 op = addarg(op, "-ds .3");
981 op = addarg(op, "-dt .1 -dc .5 -dr 1 -ss 1 -st .1");
982 if ( (overture = vint(INDIRECT)) ) {
983 sprintf(op, " -ab %d", overture);
984 op += strlen(op);
985 }
986 if (vdef(AMBFILE)) {
987 sprintf(op, " -af %s", vval(AMBFILE));
988 op += strlen(op);
989 } else
990 overture = 0;
991 switch (vscale(VARIABILITY)) {
992 case LOW:
993 op = addarg(op, "-aa .2 -ad 329 -as 42");
994 break;
995 case MEDIUM:
996 op = addarg(op, "-aa .15 -ad 800 -as 128");
997 break;
998 case HIGH:
999 op = addarg(op, "-aa .1 -ad 1536 -as 392");
1000 break;
1001 }
1002 d = ambval();
1003 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
1004 op += strlen(op);
1005 op = addarg(op, "-lr 8 -lw 1e-4");
1006 }
1007
1008
1009 static void
1010 hiqopts( /* high quality rendering options */
1011 char *op,
1012 char *po
1013 )
1014 {
1015 double d, org[3], siz[3], asz;
1016
1017 *op = '\0';
1018 *po = '\0';
1019 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
1020 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
1021 badvalue(ZONE);
1022 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
1023 if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY))
1024 badvalue(ZONE);
1025 getoctcube(org, &d);
1026 asz = (siz[0]+siz[1]+siz[2])/3.;
1027 d /= asz;
1028 switch (vscale(DETAIL)) {
1029 case LOW:
1030 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
1031 op = addarg(op, "-dp 1024");
1032 sprintf(op, " -ar %d", (int)(32*d));
1033 op += strlen(op);
1034 sprintf(op, " -ms %.2g", asz/40.);
1035 op += strlen(op);
1036 break;
1037 case MEDIUM:
1038 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
1039 op = addarg(op, "-dp 2048");
1040 sprintf(op, " -ar %d", (int)(64*d));
1041 op += strlen(op);
1042 sprintf(op, " -ms %.2g", asz/80.);
1043 op += strlen(op);
1044 break;
1045 case HIGH:
1046 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
1047 op = addarg(op, "-dp 4096");
1048 sprintf(op, " -ar %d", (int)(128*d));
1049 op += strlen(op);
1050 sprintf(op, " -ms %.2g", asz/160.);
1051 op += strlen(op);
1052 break;
1053 }
1054 po = addarg(po, "-pt .04");
1055 if (vbool(PENUMBRAS))
1056 op = addarg(op, "-ds .1 -dj .9");
1057 else
1058 op = addarg(op, "-ds .2");
1059 op = addarg(op, "-dt .05 -dc .75 -dr 3 -ss 16 -st .01");
1060 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
1061 op += strlen(op);
1062 if (vdef(AMBFILE)) {
1063 sprintf(op, " -af %s", vval(AMBFILE));
1064 op += strlen(op);
1065 } else
1066 overture = 0;
1067 switch (vscale(VARIABILITY)) {
1068 case LOW:
1069 op = addarg(op, "-aa .125 -ad 512 -as 64");
1070 break;
1071 case MEDIUM:
1072 op = addarg(op, "-aa .1 -ad 1536 -as 768");
1073 break;
1074 case HIGH:
1075 op = addarg(op, "-aa .075 -ad 4096 -as 2048");
1076 break;
1077 }
1078 d = ambval();
1079 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
1080 op += strlen(op);
1081 op = addarg(op, "-lr 12 -lw 1e-5");
1082 }
1083
1084
1085 #if defined(_WIN32) || defined(_WIN64)
1086 static void
1087 setenv( /* set an environment variable */
1088 char *vname,
1089 char *value
1090 )
1091 {
1092 char *evp;
1093
1094 evp = bmalloc(strlen(vname)+strlen(value)+2);
1095 if (evp == NULL)
1096 syserr(progname);
1097 sprintf(evp, "%s=%s", vname, value);
