--- ray/src/util/rad.c 1994/04/21 12:22:44 2.40 +++ ray/src/util/rad.c 1994/10/24 13:49:16 2.41 @@ -117,6 +117,7 @@ time_t oct1date; /* date of post-mkillum octree (>= m int nowarn = 0; /* no warnings */ int explicate = 0; /* explicate variables */ int silent = 0; /* do work silently */ +int touchonly = 0; /* touch files only */ int noaction = 0; /* don't do anything */ int sayview = 0; /* print view out */ char *rvdevice = NULL; /* rview output device */ @@ -148,6 +149,9 @@ char *argv[]; case 'n': noaction++; break; + case 't': + touchonly++; + break; case 'e': explicate++; break; @@ -199,7 +203,7 @@ char *argv[]; exit(0); userr: fprintf(stderr, - "Usage: %s [-s][-n][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", +"Usage: %s [-s][-n][-t][-e][-V][-v view][-o dev] rfile [VAR=value ..]\n", progname); exit(1); } @@ -685,20 +689,24 @@ oconv() /* run oconv and mkillum if necessary */ oconvopts(ocopts); /* get options */ if (octreedate < scenedate) { /* check date on original octree */ - /* build command */ - if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s %s %s > %s", ocopts, - vval(MATERIAL), vval(SCENE), vval(OCTREE)); - else - sprintf(combuf, "oconv%s %s > %s", ocopts, - vval(SCENE), vval(OCTREE)); - - if (runcom(combuf)) { /* run it */ - fprintf(stderr, + if (touchonly && octreedate) + touch(vval(OCTREE)); + else { /* build command */ + if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vval(MATERIAL), vval(SCENE), + vval(OCTREE)); + else + sprintf(combuf, "oconv%s %s > %s", ocopts, + vval(SCENE), vval(OCTREE)); + + if (runcom(combuf)) { /* run it */ + fprintf(stderr, "%s: error generating octree\n\t%s removed\n", - progname, vval(OCTREE)); - unlink(vval(OCTREE)); - exit(1); + progname, vval(OCTREE)); + unlink(vval(OCTREE)); + exit(1); + } } octreedate = time((time_t *)NULL); if (octreedate < scenedate) /* in case clock is off */ @@ -711,59 +719,67 @@ oconv() /* run oconv and mkillum if necessary */ return; /* make octree0 */ if (oct0date < scenedate | oct0date < illumdate) { - /* build command */ + if (touchonly && oct0date) + touch(oct0name); + else { /* build command */ + if (octreedate) + sprintf(combuf, "oconv%s -i %s %s > %s", ocopts, + vval(OCTREE), vval(ILLUM), oct0name); + else if (vdef(MATERIAL)) + sprintf(combuf, "oconv%s %s %s > %s", ocopts, + vval(MATERIAL), vval(ILLUM), oct0name); + else + sprintf(combuf, "oconv%s %s > %s", ocopts, + vval(ILLUM), oct0name); + if (runcom(combuf)) { /* run it */ + fprintf(stderr, + "%s: error generating octree\n\t%s removed\n", + progname, oct0name); + unlink(oct0name); + exit(1); + } + } + oct0date = time((time_t *)NULL); + if (oct0date < octreedate) /* in case clock is off */ + oct0date = octreedate; + if (oct0date < illumdate) /* ditto */ + oct0date = illumdate; + } + if (touchonly && oct1date) + touch(oct1name); + else { + mkillumopts(mkopts); /* build mkillum command */ + mktemp(illumtmp); + sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts, + oct0name, vval(ILLUM), illumtmp); + if (runcom(combuf)) { /* run it */ + fprintf(stderr, "%s: error running mkillum\n", + progname); + unlink(illumtmp); + exit(1); + } + /* make octree1 (frozen) */ if (octreedate) - sprintf(combuf, "oconv%s -i %s %s > %s", ocopts, - vval(OCTREE), vval(ILLUM), oct0name); + sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts, + vval(OCTREE), illumtmp, oct1name); else