Revision: 2.117
Committed: Wed May 27 14:26:04 2015 UTC (10 years ago) by greg
Changes since 2.116: +5 -3 lines
Need to report photon map removal
2 static const char RCSid[] = "$Id: rad.c,v 2.116 2015/05/27 14:22:02 greg Exp $";
5 * Executive program for oconv, rpict and pfilt
6 */
7
8 #include "standard.h"
9
10 #include <ctype.h>
11 #include <time.h>
12
13 #include "platform.h"
14 #include "rtprocess.h"
15 #include "view.h"
16 #include "paths.h"
17 #include "vars.h"
18
19 #ifdef _WIN32
20 #define DELCMD "del"
21 #define RENAMECMD "rename"
22 #else
23 #define DELCMD "rm -f"
24 #define RENAMECMD "mv"
25 #include <sys/types.h>
26 #include <sys/wait.h>
27 #include <signal.h>
28 #endif
29
30 /* variables (alphabetical by name) */
31 #define AMBFILE 0 /* ambient file name */
32 #define DETAIL 1 /* level of scene detail */
33 #define EXPOSURE 2 /* picture exposure setting */
34 #define EYESEP 3 /* interocular distance */
35 #define ILLUM 4 /* mkillum input files */
36 #define INDIRECT 5 /* indirection in lighting */
37 #define MATERIAL 6 /* material files */
38 #define MKILLUM 7 /* mkillum options */
39 #define MKPMAP 8 /* mkpmap options */
40 #define OBJECT 9 /* object files */
41 #define OCONV 10 /* oconv options */
42 #define OCTREE 11 /* octree file name */
43 #define OPTFILE 12 /* rendering options file */
44 #define PCMAP 13 /* caustic photon map */
45 #define PENUMBRAS 14 /* shadow penumbras are desired */
46 #define PFILT 15 /* pfilt options */
47 #define PGMAP 16 /* global photon map */
48 #define PICTURE 17 /* picture file root name */
49 #define QUALITY 18 /* desired rendering quality */
50 #define RAWFILE 19 /* raw picture file root name */
51 #define RENDER 20 /* rendering options */
52 #define REPORT 21 /* report frequency and errfile */
53 #define RESOLUTION 22 /* maximum picture resolution */
54 #define RPICT 23 /* rpict parameters */
55 #define RVU 24 /* rvu parameters */
56 #define SCENE 25 /* scene files */
57 #define UP 26 /* view up (X, Y or Z) */
58 #define VARIABILITY 27 /* level of light variability */
59 #define VIEWS 28 /* view(s) for picture(s) */
60 #define ZFILE 29 /* distance file root name */
61 #define ZONE 30 /* simulation zone */
62 /* total number of variables */
63 int NVARS = 31;
64
65 VARIABLE vv[] = { /* variable-value pairs */
66 {"AMBFILE", 3, 0, NULL, onevalue},
67 {"DETAIL", 3, 0, NULL, qualvalue},
68 {"EXPOSURE", 3, 0, NULL, fltvalue},
69 {"EYESEP", 3, 0, NULL, fltvalue},
70 {"illum", 3, 0, NULL, catvalues},
71 {"INDIRECT", 3, 0, NULL, intvalue},
72 {"materials", 3, 0, NULL, catvalues},
73 {"mkillum", 3, 0, NULL, catvalues},
74 {"mkpmap", 3, 0, NULL, catvalues},
75 {"objects", 3, 0, NULL, catvalues},
76 {"oconv", 3, 0, NULL, catvalues},
77 {"OCTREE", 3, 0, NULL, onevalue},
78 {"OPTFILE", 3, 0, NULL, onevalue},
79 {"PCMAP", 2, 0, NULL, onevalue},
80 {"PENUMBRAS", 3, 0, NULL, boolvalue},
81 {"pfilt", 2, 0, NULL, catvalues},
82 {"PGMAP", 2, 0, NULL, onevalue},
83 {"PICTURE", 3, 0, NULL, onevalue},
84 {"QUALITY", 3, 0, NULL, qualvalue},
85 {"RAWFILE", 3, 0, NULL, onevalue},
86 {"render", 3, 0, NULL, catvalues},
87 {"REPORT", 3, 0, NULL, onevalue},
88 {"RESOLUTION", 3, 0, NULL, onevalue},
89 {"rpict", 3, 0, NULL, catvalues},
90 {"rvu", 3, 0, NULL, catvalues},
91 {"scene", 3, 0, NULL, catvalues},
92 {"UP", 2, 0, NULL, onevalue},
93 {"VARIABILITY", 3, 0, NULL, qualvalue},
94 {"view", 2, 0, NULL, NULL},
95 {"ZFILE", 2, 0, NULL, onevalue},
96 {"ZONE", 2, 0, NULL, onevalue},
97 };
98
99 /* overture calculation file */
100 #ifdef NULL_DEVICE
101 char overfile[] = NULL_DEVICE;
102 #else
103 char overfile[] = "overture.unf";
104 #endif
105
106
107 time_t scenedate; /* date of latest scene or object file */
108 time_t octreedate; /* date of octree */
109 time_t matdate; /* date of latest material file */
110 time_t illumdate; /* date of last illum file */
111
112 char *oct0name; /* name of pre-mkillum octree */
113 time_t oct0date; /* date of pre-mkillum octree */
114 char *oct1name; /* name of post-mkillum octree */
115 time_t oct1date; /* date of post-mkillum octree (>= matdate) */
116
117 char *pgmapname; /* name of global photon map */
118 time_t pgmapdate; /* date of global photon map (>= oct1date) */
119 char *pcmapname; /* name of caustic photon map */
120 time_t pcmapdate; /* date of caustic photon map (>= oct1date) */
121
122 int nowarn = 0; /* no warnings */
123 int explicate = 0; /* explicate variables */
124 int silent = 0; /* do work silently */
125 int touchonly = 0; /* touch files only */
126 int nprocs = 1; /* maximum executing processes */
127 int sayview = 0; /* print view out */
128 char *rvdevice = NULL; /* rvu output device */
129 char *viewselect = NULL; /* specific view only */
130
131 #define DEF_RPICT_PATH "rpict" /* default rpict path */
132
133 /* command paths */
134 char c_oconv[256] = "oconv";
135 char c_mkillum[256] = "mkillum";
136 char c_mkpmap[256] = "mkpmap";
137 char c_rvu[256] = "rvu";
138 char c_rpict[256] = DEF_RPICT_PATH;
139 char c_rpiece[] = "rpiece";
140 char c_pfilt[256] = "pfilt";
141
142 int overture = 0; /* overture calculation needed */
143
144 int children_running = 0; /* set negative in children */
145
146 char *progname; /* global argv[0] */
147 char *rifname; /* global rad input file name */
148
149 char radname[PATH_MAX]; /* root Radiance file name */
150
151 #define inchild() (children_running < 0)
152
153 static void rootname(char *rn, char *fn);
154 static time_t checklast(char *fnames);
155 static char * newfname(char *orig, int pred);
156 static void checkfiles(void);
157 static void getoctcube(double org[3], double *sizp);
158 static void setdefaults(void);
159 static void oconv(void);
160 static void mkpmap(void);
161 static char * addarg(char *op, char *arg);
162 static void oconvopts(char *oo);
163 static void mkillumopts(char *mo);
164 static void mkpmapopts(char *mo);
165 static void checkambfile(void);
166 static double ambval(void);
167 static void renderopts(char *op, char *po);
168 static void lowqopts(char *op, char *po);
169 static void medqopts(char *op, char *po);