1098 if (putenv(evp) != 0) {
1099 fprintf(stderr, "%s: out of environment space\n", progname);
1100 quit(1);
1101 }
1102 if (!silent)
1103 printf("set %s\n", evp);
1104 }
1105 #endif
1106
1107
1108 static void
1109 xferopts( /* transfer options if indicated */
1110 char *ro
1111 )
1112 {
1113 int fd, n;
1114 char *cp;
1115
1116 n = strlen(ro);
1117 if (n < 2)
1118 return;
1119 if (vdef(OPTFILE)) {
1120 for (cp = ro; cp[1]; cp++)
1121 if (isspace(cp[1]) && (cp[2] == '@' ||
1122 (cp[2] == '-' && isalpha(cp[3]))))
1123 *cp = '\n';
1124 else
1125 *cp = cp[1];
1126 *cp = '\n';
1127 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
1128 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
1129 syserr(vval(OPTFILE));
1130 sprintf(ro, " @%s", vval(OPTFILE));
1131 }
1132 #if defined(_WIN32) || defined(_WIN64)
1133 else if (n > 50) {
1134 setenv("ROPT", ro+1);
1135 strcpy(ro, " $ROPT");
1136 }
1137 #endif
1138 }
1139
1140
1141 static void
1142 pfiltopts( /* get pfilt options */
1143 char *po
1144 )
1145 {
1146 *po = '\0';
1147 if (vdef(EXPOSURE)) {
1148 po = addarg(po, "-1 -e");
1149 po = addarg(po, vval(EXPOSURE));
1150 }
1151 switch (vscale(QUALITY)) {
1152 case MEDIUM:
1153 po = addarg(po, "-r .6");
1154 break;
1155 case HIGH:
1156 po = addarg(po, "-m .25");
1157 break;
1158 }
1159 if (vdef(PFILT)) {
1160 if (vval(PFILT)[0] != '-') {
1161 atos(c_pfilt, sizeof(c_pfilt), vval(PFILT));
1162 po = addarg(po, sskip2(vval(PFILT), 1));
1163 } else
1164 po = addarg(po, vval(PFILT));
1165 }
1166 }
1167
1168
1169 static int
1170 matchword( /* match white-delimited words */
1171 char *s1,
1172 char *s2
1173 )
1174 {
1175 while (isspace(*s1)) s1++;
1176 while (isspace(*s2)) s2++;
1177 while (*s1 && !isspace(*s1))
1178 if (*s1++ != *s2++)
1179 return(0);
1180 return(!*s2 || isspace(*s2));
1181 }
1182
1183
1184 static char *
1185 specview( /* get proper view spec from vs */
1186 char *vs
1187 )
1188 {
1189 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
1190 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
1191 static char viewopts[128];
1192 char *cp;
1193 int xpos, ypos, zpos, viewtype, upax;
1194 int i;
1195 double cent[3], dim[3], mult, d;
1196
1197 if (vs == NULL || *vs == '-')
1198 return(vs);
1199 upax = 0; /* get the up vector */
1200 if (vdef(UP)) {
1201 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
1202 upax = 1-'X'+UPPER(vval(UP)[1]);
1203 else
1204 upax = 1-'X'+vlet(UP);
1205 if ((upax < 1) | (upax > 3))
1206 badvalue(UP);
1207 if (vval(UP)[0] == '-')
1208 upax = -upax;
1209 }
1210 /* check standard view names */
1211 xpos = ypos = zpos = 0;
1212 if (*vs == 'X') {
1213 xpos = 1; vs++;
1214 } else if (*vs == 'x') {
1215 xpos = -1; vs++;
1216 }
1217 if (*vs == 'Y') {
1218 ypos = 1; vs++;
1219 } else if (*vs == 'y') {
1220 ypos = -1; vs++;
1221 }
1222 if (*vs == 'Z') {
1223 zpos = 1; vs++;
1224 } else if (*vs == 'z') {
1225 zpos = -1; vs++;
1226 }
1227 switch (*vs) {
1228 case VT_PER:
1229 case VT_PAR:
1230 case VT_ANG:
1231 case VT_HEM:
1232 case VT_PLS:
1233 case VT_CYL:
1234 viewtype = *vs++;
1235 break;
1236 default:
1237 viewtype = VT_PER;
1238 break;
1239 }
1240 cp = viewopts;
1241 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