if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s %s %s > %s", ocopts, - vval(MATERIAL), vval(ILLUM), oct0name); + sprintf(combuf, "oconv%s -f %s %s > %s", ocopts, + vval(MATERIAL), illumtmp, oct1name); else - sprintf(combuf, "oconv%s %s > %s", ocopts, - vval(ILLUM), oct0name); + sprintf(combuf, "oconv%s -f %s > %s", ocopts, + illumtmp, oct1name); if (runcom(combuf)) { /* run it */ fprintf(stderr, "%s: error generating octree\n\t%s removed\n", - progname, oct0name); - unlink(oct0name); + progname, oct1name); + unlink(oct1name); exit(1); } - oct0date = time((time_t *)NULL); - if (oct0date < octreedate) /* in case clock is off */ - oct0date = octreedate; - if (oct0date < illumdate) /* ditto */ - oct0date = illumdate; + rmfile(illumtmp); } - mkillumopts(mkopts); /* build mkillum command */ - mktemp(illumtmp); - sprintf(combuf, "mkillum%s %s \"<\" %s > %s", mkopts, - oct0name, vval(ILLUM), illumtmp); - if (runcom(combuf)) { /* run it */ - fprintf(stderr, "%s: error running mkillum\n", progname); - unlink(illumtmp); - exit(1); - } - /* make octree1 (frozen) */ - if (octreedate) - sprintf(combuf, "oconv%s -f -i %s %s > %s", ocopts, - vval(OCTREE), illumtmp, oct1name); - else if (vdef(MATERIAL)) - sprintf(combuf, "oconv%s -f %s %s > %s", ocopts, - vval(MATERIAL), illumtmp, oct1name); - else - sprintf(combuf, "oconv%s -f %s > %s", ocopts, - illumtmp, oct1name); - if (runcom(combuf)) { /* run it */ - fprintf(stderr, - "%s: error generating octree\n\t%s removed\n", - progname, oct1name); - unlink(oct1name); - exit(1); - } oct1date = time((time_t *)NULL); if (oct1date < oct0date) /* in case clock is off */ oct1date = oct0date; - rmfile(illumtmp); } @@ -809,7 +825,10 @@ checkambfile() /* check date on ambient file */ if (!(afdate = fdate(vval(AMBFILE)))) return; if (oct1date > afdate) - rmfile(vval(AMBFILE)); + if (touchonly) + touch(vval(AMBFILE)); + else + rmfile(vval(AMBFILE)); } @@ -1342,7 +1361,7 @@ char *opts, *po; char *vw; char combuf[512]; /* build command */ - if ((vw = getview(0, NULL)) == NULL) + if (touchonly || (vw = getview(0, NULL)) == NULL) return; if (sayview) printview(vw); @@ -1367,6 +1386,7 @@ char *opts, *po; char pfopts[128]; char vs[32], *vw; int vn, mult; + time_t rfdt, pfdt; /* get pfilt options */ pfiltopts(pfopts); /* get resolution, reporting */ @@ -1416,11 +1436,22 @@ char *opts, *po; sprintf(vs, "%d", vn); sprintf(picfile, "%s_%s.pic", vval(PICTURE), vs); /* check date on picture */ - if (fdate(picfile) >= oct1date) + pfdt = fdate(picfile); + if (pfdt >= oct1date) continue; - /* build rpict command */ + /* get raw file name */ sprintf(rawfile, "%s_%s.raw", vval(PICTURE), vs); - if (fdate(rawfile) >= oct1date) /* recover */ + rfdt = fdate(rawfile); + if (touchonly) { /* update times only */ + if (rfdt) { + if (rfdt < oct1date) + touch(rawfile); + } else if (pfdt && pfdt < oct1date) + touch(picfile); + continue; + } + /* build rpict command */ + if (rfdt >= oct1date) /* recover */ sprintf(combuf, "rpict%s%s%s -ro %s %s", rep, po, opts, rawfile, oct1name); else { @@ -1465,6 +1496,22 @@ char *opts, *po; /* remove raw file */ rmfile(rawfile); } +} + + +touch(fn) /* update a file */ +char *fn; +{ + if (!silent) + printf("\ttouch %s\n", fn); + if (noaction) + return(0); +#ifdef notused + if (access(fn, F_OK) == -1) /* create it */ + if (close(open(fn, O_WRONLY|O_CREAT, 0666)) == -1) + return(-1); +#endif + return(setfdate(fn, time((time_t *)NULL))); }