170 static void hiqopts(char *op, char *po);
171 static void xferopts(char *ro);
172 static void pfiltopts(char *po);
173 static int matchword(char *s1, char *s2);
174 static char * specview(char *vs);
175 static char * getview(int n, char *vn);
176 static int myprintview(char *vopts, FILE *fp);
177 static void rvu(char *opts, char *po);
178 static void rpict(char *opts, char *po);
179 static int touch(char *fn);
180 static int runcom(char *cs);
181 static int rmfile(char *fn);
182 static int mvfile(char *fold, char *fnew);
183 static int next_process(int reserve);
184 static void wait_process(int all);
185 static void finish_process(void);
186 static void badvalue(int vc);
187 static void syserr(char *s);
188
189
190 int
191 main(
192 int argc,
193 char *argv[]
194 )
195 {
196 char ropts[512];
197 char popts[64];
198 int i;
199
200 progname = argv[0];
201 /* get options */
202 for (i = 1; i < argc && argv[i][0] == '-'; i++)
203 switch (argv[i][1]) {
204 case 's':
205 silent++;
206 break;
207 case 'n':
208 nprocs = 0;
209 break;
210 case 'N':
211 nprocs = atoi(argv[++i]);
212 if (nprocs < 0)
213 nprocs = 0;
214 break;
215 case 't':
216 touchonly++;
217 break;
218 case 'e':
219 explicate++;
220 break;
221 case 'o':
222 rvdevice = argv[++i];
223 break;
224 case 'V':
225 sayview++;
226 break;
227 case 'v':
228 viewselect = argv[++i];
229 break;
230 case 'w':
231 nowarn++;
232 break;
233 default:
234 goto userr;
235 }
236 if (i >= argc)
237 goto userr;
238 rifname = argv[i];
239 /* assign Radiance root file name */
240 rootname(radname, rifname);
241 /* load variable values */
242 loadvars(rifname);
243 /* get any additional assignments */
244 for (i++; i < argc; i++)
245 if (setvariable(argv[i], matchvar) < 0) {
246 fprintf(stderr, "%s: unknown variable: %s\n",
247 progname, argv[i]);
248 quit(1);
249 }
250 /* check assignments */
251 checkvalues();
252 /* check files and dates */
253 checkfiles();
254 /* set default values as necessary */
255 setdefaults();
256 /* print all values if requested */
257 if (explicate)
258 printvars(stdout);
259 /* build octree (and run mkillum) */
260 oconv();
261 /* run mkpmap if indicated */
262 mkpmap();
263 /* check date on ambient file */
264 checkambfile();
265 /* run simulation */
266 renderopts(ropts, popts);
267 xferopts(ropts);
268 if (rvdevice != NULL)
269 rvu(ropts, popts);
270 else
271 rpict(ropts, popts);
272 quit(0);
273 userr:
274 fprintf(stderr,
275 "Usage: %s [-w][-s][-n|-N npr][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n",
276 progname);
277 quit(1);
278 return 1; /* pro forma return */
279 }
280
281
282 static void
283 rootname( /* remove tail from end of fn */
284 char *rn,
285 char *fn
286 )
287 {
288 char *tp, *dp;
289
290 for (tp = NULL, dp = rn; (*rn = *fn++); rn++)
291 if (ISDIRSEP(*rn))
292 dp = rn;
293 else if (*rn == '.')
294 tp = rn;
295 if (tp != NULL && tp > dp)
296 *tp = '\0';
297 }
298
299
300 static time_t
301 checklast( /* check files and find most recent */
302 char *fnames
303 )
304 {
305 char thisfile[PATH_MAX];
306 time_t thisdate, lastdate = 0;
307
308 if (fnames == NULL)
309 return(0);
310 while ((fnames = nextword(thisfile, PATH_MAX, fnames)) != NULL) {
311 if (thisfile[0] == '!' ||
312 (thisfile[0] == '\\' && thisfile[1] == '!')) {
313 if (!lastdate)
314 lastdate = 1;
315 continue;
316 }
317 if (!(thisdate = fdate(thisfile)))
318 syserr(thisfile);
319 if (thisdate > lastdate)
320 lastdate = thisdate;
321 }
322 return(lastdate);
323 }
324
325
326 static char *
327 newfname( /* create modified file name */
328 char *orig,
329 int pred
330 )
331 {
332 char *cp;
333 int n;
334 int suffix;
335
336 n = 0; cp = orig; suffix = -1; /* suffix position, length */
337 while (*cp) {
338 if (*cp == '.') suffix = n;
339 else if (ISDIRSEP(*cp)) suffix = -1;
340 cp++; n++;
341 }
342 if (suffix == -1) suffix = n;
343 if ((cp = bmalloc(n+2)) == NULL)
344 syserr(progname);
345 strncpy(cp, orig, suffix);
346 cp[suffix] = pred; /* root name + pred + suffix */
347 strcpy(cp+suffix+1, orig+suffix);
348 return(cp);
349 }
350
351
352 static void
353 checkfiles(void) /* check for existence and modified times */
354 {
355 char fntemp[256];
356 time_t objdate;
357
358 if (!vdef(OCTREE)) {
359 if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL)
360 syserr(progname);
361 sprintf(vval(OCTREE), "%s.oct", radname);
362 vdef(OCTREE)++;
363 } else if (vval(OCTREE)[0] == '!') {
364 fprintf(stderr, "%s: illegal '%s' specification\n",
365 progname, vnam(OCTREE));
366 quit(1);
367 }
368 octreedate = fdate(vval(OCTREE));
369 if (vdef(ILLUM)) { /* illum requires secondary octrees */
370 oct0name = newfname(vval(OCTREE), '0');
371 oct1name = newfname(vval(OCTREE), '1');
372 oct0date = fdate(oct0name);
373 oct1date = fdate(oct1name);
374 } else
375 oct0name = oct1name = vval(OCTREE);
376 if ((scenedate = checklast(vval(SCENE))) &&
377 (objdate = checklast(vval(OBJECT))) > scenedate)
378 scenedate = objdate;
379 illumdate = checklast(vval(ILLUM));
380 if (!octreedate & !scenedate & !illumdate) {
381 fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname,
382 vnam(OCTREE), vnam(SCENE), vnam(ILLUM));
383 quit(1);
384 }
385 if (vdef(PGMAP)) {
386 if (!*sskip2(vval(PGMAP),1)) {
387 fprintf(stderr, "%s: '%s' missing # photons argument\n",
388 progname, vnam(PGMAP));
389 quit(1);
390 }
391 atos(fntemp, sizeof(fntemp), vval(PGMAP));
392 pgmapname = savqstr(fntemp);
393 pgmapdate = fdate(pgmapname);
394 }
395 if (vdef(PCMAP)) {
396 if (!*sskip2(vval(PCMAP),1)) {
397 fprintf(stderr, "%s: '%s' missing # photons argument\n",
398 progname, vnam(PCMAP));
399 quit(1);
400 }
401 atos(fntemp, sizeof(fntemp), vval(PCMAP));
402 pcmapname = savqstr(fntemp);
403 pcmapdate = fdate(pcmapname);
404 }
405 matdate = checklast(vval(MATERIAL));
406 }
407
408
409 static void
410 getoctcube( /* get octree bounding cube */
411 double org[3],
412 double *sizp
413 )
414 {
415 static double oorg[3], osiz = 0.;
416 double min[3], max[3];
417 char buf[1024];
418 FILE *fp;
419 int i;
420
421 if (osiz <= FTINY) {
422 if (!nprocs && fdate(oct1name) <
423 (scenedate>illumdate?scenedate:illumdate)) {