1242 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
1243 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
1244 &cent[0], &dim[0], &cent[1], &dim[1],
1245 &cent[2], &dim[2]) != 6)
1246 badvalue(ZONE);
1247 for (i = 0; i < 3; i++) {
1248 dim[i] -= cent[i];
1249 if (dim[i] <= FTINY)
1250 badvalue(ZONE);
1251 cent[i] += .5*dim[i];
1252 }
1253 mult = vlet(ZONE)=='E' ? 2. : .45 ;
1254 sprintf(cp, " -vp %.3g %.3g %.3g -vd %.3g %.3g %.3g",
1255 cent[0]+xpos*mult*dim[0],
1256 cent[1]+ypos*mult*dim[1],
1257 cent[2]+zpos*mult*dim[2],
1258 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
1259 cp += strlen(cp);
1260 /* redirect up axis if necessary */
1261 switch (upax) {
1262 case 3: /* plus or minus Z axis */
1263 case -3:
1264 case 0:
1265 if (!(xpos|ypos))
1266 upax = 2;
1267 break;
1268 case 2: /* plus or minus Y axis */
1269 case -2:
1270 if (!(xpos|zpos))
1271 upax = 1;
1272 break;
1273 case 1: /* plus or minus X axis */
1274 case -1:
1275 if (!(ypos|zpos))
1276 upax = 3;
1277 break;
1278 }
1279 cp = addarg(cp, vup[upax+3]);
1280 switch (viewtype) {
1281 case VT_PER:
1282 cp = addarg(cp, "-vh 45 -vv 45");
1283 break;
1284 case VT_PAR:
1285 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
1286 sprintf(cp, " -vh %.3g -vv %.3g", d, d);
1287 cp += strlen(cp);
1288 break;
1289 case VT_ANG:
1290 case VT_HEM:
1291 case VT_PLS:
1292 cp = addarg(cp, "-vh 180 -vv 180");
1293 break;
1294 case VT_CYL:
1295 cp = addarg(cp, "-vh 180 -vv 90");
1296 break;
1297 }
1298 } else {
1299 while (!isspace(*vs)) /* else skip id */
1300 if (!*vs++)
1301 return(NULL);
1302 if (upax) { /* prepend up vector */
1303 strcpy(cp, vup[upax+3]);
1304 cp += strlen(cp);
1305 }
1306 }
1307 if (cp == viewopts) /* append any additional options */
1308 vs++; /* skip prefixed space if unneeded */
1309 strcpy(cp, vs);
1310 #if defined(_WIN32) || defined(_WIN64)
1311 if (strlen(viewopts) > 40) {
1312 setenv("VIEW", viewopts);
1313 return("$VIEW");
1314 }
1315 #endif
1316 return(viewopts);
1317 }
1318
1319
1320 static char *
1321 getview( /* get view n, or NULL if none */
1322 int n,
1323 char *vn /* returned view name */
1324 )
1325 {
1326 char *mv;
1327
1328 if (viewselect != NULL) { /* command-line selected */
1329 if (n) /* only do one */
1330 return(NULL);
1331
1332 if (isint(viewselect)) { /* view number? */
1333 n = atoi(viewselect)-1;
1334 goto numview;
1335 }
1336 if (viewselect[0] == '-') { /* already specified */
1337 if (vn != NULL)
1338 strcpy(vn, "0");
1339 return(viewselect);
1340 }
1341 if (vn != NULL) {
1342 for (mv = viewselect; *mv && !isspace(*mv);
1343 *vn++ = *mv++)
1344 ;
1345 *vn = '\0';
1346 }
1347 /* check list */
1348 while ((mv = nvalue(VIEWS, n++)) != NULL)
1349 if (matchword(viewselect, mv))
1350 return(specview(mv));
1351
1352 return(specview(viewselect)); /* standard view? */
1353 }
1354 numview:
1355 mv = nvalue(VIEWS, n); /* use view n */
1356 if ((vn != NULL) & (mv != NULL)) {
1357 if (*mv != '-') {
1358 char *mv2 = mv;
1359 while (*mv2 && !isspace(*mv2))
1360 *vn++ = *mv2++;
1361 *vn = '\0';
1362 } else
1363 sprintf(vn, "%d", n+1);
1364 }
1365 return(specview(mv));
1366 }
1367
1368
1369 static int
1370 myprintview( /* print out selected view */
1371 char *vopts,
