--- ray/src/util/rad.c 1993/11/11 10:20:06 2.30 +++ ray/src/util/rad.c 1995/07/06 12:15:40 2.43 @@ -1,4 +1,4 @@ -/* Copyright (c) 1993 Regents of the University of California */ +/* Copyright (c) 1994 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -11,6 +11,7 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" #include "paths.h" #include +#include typedef struct { @@ -48,8 +49,9 @@ int onevalue(), catvalues(), boolvalue(), #define PENUMBRAS 20 /* shadow penumbras are desired */ #define VARIABILITY 21 /* level of light variability */ #define REPORT 22 /* report frequency and errfile */ +#define RAWSAVE 23 /* save raw picture file */ /* total number of variables */ -#define NVARS 23 +#define NVARS 24 VARIABLE vv[NVARS] = { /* variable-value pairs */ {"objects", 3, 0, NULL, catvalues}, @@ -75,6 +77,7 @@ VARIABLE vv[NVARS] = { /* variable-value pairs */ {"PENUMBRAS", 3, 0, NULL, boolvalue}, {"VARIABILITY", 3, 0, NULL, qualvalue}, {"REPORT", 3, 0, NULL, onevalue}, + {"RAWSAVE", 3, 0, NULL, boolvalue}, }; VARIABLE *matchvar(); @@ -101,20 +104,22 @@ char overfile[] = "overture.raw"; char overfile[] = "/dev/null"; #endif -extern unsigned long fdate(), time(); +extern time_t fdate(), time(); -unsigned long scenedate; /* date of latest scene or object file */ -unsigned long octreedate; /* date of octree */ -unsigned long matdate; /* date of latest material file */ -unsigned long illumdate; /* date of last illum file */ +time_t scenedate; /* date of latest scene or object file */ +time_t octreedate; /* date of octree */ +time_t matdate; /* date of latest material file */ +time_t illumdate; /* date of last illum file */ char *oct0name; /* name of pre-mkillum octree */ -unsigned long oct0date; /* date of pre-mkillum octree */ +time_t oct0date; /* date of pre-mkillum octree */ char *oct1name; /* name of post-mkillum octree */ -unsigned long oct1date; /* date of post-mkillum octree (>= matdate) */ +time_t oct1date; /* date of post-mkillum octree (>= matdate) */ +int nowarn = 0; /* no warnings */ int explicate = 0; /* explicate variables */ int silent = 0; /* do work silently */ +int touchonly = 0; /* touch files only */ int noaction = 0; /* don't do anything */ int sayview = 0; /* print view out */ char *rvdevice = NULL; /* rview output device */ @@ -133,6 +138,7 @@ int argc; char *argv[]; { char ropts[512]; + char popts[64]; int i; progname = argv[0]; @@ -145,6 +151,9 @@ char *argv[]; case 'n': noaction++; break; + case 't': + touchonly++; + break; case 'e': explicate++; break; @@ -157,6 +166,9 @@ char *argv[]; case 'v': viewselect = argv[++i]; break; + case 'w': + nowarn++; + break; default: goto userr; } @@ -184,16 +196,16 @@ char *argv[]; /* check date on ambient file */ checkambfile(); /* run simulation */ - renderopts(ropts); + renderopts(ropts, popts); xferopts(ropts); if (rvdevice != NULL) - rview(ropts); + rview(ropts, popts); else - rpict(ropts); + rpict(ropts, popts); exit(0); userr: fprintf(stderr, - "Usage: %s [-s][-n][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", +"Usage: %s [-s][-n][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", progname); exit(1); } @@ -252,7 +264,6 @@ setvariable(ass) /* assign variable according to stri register char *ass; { char varname[32]; - char varval[512]; int n; register char *cp; register VARIABLE *vp; @@ -273,7 +284,7 @@ register char *ass; for (n = strlen(ass); n > 0; n--) if (!isspace(ass[n-1])) break; - if (!n) { + if (!n && !nowarn) { fprintf(stderr, "%s: warning - missing value for variable '%s'\n", progname, varname); return; @@ -359,7 +370,9 @@ register VARIABLE *vp; { if (vp->nass < 2) return; - fprintf(stderr, "%s: warning - multiple assignment of variable '%s'\n", + if (!nowarn) + fprintf(stderr, + "%s: warning - multiple assignment of variable '%s'\n", progname, vp->name); do vp->value += strlen(vp->value)+1; @@ -460,12 +473,12 @@ register VARIABLE *vp; } -unsigned long +time_t checklast(fnames) /* check files and find most recent */ register char *fnames; { char thisfile[MAXPATH]; - unsigned long thisdate, lastdate = 0; + time_t thisdate, lastdate = 0; register char *cp; if (fnames == NULL) @@ -513,7 +526,7 @@ int pred; checkfiles() /* check for existence and modified times */ { - unsigned long objdate; + time_t objdate; if (!vdef(OCTREE)) { if ((vval(OCTREE) = bmalloc(strlen(radname)+5)) == NULL) @@ -636,16 +649,41 @@ setdefaults() /* set default values for unassigned v vval(VARIABILITY) = "L"; vdef(VARIABILITY)++; } + if (!vdef(RAWSAVE)) { + vval(RAWSAVE) = "F"; + vdef(RAWSAVE)++; + } } printvals() /* print variable values */ { - register int i, j; + int i, j, clipline; + register char *cp; + register int k; - for (i = 0; i < NVARS; i++) - for (j = 0; j < vdef(i); j++) - printf("%s= %s\n", vnam(i), nvalue(vv+i, j)); + for (i = 0; i < NVARS; i++) /* print each variable */ + for (j = 0; j < vdef(i); j++) { /* print each assignment */ + fputs(vnam(i), stdout); + fputs("= ", stdout); + k = clipline = ( vv[i].fixval == catvalues ? 64 : 320 ) + - strlen(vnam(i)) ; + cp = nvalue(vv+i, j); + while (*cp) { + putchar(*cp++); + if (--k <= 0) { /* line too long */ + while (*cp && !isspace(*cp)) + putchar(*cp++); /* finish this word */ + if (*cp) { /* start new line */ + putchar('\n'); + fputs(vnam(i), stdout); + putchar('='); + k = clipline; + } + } + } + putchar('\n'); + } fflush(stdout); } @@ -657,22 +695,28 @@ oconv() /* run oconv and mkillum if necessary */ oconvopts(ocopts); /* get options */ if (octreedate < scenedate) { /* check date on original octree */ - /* build command */ - if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s %s %s > %s", ocopts, - vval(MATERIAL), vval(SCENE), vval(OCTREE)); - else - sprintf(combuf, "oconv%s %s > %s", ocopts, - vval(SCENE), vval(OCTREE)); - - if (runcom(combuf)) { /* run it */ - fprintf(stderr, + if (touchonly && octreedate) + touch(vval(OCTREE)); + else { /* build command */ + if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vval(MATERIAL), vval(SCENE), + vval(OCTREE)); + else + sprintf(combuf, "oconv%s %s > %s", ocopts, + vval(SCENE), vval(OCTREE)); + + if (runcom(combuf)) { /* run it */ + fprintf(stderr, "%s: error generating octree\n\t%s removed\n", - progname, vval(OCTREE)); - unlink(vval(OCTREE)); - exit(1); + progname, vval(OCTREE)); + unlink(vval(OCTREE)); + exit(1); + } } - octreedate = time(0); + octreedate = time((time_t *)NULL); + if (octreedate < scenedate) /* in case clock is off */ + octreedate = scenedate; } if (oct1name == vval(OCTREE)) /* no mkillum? */ oct1date = octreedate > matdate ? octreedate : matdate; @@ -681,53 +725,67 @@ oconv() /* run oconv and mkillum if necessary */ return; /* make octree0 */ if (oct0date < scenedate | oct0date < illumdate) { - /* build command */ + if (touchonly && oct0date) + touch(oct0name); + else { /* build command */ + if (octreedate) + sprintf(combuf, "oconv%s -i %s %s > %s", ocopts, + vval(OCTREE), vval(ILLUM), oct0name); + else if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vval(MATERIAL), vval(ILLUM), oct0name); + else + sprintf(combuf, "oconv%s %s > %s", ocopts, + vval(ILLUM), oct0name); + if (runcom(combuf)) { /* run it */ + fprintf(stderr, + "%s: error generating octree\n\t%s removed\n", + progname, oct0name); + unlink(oct0name); + exit(1); + } + } + oct0date = time((time_t *)NULL); + if (oct0date < octreedate) /* in case clock is off */ + oct0date = octreedate; + if (oct0date < illumdate) /* ditto */ + oct0date = illumdate; + } + if (touchonly && oct1date) + touch(oct1name); + else { + mkillumopts(mkopts); /* build mkillum command */ + mktemp(illumtmp); + sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts, + oct0name, vval(ILLUM), illumtmp); + if (runcom(combuf)) { /* run it */ + fprintf(stderr, "%s: error running mkillum\n", + progname); + unlink(illumtmp); + exit(1); + } + /* make octree1 (frozen) */ if (octreedate) - sprintf(combuf, "oconv%s -i %s %s > %s", ocopts, - vval(OCTREE), vval(ILLUM), oct0name); + sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts, + vval(OCTREE), illumtmp, oct1name); else if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s %s %s > %s", ocopts, - vval(MATERIAL), vval(ILLUM), oct0name); + sprintf(combuf, "oconv%s -f %s %s > %s", ocopts, + vval(MATERIAL), illumtmp, oct1name); else - sprintf(combuf, "oconv%s %s > %s", ocopts, - vval(ILLUM), oct0name); + sprintf(combuf, "oconv%s -f %s > %s", ocopts, + illumtmp, oct1name); if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error generating octree\n\t%s removed\n", - progname, oct0name); - unlink(oct0name); + progname, oct1name); + unlink(oct1name); exit(1); } - oct0date = time(0); + rmfile(illumtmp); } - mkillumopts(mkopts); /* build mkillum command */ - mktemp(illumtmp); - sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts, - oct0name, vval(ILLUM), illumtmp); - if (runcom(combuf)) { /* run it */ - fprintf(stderr, "%s: error running mkillum\n", progname); - unlink(illumtmp); - exit(1); - } - /* make octree1 (frozen) */ - if (octreedate) - sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts, - vval(OCTREE), illumtmp, oct1name); - else if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s -f %s %s > %s", ocopts, - vval(MATERIAL), illumtmp, oct1name); - else - sprintf(combuf, "oconv%s -f %s > %s", ocopts, - illumtmp, oct1name); - if (runcom(combuf)) { /* run it */ - fprintf(stderr, - "%s: error generating octree\n\t%s removed\n", - progname, oct1name); - unlink(oct1name); - exit(1); - } - oct1date = time(0); - rmfile(illumtmp); + oct1date = time((time_t *)NULL); + if (oct1date < oct0date) /* in case clock is off */ + oct1date = oct0date; } @@ -766,14 +824,17 @@ register char *mo; checkambfile() /* check date on ambient file */ { - unsigned long afdate; + time_t afdate; if (!vdef(AMBFILE)) return; if (!(afdate = fdate(vval(AMBFILE)))) return; if (oct1date > afdate) - rmfile(vval(AMBFILE)); + if (touchonly) + touch(vval(AMBFILE)); + else + rmfile(vval(AMBFILE)); } @@ -793,53 +854,60 @@ ambval() /* compute ambient value */ } -renderopts(op) /* set rendering options */ -char *op; +renderopts(op, po) /* set rendering options */ +char *op, *po; { switch(vscale(QUALITY)) { case LOW: - lowqopts(op); + lowqopts(op, po); break; case MEDIUM: - medqopts(op); + medqopts(op, po); break; case HIGH: - lowqopts(op); + hiqopts(op, po); break; } } -lowqopts(op) /* low quality rendering options */ +lowqopts(op, po) /* low quality rendering options */ register char *op; +char *po; { double d, org[3], siz[3]; *op = '\0'; + *po = '\0'; if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) badvalue(ZONE); siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY) + badvalue(ZONE); getoctcube(org, &d); d *= 3./(siz[0]+siz[1]+siz[2]); switch (vscale(DETAIL)) { case LOW: - op = addarg(op, "-ps 16 -dp 64"); + po = addarg(po, "-ps 16"); + op = addarg(op, "-dp 64"); sprintf(op, " -ar %d", (int)(4*d)); op += strlen(op); break; case MEDIUM: - op = addarg(op, "-ps 8 -dp 128"); + po = addarg(po, "-ps 8"); + op = addarg(op, "-dp 128"); sprintf(op, " -ar %d", (int)(8*d)); op += strlen(op); break; case HIGH: - op = addarg(op, "-ps 4 -dp 256"); + po = addarg(po, "-ps 4"); + op = addarg(op, "-dp 256"); sprintf(op, " -ar %d", (int)(16*d)); op += strlen(op); break; } - op = addarg(op, "-pt .16"); + po = addarg(po, "-pt .16"); if (vbool(PENUMBRAS)) op = addarg(op, "-ds .4"); else @@ -871,39 +939,43 @@ register char *op; } -medqopts(op) /* medium quality rendering options */ +medqopts(op, po) /* medium quality rendering options */ register char *op; +char *po; { double d, org[3], siz[3]; *op = '\0'; + *po = '\0'; if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) badvalue(ZONE); siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY) + badvalue(ZONE); getoctcube(org, &d); d *= 3./(siz[0]+siz[1]+siz[2]); switch (vscale(DETAIL)) { case LOW: - op = addarg(op, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8"); + po = addarg(po, vbool(PENUMBRAS) ? "-ps 4" : "-ps 8"); op = addarg(op, "-dp 256"); sprintf(op, " -ar %d", (int)(8*d)); op += strlen(op); break; case MEDIUM: - op = addarg(op, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6"); + po = addarg(po, vbool(PENUMBRAS) ? "-ps 3" : "-ps 6"); op = addarg(op, "-dp 512"); sprintf(op, " -ar %d", (int)(16*d)); op += strlen(op); break; case HIGH: - op = addarg(op, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4"); + po = addarg(po, vbool(PENUMBRAS) ? "-ps 2" : "-ps 4"); op = addarg(op, "-dp 1024"); sprintf(op, " -ar %d", (int)(32*d)); op += strlen(op); break; } - op = addarg(op, "-pt .08"); + po = addarg(po, "-pt .08"); if (vbool(PENUMBRAS)) op = addarg(op, "-ds .2 -dj .5"); else @@ -938,41 +1010,45 @@ register char *op; } -hiqopts(op) /* high quality rendering options */ +hiqopts(op, po) /* high quality rendering options */ register char *op; +char *po; { double d, org[3], siz[3]; *op = '\0'; + *po = '\0'; if (sscanf(vval(ZONE), "%*s %lf %lf %lf %lf %lf %lf", &org[0], &siz[0], &org[1], &siz[1], &org[2], &siz[2]) != 6) badvalue(ZONE); siz[0] -= org[0]; siz[1] -= org[1]; siz[2] -= org[2]; + if (siz[0] <= FTINY | siz[1] <= FTINY | siz[2] <= FTINY) + badvalue(ZONE); getoctcube(org, &d); d *= 3./(siz[0]+siz[1]+siz[2]); switch (vscale(DETAIL)) { case LOW: - op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8"); + po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 8"); op = addarg(op, "-dp 1024"); sprintf(op, " -ar %d", (int)(16*d)); op += strlen(op); break; case MEDIUM: - op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5"); + po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 5"); op = addarg(op, "-dp 2048"); sprintf(op, " -ar %d", (int)(32*d)); op += strlen(op); break; case HIGH: - op = addarg(op, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3"); + po = addarg(po, vbool(PENUMBRAS) ? "-ps 1" : "-ps 3"); op = addarg(op, "-dp 4096"); sprintf(op, " -ar %d", (int)(64*d)); op += strlen(op); break; } - op = addarg(op, "-pt .04"); + po = addarg(po, "-pt .04"); if (vbool(PENUMBRAS)) - op = addarg(op, "-ds .1 -dj .7"); + op = addarg(op, "-ds .1 -dj .65"); else op = addarg(op, "-ds .2"); op = addarg(op, "-dt .05 -dc .75 -dr 3 -sj 1 -st .01"); @@ -1120,6 +1196,8 @@ register char *vs; badvalue(ZONE); for (i = 0; i < 3; i++) { dim[i] -= cent[i]; + if (dim[i] <= FTINY) + badvalue(ZONE); cent[i] += .5*dim[i]; } mult = vlet(ZONE)=='E' ? 