--- ray/src/util/rad.c 2003/07/03 22:41:45 2.68 +++ ray/src/util/rad.c 2008/04/21 07:31:30 2.85 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rad.c,v 2.68 2003/07/03 22:41:45 schorsch Exp $"; +static const char RCSid[] = "$Id: rad.c,v 2.85 2008/04/21 07:31:30 schorsch Exp $"; #endif /* * Executive program for oconv, rpict and pfilt @@ -8,12 +8,24 @@ static const char RCSid[] = "$Id: rad.c,v 2.68 2003/07 #include "standard.h" #include +#include #include "platform.h" +#include "rtprocess.h" #include "view.h" #include "paths.h" #include "vars.h" +#ifdef _WIN32 + #define DELCMD "del" + #define RENAMECMD "rename" +#else + #define DELCMD "rm -f" + #define RENAMECMD "mv" + #include + #include +#endif + /* variables (alphabetical by name) */ #define AMBFILE 0 /* ambient file name */ #define DETAIL 1 /* level of scene detail */ @@ -80,7 +92,6 @@ char overfile[] = NULL_DEVICE; char overfile[] = "overture.unf"; #endif -extern time_t time(); time_t scenedate; /* date of latest scene or object file */ time_t octreedate; /* date of octree */ @@ -98,7 +109,7 @@ int silent = 0; /* do work silently */ int touchonly = 0; /* touch files only */ int nprocs = 1; /* maximum executing processes */ int sayview = 0; /* print view out */ -char *rvdevice = NULL; /* rview output device */ +char *rvdevice = NULL; /* rvu output device */ char *viewselect = NULL; /* specific view only */ int overture = 0; /* overture calculation needed */ @@ -112,10 +123,46 @@ char radname[PATH_MAX]; /* root Radiance file name */ #define inchild() (children_running < 0) +static void rootname(char *rn, char *fn); +static time_t checklast(char *fnames); +static char * newfname(char *orig, int pred); +static void checkfiles(void); +static void getoctcube(double org[3], double *sizp); +static void setdefaults(void); +static void oconv(void); +static char * addarg(char *op, char *arg); +static void oconvopts(char *oo); +static void mkillumopts(char *mo); +static void checkambfile(void); +static double ambval(void); +static void renderopts(char *op, char *po); +static void lowqopts(char *op, char *po); +static void medqopts(char *op, char *po); +static void hiqopts(char *op, char *po); +static void xferopts(char *ro); +static void pfiltopts(char *po); +static int matchword(char *s1, char *s2); +static char * specview(char *vs); +static char * getview(int n, char *vn); +static int myprintview(char *vopts, FILE *fp); +static void rvu(char *opts, char *po); +static void rpict(char *opts, char *po); +static int touch(char *fn); +static int runcom(char *cs); +static int rmfile(char *fn); +static int mvfile(char *fold, char *fnew); +static int next_process(void); +static void wait_process(int all); +static void finish_process(void); +static void badvalue(int vc); +static void syserr(char *s); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { char ropts[512]; char popts[64]; @@ -161,7 +208,7 @@ char *argv[]; goto userr; rifname = argv[i]; /* check command-line options */ - if (nprocs > 1 & viewselect != NULL) + if ((nprocs > 1) & (viewselect != NULL)) nprocs = 1; /* assign Radiance root file name */ rootname(radname, rifname); @@ -191,7 +238,7 @@ char *argv[]; renderopts(ropts, popts); xferopts(ropts); if (rvdevice != NULL) - rview(ropts, popts); + rvu(ropts, popts); else rpict(ropts, popts); quit(0); @@ -200,15 +247,19 @@ userr: "Usage: %s [-w][-s][-n|-N npr][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", progname); quit(1); + return 1; /* pro forma return */ } -rootname(rn, fn) /* remove tail from end of fn */ -register char *rn, *fn; +static void +rootname( /* remove tail from end of fn */ + register char *rn, + register char *fn +) { char *tp, *dp; - for (tp = NULL, dp = rn; *rn = *fn++; rn++) + for (tp = NULL, dp = rn; (*rn = *fn++); rn++) if (ISDIRSEP(*rn)) dp = rn; else if (*rn == '.') @@ -218,9 +269,10 @@ register char *rn, *fn; } -time_t -checklast(fnames) /* check files and find most recent */ -register char *fnames; +static time_t +checklast( /* check files and find most recent */ + register char *fnames +) { char thisfile[PATH_MAX]; time_t thisdate, lastdate = 0; @@ -229,8 +281,11 @@ register char *fnames; return(0); while ((fnames = nextword(thisfile, PATH_MAX, fnames)) != NULL) { if (thisfile[0] == '!' || - (thisfile[0] == '\\' && thisfile[1] == '!')) + (thisfile[0] == '\\' && thisfile[1] == '!')) { + if (!lastdate) + lastdate = 1; continue; + } if (!(thisdate = fdate(thisfile))) syserr(thisfile); if (thisdate > lastdate) @@ -240,10 +295,11 @@ register char *fnames; } -char * -newfname(orig, pred) /* create modified file name */ -char *orig; -int pred; +static char * +newfname( /* create modified file name */ + char *orig, + int pred +) { register char *cp; register int n; @@ -265,7 +321,8 @@ int pred; } -checkfiles() /* check for existence and modified times */ +static void +checkfiles(void) /* check for existence and modified times */ { time_t objdate; @@ -300,17 +357,19 @@ checkfiles() /* check for existence and modified tim } -getoctcube(org, sizp) /* get octree bounding cube */ -double org[3], *sizp; +static void +getoctcube( /* get octree bounding cube */ + double org[3], + double *sizp +) { - extern FILE *popen(); static double oorg[3], osiz = 0.; double min[3], max[3]; char buf[1024]; FILE *fp; register int i; - if (osiz <= FTINY) + if (osiz <= FTINY) { if (!nprocs && fdate(oct1name) < (scenedate>illumdate?scenedate:illumdate)) { /* run getbbox */ @@ -346,11 +405,13 @@ double org[3], *sizp; } pclose(fp); } + } org[0] = oorg[0]; org[1] = oorg[1]; org[2] = oorg[2]; *sizp = osiz; } -setdefaults() /* set default values for unassigned var's */ +static void +setdefaults(void) /* set default values for unassigned var's */ { double org[3], lim[3], size; char buf[128]; @@ -407,10 +468,11 @@ setdefaults() /* set default values for unassigned v } -oconv() /* run oconv and mkillum if necessary */ +static void +oconv(void) /* run oconv and mkillum if necessary */ { static char illumtmp[] = "ilXXXXXX"; - char combuf[PATH_MAX], ocopts[64], mkopts[64]; + char combuf[PATH_MAX], ocopts[64], mkopts[1024]; oconvopts(ocopts); /* get options */ if (octreedate < scenedate) { /* check date on original octree */ @@ -439,11 +501,11 @@ oconv() /* run oconv and mkillum if necessary */ } if (oct1name == vval(OCTREE)) /* no mkillum? */ oct1date = octreedate > matdate ? octreedate : matdate; - if (oct1date >= octreedate & oct1date >= matdate - & oct1date >= illumdate) /* all done */ + if ((oct1date >= octreedate) & (oct1date >= matdate) + & (oct1date >= illumdate)) /* all done */ return; /* make octree0 */ - if (oct0date < scenedate | oct0date < illumdate) { + if ((oct0date < scenedate) | (oct0date < illumdate)) { if (touchonly && oct0date) touch(oct0name); else { /* build command */ @@ -509,19 +571,23 @@ oconv() /* run oconv and mkillum if necessary */ } -char * -addarg(op, arg) /* add argument and advance pointer */ -register char *op, *arg; +static char * +addarg( /* add argument and advance pointer */ +register char *op, +register char *arg +) { *op = ' '; - while (*++op = *arg++) + while ( (*++op = *arg++) ) ; return(op); } -oconvopts(oo) /* get oconv options */ -register char *oo; +static void +oconvopts( /* get oconv options */ + register char *oo +) { /* BEWARE: This may be called via setdefaults(), so no assumptions */ @@ -531,18 +597,26 @@ register char *oo; } -mkillumopts(mo) /* get mkillum options */ -register char *mo; +static void +mkillumopts( /* get mkillum options */ + char *mo +) { /* BEWARE: This may be called via setdefaults(), so no assumptions */ - *mo = '\0'; + if (nprocs > 1) { + sprintf(mo, " -n %d", nprocs); + while (*mo) + mo++; + } else + *mo = '\0'; if (vdef(MKILLUM)) addarg(mo, vval(MKILLUM)); } -checkambfile() /* check date on ambient file */ +static void +checkambfile(void) /* check date on ambient file */ { time_t afdate; @@ -550,16 +624,17 @@ checkambfile() /* check date on ambient file */ return; if (!(afdate = fdate(vval(AMBFILE)))) return; - if (oct1date > afdate) + if (oct1date > afdate) { if (touchonly) touch(vval(AMBFILE)); else rmfile(vval(AMBFILE)); + } } -double -ambval() /* compute ambient value */ +static double +ambval(void) /* compute ambient value */ { if (vdef(EXPOSURE)) { if (vval(EXPOSURE)[0] == '+' || vval(EXPOSURE)[0] == '-') @@ -571,11 +646,15 @@ ambval() /* compute ambient value */ if (vlet(ZONE) == 'I') return(.01); badvalue(ZONE); + return 0; /* pro forma return */ } -renderopts(op, po) /* set rendering options */ -char *op, *po; +static void +renderopts( /* set rendering options */ + char *op, + char *po +) { switch(vscale(QUALITY)) { case LOW: @@ -591,9 +670,11 @@ char *op, *po; } -lowqopts(op, po) /* low quality rendering options */ -register char *op; -char *po; +static void +lowqopts( /* low quality rendering options */ + register char *op, + char *po +) { double d, org[3], siz[3]; @@ -603,7 +684,7 @@ char *po; &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) badvalue(ZONE); siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; - if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY) + if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY)) badvalue(ZONE); getoctcube(org, &d); d *= 3./(siz[0]+siz[1]+siz[2]); @@ -611,19 +692,19 @@ char *po; case LOW: po = addarg(po, "-ps 16"); op = addarg(op, "-dp 64"); - sprintf(op, " -ar %d", (int)(4*d)); + sprintf(op, " -ar %d", (int)(8*d)); op += strlen(op); break; case MEDIUM: po = addarg(po, "-ps 8"); op = addarg(op, "-dp 128"); - sprintf(op, " -ar %d", (int)(8*d)); + sprintf(op, " -ar %d", (int)(16*d)); op += strlen(op); break; case HIGH: po = addarg(po, "-ps 4"); op = addarg(op, "-dp 256"); - sprintf(op, " -ar %d", (int)(16*d)); + sprintf(op, " -ar %d", (int)(32*d)); op += strlen(op); break; } @@ -640,28 +721,30 @@ char *po; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .4 -ad 64"); + op = addarg(op, "-aa .3 -ad 256"); break; case MEDIUM: - op = addarg(op, "-aa .3 -ad 128"); + op = addarg(op, "-aa .25 -ad 512"); break; case HIGH: - op = addarg(op, "-aa .25 -ad 