1372 FILE *fp
1373 )
1374 {
1375 VIEW vwr;
1376 char buf[128];
1377 char *cp;
1378 #if defined(_WIN32) || defined(_WIN64)
1379 /* XXX Should we allow something like this for all platforms? */
1380 /* XXX Or is it still required at all? */
1381 again:
1382 #endif
1383 if (vopts == NULL)
1384 return(-1);
1385 #if defined(_WIN32) || defined(_WIN64)
1386 if (vopts[0] == '$') {
1387 vopts = getenv(vopts+1);
1388 goto again;
1389 }
1390 #endif
1391 vwr = stdview;
1392 sscanview(&vwr, cp=vopts); /* set initial options */
1393 while ((cp = strstr(cp, "-vf ")) != NULL &&
1394 *atos(buf, sizeof(buf), cp += 4)) {
1395 viewfile(buf, &vwr, NULL); /* load -vf file */
1396 sscanview(&vwr, cp); /* reset tail */
1397 }
1398 fputs(VIEWSTR, fp);
1399 fprintview(&vwr, fp); /* print full spec. */
1400 fputc('\n', fp);
1401 return(0);
1402 }
1403
1404
1405 static void
1406 rvu( /* run rvu with first view */
1407 char *opts,
1408 char *po
1409 )
1410 {
1411 char *vw;
1412 char combuf[PATH_MAX];
1413 /* build command */
1414 if (touchonly || (vw = getview(0, NULL)) == NULL)
1415 return;
1416 if (sayview)
1417 myprintview(vw, stdout);
1418 sprintf(combuf, "%s %s%s%s -R %s ", c_rvu, vw, opts, po, rifname);
1419 if (nprocs > 1)
1420 sprintf(combuf+strlen(combuf), "-n %d ", nprocs);
1421 if (rvdevice != NULL)
1422 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1423 if (vdef(EXPOSURE))
1424 sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE));
1425 strcat(combuf, oct1name);
1426 if (runcom(combuf)) { /* run it */
1427 fprintf(stderr, "%s: error running %s\n", progname, c_rvu);
1428 quit(1);
1429 }
1430 }
1431
1432
1433 static int
1434 syncf_done( /* check if an rpiece sync file is complete */
1435 char *sfname
1436 )
1437 {
1438 FILE *fp = fopen(sfname, "r");
1439 int todo = 1;
1440 int x, y;
1441
1442 if (fp == NULL)
1443 return(0);
1444 if (fscanf(fp, "%d %d", &x, &y) != 2)
1445 goto checked;
1446 todo = x*y; /* total number of tiles */
1447 if (fscanf(fp, "%d %d", &x, &y) != 2 || (x != 0) | (y != 0))
1448 goto checked;
1449 /* XXX assume no redundant tiles */
1450 while (fscanf(fp, "%d %d", &x, &y) == 2)
1451 if (!--todo)
1452 break;
1453 checked:
1454 fclose(fp);
1455 return(!todo);
1456 }
1457
1458
1459 static void
1460 rpict( /* run rpict and pfilt for each view */
1461 char *opts,
1462 char *po
1463 )
1464 {
1465 #define do_rpiece (sfile[0]!='\0')
1466 char combuf[5*PATH_MAX+512];
1467 char rawfile[PATH_MAX], picfile[PATH_MAX];
1468 char zopt[PATH_MAX+4], rep[PATH_MAX+16], res[32];
1469 char rppopt[32], sfile[PATH_MAX], *pfile = NULL;
1470 char pfopts[128];
1471 char vs[32], *vw;
1472 int vn, mult;
1473 FILE *fp;
1474 time_t rfdt, pfdt;
1475 int xres, yres;
1476 double aspect;
1477 int n;
1478 /* get pfilt options */
1479 pfiltopts(pfopts);
1480 /* get resolution, reporting */
1481 switch (vscale(QUALITY)) {
1482 case LOW:
1483 mult = 1;
1484 break;
1485 case MEDIUM:
1486 mult = 2;
1487 break;
1488 case HIGH:
1489 mult = 3;
1490 break;
1491 }
1492 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1493 if (n == 3)
1494 sprintf(res, "-x %d -y %d -pa %.3f",
1495 mult*xres, mult*yres, aspect);
1496 else if (n) {
1497 aspect = 1.;
1498 if (n == 1) yres = xres;