424 /* run getbbox */
425 sprintf(buf, "getbbox -w -h %s",
426 vdef(SCENE) ? vval(SCENE) : vval(ILLUM));
427 if ((fp = popen(buf, "r")) == NULL)
428 syserr("getbbox");
429 if (fscanf(fp, "%lf %lf %lf %lf %lf %lf",
430 &min[0], &max[0], &min[1], &max[1],
431 &min[2], &max[2]) != 6) {
432 fprintf(stderr,
433 "%s: error reading bounding box from getbbox\n",
434 progname);
435 quit(1);
436 }
437 for (i = 0; i < 3; i++)
438 if (max[i] - min[i] > osiz)
439 osiz = max[i] - min[i];
440 for (i = 0; i < 3; i++)
441 oorg[i] = (max[i]+min[i]-osiz)*.5;
442 pclose(fp);
443 } else { /* from octree */
444 oconv(); /* does nothing if done already */
445 sprintf(buf, "getinfo -d < %s", oct1name);
446 if ((fp = popen(buf, "r")) == NULL)
447 syserr("getinfo");
448 if (fscanf(fp, "%lf %lf %lf %lf", &oorg[0], &oorg[1],
449 &oorg[2], &osiz) != 4) {
450 fprintf(stderr,
451 "%s: error reading bounding cube from getinfo\n",
452 progname);
453 quit(1);
454 }
455 pclose(fp);
456 }
457 }
458 org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz;
459 }
460
461
462 static void
463 setdefaults(void) /* set default values for unassigned var's */
464 {
465 double org[3], lim[3], size;
466 char buf[128];
467
468 if (!vdef(ZONE)) {
469 getoctcube(org, &size);
470 sprintf(buf, "E %g %g %g %g %g %g", org[0], org[0]+size,
471 org[1], org[1]+size, org[2], org[2]+size);
472 vval(ZONE) = savqstr(buf);
473 vdef(ZONE)++;
474 }
475 if (!vdef(EYESEP)) {
476 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
477 &org[0], &lim[0], &org[1], &lim[1],
478 &org[2], &lim[2]) != 6)
479 badvalue(ZONE);
480 sprintf(buf, "%f",
481 0.01*(lim[0]-org[0]+lim[1]-org[1]+lim[2]-org[2]));
482 vval(EYESEP) = savqstr(buf);
483 vdef(EYESEP)++;
484 }
485 if (!vdef(INDIRECT)) {
486 vval(INDIRECT) = "0";
487 vdef(INDIRECT)++;
488 }
489 if (!vdef(QUALITY)) {
490 vval(QUALITY) = "L";
491 vdef(QUALITY)++;
492 }
493 if (!vdef(RESOLUTION)) {
494 vval(RESOLUTION) = "512";
495 vdef(RESOLUTION)++;
496 }
497 if (!vdef(PICTURE)) {
498 vval(PICTURE) = radname;
499 vdef(PICTURE)++;
500 }
501 if (!vdef(VIEWS)) {
502 vval(VIEWS) = "X";
503 vdef(VIEWS)++;
504 }
505 if (!vdef(DETAIL)) {
506 vval(DETAIL) = "M";
507 vdef(DETAIL)++;
508 }
509 if (!vdef(PENUMBRAS)) {
510 vval(PENUMBRAS) = "F";
511 vdef(PENUMBRAS)++;
512 }
513 if (!vdef(VARIABILITY)) {
514 vval(VARIABILITY) = "L";
515 vdef(VARIABILITY)++;
516 }
517 }
518
519
520 static void
521 oconv(void) /* run oconv and mkillum if necessary */
522 {
523 static char illumtmp[] = "ilXXXXXX";
524 char combuf[PATH_MAX], ocopts[64], mkopts[1024];
525
526 oconvopts(ocopts); /* get options */
527 if (octreedate < scenedate) { /* check date on original octree */
528 if (touchonly && octreedate)
529 touch(vval(OCTREE));
530 else { /* build command */
531 if (vdef(MATERIAL))
532 sprintf(combuf, "%s%s %s %s > %s", c_oconv,
533 ocopts, vval(MATERIAL),
534 vval(SCENE), vval(OCTREE));
535 else
536 sprintf(combuf, "%s%s %s > %s", c_oconv, ocopts,
537 vval(SCENE), vval(OCTREE));
538
539 if (runcom(combuf)) { /* run it */
540 fprintf(stderr,
541 "%s: error generating octree\n\t%s removed\n",
542 progname, vval(OCTREE));
543 unlink(vval(OCTREE));
544 quit(1);
545 }
546 }
547 octreedate = time((time_t *)NULL);
548 if (octreedate < scenedate) /* in case clock is off */
549 octreedate = scenedate;
550 }
551 if (oct1name == vval(OCTREE)) /* no mkillum? */
552 oct1date = octreedate > matdate ? octreedate : matdate;
553 if ((oct1date >= octreedate) & (oct1date >= matdate)
554 & (oct1date >= illumdate)) /* all done */
555 return;
556 /* make octree0 */
557 if ((oct0date < scenedate) | (oct0date < illumdate)) {
558 if (touchonly && oct0date)
559 touch(oct0name);
560 else { /* build command */
561 if (octreedate)
562 sprintf(combuf, "%s%s -i %s %s > %s", c_oconv,
563 ocopts, vval(OCTREE),
564 vval(ILLUM), oct0name);
565 else if (vdef(MATERIAL))
566 sprintf(combuf, "%s%s %s %s > %s", c_oconv,
567 ocopts, vval(MATERIAL),
568 vval(ILLUM), oct0name);
569 else
570 sprintf(combuf, "%s%s %s > %s", c_oconv,
571 ocopts, vval(ILLUM), oct0name);
572 if (runcom(combuf)) { /* run it */
573 fprintf(stderr,
574 "%s: error generating octree\n\t%s removed\n",
575 progname, oct0name);
576 unlink(oct0name);
577 quit(1);
578 }
579 }
580 oct0date = time((time_t *)NULL);
581 if (oct0date < octreedate) /* in case clock is off */
582 oct0date = octreedate;
583 if (oct0date < illumdate) /* ditto */
584 oct0date = illumdate;
585 }
586 if (touchonly && oct1date)
587 touch(oct1name);
588 else {
589 mkillumopts(mkopts); /* build mkillum command */
590 mktemp(illumtmp);
591 sprintf(combuf, "%s%s %s \"<\" %s > %s", c_mkillum, mkopts,
592 oct0name, vval(ILLUM), illumtmp);
593 if (runcom(combuf)) { /* run it */
594 fprintf(stderr, "%s: error running %s\n",
595 progname, c_mkillum);
596 unlink(illumtmp);
597 quit(1);
598 }
599 rmfile(oct0name);
600 /* make octree1 (frozen) */
601 if (octreedate)
602 sprintf(combuf, "%s%s -f -i %s %s > %s", c_oconv,
603 ocopts, vval(OCTREE), illumtmp, oct1name);
604 else if (vdef(MATERIAL))
605 sprintf(combuf, "%s%s -f %s %s > %s", c_oconv,
606 ocopts, vval(MATERIAL), illumtmp, oct1name);
607 else
608 sprintf(combuf, "%s%s -f %s > %s", c_oconv, ocopts,
609 illumtmp, oct1name);
610 if (runcom(combuf)) { /* run it */
611 fprintf(stderr,
612 "%s: error generating octree\n\t%s removed\n",
613 progname, oct1name);
614 unlink(oct1name);
615 unlink(illumtmp);
616 quit(1);
617 }
618 rmfile(illumtmp);
619 }
620 oct1date = time((time_t *)NULL);
621 if (oct1date < oct0date) /* in case clock is off */
622 oct1date = oct0date;
623 }
624
625
626 static void
627 mkpmap(void) /* run mkpmap if indicated */
628 {
629 char combuf[2048], *cp;
630 time_t tnow;
631 /* nothing to do? */
632 if ((pgmapname == NULL) | (pgmapdate >= oct1date) &&
633 (pcmapname == NULL) | (pcmapdate >= oct1date))
634 return;
635 /* just update existing file dates? */
636 if (touchonly && (pgmapname == NULL) | (pgmapdate > 0) &&
637 (pcmapname == NULL) | (pcmapdate > 0)) {
638 if (pgmapname != NULL)
639 touch(pgmapname);
640 if (pcmapname != NULL)
