--- ray/src/util/rad.c 1996/01/05 14:43:03 2.50 +++ ray/src/util/rad.c 1998/01/23 15:15:59 2.54 @@ -155,7 +155,11 @@ char *argv[]; loadvars(rifname); /* get any additional assignments */ for (i++; i < argc; i++) - setvariable(argv[i]); + if (setvariable(argv[i], matchvar) < 0) { + fprintf(stderr, "%s: unknown variable: %s\n", + progname, argv[i]); + quit(1); + } /* check assignments */ checkvalues(); /* check files and dates */ @@ -176,12 +180,12 @@ char *argv[]; rview(ropts, popts); else rpict(ropts, popts); - exit(0); + quit(0); userr: fprintf(stderr, "Usage: %s [-s][-n][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", progname); - exit(1); + quit(1); } @@ -276,7 +280,7 @@ checkfiles() /* check for existence and modified tim if (!octreedate & !scenedate & !illumdate) { fprintf(stderr, "%s: need '%s' or '%s' or '%s'\n", progname, vnam(OCTREE), vnam(SCENE), vnam(ILLUM)); - exit(1); + quit(1); } matdate = checklast(vval(MATERIAL)); } @@ -306,7 +310,7 @@ double org[3], *sizp; fprintf(stderr, "%s: error reading bounding box from getbbox\n", progname); - exit(1); + quit(1); } for (i = 0; i < 3; i++) if (max[i] - min[i] > osiz) @@ -324,7 +328,7 @@ double org[3], *sizp; fprintf(stderr, "%s: error reading bounding cube from getinfo\n", progname); - exit(1); + quit(1); } pclose(fp); } @@ -402,7 +406,7 @@ oconv() /* run oconv and mkillum if necessary */ "%s: error generating octree\n\t%s removed\n", progname, vval(OCTREE)); unlink(vval(OCTREE)); - exit(1); + quit(1); } } octreedate = time((time_t *)NULL); @@ -433,7 +437,7 @@ oconv() /* run oconv and mkillum if necessary */ "%s: error generating octree\n\t%s removed\n", progname, oct0name); unlink(oct0name); - exit(1); + quit(1); } } oct0date = time((time_t *)NULL); @@ -453,7 +457,7 @@ oconv() /* run oconv and mkillum if necessary */ fprintf(stderr, "%s: error running mkillum\n", progname); unlink(illumtmp); - exit(1); + quit(1); } /* make octree1 (frozen) */ if (octreedate) @@ -471,7 +475,7 @@ oconv() /* run oconv and mkillum if necessary */ progname, oct1name); unlink(oct1name); unlink(illumtmp); - exit(1); + quit(1); } rmfile(illumtmp); } @@ -995,14 +999,14 @@ char *vn; /* returned view name */ } /* view number? */ if (isint(viewselect)) - return(specview(nvalue(vv+VIEW, atoi(viewselect)-1))); + return(specview(nvalue(VIEW, atoi(viewselect)-1))); /* check list */ - while ((mv = nvalue(vv+VIEW, n++)) != NULL) + while ((mv = nvalue(VIEW, n++)) != NULL) if (matchword(viewselect, mv)) return(specview(mv)); return(specview(viewselect)); /* standard view? */ } - mv = nvalue(vv+VIEW, n); /* use view n */ + mv = nvalue(VIEW, n); /* use view n */ if (vn != NULL & mv != NULL) { register char *mv2 = mv; if (*mv2 != '-') @@ -1089,7 +1093,7 @@ char *opts, *po; strcat(combuf, oct1name); if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error running rview\n", progname); - exit(1); + quit(1); } } @@ -1186,7 +1190,7 @@ char *opts, *po; fprintf(stderr, "%s: error in overture for view %s\n", progname, vs); - exit(1); + quit(1); } #ifdef NIX rmfile(overfile); @@ -1199,7 +1203,7 @@ char *opts, *po; if (runcom(combuf)) { /* run rpict */ fprintf(stderr, "%s: error rendering view %s\n", progname, vs); - exit(1); + quit(1); } if (!vdef(RAWFILE) || strcmp(vval(RAWFILE),vval(PICTURE))) { /* build pfilt command */ @@ -1214,7 +1218,7 @@ char *opts, *po; "%s: error filtering view %s\n\t%s removed\n", progname, vs, picfile); unlink(picfile); - exit(1); + quit(1); } } /* remove/rename raw file */ @@ -1297,7 +1301,7 @@ char *vname, *value; sprintf(evp, "%s=%s", vname, value); if (putenv(evp) != 0) { fprintf(stderr, "%s: out of environment space\n", progname); - exit(1); + quit(1); } if (!silent) printf("set %s\n", evp); @@ -1310,7 +1314,7 @@ int vc; { fprintf(stderr, "%s: bad value for variable '%s'\n", progname, vnam(vc)); - exit(1); + quit(1); } @@ -1318,5 +1322,12 @@ syserr(s) /* report a system error and exit */ char *s; { perror(s); - exit(1); + quit(1); +} + + +quit(ec) /* exit program */ +int ec; +{ + exit(ec); }