1499 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1500 } else
1501 badvalue(RESOLUTION);
1502 rep[0] = '\0';
1503 if (vdef(REPORT)) {
1504 double minutes;
1505 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1506 if (n == 2)
1507 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1508 else if (n == 1)
1509 sprintf(rep, " -t %d", (int)(minutes*60));
1510 else
1511 badvalue(REPORT);
1512 }
1513 /* set up parallel rendering */
1514 sfile[0] = '\0';
1515 if ((nprocs > 1) & !touchonly & !vdef(ZFILE) &&
1516 getview(0, vs) != NULL) {
1517 if (!strcmp(c_rpict, DEF_RPICT_PATH) &&
1518 getview(1, NULL) == NULL) {
1519 sprintf(sfile, "%s_%s_rpsync.txt",
1520 vdef(RAWFILE) ? vval(RAWFILE) : vval(PICTURE),
1521 vs);
1522 strcpy(rppopt, "-PP pfXXXXXX");
1523 } else {
1524 strcpy(rppopt, "-S 1 -PP pfXXXXXX");
1525 }
1526 pfile = rppopt + strlen(rppopt) - 8;
1527 if (mktemp(pfile) == NULL) {
1528 if (do_rpiece) {
1529 fprintf(stderr, "%s: cannot create\n", pfile);
1530 quit(1);
1531 }
1532 pfile[-5] = '\0';
1533 pfile = NULL;
1534 }
1535 }
1536 vn = 0; /* do each view */
1537 while ((vw = getview(vn++, vs)) != NULL) {
1538 if (sayview)
1539 myprintview(vw, stdout);
1540 sprintf(picfile, "%s_%s.hdr", vval(PICTURE), vs);
1541 if (vdef(ZFILE))
1542 sprintf(zopt, " -z %s_%s.zbf", vval(ZFILE), vs);
1543 else
1544 zopt[0] = '\0';
1545 /* check date on picture */
1546 pfdt = fdate(picfile);
1547 if (pfdt >= oct1date)
1548 continue;
1549 /* get raw file name */
1550 sprintf(rawfile, "%s_%s.unf",
1551 vdef(RAWFILE) ? vval(RAWFILE) : vval(PICTURE), vs);
1552 rfdt = fdate(rawfile);
1553 if (touchonly) { /* update times only */
1554 if (rfdt) {
1555 if (rfdt < oct1date)
1556 touch(rawfile);
1557 } else if (pfdt && pfdt < oct1date)
1558 touch(picfile);
1559 continue;
1560 }
1561 /* parallel running? */
1562 if (do_rpiece) {
1563 if (rfdt < oct1date || !fdate(sfile)) {
1564 int xdiv = 8+nprocs/3, ydiv = 8+nprocs/3;
1565 if (rfdt >= oct1date) {
1566 fprintf(stderr,
1567 "%s: partial output not created with %s\n", rawfile, c_rpiece);
1568 quit(1);
1569 }
1570 if (rfdt) { /* start fresh */
1571 rmfile(rawfile);
1572 rfdt = 0;
1573 }
1574 if (!silent)
1575 printf("\techo %d %d > %s\n",
1576 xdiv, ydiv, sfile);
1577 if ((fp = fopen(sfile, "w")) == NULL) {
1578 fprintf(stderr, "%s: cannot create\n",
1579 sfile);
1580 quit(1);
1581 }
1582 fprintf(fp, "%d %d\n", xdiv, ydiv);
1583 fclose(fp);
1584 }
1585 } else if (next_process(0)) {
1586 if (pfile != NULL)
1587 sleep(10);
1588 continue;
1589 } else if (!inchild())
1590 pfile = NULL;
1591 /* XXX Remember to call finish_process() */
1592 /* build rpict command */
1593 if (rfdt >= oct1date) { /* already in progress */
1594 if (do_rpiece) {
1595 sprintf(combuf, "%s -R %s %s%s %s %s%s%s -o %s %s",
1596 c_rpiece, sfile, rppopt, rep, vw,
1597 res, opts, po, rawfile, oct1name);
1598 while (next_process(1)) {
1599 sleep(10);
1600 combuf[strlen(c_rpiece)+2] = 'F';
1601 }
1602 } else
1603 sprintf(combuf, "%s%s%s%s%s -ro %s %s", c_rpict,
1604 rep, opts, po, zopt, rawfile, oct1name);
1605 if (runcom(combuf)) /* run rpict/rpiece */
1606 goto rperror;
1607 } else {
1608 if (overture) { /* run overture calculation */
1609 sprintf(combuf,