641 touch(pcmapname);
642 } else { /* else need to (re)run pkpmap */
643 strcpy(combuf, c_mkpmap);
644 for (cp = combuf; *cp; cp++)
645 ;
646 mkpmapopts(cp);
647 if (vdef(REPORT)) {
648 char errfile[256];
649 int n;
650 double minutes;
651 n = sscanf(vval(REPORT), "%lf %s", &minutes, errfile);
652 if (n == 2)
653 sprintf(cp, " -t %d -e %s", (int)(minutes*60), errfile);
654 else if (n == 1)
655 sprintf(cp, " -t %d", (int)(minutes*60));
656 else
657 badvalue(REPORT);
658 }
659 if (pgmapname != NULL && pgmapdate < oct1date) {
660 if (pgmapdate)
661 rmfile(pgmapname);
662 cp = addarg(cp, "-apg");
663 addarg(cp, vval(PGMAP));
664 cp = sskip(sskip(cp)); /* remove any bandwidth */
665 *cp = '\0';
666 }
667 if (pcmapname != NULL && pcmapdate < oct1date) {
668 if (pcmapdate)
669 rmfile(pcmapname);
670 cp = addarg(cp, "-apc");
671 addarg(cp, vval(PCMAP));
672 cp = sskip(sskip(cp)); /* remove any bandwidth */
673 *cp = '\0';
674 }
675 cp = addarg(cp, oct1name);
676 if (runcom(combuf)) {
677 fprintf(stderr, "%s: error running %s\n",
678 progname, c_mkpmap);
679 if (pgmapname != NULL && pgmapdate < oct1date)
680 unlink(pgmapname);
681 if (pcmapname != NULL && pcmapdate < oct1date)
682 unlink(pcmapname);
683 quit(1);
684 }
685 }
686 tnow = time((time_t *)NULL);
687 if (pgmapname != NULL)
688 pgmapdate = tnow;
689 if (pcmapname != NULL)
690 pcmapdate = tnow;
691 oct1date = tnow; /* trigger ambient file removal if needed */
692 }
693
694
695 static char *
696 addarg( /* append argument and advance pointer */
697 char *op,
698 char *arg
699 )
700 {
701 while (*op)
702 op++;
703 *op = ' ';
704 while ( (*++op = *arg++) )
705 ;
706 return(op);
707 }
708
709
710 static void
711 oconvopts( /* get oconv options */
712 char *oo
713 )
714 {
715 /* BEWARE: This may be called via setdefaults(), so no assumptions */
716
717 *oo = '\0';
718 if (!vdef(OCONV))
719 return;
720 if (vval(OCONV)[0] != '-') {
721 atos(c_oconv, sizeof(c_oconv), vval(OCONV));
722 oo = addarg(oo, sskip2(vval(OCONV), 1));
723 } else
724 oo = addarg(oo, vval(OCONV));
725 }
726
727
728 static void
729 mkillumopts( /* get mkillum options */
730 char *mo
731 )
732 {
733 /* BEWARE: This may be called via setdefaults(), so no assumptions */
734
735 if (nprocs > 1)
736 sprintf(mo, " -n %d", nprocs);
737 else
738 *mo = '\0';
739 if (!vdef(MKILLUM))
740 return;
741 if (vval(MKILLUM)[0] != '-') {
742 atos(c_mkillum, sizeof(c_mkillum), vval(MKILLUM));
743 mo = addarg(mo, sskip2(vval(MKILLUM), 1));
744 } else
745 mo = addarg(mo, vval(MKILLUM));
746 }
747
748
749 static void
750 mkpmapopts( /* get mkpmap options */
751 char *mo
752 )
753 {
754 /* BEWARE: This may be called via setdefaults(), so no assumptions */
755
756 *mo = '\0';
757 if (!vdef(MKPMAP))
758 return;
759 if (vval(MKPMAP)[0] != '-') {
760 atos(c_mkpmap, sizeof(c_mkpmap), vval(MKPMAP));
761 mo = addarg(mo, sskip2(vval(MKPMAP), 1));
762 } else
763 mo = addarg(mo, vval(MKPMAP));
764 }
765
766
767 static void
768 checkambfile(void) /* check date on ambient file */
769 {
770 time_t afdate;
771
772 if (!vdef(AMBFILE))
773 return;
774 if (!(afdate = fdate(vval(AMBFILE))))
775 return;
776 if (oct1date > afdate) {
777 if (touchonly)
778 touch(vval(AMBFILE));
779 else
780 rmfile(vval(AMBFILE));
781 }
782 }
783
784
785 static double
786 ambval(void) /* compute ambient value */
787 {
788 if (vdef(EXPOSURE)) {
789 if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-')
790 return(.5/pow(2.,vflt(EXPOSURE)));
791 return(.5/vflt(EXPOSURE));
792 }
793 if (vlet(ZONE) == 'E')
794 return(10.);
795 if (vlet(ZONE) == 'I')
796 return(.01);
797 badvalue(ZONE);
798 return 0; /* pro forma return */
799 }
800
801
802 static void
803 renderopts( /* set rendering options */
804 char *op,
805 char *po
806 )
807 {
808 char pmapf[256], *bw;
809
810 switch(vscale(QUALITY)) {
811 case LOW:
812 lowqopts(op, po);
813 break;
814 case MEDIUM:
815 medqopts(op, po);
816 break;
817 case HIGH:
818 hiqopts(op, po);
819 break;
820 }
821 if (vdef(PGMAP)) {
822 bw = sskip2(vval(PGMAP), 2);
823 atos(pmapf, sizeof(pmapf), vval(PGMAP));
824 op = addarg(addarg(op, "-ap"), pmapf);
825 if (atoi(bw) > 0) op = addarg(op, bw);
826 }
827 if (vdef(PCMAP)) {
828 bw = sskip2(vval(PCMAP), 2);
829 atos(pmapf, sizeof(pmapf), vval(PCMAP));
830 op = addarg(addarg(op, "-ap"), pmapf);
831 if (atoi(bw) > 0) op = addarg(op, bw);
832 }
833 if (vdef(RENDER))
834 op = addarg(op, vval(RENDER));
835 if (rvdevice != NULL) {
836 if (vdef(RVU))
837 if (vval(RVU)[0] != '-') {
838 atos(c_rvu, sizeof(c_rvu), vval(RVU));
839 po = addarg(po, sskip2(vval(RVU), 1));
840 } else
841 po = addarg(po, vval(RVU));
842 } else {
843 if (vdef(RPICT))
844 if (vval(RPICT)[0] != '-') {
845 atos(c_rpict, sizeof(c_rpict), vval(RPICT));
846 po = addarg(po, sskip2(vval(RPICT), 1));
847 } else
848 po = addarg(po, vval(RPICT));
849 }
850 }
851
852
853 static void
854 lowqopts( /* low quality rendering options */
855 char *op,
856 char *po
857 )
858 {
859 double d, org[3], siz[3];
860
861 *op = '\0';
862 *po = '\0';
863 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
864 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
865 badvalue(ZONE);
866 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
867 if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY))
868 badvalue(ZONE);
869 getoctcube(org, &d);
870 d *= 3./(siz[0]+siz[1]+siz[2]);
871 switch (vscale(DETAIL)) {
872 case LOW:
873 po = addarg(po, "-ps 16");
874 op = addarg(op, "-dp 64");
875 sprintf(op, " -ar %d", (int)(8*d));
876 op += strlen(op);
877 break;
878 case MEDIUM:
879 po = addarg(po, "-ps 8");
880 op = addarg(op, "-dp 128");
881 sprintf(op, " -ar %d", (int)(16*d));
882 op += strlen(op);
883 break;
884 case HIGH:
885 po = addarg(po, "-ps 4");
886 op = addarg(op, "-dp 256");
887 sprintf(op, " -ar %d", (int)(32*d));
888 op += strlen(op);
889 break;
890 }
891 po = addarg(po, "-pt .16");
892 if (vbool(PENUMBRAS))
893 op = addarg(op, "-ds .4");
894 else
895 op = addarg(op, "-ds 0");
896 op = addarg(op, "-dt .2 -dc .25 -dr 0 -ss 0 -st .5");
897 if (vdef(AMBFILE)) {
898 sprintf(op, " -af %s", vval(AMBFILE));