2. : .45 ; @@ -1283,17 +1361,17 @@ register char *vopts; } -rview(opts) /* run rview with first view */ -char *opts; +rview(opts, po) /* run rview with first view */ +char *opts, *po; { char *vw; char combuf[512]; /* build command */ - if ((vw = getview(0, NULL)) == NULL) + if (touchonly || (vw = getview(0, NULL)) == NULL) return; if (sayview) printview(vw); - sprintf(combuf, "rview %s%s -R %s ", vw, opts, rifname); + sprintf(combuf, "rview %s%s%s -R %s ", vw, po, opts, rifname); if (rvdevice != NULL) sprintf(combuf+strlen(combuf), "-o %s ", rvdevice); if (vdef(EXPOSURE)) @@ -1306,18 +1384,29 @@ char *opts; } -rpict(opts) /* run rpict and pfilt for each view */ -char *opts; +rpict(opts, po) /* run rpict and pfilt for each view */ +char *opts, *po; { char combuf[1024]; char rawfile[MAXPATH], picfile[MAXPATH], rep[MAXPATH+16], res[32]; char pfopts[128]; char vs[32], *vw; int vn, mult; + time_t rfdt, pfdt; /* get pfilt options */ pfiltopts(pfopts); /* get resolution, reporting */ - mult = vscale(QUALITY)+1; + switch (vscale(QUALITY)) { + case LOW: + mult = 1; + break; + case MEDIUM: + mult = 2; + break; + case HIGH: + mult = 3; + break; + } { int xres, yres; double aspect; @@ -1353,13 +1442,24 @@ char *opts; sprintf(vs, "%d", vn); sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs); /* check date on picture */ - if (fdate(picfile) >= oct1date) + pfdt = fdate(picfile); + if (pfdt >= oct1date) continue; - /* build rpict command */ + /* get raw file name */ sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs); - if (fdate(rawfile) >= oct1date) /* recover */ - sprintf(combuf, "rpict%s%s -ro %s %s", - rep, opts, rawfile, oct1name); + rfdt = fdate(rawfile); + if (touchonly) { /* update times only */ + if (rfdt) { + if (rfdt < oct1date) + touch(rawfile); + } else if (pfdt && pfdt < oct1date) + touch(picfile); + continue; + } + /* build rpict command */ + if (rfdt >= oct1date) /* recover */ + sprintf(combuf, "rpict%s%s%s -ro %s %s", + rep, po, opts, rawfile, oct1name); else { if (overture) { /* run overture calculation */ sprintf(combuf, @@ -1376,8 +1476,8 @@ char *opts; rmfile(overfile); #endif } - sprintf(combuf, "rpict%s %s %s%s %s > %s", - rep, vw, res, opts, + sprintf(combuf, "rpict%s %s %s%s%s %s > %s", + rep, vw, res, po, opts, oct1name, rawfile); } if (runcom(combuf)) { /* run rpict */ @@ -1399,12 +1499,32 @@ char *opts; unlink(picfile); exit(1); } - /* remove raw file */ - rmfile(rawfile); + /* remove/rename raw file */ + if (vbool(RAWSAVE)) { + sprintf(combuf, "%s_%s.rwp", vval(PICTURE), vs); + mvfile(rawfile, combuf); + } else + rmfile(rawfile); } } +touch(fn) /* update a file */ +char *fn; +{ + if (!silent) + printf("\ttouch %s\n", fn); + if (noaction) + return(0); +#ifdef notused + if (access(fn, F_OK) == -1) /* create it */ + if (close(open(fn, O_WRONLY|O_CREAT, 0666)) == -1) + return(-1); +#endif + return(setfdate(fn, time((time_t *)NULL))); +} + + runcom(cs) /* run command */ char *cs; { @@ -1429,6 +1549,21 @@ char *fn; if (noaction) return(0); return(unlink(fn)); +} + + +mvfile(fold, fnew) /* move a file */ +char *fold, *fnew; +{ + if (!silent) +#ifdef MSDOS + printf("\trename %s %s\n", fold, fnew); +#else + printf("\tmv %s %s\n", fold, fnew); +#endif + if (noaction) + return(0); + return(rename(fold, fnew)); }