1610 "%s%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1611 c_rpict, rep, vw, opts,
1612 oct1name, overfile);
1613 if (!do_rpiece || !next_process(0)) {
1614 if (runcom(combuf)) {
1615 fprintf(stderr,
1616 "%s: error in overture for view %s\n",
1617 progname, vs);
1618 quit(1);
1619 }
1620 #ifndef NULL_DEVICE
1621 rmfile(overfile);
1622 #endif
1623 } else if (do_rpiece)
1624 sleep(20);
1625 }
1626 if (do_rpiece) {
1627 sprintf(combuf, "%s -F %s %s%s %s %s%s%s -o %s %s",
1628 c_rpiece, sfile, rppopt, rep, vw,
1629 res, opts, po, rawfile, oct1name);
1630 while (next_process(1))
1631 sleep(10);
1632 } else {
1633 sprintf(combuf, "%s%s %s %s%s%s%s %s > %s",
1634 c_rpict, rep, vw, res, opts, po,
1635 zopt, oct1name, rawfile);
1636 }
1637 if ((pfile != NULL) & !do_rpiece) {
1638 if (!silent)
1639 printf("\t%s\n", combuf);
1640 fflush(stdout);
1641 sprintf(combuf, "%s%s %s %s%s%s %s > %s",
1642 c_rpict, rep, rppopt, res,
1643 opts, po, oct1name, rawfile);
1644 fp = popen(combuf, "w");
1645 if (fp == NULL)
1646 goto rperror;
1647 myprintview(vw, fp);
1648 if (pclose(fp))
1649 goto rperror;
1650 } else if (runcom(combuf))
1651 goto rperror;
1652 }
1653 if (do_rpiece) { /* need to finish raw, first */
1654 finish_process();
1655 wait_process(1);
1656 if (!syncf_done(sfile)) {
1657 fprintf(stderr,
1658 "%s: %s did not complete rendering of view %s\n",
1659 progname, c_rpiece, vs);
1660 quit(1);
1661 }
1662 }
1663 if (!vdef(RAWFILE) || strcmp(vval(RAWFILE),vval(PICTURE))) {
1664 /* build pfilt command */
1665 if (do_rpiece)
1666 sprintf(combuf,
1667 "%s%s -x %d -y %d -p %.3f %s > %s",
1668 c_pfilt, pfopts, xres, yres, aspect,
1669 rawfile, picfile);
1670 else if (mult > 1)
1671 sprintf(combuf, "%s%s -x /%d -y /%d %s > %s",
1672 c_pfilt, pfopts, mult, mult,
1673 rawfile, picfile);
1674 else
1675 sprintf(combuf, "%s%s %s > %s", c_pfilt,
1676 pfopts, rawfile, picfile);
1677 if (runcom(combuf)) { /* run pfilt */
1678 fprintf(stderr,
1679 "%s: error filtering view %s\n\t%s removed\n",
1680 progname, vs, picfile);
1681 unlink(picfile);
1682 quit(1);
1683 }
1684 }
1685 /* remove/rename raw file */
1686 if (vdef(RAWFILE)) {
1687 sprintf(combuf, "%s_%s.hdr", vval(RAWFILE), vs);
1688 mvfile(rawfile, combuf);
1689 } else
1690 rmfile(rawfile);
1691 if (do_rpiece) /* done with sync file */
1692 rmfile(sfile);
1693 else
1694 finish_process(); /* exit if child */
1695 }
1696 wait_process(1); /* wait for children to finish */
1697 if (pfile != NULL) { /* clean up persistent rpict */
1698 RT_PID pid;
1699 fp = fopen(pfile, "r");
1700 if (fp != NULL) {
1701 if (fscanf(fp, "%*s %d", &pid) != 1 ||
1702 kill(pid, 1) < 0)
1703 unlink(pfile);
1704 fclose(fp);
1705 }
1706 }
1707 return;
1708 rperror:
1709 fprintf(stderr, "%s: error rendering view %s\n", progname, vs);
1710 quit(1);
1711 #undef do_rpiece
1712 }
1713
1714
1715 static int
1716 touch( /* update a file */
1717 char *fn
1718 )
1719 {
1720 if (!silent)
1721 printf("\ttouch %s\n", fn);
1722 if (!nprocs)
1723 return(0);
1724 return(setfdate(fn, time((time_t *)NULL)));
1725 }
1726
1727
1728 static int
1729 runcom( /* run command */
1730 char *cs
1731 )
1732 {
1733 if (!silent) /* echo it */
1734 printf("\t%s\n", cs);
1735 if (!nprocs)
1736 return(0);