899 op += strlen(op);
900 } else
901 overture = 0;
902 switch (vscale(VARIABILITY)) {
903 case LOW:
904 op = addarg(op, "-aa .3 -ad 256");
905 break;
906 case MEDIUM:
907 op = addarg(op, "-aa .25 -ad 512");
908 break;
909 case HIGH:
910 op = addarg(op, "-aa .2 -ad 1024");
911 break;
912 }
913 op = addarg(op, "-as 0");
914 d = ambval();
915 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
916 op += strlen(op);
917 op = addarg(op, "-lr 6 -lw .003");
918 }
919
920
921 static void
922 medqopts( /* medium quality rendering options */
923 char *op,
924 char *po
925 )
926 {
927 double d, org[3], siz[3], asz;
928
929 *op = '\0';
930 *po = '\0';
931 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
932 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
933 badvalue(ZONE);
934 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
935 if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY))
936 badvalue(ZONE);
937 getoctcube(org, &d);
938 asz = (siz[0]+siz[1]+siz[2])/3.;
939 d /= asz;
940 switch (vscale(DETAIL)) {
941 case LOW:
942 po = addarg(po, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8");
943 op = addarg(op, "-dp 256");
944 sprintf(op, " -ar %d", (int)(16*d));
945 op += strlen(op);
946 sprintf(op, " -ms %.2g", asz/20.);
947 op += strlen(op);
948 break;
949 case MEDIUM:
950 po = addarg(po, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6");
951 op = addarg(op, "-dp 512");
952 sprintf(op, " -ar %d", (int)(32*d));
953 op += strlen(op);
954 sprintf(op, " -ms %.2g", asz/40.);
955 op += strlen(op);
956 break;
957 case HIGH:
958 po = addarg(po, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4");
959 op = addarg(op, "-dp 1024");
960 sprintf(op, " -ar %d", (int)(64*d));
961 op += strlen(op);
962 sprintf(op, " -ms %.2g", asz/80.);
963 op += strlen(op);
964 break;
965 }
966 po = addarg(po, "-pt .08");
967 if (vbool(PENUMBRAS))
968 op = addarg(op, "-ds .2 -dj .9");
969 else
970 op = addarg(op, "-ds .3");
971 op = addarg(op, "-dt .1 -dc .5 -dr 1 -ss 1 -st .1");
972 if ( (overture = vint(INDIRECT)) ) {
973 sprintf(op, " -ab %d", overture);
974 op += strlen(op);
975 }
976 if (vdef(AMBFILE)) {
977 sprintf(op, " -af %s", vval(AMBFILE));
978 op += strlen(op);
979 } else
980 overture = 0;
981 switch (vscale(VARIABILITY)) {
982 case LOW:
983 op = addarg(op, "-aa .2 -ad 329 -as 42");
984 break;
985 case MEDIUM:
986 op = addarg(op, "-aa .15 -ad 800 -as 128");
987 break;
988 case HIGH:
989 op = addarg(op, "-aa .1 -ad 1536 -as 392");
990 break;
991 }
992 d = ambval();
993 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
994 op += strlen(op);
995 op = addarg(op, "-lr 8 -lw 1e-4");
996 }
997
998
999 static void
1000 hiqopts( /* high quality rendering options */
1001 char *op,
1002 char *po
1003 )
1004 {
1005 double d, org[3], siz[3], asz;
1006
1007 *op = '\0';
1008 *po = '\0';
1009 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0],
1010 &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6)
1011 badvalue(ZONE);
1012 siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2];
1013 if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY))
1014 badvalue(ZONE);
1015 getoctcube(org, &d);
1016 asz = (siz[0]+siz[1]+siz[2])/3.;
1017 d /= asz;
1018 switch (vscale(DETAIL)) {
1019 case LOW:
1020 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8");
1021 op = addarg(op, "-dp 1024");
1022 sprintf(op, " -ar %d", (int)(32*d));
1023 op += strlen(op);
1024 sprintf(op, " -ms %.2g", asz/40.);
1025 op += strlen(op);
1026 break;
1027 case MEDIUM:
1028 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5");
1029 op = addarg(op, "-dp 2048");
1030 sprintf(op, " -ar %d", (int)(64*d));
1031 op += strlen(op);
1032 sprintf(op, " -ms %.2g", asz/80.);
1033 op += strlen(op);
1034 break;
1035 case HIGH:
1036 po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3");
1037 op = addarg(op, "-dp 4096");
1038 sprintf(op, " -ar %d", (int)(128*d));
1039 op += strlen(op);
1040 sprintf(op, " -ms %.2g", asz/160.);
1041 op += strlen(op);
1042 break;
1043 }
1044 po = addarg(po, "-pt .04");
1045 if (vbool(PENUMBRAS))
1046 op = addarg(op, "-ds .1 -dj .9");
1047 else
1048 op = addarg(op, "-ds .2");
1049 op = addarg(op, "-dt .05 -dc .75 -dr 3 -ss 16 -st .01");
1050 sprintf(op, " -ab %d", overture=vint(INDIRECT)+1);
1051 op += strlen(op);
1052 if (vdef(AMBFILE)) {
1053 sprintf(op, " -af %s", vval(AMBFILE));
1054 op += strlen(op);
1055 } else
1056 overture = 0;
1057 switch (vscale(VARIABILITY)) {
1058 case LOW:
1059 op = addarg(op, "-aa .125 -ad 512 -as 64");
1060 break;
1061 case MEDIUM:
1062 op = addarg(op, "-aa .1 -ad 1536 -as 768");
1063 break;
1064 case HIGH:
1065 op = addarg(op, "-aa .075 -ad 4096 -as 2048");
1066 break;
1067 }
1068 d = ambval();
1069 sprintf(op, " -av %.2g %.2g %.2g", d, d, d);
1070 op += strlen(op);
1071 op = addarg(op, "-lr 12 -lw 1e-5");
1072 }
1073
1074
1075 #ifdef _WIN32
1076 static void
1077 setenv( /* set an environment variable */
1078 char *vname,
1079 char *value
1080 )
1081 {
1082 char *evp;
1083
1084 evp = bmalloc(strlen(vname)+strlen(value)+2);
1085 if (evp == NULL)
1086 syserr(progname);
1087 sprintf(evp, "%s=%s", vname, value);
1088 if (putenv(evp) != 0) {
1089 fprintf(stderr, "%s: out of environment space\n", progname);
1090 quit(1);
1091 }
1092 if (!silent)
1093 printf("set %s\n", evp);
1094 }
1095 #endif
1096
1097
1098 static void
1099 xferopts( /* transfer options if indicated */
1100 char *ro
1101 )
1102 {
1103 int fd, n;
1104 char *cp;
1105
1106 n = strlen(ro);
1107 if (n < 2)
1108 return;
1109 if (vdef(OPTFILE)) {
1110 for (cp = ro; cp[1]; cp++)
1111 if (isspace(cp[1]) && (cp[2] == '@' ||
1112 (cp[2] == '-' && isalpha(cp[3]))))
1113 *cp = '\n';
1114 else
1115 *cp = cp[1];
1116 *cp = '\n';
1117 fd = open(vval(OPTFILE), O_WRONLY|O_CREAT|O_TRUNC, 0666);
1118 if (fd < 0 || write(fd, ro, n) != n || close(fd) < 0)
1119 syserr(vval(OPTFILE));
1120 sprintf(ro, " @%s", vval(OPTFILE));
1121 }
1122 #ifdef _WIN32
1123 else if (n > 50) {
1124 setenv("ROPT", ro+1);
1125 strcpy(ro, " $ROPT");
1126 }
1127 #endif
1128 }
1129
1130
1131 static void
1132 pfiltopts( /* get pfilt options */