256"); + op = addarg(op, "-aa .2 -ad 1024"); break; } op = addarg(op, "-as 0"); d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 3 -lw .02"); + op = addarg(op, "-lr 6 -lw .01"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } -medqopts(op, po) /* medium quality rendering options */ -register char *op; -char *po; +static void +medqopts( /* medium quality rendering options */ + register char *op, + char *po +) { double d, org[3], siz[3], asz; @@ -671,7 +754,7 @@ char *po; &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) badvalue(ZONE); siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; - if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY) + if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY)) badvalue(ZONE); getoctcube(org, &d); asz = (siz[0]+siz[1]+siz[2])/3.; @@ -680,7 +763,7 @@ char *po; case LOW: po = addarg(po, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8"); op = addarg(op, "-dp 256"); - sprintf(op, " -ar %d", (int)(8*d)); + sprintf(op, " -ar %d", (int)(16*d)); op += strlen(op); sprintf(op, " -ms %.2g", asz/20.); op += strlen(op); @@ -688,7 +771,7 @@ char *po; case MEDIUM: po = addarg(po, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6"); op = addarg(op, "-dp 512"); - sprintf(op, " -ar %d", (int)(16*d)); + sprintf(op, " -ar %d", (int)(32*d)); op += strlen(op); sprintf(op, " -ms %.2g", asz/40.); op += strlen(op); @@ -696,7 +779,7 @@ char *po; case HIGH: po = addarg(po, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4"); op = addarg(op, "-dp 1024"); - sprintf(op, " -ar %d", (int)(32*d)); + sprintf(op, " -ar %d", (int)(64*d)); op += strlen(op); sprintf(op, " -ms %.2g", asz/80.); op += strlen(op); @@ -708,7 +791,7 @@ char *po; else op = addarg(op, "-ds .3"); op = addarg(op, "-dt .1 -dc .5 -dr 1 -sj .7 -st .1"); - if (overture = vint(INDIRECT)) { + if ( (overture = vint(INDIRECT)) ) { sprintf(op, " -ab %d", overture); op += strlen(op); } @@ -719,27 +802,29 @@ char *po; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .25 -ad 196 -as 0"); + op = addarg(op, "-aa .2 -ad 329 -as 42"); break; case MEDIUM: - op = addarg(op, "-aa .2 -ad 400 -as 64"); + op = addarg(op, "-aa .15 -ad 800 -as 128"); break; case HIGH: - op = addarg(op, "-aa .15 -ad 768 -as 196"); + op = addarg(op, "-aa .1 -ad 1536 -as 392"); break; } d = ambval(); sprintf(op, " -av %.2g %.2g %.2g", d, d, d); op += strlen(op); - op = addarg(op, "-lr 6 -lw .002"); + op = addarg(op, "-lr 8 -lw .002"); if (vdef(RENDER)) op = addarg(op, vval(RENDER)); } -hiqopts(op, po) /* high quality rendering options */ -register char *op; -char *po; +static void +hiqopts( /* high quality rendering options */ + register char *op, + char *po +) { double d, org[3], siz[3], asz; @@ -749,7 +834,7 @@ char *po; &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) badvalue(ZONE); siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; - if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY) + if ((siz[0] <= FTINY) | (siz[1] <= FTINY) | (siz[2] <= FTINY)) badvalue(ZONE); getoctcube(org, &d); asz = (siz[0]+siz[1]+siz[2])/3.; @@ -758,7 +843,7 @@ char *po; case LOW: po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8"); op = addarg(op, "-dp 1024"); - sprintf(op, " -ar %d", (int)(16*d)); + sprintf(op, " -ar %d", (int)(32*d)); op += strlen(op); sprintf(op, " -ms %.2g", asz/40.); op += strlen(op); @@ -766,7 +851,7 @@ char *po; case MEDIUM: po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5"); op = addarg(op, "-dp 2048"); - sprintf(op, " -ar %d", (int)(32*d)); + sprintf(op, " -ar %d", (int)(64*d)); op += strlen(op); sprintf(op, " -ms %.2g", asz/80.); op += strlen(op); @@ -774,7 +859,7 @@ char *po; case HIGH: po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3"); op = addarg(op, "-dp 4096"); - sprintf(op, " -ar %d", (int)(64*d)); + sprintf(op, " -ar %d", (int)(128*d)); op += strlen(op); sprintf(op, " -ms %.2g", asz/160.); op += strlen(op); @@ -795,13 +880,13 @@ char *po; overture = 0; switch (vscale(VARIABILITY)) { case LOW: - op = addarg(op, "-aa .15 -ad 256 -as 0"); + op = addarg(op, "-aa .125 -ad 512 -as 64"); break; case MEDIUM: - op = addarg(op, "-aa .125 -ad 512 -as 256"); + op = addarg(op, "-aa .1 -ad 1536 -as 768"); break; case HIGH: - op = addarg(op, "-aa .08 -ad 1024 -as 512"); + op = addarg(op, "-aa .075 -ad 4096 -as 2048"); break; } d = ambval(); @@ -813,8 +898,10 @@ char *po; } -xferopts(ro) /* transfer options if indicated */ -char *ro; +static void +xferopts( /* transfer options if indicated */ + char *ro +) { int fd, n; register char *cp; @@ -844,8 +931,10 @@ char *ro; } -pfiltopts(po) /* get pfilt options */ -register char *po; +static void +pfiltopts( /* get pfilt options */ + register char *po +) { *po = '\0'; if (vdef(EXPOSURE)) { @@ -865,8 +954,11 @@ register char *po; } -matchword(s1, s2) /* match white-delimited words */ -register char *s1, *s2; +static int +matchword( /* match white-delimited words */ + register char *s1, + register char *s2 +) { while (isspace(*s1)) s1++; while (isspace(*s2)) s2++; @@ -877,9 +969,10 @@ register char *s1, *s2; } -char * -specview(vs) /* get proper view spec from vs */ -register char *vs; +static char * +specview( /* get proper view spec from vs */ + register char *vs +) { static char vup[7][12] = {"-vu 0 0 -1","-vu 0 -1 0","-vu -1 0 0", "-vu 0 0 1", "-vu 1 0 0","-vu 0 1 0","-vu 0 0 1"}; @@ -897,7 +990,7 @@ register char *vs; upax = 1-'X'+UPPER(vval(UP)[1]); else upax = 1-'X'+vlet(UP); - if (upax < 1 | upax > 3) + if ((upax < 1) | (upax > 3)) badvalue(UP); if (vval(UP)[0] == '-') upax = -upax; @@ -919,9 +1012,19 @@ register char *vs; } else if (*vs == 'z') { zpos = -1; vs++; } - viewtype = 'v'; - if (*vs == 'v' | *vs == 'l' | *vs == 'a' | *vs == 'h' | *vs == 'c') + switch (*vs) { + case VT_PER: + case VT_PAR: + case VT_ANG: + case VT_HEM: + case VT_PLS: + case VT_CYL: viewtype = *vs++; + break; + default: + viewtype = VT_PER; + break; + } cp = viewopts; if ((!*vs || isspace(*vs)) && (xpos|ypos|zpos)) { /* got one! */ *cp++ = '-'; *cp++ = 'v'; *cp++ = 't'; *cp++ = viewtype; @@ -963,19 +1066,20 @@ register char *vs; } cp = addarg(cp, vup[upax+3]); switch (viewtype) { - case 'v': + case VT_PER: cp = addarg(cp, "-vh 45 -vv 45"); break; - case 'l': + case VT_PAR: d = sqrt(dim[0]*dim[0]+dim[1]*dim[1]+dim[2]*dim[2]); sprintf(cp, " -vh %.2g -vv %.2g", d, d); cp += strlen(cp); break; - case 'a': - case 'h': + case VT_ANG: + case VT_HEM: + case VT_PLS: cp = addarg(cp, "-vh 180 -vv 180"); break; - case 'c': + case VT_CYL: cp = addarg(cp, "-vh 180 -vv 90"); break; } @@ -1001,10 +1105,11 @@ register char *vs; } -char * -getview(n, vn) /* get view n, or NULL if none */ -int n; -char *vn; /* returned view name */ +static