1737 fflush(NULL); /* flush output and pass to shell */
1738 return(system(cs));
1739 }
1740
1741
1742 static int
1743 rmfile( /* remove a file */
1744 char *fn
1745 )
1746 {
1747 if (!silent)
1748 printf("\t%s %s\n", DELCMD, fn);
1749 if (!nprocs)
1750 return(0);
1751 return(unlink(fn));
1752 }
1753
1754
1755 static int
1756 mvfile( /* move a file */
1757 char *fold,
1758 char *fnew
1759 )
1760 {
1761 if (!silent)
1762 printf("\t%s %s %s\n", RENAMECMD, fold, fnew);
1763 if (!nprocs)
1764 return(0);
1765 return(rename(fold, fnew));
1766 }
1767
1768
1769 #ifdef RHAS_FORK_EXEC
1770 static int
1771 next_process(int reserve) /* fork the next process */
1772 {
1773 RT_PID child_pid;
1774
1775 if (nprocs <= 1)
1776 return(0); /* it's us or no one */
1777 if (inchild()) {
1778 fprintf(stderr, "%s: internal error 1 in next_process()\n",
1779 progname);
1780 quit(1);
1781 }
1782 if (reserve > 0 && children_running >= nprocs-reserve)
1783 return(0); /* caller holding back process(es) */
1784 if (children_running >= nprocs)
1785 wait_process(0); /* wait for someone to finish */
1786 fflush(NULL); /* flush output */
1787 child_pid = fork(); /* split process */
1788 if (child_pid == 0) { /* we're the child */
1789 children_running = -1;
1790 nprocs = 1;
1791 return(0);
1792 }
1793 if (child_pid > 0) { /* we're the parent */
1794 ++children_running;
1795 return(1);
1796 }
1797 fprintf(stderr, "%s: warning -- fork() failed\n", progname);
1798 return(0);
1799 }
1800
1801 static void
1802 wait_process( /* wait for process(es) to finish */
1803 int all
1804 )
1805 {
1806 int ourstatus = 0, status;
1807 RT_PID pid;
1808
1809 if (all)
1810 all = children_running;
1811 else if (children_running > 0)
1812 all = 1;
1813 while (all-- > 0) {
1814 pid = wait(&status);
1815 if (pid < 0)
1816 syserr(progname);
1817 status = status>>8 & 0xff;
1818 --children_running;
1819 if (status != 0) { /* child's problem is our problem */
1820 if ((ourstatus == 0) & (children_running > 0))
1821 fprintf(stderr, "%s: waiting for remaining processes\n",
1822 progname);
1823 ourstatus = status;
1824 all = children_running;
1825 }
1826 }
1827 if (ourstatus != 0)
1828 quit(ourstatus); /* bad status from child */
1829 }
1830 #else /* ! RHAS_FORK_EXEC */
1831 static int
1832 next_process(int reserve)
1833 {
1834 return(0); /* cannot start new process */
1835 }
1836 static void
1837 wait_process(all)
1838 int all;
1839 {
1840 (void)all; /* no one to wait for */
1841 }
1842 int
1843 kill(pid, sig) /* win|unix_process.c should also wait and kill */
1844 RT_PID pid;
1845 int sig;
1846 {
1847 return 0;
1848 }
1849 #endif /* ! RHAS_FORK_EXEC */
1850
1851 static void
1852 finish_process(void) /* exit a child process */
1853 {
1854 if (!inchild())
1855 return; /* in parent -- noop */
1856 exit(0);
1857 }
1858
1859
1860 static void
1861 badvalue( /* report bad variable value and exit */
1862 int vc
1863 )
1864 {
1865 fprintf(stderr, "%s: bad value for variable '%s'\n",
1866 progname, vnam(vc));
1867 quit(1);
1868 }
1869
1870
1871 static void
1872 syserr( /* report a system error and exit */
1873 char *s
1874 )
1875 {
1876 perror(s);
1877 quit(1);
1878 }
1879
1880
1881 void
1882 quit(ec) /* exit program */
1883 int ec;
1884 {
1885 exit(ec);
1886 }