1133 char *po
1134 )
1135 {
1136 *po = '\0';
1137 if (vdef(EXPOSURE)) {
1138 po = addarg(po, "-1 -e");
1139 po = addarg(po, vval(EXPOSURE));
1140 }
1141 switch (vscale(QUALITY)) {
1142 case MEDIUM:
1143 po = addarg(po, "-r .6");
1144 break;
1145 case HIGH:
1146 po = addarg(po, "-m .25");
1147 break;
1148 }
1149 if (vdef(PFILT))
1150 if (vval(PFILT)[0] != '-') {
1151 atos(c_pfilt, sizeof(c_pfilt), vval(PFILT));
1152 po = addarg(po, sskip2(vval(PFILT), 1));
1153 } else
1154 po = addarg(po, vval(PFILT));
1155 }
1156
1157
1158 static int
1159 matchword( /* match white-delimited words */
1160 char *s1,
1161 char *s2
1162 )
1163 {
1164 while (isspace(*s1)) s1++;
1165 while (isspace(*s2)) s2++;
1166 while (*s1 && !isspace(*s1))
1167 if (*s1++ != *s2++)
1168 return(0);
1169 return(!*s2 || isspace(*s2));
1170 }
1171
1172
1173 static char *
1174 specview( /* get proper view spec from vs */
1175 char *vs
1176 )
1177 {
1178 static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0",
1179 "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"};
1180 static char viewopts[128];
1181 char *cp;
1182 int xpos, ypos, zpos, viewtype, upax;
1183 int i;
1184 double cent[3], dim[3], mult, d;
1185
1186 if (vs == NULL || *vs == '-')
1187 return(vs);
1188 upax = 0; /* get the up vector */
1189 if (vdef(UP)) {
1190 if (vval(UP)[0] == '-' || vval(UP)[0] == '+')
1191 upax = 1-'X'+UPPER(vval(UP)[1]);
1192 else
1193 upax = 1-'X'+vlet(UP);
1194 if ((upax < 1) | (upax > 3))
1195 badvalue(UP);
1196 if (vval(UP)[0] == '-')
1197 upax = -upax;
1198 }
1199 /* check standard view names */
1200 xpos = ypos = zpos = 0;
1201 if (*vs == 'X') {
1202 xpos = 1; vs++;
1203 } else if (*vs == 'x') {
1204 xpos = -1; vs++;
1205 }
1206 if (*vs == 'Y') {
1207 ypos = 1; vs++;
1208 } else if (*vs == 'y') {
1209 ypos = -1; vs++;
1210 }
1211 if (*vs == 'Z') {
1212 zpos = 1; vs++;
1213 } else if (*vs == 'z') {
1214 zpos = -1; vs++;
1215 }
1216 switch (*vs) {
1217 case VT_PER:
1218 case VT_PAR:
1219 case VT_ANG:
1220 case VT_HEM:
1221 case VT_PLS:
1222 case VT_CYL:
1223 viewtype = *vs++;
1224 break;
1225 default:
1226 viewtype = VT_PER;
1227 break;
1228 }
1229 cp = viewopts;
1230 if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */
1231 *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype;
1232 if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf",
1233 &cent[0], &dim[0], &cent[1], &dim[1],
1234 &cent[2], &dim[2]) != 6)
1235 badvalue(ZONE);
1236 for (i = 0; i < 3; i++) {
1237 dim[i] -= cent[i];
1238 if (dim[i] <= FTINY)
1239 badvalue(ZONE);
1240 cent[i] += .5*dim[i];
1241 }
1242 mult = vlet(ZONE)=='E' ? 2. : .45 ;
1243 sprintf(cp, " -vp %.3g %.3g %.3g -vd %.3g %.3g %.3g",
1244 cent[0]+xpos*mult*dim[0],
1245 cent[1]+ypos*mult*dim[1],
1246 cent[2]+zpos*mult*dim[2],
1247 -xpos*dim[0], -ypos*dim[1], -zpos*dim[2]);
1248 cp += strlen(cp);
1249 /* redirect up axis if necessary */
1250 switch (upax) {
1251 case 3: /* plus or minus Z axis */
1252 case -3:
1253 case 0:
1254 if (!(xpos|ypos))
1255 upax = 2;
1256 break;
1257 case 2: /* plus or minus Y axis */
1258 case -2:
1259 if (!(xpos|zpos))
1260 upax = 1;
1261 break;
1262 case 1: /* plus or minus X axis */
1263 case -1:
1264 if (!(ypos|zpos))
1265 upax = 3;
1266 break;
1267 }
1268 cp = addarg(cp, vup[upax+3]);
1269 switch (viewtype) {
1270 case VT_PER:
1271 cp = addarg(cp, "-vh 45 -vv 45");
1272 break;
1273 case VT_PAR:
1274 d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]);
1275 sprintf(cp, " -vh %.3g -vv %.3g", d, d);
1276 cp += strlen(cp);
1277 break;
1278 case VT_ANG:
1279 case VT_HEM:
1280 case VT_PLS:
1281 cp = addarg(cp, "-vh 180 -vv 180");
1282 break;
1283 case VT_CYL:
1284 cp = addarg(cp, "-vh 180 -vv 90");
1285 break;
1286 }
1287 } else {
1288 while (!isspace(*vs)) /* else skip id */
1289 if (!*vs++)
1290 return(NULL);
1291 if (upax) { /* prepend up vector */
1292 strcpy(cp, vup[upax+3]);
1293 cp += strlen(cp);
1294 }
1295 }
1296 if (cp == viewopts) /* append any additional options */
1297 vs++; /* skip prefixed space if unneeded */
1298 strcpy(cp, vs);
1299 #ifdef _WIN32
1300 if (strlen(viewopts) > 40) {
1301 setenv("VIEW", viewopts);
1302 return("$VIEW");
1303 }
1304 #endif
1305 return(viewopts);
1306 }
1307
1308
1309 static char *
1310 getview( /* get view n, or NULL if none */
1311 int n,
1312 char *vn /* returned view name */
1313 )
1314 {
1315 char *mv;
1316
1317 if (viewselect != NULL) { /* command-line selected */
1318 if (n) /* only do one */
1319 return(NULL);
1320
1321 if (isint(viewselect)) { /* view number? */
1322 n = atoi(viewselect)-1;
1323 goto numview;
1324 }
1325 if (viewselect[0] == '-') { /* already specified */
1326 if (vn != NULL)
1327 strcpy(vn, "0");
1328 return(viewselect);
1329 }
1330 if (vn != NULL) {
1331 for (mv = viewselect; *mv && !isspace(*mv);
1332 *vn++ = *mv++)
1333 ;
1334 *vn = '\0';
1335 }
1336 /* check list */
1337 while ((mv = nvalue(VIEWS, n++)) != NULL)
1338 if (matchword(viewselect, mv))
1339 return(specview(mv));
1340
1341 return(specview(viewselect)); /* standard view? */
1342 }
1343 numview:
1344 mv = nvalue(VIEWS, n); /* use view n */
1345 if ((vn != NULL) & (mv != NULL))
1346 if (*mv != '-') {
1347 char *mv2 = mv;
1348 while (*mv2 && !isspace(*mv2))
1349 *vn++ = *mv2++;
1350 *vn = '\0';
1351 } else
1352 sprintf(vn, "%d", n+1);
1353
1354 return(specview(mv));
1355 }
1356
1357
1358 static int
1359 myprintview( /* print out selected view */
1360 char *vopts,
1361 FILE *fp
1362 )
1363 {
1364 VIEW vwr;
1365 char buf[128];
1366 char *cp;
1367 #ifdef _WIN32
1368 /* XXX Should we allow something like this for all platforms? */
1369 /* XXX Or is it still required at all? */
1370 again:
1371 #endif
1372 if (vopts == NULL)
1373 return(-1);
1374 #ifdef _WIN32
1375 if (vopts[0] == '$') {
1376 vopts = getenv(vopts+1);
1377 goto again;
1378 }
1379 #endif
1380 vwr = stdview;
1381 sscanview(&vwr, cp=vopts); /* set initial options */
1382 while ((cp = strstr(cp, "-vf ")) != NULL &&
1383 *atos(buf, sizeof(buf), cp += 4)) {
1384 viewfile(buf, &vwr, NULL); /* load -vf file */
1385 sscanview(&vwr, cp); /* reset tail */