char * +getview( /* get view n, or NULL if none */ + int n, + char *vn /* returned view name */ +) { register char *mv; @@ -1031,7 +1136,7 @@ char *vn; /* returned view name */ return(specview(viewselect)); /* standard view? */ } mv = nvalue(VIEWS, n); /* use view n */ - if (vn != NULL & mv != NULL) { + if ((vn != NULL) & (mv != NULL)) { register char *mv2 = mv; if (*mv2 != '-') while (*mv2 && !isspace(*mv2)) @@ -1042,15 +1147,20 @@ char *vn; /* returned view name */ } -int -myprintview(vopts, fp) /* print out selected view */ -register char *vopts; -FILE *fp; +static int +myprintview( /* print out selected view */ + register char *vopts, + FILE *fp +) { VIEW vwr; char buf[128]; register char *cp; +#ifdef _WIN32 +/* XXX Should we allow something like this for all platforms? */ +/* XXX Or is it still required at all? */ again: +#endif if (vopts == NULL) return(-1); #ifdef _WIN32 @@ -1059,7 +1169,7 @@ again: goto again; } #endif - copystruct(&vwr, &stdview); + vwr = stdview; sscanview(&vwr, cp=vopts); /* set initial options */ while ((cp = strstr(cp, "-vf ")) != NULL && *atos(buf, sizeof(buf), cp += 4)) { @@ -1073,8 +1183,11 @@ again: } -rview(opts, po) /* run rview with first view */ -char *opts, *po; +static void +rvu( /* run rvu with first view */ + char *opts, + char *po +) { char *vw; char combuf[PATH_MAX]; @@ -1083,21 +1196,24 @@ char *opts, *po; return; if (sayview) myprintview(vw, stdout); - sprintf(combuf, "rview %s%s%s -R %s ", vw, po, opts, rifname); + sprintf(combuf, "rvu %s%s%s -R %s ", vw, po, opts, rifname); if (rvdevice != NULL) sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); if (vdef(EXPOSURE)) sprintf(combuf+strlen(combuf), "-pe %s ", vval(EXPOSURE)); strcat(combuf, oct1name); if (runcom(combuf)) { /* run it */ - fprintf(stderr, "%s: error running rview\n", progname); + fprintf(stderr, "%s: error running rvu\n", progname); quit(1); } } -rpict(opts, po) /* run rpict and pfilt for each view */ -char *opts, *po; +static void +rpict( /* run rpict and pfilt for each view */ + char *opts, + char *po +) { char combuf[PATH_MAX]; char rawfile[PATH_MAX], picfile[PATH_MAX]; @@ -1149,7 +1265,7 @@ char *opts, *po; badvalue(REPORT); } /* set up parallel rendering */ - if (nprocs > 1 & !vdef(ZFILE)) { + if ((nprocs > 1) & (!vdef(ZFILE))) { strcpy(rppopt, "-S 1 -PP pfXXXXXX"); pfile = rppopt+9; if (mktemp(pfile) == NULL) @@ -1217,10 +1333,10 @@ char *opts, *po; /* rpict persistent mode */ if (!silent) printf("\t%s\n", combuf); + fflush(stdout); sprintf(combuf, "rpict%s %s %s%s%s %s > %s", rep, rppopt, res, po, opts, oct1name, rawfile); - fflush(stdout); fp = popen(combuf, "w"); if (fp == NULL) goto rperror; @@ -1254,15 +1370,15 @@ char *opts, *po; mvfile(rawfile, combuf); } else rmfile(rawfile); - finish_process(); /* leave if child */ + finish_process(); /* exit if child */ } wait_process(1); /* wait for children to finish */ if (pfile != NULL) { /* clean up rpict persistent mode */ - int pid; + RT_PID pid; fp = fopen(pfile, "r"); if (fp != NULL) { if (fscanf(fp, "%*s %d", &pid) != 1 || - kill(pid, 1) == -1) + kill(pid, 1) < 0) unlink(pfile); fclose(fp); } @@ -1274,8 +1390,10 @@ rperror: } -touch(fn) /* update a file */ -char *fn; +static int +touch( /* update a file */ + char *fn +) { if (!silent) printf("\ttouch %s\n", fn); @@ -1290,42 +1408,41 @@ char *fn; } -runcom(cs) /* run