1386 }
1387 fputs(VIEWSTR, fp);
1388 fprintview(&vwr, fp); /* print full spec. */
1389 fputc('\n', fp);
1390 return(0);
1391 }
1392
1393
1394 static void
1395 rvu( /* run rvu with first view */
1396 char *opts,
1397 char *po
1398 )
1399 {
1400 char *vw;
1401 char combuf[PATH_MAX];
1402 /* build command */
1403 if (touchonly || (vw = getview(0, NULL)) == NULL)
1404 return;
1405 if (sayview)
1406 myprintview(vw, stdout);
1407 sprintf(combuf, "%s %s%s%s -R %s ", c_rvu, vw, opts, po, rifname);
1408 if (nprocs > 1)
1409 sprintf(combuf+strlen(combuf), "-n %d ", nprocs);
1410 if (rvdevice != NULL)
1411 sprintf(combuf+strlen(combuf), "-o %s ", rvdevice);
1412 if (vdef(EXPOSURE))
1413 sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE));
1414 strcat(combuf, oct1name);
1415 if (runcom(combuf)) { /* run it */
1416 fprintf(stderr, "%s: error running %s\n", progname, c_rvu);
1417 quit(1);
1418 }
1419 }
1420
1421
1422 static int
1423 syncf_done( /* check if an rpiece sync file is complete */
1424 char *sfname
1425 )
1426 {
1427 FILE *fp = fopen(sfname, "r");
1428 int todo = 1;
1429 int x, y;
1430
1431 if (fp == NULL)
1432 return(0);
1433 if (fscanf(fp, "%d %d", &x, &y) != 2)
1434 goto checked;
1435 todo = x*y; /* total number of tiles */
1436 if (fscanf(fp, "%d %d", &x, &y) != 2 || (x != 0) | (y != 0))
1437 goto checked;
1438 /* XXX assume no redundant tiles */
1439 while (fscanf(fp, "%d %d", &x, &y) == 2)
1440 if (!--todo)
1441 break;
1442 checked:
1443 fclose(fp);
1444 return(!todo);
1445 }
1446
1447
1448 static void
1449 rpict( /* run rpict and pfilt for each view */
1450 char *opts,
1451 char *po
1452 )
1453 {
1454 #define do_rpiece (sfile[0]!='\0')
1455 char combuf[5*PATH_MAX+512];
1456 char rawfile[PATH_MAX], picfile[PATH_MAX];
1457 char zopt[PATH_MAX+4], rep[PATH_MAX+16], res[32];
1458 char rppopt[32], sfile[PATH_MAX], *pfile = NULL;
1459 char pfopts[128];
1460 char vs[32], *vw;
1461 int vn, mult;
1462 FILE *fp;
1463 time_t rfdt, pfdt;
1464 int xres, yres;
1465 double aspect;
1466 int n;
1467 /* get pfilt options */
1468 pfiltopts(pfopts);
1469 /* get resolution, reporting */
1470 switch (vscale(QUALITY)) {
1471 case LOW:
1472 mult = 1;
1473 break;
1474 case MEDIUM:
1475 mult = 2;
1476 break;
1477 case HIGH:
1478 mult = 3;
1479 break;
1480 }
1481 n = sscanf(vval(RESOLUTION), "%d %d %lf", &xres, &yres, &aspect);
1482 if (n == 3)
1483 sprintf(res, "-x %d -y %d -pa %.3f",
1484 mult*xres, mult*yres, aspect);
1485 else if (n) {
1486 aspect = 1.;
1487 if (n == 1) yres = xres;
1488 sprintf(res, "-x %d -y %d", mult*xres, mult*yres);
1489 } else
1490 badvalue(RESOLUTION);
1491 rep[0] = '\0';
1492 if (vdef(REPORT)) {
1493 double minutes;
1494 n = sscanf(vval(REPORT), "%lf %s", &minutes, rawfile);
1495 if (n == 2)
1496 sprintf(rep, " -t %d -e %s", (int)(minutes*60), rawfile);
1497 else if (n == 1)
1498 sprintf(rep, " -t %d", (int)(minutes*60));
1499 else
1500 badvalue(REPORT);
1501 }
1502 /* set up parallel rendering */
1503 sfile[0] = '\0';
1504 if ((nprocs > 1) & !touchonly & !vdef(ZFILE) &&
1505 getview(0, vs) != NULL) {
1506 if (!strcmp(c_rpict, DEF_RPICT_PATH) &&
1507 getview(1, NULL) == NULL) {
1508 sprintf(sfile, "%s_%s_rpsync.txt",
1509 vdef(RAWFILE) ? vval(RAWFILE) : vval(PICTURE),
1510 vs);
1511 strcpy(rppopt, "-PP pfXXXXXX");
1512 } else {
1513 strcpy(rppopt, "-S 1 -PP pfXXXXXX");
1514 }
1515 pfile = rppopt + strlen(rppopt) - 8;
1516 if (mktemp(pfile) == NULL) {
1517 if (do_rpiece) {
1518 fprintf(stderr, "%s: cannot create\n", pfile);
1519 quit(1);
1520 }
1521 pfile = NULL;
1522 }
1523 }
1524 vn = 0; /* do each view */
1525 while ((vw = getview(vn++, vs)) != NULL) {
1526 if (sayview)
1527 myprintview(vw, stdout);
1528 sprintf(picfile, "%s_%s.hdr", vval(PICTURE), vs);
1529 if (vdef(ZFILE))
1530 sprintf(zopt, " -z %s_%s.zbf", vval(ZFILE), vs);
1531 else
1532 zopt[0] = '\0';
1533 /* check date on picture */
1534 pfdt = fdate(picfile);
1535 if (pfdt >= oct1date)
1536 continue;
1537 /* get raw file name */
1538 sprintf(rawfile, "%s_%s.unf",
1539 vdef(RAWFILE) ? vval(RAWFILE) : vval(PICTURE), vs);
1540 rfdt = fdate(rawfile);
1541 if (touchonly) { /* update times only */
1542 if (rfdt) {
1543 if (rfdt < oct1date)
1544 touch(rawfile);
1545 } else if (pfdt && pfdt < oct1date)
1546 touch(picfile);
1547 continue;
1548 }
1549 /* parallel running? */
1550 if (do_rpiece) {
1551 if (rfdt < oct1date || !fdate(sfile)) {
1552 int xdiv = 8+nprocs/3, ydiv = 8+nprocs/3;
1553 if (rfdt >= oct1date) {
1554 fprintf(stderr,
1555 "%s: partial output not created with %s\n", rawfile, c_rpiece);
1556 quit(1);
1557 }
1558 if (rfdt) { /* start fresh */
1559 rmfile(rawfile);
1560 rfdt = 0;
1561 }
1562 if (!silent)
1563 printf("\techo %d %d > %s\n",
1564 xdiv, ydiv, sfile);
1565 if ((fp = fopen(sfile, "w")) == NULL) {
1566 fprintf(stderr, "%s: cannot create\n",
1567 sfile);
1568 quit(1);
1569 }
1570 fprintf(fp, "%d %d\n", xdiv, ydiv);
1571 fclose(fp);
1572 }
1573 } else if (next_process(0)) {
1574 if (pfile != NULL)
1575 sleep(10);
1576 continue;
1577 } else if (!inchild())
1578 pfile = NULL;
1579 /* XXX Remember to call finish_process() */
1580 /* build rpict command */
1581 if (rfdt >= oct1date) { /* already in progress */
1582 if (do_rpiece) {
1583 sprintf(combuf, "%s -R %s %s%s %s %s%s%s -o %s %s",
1584 c_rpiece, sfile, rppopt, rep, vw,
1585 res, opts, po, rawfile, oct1name);
1586 while (next_process(1)) {
1587 sleep(10);
1588 combuf[strlen(c_rpiece)+2] = 'F';
1589 }
1590 } else
1591 sprintf(combuf, "%s%s%s%s%s -ro %s %s", c_rpict,
1592 rep, opts, po, zopt, rawfile, oct1name);
1593 if (runcom(combuf)) /* run rpict/rpiece */
1594 goto rperror;
1595 } else {
1596 if (overture) { /* run overture calculation */
1597 sprintf(combuf,
1598 "%s%s %s%s -x 64 -y 64 -ps 1 %s > %s",
1599 c_rpict, rep, vw, opts,
1600 oct1name, overfile);
1601 if (!do_rpiece || !next_process(0)) {
1602 if (runcom(combuf)) {
1603 fprintf(stderr,
1604 "%s: error in overture for view %s\n",
1605 progname, vs);
1606 quit(1);
1607 }
1608 #ifndef NULL_DEVICE
1609 rmfile(overfile);
1610 #endif
1611 } else if (do_rpiece)
1612 sleep(20);
1613 }
1614 if (do_rpiece) {
1615 sprintf(combuf, "%s -F %s %s%s %s %s%s%s -o %s %s",
1616 c_rpiece, sfile, rppopt, rep, vw,
1617 res, opts, po, rawfile, oct1name);
1618 while (next_process(1))
1619 sleep(10);
1620 } else {
1621 sprintf(combuf, "%s%s %s %s%s%s%s %s > %s",
1622 c_rpict, rep, vw, res, opts, po,
1623 zopt, oct1name, rawfile);
1624 }
1625 if ((pfile != NULL) & !do_rpiece) {
1626 if (!silent)
1627 printf("\t%s\n", combuf);
1628 fflush(stdout);
1629 sprintf(combuf, "%s%s %s %s%s%s %s > %s",
1630 c_rpict, rep, rppopt, res,
1631 opts, po, oct1name, rawfile);
1632 fp = popen(combuf, "w");
1633 if (fp == NULL)
1634 goto rperror;
1635 myprintview(vw, fp);
1636 if (pclose(fp))
1637 goto rperror;
1638 } else if (runcom(combuf))
1639 goto rperror;
1640 }
1641 if (do_rpiece) { /* need to finish raw, first */
1642 finish_process();
1643 wait_process(1);
1644 if (!syncf_done(sfile)) {
1645 fprintf(stderr,
1646 "%s: %s did not complete rendering of view %s\n",
1647 progname, c_rpiece, vs);
1648 quit(1);
1649 }
1650 }
1651 if (!vdef(RAWFILE) || strcmp(vval(RAWFILE),vval(PICTURE))) {
1652 /* build pfilt command */
1653 if (do_rpiece)
1654 sprintf(combuf,
1655 "%s%s -x %d -y %d -p %.3f %s > %s",
1656 c_pfilt, pfopts, xres, yres, aspect,
1657 rawfile, picfile);
1658 else if (mult > 1)
1659 sprintf(combuf, "%s%s -x /%d -y /%d %s > %s",
1660 c_pfilt, pfopts, mult, mult,
1661 rawfile, picfile);
1662 else
1663 sprintf(combuf, "%s%s %s > %s", c_pfilt,
1664 pfopts, rawfile, picfile);
1665 if (runcom(combuf)) { /* run pfilt */
1666 fprintf(stderr,
1667 "%s: error filtering view %s\n\t%s removed\n",
1668 progname, vs, picfile);
1669 unlink(picfile);
1670 quit(1);
1671 }
1672 }
1673 /* remove/rename raw file */
1674 if (vdef(RAWFILE)) {
1675 sprintf(combuf, "%s_%s.hdr", vval(RAWFILE), vs);
1676 mvfile(rawfile, combuf);
1677 } else
1678 rmfile(rawfile);
1679 if (do_rpiece) /* done with sync file */
1680 rmfile(sfile);
1681 else
1682 finish_process(); /* exit if child */
1683 }
1684 wait_process(1); /* wait for children to finish */
1685 if (pfile != NULL) { /* clean up persistent rpict */
1686 RT_PID pid;
1687 fp = fopen(pfile, "r");
1688 if (fp != NULL) {
1689 if (fscanf(fp, "%*s %d", &pid) != 1 ||
1690 kill(pid, 1) < 0)
1691 unlink(pfile);
1692 fclose(fp);
1693 }
1694 }
1695 return;
1696 rperror:
1697 fprintf(stderr, "%s: error rendering view %s\n", progname, vs);
1698 quit(1);
1699 #undef do_rpiece
1700 }
1701
1702
1703 static int
1704 touch( /* update a file */
1705 char *fn
1706 )
1707 {
1708 if (!silent)
1709 printf("\ttouch %s\n", fn);
1710 if (!nprocs)
1711 return(0);
1712 return(setfdate(fn, time((time_t *)NULL)));
1713 }
1714
1715
1716 static int
1717 runcom( /* run command */
1718 char *cs
1719 )
1720 {
1721 if (!silent) /* echo it */
1722 printf("\t%s\n", cs);
1723 if (!nprocs)
1724 return(0);
1725 fflush(NULL); /* flush output and pass to shell */
1726 return(system(cs));
1727 }
1728
1729
1730 static int
1731 rmfile( /* remove a file */
1732 char *fn
1733 )
1734 {
1735 if (!silent)
1736 printf("\t%s %s\n", DELCMD, fn);
1737 if (!nprocs)
1738 return(0);
1739 return(unlink(fn));
1740 }
1741
1742
1743 static int
1744 mvfile( /* move a file */
1745 char *fold,
1746 char *fnew
1747 )
1748 {
1749 if (!silent)
1750 printf("\t%s %s %s\n", RENAMECMD, fold, fnew);
1751 if (!nprocs)
1752 return(0);
1753 return(rename(fold, fnew));
1754 }
1755
1756
1757 #ifdef RHAS_FORK_EXEC
1758 static int
1759 next_process(int reserve) /* fork the next process */
1760 {
1761 RT_PID child_pid;
1762
1763 if (nprocs <= 1)
1764 return(0); /* it's us or no one */
1765 if (inchild()) {
1766 fprintf(stderr, "%s: internal error 1 in next_process()\n",
1767 progname);
1768 quit(1);
1769 }
1770 if (reserve > 0 && children_running >= nprocs-reserve)
1771 return(0); /* caller holding back process(es) */
1772 if (children_running >= nprocs)
1773 wait_process(0); /* wait for someone to finish */
1774 fflush(NULL); /* flush output */
1775 child_pid = fork(); /* split process */
1776 if (child_pid == 0) { /* we're the child */
1777 children_running = -1;
1778 nprocs = 1;
1779 return(0);
1780 }
1781 if (child_pid > 0) { /* we're the parent */
1782 ++children_running;
1783 return(1);
1784 }
1785 fprintf(stderr, "%s: warning -- fork() failed\n", progname);
1786 return(0);
1787 }
1788
1789 static void
1790 wait_process( /* wait for process(es) to finish */
1791 int all
1792 )
1793 {
1794 int ourstatus = 0, status;
1795 RT_PID pid;
1796
1797 if (all)
1798 all = children_running;
1799 else if (children_running > 0)
1800 all = 1;
1801 while (all-- > 0) {
1802 pid = wait(&status);
1803 if (pid < 0)
1804 syserr(progname);
1805 status = status>>8 & 0xff;
1806 --children_running;
1807 if (status != 0) { /* child's problem is our problem */
1808 if ((ourstatus == 0) & (children_running > 0))
1809 fprintf(stderr, "%s: waiting for remaining processes\n",
1810 progname);
1811 ourstatus = status;
1812 all = children_running;
1813 }
1814 }
1815 if (ourstatus != 0)
1816 quit(ourstatus); /* bad status from child */
1817 }
1818 #else /* ! RHAS_FORK_EXEC */
1819 static int
1820 next_process(int reserve)
1821 {
1822 return(0); /* cannot start new process */
1823 }
1824 static void
1825 wait_process(all)
1826 int all;
1827 {
1828 (void)all; /* no one to wait for */
1829 }
1830 int
1831 kill(pid, sig) /* win|unix_process.c should also wait and kill */
1832 RT_PID pid;
1833 int sig;
1834 {
1835 return 0;
1836 }
1837 #endif /* ! RHAS_FORK_EXEC */
1838
1839 static void
1840 finish_process(void) /* exit a child process */
1841 {
1842 if (!inchild())
1843 return; /* in parent -- noop */
1844 exit(0);
1845 }
1846
1847
1848 static void
1849 badvalue( /* report bad variable value and exit */
1850 int vc
1851 )
1852 {
1853 fprintf(stderr, "%s: bad value for variable '%s'\n",
1854 progname, vnam(vc));
1855 quit(1);
1856 }
1857
1858
1859 static void
1860 syserr( /* report a system error and exit */
1861 char *s
1862 )
1863 {
1864 perror(s);
1865 quit(1);
1866 }
1867
1868
1869 void
1870 quit(ec) /* exit program */
1871 int ec;
1872 {
1873 exit(ec);
1874 }