command */ -char *cs; +static int +runcom( /* run command */ + char *cs +) { if (!silent) /* echo it */ printf("\t%s\n", cs); if (!nprocs) return(0); - fflush(stdout); /* flush output and pass to shell */ + fflush(NULL); /* flush output and pass to shell */ return(system(cs)); } -rmfile(fn) /* remove a file */ -char *fn; +static int +rmfile( /* remove a file */ + char *fn +) { if (!silent) -#ifdef _WIN32 - printf("\tdel %s\n", fn); -#else - printf("\trm -f %s\n", fn); -#endif + printf("\t%s %s\n", DELCMD, fn); if (!nprocs) return(0); return(unlink(fn)); } -mvfile(fold, fnew) /* move a file */ -char *fold, *fnew; +static int +mvfile( /* move a file */ + char *fold, + char *fnew +) { if (!silent) -#ifdef _WIN32 - printf("\trename %s %s\n", fold, fnew); -#else - printf("\tmv %s %s\n", fold, fnew); -#endif + printf("\t%s %s %s\n", RENAMECMD, fold, fnew); if (!nprocs) return(0); return(rename(fold, fnew)); @@ -1333,21 +1450,21 @@ char *fold, *fnew; #ifdef RHAS_FORK_EXEC -int -next_process() /* fork the next process (max. nprocs) */ +static int +next_process(void) /* fork the next process (max. nprocs) */ { - int child_pid; + RT_PID child_pid; if (nprocs <= 1) return(0); /* it's us or no one */ if (inchild()) { - fprintf(stderr, "%s: internal error 1 in spawn_process()\n", + fprintf(stderr, "%s: internal error 1 in next_process()\n", progname); quit(1); } if (children_running >= nprocs) wait_process(0); /* wait for someone to finish */ - fflush(stdout); + fflush(NULL); /* flush output */ child_pid = fork(); /* split process */ if (child_pid == 0) { /* we're the child */ children_running = -1; @@ -1361,11 +1478,13 @@ next_process() /* fork the next process (max. nprocs return(0); } -wait_process(all) /* wait for process(es) to finish */ -int all; +static void +wait_process( /* wait for process(es) to finish */ + int all +) { - int ourstatus = 0; - int pid, status; + int ourstatus = 0, status; + RT_PID pid; if (all) all = children_running; @@ -1378,7 +1497,7 @@ int all; status = status>>8 & 0xff; --children_running; if (status != 0) { /* child's problem is our problem */ - if (ourstatus == 0 & children_running > 0) + if ((ourstatus == 0) & (children_running > 0)) fprintf(stderr, "%s: waiting for remaining processes\n", progname); ourstatus = status; @@ -1389,11 +1508,12 @@ int all; quit(ourstatus); /* bad status from child */ } #else /* ! RHAS_FORK_EXEC */ -int -next_process() +static int +next_process(void) { return(0); /* cannot start new process */ } +static void wait_process(all) int all; { @@ -1401,13 +1521,15 @@ int all; } int kill(pid, sig) /* win|unix_process.c should also wait and kill */ -int pid, sig; +RT_PID pid; +int sig; { return 0; } #endif /* ! RHAS_FORK_EXEC */ -finish_process() /* exit a child process */ +static void +finish_process(void) /* exit a child process */ { if (!inchild()) return; /* in parent -- noop */ @@ -1434,8 +1556,10 @@ char *vname, *value; #endif -badvalue(vc) /* report bad variable value and exit */ -int vc; +static void +badvalue( /* report bad variable value and exit */ + int vc +) { fprintf(stderr, "%s: bad value for variable '%s'\n", progname, vnam(vc)); @@ -1443,8 +1567,10 @@ int vc; } -syserr(s) /* report a system error and exit */ -char *s; +static void +syserr( /* report a system error and exit */ + char *s +) { perror(s); quit(1);
